Драйвер sayit
Заметил в логе ощибки
! host-Server-PC 2015-10-27 10:06:10 error instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
! TypeError: 2015-10-27 10:06:09 error at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
! TypeError: 2015-10-27 10:06:09 error at null._onTimeout (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:1911:34)
! TypeError: 2015-10-27 10:06:09 error at Adapter.emit (events.js:98:17)
! TypeError: 2015-10-27 10:06:09 error at Adapter.sayLastGeneratedText (C:\ioBroker\node_modules\iobroker.sayit\main.js:27:13)
! TypeError: 2015-10-27 10:06:09 error at sayIt (C:\ioBroker\node_modules\iobroker.sayit\main.js:1037:13)
! TypeError: 2015-10-27 10:06:09 error at getLength (C:\ioBroker\node_modules\iobroker.sayit\main.js:172:23)
! TypeError: 2015-10-27 10:06:09 error at C:\ioBroker\node_modules\iobroker.sayit\main.js:1038:51
! TypeError: 2015-10-27 10:06:09 error at Object.sayItWindows [as func] (C:\ioBroker\node_modules\iobroker.sayit\main.js:766:9)
! TypeError: 2015-10-27 10:06:09 error at sayItSystem (C:\ioBroker\node_modules\iobroker.sayit\main.js:698:21)
! TypeError: 2015-10-27 10:06:09 error Cannot call method 'platform' of undefined
! uncaught 2015-10-27 10:06:09 error exception: Cannot call method 'platform' of undefined -
Поправил. Спасибо.
5278_unbenannt.png -
Добрался я до sayit наконец то, но не тут то было, драйвер не работает
! sayit.0 2015-11-01 22:27:55 error TypeError: Cannot call method 'exec' of undefined at sayItSystem (C:\ioBroker\node_modules\iobroker.sayit\main.js:733:37) at Object.sayItWindows [as func] (C:\ioBroker\node_modules\iobroker.sayit\main.js:767:9) at C:\ioBroker\node_modules\iobroker.sayit\main.js:1042:51 at getLength (C:\ioBroker\node_modules\iobroker.sayit\main.js:172:23) at sayIt (C:\ioBroker\node_modules\iobroker.sayit\main.js:1041:13) at Adapter.sayLastGeneratedText (C:\ioBroker\node_modules\iobroker.sayit\main.js:27:13) at Adapter.emit (events.js:98:17) at null._onTimeout (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:1911:34) at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
! sayit.0 2015-11-01 22:27:55 error uncaught exception: Cannot call method 'exec' of undefined! host-Server-PC 2015-11-01 22:22:53 error instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
! TypeError: 2015-11-01 22:22:53 error at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
! TypeError: 2015-11-01 22:22:53 error at null._onTimeout (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:1911:34)
! TypeError: 2015-11-01 22:22:53 error at Adapter.emit (events.js:98:17)
! TypeError: 2015-11-01 22:22:53 error at Adapter.sayLastGeneratedText (C:\ioBroker\node_modules\iobroker.sayit\main.js:27:13)
! TypeError: 2015-11-01 22:22:53 error at sayIt (C:\ioBroker\node_modules\iobroker.sayit\main.js:1041:13)
! TypeError: 2015-11-01 22:22:53 error at getLength (C:\ioBroker\node_modules\iobroker.sayit\main.js:172:23)
! TypeError: 2015-11-01 22:22:53 error at C:\ioBroker\node_modules\iobroker.sayit\main.js:1042:51
! TypeError: 2015-11-01 22:22:53 error at Object.sayItWindows [as func] (C:\ioBroker\node_modules\iobroker.sayit\main.js:767:9)
! TypeError: 2015-11-01 22:22:53 error at sayItSystem (C:\ioBroker\node_modules\iobroker.sayit\main.js:733:37)
! TypeError: 2015-11-01 22:22:53 error Cannot call method 'exec' of undefined
! uncaught 2015-11-01 22:22:52 error exception: Cannot call method 'exec' of undefined -
! uncaught 2015-11-01 22:22:52 error exception: Cannot call method 'exec' of undefined `Заработал, нужно было выбрать System а стоял Windows engine
Вопрос к Bluefox.
Может добавить в драйвер возможность задать время задержки перед дин дон?
