  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер sayit
Драйвер sayit
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
178 Beiträge 16 Kommentatoren 78.1k Aufrufe 2 Beobachtet
  • BluefoxB
    #98
    Поправил. Спасибо.
    • I
      I
      instalator
      #99
      Добрался я до sayit наконец то, но не тут то было, драйвер не работает
      ! sayit.0 2015-11-01 22:27:55 error TypeError: Cannot call method 'exec' of undefined at sayItSystem (C:\ioBroker\node_modules\iobroker.sayit\main.js:733:37) at Object.sayItWindows [as func] (C:\ioBroker\node_modules\iobroker.sayit\main.js:767:9) at C:\ioBroker\node_modules\iobroker.sayit\main.js:1042:51 at getLength (C:\ioBroker\node_modules\iobroker.sayit\main.js:172:23) at sayIt (C:\ioBroker\node_modules\iobroker.sayit\main.js:1041:13) at Adapter.sayLastGeneratedText (C:\ioBroker\node_modules\iobroker.sayit\main.js:27:13) at Adapter.emit (events.js:98:17) at null._onTimeout (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:1911:34) at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
      ! sayit.0 2015-11-01 22:27:55 error uncaught exception: Cannot call method 'exec' of undefined
      ! host-Server-PC 2015-11-01 22:22:53 error instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
      ! TypeError: 2015-11-01 22:22:53 error at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
      ! TypeError: 2015-11-01 22:22:53 error at null._onTimeout (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:1911:34)
      ! TypeError: 2015-11-01 22:22:53 error at Adapter.emit (events.js:98:17)
      ! TypeError: 2015-11-01 22:22:53 error at Adapter.sayLastGeneratedText (C:\ioBroker\node_modules\iobroker.sayit\main.js:27:13)
      ! TypeError: 2015-11-01 22:22:53 error at sayIt (C:\ioBroker\node_modules\iobroker.sayit\main.js:1041:13)
      ! TypeError: 2015-11-01 22:22:53 error at getLength (C:\ioBroker\node_modules\iobroker.sayit\main.js:172:23)
      ! TypeError: 2015-11-01 22:22:53 error at C:\ioBroker\node_modules\iobroker.sayit\main.js:1042:51
      ! TypeError: 2015-11-01 22:22:53 error at Object.sayItWindows [as func] (C:\ioBroker\node_modules\iobroker.sayit\main.js:767:9)
      ! TypeError: 2015-11-01 22:22:53 error at sayItSystem (C:\ioBroker\node_modules\iobroker.sayit\main.js:733:37)
      ! TypeError: 2015-11-01 22:22:53 error Cannot call method 'exec' of undefined
      ! uncaught 2015-11-01 22:22:52 error exception: Cannot call method 'exec' of undefined
      Высокий уровень Децибел вреден для здоровья!
      http://blog.instalator.ru/
      • I
        I
        instalator
        #100
        @instalator:
        ! uncaught 2015-11-01 22:22:52 error exception: Cannot call method 'exec' of undefined `
        Заработал, нужно было выбрать System а стоял Windows engine
        • I
          I
          instalator
          #101
          Вопрос к Bluefox.
          Может добавить в драйвер возможность задать время задержки перед дин дон?
          Смысл в том что сделал усилитель D класса на микрушке, так вот у него есть логический вход FADE, т.е. при подачи управляющего сигнала он плавно включает громкость (примерно 2 сек.) и так же после снятия управляющего сигнала плавно убавляет громкость до 0 (чтобы небыло шума в динамиках при простое).
          И кстати sayit.0.tts.playing у меня работает не корректно, менят статус через секунды 3 на false, хотя фраза еще произносится.
          • aurodionovA
            aurodionovA
            aurodionov
            #102
            instalator, а если пнутьв скрипте включение усилка выдержать паузу потом сказать фразу.
            я к тому что-бы задержку сделать не в драйвере а в скрипте.
            Пишу с пульта….
            • I
              I
              instalator
              #103
              @aurodionov:
              я к тому что-бы задержку сделать не в драйвере а в скрипте. `
              А как ты угадаешь когда будет что то говорить? делать вывод каждый раз добавляя в скриптах задержку?
              • aurodionovA
                aurodionovA
                aurodionov
                #104
                @instalator:
                Нак FADE чем то же дёргаете перед тем как сказать фразу.
                Получается дёрнули FADE->pause->seyit. Или не?
                Пишу с пульта….
                • I
                  I
                  instalator
                  #105
                  @aurodionov:
                  @instalator:
                  Fade дергаю sayit.0.tts.playing `
                  • aurodionovA
                    aurodionovA
                    aurodionov
                    #106
                    @instalator:
                    Под линуксом sayit.0.tts.playing вроде не работает, или я не понял как пользоватся
                    Пишу с пульта….
