  4. [Vorlage] Script für Sonos-Adapter
vis
163 Beiträge 47 Kommentatoren 59.5k Aufrufe 54 Beobachtet
  • IccubeI Iccube
    @BBTown okay danke
    undefined2019-11-10 12:18:58.577 - info: javascript.0 Stop script script.js.Test.sonos123
    2019-11-10 12:19:00.357 - info: javascript.0 Start javascript script.js.Test.sonos123
    2019-11-10 12:19:00.362 - error: javascript.0 script.js.Test.sonos123 compile failed:
    at script.js.Test.sonos123:92
    2019-11-10 12:19:00.362 - error: javascript.0 const LOG_INFO = true;
    2019-11-10 12:19:00.362 - error: javascript.0 ^
    2019-11-10 12:19:00.362 - error: javascript.0 SyntaxError: Identifier 'LOG_INFO' has already been declared
    2019-11-10 12:19:00.362 - error: javascript.0 at new Script (vm.js:83:7)
    2019-11-10 12:19:00.362 - error: javascript.0 at Object.createScript (vm.js:277:10)
    2019-11-10 12:19:00.362 - error: javascript.0 at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:961:28)
    2019-11-10 12:19:00.362 - error: javascript.0 at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1184:37)
    2019-11-10 12:19:00.362 - error: javascript.0 at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1237:17)
    2019-11-10 12:19:00.362 - error: javascript.0 at Socket.adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:828:17)
    2019-11-10 12:19:00.362 - error: javascript.0 at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    2019-11-10 12:19:00.363 - error: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    2019-11-10 12:19:00.363 - error: javascript.0 at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-11-10 12:19:00.363 - error: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    2019-11-10 12:19:00.363 - error: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    2019-11-10 12:19:00.363 - error: javascript.0 at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-11-10 12:19:00.363 - error: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    2019-11-10 12:19:00.363 - error: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    2019-11-10 12:19:00.363 - error: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    2019-11-10 12:19:00.363 - error: javascript.0 at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2019-11-10 12:19:00.363 - error: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    2019-11-10 12:19:00.363 - error: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    2019-11-10 12:19:00.363 - error: javascript.0 at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    2019-11-10 12:19:00.363 - error: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    2019-11-10 12:19:00.363 - error: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    2019-11-10 12:19:00.363 - error: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    2019-11-10 12:19:00.363 - error: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    2019-11-10 12:19:00.364 - error: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    2019-11-10 12:19:00.364 - error: javascript.0 at WebSocket.emit (events.js:198:13)
    2019-11-10 12:19:00.364 - error: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    2019-11-10 12:19:00.364 - error: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    2019-11-10 12:19:00.364 - error: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    2019-11-10 12:19:00.364 - error: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    2019-11-10 12:19:00.364 - error: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    2019-11-10 12:19:00.364 - error: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    2019-11-10 12:19:00.364 - error: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    2019-11-10 12:19:00.364 - error: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    2019-11-10 12:19:00.364 - error: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    2019-11-10 12:19:00.364 - error: javascript.0 at Socket.emit (events.js:198:13)
    2019-11-10 12:19:00.364 - error: javascript.0 at addChunk (_stream_readable.js:287:12)
    2019-11-10 12:19:00.365 - error: javascript.0 at readableAddChunk (_stream_readable.js:268:11)
    2019-11-10 12:19:00.365 - error: javascript.0 at Socket.Readable.push (_stream_readable.js:223:10)
    2019-11-10 12:19:00.365 - error: javascript.0 at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
    BBTownB
    BBTownB
    BBTown
    @Icube
    wäre schön wenn Du das in deiner vorherigen Antwort auch noch änderst (code-Tags).
    welche Versionen hast Du im Einsatz?
    node -v
    nodejs -v
    npm -v
    und welche javascript Version?
    ioBroker auf NUC (VM debian v13 (Trixie ), node v24.21.0 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
    IccubeI 1 Antwort Letzte Antwort
    • BBTownB BBTown
      @Icube
      node -v
      nodejs -v
      npm -v
      IccubeI
      IccubeI
      Iccube
      @BBTown said in [Vorlage] Script für Sonos-Adapter:
      node -v
      nodejs -v
      npm -v
      Java V ist 4.3.0
      • MicM Mic
        @Manu-Oe
        Wann genau erscheint denn diese Fehlermeldung? Bei Script-Start, beim Klicken auf einen Favoriten, oder wann?
        @Mic Jetzt ist der Fehler weg und ich bekomme die Favoriten angezeigt.
        Wenn ich allerdings einen Favoriten aus der Liste hinzufügen oder entfernen möchte, kommt folgendes
        javascript.0 2019-11-15 09:15:58.145 warn at Object.<anonymous> (script.js.common.Test.Sonos_Favoriten:279:17)
        javascript.0 2019-11-15 09:15:58.145 warn at customFavoritesAddRemove (script.js.common.Test.Sonos_Favoriten:444:17)
        javascript.0 2019-11-15 09:15:58.145 warn Wrong type of javascript.0.Sonos.192_168_0_203.customFavoriteListArray: "object". Please fix, while deprecated and will not work in next versions.
        und die Favoritenliste ändert sich nicht. Weder wird hinzugefügt, noch entfernt.
        Manu
        BBTownB 1 Antwort Letzte Antwort
          Manu
          BBTownB
          BBTownB
          BBTown
          @Manu-Oe wo und wie löscht bzw. fügst Du Favoriten hinzu?
            in der VIS
            links sind die aktuellen in der vis und rechts im Popup sind die in Sonos verfügbaren. irgendwie sind alle hinzugefügt und ich kann die liste nicht editieren
            es wird auch optisch nichts markiert wenn ich rechts etwas anklicke
              in der VIS
              BBTownB
              BBTownB
              BBTown
              @Manu-Oe
              Wie ist denn das Verhalten wenn Du die Favoriten in der SONOS-App entfernst?
                Dann ist der entfernte Favorit in der rechten Spalte weg.
                Aber ich seh weder wie oben beschrieben gelb oder grau markierte um überhaupt zu sehen welche schon da sind
                Manu
                  Manu
                  BBTownB
                  BBTownB
                  BBTown
                  schrieb am zuletzt editiert von BBTown
                  @Manu-Oe sagte in [Vorlage] Script für Sonos-Adapter:
                  Ich gebe zu, ich habe keine Ahnung wovon Du sprichst - Ich sehe deine Worte, aber verstehe nicht was Du mir mit grau und gelb sagen willst 😎
                    in dem Screenshot oben sind beide Spalten eingeblendet
                    in der rechten sind die in Sonos verfügbaren Favoriten. und ganz oben im steht als Kommentar "gelb":bereits in Favoritenliste, "grau": nicht in Favoritenliste. Ich habe in beiden Spalten exakt dieselben Sender, aber bekomm keinen von links raus, und keinen neuen von rechts rein.
                    Hoffe das ist so verständlich
                    hab jetzt testweise unter Objekte den Inhalt von "customFavoriteListArray" gelöscht um zu schauen ob sich jetzt was ändert.
                    Leider ist die linke Spalte jetzt leer und es lässt sich nichts mehr hinzufügen
                    beim hinzufügeversuch in der VIS kommt im Log folgendes
                    javascript.0 2019-11-15 14:13:58.809 error at Object.<anonymous> (script.js.common.Test.Sonos_Favoriten:268:17)
                    javascript.0 2019-11-15 14:13:58.809 error at customFavoritesAddRemove (script.js.common.Test.Sonos_Favoriten:434:37)
                    javascript.0 2019-11-15 14:13:58.809 error Error in callback: TypeError: customFavorites.push is not a function
                    javascript.0 2019-11-15 14:13:57.779 error at Object.<anonymous> (script.js.common.Test.Sonos_Favoriten:268:17)
                    javascript.0 2019-11-15 14:13:57.779 error at customFavoritesAddRemove (script.js.common.Test.Sonos_Favoriten:434:37)
                    javascript.0 2019-11-15 14:13:57.779 error Error in callback: TypeError: customFavorites.push is not a function
                    javascript.0 2019-11-15 14:13:56.752 error at Object.<anonymous> (script.js.common.Test.Sonos_Favoriten:268:17)
                    javascript.0 2019-11-15 14:13:56.752 error at customFavoritesAddRemove (script.js.common.Test.Sonos_Favoriten:434:37)
                    javascript.0 2019-11-15 14:13:56.752 error Error in callback: TypeError: customFavorites.push is not a function
                    • MicM Mic
                      diese Vorlage bietet diverse Zusatzfunktionen zur Steuerung der Sonos-Geräte. Voraussetzung ist natürlich der Sonos-Adapter.
