  4. AVM tr-064 Adapter funktioniert nicht
avm tr-064 adapter
35 Beiträge 6 Kommentatoren 3.2k Aufrufe 5 Beobachtet
  • Hideki3001H Hideki3001
    @foxriver76 said in AVM tr-064 Adapter funktioniert nicht:
    https://github.com/iobroker-community-adapters/ioBroker.tr-064-community
    community Version funktioniert nicht
    host.iobroker	2019-12-12 15:00:37.649	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2019-12-12 15:00:37.649	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    host.iobroker	2019-12-12 15:00:37.648	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    host.iobroker	2019-12-12 15:00:37.647	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    host.iobroker	2019-12-12 15:00:37.647	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.iobroker	2019-12-12 15:00:37.647	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.iobroker	2019-12-12 15:00:37.646	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.iobroker	2019-12-12 15:00:37.646	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.iobroker	2019-12-12 15:00:37.645	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.iobroker	2019-12-12 15:00:37.645	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:15:20)
    host.iobroker	2019-12-12 15:00:37.644	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    host.iobroker	2019-12-12 15:00:37.644	error	Caught by controller[0]: TypeError: fns.adapter is not a function
    host.iobroker	2019-12-12 15:00:37.644	error	Caught by controller[0]: ^
    host.iobroker	2019-12-12 15:00:37.643	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
    host.iobroker	2019-12-12 15:00:37.642	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    Jan1
    @Hideki3001
    deinstalliere vorher mal den alten
    • Hideki3001H Offline
      Hideki3001H Offline
      Hideki3001
      hab ich gemacht 😐
      HomoranH J 2 Antworten Letzte Antwort
        hab ich gemacht 😐
        @Hideki3001 und was steht zeitlich vor dem "Caught" die eigentliche Fehlermeldung fehlt.
        Bitte das log in Code-Tags setzen <>
          hab ich gemacht 😐
          Jan1
          @Hideki3001
          Dann schau mal ob im Module Ordner nicht noch was liegt von den TR-064 Adaptern. Der neue will auch das soef und das will er nur, wenn der alte noch rumspuckt.
          Kannst auch mal neu booten nach der Deinstallation.
            apollon77A Online
            apollon77A Online
            @Hideki3001 sagte in AVM tr-064 Adapter funktioniert nicht:
            Da sist der alte ... nicht community Version ...
              Hideki3001H Offline
              Hideki3001
              ich hab die Version 0.4.14 installiert
              vorher hatte ich 1.2.0 und ich habe den Adapter komplett gelöscht
                Jan1
                @Hideki3001
                1.2.0 passt.
                Alles noch mal deinstallieren und IOBroker neu starten, alternativ das ganze System.
                Nach der Installation über Github die Instanz noch manuell installieren und es sollte laufen
                  Hideki3001H Offline
                  Hideki3001
                  hab die Virtual Machine neu gestartet und 1.2.0 installiert 😬
                  ist grün aber 😔
                  tr-064-community.0	2019-12-12 15:31:54.515	error	(1848) updateAll:exists
                  tr-064-community.0	2019-12-12 15:31:43.264	error	(1848) updateAll:exists
                  tr-064-community.0	2019-12-12 15:31:31.986	error	(1848) updateAll:exists
                  tr-064-community.0	2019-12-12 15:31:20.743	error	(1848) updateAll:exists
                  tr-064-community.0	2019-12-12 15:31:09.484	error	(1848) updateAll:exists
                    ist grün aber 😔
                    Jan1
                    @Hideki3001
                    OK, ich war nur für grün zuständig 😊
                      Hideki3001H Offline
                      Hideki3001
                      ok 🙃
                        Hideki3001H Offline
                        Hideki3001
                        Fehlermeldung 1848 hat sich erledigt 😬
                        danke für die schnelle Hilfe
                          Jan1
                          @Hideki3001
                          und was war es?
                            Hideki3001H Offline
                            Hideki3001
                            hab den Adapter neu gestartet
                              Jan1
                              @Hideki3001
                              Dann schreib es Dir gleich hinter die Ohren, wenn von Github was installiert wird, die Instanz manuell anlegen und wenn schon vorhanden den Neustart nicht vergessen.
                                Hideki3001H Offline
                                Hideki3001
                                ok mache ich 😬
                                  Hideki3001H Offline
                                  Hideki3001
                                  bei mir taucht immer wieder ein zweites Gerät auf !
                                  laut fritz-box gib es aber nur eins mit der IP Adresse🙄
                                  das licht geht zwar aus ,wenn ich abwesend bin
                                  komme ich nach Hause geht das Licht an und nach 15 Minuten wieder aus 😞
                                  entferne ich das zweite Gerät aus den Objekten in iobroker funktioniert wieder alles
                                    apollon77A Online
                                    apollon77A Online
                                    @Hideki3001 Wie sieht denn die Adapter Konfig aus? An sich definierst DU dort welche IPs und Namen du hast ,...
                                      Hideki3001H Offline
                                      Hideki3001
                                      im Adapter steht immer nur eine IP-Adresse unter Geräten ,aber unter Objekten taucht immer wieder das zweite Smartphone auf 😞
