  4. js-controller 2 jetzt für alle im Stable
js-controllerjs-controller 2
556 Beiträge 74 Kommentatoren 209.4k Aufrufe 56 Beobachtet
    Taliesin
    #152
    hab eben das Update gemacht. Beim updaten gab es eine Menge Fehlermeldungen:
    Update js-controller from @1.5.14 to @2.1.0
    NPM version: 6.11.3
    npm install iobroker.js-controller@2.1.0 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    In file included from ../src/unix_dgram.cc:5:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
    ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                         argv);
    ../../nan/nan.h:1024:46: note: declared here
       NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                         argv);
    ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
    ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                         0, NULL);
                         0, NULL);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       domain      = info[0]->Int32Value();
    In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26,
                     from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63,
                     from ../../nan/nan.h:54,
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       type        = info[1]->Int32Value();
    ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       protocol    = info[2]->Int32Value();
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       fd = info[0]->Int32Value();
    ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[1]);
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       buf = info[1]->ToObject();
    In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63,
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       offset = info[2]->Uint32Value();
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
       V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
    ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       length = info[3]->Uint32Value();
    ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[4]);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    In file included from ../../nan/nan.h:54,
    ../src/unix_dgram.cc: At global scope:
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:420:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78:   required from here
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    (node:29274) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
        at handleError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:190:15)
        at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:304:14)
    (node:29274) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    (node:29274) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    (node:29274) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    Hab danach den Installationsfixer laufen lassen aber hab jetzt trotzdem nach dem Reboot folgende fehler im iobroker Log:
    host.phoscon	2019-11-18 09:40:39.878	info	instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    host.phoscon	2019-11-18 09:40:39.878	error	Caught by controller[0]: at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
    host.phoscon	2019-11-18 09:40:39.878	error	Caught by controller[0]: at emitErrorNT (internal/streams/destroy.js:91:8)
    host.phoscon	2019-11-18 09:40:39.877	error	Caught by controller[0]: at Socket.emit (events.js:198:13)
    host.phoscon	2019-11-18 09:40:39.877	error	Caught by controller[0]: at Socket.socketErrorListener (_http_client.js:392:9)
    host.phoscon	2019-11-18 09:40:39.877	error	Caught by controller[0]: at ClientRequest.emit (events.js:198:13)
    host.phoscon	2019-11-18 09:40:39.877	error	Caught by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
    host.phoscon	2019-11-18 09:40:39.876	error	Caught by controller[0]: at Request.emit (events.js:198:13)
    host.phoscon	2019-11-18 09:40:39.875	error	Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    host.phoscon	2019-11-18 09:40:39.875	error	Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:692:28)
    host.phoscon	2019-11-18 09:40:39.875	error	Caught by controller[0]: at JSON.parse (<anonymous>)
    host.phoscon	2019-11-18 09:40:39.874	error	Caught by controller[0]: SyntaxError: Unexpected token u in JSON at position 0
    deconz.0	2019-11-18 09:40:39.281	info	(1557) Terminated (NO_ERROR): Without reason
    deconz.0	2019-11-18 09:40:39.279	info	(1557) terminating
    deconz.0	2019-11-18 09:40:38.773	error	at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
    deconz.0	2019-11-18 09:40:38.773	error	at emitErrorNT (internal/streams/destroy.js:91:8)
    deconz.0	2019-11-18 09:40:38.773	error	at Socket.emit (events.js:198:13)
    deconz.0	2019-11-18 09:40:38.773	error	at Socket.socketErrorListener (_http_client.js:392:9)
    deconz.0	2019-11-18 09:40:38.773	error	at ClientRequest.emit (events.js:198:13)
    deconz.0	2019-11-18 09:40:38.773	error	at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
    deconz.0	2019-11-18 09:40:38.773	error	at Request.emit (events.js:198:13)
    deconz.0	2019-11-18 09:40:38.773	error	at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    deconz.0	2019-11-18 09:40:38.773	error	at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:692:28)
    deconz.0	2019-11-18 09:40:38.773	error	at JSON.parse (<anonymous>)
    deconz.0	2019-11-18 09:40:38.773	error	(1557) SyntaxError: Unexpected token u in JSON at position 0
    deconz.0	2019-11-18 09:40:38.772	error	(1557) uncaught exception: Unexpected token u in JSON at position 0
    deconz.0	2019-11-18 09:40:38.683	info	(1557) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
    Bin um jede Hilfe dankbar. Hätte gerne wieder ein sauberes Log :-).
    • A H 0A A H 0
      @apollon77 said in js-controller 2 jetzt für alle im Stable:
      @A-H-0 ja wird er an sich. Im Admin müsste er ganz oben auftauchen.
      Falls du den Ordner im Dateisystem meinst dann wird der erst mit dem ersten file was du darin anlegst erzeugt. Ja das ist durchaus blöd. Mach mal einen writeFile Aufruf. Danach ist der sichtbar. Ich leg dazu ein issue an
      Danke! Auch etwas ungewöhnlich, dass Handling im Admin. Ich habe testweise einen DP angelegt, gibt aber kein icon um ihn wieder zu löschen.
      #153
      @A-H-0 Da sollte aber das Löasch Icon unter "Objekte" wie sonst auch existieren
      • T Taliesin
        NPM version: 6.11.3
                             argv);
                             argv);
                             0, NULL);
                             0, NULL);
        #154
        @Taliesin Das waren alles nur Warnungen keine Fehler. Alles ok.
        Deconz bitte beim Deconz Adapter schauen. AUch wenn die Zeile im GitHub was leicht anderes ist sieht es so aus als ob von dem Deconz Service wenn er die Konfig abfragt kein JSON zurückgegeben wird. Also hat nix mit controller zu tun
        • A H 0A A H 0
          #155
          @A-H-0 sagte in js-controller 2 jetzt für alle im Stable:
          Beim DP schon, beim Ordner nicht
          Auch bei neu angelegten
          AlCalzoneA A H 0A 2 Antworten Letzte Antwort
          • apollon77A apollon77
            Taliesin
            #156
            @apollon77
            vielen Dank schon Mal :-). Hab jetzt auf Debug gestellt und mal neu gestartet. im Log sehe ich aber auch nur diese Infos:
            2019-11-18 10:36:46.779  - ESC[32minfoESC[39m: deconz.0 (1560) starting. Version 1.1.2 in /opt/iobroker/node_modul
            2019-11-18 10:36:46.881  - ESC[31merrorESC[39m: deconz.0 (1560) uncaught exception: Unexpected token u in JSON at
            position 0
            2019-11-18 10:36:46.882  - ESC[31merrorESC[39m: deconz.0 (1560) SyntaxError: Unexpected token u in JSON at positio
            n 0
            2019-11-18 10:36:47.388  - ESC[32minfoESC[39m: deconz.0 (1560) terminating
            2019-11-18 10:36:47.389  - ESC[32minfoESC[39m: deconz.0 (1560) Terminated (NO_ERROR): Without reason
            Mir ist auch aufgefallen das ich unter objekte keinen 0_userdata.0 Ordner habe. Sollte der nicht mit der neuen Version da sein?
            HomoranH apollon77A 2 Antworten Letzte Antwort
            • T Taliesin
              @apollon77
              position 0
              n 0
              #157
              @Taliesin sagte in js-controller 2 jetzt für alle im Stable:
              Die Instanz, oder nur den log-Filter?
                Superdad
                #158
                Musste heute früh wieder den Cache in Firefox und Chrom leeren um auf die Seite zu kommen.
                CCU3
                iOBroker auf IntelNUC Proxmox
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #159
                  @Homoran Das Objekt für den Ordner hat ein Attribut dontDelete: true, also gehe ich davon aus, dass das gewollt ist.
                  • AlCalzoneA AlCalzone
                    #160
                    @AlCalzone
                    Sehe ich auch so, gibt auch einen entsprechenden Thread, dass das Verzeichnis immer wieder von den Toten aufersteht.
                    War aber nicht als "Kritik" sondern als Info zur Abklärung bei @A-H-0 gedacht
                      Taliesin
                      #161
                      @Homoran
                      Die Logstufe unter Instanz.
                      Aber glaube hab das Problem gelöst. Hab den deconz Adapter deinstalliert und den Ordner /opt/iobroker/node_modules/iobroker.deconz gelöscht. Danach den Adapter neu installiert.
                      Log ist jetzt auch nach 2 mal neu starten sauber und der fehlende userdata Ordner ist mittlerweile auch aufgetaucht 👍
                      • werner_qW werner_q
                        @UweRLP Ich habe, glaube ich, erfolgreich migriert. Ein wenig holprig, und einiges ist mir unklar. Aber die Instanzen laufen (ich habe eine überschaubare Anzahl, Homematic RF und IP, vis, Flot, IOT, History und Cloud im wesentlichen). Auch stabil, jedenfalls von gestern Abend bis heute.
                        Probleme: Direkt nach der Installation bekam ich die Fehlermeldung, das unter Port 8086 (wo auch der alte ioBroker war) kein admin läuft (oder so) und jetzt abgebrochen wird. Ich habe mich kurz geärgert und als typischer Windows klicki-bunti-User die Installation noch einmal gestartet. Die selbe Meldung, aber ich habe dann festgestellt, dass ich den "alten" ioBroker Dienst manuell beenden und den neuen manuell starten kann und dann war alles gut und hat auch einen Rechnerneustart überlebt. Zweite komische Sache: Welche Node-Version habe ich jetzt? ioBroker sagt im Info-Tab 10, das cmd-Fenster sagt 8. Dürfte aber nicht so wichtig sein.
                        StabilostickS Offline
                        Stabilostick
                        schrieb am zuletzt editiert von Stabilostick
                        #162
                        @werner_q
                        Dann hast Du die Kommandozeile nicht über den Link im Startmenü aufgerufen. Jede ioBroker-Instanz hat dort zwei Links genau für den Zweck, einen für ein vorkonfiguriertes Kommandozeilenfenster und einen für den Admin.
                          @apollon77 Könnte ich dann theoretisch versuchen, die alte Node.js Version und auch die alte ioBroker Installation zu deinstallieren? Und kann ich auch das alte ioBroker-Verzeichnis löschen? (Ich habe ursprünglich vor Jahr und Tag auch den Windows-Installer verwendet und daher eine De-Installations-Option für ioBroker in der Systemsteuerung).
                          Danke für die Unterstützung!
                          Stabilostick
                          #163
                          @werner_q sagte in js-controller 2 jetzt für alle im Stable:
                          Ja. Wenn Du der Meinung bist, dass in der neuen Instanz alles ok ist. Zur Sicherheit kannst Du Dir eine Kopie des alten iobroker-data-Ordners aufheben.
                          Beginnend mit dem neuen Installer kann man einzelne Instanzen über den Installer selbst löschen. Da werden dann auch Dienste und sonstige instanzspezifische Konfigs entfernt und man hat zusätzlich die Möglichkeit, sich einen Abzug des ioBroker-data Ordners aufzuheben.
                            #164
                            @AlCalzone korrekt :-)
                            • T Taliesin
                              @apollon77
                              position 0
                              n 0
                              #165
                              @Taliesin Meine Antwort ist die gleiche wie oben. Bitte Issue beim Adapter öffnen bzw rausfinden warum die Deconz seite wo die Konfig abgeholt wird kein JSON zurückgibt. Hat nichts mit dem Controller zu tun!
                              • E Offline
                                e-i-k-e
                                schrieb am zuletzt editiert von e-i-k-e
                                #166
                                Guten Abend,
                                ich habe seit dem Update von 2.0.39 auf 2.1.0 große Probleme mit meinem IoBroker.
                                Ob dieses Problem nun an dem neuen Js-Controller oder evtl eine andere Ursache hat, kann ich nicht beurteilen.
                                Iobroker (redis/redis) läuft auf einem Intel NUC (Proxmox) in einem Container mit Ubuntu.
                                ioBroker stürzt sporadisch ab und lässt sich nicht wieder startet, auch ein neustart von Proxmox bringt keine Verbesserung.
                                Im Anhang ist die log-Datei zu finden, bitte bis zum ende scrollen ab 15.20 Uhr ist ioBroker nicht mehr zu erreichen und lässt sich auch nicht mehr starten. Nur ein vorher erstellter snapshot kann das System wieder starten lassen.
                                Habe test weise den Fixer drüber laufen lassen. Dieser spuckt plötzlich sehr viele Meldungen raus.
                                Anbei ein Auszug davon.
