  4. Test Adapter Weatherunderground v3.1.x
weatherundergroundweatherunderground adapter
43 Beiträge 9 Kommentatoren 5.0k Aufrufe 7 Beobachtet
  • apollon77A Offline
    ok, schmeiss mal die ganzen URLs aus den States auch raus. Eine URL ist falsch
    • apollon77A apollon77
      crunchipC Offline
      crunchipC Offline
      @apollon77 hab alle drei entfernt, jedoch immer noch der gleiche Fehler
        nochmal log bitte
          nochmal log bitte
          crunchipC Offline
          crunchipC Offline
          @apollon77
          2019-10-27 21:32:35.788 - info: host.IoBroker instance scheduled system.adapter.weatherunderground.0 */11 * * * *
          2019-10-27 21:32:35.814 - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 22519
          2019-10-27 21:32:36.956 - debug: weatherunderground.0 (22519) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2019-10-27 21:32:37.023 - debug: weatherunderground.0 (22519) Objects connected to redis: 127.0.0.1:9001
          2019-10-27 21:32:37.030 - debug: weatherunderground.0 (22519) objectDB connected
          2019-10-27 21:32:37.033 - debug: weatherunderground.0 (22519) Redis States: Use Redis connection: 127.0.0.1:6379
          2019-10-27 21:32:37.041 - debug: weatherunderground.0 (22519) statesDB connected
          2019-10-27 21:32:37.061 - debug: weatherunderground.0 (22519) States connected to redis: 127.0.0.1:6379
          2019-10-27 21:32:37.798 - info: weatherunderground.0 (22519) starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.16.0
          2019-10-27 21:32:37.832 - debug: weatherunderground.0 (22519) on ready: DL true true true true
          2019-10-27 21:32:37.837 - debug: weatherunderground.0 (22519) init conditions objects
          2019-10-27 21:32:37.845 - debug: weatherunderground.0 (22519) init forecast objects
          2019-10-27 21:32:37.994 - debug: weatherunderground.0 (22519) initialize PWS Station Key: d8585d80376a429e
          2019-10-27 21:32:38.051 - debug: weatherunderground.0 (22519) initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
          2019-10-27 21:32:38.058 - debug: weatherunderground.0 (22519) initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IBURGE2&format=json
          2019-10-27 21:32:38.060 - debug: weatherunderground.0 (22519) initialize Daily Forecast Url: https://api.weather.com/v3/wx/forecast/daily/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=49.773%2C10.804&language=en-US&units=e&format=json
          2019-10-27 21:32:38.064 - debug: weatherunderground.0 (22519) initialize Hourly Forecast Url: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=49.773%2C10.804&units=e&language=en-US&format=json
          2019-10-27 21:32:38.067 - debug: weatherunderground.0 (22519) location has not changed, reuse extracted URLs
          2019-10-27 21:32:38.070 - debug: weatherunderground.0 (22519) Use New API
          2019-10-27 21:32:38.071 - debug: weatherunderground.0 (22519) Use new API Key 6532d6454b8aa370768e63d6ba5a832e
          2019-10-27 21:32:38.071 - debug: weatherunderground.0 (22519) get current observation data: https://api.weather.com/v2/pws/observations/current?stationId=IPOMME2&format=json&units=m&numericPrecision=decimal&apiKey=3d1dcaf9453a47dc9dcaf9453a07dc04
          2019-10-27 21:32:38.402 - error: weatherunderground.0 (22519) Wunderground reported an error: 204/null
          2019-10-27 21:32:38.404 - debug: weatherunderground.0 (22519) get daily forecast data: https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=49.773%2C10.804&language=de&units=m&format=json
          2019-10-27 21:32:38.462 - debug: weatherunderground.0 (22519) get hourly forecast data: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=49.773%2C10.804&units=m&language=de&format=json
          2019-10-27 21:32:38.572 - error: weatherunderground.0 (22519) No current observation data found in response
          2019-10-27 21:32:38.712 - debug: weatherunderground.0 (22519) all forecast values set
          2019-10-27 21:32:41.222 - info: weatherunderground.0 (22519) Terminated (NO_ERROR): Without reason
          2019-10-27 21:32:41.759 - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
            @apollon77
            @crunchip Bei mir funktioniert alles. Ich hatte schonmal solche Antworten wenn die Wetterstation nichts gemeldet hatte. Zeit die WU Webseite aktuelle Daten an?
