  4. js-controller 2 jetzt für alle im Stable
js-controllerjs-controller 2
556 Beiträge 74 Kommentatoren 209.4k Aufrufe 56 Beobachtet
  • P Offline
    piForscher
    #184
    ich habe mein Multihost-System klassisch aktualisiert, also erst machen, dann lesen.
    Deswegen habe ich den Master aktualisiert und jetzt geht es auf dem Slave nicht:
    /opt/iobroker $ sudo npm install iobroker.js-controller
    > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.11.3
    npm version >= 5: disabling package-lock
    > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    fs.js:114
        throw err;
    Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
        at Object.mkdirSync (fs.js:757:3)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:189:58)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:653:27
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:691:15)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3193:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:38)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@1.5.14 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@1.5.14 install script.
    npm ERR!     /root/.npm/_logs/2019-11-20T19_02_39_563Z-debug.log
    Hat jemand eine Idee, wie ich das wieder flott kriege ?
    Danke!
    Master: Ubuntu
    Slave: Raspi
    node: 10.17.0
    nodejs: 10.17.0
    44 HM-Geräte mit CCU2
    iobroker auf MSI Ubuntu, Raspi2 und RaspiB.
    dslraserD apollon77A 2 Antworten Letzte Antwort
    • P piForscher
      NPM version: 6.11.3
      fs.js:114
          throw err;
      npm ERR! errno 1
      npm ERR!
      Danke!
      Master: Ubuntu
      Slave: Raspi
      node: 10.17.0
      nodejs: 10.17.0
      dslraserD Offline
      dslraserD Offline
      dslraser
      #185
      @piForscher
      2.Post von oben
      "9. Uups, ich habe meinen Master zuerst aktualisiert und jetzt können sich die Slaves nicht mehr verbinden. Was nun?
      Alles halb so wild, die Slaves müssen jetzt nur leicht anders aktualisiert werden:
      ioBroker stoppen, Backup machen
      Prüfen das keine Prozesse mehr laufen (ps auxww|grep io und ps auxww|grep backup)
      im ioBroker Verzeichnis npm install iobroker.js-controller ausführen. Falls es dabei auf Linux zu Fehlern kommt und nicht funktioniert bitte sudo -u iobroker -H npm install iobroker.js-controller nutzen.
      starten"
      P 1 Antwort Letzte Antwort
      • dslraserD dslraser
        @piForscher
        2.Post von oben
        starten"
        piForscher
        schrieb am zuletzt editiert von piForscher
        #186
        @dslraser Ja, genau das habe ich gemacht. aber ich bekomme leider einen permission Fehler (s.o.)...
        Beim zweiten Weg sagt er, dass es den User nicht gibt.
        Johannes BauerstatterJ 1 Antwort Letzte Antwort
        • P piForscher
          Johannes BauerstatterJ Offline
          #187
          Hallo, kann mir bitte jemand helfen? Bekomme bei den Befehlen im ersten Post
          Linux:
              Mindestanforderung: Node.js 8.x, besser 10.x installieren! Prüfen mit node -v. Update nötig? -> Bitte im Text lesen!
              Reihenfolge: Slave-Systeme zuerst aktualisieren! Master zuletzt!
              iobroker update - Repository updaten und schauen ob Update angeboten wird!
              iobroker stop -ioBroker stoppen. Prüfen das keine Prozesse (auch ggf. Backups o.ä.) mehr laufen/hängen!
              iobroker upgrade self - Das eigentliche Update
              iobroker start - ioBroker wieder starten
          folgende Fehlermeldung:
          pi@raspberrypi:~ $ iobroker stop
          -bash: /usr/bin/iobroker: /usr/bin/bash: bad interpreter: No such file or directory
          Es läuft auf einen Raspi4 unter Buster Light. Bin im Moment auf 5.1.14 js-controller. Node Version 10.17.0.
