  4. Wir helfen Altersrentner
    1.0k
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
zigbee adapterinvalid option
224 Beiträge 8 Kommentatoren 33.3k Aufrufe 7 Beobachtet
  • A Altersrentner
    Er läuft!
    Jan1
    #162
    @Altersrentner
    geil, dann ab zum Zigbee.
    Also den erst mal installieren, ganz normal 😬
      Altersrentner
      #163
      Aber jetzt sind Error Meldungen im Log.
      tr-064-community.0	2019-10-19 15:10:29.735	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 15:10:17.153	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:10:04.534	error	(11124) updateAll:exists
      host.raspberrypi	2019-10-19 14:10:03.779	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      dwd.0	2019-10-19 14:10:03.767	info	(11360) Terminated (NO_ERROR): Without reason
      dwd.0	2019-10-19 14:10:02.535	info	(11360) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.16.3
      host.raspberrypi	2019-10-19 14:10:00.034	info	instance system.adapter.dwd.0 started with pid 11360
      tr-064-community.0	2019-10-19 14:09:52.188	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:09:40.123	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:09:27.804	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:09:15.007	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:09:02.759	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:08:50.216	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:08:37.635	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:08:25.160	error	(11124) updateAll:exists
      fhem.0	2019-10-19 14:08:22.350	info	(6298) event ioBroker "fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360" > set fhem.0.alive on-for-timer 360
      tr-064-community.0	2019-10-19 14:08:12.738	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:08:00.214	error	(11124) updateAll:exists
      tr-064-community.0	2019-10-19 14:07:56.303	error	(11124) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.178.1:1012
      tr-064-community.0	2019-10-19 14:07:56.301	error	(11124) --- To use the callmonitor, enable connects to port 1012 on FritsBox by dialing #96*5* and restart this adapter
      tr-064-community.0	2019-10-19 14:07:53.994	info	(11124) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.16.3
      host.raspberrypi	2019-10-19 14:07:51.902	info	instance system.adapter.tr-064-community.0 started with pid 11124
      javascript.0	2019-10-19 14:07:36.064	warn	(726) script.js.Heizungssteuerung_Neu.Steuerung_Heizkreise_EG_Wohnzimmer.Wandheizkreis_2_Wohnzimmer_Ansteuerung_Ventil: Wenn Temp Wand Wohnzimmer2 >25 dann Ventil zu
      javascript.0	2019-10-19 14:07:36.063	warn	(726) script.js.Heizungssteuerung_Neu.Steuerung_Heizkreise_EG_Wohnzimmer.Wandheizkreis_2_Wohnzimmer_Ansteuerung_Ventil: Temp Wohnzimmer2 <24 Ventil auf
      host.raspberrypi	2019-10-19 14:07:28.481	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.raspberrypi	2019-10-19 14:07:28.480	error	instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064-community.0	2019-10-19 14:07:23.335	error	(11074) ~
      tr-064-community.0	2019-10-19 14:07:23.334	error	(11074) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      tr-064-community.0	2019-10-19 14:07:23.334	error	(11074) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064-community.0	2019-10-19 14:07:23.333	error	(11074) ~
      tr-064-community.0	2019-10-19 14:07:23.331	error	(11074) Error: getaddrinfo ENOTFOUND fritz fritz:80 - {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"fritz","host":"fritz","port":80}
      tr-064-community.0	2019-10-19 14:07:23.109	info	(11074) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.16.3
      host.raspberrypi	2019-10-19 14:07:21.119	info	instance system.adapter.tr-064-community.0 started with pid 11074
      host.raspberrypi	2019-10-19 14:06:51.078	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.raspberrypi	2019-10-19 14:06:51.078	error	instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064-community.0	2019-10-19 14:06:46.050	error	(10977) ~
      tr-064-community.0	2019-10-19 14:06:46.050	error	(10977) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      tr-064-community.0	2019-10-19 14:06:46.049	error	(10977) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064-community.0	2019-10-19 14:06:46.048	error	(10977) Error: getaddrinfo ENOTFOUND fritz fritz:80 - {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"fritz","host":"fritz","port":80}
      tr-064-community.0	2019-10-19 14:06:45.887	info	(10977) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.16.3
      host.raspberrypi	2019-10-19 14:06:43.870	info	instance system.adapter.tr-064-community.0 started with pid 10977
      host.raspberrypi	2019-10-19 14:06:37.162	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.raspberrypi	2019-10-19 14:06:37.161	error	instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064-community.0	2019-10-19 14:06:32.065	error	(10948) ~
