  4. Hardware für ioBroker
iobrokersystem
26 Beiträge 9 Kommentatoren 3.6k Aufrufe 5 Beobachtet
  • Uli977U Uli977
    @paul53 schickst du mir das mal
    @Uli977 sagte:
     <variables>
       <variable type="" id="9YNR~52d77kjg`r(9k#{">total</variable>
       <variable type="" id="!d%.`(CX,BI.SLc^m|pi">percent</variable>
     </variables>
     <block type="comment" id="5dq3Hhdkfq7.Q;*Q@RF=" x="98" y="456">
       <field name="COMMENT">RAM Nutzung</field>
       <next>
         <block type="variables_set" id="W(^B@g2VZ`_Q1QQ)lrG*">
           <field name="VAR" id="9YNR~52d77kjg`r(9k#{" variabletype="">total</field>
           <value name="VALUE">
             <block type="get_value" id="JzLCf2a1rz1:U6Qg6`Wk">
               <field name="OID">info.0.sysinfo.memory.info.total</field>
             </block>
           </value>
           <next>
             <block type="on_ext" id="lGQp2HBNl8MfT|0(S)pq">
               <mutation items="1"></mutation>
               <value name="OID0">
                 <shadow type="field_oid" id="p`[G3--3OTMAUj]gY_NK">
                   <field name="oid">info.0.sysinfo.memory.info.active</field>
                 </shadow>
               </value>
               <statement name="STATEMENT">
                 <block type="variables_set" id="rEXN;8WDn]m*3h$)g*4!">
                   <field name="VAR" id="!d%.`(CX,BI.SLc^m|pi" variabletype="">percent</field>
                     <block type="math_arithmetic" id="G3UG!CIoA;oXwV]N[(nO">
                       <field name="OP">MULTIPLY</field>
                       <value name="A">
                         <shadow type="math_number" id="y=@(T=aeIrn;NTb]2%Yt">
                           <field name="NUM">100</field>
                         </shadow>
                       </value>
                       <value name="B">
                         <shadow type="math_number" id="wN^+zFK:qnEe2+.WGwUI">
                           <field name="NUM">1</field>
                         </shadow>
                         <block type="math_arithmetic" id="vjD]=;Fy@2tS)kn^n`m=" inline="false">
                           <field name="OP">DIVIDE</field>
                           <value name="A">
                             <shadow type="math_number" id="?S}65FoLBHJvS0WYKV{W">
                             </shadow>
                             <block type="on_source" id="mDyOaGm!j:vF^%cri1-u">
                             </block>
                           </value>
                           <value name="B">
                             <shadow type="math_number" id="OyQx:sy)lRpP[3r/Aevr">
                             </shadow>
                             <block type="variables_get" id="Q4~0-`.j@,+gH+12`n.[">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="update" id=".Gp5J|N,QP8(uoRj@1a3">
                       <mutation delay_input="false"></mutation>
                         <block type="math_round" id="5i=1:k$fji=Z[MP1^ytC">
                           <field name="OP">ROUND</field>
                           <value name="NUM">
                             <shadow type="math_number" id="@A$uhumpjPTkf9,b4Ok4">
                               <field name="NUM">3.1</field>
                             </shadow>
                             <block type="variables_get" id="thwD^2;K--dx`ThDTe?I">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    Uli977U 1 Antwort Letzte Antwort
      @Uli977 sagte:
       <variables>
       </variables>
         <next>
               </block>
             </value>
             <next>
                 <value name="OID0">
                   </shadow>
                 </value>
                         <value name="A">
                           </shadow>
                         </value>
                         <value name="B">
                           </shadow>
                             <value name="A">
                               </shadow>
                               </block>
                             </value>
                             <value name="B">
                               </shadow>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                             <value name="NUM">
                               </shadow>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
         </next>
       </block>
      </xml>
      Uli977U Offline
      Uli977U Offline
      Uli977
      @paul53 Danke dir! Habe ich so gemacht.
      Lasse den Wert dann lediglich in das Objekt "iobroker_ram_usage" schreiben.