          • O Oli
            ich bekomme seit dem Update folgende Logeinträge:
            host.ioBroker	2019-11-20 18:46:12.003	error	instance system.adapter.bring.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.ioBroker	2019-11-20 18:46:12.003	error	Caught by controller[4]: (node:22942) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
            host.ioBroker	2019-11-20 18:46:12.002	error	Caught by controller[3]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:304:14)
            host.ioBroker	2019-11-20 18:46:12.002	error	Caught by controller[3]: at handleError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:190:15)
            host.ioBroker	2019-11-20 18:46:12.002	error	Caught by controller[3]: (node:22942) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
            host.ioBroker	2019-11-20 18:46:12.002	error	Caught by controller[2]: (node:22942) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proc
            host.ioBroker	2019-11-20 18:46:12.002	error	Caught by controller[1]: (node:22942) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
            host.ioBroker	2019-11-20 18:46:12.001	error	Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:304:14)
            host.ioBroker	2019-11-20 18:46:12.001	error	Caught by controller[0]: at handleError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:190:15)
            host.ioBroker	2019-11-20 18:46:12.001	error	Caught by controller[0]: (node:22942) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
            Woran könnte das liegen?
            #188
            @Oli Dieser Fehler kommt wenn der Adapter versucht zu einem 1.5er Controller zu verbinden. Ggf reboote mal
            O 1 Antwort Letzte Antwort
            • falke69F falke69
              Re: js-controller 2 jetzt für alle im Stable
              Hallo zusammen, seit dem aktuellen Update, habe ich von meinem MagicMirror über das MMM-iobroker scheinbar keine Verbindung mehr zur Iobroker Instanz auf meinem zweiten PI.
              Ich bin nach der Updateanleitung vorgegangen. zuerst alle Adapter installiert, danach die Node.js 10 noch aufgespielt. Bis dahin lief alles ohne Probleme. Die Anzeige auf meinem MagicMirror war bis dahin noch in Ordnung. Nach dem ich den controller aktuallisiert hatte, war es mit der Anzeige leider vorbei. Mit downgrade auf die letze stabile Version 1.5.14 lief alles wieder wie früher.
              Hatt sich da ggf. ein Port geändert?
              Hier mal ein Ausschnitt aus der config auf dem MM.
                        config: {
                          host: '192.168.xxx.xxx',
                          port: '8082',
                          https: false,
                    devices: [
                        { name: 'offene Fenster:',
                          deviceStates: [
                                            { id: 'hm-rega.0.3102',},
              Hat vielleicht jemand eine Idee, wie ich das ganze wieder zum laufen bekomme?
              Eine Neuinstallation vom Iobroker brachte leider auch keine Verbesserung.
              #189
              @falke69 naja die Verbinudng läuft ja an der Stelle zum Web Adapter über socket.io denke ich. Daran sollte nichts geändert sein. Gibt es denn Fehlermeldungen auf eem "MagicMirror Host"?
              falke69F 1 Antwort Letzte Antwort
              • P piForscher
                NPM version: 6.11.3
                fs.js:114
                    throw err;
                npm ERR! errno 1
                npm ERR!
                Danke!
                Master: Ubuntu
                Slave: Raspi
                node: 10.17.0
                nodejs: 10.17.0
                #190
                @piForscher Sehr interessant warum er trotz der 2.10 als "Latest" auf npm die alte Version installiert. Häng mal bei dem install ein "@2.1.0" hinten dran
                Ansonsten den Fixer mal nutzen
                • Johannes BauerstatterJ Johannes Bauerstatter
                  Linux:
                  #191
                  @Johannes-Bauerstatter Installation Fixer bitte nutzen
                  • apollon77A apollon77
                    #192
                    @apollon77 Hallo funktioniert leider nicht, da ich iobroker nicht stoppen kann.
                    pi@raspberrypi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                    ioBroker or some processes are still running:
                     io.mqtt.0
                     io.web.0
                     io.sonoff.0
                     io.javascript.0
                     io.cloud.0
                     io.telegram.1
                     io.history.0
                     io.info.0
                     io.text2command.0
                     io.telegram.0
                     io.admin.0
                    Please stop them first and try again!
