  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер sayit
Драйвер sayit
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
178 Beiträge 16 Kommentatoren 68.6k Aufrufe 2 Beobachtet
  • I Offline
    I Offline
    instalator
    #99
    Добрался я до sayit наконец то, но не тут то было, драйвер не работает
    ! sayit.0 2015-11-01 22:27:55 error TypeError: Cannot call method 'exec' of undefined at sayItSystem (C:\ioBroker\node_modules\iobroker.sayit\main.js:733:37) at Object.sayItWindows [as func] (C:\ioBroker\node_modules\iobroker.sayit\main.js:767:9) at C:\ioBroker\node_modules\iobroker.sayit\main.js:1042:51 at getLength (C:\ioBroker\node_modules\iobroker.sayit\main.js:172:23) at sayIt (C:\ioBroker\node_modules\iobroker.sayit\main.js:1041:13) at Adapter.sayLastGeneratedText (C:\ioBroker\node_modules\iobroker.sayit\main.js:27:13) at Adapter.emit (events.js:98:17) at null._onTimeout (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:1911:34) at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
    ! sayit.0 2015-11-01 22:27:55 error uncaught exception: Cannot call method 'exec' of undefined
    ! host-Server-PC 2015-11-01 22:22:53 error instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
    ! TypeError: 2015-11-01 22:22:53 error at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
    ! TypeError: 2015-11-01 22:22:53 error at null._onTimeout (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:1911:34)
    ! TypeError: 2015-11-01 22:22:53 error at Adapter.emit (events.js:98:17)
    ! TypeError: 2015-11-01 22:22:53 error at Adapter.sayLastGeneratedText (C:\ioBroker\node_modules\iobroker.sayit\main.js:27:13)
    ! TypeError: 2015-11-01 22:22:53 error at sayIt (C:\ioBroker\node_modules\iobroker.sayit\main.js:1041:13)
    ! TypeError: 2015-11-01 22:22:53 error at getLength (C:\ioBroker\node_modules\iobroker.sayit\main.js:172:23)
    ! TypeError: 2015-11-01 22:22:53 error at C:\ioBroker\node_modules\iobroker.sayit\main.js:1042:51
    ! TypeError: 2015-11-01 22:22:53 error at Object.sayItWindows [as func] (C:\ioBroker\node_modules\iobroker.sayit\main.js:767:9)
    ! TypeError: 2015-11-01 22:22:53 error at sayItSystem (C:\ioBroker\node_modules\iobroker.sayit\main.js:733:37)
    ! TypeError: 2015-11-01 22:22:53 error Cannot call method 'exec' of undefined
    ! uncaught 2015-11-01 22:22:52 error exception: Cannot call method 'exec' of undefined
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • I Offline
      I Offline
      instalator
      #100
      @instalator:
      ! uncaught 2015-11-01 22:22:52 error exception: Cannot call method 'exec' of undefined `
      Заработал, нужно было выбрать System а стоял Windows engine
      • I Offline
        I Offline
        instalator
        #101
        Вопрос к Bluefox.
        Может добавить в драйвер возможность задать время задержки перед дин дон?
        Смысл в том что сделал усилитель D класса на микрушке, так вот у него есть логический вход FADE, т.е. при подачи управляющего сигнала он плавно включает громкость (примерно 2 сек.) и так же после снятия управляющего сигнала плавно убавляет громкость до 0 (чтобы небыло шума в динамиках при простое).
        И кстати sayit.0.tts.playing у меня работает не корректно, менят статус через секунды 3 на false, хотя фраза еще произносится.
        • aurodionovA Offline
          aurodionovA Offline
          aurodionov
          #102
          instalator, а если пнутьв скрипте включение усилка выдержать паузу потом сказать фразу.
          я к тому что-бы задержку сделать не в драйвере а в скрипте.
          Пишу с пульта….
          • I Offline
            I Offline
            instalator
            #103
            @aurodionov:
            я к тому что-бы задержку сделать не в драйвере а в скрипте. `
            А как ты угадаешь когда будет что то говорить? делать вывод каждый раз добавляя в скриптах задержку?
              aurodionovA Offline
              aurodionov
              #104
              @instalator:
              Нак FADE чем то же дёргаете перед тем как сказать фразу.
              Получается дёрнули FADE->pause->seyit. Или не?
              Пишу с пульта….
              • I Offline
                I Offline
                instalator
                #105
                @aurodionov:
                @instalator:
                Fade дергаю sayit.0.tts.playing `
                  aurodionovA Offline
                  aurodionov
                  #106
                  @instalator:
                  Под линуксом sayit.0.tts.playing вроде не работает, или я не понял как пользоватся
                  Пишу с пульта….
                  • I Offline
                    I Offline
                    instalator
                    #107
                    @aurodionov:
                    @instalator:
                    Fade дергаю sayit.0.tts.playing Под линуксом sayit.0.tts.playing вроде не работает, или я не понял как пользоватся
                    У меня винда.
                    Bluefox.
