  4. [Neuer Adapter] Homepilot20
    1.0k
    6.1k
adapter
268 Beiträge 57 Kommentatoren 69.6k Aufrufe 51 Beobachtet
  • I Indiz
    @homecineplexx
    Hallo Chris,
    hier der Output von http://<hompilot-ip>/v4/devices?devtype=Transmitter
    {"response":"get_transmitters","transmitters":[{"description":"Ihre Gerätebeschreibung","did":1010014,"name":"Handsender GZ","uid":"a054e9_1","deviceNumber":"32480366","deviceGroup":10,"statusValid":true,"visible":true,"iconSetInverted":0,"iconSet":{"k":"iconset35"},"batteryLow":false},{"description":"Ihre Gerätebeschreibung","did":1010019,"name":"Handsender KZ","uid":"a0680f_1","deviceNumber":"32480366","deviceGroup":10,"statusValid":true,"visible":true,"iconSetInverted":0,"iconSet":{"k":"iconset35"},"batteryLow":false},{"description":"Ihre Gerätebeschreibung","did":1010016,"name":"Handsender WZ","uid":"a06800_1","deviceNumber":"32480366","deviceGroup":10,"statusValid":true,"visible":true,"iconSetInverted":0,"iconSet":{"k":"iconset35"},"batteryLow":false}]}
    LG
    Micha
    homecineplexx
    @Indiz
    ok super danke und nun bräuchte ich noch folgendes:
    http://<hompilot-ip>/devices/1010014
    I 1 Antwort Letzte Antwort
    • H homecineplexx
      @Indiz
      I Offline
      I Offline
      Indiz
      @homecineplexx said in [Neuer Adapter] Homepilot20:
      Hallo Chris,
      nachfolgend der gewünschte Output:
      {"error_description":"OK","error_code":0,"payload":{"device":{"capabilities":[{"name":"KEY_DOWN_EVT","min_value":"1","max_value":"6","step_size":"1","timestamp":-1},{"name":"KEY_INC_EVT","min_value":"1","max_value":"6","step_size":"1","timestamp":-1},{"name":"BATT_LOW_EVT","value":"false","timestamp":1570686187},{"name":"PAIRING_CONFIRMED_LOC","value":"true","timestamp":-1},{"name":"ID_DEVICE_LOC","value":"1010014","timestamp":-1},{"name":"PROTOCOL_ID_CFG","value":"a054e9","timestamp":-1},{"name":"VERSION_CFG","value":"1.6","timestamp":1570686187},{"name":"PROD_CODE_DEVICE_LOC","value":"32480366","timestamp":-1},{"name":"REACHABILITY_EVT","value":"true","timestamp":1570686187},{"name":"KEY_STOP_EVT","min_value":"1","max_value":"6","step_size":"1","timestamp":-1},{"name":"NAME_DEVICE_LOC","value":"Handsender GZ","timestamp":-1},{"name":"PROT_ID_DEVICE_LOC","value":"a054e9_1","timestamp":-1},{"name":"INTF_ID_DEVICE_LOC","value":"3","timestamp":-1},{"name":"KEY_DEC_EVT","min_value":"1","max_value":"6","step_size":"1","timestamp":-1},{"name":"KEY_UP_EVT","value":"1","min_value":"1","max_value":"6","step_size":"1","timestamp":1570686187},{"name":"ICONSET_LOC","value":"iconset35","timestamp":-1},{"name":"VIS_DEVICE_LOC","value":"true","timestamp":-1},{"name":"DEVICE_TYPE_LOC","value":"10","timestamp":-1},{"name":"ICONSET_INV_LOC","value":"false","timestamp":-1},{"name":"DESCR_DEVICE_LOC","value":"Ihre Gerätebeschreibung","timestamp":-1}],"scenes":[]}}}
      Gruß und vielen Dank
      Micha
      H 1 Antwort Letzte Antwort
      • H homecineplexx
        @Indiz
        hi, also was ich aus deinem log sehe, dass das ack flag auf true gesetzt wird. ist komisch, denn das macht normalerweise nur der adapter und du hast es aber nicht über den adapter gesetzt. änder das mal auf false und versuch es
        glg chris
        I Offline
        I Offline
        Indiz
        schrieb am zuletzt editiert von Indiz
        @homecineplexx
        Hallo Chris,
        stimmt, ack steht auf true. Ich verwende den "mqtt out node" und habe echt viel gesucht aber leider nichts gefunden wie ich diesen Node dazu überreden kann, statt ack=true ack=false zu senden. Kannst Du mir auf die Sprünge helfen?