                                da3be48b27a5af4477f0a1140a701433b3db7136a60197': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/dc': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/94/b8d7797b2752e380d1cf47c7a55a128270ab3b1832f9c784adbcbfdbe81b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/94': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/61/e760160e8107e05f76ca135d8374ac7b8c7786c0547ce9c555cea902d80e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/61': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6/1c4e4b3dc3c6fb34579982f0554d9385b59a2e98b6e6d6594219c6384e46': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6/46e4f928c457b978ce88f39772738dcb5096760a84d945dcb63095c75ff3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/51/7fedfaa7cd933dbb1304a04f5c8aea0e2f76639a150c97a047b0cb57dc62': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/51': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/08/bad04d8ac32f2241b2659718882158c86c01f53845099f9c453f67b03f39': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/08': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/cd/e3a401508c0f1a92aa62ceb9c24eacfc6d282702da0a4b6cb6bd47a2ddbc': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/cd': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe/9c43f3b048ef1201673bfea640b64c9d4b5264f75c3fa308f333a57f6e47': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe/8194f4807b9b6085a2f2e390f8d019e9e53f5c5c1653ee5fb055ca99309e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/cb/d76feb04aeea2cd77b2f0eb08205fcb1508ca9ca2c4c5e1cd4bdcc100a47': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/cb': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a4/ae299f1e3e729d7098795e9e3285ee7b674b05b5efe5d5954725c3930ee0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bd/22e4892cef0bb4f9e69213274833378febde4c117f33212c391bf0f7d119': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bd': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3a/473a66dae428aca5dabba04c2928b4e2eeecd2b359c096572c1061b5c2fc': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f7/ae8abcb39b4f35c14116b197d3ee4cb09729ca8efffb304f4fd11f67c3b0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/d3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a2/1afeb80d67ef938cd56e49c6108229217c5c182d8eded1bf7fded99df5e7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3d/f2f0f797a9b8bc04ff5a617328dd807c77dc2d1a81c8243f65499cc44d81': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bb/e3ebbbd48a30c8b9386f83d99cfbf58708a487a84c35edc9d3709473505d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bb': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/00/3b96abe969aab388681e91bd78b5cc31c2442f23be4bf31a54b0a58732e6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/00': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/7d/ae9bac79ed0bc579c1d312148ac8ccc1093e19c5201ef407838486754e94': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/7d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/ae/de49cf6944cdd240c92851ef11f3895eeb008b10272aab1cec4445140622': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/ae': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/34/34908163c064bbcad301c3fdd7ead62161a272dd90c70819ddace14b7861': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/34': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/93/58ea2565fbb8444f965ef9675842362cfd14ede1ba675c9e205b668fc80e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/93': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/1f/812fbd2f6576d9b47136e0b3c45c98e97b2b0a5b2627cd23b4d2d7def13a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/1f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/76/b307bf2099531873e0b1e3aad52736171cfec1a5a1b172318eb7ad5b336a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/76': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/73/8eade1d8b68283c8566a83f4fe5e4c1048219f28d01bac80087966810210': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/73': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f3/81a49ac1c06b674e36b2f9806e71ec2ea231fdf2d0ed27d4494057760304': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/42/37a652adef68b619fc16b9d625c2949ef61479842fc1964de0fc8f59cb36': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/42': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a7/2f8607e4e45c810d05364e5ff32e5b7cfe679eda67a93820be80876b10e6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc/8b88c4372b5c39f0b3a1e95034483b4a51375fedfe2af7818abd0f1e76ba': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc/0ef7ed77b33b62b931d8e9a09ef845d029b64a7c49025994b28449a26686': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f1/fa42c233e0670045f632ac61bacdd26fbec2535480c71103625f391a6388': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f1': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/56/af929b90dd2b5bf9af2f00d843278312247d4b778e3a3b21216ab0ddc2c7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/56': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f5/434e1f11a531e58fb76713c16b39343a0d442d8bf9a48c74723c43aebb0d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/d0/505f8e28a1b7000cde123d9232e66c95a0259114d60c5a6d4426304ec274': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/d0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/4b/e7e3758c2d19e1b8cf9a59f9a3bb013c0f8040f12ec62bfaa7fb9f279066': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/4b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/6b/b4269307874a79da15ffd7a6ba4bbede653d1a0490b7a08924bf7b5aa19e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/6b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cf/e08864bcda71cda12449f15de938ef01fa6d5c439afddcbb2b8bb3a3f67e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cf': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/e0/c2272d7175091e9df846535741af3cc795e3f8819eda506eec5047ef33be': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/e0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/00/36df83b59945f1327b718bf85b9096766aebb81a14226ccb633b78434219': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/00': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/32/16152c2ccccc38eeeb755adc3efd433cb23baea20fa678e8b19e74e780f5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/32': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96/db732c082b5a904a7ae935037c08343e50e345e5c26864264d7448eee157': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96/be72507b6fc870d80587cbda0bab4fba3321c62a7d82aa97d0715061f49b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/02/a4d888268ff14e42946cd7c95823ef41e95209674fd2846654b819ae5f83': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/02': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/7a/1957bca0c9949aad254fe46114c61fbc7d2cce2e411ff11765c5862d19a2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/7a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82/da1e6e17108be2ddd7f87021521e8bb1fbb576c63c124b588084660944e2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82/283d353be571fd3a81096d7e8fa03e8fe25ad7cbf9370dbcca196d4f709b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/b1/4dd403225670ecc54d9bb66f029473fec9dcae3bae4fe478ff93caa0e7bb': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/b1': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/a1/ed4f9af68a05e530bfa9e38ff6c86f99e4e7c3b591a234a9b399ab033e35': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/a1': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/0c/24e2e5ce0d053d72356aec00cb3bcb62cf36429c906b157eb9cc0e771599': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/0c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/6d/ee6c5b606d31dbc4ad48eaf2d96457498d13144359e2211fd07c1b35d149': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/6d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0/b83e657b12bafc7e4dbf597374a09845ebdfc8300862fe2190072979b03f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0/4fe556f104b09be642895a82afa463fe560d9a0dc8f507efeef825a6905e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/c8/25fb6174489f9eee738a1f70d64c35a084e80e57978f65718efbeb54808d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/c8': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/81/acb1e9ee22b63308732521fb94e2ca1eb9538a418074273ee5cf0373db78': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/81': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a5/6d71d817cd71ea8bc2e2e79c5772127a9c3d907475b75365f896af73af56': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a2/2894ef5992aab46c62615822f4269bfe86c52d633edbcdc9628d82bc9ed2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/52/7f9b06983f2a9167d6a83be35663cc1368166149da11d45ae881f3120541': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/52': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ee/85502d3e649f41a9bac5bcb9716f912ee596f2356b66101192a5df278d0e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ee': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/00/df2874e7ec7673134648181186dbe92d5c86ce2651e2445156e4fc2ce152': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/00': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/01/a3682cefaf787b8e747165953acb4c8295b4a4a6b7240dccebae7de61319': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/01': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/26/5bc5b0f8169f252833a46323cd11c1948ef16a3b2676a2b514bde11b0f24': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/26': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/34/1dea1038910bc69b4fca1995db146c975d75b0a61676729cea425cf9548d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/34': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/0b/41fa759a8c00680f89380affdccdd6235e5932bffef5c6b785bf50828d60': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/0b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/83/357ff6d2b4d78156eca14b9d0fda9fa24177c98365f68b3cc46f08d38c80': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/83': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/bf/3c961a046544d3ec2e4503864ec83b9e773bc76e51e9266e0a58f7087ef2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/bf': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/02/770e04a5c7677acd2b2c3544fbd1096cf305b632922c0c6a2a87256ba22f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/02': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/47/dadb4038d7134c35737d30b1988ec4699a273d60137d2845c10235e0deac': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/47': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/b1/2db50c8d0a2fb4099123888b2a2669d92e2be64d118119fe670b9ca30de4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/b1': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/8d/0088a8a005072e5d28cb1328cf77a15f20b56058f2028ae5ef2dd99c4926': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/8d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ba/4329bdc620971a4c0d92c471d31977e529fdb48af0e0c7234b3365574030': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ba': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/14/a2032208e1c7a62e33f37f602c68fd853567472a6b50a347da7e697fb379': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/14': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/3c/431e6d192a49b59fc29b4a8214c6ce7f06d38e7a326aa79c154c7ad3d857': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/3c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/24/5a3a63f373b73c8aedb555037b4b52193b1b0ab7b9bcc0091a0cc5c94b70': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/24': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/ce/d3351e2727a2b6b6d4080cc056b73f4d3aa5cf23ef1d7b75c2d7da606329': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/ce': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7f/f5a90a8423d33ffa837e8ed57f8d96b4c1e7006cce7035a2ca88d5fe3706': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/8f/50e3707651fecee0ade6da7d20759d45dececaab1fecdf90c9a42cf8d922': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/8f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/d3/7697273802dffa158119427da833e251b88e0e9d4c73d8f5f964476884f4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/d3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/52/9e8c769eb26be17ef9f048b5ef04f8332b2254221e0c0daac3e753181b19': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/52': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/37/62e59a65e3fa96dc48d3adedfd2df02db2590274fa133fea39fbe8edd547': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/37': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b/d738e92d28a95122ca5354c837624c07986f2a8932ac7bda68a293f5185e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b/e39f55cc4a867a7cb6219270fb9e9a185651d8b01a18d37b051a94aabaa3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7d/25e51f2ab1bbcdf5455baaafe3c3a6309de5f615f2ffae63c19c9ae06cf3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/fa/a6a079afd3dd1f324310e7c47c3e23758cab72a45186d1fd22669816616c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/fa': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/6f/fcee44c502a8b6f22637f9e7c48e333fff4dbb696d7a1f139aa3dff264aa': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/6f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/30/2252b187203d7250d1afc85797278dea82dc6c814c83b203383958b29cd6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/30': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/57/74f562d002abd9fd4fa2fadea83170c075f83a0df2ce00cef8b2adaafe73': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/57': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/07/307d217a7e74c1650be66f33e69f694833caa1b55d1086574f2509cb5acf': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/07': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/c4/70b79340f3c3771c289cb21d389234b4bbd8f1b0205307c4854b03a49e16': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/c4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/61/6fb9b18eec6b3afc804af9fd508931055bda5a41b95ed9b792193c848750': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/61': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/51/f076431a8a2711186615c69503b7ebcc4ae98d3408cf258a9f0949fa55cc': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/51': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/c5/8b4e0c746f9dcf84bef48aeba6071577e3780a1cb841037d6ad06f68751e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/c5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/b4/6668c405c1127931b21a3f0d2c39a5460fad651a609e5b4fefb176d1be8e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/b4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f0/6986d038de42bdb42462881e9a82767be8a642e34312a5cf86f98fb9d00c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/5f/6e2956b950b124b9bf3d0e3b14a8ffb59cd858fd75ac433405cc316cc14f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/5f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/78/b9c6d02750f707247c29f429225523868ffa6a5a60c0cc25f1ecc615dd6d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/78': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f7/87042931e5944467d47331c350feb4384bf9143ab6ceebf7108a55905843': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/37/a4d675e1e3f697321e88084ccfeb1928eefc4b7828f2b09cfdff0714a2fb': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/37': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/fa/f87baceab26935686548c742091e7014930673bc1f077574c54c4c6c2d2d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/fa': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1a/4acb93e17b849f731fdc2713e65b1349ce74768503c06c87639c392f6a0f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1f/082d4a06ccf797c3905f27c42bebec5acaf1c6c858a3a5abc48c3dbe82c3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/36/c2fbbfb91ed4e23ae02c15f665a55e56f73e1f774e485f663c63ddd92a59': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/36': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f3/5842983c780cc28425750762f083655b954ec48b5d87f2e2e4afc21dc371': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/8b/e2b51aed1de49b0fd9c7b12abf936739009dafe0ebb80b6d0f959990b1e6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/8b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/46/ed7592e0bc7537e303b400259ce143650ee65dbcf60d0216abdc077e915d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/46': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/a3/7a82019a9db758aaf72f4b337476898ac4f4b990d00182341ac788806e91': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/a3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/52/abeb87386808aec4cd167ec5a1e23a9617536f6be5b6a50b86c312d1dd8b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/52': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/69/7bde42484a73102035894c5c428b6713b26afb4f0eab94d6994207798808': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/69': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/2c/ecf8d7a27f9badae55d265950f4dc536a8bd1b164e88a3e1b6b80b483734': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/2c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/6f/d41f5b4ebdbd368f2fed6b685643bafdcf70fcd5d7aa9a8420610977544b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/6f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/66/b560891cb76c1fa15da8783719ac89328f8a971b3e1f2ffb06a00853fa19': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/66': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/36/e0b9bba658386b1654960be36583e4d41ec8878b58397578d9078858d10a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/36': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/13/9845cf958896ac60fb7bad0f0ee3b10b02cc11bd08613674ac038a741025': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/13': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/1e/d37b96b3ec7ddc16a2fdeba79ec051a6bef7c9112006e6b181f049323403': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/1e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/97/8d51650d6522d0922d4dca4968f1fa1c42b218f74aeb8a2af25bcf9ff98d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/97': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/71/f68a6750f3db4df84a6f6c31eba19daed52dc3c2a615b66b97cea205353b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/71': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/19/35638765772d89997e949c58a55a6045a598729727f1de4bc2d012f0880f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/19': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d3/470c9cbb447615faafb6dfdf54632831f7f96c77771ea06a1eeffba41373': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/a2/d192ea48452222fa74ca6c73d5c4dc9fb3d73b669f84e7b26e26edc7299e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/a2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/11/5ad280305e1c607a1d5b4ac826f7b7ea40efb4aa64871dbbed235cfb1825': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/11': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/8a/b10c99585d0abe29a19f2f7f7bb5d829f7c22af3fd8c33f86514ff11c577': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/8a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4d/16a027afa526cdd80817b59459fb9019ea3f4f330989a3df3b2dd424d31c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/86/caeb58d7dd6f6511597a4a33b82f94a10ef0c71396c9582588bdd21c8c73': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/86': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/2f/0d6de8daa7de9c1a220162737d8aa09280826eb3cff7d6da43b38fcad8c0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/2f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/9c/6fffa7a1f3b1336db5fd1d177f3e1b2efd95f3689885306e8958693c380e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/9c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4c/811e3b437dc243385ceb2a5e7a681f88e9a8c832706a0be2697752e97ca9': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