  4. Test Adapter EnOcean v0.3.x
    6.4k
enocean
265 Beiträge 31 Kommentatoren 88.9k Aufrufe 12 Beobachtet
  • 9 Offline
    9 Offline
    9_Mad-Max_5
    #209
    @Jey-Cee :
    Nun habe ich es nochmal bedient.
    Das ist ein komplettes öffnen auf kipp und schließen des Fensters.
    Der letzte state ist wie man sehen kann gekippt.
    Auch wenn nun das Fenster wieder geschlossen ist.
    enocean.0	2019-11-22 15:15:02.021	debug	(4152) else: window_handle
    enocean.0	2019-11-22 15:15:02.019	debug	(4152) variables to set : {"window_handle":2}
    enocean.0	2019-11-22 15:15:02.014	debug	(4152) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-22 15:15:02.012	debug	(4152) Packet type: 1
    enocean.0	2019-11-22 15:15:02.011	debug	(4152) Received raw message: 55000707017af6d0019b0ffa2000ffffffff5c00
    enocean.0	2019-11-22 15:15:01.549	debug	(4152) else: window_handle
    enocean.0	2019-11-22 15:15:01.548	debug	(4152) variables to set : {"window_handle":1}
    enocean.0	2019-11-22 15:15:01.548	debug	(4152) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-22 15:15:01.547	debug	(4152) Packet type: 1
    enocean.0	2019-11-22 15:15:01.546	debug	(4152) Received raw message: 55000707017af6c0019b0ffa2000ffffffff5900
    enocean.0	2019-11-22 15:14:52.379	debug	(4152) else: window_handle
    enocean.0	2019-11-22 15:14:52.378	debug	(4152) variables to set : {"window_handle":2}
    enocean.0	2019-11-22 15:14:52.377	debug	(4152) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-22 15:14:52.376	debug	(4152) Packet type: 1
    enocean.0	2019-11-22 15:14:52.374	debug	(4152) Received raw message: 55000707017af6d0019b0ffa2000ffffffff5b00
    enocean.0	2019-11-22 15:14:52.188	debug	(4152) else: window_handle
    enocean.0	2019-11-22 15:14:52.187	debug	(4152) variables to set : {"window_handle":1}
    enocean.0	2019-11-22 15:14:52.185	debug	(4152) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-22 15:14:52.184	debug	(4152) Packet type: 1
    enocean.0	2019-11-22 15:14:52.183	debug	(4152) Received raw message: 55000707017af6e0019b0ffa2000ffffffff5c00
    enocean.0	2019-11-22 15:14:52.044	debug	(4152) else: window_handle
    enocean.0	2019-11-22 15:14:52.043	debug	(4152) variables to set : {"window_handle":2}
    enocean.0	2019-11-22 15:14:52.041	debug	(4152) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-22 15:14:52.041	debug	(4152) Packet type: 1
    enocean.0	2019-11-22 15:14:52.039	debug	(4152) Received raw message: 55000707017af6d0019b0ffa2000ffffffff5b00
    • 9 9_Mad-Max_5
      @Jey-Cee :
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      #210
      @9_Mad-Max_5 soweit ich das beurteilen kann ist der State entsprechend den Datentelegrammen OK. Ich hab keinen dieser Griffe und hab auch die Integration dafür nicht gemacht, aber wenn ich das richtig verstehe ist da ein Vibrationssensor drin und der scheint recht empfindlich zu sein. Deshalb springt der immer auf tilt (geöffnet).
      Da ist Software seitig nichts zu machen, vielleicht kann man die Empfindlichkeit am Griff einstellen.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • 9 Offline
        9 Offline
        9_Mad-Max_5
        #211
        @Jey-Cee
        Soweit ich das weis wird durch die bewegung des Griffs ein elektrischer impuls ausgesendet.
        Hierbei geht der griff recht schwer und man bewegt ihn in der idee gegen einen Dynamo.
        Dieser kennt den Ausgangspunkt und bei einer Drehung um etwa 90° sendet er open.
        Weist du wer diese Integration gemacht hat?
        Bzw wie komme ich weiter mit der nicht guten erkennung?
        • 9 Offline
          9 Offline
          9_Mad-Max_5
          #212
          @Jey-Cee
          benutzt du node-enocean?
          Hast du gesehen das es mittlerweile was neues von ihm gibt?
          Es heißt enocean-js. Leider verstehe ich nicht genau was es ist um ehrlich zu sein.