        Der Node-Red Flow sieht wie folgt aus:
        Verwende ich den ioBroker Out Node fährt zwar das Rollo aber der MQTT Server bekommt das irgendwie nicht mit (bleibt auf 0 stehen obwohl beispielsweise hier 10% unten)
        Nachtrag: ... nach dem Restart des Adapters wurde auch der Wert erkannt und übernommen.
        LG
        Micha
        H V 2 Antworten Letzte Antwort
        • I Indiz
          Hallo Chris,
          Micha
          homecineplexx
          @Indiz said in [Neuer Adapter] Homepilot20:
          Hallo Chris,
          Micha
          also ich hab dir das device jetzt eingebaut und auf git gepushed...könntest mal probieren
          • I Indiz
            @homecineplexx
            Hallo Chris,
            LG
            Micha
            homecineplexx
            @homecineplexx
            Hallo Chris,
            LG
            Micha
            ich verwende Node-Red ja nicht, daher bin ich dir da auch keine Hilfe, oder funktioniert das nun eh (wie im Nachtrag geschrieben)?
            • H homecineplexx
              Hallo Chris,
              Micha
              I Offline
              I Offline
              Indiz
              @homecineplexx
              Hallo Chris,
              ja, klappt.
              Die Node-Red Verbindung klappt mit dem ioBroker Out Node auch. Mit dem mqtt out Node leider nicht - aber egal, ich verwende hierfür jetzt den ioBroker Out Node.
              Vielen, vielen Dank für Deinen Support und für Deine Arbeit! TOP! 👍 👍 👍
              LG Micha
                ArminPetry
                @homecineplexx Hallo Chris,
                vielen Dank für die schnelle Umsetzung des Adapters. Funktioniert prima.
                Lediglich die Rademacher Innenkamera HD9483 liefert permanent Fehler im Log:
                "homepilot20.0 2019-11-05 19:52:46.251 warn (7525) Unknown Sensor deviceNumber=32004119"
                Diese ist wohl im Adapter noch nicht implementiert. Wäre toll, wenn Du die Kamera noch ergänzen könntest.
                LG Armin
                • A ArminPetry
                  LG Armin
                  homecineplexx
                  @ArminPetry said in [Neuer Adapter] Homepilot20:
                  LG Armin
                  hallo Armin
                  wenn du möchtest, könnte ich dir diese Kamera noch integrieren, wobei ich nicht weiß, welche möglichkeiten man damit hätte.
                  oder du ignorierst den LOG.
                  glg chris
                  • H homecineplexx
                    LG Armin
                    hallo Armin
                    glg chris
                    ArminPetry
                    Hallo Chris,
                    wäre die Bewegungserkennung der Kamera in Iobroker auswertbar?
                    Hier der Output von http://<homepilot-ip>/v4/devices?devtype=Sensor:
                    {"response":"get_meters","meters":[{"description":"Flur","deviceGroup":9,"did":1010015,"automations":[90],"readings":{"movement_detected":false},"timestamp":1573065540,"iconSetInverted":0,"iconSet":{"k":"iconset23"},"name":"HD_Kamera_9483","statusValid":true,"deviceNumber":"32004119","uid":"CAM_VV94831505045332-kTul64uoNF5taBX","visible":true}]}
                    LG Armin
                    W 1 Antwort Letzte Antwort
                    • W Offline
                      W Offline
                      Wumpus
                      @homecineplexx
                      Hallo Chris,
                      vielen Dank für Deine Arbeit, es funktioniert soweit alles wunderbar.