Смысл в том что сделал усилитель D класса на микрушке, так вот у него есть логический вход FADE, т.е. при подачи управляющего сигнала он плавно включает громкость (примерно 2 сек.) и так же после снятия управляющего сигнала плавно убавляет громкость до 0 (чтобы небыло шума в динамиках при простое).
И кстати sayit.0.tts.playing у меня работает не корректно, менят статус через секунды 3 на false, хотя фраза еще произносится.
instalator, а если пнутьв скрипте включение усилка выдержать паузу потом сказать фразу.
я к тому что-бы задержку сделать не в драйвере а в скрипте.
я к тому что-бы задержку сделать не в драйвере а в скрипте. `
А как ты угадаешь когда будет что то говорить? делать вывод каждый раз добавляя в скриптах задержку? -
Нак FADE чем то же дёргаете перед тем как сказать фразу.
Получается дёрнули FADE->pause->seyit. Или не?
Fade дергаю sayit.0.tts.playing `
Под линуксом sayit.0.tts.playing вроде не работает, или я не понял как пользоватся -
У меня винда.Bluefox.
Драйвер сегодня стал проговаривать любую фразу по два раза. В логе ошибок нет
! sayit.0 2015-11-03 18:34:09 info sayit.0 saying: 1
! sayit.0 2015-11-03 18:34:07 info sayit.0 saying: 1
! sayit.0 2015-11-03 18:34:05 info sayit.0 saying: C:\ioBroker\node_modules\iobroker.sayit/gong.mp3
! sayit.0 2015-11-03 18:34:05 info sayit.0 saying: C:\ioBroker\node_modules\iobroker.sayit/gong.mp3 -
Вопрос к Bluefox.
И кстати sayit.0.tts.playing у меня работает не корректно, менят статус через секунды 3 на false, хотя фраза еще произносится. `
Слишком специфичный случай. Вот если бы пришёл pul reuquest, я бы подумал..Вставь в файл дин дон 2 секунды тишины в начале.
Вопрос к Bluefox.
Слишком специфичный случай. Вот если бы пришёл pul reuquest, я бы подумал..Вставь в файл дин дон 2 секунды тишины в начале. `
Ну да специфичен, но а если стоит зонный услитель? и надо перед каждым произношение переключать зоны и тд.? я думаю задержка бы не помешала.Ок как будет время зайду на гит. А тишина вначале это у меня план Б)
Server-PC 2015-11-26 20:32:21 error host.Server-PC instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
sayit.0 2015-11-26 20:32:21 error Error: EBUSY, open 'C:\ioBroker\node_modules\iobroker.sayit\say.mp3'
sayit.0 2015-11-26 20:32:21 error uncaught exception: EBUSY, open 'C:\ioBroker\node_modules\iobroker.sayit\say.mp3
Сегодня выскочила такая ошибочка.
Насколько я понял он говорит я еб..я открывать файл)
Насколько я понял он говорит я еб..я открывать файл) `
Хм. Ошибка говорит, что не могу открыть, т.к кто то уже открыл.. Осталось выяснить, кто. -
Хм. Ошибка говорит, что не могу открыть, т.к кто то уже открыл.. Осталось выяснить, кто. `
А что это за файл вообще? у меня свой стоит для диндона. -
пока не знаю почему. Перезапусти iobroker `
Я так понимаю когда setState ('sayit.0.tts.text', ''); устанавливает значение одновременно,происходит это насколько я понял из-за того что js выполняется не линейно
например:
setTimeout(function() {setState ('sayit.0.tts.text', 'Прогноз погоды на сегодня: '+getState("javascript.0.forecast.today").val); setState ('sayit.0.tts.text', 'Сейчас за окном '+ parseFloat(getState("mqtt.0.myhome.Bedroom.Temp_in").val).toFixed(0)+'°'); }, 1000); setTimeout(function() { setState ('sayit.0.tts.text', 'Курс доллара '+ (getState("javascript.0.Valuta.USD").val.toFixed(2)).toString().replace(/[.]+/g, ',')+' руб. , '+ 'курс евро '+ (getState("javascript.0.Valuta.EUR").val.toFixed(2)).toString().replace(/[.]+/g, ',')+ ' руб.'); }, 2000);иногда (скорее всего, когда файла нет в кеше) произносится одновременно видимо из-за потраченного времени на преобразование переменных.