                    Драйвер сегодня стал проговаривать любую фразу по два раза. В логе ошибок нет
                    ! sayit.0 2015-11-03 18:34:09 info sayit.0 saying: 1
                    ! sayit.0 2015-11-03 18:34:07 info sayit.0 saying: 1
                    ! sayit.0 2015-11-03 18:34:05 info sayit.0 saying: C:\ioBroker\node_modules\iobroker.sayit/gong.mp3
                    • BluefoxB Offline
                      BluefoxB Offline
                      #108
                      пока не знаю почему. Перезапусти iobroker
                      • BluefoxB Offline
                        BluefoxB Offline
                        #109
                        @instalator:
                        Вопрос к Bluefox.
                        И кстати sayit.0.tts.playing у меня работает не корректно, менят статус через секунды 3 на false, хотя фраза еще произносится. `
                        Слишком специфичный случай. Вот если бы пришёл pul reuquest, я бы подумал..
                        Вставь в файл дин дон 2 секунды тишины в начале.
                        • V Offline
                          V Offline
                          vtec
                          #110
                          То же иногда встречается проговаривание по 2-а раза. Тоже не пойму почему.
                          • I Offline
                            I Offline
                            instalator
                            #111
                            @Bluefox:
                            @instalator:
                            Вопрос к Bluefox.
                            Вставь в файл дин дон 2 секунды тишины в начале. `
                            Ну да специфичен, но а если стоит зонный услитель? и надо перед каждым произношение переключать зоны и тд.? я думаю задержка бы не помешала.
                            Ок как будет время зайду на гит. А тишина вначале это у меня план Б)
                            • I Offline
                              I Offline
                              instalator
                              #112
                              Server-PC 2015-11-26 20:32:21 error host.Server-PC instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
                              sayit.0 2015-11-26 20:32:21 error Error: EBUSY, open 'C:\ioBroker\node_modules\iobroker.sayit\say.mp3'
                              sayit.0 2015-11-26 20:32:21 error uncaught exception: EBUSY, open 'C:\ioBroker\node_modules\iobroker.sayit\say.mp3
                              Сегодня выскочила такая ошибочка.
                              Насколько я понял он говорит я еб..я открывать файл)
                              • BluefoxB Offline
                                BluefoxB Offline
                                #113
                                @instalator:
                                Насколько я понял он говорит я еб..я открывать файл) `
                                Хм. Ошибка говорит, что не могу открыть, т.к кто то уже открыл.. Осталось выяснить, кто.
                                • I Offline
                                  I Offline
                                  instalator
                                  #114
                                  @Bluefox:
                                  Хм. Ошибка говорит, что не могу открыть, т.к кто то уже открыл.. Осталось выяснить, кто. `
                                  А что это за файл вообще? у меня свой стоит для диндона.
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    #115
                                    @instalator:
                                    @Bluefox:
                                    Хм. Ошибка говорит, что не могу открыть, т.к кто то уже открыл.. Осталось выяснить, кто. А что это за файл вообще? у меня свой стоит для диндона.
                                    Это файл с текстом.
                                    • I Offline
                                      I Offline
                                      instalator
                                      #116
                                      @Bluefox:
                                      пока не знаю почему. Перезапусти iobroker `
                                      Я так понимаю когда setState ('sayit.0.tts.text', ''); устанавливает значение одновременно,
                                      происходит это насколько я понял из-за того что js выполняется не линейно
                                      например:
                                      setTimeout(function() {setState ('sayit.0.tts.text', 'Прогноз погоды на сегодня: '+getState("javascript.0.forecast.today").val);
                                                          setState ('sayit.0.tts.text', 'Сейчас за окном '+ parseFloat(getState("mqtt.0.myhome.Bedroom.Temp_in").val).toFixed(0)+'°');
                                                      }, 1000);
                                                          setState ('sayit.0.tts.text', 'Курс доллара '+ (getState("javascript.0.Valuta.USD").val.toFixed(2)).toString().replace(/[.]+/g, ',')+' руб. , '+
                                                          'курс евро '+ (getState("javascript.0.Valuta.EUR").val.toFixed(2)).toString().replace(/[.]+/g, ',')+ ' руб.');
                                                      }, 2000);
                                      иногда (скорее всего, когда файла нет в кеше) произносится одновременно видимо из-за потраченного времени на преобразование переменных.
                                      • I Offline
                                        I Offline
                                        instalator
                                        #117
                                        В коде драйвера не разбирался еще.
                                        Может организовать буфер в виде массива? Например: по setState('sayit.0.tts.text', 'Str') добавляем в массив строку, а потом уже массив обрабатываем с начало до конца, с проверкой что предыдущий элемент выполнен или сдвигая элементы массива.
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          #118
                                          @instalator:
                                          Может организовать буфер в виде массива? Например: по setState('sayit.0.tts.text', 'Str') добавляем в массив строку, а потом уже массив обрабатываем с начало до конца, с проверкой что предыдущий элемент выполнен или сдвигая элементы массива. `
                                          Именно так это и работает
                                          https://github.com/ioBroker/ioBroker.sa … n.js#L1027
