  4. Script für einen SpeedTest über speedtest.net
    6.6k
javascript
177 Beiträge 57 Kommentatoren 56.4k Aufrufe 39 Beobachtet
  • C Offline
    Coffeelover
    #80
    Achtung Anfängerfrage: wie bekomme ich eine graphische Darstellung der Werte über den Zeitverlauf in vis dargestellt?
    sigi234S NegaleinN 2 Antworten Letzte Antwort
    • C Coffeelover
      sigi234S Online
      sigi234S Online
      #81
      @Coffeelover sagte in Script für einen SpeedTest über speedtest.net:
      Flot und History Adapter
      • C Coffeelover
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #82
        Hier als Beispiel der Flot von mir!
        IP in deine ändern und index.html in edit.html ändern.
        Dann wird direkt im Flot-Edit geöffnet.
        Und natürlich die passenden DP in History aufzeichnen lassen.
        http://10.0.1.200:8082/flot/index.html?l%5B0%5D%5Bid%5D=javascript.0.Speed-Test.data.speeds.download&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bcolor%5D=%23ff3333&l%5B0%5D%5Bmin%5D=8&l%5B0%5D%5Bmax%5D=50&l%5B0%5D%5Bthickness%5D=2&l%5B0%5D%5Bshadowsize%5D=2&l%5B0%5D%5Bunit%5D=m%2Fbit&l%5B0%5D%5Bname%5D=Download&l%5B0%5D%5Byaxe%5D=rightColor&l%5B0%5D%5Bxaxe%5D=bottom&l%5B0%5D%5Bpoints%5D=false&l%5B0%5D%5Bv%5D=landroid-s.0.mower.status&l%5B0%5D%5Bvl%5D=landroid-s.0.mower.status&l%5B0%5D%5BchartType%5D=spline&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Byticks%5D=20&l%5B0%5D%5Binstance%5D=history.0&l%5B0%5D%5Bfill%5D=0&l%5B0%5D%5BcommonYAxis%5D=1&l%5B1%5D%5Bid%5D=javascript.0.Speed-Test.ping&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2333ff33&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=1&l%5B1%5D%5Bunit%5D=ms&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bname%5D=Ping&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5Bmin%5D=0.1&l%5B1%5D%5Bmax%5D=120&l%5B1%5D%5BafterComma%5D=0&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5BchartType%5D=spline&l%5B1%5D%5Binstance%5D=history.0&l%5B1%5D%5Bfill%5D=0&l%5B1%5D%5Bpoints%5D=false&l%5B1%5D%5BcommonYAxis%5D=1&l%5B2%5D%5Bid%5D=javascript.0.Speed-Test.data.speeds.upload&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=average&l%5B2%5D%5Bcolor%5D=%2344ffFF&l%5B2%5D%5Bmin%5D=0.1&l%5B2%5D%5Bmax%5D=20&l%5B2%5D%5Bthickness%5D=2&l%5B2%5D%5Bshadowsize%5D=2&l%5B2%5D%5Bunit%5D=m%2FBit&l%5B2%5D%5Bname%5D=Upload&l%5B2%5D%5Byaxe%5D=rightColor&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BignoreNull%5D=false&l%5B2%5D%5BafterComma%5D=1&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B2%5D%5Byticks%5D=3&l%5B2%5D%5BchartType%5D=spline&l%5B2%5D%5Binstance%5D=history.0&l%5B2%5D%5Bfill%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B2%5D%5BcommonYAxis%5D=1&timeType=relative&relativeEnd=now&range=2880&live=900&aggregateType=step&aggregateSpan=300&window_bg=%23202020&bg=%23202020&legend=nw&hoverDetail=true&useComma=false&zoom=true&noedit=true&animation=0&noBorder=noborder&barLabels=topover&titleColor=%23000000&titleSize=15&legColumns=5&timeFormat=%25H%3A%25M&legBgOpacity=0.7&border_color=%23202020&start=2019-05-29&start_time=13%3A38&barWidth=0.1&barFontSize=12px&barFontColor=%23000000&legBg=%23ffffff&end=2019-01-27&end_time=23%3A59&x_labels_color=%23ffffff&y_labels_color=%23ffffff&title=Stromverbrauch&border_width=1&barColor=dsf
        ° Fixer ---> iob fix
        • C Offline
          Coffeelover
          #83
          Danke euch beiden. Habe ich hinbekommen und an meine VIS angepasst.