          Könnte man das anstatt als basis für den enocean Adapter benutzen?
          https://github.com/enocean-js/enocean-js
          • 9 9_Mad-Max_5
            @Jey-Cee
            Jey CeeJ Online
            Jey CeeJ Online
            Jey Cee
            schrieb am zuletzt editiert von Jey Cee
            #213
            @9_Mad-Max_5 ja das war @Darnat, der ist aber wohl schon lange nicht mehr hier gewesen.
            Wie gesagt das Problem liegt am/im Griff der sendet ein Datentelegramm und das wird interpretiert. Wenn man am Griff nichts einstellen kann ist da nix zu machen.
            Da hilft auch keine andere Basis.
            Aber der EnOcean Adapter nutzt seine eigene Basis an, die haben Darnat, AlCalzone und ich geschrieben.
            • 9 Offline
              9 Offline
              9_Mad-Max_5
              #214
              @Jey-Cee ah ok ihr habt das alle zusammen gemacht.
              Gibt es eine möglichkeit die rohdaten anzusehen?
              Also das was der enocean 300 Stick selbst empfängt?
              Der Adapter interpretiert doch sicherlich die Telegramme die eingehen oder?
              • 9 9_Mad-Max_5
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                #215
                @9_Mad-Max_5 klar die siehst du schon im Log:
                • 9 Offline
                  9 Offline
                  9_Mad-Max_5
                  #216
                  @Jey-Cee
                  Das heist der ganze String sind die RAW nutzdaten richtig?
                  Aber bei dem ersten Tilt oder 2 oder gekippt endet es auf ffffffff5b00
                  Das war auch ein tatsächliches gekippt.
                  Beim letzten tilt was eigentlich ein closed sein müsste endet es mit ffffffff5c00
                  Ist hier vl was falsch interpretiert worden?
                  • 9 9_Mad-Max_5
                    @Jey-Cee
                    Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    #217
                    @9_Mad-Max_5 ich sagte ja bereits müsste mich erst mit den bytecodes beschäftigen. Laut beschreibung sollte der griff sogar die Drehrichtung erkennen, es gibt 8 oder mehr verschiedene codes.
                    • 9 Offline
                      9 Offline
                      9_Mad-Max_5
                      #218
                      @Jey-Cee
                      Kann ich dir irgendwie helfen indem ich mal noch mehr logge?
                      Am besten sagst du mir kurz was du sehen möchtest.
                      • 9 9_Mad-Max_5
                        @Jey-Cee
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #219
                        @9_Mad-Max_5 was noch interessant ist in welche Richting die jeweiligen griffe gedreht werden. Also von Unten (geschlossen) nach oben, linls oder rechts herum. Das macht einen Unterschied.
                        Vielleicht auch einfach mal mit Unterschiedlichen Geschwindigkeiten
                        • 9 Offline
                          9 Offline
                          9_Mad-Max_5
                          #220
                          @Jey-Cee
                          Ich drehe ihn Links herum werde aber gleich mal ein log machen.
                          • 9 Offline
                            9 Offline
                            9_Mad-Max_5
                            #221
                            @Jey-Cee
                            Hat doch etwas gedauert bis ich dazu kam.
                            Also:
                            Griff ist geschlossen:
                            Eine Öffnung mit dem Uhrzeigersinn auf die Schwenk oder auch offen Stellung
                            enocean.0	2019-11-24 14:04:41.424	debug	(1257) else: window_handle
                            enocean.0	2019-11-24 14:04:41.423	debug	(1257) variables to set : {"window_handle":1}
                            enocean.0	2019-11-24 14:04:41.422	debug	(1257) Message for ID 019b0ffa has been received.
                            enocean.0	2019-11-24 14:04:41.422	debug	(1257) Packet type: 1
                            enocean.0	2019-11-24 14:04:41.421	debug	(1257) Received raw message: 55000707017af6e0019b0ffa2000ffffffff5f00
                            Ich lasse den Griff los und warte 20 Sekunden.
                            Anschließendes schließen dieses mal gegen den Uhrzeigersinn
                            enocean.0	2019-11-24 14:04:55.999	debug	(1257) else: window_handle
                            enocean.0	2019-11-24 14:04:55.998	debug	(1257) variables to set : {"window_handle":2}
                            enocean.0	2019-11-24 14:04:55.998	debug	(1257) Message for ID 019b0ffa has been received.