                      Auszug aus den Funktionen:
                      1. Favoriten in VIS: In VIS können die Sonos-Favoriten, also die in der App unter "Mein Sonos" gelistet sind, als Liste dargestellt werden. Klickt man auf einen dieser Favoriten, so wird der abgespielt und entsprechend im VIS auch markiert. Ein Menü bietet auch eine Auswahl, welche Favoriten zur Auswahl stehen sollen. Hier ein gif-Video, welches das zeigt.
                      2. State 'allStop': Setzt ALLE Sonos-Geräte des Adapters auf "stop".
                      3. State 'customFavoritesPlay': Startet das Abspielen der Favoriten. Dabei wird der aktuell im Adapter gesetzte Favorit genommen, falls dieser nicht gesetzt ist, dann wird der 1. Favorit genommen. Es wird dabei auch eine Standard-Lautstärke gesetzt, die im Script unter PRESET_VOLUME definiert wird.
                      4. State 'customFavoritesPlayG': Wie 'customFavoritesPlay', nur dass die Standard-Lautstärke der Sonos-Gruppe gesetzt wird, und nicht des einzelnen Gerätes.
                      5. State 'customFavoritesPlayByNumber': Spielt einen Favoriten ab, in dem die entsprechende Nummer dem State übergeben wird.
                      6. State 'customFavoritesPlayNext': Springt zum nächsten Favoriten-Eintrag in der Favoriten-Liste. Spielt den ersten Favoriten ab, falls aktuell der letzte Favorit gewählt ist.
                      7. State 'customFavoritesPlayPrevious': Springt zum vorangegangenen Favoriten-Eintrag in der Favoriten-Liste. Spielt den letzten Favoriten ab, falls aktuell der erste Favorit gewählt ist.
                      8. State 'volumeUp': Erhöht die Lautstärke. Voreingestellt ist die Erhöhung um 3 %, kann über VOL_VALUE in den Script-Einstellungen angepasst werden.
                      9. State 'volumeDown': Verringert die Lautstärke. Voreingestellt ist die Verringerung um 3 %, kann über VOL_VALUEin den Script-Einstellungen angepasst werden.
                      10. State 'volumeGroupUp': Wie 'volumeUp', nur dass hier die Gruppen-Lautstärke angepasst wird.
                      11. State 'volumeGroupDown': Wie 'volumeDown', nur dass hier die Gruppen-Lautstärke angepasst wird.
                      12. Geräte als Gruppe hinzufügen: Mittels GROUP_ON_PLAY / GROUP_ON_PLAY_DEVICES kann man in den Script-Einstellungen definieren, dass beim Abspielen eines Sonos-Gerätes automatisch weitere Geräte zur Gruppe hinzugefügt werden.
                      Zur Einrichtung:
                      1. Das Script in den JavaScript-Adapter als neues JS einfügen. Dort dann entsprechend die Einstellungen vornehmen. Das Script legt pro Sonos-Gerät entsprechende Datenpunkte (States) an, also wie im Sonos-Adapter:
                      2. Für VIS habe ich ein Projekt sonos-vis-project.zip erstellt, dieses ist hier zum Herunterladen verfügbar. Die Datei vis-views.json öffnet ihr am besten in einem Text-Editor, und macht dort Suchen/Ersetzen (STRG+h): suchen nach 10_10_10_10, ersetzen durch den Channel eures Sonos-Gerätes zur Anzeige in VIS. Channel ist der Teil des States in eurem Sonos-Adapter. Also bei sonos.0.root.192_168_0_100 ist das dann 192_168_0_100.
                        Dann importiert ihr das Projekt in VIS.
                      3. Wichtig: Wenn ihr die Größe des Widgets zur Darstellung der Favoriten ändert, müsst ihr auch die CSS-Datei anpassen, damit die Darstellung nicht "unsauber" wird.
                      Und nun?
                      Das war es auch schon :-) Nun sollte alles laufen.
                      Zur Formatierung im VIS passt ihr entsprechend das CSS im VIS an, also z.B. die Farbe des aktuell ausgewählten Favoriten.
                      Ich freue mich auf eure Rückmeldung.
                      TJJochenT
                      TJJochenT
                      TJJochen
                      @Mic sagte in [Vorlage] Script für Sonos-Adapter:
                      Und nun?
                      Das war es auch schon Nun sollte alles laufen.
                      Vorab muss ich sagen, installiert und funktioniert auf anhieb. Sehr tolle arbeit von dir :-)
                      Wie wäre es denn noch mit einer kleinen Verbesserung in Bezug auf die "Seek" Leiste?
                      Wäre doch geil, wenn man damit einen schnellen Vorlauf hätte oder direkt eine Liedposition ansteuern könnte.
                      Und ein Überblenden der Titel als "Fading Button" wäre ganz nett. ;-)
                      Ansonsten wirklich gelungen :-)
                      Jochen
                      • Matthias83M
                        Matthias83M
                        Matthias83
                        Hallo ich bin relativ neu bei iobroker.
                        Ich habe mehrfach versucht die Vis einzufügen Bei mir kommt immer die Meldung
                        invalid Settings
                        Und in der Vis zeigts mir nichts an,
                        Was mache ich falsch ?
                        • I
                          I
                          IOT
                          Hi Mic, cool nach ein bisserl suche in dem Thread funktioniert diese VIS SONOS Integration. thx!
                          • MicM
                            MicM
                            Mic
                            schrieb am zuletzt editiert von Mic
                            Hi zusammen,
                            vielen Dank für euer Feedback! 👍 :-)
                            Kurze Zwischeninfo: Ich werde demnächst eine entsprechend verbesserte Version hier veröffentlichen (kann noch mehrere Tage dauern, aber wohl noch vor der Schneeschmelze 😀 ). Hoffentlich dann per "copy/paste" als Beispiel-Projekt in VIS einfach zu integrieren.
                            Weitere Probleme / Wünsche / Vorschläge / usw. sind sehr gerne willkommen ;)
                            • T
                              T
                              tim210
                              schrieb am zuletzt editiert von tim210
                              Hallo, danke für das Script.
                              Leider habe ich noch ein kleines Problem bei dem ich nicht weiter weiß, vielleicht kann mir einer helfen. Irgendwie stehe ich auf dem Schlauch.
                              Ich kann nur einen Favoriten anwählen und der wird dann wie auf dem Bild dargestellt. Danach stopt das Script.
                              Danke und schöne Grüße
                              Tim
                              MicM 1 Antwort Letzte Antwort
                              • T tim210
                                Tim
                                MicM
                                MicM
                                Mic
                                Hey Tim,
                                poste am besten mal dein komplettes Script, sieht auf den ersten Blick nach Sonderzeichen-Problem aus.
                                Außerdem: welche Sonderzeichen hast du denn in deinen Sonos-Favoriten (Sonos-App)?
                                Ergänzung: und kompletter Error-Log wäre gut als Textdatei hier in Code-Tags (im ioBroker Admin > Log)
                                • MicM Mic
                                  Hi zusammen,
                                  T
                                  T
                                  Termina
                                  Hi zusammen,
                                  Vielen Dank für Deine Mühe! Wollte mich gerade dran machen, mal alles bei mir zu installieren, nach diesem Post sollte ich aber warten, oder?
                                  • T Termina
                                    Hi zusammen,
                                    MicM
                                    MicM
                                    Mic
                                    @Termina sagte in [Vorlage] Script für Sonos-Adapter:
                                    Nicht warten, kann noch dauern aus Zeitgründen bei mir ;-)
                                    • T
                                      T
                                      tim210
                                      Hallo, danke schon mal für die Antwort. So nun das Script und Error-Log. Hoffe ich habe das richtig eingefügt.🙈
                                       * SONOS-Script: Bietet diverse Zusatz-Funktionen zur Steuerung von SONOS-Geräten
                                       * mit dem SONOS-Adapter (https://github.com/ioBroker/ioBroker.sonos).