      Und siehe da! Die Auslastung ist nur noch 63%!
      Sooo beseitigt man zu wenig RAM :-)
      • Uli977U Offline
        Uli977U Offline
        Uli977
        schrieb am zuletzt editiert von Uli977
        Kann mir jemand sagen warum er mir bei RAM Auslastung die Kurve nicht rauswirft?
        History Aufzeichnung ist aktiviert!
        • Uli977U Uli977
          GlasfaserG Offline
          GlasfaserG Offline
          @Uli977
          Schau mal hier , ob dort Daten von der Aufzeichnung sind !?
          • GlasfaserG Glasfaser
            @Uli977
            Uli977U Offline
            Uli977U Offline
            Uli977
            @Glasfaser Danke für den Tipp!
            Ja, da sind Daten und mittlerweile ist auch hier was
            War ich wohl zu voreilig!
            Danke, danke, danke!
              @Uli977 nur so nebenbei
              discovery kannste doch abschalten, muss ja nicht permanent laufen,
              warum hast du cloud und iot zusammen laufen?
              js2fs müsste doch auch nicht permanent laufen, oder? hab ich selbst nicht, deshalb bin ich mir da nicht sicher
              Ausschlaggebend ist dann auch, welche Skripte du alles laufen hast
              Uli977U Offline
              Uli977U Offline
              Uli977
              @crunchip
              • discovery aus - ok
              • den cloud Adapter brauche ich doch für den Fernzugriff vom Handy für meine "pockeControl" App auf dem Handy, oder nicht?
              • js2fs habe ich gerade wieder gelöscht. Habe letzte Tage was versucht, aber ohne Erfolg
              Skripte habe ich so einige laufen.
              Nutze die Visualisierung von @Kuddel - aber es laufen nicht als Skripte davon.
              In dem Zusammenhang...
              Ich habe ja in meiner CCU3 eine ganze Menge Programme.
              Automatiken, Lichtsteuerung, Rolladen, Anwesenheitssimulation usw.
              Theoretisch könnte man diese ganzen Programme doch auch als Skript über den ioBroker laufen lassen, oder?
              Wie macht ihr das denn so?
              GlasfaserG M 2 Antworten Letzte Antwort
              • Uli977U Uli977
                @crunchip
                GlasfaserG Offline
                GlasfaserG Offline
                @Uli977
                Hier als Beispiel :
                Variable Zeitsteuerung mit VIS Editor
                Shuttercontrol
                  @Uli977
                  Hier als Beispiel :
                  Shuttercontrol
                  Uli977U Offline
                  Uli977U Offline
                  Uli977
                  @Glasfaser Ok :-)
                  Es läuft alles... ich lasse die Finger da von... dafür habe ich auch zu wenig Ahnung!
                  • Uli977U Uli977
                    @crunchip
                    Marty56
                    @Uli977
                    Ich habe vor 3 Jahren alles was ich noch auf der CCU hatte, noch ioBroker "übersetzt". Mit Javascript ging das auch relativ einfach (bei mir ca. 1 Arbeitswoche), zu Blocky kann ich nichts sagen. Die Vorteile einer mächtigen, standardisierten Programmiersprache und die Wartungsfreundlichkeit der Scripts in ioBroker hat diesen Aufwand mehr als gerechtfertigt.
                    HW:NUC (16 GB Ram)
                    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                      Kuddel
                      Meine CCU fungiert auch nur noch als Gateway.
                      ich habe alle Skript auf meinen ioBroker umgezogen, weil man mehr Möglichkeiten hat.
                      • K Kuddel
                        Uli977U Offline
                        Uli977U Offline
                        Uli977
                        @Kuddel
                        Sind das dann Blockys oder andere Skripte?
                        • Uli977U Offline
                          Uli977U Offline
                          Uli977
                          Ich würde das mal ausprobieren wollen...
                          Würde mal mit den Rollos anfangen wollen.
                          Nutzt ihr da Dann Shuttercontrol, oder geht das auch ohne diesen Adapter und nur mit Skripten.... wie geht man da ran?