                            enocean.0	2019-11-24 14:04:55.997	debug	(1257) Packet type: 1
                            enocean.0	2019-11-24 14:04:55.997	debug	(1257) Received raw message: 55000707017af6d0019b0ffa2000ffffffff5c00
                            Fenster wird als gekippt detektiert.
                            Auch scheint es mir bei zu schnellen Handlungen im Testsenario zu Problemen zu kommen.
                            • 9 Offline
                              9 Offline
                              9_Mad-Max_5
                              #222
                              @Jey-Cee
                              Er wird schnell mit dem Uhrzeigersinn in Richtung kippen gedreht.
                              enocean.0	2019-11-24 14:10:38.247	debug	(1257) else: window_handle
                              enocean.0	2019-11-24 14:10:38.246	debug	(1257) variables to set : {"window_handle":2}
                              enocean.0	2019-11-24 14:10:38.244	debug	(1257) Message for ID 019b0ffa has been received.
                              enocean.0	2019-11-24 14:10:38.243	debug	(1257) Packet type: 1
                              enocean.0	2019-11-24 14:10:38.242	debug	(1257) Received raw message: 55000707017af6d0019b0ffa2000ffffffff5c00
                              enocean.0	2019-11-24 14:10:38.039	debug	(1257) else: window_handle
                              enocean.0	2019-11-24 14:10:38.038	debug	(1257) variables to set : {"window_handle":1}
                              enocean.0	2019-11-24 14:10:38.036	debug	(1257) Message for ID 019b0ffa has been received.
                              enocean.0	2019-11-24 14:10:38.035	debug	(1257) Packet type: 1
                              enocean.0	2019-11-24 14:10:38.034	debug	(1257) Received raw message: 55000707017af6e0019b0ffa2000ffffffff5c00
                              Dort verhaart der griff für ca. 40 Sekunden.
                              Von dort wird er schnell gegen den Uhrzeigersinn geschlossen ohne in der geöffnet Position zu verhaaren.
                              enocean.0	2019-11-24 14:11:23.683	debug	(1257) else: window_handle
                              enocean.0	2019-11-24 14:11:23.681	debug	(1257) variables to set : {"window_handle":2}
                              enocean.0	2019-11-24 14:11:23.680	debug	(1257) Message for ID 019b0ffa has been received.
                              enocean.0	2019-11-24 14:11:23.679	debug	(1257) Packet type: 1
                              enocean.0	2019-11-24 14:11:23.673	debug	(1257) Received raw message: 55000707017af6d0019b0ffa2000ffffffff5c00
                              enocean.0	2019-11-24 14:11:22.972	debug	(1257) else: window_handle
                              enocean.0	2019-11-24 14:11:22.972	debug	(1257) variables to set : {"window_handle":1}
                              enocean.0	2019-11-24 14:11:22.971	debug	(1257) Message for ID 019b0ffa has been received.
                              enocean.0	2019-11-24 14:11:22.971	debug	(1257) Packet type: 1
                              enocean.0	2019-11-24 14:11:22.970	debug	(1257) Received raw message: 55000707017af6c0019b0ffa2000ffffffff5900
                                mustang
                                #223
                                Moin - ich hab mich gerade erst angemeldet und iobroker vor 4 Tagen unter Kubuntu auf einem Kleinrechner installiert. Als Funkempfänger dient ein enocean-USB-Stick 300 mit externer Antenne.
                                Von Eltako soll ein TF-FKE Fensterkontakt (mit zwei Schaltzuständen) zum Einsatz kommen. Laut Beschreibung von Eltako wird ein Funktelegramm "geschlossen 0xF0" und "offen 0xE0" gesendet.
                                Entsprechend meines Logs in iobroker befinden sich die gesendeten Werte NICHT im String am Ende "ffffffff3700" sondern "55000707017af6(f0)fef6e05f2000ffffffff3700" unmittelbar vor der ID (fef6e05f). Das am Ende könnte vielleicht auch der RSSI-Wert des TF-FKE sein(?), jedoch sind die Schaltzustände bei meinem Kontakt mit Sicherheit an der von mir markierten Stelle. Ich weiß nur noch nicht, wie das auswerten soll - Programmieren ist nicht ganz so meins.
                                Das Log:
                                enocean.0 2019-12-10 05:18:20.204 debug (10372) variables to set : {}
                                enocean.0 2019-12-10 05:18:20.203 debug (10372) Message for ID fef6e05f has been received.