                                       * Quelle: https://github.com/Mic-M/iobroker.sonos-script
                                       * Autor: Mic (ioBroker) | Mic-M (github)
                                       * Support: https://forum.iobroker.net/topic/24743/
                                       * Change log:
                                       * 1.2 + Use new Sonos adapter state (since 2.0.0, pull request 55) 'favorites_list_array' to allow comma
                                       *       in favorite name, see https://github.com/ioBroker/ioBroker.sonos/pull/55
                                       *     + Replaced state 'customFavoriteList' with 'customFavoriteListArray', to allow semicolon in fav name
                                       * 1.1 + On script start, push all Sonos favorites into custom favorites initially
                                       * 1.0 + Major release, added several additional functions and improvements
                                       * 0.3 + Create states for each Sonos device automatically
                                       *     + New state 'allStop' to stop all Sonos devices
                                       * 0.2 - Fix: added missing function isLikeEmpty()
                                       * 0.1 - initial version
                                       * Einstellungen: Allgemein
                                      // Datenpunkt-Pfad, unter dem die entsprechenden Script-Datenpunkte angelegt werden.
                                      const SCRIPT_STATE_PATH = 'javascript.' + 0 + '.' + 'Sonos';
                                      // Instanz des SONOS-Adapters. Standard ist 0.
                                      const SONOS_ADAPTER_INSTANCE = 0;
                                       * Einstellungen: Favoriten-Liste für VIS
                                      // Favoriten-Liste: alphabetisch sortieren? true = ja, false = nein
                                      const SORT_LIST = true;
                                      // Favoriten-Liste: Den Favoriten eine fortlaufende Nummer voranstellen (1, 2, 3, ...)?
                                      const LIST_NO_ADD = true;  // auf false setzen, wenn nicht gewünscht.
                                      const LIST_NO_SEP = '. ' // Trennzeichen nach der Nummer. Gilt nur, wenn LIST_NO_ADD = true gesetzt.
                                      //  Favoriten-Liste: CSS-Bezeichnungen. Kann man einfach so stehen lassen.
                                      const CSS_CURRENT_SEL = 'currentsonosFavorite';  // CSS-ID für die aktuelle Auswahl
                                      const CSS_FAVORITE_ELEM = 'favoritesonosTitle'   // CSS-Klasse für jeden Eintrag der Liste
                                       * Einstellungen: 'favoritesPlayPrevious' und 'favoritesPlayNext'
                                      // Normalerweise wird bei Klicken auf Datenpunkt favoritesPlayNext/favoritesPlayPrevious
                                      // der nächste/vorherige Favorit lt. SONOS-App abgespielt. Wir können dies aber hiermit
                                      // alphabetisch sortieren, so dass der nächste/vorherige lt. Alphabet gespielt wird.
                                      // true = alphabetisch sortieren, false = nicht alphabetisch sortieren
                                      const FAVORITES_PLAY_PREV_NEXT_SORT = true;
                                       * Einstellungen: Buttons volumeUp/volumeDown zum erhöhen/verringern der Lautstärke
                                      // um wie viel % wird erhöht/verringert beim klicken auf volumeUp/volumeDown?
                                      const VOL_VALUE = 3;
                                      // Maximale Lautstärke in %, mehr wird nicht erhöht.
                                      const MAX_VOLUME = 95;
                                       * Einstellungen: Beim Abspielen immer Sonos-Geräte als Gruppe hinzufügen
                                      // Hiermit kann man Sonos-Geräte definieren, zu denen immer beim Abspielen weitere Geräte
                                      // als Gruppe hinzugefügt werden.
                                      // Zum Einschalten: auf true setzen.
                                      const GROUP_ON_PLAY = false;
                                      // Falls GROUP_ON_PLAY = false, fann kann man folgendes ignorieren.
                                      // Es können beliebig viele Zeilen hinzugefügt werden.
                                      // channelMain: Hier den Channel des 1. Gerätes eintragen, also die IP, aber "_" statt Punkt, also z.B. '192_168_10_12'
                                      // channelsToAdd: Hier Geräte eintragen, welche zum ersten Gerät als Gruppe hinzugefügt werden sollen
                                      //               Außerdem unter volumeAdjust das Volumen gegenüber dem channelMain nach oben oder unten anpassen.
                                      const GROUP_ON_PLAY_DEVICES = [
                                          { channelMain: '192_168_178_53', channelsToAdd: [{ channel: '192_168_10_7', volumeAdjust: -3 }] },
                                          { channelMain: '192_168_10_10', channelsToAdd: [{ channel: '192_168_10_25', volumeAdjust: -2 }, { channel: '192_168_10_26', volumeAdjust: 0 }] },
                                       * Einstellungen: Sonstige
                                      // Standard-Lautstärke beim Starten mit customFavoritesPlay / .customFavoritesPlayG
                                      const PRESET_VOLUME = 15;
                                      // Ein paar Infos im Log anzeigen?
                                       * Das war es auch schon. Ab hier nichts mehr ändern!
                                       * Global variables and constants
                                      // Alle Sonos-States (Geräte) in Array, also z.B. ['sonos.0.root.192_168_0_12', 'sonos.0.root.192_168_0_13']
                                      const SONOS_CHANNELS = getAllSonosChannels(SONOS_ADAPTER_INSTANCE);
                                       * Initialize
                                      init();
                                      function init() {
                                          createStates();
                                          setTimeout(function () {
                                              // Subscribe to states
                                              subscribeToStates();
                                              for (let lpChannel of SONOS_CHANNELS) {
                                                  let sonosFavsArray = sonosFavoritesArray(lpChannel);
                                                  let customFavsArray = getState(scriptPath(lpChannel) + '.customFavoriteListArray').val;
                                                  // If custom favorites list is empty, we push all Sonos Favorites into it in the beginning.
                                                  if (isLikeEmpty(customFavsArray)) {
                                                      let customFavsArray = [...sonosFavsArray]; // copy array
                                                      if (SORT_LIST) customFavsArray = arraySortCaseInsensitive(customFavsArray);
                                                      setState(scriptPath(lpChannel) + '.customFavoriteListArray', customFavsArray, true);
                                                  // Refresh global HTML playlist initially
                                                  refreshFavoritesHtmlList(lpChannel, sonosFavsArray, scriptPath(lpChannel) + '.sonosFavoriteListHtml');
                                                  // Refresh custom HTML playlist initially
                                                  refreshFavoritesHtmlList(lpChannel, customFavsArray, scriptPath(lpChannel) + '.customFavoriteListHtml');
                                                  // Refresh Configuration HTML
                                                  refreshConfigurationHtml(lpChannel);
                                                      // Clean Custom Favorites List, if Sonos Favorite was deleted.
                                                      // We perfom this also in the beginning.