1b/f6b50f4c1ad5ccdba9c6ffc4fbd267713841d8d24039339fd97c4a03bb9a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/7c/02d2df9400272bb9cc56a006541e41460e8973721cd72ae78261e6db876b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/7c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/33/bea802424bc10eed30eed2ac1df5cd8277bdeedab5f08e3c4629fcaa68b6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/33': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/db/96ea9765abd3cc239baac6e194871f5fd7732a3657a7444b8c8513bc8455': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/db': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b5/844264280dfb76a29e7a7afe23fc05d40aac4dd573eea0bec2db2e5a2add': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b1/7f5a9b4981107c0957571c6aea09409de107f9203452fad14a9653b7cd72': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b1': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1e/ae5e7b1c82b02a2af9acccb88bf4da3b2d5d059384f8d92af3c3b76a1a4c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d1/73825d96cbb41bc8c0bf9f2a78d6281633aebedbd052caaf1d51fffa4311': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d1': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/97/fed28c4f00d3eeb0f0e79d50b09bd95e529fff6d4f1a764e73fcda69a842': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/97': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/f6/043b7bf3ca70506f520273ec16fa0316aa9269b2ee01429bb3298c94e053': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/f6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/14/c90049198f353f04aa7296e700da0a56b8c4b0e38184f9039b6724e62125': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/14': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ef/3e25234e1be03662057aeb474090c320ef2e89992c14b616f4c5469babba': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ef': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ec/d14829a7c1af48dbb7ff77fff9319258f8b205c7ce4a8fd95cf46a4bcadd': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ec': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b6/899314477b68fc8d7aad3a64e8285f65984d38c54dcc3939db2606c921ba': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/38/e7c4949c208bda7986ed8052bb24441f6f116b54f6288e257a2aa1b633a3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/38': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/5d/393bfbcabebab0809010c29f6fb7c7f532f8333edc64be087a2ddcde2d86': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/5d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b0/a4331403838762a771b8749ad57d45f57b02407b4e467039188bd126fe96': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/59/4d920c893d5be1a1e54231c8cdd7fc182ea0c735346e4759ffb02c67f870': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/59': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/f9/4ada453499bcc74c6f62ab9565b490a863bc874d691677add95ecf947c78': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/f9': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b7/476b08defc5621c5ae7caf17631ea22fda40726e7c9898862f6ef34402fc': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b3/b16fdff1edd94b37a94bd7db2184982c2238e04c4eb0b665c8a081d3f5a9': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b3': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/39/0d140fe159ac444763e5c4f05d9d2bba1327083675ed20dbbbf63683e7ff': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/39': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/03/f0dd7de970ceaa1f0b8e1bf05bbdfe065f5be795bcfb2e075e7576d7a670': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/03': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/54/4263efad7cfdd6f394d102bca236a76688809923cbe19f10331ded603b89': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/54': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/09/b5ad6166b743ce97673a0966ecde746512cbe18b4d7c310f36f03c01e3bd': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/09': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/88/8351ea69396b436ec7a2595350f815b4a595dd9449f447170068b8307051': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/88': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/01/f85ceaf0ff181f9b0db6422a6a86d713d2931f3c94b9bce872793e4f3bfb': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/01': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/92/646d6eb727e22ebeca12d558cffbe9fd8cf4f5674a4e411e68344640a6d0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/92': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/bf/d2987a7db80f4e0738cc6f2af13aadeaa56311fb9d65373b0e9bb20f67d5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/bf': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/da/4021979edf0d2c56dc28304170e8afe2f90ec1a5620cd987dde84e2fc58b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/da': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/73/47877fb05b9134a2e3b66012ed97767017380d4453582e9f39765e958d09': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/73': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/84/d39f10ff4bdf9bd11450faf4a8bbbe361ef4da77d743fce5adfbd4859d1a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/84': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/3e/151b03bcacd057978b4c891ae842f10b5c2fffcb8c0fe905a0ae7d3751d2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/3e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b/e21fe9c19b958a620cbc71d80f97bfc371bb361573d441294570eb583134': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b/12f2f7af7f950c23d4cdb66d81b57e5ffd679a24f66f54f69674376024a5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/cd/3539b50b6ce10a6099da623467c7a4f0930e6cc79b75ac77aff19c4c82b7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/cd': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/ec/92e2016477c65cf7ae1b6c42f15723842175a9735acc8dd23a6b85afe34a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/ec': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/4a/a53ab2dd740f6401643d51bfee7c2e7d6120dba24b566422e7101b78da3e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/4a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/bd/a6f543a4c160c81541f1941ac3a4f22e24c720cb0812c8a0b4b190f525da': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/bd': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5f/a80eaf748391860ea374caba3171c449c4d9819ea99724eb644ff6db0e91': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e7/836747f2490d9ad67b369ec82fb4e0b82fbb8fe3ab58c500f4dee8c5d7a6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/31/11eb65d70a004ba6dc4f967bae593980ef09d70ba81fd2af497387d1d59a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/31': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/63/49d9d6a2058fb1376caf4de0884b52be6440a5a13a30ac7e5c720c7be0ad': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/63': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/75/0b298e16b2be5f5a50a3c46bd8ebf41296b5430a1faa29b08922bd2b2f14': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/75': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/45/0f087a72405cc722d634bcfedbc5b14d65cdf1e88b133cdde8d8c4c0c160': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/45': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/91/dbfac5a17511327401d3f24dbd4b15e42751a4ca0a9744d3e795cbb30772': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/91': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e4/85c453c0b7c6d00627bbc4a99aacaf9f8afc4a98a767adf60a0ccadbc990': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/69/1d82a0bae7afd711fcef1d246d260691a22315303d31f649187496291a78': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/69': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/c0/673e4f716a0a97692176a610b077c1e4c37f0657b07b69cac7afc9979405': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/c0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/37/c9e69f5074e9a22c766ffcc622280d4e580d2ee0238f670f28199487dd44': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/37': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/3b/7656677b4ce98fa80fbd05eb933b9b5a858fb4a25d07d9ecd22267443c62': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/3b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5b/a5ccd6d9f05959c1c89efc411510f733374f46f5e7c4ee798f587f5ae931': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/30/eb11cf8343b323649a963f633068a14c0cfe8e76c423f2107daa2a419059': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/30': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/be/6e1283f2345247c106f9fd360a38dfd752ea3fc358323729d4095f466da8': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/be': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/57/7f46ee7c4fb819256f5c28a6cd4f231734deae83dd742f2b523f10ac0633': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/57': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/95/fa9c994121ed142a2e5d4f1ac42e1b494f767340cb6ba4e34f0f31facc9d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/95': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/33/e5c1af689be93f794b86f66d7dfbe6bae4e548b2135a4789bf94a09d3372': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/33': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/73/7a110e38bbccbdf42210ae85da034a9311e0f4299050e50f3c8191501c71': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/73': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/12/377ab6ff432fac53c8c672a1bf5732512e5b619173714e383359d443642a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/12': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/61/8cbf374dc4a22dea9866259dd98cca4184f65ebaff7dba6afbeaf6e06fa4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/61': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/08/3ba9ab86283ac5b5641abfdd4a37885231614123fec1c9d9b47a1c12595a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/08': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/fb/8c070eb7c9d840daf6f8862fdf5c462eef4ce470c92316b36076a8ec4ae2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/fb': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b8/c350b4c87e03f50e668f69fdc4840256ed1a3d60fbd3e90d624bd0138004': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b8': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/5d/70974ce696936b845f14e8e48e153f5dd7482eaf1f17a7af992a927115b8': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/5d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/19/b0d987af1fdb73b10ac24ff43db0f296be2745d0cd2bf5119078fac111e7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/19': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/63/c0df8adcf22021b52c33a707d11bb4428944f3147e167201933b77cd6551': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/63': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/4b/40bd19b841405182387e13123d31c6309b162d81d0db86ee52736a9bd643': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/4b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/a6/a58b1280f8bb14298a70a8ef7cdbab9f28d319d511f11ca084211f2bcc05': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/a6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/91/fc3843be160bcbe54a87c70cf0217f9f7166e72d297a198ed0f8cf93d7d5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/91': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/52/cfba3106ef0da44f06a883b7b9d1fc70b8ed2a1d170599f48805f689e53c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/52': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/44/6b35922d71beeb2843639c393d28f2684b260a14e0dc7ec7ce856b28610a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/44': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/6e/1b57fa2c400ae0176683235ee3685bcc4c42f3def62180e77471eb79fca4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/6e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/2f/dc75f5beaa45c77b4d14903f07840533c5357142fdba60d7c4481e4fc5db': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/2f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2/0e3c9e2baf2567a6bd9f81829d3cb6204255d8fbe622583524708853d610': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2/72a6c9df044cb26b10a04bf261bce41420c99f77d49e6a53e767ea3a6fa8': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/da/e8654aad33bbbf62a4857fbf8beed9c4ce05a6b6fee192da0d679cf0e3cc': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/da': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d2/d5d7acda4c2ad2ffbeda6ceb752dfc56f66153eac8ebc8f7ee2c5a8414b8': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/07/ba09e5cbea02069d6fc80814eca98c9ef14b785b54378abf33641eef8753': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/07': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/ac/feef31c8f79f79090b2ddd82e57346ae532d7e69fa53cee8969225ade33e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/ac': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d8/342048477d8d1a66dcf45723307d428757556956d99a5aed2bdb0f2a269b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d8': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/40/a0f8b6ed4650fba1bdce3d598725165dfde297436aa3bbd3c591c6fe4f21': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/40': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d1/54737918360c9f80d2be568380068e5f0c9d2ea370407da34d92a8f687c5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d1': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/f6/492d7af722115ca18f328cce017e91ada962beb0adea68f213393af0928a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/f6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/08/5e07feb6be282ff79bae817d3fd16e5359483cd774f506cad08ba4e58eea': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/08': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/b4/5e8ad2b29fe1334c4aa0178c518b43a732aab578a476f69cb49cc81a8762': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/b4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f0/22cc0b58a3130a20fc0015a98a37eff19452bd09903bad6286495faad602': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5f/066eac5b28b0fc192c75d345a821b4ea45dffebb1c729afd27e4fb90e111': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f5/462c0215e13359a052b9d08b2f00ef669a10531bcf01806ae0106c9e99d0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/cf/8711cafb6666a89091dfc5b318f2c5009e9be2ea25532b176edb9e312c88': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/cf': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/91/a77f215851fd29297a480f3edbed051747f3e7d5ca06d5612c842c1c6e31': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/91': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/3d/8a65927dadb603aa6974e7136c2539d30e27408a36712dc732da8ba52f87': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/3d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/26/8c97b83b5df53797ba6d8937982f6ff0336a8f15282585415484154a85a6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/26': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4d/d8bcde1b0c0e9022e4389a309fcde945357c90955f52a967f55bfecd86c9': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/32/d09169f60fcc3107c776d307f1225766793fc9086be98095a4fcda130355': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/32': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4f/b991304b3c794a52704073ade76bc3fdc85bea273ed875333feee9c50f41': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5c/8292eb35ff5c46c53be1f45609df1b5ad53b1ef7beb53e25830771fff476': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/c4/576ae94b481d6eba722899b489cbd0e629782a11798b7bc8a55fdb728630': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/c4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/15/8f5843e13eebe66d43fb4fce10a5b862a831e8e5cae63e31b326f1376c76': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/15': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f6/38b8038e95b147174eab43053d49e5078953e257487592e1ac94a0aa2544': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f6': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/9f/56df86c5348a44745233ccca8b1cf6d9e372726c0c2bb6404a3274e02c63': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/9f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/1d/255a2fe5c32486b5e3869636f5f541a825ca87912ce55459478af5d5db8f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/1d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/18/13e5f9ff07fea3e2e6cbdabb965524040a2a95e912ce1327641fc2c86a9e': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/18': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b7/3ec33017ccd57f05bcb1cd5b86f58cfad2f5087ec3f70e7697c7ee8fdfd0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/af/43873f6488ed910e6a4c19415fa4f6ec72fab2d58568d8dc39fd00bfe614': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/af': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2/80dc7881806fc9766aaf8871f305013551427a6fc2ccf54c7c6c9e1cbdc4': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2/d0ac28c8886d6cc0cc3d5d9b8f9c6ce73a0b0aa163fee6f96fdcf19d1b77': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/70/edd39740b489f3bf9dcf50dac3465c5292428092177e8513dcde4970025c': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/70': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/4f/bdc56d6040878bf76dd7291eaf4aa1effc129360c0c415dcbab70392f371': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/4f': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/86/4d07f9d587581d931fc5c689754fe98f9d5db2c028449bacd8b94ced52e2': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/86': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/92/93cc98c580e58ecce81f2c200e7a1ae3118e645eea4218f8a655c7f732f8': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/92': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/02/2a512783001403565cf7460ec142510337da7589c82f0d17b3f0c10f204a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/02': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73/b909ded8d742ea013c07c94da2088b4eb708d22a8a7a79b799528b4e0ab0': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73/d6f3db4659ba10691d680e0fb26886d5699d6cfe92b3ac5ad0c9b0916a0a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b5/8cbe8c4af4bc8892f2688ef27617b41965ee1f0692fa48d0c722d782598d': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/7a/cc8368635ad6a5279a0cec27dcb6bb44c0ea1c4e62950fc081721af4c205': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/7a': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/42/390144a89b8971bc53d08c2597eb88288e52cf442b526f07a06996cdb209': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/42': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/8b/763c67ce4bcc6a34398d50c8f871b39118cb4437567a2d82cc97651a9d86': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/8b': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/cd/94ce767cc4b22c4a02e3b458a868966790c44d93f2f389d0ef78e7e30687': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/cd': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_cacache': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/anonymous-cli-metrics.json': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_locks': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T11_08_11_932Z-debug.log': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-31T19_33_06_675Z-debug.log': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-31T19_28_39_025Z-debug.log': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T21_18_28_912Z-debug.log': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T21_27_06_925Z-debug.log': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_logs': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_prebuilds/a93ec4-bindings-v2.0.8-node-v64-linux-x64.tar.gz': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm/_prebuilds': Read-only file system
                                chown: changing ownership of '/home/iobroker/.npm': Read-only file system
                                This system does not support setting default permissions.