          Jetzt frage ich mich nur, was mir die Werte sagen:
          Download lt. Adapter: 1.272 Mbit/s, ORIGDONWLOAD 140127 bit/s
          Ein gleichzeitig durchgeführter DSL Speedcheck zeigt mir etwa 46.000 kBit/s?
          • C Offline
            Coffeelover
            #84
            Hallo nochmal,
            ich möchte nochmals nachfragen, da mir die ausgewerteten Daten nicht plausibel vorkommen: Habe ich etwas falsch gemacht oder nicht entsprechend konfiguriert?
            Ich nutze iobroker in einem Docker auf meinem NAS. Selbiger ist per Gigabit-Leitung mit dem Router verbunden. Der Router wiederum hängt via Kabel an der Vodafone Kabel Box.
            • C Coffeelover
              #85
              @Coffeelover das siehst du ja an den Verbindungsdaten. Deine Leitung koennte max 140127, deine gemessene Geschwindigkeit mit dem speedtest ist 127200, was passt. ( etwas overhead etc ).
              Was meinst du mit gleichzeitig durchgeführter DSL Speedcheck? mit was? von wo nach wo?
              Sind leider recht wenige Informationen.. was fuer einen Anschluss hast du bekommen, was hast du gebucht, was wurde geschaltet, und dann was hast du wie mit was gemessen??
              C 1 Antwort Letzte Antwort
                Coffeelover
                #86
                @ilovegym den Speedtest habe ich vom Handy aus durchgeführt (glaube auf heise.de). Eigentlich hängt die ganze Geschichte an einer 1000er Vodafone Kabel Verbindung. Wenn ich das nicht ganz falsch kommen davon im Adapter 0,1% an. Das kann ich kaum glauben mit dem parallel ausgeführten DSL Speedtest.
                • C Coffeelover
                  #87
                  @Coffeelover Also... Ich empfehle dir, wenn du Interesse hast, ein paar Bücher über Netzwerke zu lesen, musst ja nicht gleich den ccna machen😁, aber etwas Grundwissen schadet nie..
                  Kurz:
                  Mehrere Speedtests zur gleichen Zeit sind nicht empfehlenswert
                  Mit WLAN schon gar nicht
                  Wie gesagt, schau erstmal, was für eine Leitung dir geschaltet wurde, nicht was Du gebucht hast.
                    Kurz:
                    Coffeelover
                    #88
                    @ilovegym Ich habe sie ja nicht direkt parallel betrieben, sondern zeitgleich, sodass die Werte halbwegs vergleichbar sind. Der Adapter liefert mir rund um die Uhr im Vis dieses 1 MBit +/-. Deswegen spreche ich doch davon, dass ich dem Adapter nicht traue.
                    Und gem. Vodafone ist tatsächlich auch die 1000er Leitung geschaltet. Lange war die auch sehr performant, zuletzt ist sie es nicht mehr. (Ende der Angebotsphase natürlich). Und bevor mir die Hotline nun etwas von Auslastungsspitzenzeiten erzählt, hätte ich gerne einfach die Daten über Zeit mittels iobroker erfasst.
                    • C Coffeelover
                      aleks-83
                      schrieb am zuletzt editiert von aleks-83
                      #89
                      @Coffeelover
                      Also bei mir hat der Test gepasst als er noch funktionierte.
                      Jetzt findet er trotz des installierten Speed-Test diesen nicht mehr. Aber andere Geschichte.
                      Du kannst ja in der fritzbox sehen mit welcher Geschwindigkeit sie an den Knotenpunkt angeschlossen ist.
                      Messungen in einem solchen hohen Geschwindigkeitsbereich immer über ein Gerät messen welches per LAN (>= Cat6) verbunden ist.
                      OT:
                      Hast du Glasfaser? FTTH?