                                enocean.0 2019-12-10 05:18:20.203 debug (10372) Packet type: 1
                                enocean.0 2019-12-10 05:18:20.202 debug (10372) Received raw message: 55000707017af6e0fef6e05f2000ffffffff3c00
                                enocean.0 2019-12-10 05:18:19.148 debug (10372) variables to set : {}
                                enocean.0 2019-12-10 05:18:19.147 debug (10372) Message for ID fef6e05f has been received.
                                enocean.0 2019-12-10 05:18:19.147 debug (10372) Packet type: 1
                                enocean.0 2019-12-10 05:18:19.146 debug (10372) Received raw message: 55000707017af6f0fef6e05f2000ffffffff3c00
                                enocean.0 2019-12-10 05:17:16.426 debug (10372) variables to set : {}
                                enocean.0 2019-12-10 05:17:16.425 debug (10372) Message for ID fef6e05f has been received.
                                enocean.0 2019-12-10 05:17:16.424 debug (10372) Packet type: 1
                                enocean.0 2019-12-10 05:17:16.424 debug (10372) Received raw message: 55000707017af6e0fef6e05f2000ffffffff3700
                                enocean.0 2019-12-10 05:17:15.356 debug (10372) variables to set : {}
                                enocean.0 2019-12-10 05:17:15.355 debug (10372) Message for ID fef6e05f has been received.
                                enocean.0 2019-12-10 05:17:15.352 debug (10372) Packet type: 1
                                enocean.0 2019-12-10 05:17:15.352 debug (10372) Received raw message: 55000707017af6f0fef6e05f2000ffffffff3700
                                enocean.0 2019-12-10 05:16:54.556 debug (10372) system.adapter.admin.0: logging true
                                  mustang
                                  schrieb am zuletzt editiert von mustang
                                  #224
                                  @9_Mad-Max_5 So gesehen sehe ich bei dir die drei Schaltzustände: c0, d0, und e0! Mit der Drehgeschwindigkeit dürfte das nichts zu tun haben.
                                  • 9 Offline
                                    9 Offline
                                    9_Mad-Max_5
                                    #225
                                    @mustang
                                    Das ist sehr gut möglich.
                                    Dann hätte ich bei meiner einbau Position folgende Postionen:
                                    Offen mit Uhrzeigersinn: e0
                                    Offen gegen Uhrzeigersinn: c0
                                    Gekippt mit Uhrzeigersinn: d0
                                    Geschlossen gegen Uhrzeigersinn: d0
                                    Warum verstehe ich auch nicht.
                                    Normal müsste das ja aufgrund der Richtung alleine eine andere Nummer bekommen.
                                    @Jey-Cee
                                    Könnte man Aufgrund des vorigen Zustands den geschlossen neu setzten. Also wenn ich von einem c0 komme wird es zu einem geschlossen?
                                    • 9 Offline
                                      9 Offline
                                      9_Mad-Max_5
                                      #226
                                      uff ich habe heute nochmal ein wenig getestet auch mit einem anderen Griff.
                                      Bei dem klappt alles Problemlos es scheint mir so als wäre deine Software bis auf die Auto Erkennung Problemlos.
                                      Hier wurden beide als EnOcean Blinds and Shutter erkannt.
                                      • 9 9_Mad-Max_5
                                        Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        #227
                                        @9_Mad-Max_5 OK das ist positiv. Auto erkennung muss ich mir anschauen wie das kommt.
                                          mustang
                                          #228
                                          @Jey-Cee
                                          So - jetzt hab ich mal wieder etwas Zeit gefunden mich mit den enocean-Modulen zu beschäftigen.
                                          Zur Zeit habe ich drei Eltako - 1x TF-FTE, 1x TF-FKe, 1x FSM14-UC. Alle werden als Light and Blind Control automatisch erkannt. Der FSM14 wird unter Objekte korrekt mit 4 Kanälen eingebunden und die Statusanzeige wechselt richtigerweise von false auf true bei entsprechendem Signal am Eingang jedes einzelnen Kanals. Was mir jetzt nicht klar ist, daß die TF-FKE und TF-FTE als einfache On/OFF-Schalter ebenfalls mit 4 Kanälen eingebunden werden und auf keinem Kanal bei Betätigung des Schalters eine Zustandsänderung von false auf true erfolgt? Erwarten würde ich auf mindestens einem Kanal eine Änderung. Wie schon von mir geschrieben, werden nur zwei Codes übermittelt. Die Auswertung des RSSI ist bei allen vorhanden.