                                Do not use npm to manually install adapters unless you know what you are doing!
                                main: line 536: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                    Checking autostart (3/3)
                                rm: cannot remove '/lib/systemd/system/iobroker.service': Read-only file system
                                bash: line 742: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                bash: line 764: cannot create temp file for here-document: Read-only file system
                                rm: cannot remove '/opt/iobroker/iobroker': Read-only file system
                                rm: cannot remove '/usr/bin/iobroker': Read-only file system
                                rm: cannot remove '/opt/iobroker/iob': Read-only file system
                                rm: cannot remove '/usr/bin/iob': Read-only file system
                                ln: failed to create symbolic link '/usr/bin/iobroker': Read-only file system
                                ln: failed to create symbolic link '/usr/bin/iob': Read-only file system
                                ln: failed to create symbolic link '/opt/iobroker/iob': Read-only file system
                                chmod: changing permissions of '/opt/iobroker/iobroker': Read-only file system
                                chown: changing ownership of '/opt/iobroker/iobroker': Read-only file system
                                chown: changing ownership of '/opt/iobroker/iob': Read-only file system
                                Enabling autostart...
                                bash: line 896: cannot create temp file for here-document: Read-only file system
                                chmod: changing permissions of '/lib/systemd/system/iobroker.service': Read-only file system
                                Autostart enabled!
                                bash: line 909: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                                • E e-i-k-e
                                  Guten Abend,
                                  ich habe seit dem Update von 2.0.39 auf 2.1.0 große Probleme mit meinem IoBroker.
                                  Ob dieses Problem nun an dem neuen Js-Controller oder evtl eine andere Ursache hat, kann ich nicht beurteilen.
                                  Iobroker (redis/redis) läuft auf einem Intel NUC (Proxmox) in einem Container mit Ubuntu.
                                  ioBroker stürzt sporadisch ab und lässt sich nicht wieder startet, auch ein neustart von Proxmox bringt keine Verbesserung.
                                  Im Anhang ist die log-Datei zu finden, bitte bis zum ende scrollen ab 15.20 Uhr ist ioBroker nicht mehr zu erreichen und lässt sich auch nicht mehr starten. Nur ein vorher erstellter snapshot kann das System wieder starten lassen.
                                  Habe test weise den Fixer drüber laufen lassen. Dieser spuckt plötzlich sehr viele Meldungen raus.
                                  Anbei ein Auszug davon.
                                  da3be48b27a5af4477f0a1140a701433b3db7136a60197': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/dc': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/94/b8d7797b2752e380d1cf47c7a55a128270ab3b1832f9c784adbcbfdbe81b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/94': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/61/e760160e8107e05f76ca135d8374ac7b8c7786c0547ce9c555cea902d80e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/61': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6/1c4e4b3dc3c6fb34579982f0554d9385b59a2e98b6e6d6594219c6384e46': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6/46e4f928c457b978ce88f39772738dcb5096760a84d945dcb63095c75ff3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/51/7fedfaa7cd933dbb1304a04f5c8aea0e2f76639a150c97a047b0cb57dc62': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/51': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/08/bad04d8ac32f2241b2659718882158c86c01f53845099f9c453f67b03f39': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/08': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/cd/e3a401508c0f1a92aa62ceb9c24eacfc6d282702da0a4b6cb6bd47a2ddbc': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/cd': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe/9c43f3b048ef1201673bfea640b64c9d4b5264f75c3fa308f333a57f6e47': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe/8194f4807b9b6085a2f2e390f8d019e9e53f5c5c1653ee5fb055ca99309e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/cb/d76feb04aeea2cd77b2f0eb08205fcb1508ca9ca2c4c5e1cd4bdcc100a47': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/cb': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a4/ae299f1e3e729d7098795e9e3285ee7b674b05b5efe5d5954725c3930ee0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bd/22e4892cef0bb4f9e69213274833378febde4c117f33212c391bf0f7d119': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bd': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3a/473a66dae428aca5dabba04c2928b4e2eeecd2b359c096572c1061b5c2fc': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f7/ae8abcb39b4f35c14116b197d3ee4cb09729ca8efffb304f4fd11f67c3b0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/d3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a2/1afeb80d67ef938cd56e49c6108229217c5c182d8eded1bf7fded99df5e7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3d/f2f0f797a9b8bc04ff5a617328dd807c77dc2d1a81c8243f65499cc44d81': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bb/e3ebbbd48a30c8b9386f83d99cfbf58708a487a84c35edc9d3709473505d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bb': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/00/3b96abe969aab388681e91bd78b5cc31c2442f23be4bf31a54b0a58732e6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/00': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/7d/ae9bac79ed0bc579c1d312148ac8ccc1093e19c5201ef407838486754e94': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/7d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/ae/de49cf6944cdd240c92851ef11f3895eeb008b10272aab1cec4445140622': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/ae': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/34/34908163c064bbcad301c3fdd7ead62161a272dd90c70819ddace14b7861': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/34': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/93/58ea2565fbb8444f965ef9675842362cfd14ede1ba675c9e205b668fc80e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/93': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/1f/812fbd2f6576d9b47136e0b3c45c98e97b2b0a5b2627cd23b4d2d7def13a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/1f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/76/b307bf2099531873e0b1e3aad52736171cfec1a5a1b172318eb7ad5b336a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/76': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/73/8eade1d8b68283c8566a83f4fe5e4c1048219f28d01bac80087966810210': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/73': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f3/81a49ac1c06b674e36b2f9806e71ec2ea231fdf2d0ed27d4494057760304': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/42/37a652adef68b619fc16b9d625c2949ef61479842fc1964de0fc8f59cb36': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/42': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a7/2f8607e4e45c810d05364e5ff32e5b7cfe679eda67a93820be80876b10e6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc/8b88c4372b5c39f0b3a1e95034483b4a51375fedfe2af7818abd0f1e76ba': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc/0ef7ed77b33b62b931d8e9a09ef845d029b64a7c49025994b28449a26686': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f1/fa42c233e0670045f632ac61bacdd26fbec2535480c71103625f391a6388': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f1': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/56/af929b90dd2b5bf9af2f00d843278312247d4b778e3a3b21216ab0ddc2c7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/56': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f5/434e1f11a531e58fb76713c16b39343a0d442d8bf9a48c74723c43aebb0d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/d0/505f8e28a1b7000cde123d9232e66c95a0259114d60c5a6d4426304ec274': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/d0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/4b/e7e3758c2d19e1b8cf9a59f9a3bb013c0f8040f12ec62bfaa7fb9f279066': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/4b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/6b/b4269307874a79da15ffd7a6ba4bbede653d1a0490b7a08924bf7b5aa19e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/6b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cf/e08864bcda71cda12449f15de938ef01fa6d5c439afddcbb2b8bb3a3f67e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cf': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/e0/c2272d7175091e9df846535741af3cc795e3f8819eda506eec5047ef33be': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/e0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/00/36df83b59945f1327b718bf85b9096766aebb81a14226ccb633b78434219': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/00': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/32/16152c2ccccc38eeeb755adc3efd433cb23baea20fa678e8b19e74e780f5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/32': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96/db732c082b5a904a7ae935037c08343e50e345e5c26864264d7448eee157': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96/be72507b6fc870d80587cbda0bab4fba3321c62a7d82aa97d0715061f49b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/02/a4d888268ff14e42946cd7c95823ef41e95209674fd2846654b819ae5f83': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/02': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/7a/1957bca0c9949aad254fe46114c61fbc7d2cce2e411ff11765c5862d19a2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/7a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82/da1e6e17108be2ddd7f87021521e8bb1fbb576c63c124b588084660944e2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82/283d353be571fd3a81096d7e8fa03e8fe25ad7cbf9370dbcca196d4f709b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/b1/4dd403225670ecc54d9bb66f029473fec9dcae3bae4fe478ff93caa0e7bb': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/b1': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/a1/ed4f9af68a05e530bfa9e38ff6c86f99e4e7c3b591a234a9b399ab033e35': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/a1': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/0c/24e2e5ce0d053d72356aec00cb3bcb62cf36429c906b157eb9cc0e771599': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/0c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/6d/ee6c5b606d31dbc4ad48eaf2d96457498d13144359e2211fd07c1b35d149': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/6d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0/b83e657b12bafc7e4dbf597374a09845ebdfc8300862fe2190072979b03f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0/4fe556f104b09be642895a82afa463fe560d9a0dc8f507efeef825a6905e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/c8/25fb6174489f9eee738a1f70d64c35a084e80e57978f65718efbeb54808d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/c8': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/81/acb1e9ee22b63308732521fb94e2ca1eb9538a418074273ee5cf0373db78': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/81': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a5/6d71d817cd71ea8bc2e2e79c5772127a9c3d907475b75365f896af73af56': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a2/2894ef5992aab46c62615822f4269bfe86c52d633edbcdc9628d82bc9ed2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/52/7f9b06983f2a9167d6a83be35663cc1368166149da11d45ae881f3120541': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/52': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ee/85502d3e649f41a9bac5bcb9716f912ee596f2356b66101192a5df278d0e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ee': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/00/df2874e7ec7673134648181186dbe92d5c86ce2651e2445156e4fc2ce152': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/00': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/01/a3682cefaf787b8e747165953acb4c8295b4a4a6b7240dccebae7de61319': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/01': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/26/5bc5b0f8169f252833a46323cd11c1948ef16a3b2676a2b514bde11b0f24': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/26': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/34/1dea1038910bc69b4fca1995db146c975d75b0a61676729cea425cf9548d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/34': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/0b/41fa759a8c00680f89380affdccdd6235e5932bffef5c6b785bf50828d60': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/0b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/83/357ff6d2b4d78156eca14b9d0fda9fa24177c98365f68b3cc46f08d38c80': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/83': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/bf/3c961a046544d3ec2e4503864ec83b9e773bc76e51e9266e0a58f7087ef2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/bf': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/02/770e04a5c7677acd2b2c3544fbd1096cf305b632922c0c6a2a87256ba22f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/02': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/47/dadb4038d7134c35737d30b1988ec4699a273d60137d2845c10235e0deac': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/47': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/b1/2db50c8d0a2fb4099123888b2a2669d92e2be64d118119fe670b9ca30de4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/b1': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/8d/0088a8a005072e5d28cb1328cf77a15f20b56058f2028ae5ef2dd99c4926': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/8d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ba/4329bdc620971a4c0d92c471d31977e529fdb48af0e0c7234b3365574030': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ba': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/14/a2032208e1c7a62e33f37f602c68fd853567472a6b50a347da7e697fb379': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/14': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/3c/431e6d192a49b59fc29b4a8214c6ce7f06d38e7a326aa79c154c7ad3d857': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/3c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/24/5a3a63f373b73c8aedb555037b4b52193b1b0ab7b9bcc0091a0cc5c94b70': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/24': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/ce/d3351e2727a2b6b6d4080cc056b73f4d3aa5cf23ef1d7b75c2d7da606329': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/ce': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7f/f5a90a8423d33ffa837e8ed57f8d96b4c1e7006cce7035a2ca88d5fe3706': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/8f/50e3707651fecee0ade6da7d20759d45dececaab1fecdf90c9a42cf8d922': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/8f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/d3/7697273802dffa158119427da833e251b88e0e9d4c73d8f5f964476884f4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/d3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/52/9e8c769eb26be17ef9f048b5ef04f8332b2254221e0c0daac3e753181b19': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/52': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/37/62e59a65e3fa96dc48d3adedfd2df02db2590274fa133fea39fbe8edd547': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/37': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b/d738e92d28a95122ca5354c837624c07986f2a8932ac7bda68a293f5185e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b/e39f55cc4a867a7cb6219270fb9e9a185651d8b01a18d37b051a94aabaa3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7d/25e51f2ab1bbcdf5455baaafe3c3a6309de5f615f2ffae63c19c9ae06cf3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/fa/a6a079afd3dd1f324310e7c47c3e23758cab72a45186d1fd22669816616c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/fa': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/6f/fcee44c502a8b6f22637f9e7c48e333fff4dbb696d7a1f139aa3dff264aa': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/6f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/30/2252b187203d7250d1afc85797278dea82dc6c814c83b203383958b29cd6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/30': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/57/74f562d002abd9fd4fa2fadea83170c075f83a0df2ce00cef8b2adaafe73': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/57': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/07/307d217a7e74c1650be66f33e69f694833caa1b55d1086574f2509cb5acf': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/07': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/c4/70b79340f3c3771c289cb21d389234b4bbd8f1b0205307c4854b03a49e16': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/c4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/61/6fb9b18eec6b3afc804af9fd508931055bda5a41b95ed9b792193c848750': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/61': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/51/f076431a8a2711186615c69503b7ebcc4ae98d3408cf258a9f0949fa55cc': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/51': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/c5/8b4e0c746f9dcf84bef48aeba6071577e3780a1cb841037d6ad06f68751e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/c5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/b4/6668c405c1127931b21a3f0d2c39a5460fad651a609e5b4fefb176d1be8e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/b4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f0/6986d038de42bdb42462881e9a82767be8a642e34312a5cf86f98fb9d00c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/5f/6e2956b950b124b9bf3d0e3b14a8ffb59cd858fd75ac433405cc316cc14f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/5f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/78/b9c6d02750f707247c29f429225523868ffa6a5a60c0cc25f1ecc615dd6d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/78': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f7/87042931e5944467d47331c350feb4384bf9143ab6ceebf7108a55905843': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/37/a4d675e1e3f697321e88084ccfeb1928eefc4b7828f2b09cfdff0714a2fb': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/37': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/fa/f87baceab26935686548c742091e7014930673bc1f077574c54c4c6c2d2d