  4. History überarbeitet
149 Beiträge 18 Kommentatoren 46.9k Aufrufe
  • eric2905E Offline
    eric2905E Offline
    eric2905
    So, update ist durch.
    Direkt nach dem Start kamen nochmal einige Meldungen :
    ` > sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rega.0.41482
    sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rpc.0.xxxxxxxxxx.1.POWER
    sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rpc.0.xxxxxxxxxx.1.TEMPERATURE
    sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rpc.0.xxxxxxxxxx.1.HUMIDITY
    sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of system.host.cubietruck.load
    sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of system.host.cubietruck.mem
    sql.0 2015-12-06 18:39:08 info sql.0 Connected to sqlite
    sql.0 2015-12-06 18:39:07 info sql.0 starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.sql
    host-cubietruck 2015-12-06 18:38:59 info instance system.adapter.sql.0 started with pid 5980
    host-cubietruck 2015-12-06 18:38:56 info instance system.adapter.sql.0 terminated with code 0 (OK)
    sql-0 2015-12-06 18:38:56 info terminating
    host-cubietruck 2015-12-06 18:38:56 info stopInstance system.adapter.sql.0 killing pid 5965
    host-cubietruck 2015-12-06 18:38:56 info object change system.adapter.sql.0
    sql-0 2015-12-06 18:38:45 error Cannot delete DELETE FROM ts_number WHERE id=21 AND ts < 1449337080;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-06 18:38:40 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1449423508000, 20, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-06 18:38:20 warn Cannot get index of 'hm-rpc.0.IEQ0150728.1.TEMPERATURE': Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-06 18:38:20 error Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.IEQ0150728.1.TEMPERATURE';: Error: SQLITE_BUSY: database is locked
    host-cubietruck 2015-12-06 18:38:17 info Update repository 'default' under 'conf/sources-dist.json'
    sql-0 2015-12-06 18:38:00 info Connected to sqlite
    sql-0 2015-12-06 18:38:00 info enabled logging of hm-rega.0.41482
    sql-0 2015-12-06 18:38:00 info enabled logging of hm-rpc.0.xxxxxxxxxx.1.POWER
    sql-0 2015-12-06 18:38:00 info enabled logging of system.host.cubietruck.load
    sql-0 2015-12-06 18:38:00 info enabled logging of system.host.cubietruck.mem
    sql-0 2015-12-06 18:38:00 info starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.sql
    host-cubietruck 2015-12-06 18:37:51 info instance system.adapter.sql.0 started with pid 5965
    host-cubietruck 2015-12-06 18:37:51 info 'system.adapter.sql.0' enabled
    host-cubietruck 2015-12-06 18:37:51 info object change system.adapter.sql.0 `
    und kurz darauf wieder diese Meldungen:
    ` > sql.0 2015-12-06 18:44:41 warn sql.0 Cannot get index of 'hm-rpc.0.xxxxxxxxxx.3.TEMPERATURE': Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:44:41 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.LEQ0773872.3.TEMPERATURE';: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:42:49 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=11 AND ts < 1449337320;: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:42:48 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=8 AND ts < 1449337320;: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:42:34 warn sql.0 Cannot get index of 'hm-rpc.0.xxxxxxxxxx.3.TEMPERATURE': Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:42:34 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.LEQ0773872.3.TEMPERATURE';: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:41:40 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=17 AND ts < 1449337261;: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:40:43 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=14 AND ts < 1449337200;: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:40:42 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=6 AND ts < 1449337201;: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:40:41 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=23 AND ts < 1449337201;: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:40:25 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=33 AND ts < 1449337201;: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:40:13 warn sql.0 Cannot get index of 'hm-rpc.0.xxxxxxxxxx.3.TEMPERATURE': Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:40:13 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.xxxxxxxxxx.3.TEMPERATURE';: Error: SQLITE_BUSY: database is locked
    sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rpc.0.xxxxxxxxxx.1.TEMPERATURE `
    Irgendwas klemmt da noch.