      tr-064-community.0	2019-10-19 14:06:32.064	error	(10948) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      tr-064-community.0	2019-10-19 14:06:32.063	error	(10948) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064-community.0	2019-10-19 14:06:32.062	error	(10948) ~
      tr-064-community.0	2019-10-19 14:06:32.061	error	(10948) Error: getaddrinfo ENOTFOUND fritz fritz:80 - {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"fritz","host":"fritz","port":80}
      tr-064-community.0	2019-10-19 14:06:31.878	info	(10948) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.16.3
      host.raspberrypi	2019-10-19 14:06:29.846	info	instance system.adapter.tr-064-community.0 started with pid 10948
      host.raspberrypi	2019-10-19 14:06:14.569	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.raspberrypi	2019-10-19 14:06:14.566	error	instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064-community.0	2019-10-19 14:06:09.528	error	(10911) ~
      tr-064-community.0	2019-10-19 14:06:09.528	error	(10911) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      tr-064-community.0	2019-10-19 14:06:09.528	error	(10911) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064-community.0	2019-10-19 14:06:09.527	error	(10911) ~
      tr-064-community.0	2019-10-19 14:06:09.527	error	(10911) Error: getaddrinfo ENOTFOUND fritz fritz:80 - {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"fritz","host":"fritz","port":80}
      tr-064-community.0	2019-10-19 14:06:09.308	info	(10911) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.16.3
      host.raspberrypi	2019-10-19 14:06:08.917	info	instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2019-10-19 14:06:07.175	info	instance system.adapter.tr-064-community.0 started with pid 10911
      yr.0	2019-10-19 14:06:03.797	info	(10846) got weather data from yr.no
      yr.0	2019-10-19 14:06:03.607	info	(10846) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v10.16.3
      host.raspberrypi	2019-10-19 14:06:00.064	info	instance system.adapter.yr.0 started with pid 10846
      host.raspberrypi	2019-10-19 14:05:36.798	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.raspberrypi	2019-10-19 14:05:36.797	error	instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064-community.0	2019-10-19 14:05:31.720	error	(10785) ~
      tr-064-community.0	2019-10-19 14:05:31.719	error	(10785) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      tr-064-community.0	2019-10-19 14:05:31.719	error	(10785) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064-community.0	2019-10-19 14:05:31.718	error	(10785) Error: getaddrinfo ENOTFOUND fritz fritz:80 - {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"fritz","host":"fritz","port":80}
      tr-064-community.0	2019-10-19 14:05:31.528	info	(10785) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.16.3
      host.raspberrypi	2019-10-19 14:05:29.448	info	instance system.adapter.tr-064-community.0 started with pid 10785
      host.raspberrypi	2019-10-19 14:05:03.681	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      dwd.0	2019-10-19 14:05:03.657	info	(10699) Terminated (NO_ERROR): Without reason
      dwd.0	2019-10-19 14:05:02.443	info	(10699) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.16.3
      host.raspberrypi	2019-10-19 14:05:00.064	info	instance system.adapter.dwd.0 started with pid 10699
      host.raspberrypi	2019-10-19 14:04:59.434	info	Restart adapter system.adapter.tr-064-community.0 because enabled
      host.raspberrypi	2019-10-19 14:04:59.433	error	instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064-community.0	2019-10-19 14:04:54.407	error	(10676) ~
      tr-064-community.0	2019-10-19 14:04:54.406	error	(10676) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      tr-064-community.0	2019-10-19 14:04:54.405	error	(10676) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064-community.0	2019-10-19 14:04:54.404	error	(10676) Error: getaddrinfo ENOTFOUND fritz fritz:80 - {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"fritz","host":"fritz
        Altersrentner
        #164
        tr-064-community.0	2019-10-19 15:11:43.994	error	(11124) updateAll:exists
        tr-064-community.0	2019-10-19 15:11:31.749	error	(11124) updateAll:exists
        tr-064-community.0	2019-10-19 15:11:19.183	error	(11124) updateAll:exists
        tr-064-community.0	2019-10-19 15:11:06.824	error	(11124) updateAll:exists
        tr-064-community.0	2019-10-19 15:10:54.282	error	(11124) updateAll:exists
        tr-064-community.0	2019-10-19 15:10:41.721	error	(11124) updateAll:exists
        • A Altersrentner
          Jan1
          #165
          @Altersrentner
          Die Lösung steht schon im Log, Du musst den Callmonitor an der Fritz aktivieren.