              crunchipC Offline
              crunchipC Offline
              @apollon77 das ist meine eigene Wetterstation😁
                Zeit WU Webseite aktuelle Daten an? Wie gesagt hatte ich bei mir auch mal ... oder schalt mal aus, lass mal ne Stunde aus :-)
                  crunchipC Offline
                  crunchipC Offline
                  @apollon77 das hängt dann aber mit WU zusammen, Gerät ist dort online aber keine Daten
                  meine Station sendet auch an weathercloud und da sind Daten vorhanden
                  ich steck se mal kurz aus, damit se sich neu verbindet
                    crunchipC Offline
                    crunchipC Offline
                    @apollon77 also, ich werd es mir für die Zukunft merken, erstmal gucken ob meine Station noch sendet bzw dort was ankommt ☺ klappt übrigens wieder, kurz mal vom Netzt genommen....keine Fehlermeldung mehr.
                    verstehen kann ich´s aber trotzdem nicht
                    • W Offline
                      W Offline
                      watcherkb
                      @apollon77 bekomme seit gestern Abend keine neuen Daten rein.
                      weatherunderground.0	2019-11-14 12:24:34.812	debug	system.adapter.admin.0: logging true
                      weatherunderground.0	2019-11-14 12:24:32.707	debug	all forecast values set
                      weatherunderground.0	2019-11-14 12:24:32.695	error	No current observation data found in response
                      weatherunderground.0	2019-11-14 12:24:32.527	debug	get hourly forecast data: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.13%2C8.67&units=m&language=de&format=json
                      weatherunderground.0	2019-11-14 12:24:32.377	debug	get daily forecast data: https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.13%2C8.67&language=de&units=m&format=json
                      weatherunderground.0	2019-11-14 12:24:32.376	error	Wunderground reported an error: 204/null
                      weatherunderground.0	2019-11-14 12:24:32.069	debug	get current observation data: https://api.weather.com/v2/pws/observations/current?numericPrecision=decimal&apiKey=6532d6454b8aa370768e63d6ba5a832e&units=m&stationId=IHERFORD67&format=json
                      weatherunderground.0	2019-11-14 12:24:32.069	debug	Use new API Key 6532d6454b8aa370768e63d6ba5a832e
                      weatherunderground.0	2019-11-14 12:24:32.068	debug	Use New API
                      weatherunderground.0	2019-11-14 12:24:32.068	debug	location has not changed, reuse extracted URLs
                      weatherunderground.0	2019-11-14 12:24:32.065	debug	initialize Hourly Forecast Url: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.13%2C8.67&units=e&language=en-US&format=json
                      weatherunderground.0	2019-11-14 12:24:32.064	debug	initialize Daily Forecast Url: https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.13%2C8.67&language=en-US&units=e&format=json
                      weatherunderground.0	2019-11-14 12:24:32.062	debug	initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IHERFORD67&format=json
                      weatherunderground.0	2019-11-14 12:24:32.062	debug	initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
                      weatherunderground.0	2019-11-14 12:24:31.987	debug	initialize PWS Station Key: d8585d80376a429e
                      weatherunderground.0	2019-11-14 12:24:31.867	debug	init forecast objects
                      weatherunderground.0	2019-11-14 12:24:31.866	debug	init conditions objects
                      weatherunderground.0	2019-11-14 12:24:31.865	debug	on ready: DL true true true true
                      weatherunderground.0	2019-11-14 12:24:31.850	info	starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.16.3
                      weatherunderground.0	2019-11-14 12:24:31.842	debug	statesDB connected
                      weatherunderground.0	2019-11-14 12:24:31.835	debug	objectDB connected
                      host.IOBroker_Produktiv	2019-11-14 12:24:31.597	info	instance system.adapter.weatherunderground.0 started with pid 29224
                      host.IOBroker_Produktiv	2019-11-14 12:24:31.587	info	instance scheduled system.adapter.weatherunderground.0 15 * * * *
                      host.IOBroker_Produktiv	2019-11-14 12:24:29.085	warn	stopInstance system.adapter.weatherunderground.0 not scheduled
                      host.IOBroker_Produktiv	2019-11-14 12:24:29.085	info	stopInstance system.adapter.weatherunderground.0
                      host.IOBroker_Produktiv	2019-11-14 12:24:29.085	info	"system.adapter.weatherunderground.0" enabled
                      host.IOBroker_Produktiv	2019-11-14 12:24:29.085	info	object change system.adapter.weatherunderground.0
                      Über StationID auf der Website sind die Daten aber aktuell.