    Es läuft auch sonst nichts mit SQL auf dem Cubietruck - der macht nichts anderes als ioBroker.
    Gruß,
    Eric
    PS:
    Wenn ich versuche, Flot zu installieren, meckert die Installation am Ende, das die Version des History-Adapters >= 0.2.0 sein soll (error 30).
    Ich habe die Version 0.1.3 drauf.
    Hab ich irgendwas überlesen?
      starfish
      @Bluefox:
      Kannst du mit andren Clients dadrauf zugegriffen?
      Ich habe so verstanden, dass MySQL auf dem anderen Rechner läuft. Kannst du vom ioBroker Rechner auf MySQL mit normalem Client zugreifen? `
      ja, kann ich (mit mysql -u xxxx -h 192.168.0.61 -p) , allerdings habe ich jetzt auf dem iobroker testserver ein eigener mysql-server eingerichtet, über localhost müsste es eigentlich problemlos laufen.
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        Habe das Update durchgeführt.
        ` > sql.0 Cannot delete DELETE FROM ts_number WHERE id=172 AND ts < 1417897381;: Error: SQLITE_BUSY: database is locked
        sql.0 2015-12-06 21:23:23 error sql.0 Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(112, 1449433400000, 0, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
        sql.0 2015-12-06 21:23:23 error sql.0 Cannot delete DELETE FROM ts_bool WHERE id=111 AND ts < 1417897380;: Error: SQLITE_BUSY: database is locked
        sql.0 2015-12-06 21:23:23 error sql.0 Cannot delete DELETE FROM ts_bool WHERE id=110 AND ts < 1417897380;: Error: SQLITE_BUSY: database is locked
        sql.0 2015-12-06 21:23:21 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='ping.0.raspberrypi.192_168_1_11';: Error: SQLITE_BUSY: database is locked `
        MfG
        Sissi
        1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
        • ThisoftT Offline
          ThisoftT Offline
          Thisoft
          ich hatte jetzt auch einmal den Zugriffsfehler:
          ` > sql.0 2015-12-06 21:23:05 error sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(10, 1449433373000, 271.35, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql.0 2015-12-06 21:23:04 debug sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1449433373000, 28, 1, 1, 0); `
          Und ich denke, man sieht hier im Vergleich mit dem unmittelbar zuvor (erfolgreich) ausgeführten Statement dass der Grund dafür ist, dass der zweite Datensatz hier mit einem bereits existierenden Timestamp eingefügt werden soll. Die Fehlermeldung "Database locked" ist da natürlich ziemlich irreführend ;)
          @Bluefox: Ich hab's mir zwar im Code mal angeschaut wie Du den Timestamp generierst, aber da sind meine JS-Kenntnisse noch zu rudimentär um herauszufinden warum der doppelt generiert wird :oops:
          22 HM-Geräte; PivCCU2 auf RasPi
          ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
          • sissiwupS Offline
            sissiwupS Offline
            sissiwup
            Kannst du den .timeout auf 11000 setzen?
            Der Pi kann scheinbar nur Sekunden Sleeps und könnte damit ein Problem haben.
            MfG
            Sissi
            • sissiwupS Offline
              sissiwupS Offline
              sissiwup
              @Thisoft:
              @Bluefox: Ich hab's mir zwar im Code mal angeschaut wie Du den Timestamp generierst, aber da sind meine JS-Kenntnisse noch zu rudimentär um herauszufinden warum der doppelt generiert wird :oops: `
              Kann es daran liegen, dass der Pi keine Millisekunden liefert?
              MfG
              Sissi
              • eric2905E Offline
                eric2905E Offline
                eric2905
                @sissiwup:
                Kann es daran liegen, dass der Pi keine Millisekunden liefert? `
                Bei mir läuft ioBroker nicht auf einem Raspberry Pi, sondern auf einem Cubietruck.
                Oder meinst Du grundsätzlich die ARM-Plattform?
