  4. [gelöst]HM RPC Adapter nach Update auf v1.10.3 rot
homematic rpc adapter
39 Beiträge 2 Kommentatoren 3.5k Aufrufe 2 Beobachtet
  • GlasfaserG Glasfaser
    @w00dy
    Hast bestimmt ein Update NPM durchgeführt .
    Mache mal das :
    rm -rf node_modules
    npm install -g npm@latest
    Und dann den Adapter mit der Katze auf den neusten Stand bringen .
    W Offline
    W Offline
    w00dy
    @Glasfaser
    Hm, evtl. möglich, erinnere mich gerade nicht...
    Die Ausgabe sieht wohl nicht so gut aus:
    root@rock64:/opt/iobroker# rm -rf node_modules
    root@rock64:/opt/iobroker# npm install -g npm@latest
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chownr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/hosted-git-info
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ignore-walk
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minipass/node_modules/yallist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minizlib
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-packlist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pacote/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-cmd-shim
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stringify-package
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/yallist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-lifecycle
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uuid
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libcipm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-install-checks
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /usr/lib/node_modules/npm/node_modules/chownr
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/chownr'
    npm ERR!  { [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/chownr']
    npm ERR!   stack:
    npm ERR!    'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/chownr\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/chownr' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    Viele Grüße
    w00dy
    • W w00dy
      @Glasfaser
      npm ERR! errno -13
      npm ERR!   stack:
      npm ERR!
      npm ERR!
      GlasfaserG Offline
      GlasfaserG Offline
      @w00dy
      Du hast keine Root Rechte .
      Hast du schonmal den Fixer drüber laufen lassen , ich denke mal nicht !?
      Fixer drüber , Reboot und dann den Adapter nochmal versuchen.
      curl -sL https://iobroker.net/fix.sh | bash -
      W 2 Antworten Letzte Antwort
        @w00dy
        W Offline
        W Offline
        w00dy
        @Glasfaser
        habs gerade gemerkt, mit Sudo lief´s durch.
        OK, führe den Fix aus und melde dann zurück...
        Bis dahin schonmal vielen Dank👍
        Viele Grüße
        w00dy
          @w00dy
          W Offline
          W Offline
          w00dy
          @Glasfaser
          Der Fix läuft nicht durch, angeblich ist ioB nicht in "/opt/iobroker" installiert ?!?
          Aber dort ist ioB definitiv installiert und vorhanden.
          root@rock64:/# curl -sL https://iobroker.net/fix.sh | bash -
          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
          Viele Grüße
          w00dy
          • W w00dy
            @Glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @w00dy
            mach mal
            cd /opt/iobroker
            W 1 Antwort Letzte Antwort
              @w00dy
              mach mal
              cd /opt/iobroker
              W Offline
              W Offline
              w00dy
              @Glasfaser
              root@rock64:/# cd /opt/iobroker
              Viele Grüße
              w00dy
              • W w00dy
                @Glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                @w00dy
                und dann den Fix
                  @w00dy
                  und dann den Fix
                  W Offline
                  W Offline
                  w00dy
                  @Glasfaser
                  leider das gleiche
                  root@rock64:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
                  Viele Grüße
                  w00dy
                  • W w00dy
                    @Glasfaser
                    leider das gleiche
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @w00dy
                    zeige mal
                    iobroker status
                    iobroker list adapters
                    iobroker list instances
                      @w00dy
                      zeige mal
                      iobroker status
                      W Offline
                      W Offline
                      w00dy
                      @Glasfaser
                      irgendwas hat ioB jetzt gecrasht. iobroker start bringt auch nichts:
                      root@rock64:~# iobroker status
                      internal/modules/cjs/loader.js:638
                          throw err;
                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                          at startup (internal/bootstrap/node.js:283:19)
                          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                      root@rock64:~# iobroker list adapters
                          throw err;
                      root@rock64:~# iobroker list instances
                          throw err;
                      root@rock64:~# ```
                      Viele Grüße
                      w00dy
                      • W w00dy
                        @Glasfaser
                            throw err;
                            throw err;
                            throw err;
                        root@rock64:~# ```
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @w00dy
                        sudo npm install iobroker.js-controller --production
                          @w00dy
                          W Offline
                          W Offline
                          w00dy
                          @Glasfaser
                          lief durch, aber mit Fehlermeldung - dann Reboot, aber ioB. startet nicht
                          Greenlock and ACME.js v3 are on the way!
                          Watch for updates at https://indiegogo.com/at/greenlock
                          npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
                          npm notice created a lockfile as package-lock.json. You should commit this file.
                          npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                          npm WARN root No description
                          npm WARN root No repository field.
                          npm WARN root No README data
                          npm WARN root No license field.
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                          + iobroker.js-controller@2.0.39
                          added 291 packages from 281 contributors and audited 581 packages in 90.777s
                          1 package is looking for funding.
                          Run "npm fund" to find out more.
                          Viele Grüße
                          w00dy
                          • W w00dy
                            @Glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @w00dy
                            iobroker start
                              @w00dy
                              iobroker start
                              W Offline
                              W Offline
                              w00dy
                              schrieb am zuletzt editiert von w00dy
                              @Glasfaser
                              root@rock64:~# iobroker start
                                  throw err;
                              root@rock64:~#
                              EDIT: ioB startet leider nicht
                              Viele Grüße
                              w00dy
                              • W w00dy
                                @Glasfaser
                                    throw err;
                                root@rock64:~#
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @w00dy
                                npm -v
                                  @w00dy
                                  npm -v
                                  W Offline
                                  W Offline
                                  w00dy
                                  @Glasfaser
                                  root@rock64:~# npm -v
                                  6.13.0
                                  Viele Grüße
                                  w00dy
                                  • W w00dy
                                    @Glasfaser
                                    6.13.0
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @w00dy
                                    cd /opt/iobroker
                                    ./reinstall.sh
                                      @w00dy
                                      cd /opt/iobroker
                                      ./reinstall.sh
                                      W Offline
                                      W Offline
                                      w00dy
                                      @Glasfaser
                                      root@rock64:/opt/iobroker# ./reinstall.sh
                                      -bash: ./reinstall.sh: No such file or directory
                                      Viele Grüße
                                      w00dy
                                      • W w00dy
                                        @Glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @w00dy
                                        sorry mein Fehler :
                                        cd /opt/iobroker
                                        mv reinstall.sh reinstall.dos
                                        tr -d '\r' < reinstall.dos > reinstall.sh
                                        chmod +x reinstall.sh
                                        ./reinstall.sh
                                          @w00dy
                                          sorry mein Fehler :
                                          cd /opt/iobroker
                                          ./reinstall.sh
                                          W Offline
                                          W Offline
                                          w00dy
                                          @Glasfaser
                                          root@rock64:/opt/iobroker# mv reinstall.sh reinstall.dos
                                          mv: cannot stat 'reinstall.sh': No such file or directory
                                          root@rock64:/opt/iobroker# tr -d '\r' < reinstall.dos > reinstall.sh
                                          -bash: reinstall.dos: No such file or directory
                                          root@rock64:/opt/iobroker# chmod +x reinstall.sh
                                          chmod: cannot access 'reinstall.sh': No such file or directory
                                          Viele Grüße
                                          w00dy