                                                      cleanCustomFavoritesList(lpChannel);
                                                  }, 2000);
                                          }, 2000);
                                      function createStates() {
                                              createState(scriptPath(lpChannel) + '.sonosFavoriteListHtml', { 'name': 'Sonos Favorites HTML List', 'type': 'string', 'read': true, 'write': true, 'role': 'media.list', 'def': '' });
                                              createState(scriptPath(lpChannel) + '.sonosFavoritesPlayNext', { 'name': 'Favorites: play next', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.sonosFavoritesPlayPrevious', { 'name': 'Favorites: play previous', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.customFavoriteAdd', { 'name': 'Custom Favorites: Add a favorite', 'type': 'string', 'read': true, 'write': true, 'role': 'state', 'def': '' });
                                              createState(scriptPath(lpChannel) + '.customFavoriteRemove', { 'name': 'Custom Favorites: Remove a favorite', 'type': 'string', 'read': true, 'write': true, 'role': 'state', 'def': '' });
                                              createState(scriptPath(lpChannel) + '.customFavoriteListArray', { 'name': 'Custom Favorites List Array', 'type': 'array', 'read': true, 'write': true, 'role': 'state', 'def': '' });
                                              createState(scriptPath(lpChannel) + '.customFavoriteListHtml', { 'name': 'Custom Favorites HTML List', 'type': 'string', 'read': true, 'write': true, 'role': 'media.list', 'def': '' });
                                              createState(scriptPath(lpChannel) + '.customFavoriteConfigHtml', { 'name': 'Custom Favorites HTML Configuration', 'type': 'string', 'read': true, 'write': true, 'role': 'state', 'def': '' });
                                              createState(scriptPath(lpChannel) + '.customFavoriteToggleConfigVis', { 'name': 'Custom Favorites: For Vis to toggle config', 'type': 'boolean', 'read': true, 'write': true, 'role': 'state', 'def': false });
                                              createState(scriptPath(lpChannel) + '.customFavoritesPlay', { 'name': 'Custom Favorites: Start playing and set default volume for device', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.customFavoritesPlayG', { 'name': 'Custom Favorites: Start playing and set default volume for GROUP', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.customFavoritesPlayNext', { 'name': 'Custom Favorites: play next', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.customFavoritesPlayPrevious', { 'name': 'Custom Favorites: play previous', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.customFavoritesPlayByNumber', { 'name': 'Custom Favorites: Play a favorite by number (1-x)', 'type': 'number', 'min': 1, 'max': 999, 'read': true, 'write': true, 'role': 'state' });
                                              createState(scriptPath(lpChannel) + '.volumeUp', { 'name': 'Increase volume', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.volumeDown', { 'name': 'Decrease volume', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.volumeGroupUp', { 'name': 'Increase volume of group', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                              createState(scriptPath(lpChannel) + '.volumeGroupDown', { 'name': 'Decrease volume of group', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                          createState(SCRIPT_STATE_PATH + '.' + 'allStop', { 'name': 'Stop all Sonos devices', 'type': 'boolean', 'read': false, 'write': true, 'role': 'button', 'def': false });
                                      function subscribeToStates() {
                                               * Global Favorites
                                               * Refresh if the Sonos Favorites list changes
                                              on({ id: sonosPath(lpChannel) + '.favorites_list', change: 'ne' }, function (obj) {
                                                  let channel = getChannel(obj.id);
                                                  // Refresh HTML
                                                  refreshFavoritesHtmlList(channel, sonosFavoritesArray(channel), scriptPath(channel) + '.sonosFavoriteListHtml'); // Nun können wir refreshen
                                                  refreshConfigurationHtml(channel);
                                                  cleanCustomFavoritesList(channel);
                                               *  Refresh if the current favorite changes
                                              on({ id: sonosPath(lpChannel) + '.favorites_set', change: 'ne' }, function (obj) {
                                               *  Play next Sonos favorite
                                              on({ id: scriptPath(lpChannel) + '.sonosFavoritesPlayNext', change: 'any', val: true }, function (obj) {
                                                  let favsArray = sonosFavoritesArray(lpChannel);
                                                  if (FAVORITES_PLAY_PREV_NEXT_SORT) favsArray = arraySortCaseInsensitive(favsArray);
                                                  favoritesPlayNext(lpChannel, favsArray, true);
                                               *  Play previous Sonos favorite
                                              on({ id: scriptPath(lpChannel) + '.sonosFavoritesPlayPrevious', change: 'any', val: true }, function (obj) {
                                                  favoritesPlayNext(lpChannel, favsArray, false);
                                               * Custom Favorites
                                               * Refresh if the Custom Favorites list changes
                                              on({ id: scriptPath(lpChannel) + '.customFavoriteListArray', change: 'ne' }, function (obj) {
                                                  // Refresh Custom Favorites HTML List
                                                  refreshFavoritesHtmlList(channel, getState(scriptPath(channel) + '.customFavoriteListArray').val, scriptPath(channel) + '.customFavoriteListHtml'); // Nun können wir refreshen
                                               *  Refresh if the current Sonos favorite changes
                                                  refreshFavoritesHtmlList(channel, getState(scriptPath(lpChannel) + '.customFavoriteListArray').val, scriptPath(channel) + '.customFavoriteListHtml'); // Nun können wir refreshen
                                               *  Add a Favorite to Custom Favorite List
                                              on({ id: scriptPath(lpChannel) + '.customFavoriteAdd', change: 'any' }, function (obj) {
                                                  if (!isLikeEmpty(obj.state.val)) {
                                                      customFavoritesAddRemove(lpChannel, obj.state.val, true);
                                                      if (LOG_INFO) log('[' + obj.state.val + '] added to custom favorite list.');
                                                      setStateDelayed(obj.id, '', true, 500);
                                               *  Remove a Favorite from Custom Favorite List
                                              on({ id: scriptPath(lpChannel) + '.customFavoriteRemove', change: 'any' }, function (obj) {
                                                      customFavoritesAddRemove(lpChannel, obj.state.val, false);
                                                      if (LOG_INFO) log('[' + obj.state.val + '] removed from custom favorite list.');
                                               *  Play next custom favorite
                                              on({ id: scriptPath(lpChannel) + '.customFavoritesPlayNext', change: 'any', val: true }, function (obj) {
                                                  let favsArray = getState(scriptPath(lpChannel) + '.customFavoriteListArray').val;
                                               *  Play previous custom favorite
                                              on({ id: scriptPath(lpChannel) + '.customFavoritesPlayPrevious', change: 'any', val: true }, function (obj) {
                                               * Volume
                                               * Volume Up: Device
                                              on({ id: scriptPath(lpChannel) + '.volumeUp', change: 'any', val: true }, function (obj) {
                                                  volumeUp(channel, 'volume', true, VOL_VALUE);
                                               * Volume Down: Device
                                              on({ id: scriptPath(lpChannel) + '.volumeDown', change: 'any', val: true }, function (obj) {
                                                  volumeUp(channel, 'volume', false, VOL_VALUE);
                                               * Volume Up: Group
                                              on({ id: scriptPath(lpChannel) + '.volumeGroupUp', change: 'any', val: true }, function (obj) {
                                                  volumeUp(channel, 'group_volume', true, VOL_VALUE);
                                               * Volume Down: Group
                                              on({ id: scriptPath(lpChannel) + '.volumeGroupDown', change: 'any', val: true }, function (obj) {
                                                  volumeUp(channel, 'group_volume', false, VOL_VALUE);
                                               * Others
                                               * Custom Favorites: Play favorite by number.
                                              on({ id: scriptPath(lpChannel) + '.customFavoritesPlayByNumber', change: 'any' }, function (obj) {
                                                  playCustomFavoriteByNumber(channel, obj.state.val);
                                               * Custom Favorites: Start playing and set standard volume level to device
                                              on({ id: scriptPath(lpChannel) + '.customFavoritesPlay', change: 'any', val: true }, function (obj) {
                                                  sonosStart(channel, 'volume', PRESET_VOLUME);
                                               * Custom Favorites: Start playing and set standard volume level to GROUP
                                              on({ id: scriptPath(lpChannel) + '.customFavoritesPlayG', change: 'any', val: true }, function (obj) {
                                                  sonosStart(channel, 'group_volume', PRESET_VOLUME);
                                           * Group Sonos devices once status is play
                                          if (GROUP_ON_PLAY) {
                                              for (let lpItem of GROUP_ON_PLAY_DEVICES) {
                                                  let channelMain = lpItem['channelMain'];
                                                  on({ id: sonosPath(channelMain) + '.state_simple', change: 'any', val: true }, function (obj) {
                                                      groupSonos(channel);
                                            * Stop playing at all Sonos devices
                                          on({ id: SCRIPT_STATE_PATH + '.' + 'allStop', change: "any", val: true }, function (obj) {
                                                  setState(sonosPath(lpChannel) + '.stop', true);
                                              setState(obj.id, false, true); // jetzt Datenpunkt wieder auf false setzen. https://forum.iobroker.net/topic/12708/
                                       * Clean custom favorites list, if a Sonos Favorite was removed.
                                       * @param {string}  channel    The channel xx_xx_xx_xx
                                      function cleanCustomFavoritesList(channel) {
                                          // Sonos Favorites in Array
                                          let sonosFavsArray = sonosFavoritesArray(channel);
                                          // Custom Favorites in Array
                                          let customFavsArray = getState(scriptPath(channel) + '.customFavoriteListArray').val;
                                          // Now remove all items from Custom Favs Array, if not existing in Sonos Favorites
                                          let resultArray = [];
                                          for (let lpCustomItem of customFavsArray) {
                                              if (sonosFavsArray.indexOf(lpCustomItem) != -1) {
                                                  resultArray.push(lpCustomItem);
                                          setState(scriptPath(channel) + '.customFavoriteListArray', resultArray, true);
                                       * Adds or removes a favorite to/from custom favorite list
                                       * @param {string}  favorite   The favorite to add or remove
                                       * @param {boolean} add        add if true, or remove, if false
                                      function customFavoritesAddRemove(channel, favorite, add) {
                                          // favorite = favorite.replace (/,/g, ''); // Remove any comma from string.  // 12-Sep-2019: removed as Sonos adapter now allows with state favorites_list_array commas as well
                                          let statePth = scriptPath(channel) + '.customFavoriteListArray';
                                          let customFavorites = getState(statePth).val;
                                          if (!isLikeEmpty(favorite)) {
                                              if (add) {
                                                  if (customFavorites.indexOf(favorite) == -1) {
                                                      // Check if given favorite is member of Sonos favorites.