                          Viele Grüße
                          PeoplesP K 2 Antworten Letzte Antwort
                          • Uli977U Uli977
                            Viele Grüße
                            PeoplesP Offline
                            PeoplesP Offline
                            Peoples
                            schrieb am zuletzt editiert von Peoples
                            @Uli977
                            Das geht auch nur mit Scripten.
                            Simples Beispiel:
                            if(getState('RaumlichtDatenpunkt').val === true){
                                setState('RolloDatenpunkt',0);
                            Würde bedeuten "Wenn" du dein Raumlicht einschaltest "true" wird bei deinem Rollo das Level "0" gesetzt (sprich Licht ein -> Rollo runter)
                            Für Javascript selbst kann man viel Googlen und eine Übersicht der Funktionen für Iobroker speziell findest du hier: https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md
                            Du kannst auch ein Blocky erstellen und über den Button oben rechts blocky.JPG
                            hin und her schalten so kann man sich vielleicht vieles leichter erklären.
                            • Uli977U Uli977
                              @Kuddel
                              Kuddel
                              @Uli977 eigene Skripte sind Blockly.
                              Alles was ich an Javascript verwende, habe ich hier aus dem Forum.
                              • Uli977U Uli977
                                Viele Grüße
                                Kuddel
                                @Uli977 ich nutze shuttercontrol nicht.
                                Ich steure meine Rolloden einfach abhängig vom Sonnenuntergang und stelle in meiner VIS nur die Verzögerung des Herunterfahrens wie z.B. Sonnenuntergang +15 (Minuten) ein.
                                • K Kuddel
                                  Uli977U Offline
                                  Uli977U Offline
                                  Uli977
                                  @Kuddel Wofür brauchst du die Verzögerung? Damit die Rollos nicht schon zu früh runter fahren? Da könnte man sich doch auch nach der Helligkeit draußen richten.
                                  Kannst du mir dein Rolloskript und dass für die Zeiten nochmal hier zur Verfügung stellen?
                                  Danke dir!
                                  • Uli977U Uli977
                                    Danke dir!
                                    Kuddel
                                    @Uli977 ja genau, damit man die Rollos der Helligkeit anpasst.
                                    Sauberer wäre es natürlich mit einem Helligkeitssensor draußen, aber den habe ich (noch) nicht.
                                    Benötigte Objekte (javascript)
                                    createState('javascript.0.zeiten.rolladen_oeffnen', false, {type: 'string',name: 'rolladen_oeffnen'});
                                    createState('javascript.0.zeiten.rolladen_oeffnen_minute', false, {type: 'string',name: 'rolladen_oeffnen_minute'});
                                    createState('javascript.0.zeiten.rolladen_oeffnen_stunde', false, {type: 'string',name: 'rolladen_oeffnen_stunde'});
                                    createState('javascript.0.zeiten.rolladen_oeffnen_timer_restart', false, {type: 'boolean',name: 'rolladen_oeffnen_timer_restart'});
                                    createState('javascript.0.zeiten.rolladen_oeffnen_verzoegerung', false, {type: 'string',name: 'rolladen_oeffnen_verzoegerung'});
                                    createState('javascript.0.zeiten.rolladen_schliessen', false, {type: 'string',name: 'rolladen_schliessen'});
                                    createState('javascript.0.zeiten.rolladen_schliessen_minute', false, {type: 'string',name: 'rolladen_schliessen_minute'});
                                    createState('javascript.0.zeiten.rolladen_schliessen_stunde', false, {type: 'string',name: 'rolladen_schliessen_stunde'});
                                    createState('javascript.0.zeiten.rolladen_schliessen_timer_restart', false, {type: 'boolean',name: 'rolladen_schliessen_timer_restart'});
                                    createState('javascript.0.zeiten.rolladen_schliessen_verzoegerung', false, {type: 'string',name: 'rolladen_schliessen_verzoegerung'});
                                    Blockly Skript
                                    rollos_tag_nacht.txt