                Gruß,
                Eric
                • eric2905E Offline
                  eric2905E Offline
                  eric2905
                  @sissiwup:
                  Kannst du den .timeout auf 11000 setzen? `
                  Hab den Wert beim SQL-Adapter geändert - Meldungen ("cannot delete" und "cannot insert") kommen weiterhin.
                  Oder meintest Du am jeweiligen Objekt selber?
                  Gruß,
                  Eric
                  • ThisoftT Offline
                    ThisoftT Offline
                    Thisoft
                    Ja, es liegt offensichtlich an den fehlenden Millisekunden. Aber nicht nur auf dem Pi - ich arbeite mit Windows.
                    Ich habe mich aber jetzt noch mal in den Code reingekniet und empfehle Dir folgendes zu testen - wenn Du Dir's zutraust.
                    Und zwar musst Du in der Datei "..\iobroker\node_modules\iobroker.sql\main.js" die Zeile 552:
                    state.ts = parseInt(state.ts, 10) * 1000 + (parseInt(state.ms, 10) || 0);
                    durch die folgende ersetzen:
                        state.ts = parseInt(Date.now());
                    Dann die Datei speichern und den SQL-Adapter neustarten. Dann dürfte es keine doppelten Timestamps mehr geben (und ich hoffe dass ich damit nichts anderes durcheinanderbringe - aber wir sind ja hier noch in der Beta ;) )
                    Gruß Thilo
                    • eric2905E Offline
                      eric2905E Offline
                      eric2905
                      Probiere ich morgen früh aus.
                      Gruß,
                      Eric
                      Edit:
                      Nee, bin neugierig - mache es jetzt
                      • sissiwupS Offline
                        sissiwupS Offline
                        sissiwup
                        Verbindung an MySQL klappt bei mir nur so:
                        MfG
                        Sissi
                        • sissiwupS Offline
                          sissiwupS Offline
                          sissiwup
                          Fehler mit mysql:
                          ` > sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(53, 1449439045000, VD-12, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'VD' in 'field list'
                          sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(50, 1449439045000, W, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'W' in 'field list'
                          sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(48, 1449439045000, Windstille, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Windstille' in 'field list' `
                          MfG
                          Sissi
                          • eric2905E Offline
                            eric2905E Offline
                            eric2905
                            Hat Fehler ausgeworfen:
                            ` > sql.0 2015-12-06 22:59:12 debug inMem message * hm-rega.0.37329
                            sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37325
                            sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37324
                            sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37153
                            sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.36778
                            sql.0 2015-12-06 22:59:11 info sql.0 enabled logging of system.host.cubietruck.load
                            sql.0 2015-12-06 22:59:11 info sql.0 enabled logging of system.host.cubietruck.mem
                            sql.0 2015-12-06 22:59:10 info sql.0 Connected to sqlite
                            sql.0 2015-12-06 22:59:10 debug sql.0 Response: {'errno':1,'code':'SQLITE_ERROR'}
                            sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_bool (id INTEGER, ts INTEGER, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                            sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_string (id INTEGER, ts INTEGER, val TEXT, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                            sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_number (id INTEGER, ts INTEGER, val REAL, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                            sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE datapoints (id INTEGER NOT NULL PRIMARY KEY AUTOINCREMENT,name TEXT,type INTEGER);
                            sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE sources (id INTEGER NOT NULL PRIMARY KEY AUTOINCREMENT, name TEXT);
                            sql.0 2015-12-06 22:59:10 info sql.0 starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.sql
                            cubietruck 2015-12-06 22:59:01 info host.cubietruck instance system.adapter.sql.0 started with pid 7364
                            cubietruck 2015-12-06 22:59:01 info host.cubietruck 'system.adapter.sql.0' enabled
                            cubietruck 2015-12-06 22:59:01 info host.cubietruck object change system.adapter.sql.0 `
                            Bin wieder auf Original zurück.
                            Gruß,
                            Eric
                            • ThisoftT Offline
                              ThisoftT Offline
                              Thisoft
                              @sissiwup: Das ist der gleiche Fehler wie bei uns - bei Dir sogar dreimal der gleiche Timestamp.