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/fa': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1a/4acb93e17b849f731fdc2713e65b1349ce74768503c06c87639c392f6a0f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1f/082d4a06ccf797c3905f27c42bebec5acaf1c6c858a3a5abc48c3dbe82c3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/36/c2fbbfb91ed4e23ae02c15f665a55e56f73e1f774e485f663c63ddd92a59': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/36': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f3/5842983c780cc28425750762f083655b954ec48b5d87f2e2e4afc21dc371': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/8b/e2b51aed1de49b0fd9c7b12abf936739009dafe0ebb80b6d0f959990b1e6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/8b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/46/ed7592e0bc7537e303b400259ce143650ee65dbcf60d0216abdc077e915d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/46': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/a3/7a82019a9db758aaf72f4b337476898ac4f4b990d00182341ac788806e91': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/a3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/52/abeb87386808aec4cd167ec5a1e23a9617536f6be5b6a50b86c312d1dd8b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/52': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/69/7bde42484a73102035894c5c428b6713b26afb4f0eab94d6994207798808': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/69': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/2c/ecf8d7a27f9badae55d265950f4dc536a8bd1b164e88a3e1b6b80b483734': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/2c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/6f/d41f5b4ebdbd368f2fed6b685643bafdcf70fcd5d7aa9a8420610977544b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/6f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/66/b560891cb76c1fa15da8783719ac89328f8a971b3e1f2ffb06a00853fa19': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/66': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/36/e0b9bba658386b1654960be36583e4d41ec8878b58397578d9078858d10a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/36': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/13/9845cf958896ac60fb7bad0f0ee3b10b02cc11bd08613674ac038a741025': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/13': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/1e/d37b96b3ec7ddc16a2fdeba79ec051a6bef7c9112006e6b181f049323403': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/1e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/97/8d51650d6522d0922d4dca4968f1fa1c42b218f74aeb8a2af25bcf9ff98d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/97': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/71/f68a6750f3db4df84a6f6c31eba19daed52dc3c2a615b66b97cea205353b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/71': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/19/35638765772d89997e949c58a55a6045a598729727f1de4bc2d012f0880f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/19': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d3/470c9cbb447615faafb6dfdf54632831f7f96c77771ea06a1eeffba41373': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/a2/d192ea48452222fa74ca6c73d5c4dc9fb3d73b669f84e7b26e26edc7299e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/a2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/11/5ad280305e1c607a1d5b4ac826f7b7ea40efb4aa64871dbbed235cfb1825': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/11': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/8a/b10c99585d0abe29a19f2f7f7bb5d829f7c22af3fd8c33f86514ff11c577': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/8a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4d/16a027afa526cdd80817b59459fb9019ea3f4f330989a3df3b2dd424d31c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/86/caeb58d7dd6f6511597a4a33b82f94a10ef0c71396c9582588bdd21c8c73': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/86': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/2f/0d6de8daa7de9c1a220162737d8aa09280826eb3cff7d6da43b38fcad8c0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/2f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/9c/6fffa7a1f3b1336db5fd1d177f3e1b2efd95f3689885306e8958693c380e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/9c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4c/811e3b437dc243385ceb2a5e7a681f88e9a8c832706a0be2697752e97ca9': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1b/f6b50f4c1ad5ccdba9c6ffc4fbd267713841d8d24039339fd97c4a03bb9a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/7c/02d2df9400272bb9cc56a006541e41460e8973721cd72ae78261e6db876b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/7c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/33/bea802424bc10eed30eed2ac1df5cd8277bdeedab5f08e3c4629fcaa68b6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/33': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/db/96ea9765abd3cc239baac6e194871f5fd7732a3657a7444b8c8513bc8455': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/db': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b5/844264280dfb76a29e7a7afe23fc05d40aac4dd573eea0bec2db2e5a2add': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b1/7f5a9b4981107c0957571c6aea09409de107f9203452fad14a9653b7cd72': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b1': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1e/ae5e7b1c82b02a2af9acccb88bf4da3b2d5d059384f8d92af3c3b76a1a4c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d1/73825d96cbb41bc8c0bf9f2a78d6281633aebedbd052caaf1d51fffa4311': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d1': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/97/fed28c4f00d3eeb0f0e79d50b09bd95e529fff6d4f1a764e73fcda69a842': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/97': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/f6/043b7bf3ca70506f520273ec16fa0316aa9269b2ee01429bb3298c94e053': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/f6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/14/c90049198f353f04aa7296e700da0a56b8c4b0e38184f9039b6724e62125': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/14': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ef/3e25234e1be03662057aeb474090c320ef2e89992c14b616f4c5469babba': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ef': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ec/d14829a7c1af48dbb7ff77fff9319258f8b205c7ce4a8fd95cf46a4bcadd': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ec': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b6/899314477b68fc8d7aad3a64e8285f65984d38c54dcc3939db2606c921ba': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/38/e7c4949c208bda7986ed8052bb24441f6f116b54f6288e257a2aa1b633a3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/38': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/5d/393bfbcabebab0809010c29f6fb7c7f532f8333edc64be087a2ddcde2d86': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/5d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b0/a4331403838762a771b8749ad57d45f57b02407b4e467039188bd126fe96': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/59/4d920c893d5be1a1e54231c8cdd7fc182ea0c735346e4759ffb02c67f870': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/59': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/f9/4ada453499bcc74c6f62ab9565b490a863bc874d691677add95ecf947c78': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/f9': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b7/476b08defc5621c5ae7caf17631ea22fda40726e7c9898862f6ef34402fc': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b3/b16fdff1edd94b37a94bd7db2184982c2238e04c4eb0b665c8a081d3f5a9': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b3': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/39/0d140fe159ac444763e5c4f05d9d2bba1327083675ed20dbbbf63683e7ff': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/39': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/03/f0dd7de970ceaa1f0b8e1bf05bbdfe065f5be795bcfb2e075e7576d7a670': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/03': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/54/4263efad7cfdd6f394d102bca236a76688809923cbe19f10331ded603b89': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/54': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/09/b5ad6166b743ce97673a0966ecde746512cbe18b4d7c310f36f03c01e3bd': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/09': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/88/8351ea69396b436ec7a2595350f815b4a595dd9449f447170068b8307051': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/88': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/01/f85ceaf0ff181f9b0db6422a6a86d713d2931f3c94b9bce872793e4f3bfb': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/01': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/92/646d6eb727e22ebeca12d558cffbe9fd8cf4f5674a4e411e68344640a6d0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/92': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/bf/d2987a7db80f4e0738cc6f2af13aadeaa56311fb9d65373b0e9bb20f67d5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/bf': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/da/4021979edf0d2c56dc28304170e8afe2f90ec1a5620cd987dde84e2fc58b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/da': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/73/47877fb05b9134a2e3b66012ed97767017380d4453582e9f39765e958d09': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/73': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/84/d39f10ff4bdf9bd11450faf4a8bbbe361ef4da77d743fce5adfbd4859d1a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/84': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/3e/151b03bcacd057978b4c891ae842f10b5c2fffcb8c0fe905a0ae7d3751d2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/3e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b/e21fe9c19b958a620cbc71d80f97bfc371bb361573d441294570eb583134': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b/12f2f7af7f950c23d4cdb66d81b57e5ffd679a24f66f54f69674376024a5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/cd/3539b50b6ce10a6099da623467c7a4f0930e6cc79b75ac77aff19c4c82b7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/cd': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/ec/92e2016477c65cf7ae1b6c42f15723842175a9735acc8dd23a6b85afe34a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/ec': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/4a/a53ab2dd740f6401643d51bfee7c2e7d6120dba24b566422e7101b78da3e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/4a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/bd/a6f543a4c160c81541f1941ac3a4f22e24c720cb0812c8a0b4b190f525da': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/bd': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5f/a80eaf748391860ea374caba3171c449c4d9819ea99724eb644ff6db0e91': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e7/836747f2490d9ad67b369ec82fb4e0b82fbb8fe3ab58c500f4dee8c5d7a6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/31/11eb65d70a004ba6dc4f967bae593980ef09d70ba81fd2af497387d1d59a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/31': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/63/49d9d6a2058fb1376caf4de0884b52be6440a5a13a30ac7e5c720c7be0ad': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/63': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/75/0b298e16b2be5f5a50a3c46bd8ebf41296b5430a1faa29b08922bd2b2f14': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/75': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/45/0f087a72405cc722d634bcfedbc5b14d65cdf1e88b133cdde8d8c4c0c160': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/45': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/91/dbfac5a17511327401d3f24dbd4b15e42751a4ca0a9744d3e795cbb30772': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/91': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e4/85c453c0b7c6d00627bbc4a99aacaf9f8afc4a98a767adf60a0ccadbc990': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/69/1d82a0bae7afd711fcef1d246d260691a22315303d31f649187496291a78': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/69': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/c0/673e4f716a0a97692176a610b077c1e4c37f0657b07b69cac7afc9979405': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/c0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/37/c9e69f5074e9a22c766ffcc622280d4e580d2ee0238f670f28199487dd44': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/37': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/3b/7656677b4ce98fa80fbd05eb933b9b5a858fb4a25d07d9ecd22267443c62': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/3b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5b/a5ccd6d9f05959c1c89efc411510f733374f46f5e7c4ee798f587f5ae931': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/30/eb11cf8343b323649a963f633068a14c0cfe8e76c423f2107daa2a419059': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/30': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/be/6e1283f2345247c106f9fd360a38dfd752ea3fc358323729d4095f466da8': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/be': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/57/7f46ee7c4fb819256f5c28a6cd4f231734deae83dd742f2b523f10ac0633': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/57': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/95/fa9c994121ed142a2e5d4f1ac42e1b494f767340cb6ba4e34f0f31facc9d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/95': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/33/e5c1af689be93f794b86f66d7dfbe6bae4e548b2135a4789bf94a09d3372': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/33': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/73/7a110e38bbccbdf42210ae85da034a9311e0f4299050e50f3c8191501c71': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/73': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/12/377ab6ff432fac53c8c672a1bf5732512e5b619173714e383359d443642a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/12': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/61/8cbf374dc4a22dea9866259dd98cca4184f65ebaff7dba6afbeaf6e06fa4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/61': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/08/3ba9ab86283ac5b5641abfdd4a37885231614123fec1c9d9b47a1c12595a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/08': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/fb/8c070eb7c9d840daf6f8862fdf5c462eef4ce470c92316b36076a8ec4ae2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/fb': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b8/c350b4c87e03f50e668f69fdc4840256ed1a3d60fbd3e90d624bd0138004': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b8': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/5d/70974ce696936b845f14e8e48e153f5dd7482eaf1f17a7af992a927115b8': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/5d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/19/b0d987af1fdb73b10ac24ff43db0f296be2745d0cd2bf5119078fac111e7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/19': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/63/c0df8adcf22021b52c33a707d11bb4428944f3147e167201933b77cd6551': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/63': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/4b/40bd19b841405182387e13123d31c6309b162d81d0db86ee52736a9bd643': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/4b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/a6/a58b1280f8bb14298a70a8ef7cdbab9f28d319d511f11ca084211f2bcc05': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/a6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/91/fc3843be160bcbe54a87c70cf0217f9f7166e72d297a198ed0f8cf93d7d5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/91': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/52/cfba3106ef0da44f06a883b7b9d1fc70b8ed2a1d170599f48805f689e53c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/52': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/44/6b35922d71beeb2843639c393d28f2684b260a14e0dc7ec7ce856b28610a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/44': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/6e/1b57fa2c400ae0176683235ee3685bcc4c42f3def62180e77471eb79fca4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/6e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/2f/dc75f5beaa45c77b4d14903f07840533c5357142fdba60d7c4481e4fc5db': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/2f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2/0e3c9e2baf2567a6bd9f81829d3cb6204255d8fbe622583524708853d610': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2/72a6c9df044cb26b10a04bf261bce41420c99f77d49e6a53e767ea3a6fa8': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/da/e8654aad33bbbf62a4857fbf8beed9c4ce05a6b6fee192da0d679cf0e3cc': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/da': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d2/d5d7acda4c2ad2ffbeda6ceb752dfc56f66153eac8ebc8f7ee2c5a8414b8': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/07/ba09e5cbea02069d6fc80814eca98c9ef14b785b54378abf33641eef8753': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/07': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/ac/feef31c8f79f79090b2ddd82e57346ae532d7e69fa53cee8969225ade33e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/ac': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d8/342048477d8d1a66dcf45723307d428757556956d99a5aed2bdb0f2a269b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d8': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/40/a0f8b6ed4650fba1bdce3d598725165dfde297436aa3bbd3c591c6fe4f21': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/40': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d1/54737918360c9f80d2be568380068e5f0c9d2ea370407da34d92a8f687c5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d1': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/f6/492d7af722115ca18f328cce017e91ada962beb0adea68f213393af0928a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/f6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/08/5e07feb6be282ff79bae817d3fd16e5359483cd774f506cad08ba4e58eea': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/08': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/b4/5e8ad2b29fe1334c4aa0178c518b43a732aab578a476f69cb49cc81a8762': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/b4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f0/22cc0b58a3130a20fc0015a98a37eff19452bd09903bad6286495faad602': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5f/066eac5b28b0fc192c75d345a821b4ea45dffebb1c729afd27e4fb90e111': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f5/462c0215e13359a052b9d08b2f00ef669a10531bcf01806ae0106