          Nimm ein angeschlossenes Telefon und gib #965 ein und den grünen Hörer
          • J Jan1
            @Altersrentner
            Altersrentner
            #166
            @Jan1 said in Zigbee Stick funktioniert nicht mehr:
            Du meinst den Stick verbinden?
            • A Altersrentner
              Jan1
              #167
              @Altersrentner
              warte erst den TR064 fertig machen
                Altersrentner
                #168
                #965 und grün kommt falsche Nummer
                J 2 Antworten Letzte Antwort
                • A Altersrentner
                  Jan1
                  #169
                  @Altersrentner
                  ok, meine Schuld, sollte wie im Log schon steht #96Stern5Stern heißen
                  Lustig das Stern Sysmbol wird nicht angezeigt wenn ich es eingebe, also nicht Stern schreiben, sondern das Symbol verwenden.
                  #96*5*
                    Altersrentner
                    #170
                    #965 habe ich gemacht
                    Jetzt kommt noch diese Meldung:
                    tr-064-community.0	2019-10-19 15:21:13.476	error	(11124) updateAll:exists
                    tr-064-community.0	2019-10-19 15:21:01.155	error	(11124) updateAll:exists
                    tr-064-community.0	2019-10-19 15:20:48.790	error	(11124) updateAll:exists
                    tr-064-community.0	2019-10-19 15:20:36.827	error	(11124) updateAll:exists
                    tr-064-community.0	2019-10-19 15:20:24.187	error	(11124) updateAll:exists
                    • A Altersrentner
                      Jan1
                      #171
                      @Altersrentner
                      Der Adapter soll neu gestartet werden, steht im Log
                      • A Altersrentner
                        Jan1
                        #172
                        @Altersrentner
                        mach mal ein Backup, bevor Du weiter machst.
                        Ich muss jetzt mal Bundesliga schauen und das hat Priorität 😀
                          Altersrentner
                          #173
                          g
                          komplett oder minimal
                          • A Altersrentner
                            g
                            Jan1
                            #174
                            @Altersrentner
                            minimal ist eh immer die bessere Wahl, aber hier gilt, was man hat, hat man im Fall der Fälle, also einfach beide.
                            • A Altersrentner
                              g
                              Jan1
                              #175
                              @Altersrentner
                              so Halbzeit, wie ist der Stand?
                                Altersrentner
                                #176
                                Backup ist gemacht. Sonst alles im grünen Bereich.
                                Nur das:
                                7750) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically: {"error":"Email not found or URL key not found"}
                                er sagt mail nicht gefunden. Die ist aber ok
                                • A Altersrentner
                                  Nur das:
                                  Jan1
                                  #177
                                  @Altersrentner
                                  Von welchem Adapter kommt die Meldung? Da war doch was im IoT der das schon an gemeckert hat.
                                  TR064 läuft?
                                    Altersrentner
                                    #178
                                    TR läuft. IoT ist der Error
                                    • A Altersrentner
                                      Jan1
                                      #179
                                      @Altersrentner
                                      Und da stimmt das Login wohl von Google Home nicht, wird ja auch angemeckert.
                                      Könnte allerdings auch noch ne Einstellung am Google Konto selber sein. Wenn Du das nicht selber gelöst bekommst, bitte einen neuen Thread mit passender Überschrift öffnen.
                                      Nach dem Spiel geht es dann mit dem Zigbee weiter.
                                      • A Altersrentner
                                        Jan1
                                        #180
                                        @Altersrentner
                                        kann weiter gehen
                                          Altersrentner
                                          #181
                                          Habe das Problem gelöst. Google Home war angehakt. Das habe ich gar nicht,
                                          jetzt keine Fehlermeldung mehr.