                    pi@raspberrypi:/opt/iobroker $ iobroker stop
                       io.mqtt.0
                       io.web.0
                       io.sonoff.0
                       io.javascript.0
                       io.cloud.0
                       io.telegram.1
                       io.history.0
                       io.info.0
                       io.text2command.0
                       io.telegram.0
                       io.admin.0
                      #193
                      @Johannes-Bauerstatter Kille einfach die Prozesse manuell wo wie es oben steht. 'ps auxww|grep io' dann manuell mit 'sudo kill -9 Prozessid'
                        falke69F Offline
                        falke69F Offline
                        falke69
                        #194
                        @apollon77
                        Eine Fehlermeldung bekomme ich keine angezeigt. Dort, wo eigentlich die Ausgabe am Display stehen sollte, wird nur ein Strich angezeigt.
                        Da ich leider nicht so viel Ahnung von der Materie habe, weiß ich leider nicht, wie ich prüfen kann, ob ich irgendwie mit einem Befehl prüfen kann, ob es eine Fehlermeldung über die console gibt.
                          piForscher
                          #195
                          @apollon77 Danke für den Vorschlag, hat aber leider nichts geändert:
                          /opt/iobroker $ sudo npm install iobroker.js-controller@2.1.0
                          > iobroker.js-controller@2.1.0 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                          NPM version: 6.11.3
                          > unix-dgram@2.0.2 install /opt/iobroker/node_modules/unix-dgram
                          > node-gyp rebuild
                          gyp WARN EACCES user "pi" does not have permission to access the dev dir "/root/.cache/node-gyp/10.17.0"
                          gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
                          gyp WARN install got an error, rolling back install
                          gyp ERR! configure error
                          gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/unix-dgram/.node-gyp'
                          gyp ERR! System Linux 4.19.66-v7+
                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                          gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                          gyp ERR! node -v v10.17.0
                          gyp ERR! node-gyp -v v5.0.3
                          gyp ERR! not ok
                          > iobroker.js-controller@2.1.0 install /opt/iobroker/node_modules/iobroker.js-controller
                          Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                          fs.js:114
                              throw err;
                              at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:688:58)
                              at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:235:23)
                              at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2408:5)
                              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                              at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                          npm WARN winston-syslog@2.3.0 requires a peer of winston@^3.0.0 but none is installed. You must install peer dependencies yourself.
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules/unix-dgram):
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                          npm ERR! errno 1
                          npm ERR! iobroker.js-controller@2.1.0 install: `node iobroker.js setup first`
                          npm ERR!
                          npm ERR! Failed at the iobroker.js-controller@2.1.0 install script.
                          npm ERR!     /root/.npm/_logs/2019-11-20T19_45_31_850Z-debug.log
                          Und der Fixer:
                          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                          • falke69F falke69
                            @apollon77
                            #196
                            @falke69 Dazu kenne ich mich mit dem MMM Zeug nicht aus ... mach doch da mal ein issue auf dort. Der Web bzw Socketio adapter läuft nach dem Start vom ioBroker?
                            • P piForscher
                              NPM version: 6.11.3
                              > node-gyp rebuild
                              gyp ERR! not ok
                              fs.js:114
                                  throw err;
                              npm ERR! errno 1
                              npm ERR!
                              Und der Fixer:
                              #197
                              @piForscher Also irgendwas ist bei dir ganz gehörig verbogen.
                              Ich an Deiner Stelle würde das iobroker-data Verzeichnis aus dem /op/iobroker wegsichern und mit dem installer iobroker nochmal neu istallieren, dann wieder reinkopieren und alle Adapter nachinstallieren lassen (dauert halt ne ganze Weile)
                                schrieb am zuletzt editiert von Johannes Bauerstatter
                                #198
                                @apollon77 Hab versucht die Prozesse zu killen, starten aber immer wieder neu. Leider hab ich den Admin als erstes gestoppt, sodass ich jetzt auch nicht mehr auf die Oberfläche komme.