                                                      let sonosFavs = sonosFavoritesArray(channel);
                                                      if (sonosFavs.indexOf(favorite) != -1) {
                                                          customFavorites.push(favorite);
                                                          customFavorites = cleanArray(customFavorites); // just in case
                                                          if (SORT_LIST) customFavorites = arraySortCaseInsensitive(customFavorites);
                                                          setState(statePth, customFavorites, true);
                                              } else { // remove
                                                  if (customFavorites.indexOf(favorite) != -1) {
                                                      customFavorites = arrayRemoveElementsByValue(customFavorites, favorite, true);
                                                      setState(statePth, customFavorites, true);  // wegen {"val:..."} siehe https://forum.iobroker.net/topic/14699/array-in-state-speichern/4
                                       * Returnes the Sonos path for a given channel.
                                       * @return {string} the Sonos path, e.g. 'sonos.0.root.192_168_0_15'
                                      function sonosPath(channel) {
                                          return 'sonos.' + SONOS_ADAPTER_INSTANCE + '.root.' + channel;
                                       * Returnes the Script path for a given channel.
                                       * @return {string} the Script path, e.g. 'javascript.0.Sonos.192_168_0_15'
                                      function scriptPath(channel) {
                                          return SCRIPT_STATE_PATH + '.' + channel;
                                       * Refreshes the current Favorites HTML List.
                                       * @param {string} favArray   Array of the Favorites
                                       * @param {string} state      The state to update
                                      function refreshFavoritesHtmlList(channel, favArray, state) {
                                          let current = getState(sonosPath(channel) + '.favorites_set').val;
                                          let favArrayDisplay;
                                          let htmlResult;
                                           * Sort Array case insensitive
                                          if (SORT_LIST) favArray = arraySortCaseInsensitive(favArray);
                                           * After sorting, we do some stuff to the displayed value
                                          favArrayDisplay = [...favArray]; // copy
                                          for (let i = 0; i < favArrayDisplay.length; i++) {
                                              let strResult = favArrayDisplay[i];
                                              // Strip HTML: https://stackoverflow.com/questions/822452/strip-html-from-text-javascript
                                              strResult = strResult.replace(/<[^>]*>?/gm, '');
                                              // Add number to each element
                                              if (LIST_NO_ADD) strResult = (i + 1) + LIST_NO_SEP + strResult;
                                              // Finally, set to element
                                              favArrayDisplay[i] = strResult;
                                           * Build Playlist
                                          htmlResult = '<table>' + '\n';
                                          for (let i = 0; i < favArray.length; i++) {
                                              htmlResult += '\t' + '<tr onclick="vis.setValue(\'' + sonosPath(channel) + '.favorites_set' + '\', \'' + favArray[i] + '\')">' + '\n';
                                              htmlResult += '\t\t' + '<td>';
                                              let strCSSCurrPlaylist = '';
                                              if (isLikeEmpty(current) === false) {
                                                  if (current == favArray[i]) {
                                                      strCSSCurrPlaylist = ' id="' + CSS_CURRENT_SEL + '"';
                                              htmlResult += '<div class="' + CSS_FAVORITE_ELEM + '"' + strCSSCurrPlaylist + '>';
                                              htmlResult += favArrayDisplay[i];
                                              htmlResult += '</div>';
                                              htmlResult += '</td>' + '\n';
                                              htmlResult += '\t' + '</tr>' + '\n';
                                          htmlResult += '</table>' + '\n';
                                      	 * Automatisches Scrollen der aktuellen Playlist
                                      	 * Abgeschaut von: https://forum.iobroker.net/viewtopic.php?f=30&t=18222#p196640
                                           * 28-Aug-2018: Noch ergänzt: "if (element != undefined)". Sonst wird die Liste unsauber dargestellt.
                                          htmlResult += '<script>';
                                          htmlResult += 'let element = document.getElementById("' + CSS_CURRENT_SEL + '");'; // ID von dem aktuellen DIV in der TABLE oben
                                          htmlResult += "if (element != undefined) element.scrollIntoView(true);"; //true = Position oben / false = Position unten
                                          htmlResult += '</script>';
                                          // Finally: set state
                                          setState(state, htmlResult, true);
                                      function refreshConfigurationHtml(channel) {
                                          if (SORT_LIST) sonosFavsArray = arraySortCaseInsensitive(sonosFavsArray);
                                          let htmlResult;
                                          favArrayDisplay = [...sonosFavsArray]; // copy
                                           * Build Playlist
                                          for (let i = 0; i < sonosFavsArray.length; i++) {
                                              // Indicates if current loop item is element of custom favorites list
                                              let isActive = (customFavsArray.indexOf(sonosFavsArray[i]) != -1) ? true : false;
                                              let stateAddRemove = (isActive) ? '.customFavoriteRemove' : '.customFavoriteAdd';
                                              let classAddRemove = (isActive) ? 'removeFav' : 'addFav';
                                              htmlResult += '\t' + '<tr onclick="vis.setValue(\'' + scriptPath(channel) + stateAddRemove + '\', \'' + sonosFavsArray[i] + '\')">' + '\n';
                                              htmlResult += '<div class="' + CSS_FAVORITE_ELEM + ' ' + classAddRemove + '"' + '>';
                                          setState(scriptPath(channel) + '.customFavoriteConfigHtml', htmlResult, true);
                                       * Damit bekommen wir alle existierenden Sonos-Channels, wie 'xx_xx_xx_xx' von 'sonos.0.root.xx_xx_xx_xx' als Array
                                       * @param {number}  instance  Die Instanz des Sonos-Adapters.
                                       * @return {object} Array mit Channel aller Sonos-Geräte wie z.B. ['xx_xx_xx_xx', 'yy_yy_yy_yy').
                                       *                  Falls nicht gefunden: leeres Array.
                                      function getAllSonosChannels(instance) {
                                          let mSelector = $('[id=^sonos.' + instance + '.root.*.pause]');
                                          mSelector.each(function (id, i) {
                                              // Nun haben wir mit "id" die State-ID, z.B. sonos.0.root.xx_xx_xx_xx.pause
                                              // Wir trennen dieses String nun in ein Array auf.
                                              let lpArr = id.split(".");
                                              // Element Nr. 3 enthält xx_xx_xx_xx
                                              let loopChannel = lpArr[3];
                                              // Ins Array setzen
                                              resultArray.push(loopChannel);
                                          return resultArray;
                                       * Play next or previous favorite
                                       * @param {object} favArray  Array with the favorites
                                       * @param {boolean} [playNext=true]  Optional: If true: play next, if false: play previous. Default: true
                                      function favoritesPlayNext(channel, favArray, playNext) {
                                          if (playNext === undefined) playNext = true;
                                          // Current favorite from Sonos Adapter
                                          let currentFavSonosAdapter = getState(sonosPath(channel) + '.favorites_set').val;
                                          // Check if it is in our favorites list.
                                          // If not, we just set the first element of our custom list as current favorite.
                                          if ((currentFavSonosAdapter == '') || (favArray.indexOf(currentFavSonosAdapter) == -1)) {  // indexOf() return the index of an element in the array, or -1 if it's not in the array.
                                              currentFavSonosAdapter = favArray[0];
                                          // Get next or previous favorite
                                          let nextFav = arrayGetNextOrPreviousValue(favArray, currentFavSonosAdapter, playNext);
                                          // set it to state
                                          setState(sonosPath(channel) + '.favorites_set', nextFav);
                                          if (LOG_INFO) log('Sonos umgeschaltet auf: ' + nextFav);
                                       * Play favorite by number
                                       * @param {number} favNo      Number of favorites. Start with 1 for first favorite (not 0).