                    • I
                      I
                      instalator
                      #107
                      @aurodionov:
                      @instalator:
                      Fade дергаю sayit.0.tts.playing Под линуксом sayit.0.tts.playing вроде не работает, или я не понял как пользоватся
                      У меня винда.
                      Bluefox.
                      Драйвер сегодня стал проговаривать любую фразу по два раза. В логе ошибок нет
                      ! sayit.0 2015-11-03 18:34:09 info sayit.0 saying: 1
                      ! sayit.0 2015-11-03 18:34:07 info sayit.0 saying: 1
                      ! sayit.0 2015-11-03 18:34:05 info sayit.0 saying: C:\ioBroker\node_modules\iobroker.sayit/gong.mp3
                      • BluefoxB
                        #108
                        пока не знаю почему. Перезапусти iobroker
                        • BluefoxB
                          #109
                          @instalator:
                          Вопрос к Bluefox.
                          И кстати sayit.0.tts.playing у меня работает не корректно, менят статус через секунды 3 на false, хотя фраза еще произносится. `
                          Слишком специфичный случай. Вот если бы пришёл pul reuquest, я бы подумал..
                          Вставь в файл дин дон 2 секунды тишины в начале.
                          • V
                            V
                            vtec
                            #110
                            То же иногда встречается проговаривание по 2-а раза. Тоже не пойму почему.
                            • I
                              I
                              instalator
                              #111
                              @Bluefox:
                              @instalator:
                              Вопрос к Bluefox.
                              Вставь в файл дин дон 2 секунды тишины в начале. `
                              Ну да специфичен, но а если стоит зонный услитель? и надо перед каждым произношение переключать зоны и тд.? я думаю задержка бы не помешала.
                              Ок как будет время зайду на гит. А тишина вначале это у меня план Б)
                              • I
                                I
                                instalator
                                #112
                                Server-PC 2015-11-26 20:32:21 error host.Server-PC instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
                                sayit.0 2015-11-26 20:32:21 error Error: EBUSY, open 'C:\ioBroker\node_modules\iobroker.sayit\say.mp3'
                                sayit.0 2015-11-26 20:32:21 error uncaught exception: EBUSY, open 'C:\ioBroker\node_modules\iobroker.sayit\say.mp3
                                Сегодня выскочила такая ошибочка.
                                Насколько я понял он говорит я еб..я открывать файл)
                                • BluefoxB
                                  #113
                                  @instalator:
                                  Насколько я понял он говорит я еб..я открывать файл) `
                                  Хм. Ошибка говорит, что не могу открыть, т.к кто то уже открыл.. Осталось выяснить, кто.
                                  • I
                                    I
                                    instalator
                                    #114
                                    @Bluefox:
                                    Хм. Ошибка говорит, что не могу открыть, т.к кто то уже открыл.. Осталось выяснить, кто. `
                                    А что это за файл вообще? у меня свой стоит для диндона.
                                    • BluefoxB
                                      #115
                                      @instalator:
                                      @Bluefox:
                                      Хм. Ошибка говорит, что не могу открыть, т.к кто то уже открыл.. Осталось выяснить, кто. А что это за файл вообще? у меня свой стоит для диндона.
                                      Это файл с текстом.
                                      • I
                                        I
                                        instalator
                                        #116
                                        @Bluefox:
                                        пока не знаю почему. Перезапусти iobroker `
                                        Я так понимаю когда setState ('sayit.0.tts.text', ''); устанавливает значение одновременно,
                                        происходит это насколько я понял из-за того что js выполняется не линейно
                                        например:
                                        setTimeout(function() {setState ('sayit.0.tts.text', 'Прогноз погоды на сегодня: '+getState("javascript.0.forecast.today").val);
                                                            setState ('sayit.0.tts.text', 'Сейчас за окном '+ parseFloat(getState("mqtt.0.myhome.Bedroom.Temp_in").val).toFixed(0)+'°');
                                                        }, 1000);
                                                            setState ('sayit.0.tts.text', 'Курс доллара '+ (getState("javascript.0.Valuta.USD").val.toFixed(2)).toString().replace(/[.]+/g, ',')+' руб. , '+
                                                            'курс евро '+ (getState("javascript.0.Valuta.EUR").val.toFixed(2)).toString().replace(/[.]+/g, ',')+ ' руб.');
                                                        }, 2000);
                                        иногда (скорее всего, когда файла нет в кеше) произносится одновременно видимо из-за потраченного времени на преобразование переменных.
                                        • I
                                          I
                                          instalator
                                          #117
                                          В коде драйвера не разбирался еще.
                                          Может организовать буфер в виде массива? Например: по setState('sayit.0.tts.text', 'Str') добавляем в массив строку, а потом уже массив обрабатываем с начало до конца, с проверкой что предыдущий элемент выполнен или сдвигая элементы массива.
                                          84.2k