c9e99d0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/cf/8711cafb6666a89091dfc5b318f2c5009e9be2ea25532b176edb9e312c88': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/cf': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/91/a77f215851fd29297a480f3edbed051747f3e7d5ca06d5612c842c1c6e31': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/91': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/3d/8a65927dadb603aa6974e7136c2539d30e27408a36712dc732da8ba52f87': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/3d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/26/8c97b83b5df53797ba6d8937982f6ff0336a8f15282585415484154a85a6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/26': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4d/d8bcde1b0c0e9022e4389a309fcde945357c90955f52a967f55bfecd86c9': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/32/d09169f60fcc3107c776d307f1225766793fc9086be98095a4fcda130355': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/32': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4f/b991304b3c794a52704073ade76bc3fdc85bea273ed875333feee9c50f41': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5c/8292eb35ff5c46c53be1f45609df1b5ad53b1ef7beb53e25830771fff476': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/c4/576ae94b481d6eba722899b489cbd0e629782a11798b7bc8a55fdb728630': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/c4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/15/8f5843e13eebe66d43fb4fce10a5b862a831e8e5cae63e31b326f1376c76': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/15': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f6/38b8038e95b147174eab43053d49e5078953e257487592e1ac94a0aa2544': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f6': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/9f/56df86c5348a44745233ccca8b1cf6d9e372726c0c2bb6404a3274e02c63': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/9f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/1d/255a2fe5c32486b5e3869636f5f541a825ca87912ce55459478af5d5db8f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/1d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/18/13e5f9ff07fea3e2e6cbdabb965524040a2a95e912ce1327641fc2c86a9e': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/18': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b7/3ec33017ccd57f05bcb1cd5b86f58cfad2f5087ec3f70e7697c7ee8fdfd0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/af/43873f6488ed910e6a4c19415fa4f6ec72fab2d58568d8dc39fd00bfe614': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/af': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2/80dc7881806fc9766aaf8871f305013551427a6fc2ccf54c7c6c9e1cbdc4': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2/d0ac28c8886d6cc0cc3d5d9b8f9c6ce73a0b0aa163fee6f96fdcf19d1b77': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/70/edd39740b489f3bf9dcf50dac3465c5292428092177e8513dcde4970025c': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/70': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/4f/bdc56d6040878bf76dd7291eaf4aa1effc129360c0c415dcbab70392f371': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/4f': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/86/4d07f9d587581d931fc5c689754fe98f9d5db2c028449bacd8b94ced52e2': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/86': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/92/93cc98c580e58ecce81f2c200e7a1ae3118e645eea4218f8a655c7f732f8': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/92': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/02/2a512783001403565cf7460ec142510337da7589c82f0d17b3f0c10f204a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/02': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73/b909ded8d742ea013c07c94da2088b4eb708d22a8a7a79b799528b4e0ab0': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73/d6f3db4659ba10691d680e0fb26886d5699d6cfe92b3ac5ad0c9b0916a0a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b5/8cbe8c4af4bc8892f2688ef27617b41965ee1f0692fa48d0c722d782598d': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/7a/cc8368635ad6a5279a0cec27dcb6bb44c0ea1c4e62950fc081721af4c205': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/7a': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/42/390144a89b8971bc53d08c2597eb88288e52cf442b526f07a06996cdb209': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/42': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/8b/763c67ce4bcc6a34398d50c8f871b39118cb4437567a2d82cc97651a9d86': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/8b': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/cd/94ce767cc4b22c4a02e3b458a868966790c44d93f2f389d0ef78e7e30687': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/cd': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_cacache': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/anonymous-cli-metrics.json': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_locks': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T11_08_11_932Z-debug.log': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-31T19_33_06_675Z-debug.log': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-31T19_28_39_025Z-debug.log': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T21_18_28_912Z-debug.log': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T21_27_06_925Z-debug.log': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_logs': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_prebuilds/a93ec4-bindings-v2.0.8-node-v64-linux-x64.tar.gz': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm/_prebuilds': Read-only file system
                                  chown: changing ownership of '/home/iobroker/.npm': Read-only file system
                                  This system does not support setting default permissions.
                                  Do not use npm to manually install adapters unless you know what you are doing!
                                  main: line 536: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                      Checking autostart (3/3)
                                  rm: cannot remove '/lib/systemd/system/iobroker.service': Read-only file system
                                  bash: line 742: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                  bash: line 764: cannot create temp file for here-document: Read-only file system
                                  rm: cannot remove '/opt/iobroker/iobroker': Read-only file system
                                  rm: cannot remove '/usr/bin/iobroker': Read-only file system
                                  rm: cannot remove '/opt/iobroker/iob': Read-only file system
                                  rm: cannot remove '/usr/bin/iob': Read-only file system
                                  ln: failed to create symbolic link '/usr/bin/iobroker': Read-only file system
                                  ln: failed to create symbolic link '/usr/bin/iob': Read-only file system
                                  ln: failed to create symbolic link '/opt/iobroker/iob': Read-only file system
                                  chmod: changing permissions of '/opt/iobroker/iobroker': Read-only file system
                                  chown: changing ownership of '/opt/iobroker/iobroker': Read-only file system
                                  chown: changing ownership of '/opt/iobroker/iob': Read-only file system
                                  Enabling autostart...
                                  bash: line 896: cannot create temp file for here-document: Read-only file system
                                  chmod: changing permissions of '/lib/systemd/system/iobroker.service': Read-only file system
                                  Autostart enabled!
                                  bash: line 909: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                      Your installation was fixed successfully
                                      Run iobroker start to start ioBroker again!
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #167
                                  @e-i-k-e sagte in js-controller 2 jetzt für alle im Stable:
                                  Ich weiß nicht warum das auf nem NUC passiert, aber bei Raspberry Pi heißt das üblicherweise dass die SD-Karte hin ist.
                                  • apollon77A apollon77
                                    @Peoples Unter einem der offiziell definierten ordner. Ich würde ja "0_userdata.0" als Basis nutzen ... Siehe auch Post #3 oben
                                    PeoplesP Offline
                                    PeoplesP Offline
                                    Peoples
                                    schrieb am zuletzt editiert von Peoples
                                    #168
                                    Verschoben
                                      @A-H-0 sagte in js-controller 2 jetzt für alle im Stable:
                                      Ich habe testweise einen DP angelegt, gibt aber kein icon um ihn wieder zu löschen
                                      Beim DP schon, beim Ordner nicht
                                      Auch bei neu angelegten
                                      A H 0A Offline
                                      A H 0A Offline
                                      A H 0
                                      #169
                                      @Homoran said in js-controller 2 jetzt für alle im Stable:
                                      Danke, Problem gelöst, war aber kein Ordner. Mein Fehler war das ich beim Anlegen 123 als Rolle eingetragen hatte statt einen Wert auf dem Dropdown zu wählen. Nach Umstellung von 123 => indicator sind die fehlenden Icons aufgetaucht und ich konnte es löschen.
                                      • E e-i-k-e
                                        Guten Abend,
                                        ich habe seit dem Update von 2.0.39 auf 2.1.0 große Probleme mit meinem IoBroker.
                                        Ob dieses Problem nun an dem neuen Js-Controller oder evtl eine andere Ursache hat, kann ich nicht beurteilen.
                                        Iobroker (redis/redis) läuft auf einem Intel NUC (Proxmox) in einem Container mit Ubuntu.
                                        ioBroker stürzt sporadisch ab und lässt sich nicht wieder startet, auch ein neustart von Proxmox bringt keine Verbesserung.
                                        Im Anhang ist die log-Datei zu finden, bitte bis zum ende scrollen ab 15.20 Uhr ist ioBroker nicht mehr zu erreichen und lässt sich auch nicht mehr starten. Nur ein vorher erstellter snapshot kann das System wieder starten lassen.
                                        Habe test weise den Fixer drüber laufen lassen. Dieser spuckt plötzlich sehr viele Meldungen raus.
                                        Anbei ein Auszug davon.
                                        da3be48b27a5af4477f0a1140a701433b3db7136a60197': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/dc': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/94/b8d7797b2752e380d1cf47c7a55a128270ab3b1832f9c784adbcbfdbe81b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/94': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/61/e760160e8107e05f76ca135d8374ac7b8c7786c0547ce9c555cea902d80e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/61': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6/1c4e4b3dc3c6fb34579982f0554d9385b59a2e98b6e6d6594219c6384e46': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6/46e4f928c457b978ce88f39772738dcb5096760a84d945dcb63095c75ff3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/f6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/51/7fedfaa7cd933dbb1304a04f5c8aea0e2f76639a150c97a047b0cb57dc62': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/51': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/08/bad04d8ac32f2241b2659718882158c86c01f53845099f9c453f67b03f39': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/08': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/cd/e3a401508c0f1a92aa62ceb9c24eacfc6d282702da0a4b6cb6bd47a2ddbc': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97/cd': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/97': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe/9c43f3b048ef1201673bfea640b64c9d4b5264f75c3fa308f333a57f6e47': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe/8194f4807b9b6085a2f2e390f8d019e9e53f5c5c1653ee5fb055ca99309e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/fe': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/cb/d76feb04aeea2cd77b2f0eb08205fcb1508ca9ca2c4c5e1cd4bdcc100a47': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/cb': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a4/ae299f1e3e729d7098795e9e3285ee7b674b05b5efe5d5954725c3930ee0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bd/22e4892cef0bb4f9e69213274833378febde4c117f33212c391bf0f7d119': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bd': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3a/473a66dae428aca5dabba04c2928b4e2eeecd2b359c096572c1061b5c2fc': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f7/ae8abcb39b4f35c14116b197d3ee4cb09729ca8efffb304f4fd11f67c3b0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/d3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a2/1afeb80d67ef938cd56e49c6108229217c5c182d8eded1bf7fded99df5e7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3d/f2f0f797a9b8bc04ff5a617328dd807c77dc2d1a81c8243f65499cc44d81': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/3d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bb/e3ebbbd48a30c8b9386f83d99cfbf58708a487a84c35edc9d3709473505d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/bb': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/00/3b96abe969aab388681e91bd78b5cc31c2442f23be4bf31a54b0a58732e6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/00': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/7d/ae9bac79ed0bc579c1d312148ac8ccc1093e19c5201ef407838486754e94': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/7d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/ae/de49cf6944cdd240c92851ef11f3895eeb008b10272aab1cec4445140622': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/ae': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/34/34908163c064bbcad301c3fdd7ead62161a272dd90c70819ddace14b7861': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/34': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/93/58ea2565fbb8444f965ef9675842362cfd14ede1ba675c9e205b668fc80e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/93': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/1f/812fbd2f6576d9b47136e0b3c45c98e97b2b0a5b2627cd23b4d2d7def13a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/1f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/76/b307bf2099531873e0b1e3aad52736171cfec1a5a1b172318eb7ad5b336a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/76': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/73/8eade1d8b68283c8566a83f4fe5e4c1048219f28d01bac80087966810210': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/73': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f3/81a49ac1c06b674e36b2f9806e71ec2ea231fdf2d0ed27d4494057760304': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/f3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/42/37a652adef68b619fc16b9d625c2949ef61479842fc1964de0fc8f59cb36': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/42': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a7/2f8607e4e45c810d05364e5ff32e5b7cfe679eda67a93820be80876b10e6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6/a7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc/8b88c4372b5c39f0b3a1e95034483b4a51375fedfe2af7818abd0f1e76ba': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc/0ef7ed77b33b62b931d8e9a09ef845d029b64a7c49025994b28449a26686': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cc': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f1/fa42c233e0670045f632ac61bacdd26fbec2535480c71103625f391a6388': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f1': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/56/af929b90dd2b5bf9af2f00d843278312247d4b778e3a3b21216ab0ddc2c7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/56': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f5/434e1f11a531e58fb76713c16b39343a0d442d8bf9a48c74723c43aebb0d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/f5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/d0/505f8e28a1b7000cde123d9232e66c95a0259114d60c5a6d4426304ec274': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/d0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/4b/e7e3758c2d19e1b8cf9a59f9a3bb013c0f8040f12ec62bfaa7fb9f279066': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/4b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/6b/b4269307874a79da15ffd7a6ba4bbede653d1a0490b7a08924bf7b5aa19e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/6b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cf/e08864bcda71cda12449f15de938ef01fa6d5c439afddcbb2b8bb3a3f67e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/cf': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/e0/c2272d7175091e9df846535741af3cc795e3f8819eda506eec5047ef33be': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/e0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/00/36df83b59945f1327b718bf85b9096766aebb81a14226ccb633b78434219': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/00': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/32/16152c2ccccc38eeeb755adc3efd433cb23baea20fa678e8b19e74e780f5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/32': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96/db732c082b5a904a7ae935037c08343e50e345e5c26864264d7448eee157': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96/be72507b6fc870d80587cbda0bab4fba3321c62a7d82aa97d0715061f49b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/96': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/02/a4d888268ff14e42946cd7c95823ef41e95209674fd2846654b819ae5f83': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/02': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/7a/1957bca0c9949aad254fe46114c61fbc7d2cce2e411ff11765c5862d19a2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/7a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82/da1e6e17108be2ddd7f87021521e8bb1fbb576c63c124b588084660944e2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82/283d353be571fd3a81096d7e8fa03e8fe25ad7cbf9370dbcca196d4f709b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/82': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/b1/4dd