                              @eric: Ja, jetzt wo DU's sagst - die hat er bei mir auch geworfen. Sind aber IMO nicht weiter schlimm. Sagt ja bloß aus dass er die bereits existierenden Tabellen in der Db nicht nochmal anlegen kann. Kommen ja auch nur beim Starten des Adapters. Ich lass die Änderung bei mir drin und teste ob der andere Fehler wieder auftaucht. Vielleicht schau ich auch morgen nochmal ob ich dahinterkomme warum jetzt dieser Fehler auftaucht. Wahrscheinlich ist aber bis dahin Bluefox sowieso schneller ;)
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                Eh, bin gerade etwas verwirrt …
                                Seit dem Test habe ich keine Fehler mehr im Log .... alle INSERTs usw. gehen durch .... wie gesagt, bin wieder auf die Original-Version der main.js zurückgegangen (und hab auch den Adapter neu gestartet) ....
                                Gruß,
                                Eric
                                • sissiwupS Offline
                                  sissiwupS Offline
                                  sissiwup
                                  ` > hm-rpc.1 2015-12-07 01:24:54 info hm-rpc.1 xmlrpc -> listDevices 0
                                  sql.0 2015-12-07 01:20:54 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(53, 1449447653333, VD-12, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'VD' in 'field list'
                                  sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(52, 1449447652908, 01:00:01 07.12.2015, 1, 3, 0);: Error: ER_PARSE_ERROR: You have an error in your SQL syntax; c
                                  sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(50, 1449447652664, SW, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'SW' in 'field list'
                                  sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(48, 1449447652486, Windstille, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Windstille' in 'field list'
                                  sql.0 2015-12-07 01:20:38 info sql.0 enabled logging of hm-rpc.0.MEQ0288793.1.STATE `
                                  Hier scheint der String nicht korrekt gequotet zu werden ' fehlen.
                                  MfG
                                  Sissi
                                  • sissiwupS Offline
                                    sissiwupS Offline
                                    sissiwup
                                    MySQL:
                                    MySQL auf ioBroker
                                    apt-get install mysql-server mysql-client
                                    mysql -uroot -p
                                    CREATE USER 'iobroker‘@’%’ IDENTIFIED BY 'iobroker';
                                    GRANT ALL PRIVILEGES ON * . * TO 'iobroker'@'%';
                                    FLUSH PRIVILEGES;
                                    In /etc/mysql
                                    my.cnf: bind auf ip-Adresse umstellen (dann klappt es auch mit den Nachbarn) ;-)
                                    Achtung: iobroker ist so ein "admin". Bei Bedarf weniger Rechte einrichten.
                                    MfG
                                    Sissi
                                    • sissiwupS Offline
                                      sissiwupS Offline
                                      sissiwup
                                      lib/mysql.js anpassen:
                                      exports.insert = function (index, state, from, db) {
                                          if (db === 'ts_string') state.val = "'" + state.val + "'";
                                          return "INSERT INTO iobroker." + db + " (id, ts, val, ack, _from, q) VALUES(" + index + ", " + state.ts + ", " + state.val + ", " + (state.ack ? 1 : 0) + ", " + (from || 0) + ", " + state.q + ");";
                                      Neu ist die Zeile mit dem "if"
                                      MfG
                                      Sissi
                                      • eric2905E Offline
                                        eric2905E Offline
                                        eric2905
                                        Hmmm, mySQL installieren …
                                        Ich denke, ich warte erst mal auf Bluefox - vielleicht hat er ja eine einfache Idee / Lösung.
                                        Gruß,
                                        Eric
                                          starfish
                                          @sissiwup:
                                          filename="Bildschirmfoto 2015-12-06 um 22.56.02.png" index="0">~~ `
                                          das wars, bei mir klappt die Verbindung endlich auch, wer hätte vermutet, dass gar kein Port angegeben werden darf. (vielleicht wird default zusätzlich auch ausgegeben, wenn im Feld was steht?)