                      Es gibt von Rademacher noch den Garagentorantrieb RolloPort SX5 DuoFern zur Bedienung von Schwing- und Sektionaltoren. Dieser ist momentan bei Dir noch nicht implementiert. Der Garagentorantrieb wird wie ein Rohrmotor angesteuert.
                      homepilot20.0.Actuator-json
                      {"description": "Garagentorantrieb",
                       "deviceGroup": 8,
                       "did": 1010007,
                       "hasErrors": 0,
                       "iconSetInverted": 0,
                       "iconSet": {"k": "iconset20"},
                       "messages": [],
                       "name": "Garagentor links",
                       "properties": {"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3, warning":3,"wind":3},
                       "statusValid": true,
                       "statusesMap": {"Manuellbetrieb": 0,"Position": 0},
                       "visible": true,
                       "deviceNumber": "45059071",
                       "uid": "4e1160_1",
                       "voiceControlledBy": ""}
                      Um den Garagentorantrieb zu unterstützen, bedarf es nur 3 kleiner Änderungen:
                      Datei main.js:
                      deviceNumberId == '27601565' /*DuoFern-Rohrmotor*/ ||
                      /* dies hier neu einfuegen fuer Garagentorantrieb */
                      deviceNumberId == '45059071' /*RolloPort SX5 DuoFern*/ ||
                      /* Ende von einfuegen fuer Garagentorantrieb */
                      deviceNumberId == '35000462' /*DuoFern-Universal-Dimmaktor*/ ||
                      case "27601565":
                        deviceType = 'DuoFern-Rohrmotor';
                        deviceRole = 'level.blind';
                        break;
                      case "45059071":
                        deviceType = 'RolloPort-SX5-DuoFern';
                        break;
                      case "36500572":
                        deviceType = 'DuoFern-Troll-Comfort-5665';
                        break;
                      Datei docs/de/doc_homepilot20_de.md:
                      |   27601565    |  DuoFern Rohrmotor                         |                            | level.blind            |         | Actuator             | 0 - 100 %  |
                      |   45059071    |  RolloPort SX5 DuoFern                     |                            | level.blind            |         | Actuator             | 0 - 100 %  |
                      |   14236011    |  DuoFern RolloTron Pro Comfort             |                            | level.blind            |  9800   | Actuator             | 0 - 100 %  |
                      Wäre super, wenn Du die Änderungen auch bei Dir machen könntest, dann können alle anderen ihren Garagentorantrieb auch integrieren.
                      • A ArminPetry
                        Hallo Chris,
                        LG Armin
                        W Offline
                        W Offline
                        Wumpus
                        Hallo Chris,
                        Hallo Armin,
                        da die Innenkamera 9483 genauso angesteuert wird wie die Außenkamera 9487, benötigt man nur 4 kleine Änderungen:
                        Datei main.js:
                        case "32004329":
                         deviceType = 'HD-Kamera-9487-A';
                         //additionalSensorSettings.push(deviceId);
                         break;
                        // diese 3 Zeilen neu für Innenkamera
                        case "32004119":
                         deviceType = 'IP-Kamera-9483';
                         break;
                        // Ende neue Zeilen für Innenkamera
                        if (deviceNumber == '32501772' /*DuoFern-Bewegungsmelder-9484*/ ||
                            deviceNumber == '32004119' /*IP-Kamera-9483*/ ||   // <-- diese Zeile neu für Innenkamera
                            deviceNumber == '32004329' /*HD-Kamera-9487-A*/) {
                        |   32004329    |  HD-Kamera                                 |                            | text                   |  9487   | Sensor               |            |
                        |   32004119    |  IP-Kamera innen                           |                            | text                   |  9483   | Sensor               |            |
                        @homecineplexx
                        Es wäre super, wenn Du diese Änderungen auch bei Dir vornehmen könntest.
                        • W Offline
                          W Offline
                          Wumpus
                          @homecineplexx
                          Hallo Chris,
                          nochmal ich. Wenn das so weiter geht, dann mache ich mir doch noch einen github-Account und sende einen pull-request.
                          Rademacher hat ja 2 Handsender, einmal den 6-Kanal-Sender Typ 9491 und den 1-Kanal-Sender 9491-2. Ersterer wird unterstützt, letzterer bisher nicht.