403225670ecc54d9bb66f029473fec9dcae3bae4fe478ff93caa0e7bb': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/b1': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/a1/ed4f9af68a05e530bfa9e38ff6c86f99e4e7c3b591a234a9b399ab033e35': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/a1': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/0c/24e2e5ce0d053d72356aec00cb3bcb62cf36429c906b157eb9cc0e771599': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5/0c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/d5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/6d/ee6c5b606d31dbc4ad48eaf2d96457498d13144359e2211fd07c1b35d149': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/6d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0/b83e657b12bafc7e4dbf597374a09845ebdfc8300862fe2190072979b03f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0/4fe556f104b09be642895a82afa463fe560d9a0dc8f507efeef825a6905e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/f0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/c8/25fb6174489f9eee738a1f70d64c35a084e80e57978f65718efbeb54808d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/c8': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/81/acb1e9ee22b63308732521fb94e2ca1eb9538a418074273ee5cf0373db78': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/81': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a5/6d71d817cd71ea8bc2e2e79c5772127a9c3d907475b75365f896af73af56': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a2/2894ef5992aab46c62615822f4269bfe86c52d633edbcdc9628d82bc9ed2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/a2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/52/7f9b06983f2a9167d6a83be35663cc1368166149da11d45ae881f3120541': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/52': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ee/85502d3e649f41a9bac5bcb9716f912ee596f2356b66101192a5df278d0e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ee': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/00/df2874e7ec7673134648181186dbe92d5c86ce2651e2445156e4fc2ce152': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/00': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/01/a3682cefaf787b8e747165953acb4c8295b4a4a6b7240dccebae7de61319': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/01': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/26/5bc5b0f8169f252833a46323cd11c1948ef16a3b2676a2b514bde11b0f24': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/26': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/34/1dea1038910bc69b4fca1995db146c975d75b0a61676729cea425cf9548d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/34': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/0b/41fa759a8c00680f89380affdccdd6235e5932bffef5c6b785bf50828d60': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/0b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/83/357ff6d2b4d78156eca14b9d0fda9fa24177c98365f68b3cc46f08d38c80': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/83': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/bf/3c961a046544d3ec2e4503864ec83b9e773bc76e51e9266e0a58f7087ef2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/bf': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/02/770e04a5c7677acd2b2c3544fbd1096cf305b632922c0c6a2a87256ba22f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/02': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/47/dadb4038d7134c35737d30b1988ec4699a273d60137d2845c10235e0deac': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/47': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/b1/2db50c8d0a2fb4099123888b2a2669d92e2be64d118119fe670b9ca30de4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/b1': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/8d/0088a8a005072e5d28cb1328cf77a15f20b56058f2028ae5ef2dd99c4926': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/8d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ba/4329bdc620971a4c0d92c471d31977e529fdb48af0e0c7234b3365574030': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/ba': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/14/a2032208e1c7a62e33f37f602c68fd853567472a6b50a347da7e697fb379': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58/14': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/58': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/3c/431e6d192a49b59fc29b4a8214c6ce7f06d38e7a326aa79c154c7ad3d857': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/3c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/24/5a3a63f373b73c8aedb555037b4b52193b1b0ab7b9bcc0091a0cc5c94b70': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/24': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/ce/d3351e2727a2b6b6d4080cc056b73f4d3aa5cf23ef1d7b75c2d7da606329': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/ce': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7f/f5a90a8423d33ffa837e8ed57f8d96b4c1e7006cce7035a2ca88d5fe3706': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/8f/50e3707651fecee0ade6da7d20759d45dececaab1fecdf90c9a42cf8d922': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/8f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/d3/7697273802dffa158119427da833e251b88e0e9d4c73d8f5f964476884f4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/d3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/52/9e8c769eb26be17ef9f048b5ef04f8332b2254221e0c0daac3e753181b19': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/52': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/37/62e59a65e3fa96dc48d3adedfd2df02db2590274fa133fea39fbe8edd547': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/37': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b/d738e92d28a95122ca5354c837624c07986f2a8932ac7bda68a293f5185e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b/e39f55cc4a867a7cb6219270fb9e9a185651d8b01a18d37b051a94aabaa3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/9b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7d/25e51f2ab1bbcdf5455baaafe3c3a6309de5f615f2ffae63c19c9ae06cf3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/7d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/fa/a6a079afd3dd1f324310e7c47c3e23758cab72a45186d1fd22669816616c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/fa': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/6f/fcee44c502a8b6f22637f9e7c48e333fff4dbb696d7a1f139aa3dff264aa': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/6f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/30/2252b187203d7250d1afc85797278dea82dc6c814c83b203383958b29cd6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/30': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/57/74f562d002abd9fd4fa2fadea83170c075f83a0df2ce00cef8b2adaafe73': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/57': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/07/307d217a7e74c1650be66f33e69f694833caa1b55d1086574f2509cb5acf': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/07': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/c4/70b79340f3c3771c289cb21d389234b4bbd8f1b0205307c4854b03a49e16': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/c4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/61/6fb9b18eec6b3afc804af9fd508931055bda5a41b95ed9b792193c848750': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/61': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/51/f076431a8a2711186615c69503b7ebcc4ae98d3408cf258a9f0949fa55cc': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51/51': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/51': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/c5/8b4e0c746f9dcf84bef48aeba6071577e3780a1cb841037d6ad06f68751e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/c5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/b4/6668c405c1127931b21a3f0d2c39a5460fad651a609e5b4fefb176d1be8e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/b4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f0/6986d038de42bdb42462881e9a82767be8a642e34312a5cf86f98fb9d00c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/5f/6e2956b950b124b9bf3d0e3b14a8ffb59cd858fd75ac433405cc316cc14f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/5f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/78/b9c6d02750f707247c29f429225523868ffa6a5a60c0cc25f1ecc615dd6d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/78': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f7/87042931e5944467d47331c350feb4384bf9143ab6ceebf7108a55905843': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/37/a4d675e1e3f697321e88084ccfeb1928eefc4b7828f2b09cfdff0714a2fb': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/37': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/fa/f87baceab26935686548c742091e7014930673bc1f077574c54c4c6c2d2d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/fa': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1a/4acb93e17b849f731fdc2713e65b1349ce74768503c06c87639c392f6a0f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1f/082d4a06ccf797c3905f27c42bebec5acaf1c6c858a3a5abc48c3dbe82c3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/1f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/36/c2fbbfb91ed4e23ae02c15f665a55e56f73e1f774e485f663c63ddd92a59': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/36': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f3/5842983c780cc28425750762f083655b954ec48b5d87f2e2e4afc21dc371': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/f3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/8b/e2b51aed1de49b0fd9c7b12abf936739009dafe0ebb80b6d0f959990b1e6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/8b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/46/ed7592e0bc7537e303b400259ce143650ee65dbcf60d0216abdc077e915d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14/46': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/14': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/a3/7a82019a9db758aaf72f4b337476898ac4f4b990d00182341ac788806e91': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/a3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/52/abeb87386808aec4cd167ec5a1e23a9617536f6be5b6a50b86c312d1dd8b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/52': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/69/7bde42484a73102035894c5c428b6713b26afb4f0eab94d6994207798808': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/69': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/2c/ecf8d7a27f9badae55d265950f4dc536a8bd1b164e88a3e1b6b80b483734': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/2c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/6f/d41f5b4ebdbd368f2fed6b685643bafdcf70fcd5d7aa9a8420610977544b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/6f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/66/b560891cb76c1fa15da8783719ac89328f8a971b3e1f2ffb06a00853fa19': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/66': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/36/e0b9bba658386b1654960be36583e4d41ec8878b58397578d9078858d10a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/36': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/13/9845cf958896ac60fb7bad0f0ee3b10b02cc11bd08613674ac038a741025': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/13': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/1e/d37b96b3ec7ddc16a2fdeba79ec051a6bef7c9112006e6b181f049323403': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/1e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/97/8d51650d6522d0922d4dca4968f1fa1c42b218f74aeb8a2af25bcf9ff98d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08/97': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/08': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/71/f68a6750f3db4df84a6f6c31eba19daed52dc3c2a615b66b97cea205353b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/71': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/19/35638765772d89997e949c58a55a6045a598729727f1de4bc2d012f0880f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/19': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d3/470c9cbb447615faafb6dfdf54632831f7f96c77771ea06a1eeffba41373': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/a2/d192ea48452222fa74ca6c73d5c4dc9fb3d73b669f84e7b26e26edc7299e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/a2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/11/5ad280305e1c607a1d5b4ac826f7b7ea40efb4aa64871dbbed235cfb1825': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/11': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/8a/b10c99585d0abe29a19f2f7f7bb5d829f7c22af3fd8c33f86514ff11c577': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/8a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4d/16a027afa526cdd80817b59459fb9019ea3f4f330989a3df3b2dd424d31c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/86/caeb58d7dd6f6511597a4a33b82f94a10ef0c71396c9582588bdd21c8c73': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/86': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/2f/0d6de8daa7de9c1a220162737d8aa09280826eb3cff7d6da43b38fcad8c0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/2f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/9c/6fffa7a1f3b1336db5fd1d177f3e1b2efd95f3689885306e8958693c380e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/9c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4c/811e3b437dc243385ceb2a5e7a681f88e9a8c832706a0be2697752e97ca9': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/4c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1b/f6b50f4c1ad5ccdba9c6ffc4fbd267713841d8d24039339fd97c4a03bb9a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/7c/02d2df9400272bb9cc56a006541e41460e8973721cd72ae78261e6db876b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/7c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/33/bea802424bc10eed30eed2ac1df5cd8277bdeedab5f08e3c4629fcaa68b6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/33': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/db/96ea9765abd3cc239baac6e194871f5fd7732a3657a7444b8c8513bc8455': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/db': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b5/844264280dfb76a29e7a7afe23fc05d40aac4dd573eea0bec2db2e5a2add': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b1/7f5a9b4981107c0957571c6aea09409de107f9203452fad14a9653b7cd72': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/b1': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1e/ae5e7b1c82b02a2af9acccb88bf4da3b2d5d059384f8d92af3c3b76a1a4c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/1e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d1/73825d96cbb41bc8c0bf9f2a78d6281633aebedbd052caaf1d51fffa4311': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/d1': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/97/fed28c4f00d3eeb0f0e79d50b09bd95e529fff6d4f1a764e73fcda69a842': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/97': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/f6/043b7bf3ca70506f520273ec16fa0316aa9269b2ee01429bb3298c94e053': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/f6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/14/c90049198f353f04aa7296e700da0a56b8c4b0e38184f9039b6724e62125': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd/14': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/cd': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ef/3e25234e1be03662057aeb474090c320ef2e89992c14b616f4c5469babba': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ef': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ec/d14829a7c1af48dbb7ff77fff9319258f8b205c7ce4a8fd95cf46a4bcadd': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/ec': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b6/899314477b68fc8d7aad3a64e8285f65984d38c54dcc3939db2606c921ba': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/38/e7c4949c208bda7986ed8052bb24441f6f116b54f6288e257a2aa1b633a3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/38': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/5d/393bfbcabebab0809010c29f6fb7c7f532f8333edc64be087a2ddcde2d86': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/5d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b0/a4331403838762a771b8749ad57d45f57b02407b4e467039188bd126fe96': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/59/4d920c893d5be1a1e54231c8cdd7fc182ea0c735346e4759ffb02c67f870': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/59': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/f9/4ada453499bcc74c6f62ab9565b490a863bc874d691677add95ecf947c78': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/f9': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b7/476b08defc5621c5ae7caf17631ea22fda40726e7c9898862f6ef34402fc': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b3/b16fdff1edd94b37a94bd7db2184982c2238e04c4eb0b665c8a081d3f5a9': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/b3': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/39/0d140fe159ac444763e5c4f05d9d2bba1327083675ed20dbbbf63683e7ff': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/39': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/03/f0dd7de970ceaa1f0b8e1bf05bbdfe065f5be795bcfb2e075e7576d7a670': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/03': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/54/4263efad7cfdd6f394d102bca236a76688809923cbe19f10331ded603b89': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/54': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/09/b5ad6166b743ce97673a0966ecde746512cbe18b4d7c310f36f03c01e3bd': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/09': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/88/8351ea69396b436ec7a2595350f815b4a595dd9449f447170068b8307051': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/88': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/01/f85ceaf0ff181f9b0db6422a6a86d713d2931f3c94b9bce872793e4f3bfb': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/01': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/92/646d6eb727e22ebeca12d558cffbe9fd8cf4f5674a4e411e68344640a6d0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/92': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/bf/d2987a7db80f4e0738cc6f2af13aadeaa56311fb9d65373b0e9bb20f67d5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/bf': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/da/4021979edf0d2c56dc28304170e8afe2f90ec1a5620cd987dde84e2fc58b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/da': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/73/47877fb05b9134a2e3b66012ed97767017380d4453582e9f39765e958d09': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/73': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