                                      function playCustomFavoriteByNumber(channel, favNo) {
                                          if (favNo == 0) favNo = 1;
                                          let customFavorites = getState(scriptPath(channel) + '.customFavoriteListArray').val;
                                          if (customFavorites[favNo - 1] != undefined) {
                                              setState(sonosPath(channel) + '.favorites_set', customFavorites[favNo - 1]);
                                              if (LOG_INFO) log('Sonos umgeschaltet Favorit ' + favNo + ': ' + customFavorites[favNo - 1]);
                                          } else {
                                              log('Sonos Favorit Nummer ' + favNo + ' wurde nicht gefunden.');
                                       * Return the Sonos favorites as array
                                       * As of Sonos adapter version 2.0.0 / Pull request 55, there is a new state 'favorites_list_array'
                                       * If this state is existing, we use it, instead of favorites_list
                                       * @return {object} The favorites as array
                                      function sonosFavoritesArray(channel) {
                                          if (isState('favorites_list_array', true)) {
                                              return getState(sonosPath(channel) + '.favorites_list_array').val;
                                          } else {
                                              return getState(sonosPath(channel) + '.favorites_list').val.split(', ');
                                       * Custom Favorites: Start Playing
                                       * @param {string} volType    'volume': volume of device; 'group_volume': the group volume
                                       * @param {number} [volume=15]  Optional: Volume
                                       * @param {number} [position] Optional: Position in Favorites (starts with 1, not 0). If not provided, we use current set favorite
                                      function sonosStart(channel, volType, volume, position) {
                                          if (volume === undefined) volume = 15;
                                          if (position === undefined) position = -1; // No position provided, so we set to -1, to use current pos later
                                          if (position === 0) position = 1;
                                          // get current favorite from Sonos Adapter
                                          let currentFavorite = getState(sonosPath(channel) + '.favorites_set').val;
                                          // Check if it is in our custom favorites list.
                                          if ((currentFavorite == '') || (customFavorites.indexOf(currentFavorite) == -1)) {  // indexOf() return the index of an element in the array, or -1 if it's not in the array.
                                              currentFavorite = customFavorites[0];
                                          // If position was provided, we set accordingly.
                                          if (position != -1) {
                                              if (customFavorites[position - 1] != undefined) {
                                                  currentFavorite = customFavorites[position - 1]
                                          setState(sonosPath(channel) + '.favorites_set', currentFavorite);   // play favorite
                                          setState(sonosPath(channel) + '.' + volType, volume) // Set volume
                                          log('Sonos gestartet (Lautstärke ' + volume + '): ' + currentFavorite);
                                       * Increase or decrease volume
                                       * @param {boolean} increase  if true: increase, if false: decrease
                                       * @param {number} [value=3]  Optional: increase by how much. Default: 3
                                      function volumeUp(channel, volType, increase, value) {
                                          if (value === undefined) value = 3;
                                          let currentVolume = getState(sonosPath(channel) + '.' + volType).val;
                                          log(currentVolume);
                                          let newVolume;
                                          let logTxt;
                                          if (increase) {
                                              newVolume = currentVolume + value;
                                              if (newVolume > MAX_VOLUME) newVolume = MAX_VOLUME;
                                              logTxt = 'erhöht';
                                          } else {
                                              newVolume = currentVolume - Math.abs(value); // We accept also positive numbers, so remove minus
                                              if (newVolume <= 1) newVolume = 1; // Mindestens auf Lautstärke 1 belassen
                                              logTxt = 'verringert';
                                          setState(sonosPath(channel) + '.' + volType, newVolume);
                                          if (LOG_INFO) log('Sonos-Lautstärke um ' + value + ' auf ' + newVolume + ' ' + logTxt + '.');
                                       * Groups Sonos devices, per GROUP_ON_PLAY_DEVICES
                                       * @param {string} channelMain    The Main Channel, xx_xx_xx_xx
                                      function groupSonos(channelMain) {
                                          let channelsToAdd = getConfigValuePerKey(GROUP_ON_PLAY_DEVICES, 'channelMain', channelMain, 'channelsToAdd');
                                          let currentMemberChannels = getState(sonosPath(channelMain) + '.membersChannels').val.split(',');
                                          for (let lpChannelAddItem of channelsToAdd) {
                                              let lpChannelToAdd = lpChannelAddItem['channel'];
                                              let lpChannelToAddVolumeAdjust = lpChannelAddItem['volumeAdjust'];
                                              if (currentMemberChannels.indexOf(lpChannelToAdd) === -1) {
                                                  // channel is not in the current member channels list, so we add it
                                                  setState(sonosPath(channelMain) + '.add_to_group', lpChannelToAdd);
                                                  // Next, we adjust the volume
                                                  let currVolumeMain = getState(sonosPath(channelMain) + '.volume').val;
                                                  let volForNewChannel = currVolumeMain + lpChannelToAddVolumeAdjust;
                                                  setState(sonosPath(lpChannelToAdd) + '.volume', volForNewChannel);
                                                  // Log
                                                  if (LOG_INFO) log('Sonos device ' + lpChannelToAdd + ' added to ' + channelMain + '. Adjusted volume by [' + lpChannelToAddVolumeAdjust + '].')
                                       * Get channel from Sonos or Script state.
                                       * @param {string} state      Sonos State, e.g. sonos.0.root.xx_xx_xx_xx.favorites_set
                                       *                            Or Scrript state, e.g. javascript.0.Sonos.xx_xx_xx_xx.customFavoriteListArray
                                       * @return {string} The channel xx_xx_xx_xx
                                      function getChannel(state) {
                                          let lpArr = state.split("."); // Nun haben wir mit "obj.id" die State-ID, z.B. sonos.0.root.xx_xx_xx_xx.favorites_set. Wir trennen dieses String nun in ein Array auf.
                                          let channel = lpArr[lpArr.length - 2]; // Channel auslesen, also xx_xx_xx_xx
                                          return channel;
                                       * Sort array case-insensitive
                                       * @param {object} arrayInput  Array to be sorted
                                       * @return {object}   case-insensitive sorted array
                                      function arraySortCaseInsensitive(arrayInput) {
                                          let arrayResult = [...arrayInput]; // We use array spreads '...' to copy array. If not, array is changed by reference and not value.
                                          arrayResult.sort(function (a, b) {
                                              return a.toLowerCase().localeCompare(b.toLowerCase());
                                          return arrayResult;
                                       * Checks if Array or String is not undefined, null or empty.
                                       * 08-Sep-2019: added check for [ and ] to also catch arrays with empty strings.
                                       * @param inputVar - Input Array or String, Number, etc.
                                       * @return true if it is undefined/null/empty, false if it contains value(s)
                                       * Array or String containing just whitespaces or >'< or >"< or >[< or >]< is considered empty
                                      function isLikeEmpty(inputVar) {
                                          if (typeof inputVar !== 'undefined' && inputVar !== null) {
                                              let strTemp = JSON.stringify(inputVar);
                                              strTemp = strTemp.replace(/\s+/g, ''); // remove all whitespaces
                                              strTemp = strTemp.replace(/\"+/g, "");  // remove all >"<
                                              strTemp = strTemp.replace(/\'+/g, "");  // remove all >'<
                                              strTemp = strTemp.replace(/\[+/g, "");  // remove all >[<
                                              strTemp = strTemp.replace(/\]+/g, "");  // remove all >]<
                                              if (strTemp !== '') {
                                                  return false;
                                              } else {
                                                  return true;
                                          } else {
                                              return true;
                                       * Returns the next or previous element of an array for a given element.
                                       * Use case is to easily switch through an array of elements...
                                       * If it is the last element of the array, it will return the first one, if bNext is true.
                                       * If it is the first element of the array, it will return the last one, if bNext is false.
                                       * If not found, it will ALWAYS return the first element.
                                       * @param {array}   inputArray  Array
                                       * @param {string}  strElement  for this String we want to get the next/previous array element
                                       * @param {boolean} bNext       next element if true, previous element if false
                                       * @return {string} The next or previous element from the array
                                      function arrayGetNextOrPreviousValue(inputArray, strElement, bNext) {
                                          let iLength = inputArray.length; // Number of elements in the Array
                                          let iPosition = inputArray.indexOf(strElement) + 1; // Current position. We add 1 since first element is in position 0
                                          let iPositionNext = iPosition + 1;
                                          let iPositionPrevious = iPosition - 1;
                                          if (bNext) {
                                              // if not found, it will return the first element...
                                              if (iPositionNext > iLength) iPositionNext = 1;
                                              return inputArray[iPositionNext - 1];
                                          } else {
                                              if (iPosition === 0) { // will be zero if not found
                                                  return inputArray[0]; // return the first element, if not found
                                              } else {
                                                  if (iPositionPrevious < 1) iPositionPrevious = iLength;
                                                  return inputArray[iPositionPrevious - 1];
                                       * Removing Array element(s) by input value.