                          Um das zu ändern, bedarf es weiterer 4 Änderungen:
                          Datei main.js:
                          case "32480366":
                            deviceType = 'DuoFern-Handsender-Standard-9491';
                            break;
                          // ab hier 3 neue Zeilen einfügen für Handsender 1-Kanal
                          case "32480361":
                            deviceType = 'DuoFern-Handsender-Standard-9491-2';
                            break;
                          // Ende der neuen Zeilen für Handsender 1-Kanal
                          if (deviceNumber == '32160211' /*DuoFern-Wandtaster-9494*/ ||
                              deviceNumber == '32501974' /*DuoFern-Mehrfachwandtaster-BAT-9494-1*/ ||
                              deviceNumber == '34810060' /*DuoFern-Handzentrale-9493*/ ||
                              deviceNumber == '32480361' /*DuoFern-Handsender-Standard-9491-2*/ ||  // diese Zeile neu für Handsender 1-Kanal
                              deviceNumber == '32480366' /*DuoFern-Handsender-Standard-9491*/) {
                          |   32480366    |  DuoFern Handsender Standard 9491          |                            | text                   |  9491   | Transmitter          |            |
                          |   32480361    |  DuoFern Handsender Standard 9491-2        |                            | text                   |  9491-2 | Transmitter          |            |
                          So, das waren genug Änderungen für heute.
                          Bis Bald 😊
                          • H Offline
                            homecineplexx
                            hallo wumpus
                            ich bau dir das ein...dauert nur ein paar Tage...ich geb dir bescheid!
                            danke für die info
                            lg
                            • W Wumpus
                              Hallo Chris,
                              Hallo Armin,
                              Datei main.js:
                              case "32004329":
                               break;
                              case "32004119":
                               break;
                              @homecineplexx
                              ArminPetry
                              @Wumpus Vielen Dank, funktioniert einwandfrei.
                                dougstar
                                Moin, ich bin leider noch recht neu mit dem iobroker unterwegs.
                                Wie installiere ich den neuen Adapter auf einer Raspi?
                                Danke und Gruß
                                Doug
                                • W Offline
                                  W Offline
                                  Wumpus
                                  @dougstar
                                  Da der Adapter noch so neu ist, mußt Du ihn momentan noch manuell installieren:
                                  In einem Terminalfenster(#) folgendes eingeben:
                                  cd /opt/iobroker
                                  iobroker stop
                                  npm install iobroker.homepilot20
                                  iobroker upload homepilot20
                                  iobroker start
                                  Danach erscheint der Adapter in der Weboberfläche im Menüpunkt Adapter und Du kannst ihn ganz normal installieren, wie alle anderen Adapter auch.
                                  (#) In das Terminalfenster kommst Du z.B. indem Du Dich per SSH auf dem Computer einloggst, auf dem Du ioBroker installiert hast.
                                  Wenn Du weitere Frage hast, melde Dich nochmal.
                                  D D 2 Antworten Letzte Antwort
                                  • W Wumpus
                                    @dougstar
                                    cd /opt/iobroker
                                    iobroker stop
                                    iobroker start
                                    dougstar
                                    @Wumpus Danke
                                    jetzt kommt der nächste Fehler
                                    npm ERR! code EAI_AGAIN
                                    npm ERR! errno EAI_AGAIN
                                    npm ERR! request to https://github.com/homecineplexx/ioBroker.homepilot20/tarball/master failed, reason: getaddrinfo EAI_AGAIN github.com:443
                                    npm ERR! /home/pi/.npm/_logs/2019-11-19T21_25_36_133Z-debug.log
                                    • W Offline
                                      W Offline
                                      Wumpus
                                      @dougstar
                                      Tante Google sagt: "EAI_AGAIN is a DNS lookup timed out error, means it is a network connectivity error or proxy related error."
                                      Scheint also ein Netzwerkfehler zu sein. Versuche, den Befehl npm install iobroker.homepilot20 nochmal auszuführen.
                                      Was könnte man machen, wenn es immer noch nicht geht? Die Datei manuell herunterladen und dann installieren? Müsste gehen. Im Verzeichnis /opt/iobroker folgendes eingeben:
                                      wget --output-document=homepilot20.tar.gz https://github.com/homecineplexx/ioBroker.homepilot20/tarball/master
                                      npm install homepilot20.tar.gz
                                      • W Wumpus
                                        @dougstar
                                        dougstar
                                        @Wumpus / rollbackFailedOptional: verb npm-session
                                        Google hat mir da noch keine Hilfe gebracht :-(
                                        • W Offline
                                          W Offline
                                          Wumpus
                                          Welcher Befehl hat die neue Fehlermeldung verursacht? npm install homepilot20.tar.gz?