                      Da sollte es bei 1.000 MBit jederzeit auch min. 900 MBit geben. (Vorausgesetzt der Server kann das liefern)
                      Wir sind auch gerade im Umbau mit der deutschen Glasfaser und dort wird die gebuchte Geschwindigkeit garantiert, sonst kann man kündigen.
                      Also 600 MBit buchen und 550-600 MBit garantiert.
                      Bei 1.000 MBit 990-1.000 MBit jederzeit.
                      Das soll ja der tolle Vorteil von FTTH sein.
                      = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
                      = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
                      Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
                      Glasfaser 400
                      • C Offline
                        Coffeelover
                        #90
                        Leider kann ich das nicht ganz so einfach, da die Fritzbox nur als WLAN-Hotspot fungiert und die eigentliche Verbindung ins Internet wird über den Vodafone WLAN-Router via Kabelanschluss aufgebaut.
                        Ich werde heute Abend mal auf dem NAS über ein Linux Terminal den Speedtest wiederholen. Das ist dann zumindest der gleiche Messweg wie über den Adapter.
                        • C Coffeelover
                          #91
                          @Coffeelover Solange du nicht per Kabel an deinem vodoofone Router misst, misst du misst.
                            aleks-83
                            #92
                            Stimmt schon.
                            So würde er aber rausfinden ob der Adapter Mist macht oder die Leitung bis zum Host so langsam ist.
                            Um die reale Geschwindigkeit der Internetleitung zu messen muss man natürlich so nah wie möglich an den Hausübergabepunkt und per Kabel messen.
                            Glasfaser 400
                            • A aleks-83
                              Stimmt schon.
                              Coffeelover
                              #93
                              @aleks-83 Danke dir. Werde jetzt erst einmal weiter auf dem Linux Terminal messen und dann versuchen, per LAN an die Box zu kommen. Am Terminal hatte ich vorhin etwa 70 MBit. Zu wenig für die Leitung aber mehr als am Adapter. Der dümpelt weiter bei 1,x MBit.
                              • Elektroniker86E Offline
                                Elektroniker86
                                #94
                                was müsste ich im Script abändern damit der test alle 10 Minuten aktualisiert/ausgeführt wird?
                                Danke im voraus für eure Hilfe!
                                • Elektroniker86E Elektroniker86
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #95
                                  @Elektroniker86 sagte in Script für einen SpeedTest über speedtest.net:
                                  In Zeile 26 var cronStr = "*/30 * * * *"; ändern in var cronStr = "*/10 * * * *";
                                  Elektroniker86E 1 Antwort Letzte Antwort
                                  • NegaleinN Negalein
                                    Elektroniker86
                                    #96
                                    @Negalein
                                    Und wenn ich 5 Minuten möchte dann so?
                                    var cronStr = "*/5 * * * *";
                                      @Negalein
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #97
                                      @Negalein
                                      genau
                                        @Negalein
                                        genau
                                        Elektroniker86
                                        #98
                                        @Negalein
                                        Super, vielen lieben Dank!
                                        Es funktioniert.
                                        • A aleks-83
                                          ich bin von meiner Debian VM auf natives Win10 umgestiegen.
                                          Seitdem findet er "speed-test" nicht mehr.
                                          javascript.0	2019-09-25 12:00:01.242	error	script.js.FritzBox.speedtest: Der Befehl "speed-test" ist entweder falsch geschrieben oder konnte nicht gefunden werden
                                          speed-test ist installiert und im javascript Adapter eingetragen.
                                          Ich habe den Javascript Adapter und auch komplett ioBroker neu gestartet.
                                          Trotzdem bleibt die Meldung.
                                          aleks-83
                                          #99
                                          @aleks-83 sagte in Script für einen SpeedTest über speedtest.net:
                                          Ich bin von meiner Debian VM auf natives Win10 umgestiegen.
                                          Hat niemand sonst dieses Problem (gehabt) ?
                                          Ich habe es immer noch.
                                          Sobald das Skript durch CRON ausgeführt werden soll, kommt diese Meldung.
                                          Wird wohl am exec Befehl liegen, oder?
                                          Mein ioB läuft ja unter Windows 10.
                                          Wie macht man das denn dann hier?
                                          Glasfaser 400