                                       * @param {array}   arr             the input array
                                       * @param {string}  valRemove       the value to be removed
                                       * @param {boolean} [exact=true]    OPTIONAL: default is true. if true, it must fully match. if false, it matches also if valRemove is part of element string
                                       * @return {array}  the array without the element(s)
                                      function arrayRemoveElementsByValue(arr, valRemove, exact) {
                                          if (exact === undefined) exact = true;
                                          for (let i = 0; i < arr.length; i++) {
                                              if (exact) {
                                                  if (arr[i] === valRemove) {
                                                      arr.splice(i, 1);
                                                      i--; // required, see https://love2dev.com/blog/javascript-remove-from-array/
                                              } else {
                                                  if (arr[i].indexOf(valRemove) != -1) {
                                                      arr.splice(i, 1);
                                                      i--; // see above
                                          return arr;
                                       * Clean Array: Removes all falsy values: undefined, null, 0, false, NaN and "" (empty string)
                                       * Source: https://stackoverflow.com/questions/281264/remove-empty-elements-from-an-array-in-javascript
                                       * @param {array} inputArray       Array to process
                                       * @return {array}  Cleaned array
                                      function cleanArray(inputArray) {
                                          var newArray = [];
                                          for (let i = 0; i < inputArray.length; i++) {
                                              if (inputArray[i]) {
                                                  newArray.push(inputArray[i]);
                                          return newArray;
                                       * Removes all elements from an array contained in a second array.
                                       * It will ignore values of the second array, if not found in sourceArray.
                                       * Source: https://stackoverflow.com/questions/19957348/javascript-arrays-remove-all-elements-contained-in-another-array
                                       * @param {object} sourceArray    The array from which to remove the elements
                                       * @param {object} arrayToRemove  The array which elements we remove from sourceArray
                                       * @return {object} array without elements of arrayToRemove
                                      function arrayRemoveOtherArray(sourceArray, arrayToRemove) {
                                          let arrayResult = [...sourceArray]; // Copy given array, we use array spreads '...'
                                          arrayResult = arrayResult.filter(function (element) {
                                              return !arrayToRemove.includes(element);
                                          return arrayResult;
                                       * Retrieve values from a CONFIG variable, example:
                                       * const CONF = [{car: 'bmw', color: 'black', hp: '250'}, {car: 'audi', color: 'blue', hp: '190'}]
                                       * To get the color of the Audi, use: getConfigValuePerKey(CONF, 'car', 'audi', 'color')
                                       * To find out which car has 190 hp, use: getConfigValuePerKey(CONF, 'hp', '190', 'car')
                                       * @param {object}  config     The configuration variable/constant
                                       * @param {string}  key1       Key to look for.
                                       * @param {string}  key1Value  The value the key should have
                                       * @param {string}  key2       The key which value we return
                                       * @returns {any}    Returns the element's value, or number -1 of nothing found.
                                      function getConfigValuePerKey(config, key1, key1Value, key2) {
                                          for (let lpConfDevice of config) {
                                              if (lpConfDevice[key1] === key1Value) {
                                                  if (lpConfDevice[key2] === undefined) {
                                                      return -1;
                                                  } else {
                                                      return lpConfDevice[key2];
                                          return -1;
                                       * Checks if a a given state or part of state is existing.
                                       * This is a workaround, as getObject() or getState() throw warnings in the log.
                                       * Set strict to true if the state shall match exactly. If it is false, it will add a wildcard * to the end.
                                       * See: https://forum.iobroker.net/topic/11354/
                                       * @param {string}    strStatePath     Input string of state, like 'javas-cript.0.switches.Osram.Bedroom'
                                       * @param {boolean}   [strict=false]   Optional: if true, it will work strict, if false, it will add a wildcard * to the end of the string
                                       * @return {boolean}                   true if state exists, false if not
                                      function isState(strStatePath, strict) {
                                          let mSelector;
                                          if (strict) {
                                              mSelector = $('state[id=' + strStatePath + '$]');
                                          } else {
                                              mSelector = $('state[id=' + strStatePath + ']');
                                          if (mSelector.length > 0) {
                                              return true;
                                          } else {
                                              return false;
                                      22.1.2020, 17:45:16.953	[info ]: javascript.0 (1239) Stop script script.js.sonos-script
                                      22.1.2020, 17:45:19.644	[info ]: javascript.0 (1239) Start javascript script.js.sonos-script
                                      22.1.2020, 17:45:19.864	[info ]: javascript.0 (1239) script.js.sonos-script: setTimeout(ms=2000)
                                      22.1.2020, 17:45:19.866	[info ]: javascript.0 (1239) script.js.sonos-script: registered 0 subscriptions and 0 schedules
                                      22.1.2020, 17:45:21.871	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"sonos.0.root.192_168_178_53.favorites_list","change":"ne","q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.873	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"sonos.0.root.192_168_178_53.favorites_set","change":"ne","q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.875	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.sonosFavoritesPlayNext","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.877	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.sonosFavoritesPlayPrevious","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.878	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.customFavoriteListArray","change":"ne","q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.880	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"sonos.0.root.192_168_178_53.favorites_set","change":"ne","q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.882	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.customFavoriteAdd","change":"any","q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.883	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.customFavoriteRemove","change":"any","q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.897	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.customFavoritesPlayNext","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.898	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.customFavoritesPlayPrevious","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.899	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.volumeUp","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.900	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.volumeDown","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.901	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.volumeGroupUp","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.903	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.volumeGroupDown","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.904	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.customFavoritesPlayByNumber","change":"any","q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.906	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.customFavoritesPlay","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.907	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.192_168_178_53.customFavoritesPlayG","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.908	[info ]: javascript.0 (1239) script.js.sonos-script: subscribe: {"pattern":{"id":"javascript.0.Sonos.allStop","change":"any","val":true,"q":0},"name":"script.js.sonos-script"}
                                      22.1.2020, 17:45:21.924	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=sonos.0.root.192_168_178_53.favorites_list_array, timerId=undefined) => {"val":["1LIVE","ffn","N-JOY","Radio Sauerland","WDR 2 - Ruhrgebiet"],"ack":true,"ts":1579710340775,"q":0,"from":"system.adapter.sonos.0","user":"system.user.admin","lc":1579249377671}
                                      22.1.2020, 17:45:21.927	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=javascript.0.Sonos.192_168_178_53.customFavoriteListArray, timerId=undefined) => {"val":"[\"1LIVE\"]","ack":true,"ts":1579545075420,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1579545075420}
                                      22.1.2020, 17:45:21.935	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=sonos.0.root.192_168_178_53.favorites_set, timerId=undefined) => {"val":"]","ack":true,"ts":1579710214605,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1579552969877}