                      CC2538+CC2592 PA-Zigbee-Funkmodul
                      apollon77A 2 Antworten Letzte Antwort
                      • W watcherkb
                        @watcherkb sagte in Test Adapter Weatherunderground v3.1.x:
                        ja die observation url liefert nix zurück ... hm
                        • W watcherkb
                          Scheinbar liefert die Station aktuell keine neuen Daten. Das Problem hatten wir schon hier und da mal und hat sich meistens nach gewisser Zeit wieder gegeben - oder restart der Station
                          W 1 Antwort Letzte Antwort
                            W Offline
                            W Offline
                            watcherkb
                            @apollon77 alles klar. Hab dann mal ne andere Station angezapft und jetzt sieht es gut aus.
                            • G Offline
                              gerald123
                              Hab ein Problem beim Einrichten des WU Adapters.
                              Ich habe eine WS3500 Wetterstation die bei Wunderground registriert ist und dort auch die Werte anzeigt.
                              Jetzt wollte ich eine zweite WU Instanz anlegen und habe da auch den API Key eingetragen.
                              Leider bekomme ich in den Objekten keine Werte angezeigt.
                              Im Log wird folgendes Angezeigt:
                              weatherunderground.1	2020-01-25 20:12:05.034	info	(31582) Terminated (NO_ERROR): Without reason
                              weatherunderground.1	2020-01-25 20:12:02.527	error	(31582) No forecast data found in response
                              weatherunderground.1	2020-01-25 20:12:02.527	error	(31582) No current observation data found in response
                              weatherunderground.1	2020-01-25 20:12:02.524	error	(31582) Wunderground reported an error: --/Error: options.uri is a required argument
                              weatherunderground.1	2020-01-25 20:12:02.522	error	(31582) Wunderground reported an error: --/Error: options.uri is a required argument
                              weatherunderground.1	2020-01-25 20:12:02.520	error	(31582) Wunderground reported an error: --/Error: options.uri is a required argument
                              weatherunderground.1	2020-01-25 20:12:01.672	info	(31582) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.18.1
                              Kann mir jemand weiterhelfen was bei den Einstellungen noch fehlt
                              Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
                              • G gerald123
                                crunchipC Offline
                                crunchipC Offline
                                @gerald123
                                • für was eine 2. Instanz?
                                • Einstellungen alle ausgefüllt? DE Koordinaten NamederStation
                                also kleiner Hinweis noch, für diejenigen, die eine eigene Wetterstation haben und sich die Daten direkt holen wollen
                                https://forum.iobroker.net/post/350116
                                • G Offline
                                  gerald123
                                  Ich habe erst seit einer Woche meine eigene Wetterstation, vorher habe ich eine in meiner Nähe abgefragt.
                                  Daher die zwei Instanzen.
                                  Ausgefüllt habe ich alles mit meinen Daten, leider kommt da nichts.
                                  Den anderen Post habe ich auch schon gelesen, aber habe noch nicht ganz verstanden was da alles wo installiert werden muss.
                                  • G gerald123
                                    crunchipC Offline
                                    crunchipC Offline
                                    @gerald123 deine 1. Instanz ist also ohne Api Key und funktioniert?
                                    hast du die anderen Möglichkeiten auch mal getestet? Bei Ort, die Stadt bzw Wetterstation-ID
                                    G 1 Antwort Letzte Antwort
                                      Zeig mal die Konfig bitte (Screenshot oder so)
                                        gerald123
                                        @crunchip Ja, die 1. Instanz ist ohne API und funktioniert.
                                        Bei der 2ten habe ich alle Varianten getestet aber leider funktioniert es nicht mit meinen Daten
                                        • G gerald123
                                          @gerald123 Ute konfig Screenshot und Adapter logging auf debug stelle und log Posten. Danke. Wenn du wegen dem api key nicht willst dann kannst du mir das auch als email an iobroker@fischer-ka.de schicken