                                pi@raspberrypi:~ $ ps auxww|grep io
                                root        12  0.0  0.0      0     0 ?        S    20:54   0:00 [migration/0]
                                root        15  0.0  0.0      0     0 ?        S    20:54   0:00 [migration/1]
                                root        20  0.0  0.0      0     0 ?        S    20:54   0:00 [migration/2]
                                root        25  0.0  0.0      0     0 ?        S    20:54   0:00 [migration/3]
                                root        42  0.0  0.0      0     0 ?        I<   20:54   0:00 [rpciod]
                                root        44  0.0  0.0      0     0 ?        I<   20:54   0:00 [xprtiod]
                                root        48  0.0  0.0      0     0 ?        I<   20:54   0:00 [nfsiod]
                                root        64  0.0  0.0      0     0 ?        I<   20:54   0:00 [DWC Notificatio]
                                message+   330  0.0  0.0   6556  2932 ?        Ss   20:54   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                iobroker  1561  9.4  1.3 156436 52576 ?        Ssl  21:06   0:12 iobroker.js-controller
                                iobroker  1692  1.8  1.0 145236 41544 ?        Sl   21:07   0:01 io.sonoff.0
                                iobroker  1707  4.7  1.8 178836 73316 ?        Sl   21:07   0:04 io.javascript.0
                                iobroker  1772  2.4  1.1 151136 44716 ?        Sl   21:07   0:02 io.telegram.0
                                iobroker  1789  2.7  1.1 150084 44496 ?        Sl   21:07   0:02 io.telegram.1
                                iobroker  1816  2.3  1.2 137712 48360 ?        Sl   21:07   0:02 io.info.0
                                iobroker  2215  1.1  0.9 131464 39200 ?        Sl   21:07   0:00 io.text2command.0
                                iobroker  2232 10.2  1.2 154596 49724 ?        Sl   21:07   0:07 io.mqtt.0
                                iobroker  2247  1.9  1.2 137856 48048 ?        Sl   21:07   0:01 io.web.0
                                pi        2284  0.0  0.0   7348   528 pts/0    S+   21:08   0:00 grep --color=auto io
                                pi@raspberrypi:~ $ sudo kill -9 2247
                                pi@raspberrypi:~ $ sudo kill -9 2232
                                pi@raspberrypi:~ $ sudo kill -9 2215
                                pi@raspberrypi:~ $ sudo kill -9 1816
                                pi@raspberrypi:~ $ sudo kill -9 1789
                                pi@raspberrypi:~ $ sudo kill -9 1772
                                pi@raspberrypi:~ $ sudo kill -9 1707
                                pi@raspberrypi:~ $ sudo kill -9 1692
                                pi@raspberrypi:~ $ sudo kill -9 1561
                                  falke69F Offline
                                  falke69F Offline
                                  falke69
                                  #199
                                  @apollon77 ja der Adapter, so wie alle übrigen, sind ohne Probleme gestartet. In den Logs, konnte ich aktuell keine Fehler finden.
                                  Werde morgen nochmal auf die aktuelle Version des Controllers updaten und dann nochmal schauen, ob in den Logs was zu finden ist.
                                    #200
                                    @Johannes-Bauerstatter sagte in js-controller 2 jetzt für alle im Stable:
                                    Du musst den iobroker.js-controller zuerst killen
                                      #201
                                      @apollon77 Du musst den iobroker.js-controller zuerst killen. Sobald ich diesen kille startet er automatisch wieder neu. Bekomme auch auf Telegram sofort die Meldung Restarting...
                                        #202
                                        @Johannes-Bauerstatter Dann mach mal "sudo systemctl stop iobroker"
                                        Johannes BauerstatterJ 2 Antworten Letzte Antwort
                                          #203
                                          @apollon77 Danke. Das hat funktioniert. Muss ich jetzt bei allen Befehlen vom ersten Post das "sudo systemctl" voran stellen damit es funktioniert?
                                          apollon77A A H 0A 2 Antworten Letzte Antwort