                                      22.1.2020, 17:45:21.998	[info ]: javascript.0 (1239) script.js.sonos-script: setForeignState(id=javascript.0.Sonos.192_168_178_53.sonosFavoriteListHtml, state={"val":"<table>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '1LIVE')\">\n\t\t<td><div class=\"favoritesonosTitle\">1. 1LIVE</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'ffn')\">\n\t\t<td><div class=\"favoritesonosTitle\">2. ffn</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'N-JOY')\">\n\t\t<td><div class=\"favoritesonosTitle\">3. N-JOY</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'Radio Sauerland')\">\n\t\t<td><div class=\"favoritesonosTitle\">4. Radio Sauerland</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'WDR 2 - Ruhrgebiet')\">\n\t\t<td><div class=\"favoritesonosTitle\">5. WDR 2 - Ruhrgebiet</div></td>\n\t</tr>\n</table>\n<script>let element = document.getElementById(\"currentsonosFavorite\");if (element != undefined) element.scrollIntoView(true);</script>","ack":true})
                                      22.1.2020, 17:45:22.001	[warn ]: javascript.0 (1239) script.js.sonos-script: setForeignState(id=javascript.0.Sonos.192_168_178_53.sonosFavoriteListHtml, state={"val":"<table>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '1LIVE')\">\n\t\t<td><div class=\"favoritesonosTitle\">1. 1LIVE</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'ffn')\">\n\t\t<td><div class=\"favoritesonosTitle\">2. ffn</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'N-JOY')\">\n\t\t<td><div class=\"favoritesonosTitle\">3. N-JOY</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'Radio Sauerland')\">\n\t\t<td><div class=\"favoritesonosTitle\">4. Radio Sauerland</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'WDR 2 - Ruhrgebiet')\">\n\t\t<td><div class=\"favoritesonosTitle\">5. WDR 2 - Ruhrgebiet</div></td>\n\t</tr>\n</table>\n<script>let element = document.getElementById(\"currentsonosFavorite\");if (element != undefined) element.scrollIntoView(true);</script>","ack":true}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                      22.1.2020, 17:45:22.002	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=sonos.0.root.192_168_178_53.favorites_set, timerId=undefined) => {"val":"]","ack":true,"ts":1579710214605,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1579552969877}
                                      22.1.2020, 17:45:22.006	[info ]: javascript.0 (1239) script.js.sonos-script: setForeignState(id=javascript.0.Sonos.192_168_178_53.customFavoriteListHtml, state={"val":"<table>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '\"')\">\n\t\t<td><div class=\"favoritesonosTitle\">1. \"</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '\"')\">\n\t\t<td><div class=\"favoritesonosTitle\">2. \"</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '[')\">\n\t\t<td><div class=\"favoritesonosTitle\">3. [</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', ']')\">\n\t\t<td><div class=\"favoritesonosTitle\">4. ]</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '1')\">\n\t\t<td><div class=\"favoritesonosTitle\">5. 1</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'E')\">\n\t\t<td><div class=\"favoritesonosTitle\">6. E</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'I')\">\n\t\t<td><div class=\"favoritesonosTitle\">7. I</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'L')\">\n\t\t<td><div class=\"favoritesonosTitle\">8. L</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'V')\">\n\t\t<td><div class=\"favoritesonosTitle\">9. V</div></td>\n\t</tr>\n</table>\n<script>let element = document.getElementById(\"currentsonosFavorite\");if (element != undefined) element.scrollIntoView(true);</script>","ack":true})
                                      22.1.2020, 17:45:22.007	[warn ]: javascript.0 (1239) script.js.sonos-script: setForeignState(id=javascript.0.Sonos.192_168_178_53.customFavoriteListHtml, state={"val":"<table>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '\"')\">\n\t\t<td><div class=\"favoritesonosTitle\">1. \"</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '\"')\">\n\t\t<td><div class=\"favoritesonosTitle\">2. \"</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '[')\">\n\t\t<td><div class=\"favoritesonosTitle\">3. [</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', ']')\">\n\t\t<td><div class=\"favoritesonosTitle\">4. ]</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', '1')\">\n\t\t<td><div class=\"favoritesonosTitle\">5. 1</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'E')\">\n\t\t<td><div class=\"favoritesonosTitle\">6. E</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'I')\">\n\t\t<td><div class=\"favoritesonosTitle\">7. I</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'L')\">\n\t\t<td><div class=\"favoritesonosTitle\">8. L</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('sonos.0.root.192_168_178_53.favorites_set', 'V')\">\n\t\t<td><div class=\"favoritesonosTitle\">9. V</div></td>\n\t</tr>\n</table>\n<script>let element = document.getElementById(\"currentsonosFavorite\");if (element != undefined) element.scrollIntoView(true);</script>","ack":true}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                      22.1.2020, 17:45:22.022	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=sonos.0.root.192_168_178_53.favorites_list_array, timerId=undefined) => {"val":["1LIVE","ffn","N-JOY","Radio Sauerland","WDR 2 - Ruhrgebiet"],"ack":true,"ts":1579710340775,"q":0,"from":"system.adapter.sonos.0","user":"system.user.admin","lc":1579249377671}
                                      22.1.2020, 17:45:22.023	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=javascript.0.Sonos.192_168_178_53.customFavoriteListArray, timerId=undefined) => {"val":"[\"1LIVE\"]","ack":true,"ts":1579545075420,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1579545075420}
                                      22.1.2020, 17:45:22.024	[info ]: javascript.0 (1239) script.js.sonos-script: setForeignState(id=javascript.0.Sonos.192_168_178_53.customFavoriteConfigHtml, state={"val":"<table>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteRemove', '1LIVE')\">\n\t\t<td><div class=\"favoritesonosTitle removeFav\">1. 1LIVE</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteAdd', 'ffn')\">\n\t\t<td><div class=\"favoritesonosTitle addFav\">2. ffn</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteAdd', 'N-JOY')\">\n\t\t<td><div class=\"favoritesonosTitle addFav\">3. N-JOY</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteAdd', 'Radio Sauerland')\">\n\t\t<td><div class=\"favoritesonosTitle addFav\">4. Radio Sauerland</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteAdd', 'WDR 2 - Ruhrgebiet')\">\n\t\t<td><div class=\"favoritesonosTitle addFav\">5. WDR 2 - Ruhrgebiet</div></td>\n\t</tr>\n</table>\n","ack":true})
                                      22.1.2020, 17:45:22.025	[warn ]: javascript.0 (1239) script.js.sonos-script: setForeignState(id=javascript.0.Sonos.192_168_178_53.customFavoriteConfigHtml, state={"val":"<table>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteRemove', '1LIVE')\">\n\t\t<td><div class=\"favoritesonosTitle removeFav\">1. 1LIVE</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteAdd', 'ffn')\">\n\t\t<td><div class=\"favoritesonosTitle addFav\">2. ffn</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteAdd', 'N-JOY')\">\n\t\t<td><div class=\"favoritesonosTitle addFav\">3. N-JOY</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteAdd', 'Radio Sauerland')\">\n\t\t<td><div class=\"favoritesonosTitle addFav\">4. Radio Sauerland</div></td>\n\t</tr>\n\t<tr onclick=\"vis.setValue('javascript.0.Sonos.192_168_178_53.customFavoriteAdd', 'WDR 2 - Ruhrgebiet')\">\n\t\t<td><div class=\"favoritesonosTitle addFav\">5. WDR 2 - Ruhrgebiet</div></td>\n\t</tr>\n</table>\n","ack":true}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                      22.1.2020, 17:45:22.026	[info ]: javascript.0 (1239) script.js.sonos-script: setTimeout(ms=2000)
                                      22.1.2020, 17:45:24.038	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=sonos.0.root.192_168_178_53.favorites_list_array, timerId=undefined) => {"val":["1LIVE","ffn","N-JOY","Radio Sauerland","WDR 2 - Ruhrgebiet"],"ack":true,"ts":1579710340775,"q":0,"from":"system.adapter.sonos.0","user":"system.user.admin","lc":1579249377671}
                                      22.1.2020, 17:45:24.040	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=javascript.0.Sonos.192_168_178_53.customFavoriteListArray, timerId=undefined) => {"val":"[\"1LIVE\"]","ack":true,"ts":1579545075420,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1579545075420}
                                      22.1.2020, 17:45:24.042	[info ]: javascript.0 (1239) script.js.sonos-script: setForeignState(id=javascript.0.Sonos.192_168_178_53.customFavoriteListArray, state={"val":[],"ack":true})
                                      22.1.2020, 17:45:24.043	[warn ]: javascript.0 (1239) script.js.sonos-script: setForeignState(id=javascript.0.Sonos.192_168_178_53.customFavoriteListArray, state={"val":[],"ack":true}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                      22.1.2020, 17:47:12.876	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=javascript.0.Sonos.192_168_178_53.customFavoriteListArray, timerId=undefined) => {"val":"[\"1LIVE\"]","ack":true,"ts":1579545075420,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1579545075420}
                                      22.1.2020, 17:47:12.889	[info ]: javascript.0 (1239) script.js.sonos-script: getState(id=sonos.0.root.192_168_178_53.favorites_list_array, timerId=undefined) => {"val":["1LIVE","ffn","N-JOY","Radio Sauerland","WDR 2 - Ruhrgebiet"],"ack":true,"ts":1579710340775,"q":0,"from":"system.adapter.sonos.0","user":"system.user.admin","lc":1579249377671}
                                      22.1.2020, 17:47:12.895	[error]: javascript.0 (1239)     at customFavoritesAddRemove (script.js.sonos-script:434:37)
                                      22.1.2020, 17:47:12.896	[error]: javascript.0 (1239)     at Object.<anonymous> (script.js.sonos-script:268:17)
                                      • MicM Mic
                                        Hey Tim,
                                        MicM
                                        MicM
                                        Mic
                                        Hey @tim210 das hast du noch nicht beantwortet ;-) :
                                        • MicM Mic
                                          T
                                          T
                                          tim210
                                          @Mic
                                          Hey wie meinst du das mit den Sonderzeichen? Sonos-Favoriten (Sonos-App)?
                                          Da hab ich nur die 5 Radio Sender.
                                          84.2k