/84/d39f10ff4bdf9bd11450faf4a8bbbe361ef4da77d743fce5adfbd4859d1a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/84': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/3e/151b03bcacd057978b4c891ae842f10b5c2fffcb8c0fe905a0ae7d3751d2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/3e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b/e21fe9c19b958a620cbc71d80f97bfc371bb361573d441294570eb583134': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b/12f2f7af7f950c23d4cdb66d81b57e5ffd679a24f66f54f69674376024a5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/7b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/cd/3539b50b6ce10a6099da623467c7a4f0930e6cc79b75ac77aff19c4c82b7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41/cd': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/41': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/ec/92e2016477c65cf7ae1b6c42f15723842175a9735acc8dd23a6b85afe34a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/ec': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/4a/a53ab2dd740f6401643d51bfee7c2e7d6120dba24b566422e7101b78da3e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/4a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/bd/a6f543a4c160c81541f1941ac3a4f22e24c720cb0812c8a0b4b190f525da': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/bd': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5f/a80eaf748391860ea374caba3171c449c4d9819ea99724eb644ff6db0e91': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e7/836747f2490d9ad67b369ec82fb4e0b82fbb8fe3ab58c500f4dee8c5d7a6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/31/11eb65d70a004ba6dc4f967bae593980ef09d70ba81fd2af497387d1d59a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/31': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/63/49d9d6a2058fb1376caf4de0884b52be6440a5a13a30ac7e5c720c7be0ad': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/63': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/75/0b298e16b2be5f5a50a3c46bd8ebf41296b5430a1faa29b08922bd2b2f14': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/75': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/45/0f087a72405cc722d634bcfedbc5b14d65cdf1e88b133cdde8d8c4c0c160': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/45': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/91/dbfac5a17511327401d3f24dbd4b15e42751a4ca0a9744d3e795cbb30772': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/91': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e4/85c453c0b7c6d00627bbc4a99aacaf9f8afc4a98a767adf60a0ccadbc990': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/e4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/69/1d82a0bae7afd711fcef1d246d260691a22315303d31f649187496291a78': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/69': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/c0/673e4f716a0a97692176a610b077c1e4c37f0657b07b69cac7afc9979405': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/c0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/37/c9e69f5074e9a22c766ffcc622280d4e580d2ee0238f670f28199487dd44': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/37': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/3b/7656677b4ce98fa80fbd05eb933b9b5a858fb4a25d07d9ecd22267443c62': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/3b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5b/a5ccd6d9f05959c1c89efc411510f733374f46f5e7c4ee798f587f5ae931': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/5b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/30/eb11cf8343b323649a963f633068a14c0cfe8e76c423f2107daa2a419059': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/30': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/be/6e1283f2345247c106f9fd360a38dfd752ea3fc358323729d4095f466da8': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/be': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/57/7f46ee7c4fb819256f5c28a6cd4f231734deae83dd742f2b523f10ac0633': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/57': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/95/fa9c994121ed142a2e5d4f1ac42e1b494f767340cb6ba4e34f0f31facc9d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/95': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/33/e5c1af689be93f794b86f66d7dfbe6bae4e548b2135a4789bf94a09d3372': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/33': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/73/7a110e38bbccbdf42210ae85da034a9311e0f4299050e50f3c8191501c71': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/73': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/12/377ab6ff432fac53c8c672a1bf5732512e5b619173714e383359d443642a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/12': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/61/8cbf374dc4a22dea9866259dd98cca4184f65ebaff7dba6afbeaf6e06fa4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/61': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/08/3ba9ab86283ac5b5641abfdd4a37885231614123fec1c9d9b47a1c12595a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6/08': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/e6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/fb/8c070eb7c9d840daf6f8862fdf5c462eef4ce470c92316b36076a8ec4ae2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/fb': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b8/c350b4c87e03f50e668f69fdc4840256ed1a3d60fbd3e90d624bd0138004': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b8': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/5d/70974ce696936b845f14e8e48e153f5dd7482eaf1f17a7af992a927115b8': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/5d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/19/b0d987af1fdb73b10ac24ff43db0f296be2745d0cd2bf5119078fac111e7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/19': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/63/c0df8adcf22021b52c33a707d11bb4428944f3147e167201933b77cd6551': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/63': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/4b/40bd19b841405182387e13123d31c6309b162d81d0db86ee52736a9bd643': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/4b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/a6/a58b1280f8bb14298a70a8ef7cdbab9f28d319d511f11ca084211f2bcc05': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/a6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/91/fc3843be160bcbe54a87c70cf0217f9f7166e72d297a198ed0f8cf93d7d5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/91': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/52/cfba3106ef0da44f06a883b7b9d1fc70b8ed2a1d170599f48805f689e53c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/52': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/44/6b35922d71beeb2843639c393d28f2684b260a14e0dc7ec7ce856b28610a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/44': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/6e/1b57fa2c400ae0176683235ee3685bcc4c42f3def62180e77471eb79fca4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/6e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/2f/dc75f5beaa45c77b4d14903f07840533c5357142fdba60d7c4481e4fc5db': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/2f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2/0e3c9e2baf2567a6bd9f81829d3cb6204255d8fbe622583524708853d610': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2/72a6c9df044cb26b10a04bf261bce41420c99f77d49e6a53e767ea3a6fa8': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/b2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/da/e8654aad33bbbf62a4857fbf8beed9c4ce05a6b6fee192da0d679cf0e3cc': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/da': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d2/d5d7acda4c2ad2ffbeda6ceb752dfc56f66153eac8ebc8f7ee2c5a8414b8': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/07/ba09e5cbea02069d6fc80814eca98c9ef14b785b54378abf33641eef8753': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/07': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/ac/feef31c8f79f79090b2ddd82e57346ae532d7e69fa53cee8969225ade33e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/ac': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d8/342048477d8d1a66dcf45723307d428757556956d99a5aed2bdb0f2a269b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d8': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/40/a0f8b6ed4650fba1bdce3d598725165dfde297436aa3bbd3c591c6fe4f21': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/40': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d1/54737918360c9f80d2be568380068e5f0c9d2ea370407da34d92a8f687c5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/d1': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/f6/492d7af722115ca18f328cce017e91ada962beb0adea68f213393af0928a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/f6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/08/5e07feb6be282ff79bae817d3fd16e5359483cd774f506cad08ba4e58eea': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c/08': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/0c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/b4/5e8ad2b29fe1334c4aa0178c518b43a732aab578a476f69cb49cc81a8762': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/b4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f0/22cc0b58a3130a20fc0015a98a37eff19452bd09903bad6286495faad602': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5f/066eac5b28b0fc192c75d345a821b4ea45dffebb1c729afd27e4fb90e111': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f5/462c0215e13359a052b9d08b2f00ef669a10531bcf01806ae0106c9e99d0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/cf/8711cafb6666a89091dfc5b318f2c5009e9be2ea25532b176edb9e312c88': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/cf': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/91/a77f215851fd29297a480f3edbed051747f3e7d5ca06d5612c842c1c6e31': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/91': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/3d/8a65927dadb603aa6974e7136c2539d30e27408a36712dc732da8ba52f87': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/3d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/26/8c97b83b5df53797ba6d8937982f6ff0336a8f15282585415484154a85a6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/26': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4d/d8bcde1b0c0e9022e4389a309fcde945357c90955f52a967f55bfecd86c9': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/32/d09169f60fcc3107c776d307f1225766793fc9086be98095a4fcda130355': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/32': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4f/b991304b3c794a52704073ade76bc3fdc85bea273ed875333feee9c50f41': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/4f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5c/8292eb35ff5c46c53be1f45609df1b5ad53b1ef7beb53e25830771fff476': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/5c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/c4/576ae94b481d6eba722899b489cbd0e629782a11798b7bc8a55fdb728630': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/c4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/15/8f5843e13eebe66d43fb4fce10a5b862a831e8e5cae63e31b326f1376c76': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/15': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f6/38b8038e95b147174eab43053d49e5078953e257487592e1ac94a0aa2544': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4/f6': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/f4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/9f/56df86c5348a44745233ccca8b1cf6d9e372726c0c2bb6404a3274e02c63': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/9f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/1d/255a2fe5c32486b5e3869636f5f541a825ca87912ce55459478af5d5db8f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/1d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/18/13e5f9ff07fea3e2e6cbdabb965524040a2a95e912ce1327641fc2c86a9e': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/18': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b7/3ec33017ccd57f05bcb1cd5b86f58cfad2f5087ec3f70e7697c7ee8fdfd0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/af/43873f6488ed910e6a4c19415fa4f6ec72fab2d58568d8dc39fd00bfe614': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/af': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2/80dc7881806fc9766aaf8871f305013551427a6fc2ccf54c7c6c9e1cbdc4': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2/d0ac28c8886d6cc0cc3d5d9b8f9c6ce73a0b0aa163fee6f96fdcf19d1b77': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/a2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/70/edd39740b489f3bf9dcf50dac3465c5292428092177e8513dcde4970025c': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/70': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/4f/bdc56d6040878bf76dd7291eaf4aa1effc129360c0c415dcbab70392f371': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/4f': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/86/4d07f9d587581d931fc5c689754fe98f9d5db2c028449bacd8b94ced52e2': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/86': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/92/93cc98c580e58ecce81f2c200e7a1ae3118e645eea4218f8a655c7f732f8': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/92': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/02/2a512783001403565cf7460ec142510337da7589c82f0d17b3f0c10f204a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/02': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73/b909ded8d742ea013c07c94da2088b4eb708d22a8a7a79b799528b4e0ab0': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73/d6f3db4659ba10691d680e0fb26886d5699d6cfe92b3ac5ad0c9b0916a0a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/73': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b5/8cbe8c4af4bc8892f2688ef27617b41965ee1f0692fa48d0c722d782598d': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/b5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/7a/cc8368635ad6a5279a0cec27dcb6bb44c0ea1c4e62950fc081721af4c205': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/7a': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/42/390144a89b8971bc53d08c2597eb88288e52cf442b526f07a06996cdb209': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/42': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/8b/763c67ce4bcc6a34398d50c8f871b39118cb4437567a2d82cc97651a9d86': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/8b': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/cd/94ce767cc4b22c4a02e3b458a868966790c44d93f2f389d0ef78e7e30687': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7/cd': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5/a7': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache/index-v5': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_cacache': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/anonymous-cli-metrics.json': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_locks': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T11_08_11_932Z-debug.log': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-31T19_33_06_675Z-debug.log': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-31T19_28_39_025Z-debug.log': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T21_18_28_912Z-debug.log': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_logs/2019-10-29T21_27_06_925Z-debug.log': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_logs': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_prebuilds/a93ec4-bindings-v2.0.8-node-v64-linux-x64.tar.gz': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm/_prebuilds': Read-only file system
                                        chown: changing ownership of '/home/iobroker/.npm': Read-only file system
                                        This system does not support setting default permissions.
                                        Do not use npm to manually install adapters unless you know what you are doing!
                                        main: line 536: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                            Checking autostart (3/3)
                                        rm: cannot remove '/lib/systemd/system/iobroker.service': Read-only file system
                                        bash: line 742: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                        bash: line 764: cannot create temp file for here-document: Read-only file system
                                        rm: cannot remove '/opt/iobroker/iobroker': Read-only file system
                                        rm: cannot remove '/usr/bin/iobroker': Read-only file system
                                        rm: cannot remove '/opt/iobroker/iob': Read-only file system
                                        rm: cannot remove '/usr/bin/iob': Read-only file system
                                        ln: failed to create symbolic link '/usr/bin/iobroker': Read-only file system
                                        ln: failed to create symbolic link '/usr/bin/iob': Read-only file system
                                        ln: failed to create symbolic link '/opt/iobroker/iob': Read-only file system
                                        chmod: changing permissions of '/opt/iobroker/iobroker': Read-only file system
                                        chown: changing ownership of '/opt/iobroker/iobroker': Read-only file system
                                        chown: changing ownership of '/opt/iobroker/iob': Read-only file system
                                        Enabling autostart...
                                        bash: line 896: cannot create temp file for here-document: Read-only file system
                                        chmod: changing permissions of '/lib/systemd/system/iobroker.service': Read-only file system
                                        Autostart enabled!
                                        bash: line 909: /opt/iobroker/INSTALLER_INFO.txt: Read-only file system
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                        #170
                                        @e-i-k-e Mal FileSystem check machen von der VM ...
                                        • PeoplesP Peoples
                                          Verschoben
                                          #171
                                          @Peoples lass das doch bitte in dem anderen verlinkten Thread diskutieren. Dann sind diese Themen zusammen!
                                          Generell: der controller kann rename, javascript Adapter aber stellt die Funktion nicht bereit. Daher read/write ...
