  4. Windows Dienst lässt sich nicht mehr starten
    6.4k
windows dienstnode.js
54 Beiträge 4 Kommentatoren 8.4k Aufrufe 4 Beobachtet
  • sigi234S Online
    sigi234S Online
    Was kommt bei:
    iobroker list instances
    node -v
    nodejs -v
    npm -v
    A StabilostickS 2 Antworten Letzte Antwort
    • A aleks-83
      ich hatte Probleme mit meinem Sonos Adapter (Thread)
      Daraufhin habe ich den Adapter deinstalliert und neu installiert.
      Beim Starten des neu installierten Adapter bekam ich die Fehlermeldung:
      host.NUC(NUC)  2019-10-11 13:23:53.162 info    instance system.adapter.sonos.0 started with pid 12228
      Caught  2019-10-11 13:23:54.145 error   by controller[0]: ^
      Caught  2019-10-11 13:23:54.145 error   by controller[0]: fs.js:114
      Caught  2019-10-11 13:23:54.145 error   by controller[0]: throw err;
      Caught  2019-10-11 13:23:54.145 error   by controller[1]:
      Caught  2019-10-11 13:23:54.145 error   by controller[1]: at D:\ioBroker\NUC\node_modules\iobroker.js-controller\node_modules\file-stream-rotator\FileStreamRotator.js:640:
      Caught  2019-10-11 13:23:54.145 error   by controller[1]: at Object.mkdirSync (fs.js:757:3)
      Caught  2019-10-11 13:23:54.145 error   by controller[1]: Error: ENOENT: no such file or directory, mkdir 'D:\ioBroker\NUC\log\iobroker..yyyy-10-Fr.10/11\'
      Caught  2019-10-11 13:23:54.145 error   by controller[2]: 20
      Caught  2019-10-11 13:23:54.145 error   by controller[2]: at Array.reduce (<anonymous>)
      Caught  2019-10-11 13:23:54.145 error   by controller[2]: at mkDirForFile (D:\ioBroker\NUC\node_modules\iobroker.js-controller\node_modules\file-stream-rotator\FileStreamRotator.js:628:27)
      Caught  2019-10-11 13:23:54.145 error   by controller[2]: at Object.FileStreamRotator.getStream (D:\ioBroker\NUC\node_module
      Caught  2019-10-11 13:23:54.145 error   by controller[3]: at new DailyRotateFile (D:\ioBroker\NUC\node_modules\iobroker.js-controller\node_modules\winston-daily-rotate-file
      Caught  2019-10-11 13:23:54.145 error   by controller[3]: s\iobroker.js-controller\node_modules\file-stream-rotator\FileStreamRotator.js:505:5)
      Caught  2019-10-11 13:23:54.145 error   by controller[4]: \daily-rotate-file.js:80:57)
      Caught  2019-10-11 13:23:54.145 error   by controller[4]: at logger (D:\ioBroker\NUC\node_modules\iobroker.js-controller\lib\logger.js:83:34)
      Caught  2019-10-11 13:23:54.146 error   by controller[4]: at new Adapter (D:\ioBroker\NUC\node_modules\iobroker.js-controller\lib\adapter.js:129:53)
      Caught  2019-10-11 13:23:54.146 error   by controller[4]: at Object.<anonymous> (D:\ioBroker\NUC\node_modules\iobroker.sonos\main.js:1851:5)
      Caught  2019-10-11 13:23:54.146 error   by controller[4]: at startAdapter (D:\ioBroker\NUC\node_modules\iobroker.sonos\main.js:29:16)
      host.NUC(NUC)  2019-10-11 13:23:54.146 error   instance system.adapter.sonos.0 terminated with code 1 ()
      Das Problem war nicht behoben.
      Dann habe ich den NUC mit (Windwos 10) neu gestartet.
      In der ioBroker Kommandozeile habe ich dann gesehen dass ioBroker nicht gestartet ist.
      In den Diensten lässt er sich starten, beendet sich aber sofort wieder.
      Wenn ich jetzt versuche node JS zu starten
      D:\ioBroker\NUC>node node_modules/iobroker.js-controller/controller.js --logs
      fs.js:114
          throw err;
          at D:\ioBroker\NUC\node_modules\iobroker.js-controller\node_modules\file-stream-rotator\FileStreamRotator.js:640:20
          at Object.FileStreamRotator.getStream (D:\ioBroker\NUC\node_modules\iobroker.js-controller\node_modules\file-stream-rotator\FileStreamRotator.js:505:5)
          at new DailyRotateFile (D:\ioBroker\NUC\node_modules\iobroker.js-controller\node_modules\winston-daily-rotate-file\daily-rotate-file.js:80:57)
          at init (D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js:2740:55)
          at Object.<anonymous> (D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js:2879:1)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
      was natürlich nicht geht, bekomme ich aber die selbe Fehlermeldung wie oben beim Starten vom Sonos Adapter.
      Hilft euch das bei der Fehlersuche?
      Ich komme alleine nicht klar.
      @Stabilostick kannst du als Windows Experte hier helfen?
      Hängt das vllt mit dem Update auf JS 2.0 zusammen was mir seit heute angeboten wird?
      Bin aber noch auf 1.5.14
      sigi234S Online
      sigi234S Online
      @aleks-83 sagte in Windows Dienst lässt sich nicht mehr starten:
      Das habe ich auch manchmal, warum auch immer.
        aleks-83
        Und was hilft dann?
        = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
        = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
        Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
        Glasfaser 400
        • A aleks-83
          Und was hilft dann?
          sigi234S Online
          sigi234S Online
          Und was hilft dann?
          Neustart von Windows.
          • sigi234S sigi234
            Was kommt bei:
            node -v
            nodejs -v
            npm -v
            aleks-83
            schrieb am zuletzt editiert von aleks-83
            @sigi234 sagte in Windows Dienst lässt sich nicht mehr starten:
            Was kommt bei:
            node -v
            nodejs -v
            npm -v
            iobroker list instances:
            Zählt alle meine Instanzen auf, aber keine mit einem + davor.
            D:\ioBroker\NUC>node -v
            v10.16.3
            D:\ioBroker\NUC>nodejs -v
            Der Befehl "nodejs" ist entweder falsch geschrieben oder
            konnte nicht gefunden werden.
            D:\ioBroker\NUC>npm -v
            6.9.0
            Glasfaser 400
            • sigi234S sigi234
              Und was hilft dann?
              aleks-83
              Und was hilft dann?
              Hab ihn jetzt 3x neu gestartet. Bleibt dabei...
              Glasfaser 400
                aleks-83
                Bleibt mir wohl nur die Neuinstallation!? 😞
                Ist zwar mit der Migration im WIndows Installer von Stabilostick super einfach.
                Aber einige Adapter funktionierten dann doch nicht ganz korrekt, sodass ich sie neu installieren musste.
                Glasfaser 400
                StabilostickS 1 Antwort Letzte Antwort
                • A aleks-83
                  StabilostickS Offline
                  Stabilostick
                  schrieb am zuletzt editiert von Stabilostick
                  @aleks-83
                  Im Unterordner „daemon“ der ioBroker-Serverinstanz sind einige Logdateien hinterlegt, die den Dienst und dessen Start aufzeichnen. Was steht in den Logs drin, dass zum Zeitpunkt eines versuchten Dienststarts passt? Was sagt zu der Zeit das ioBroker-Log im Log-Ordner?
                  • StabilostickS Stabilostick
                    @aleks-83
                    aleks-83
                    @Stabilostick
                    Danke für die Antowrt.
                    Ich habe gerade nochmal den Dienst gestartet und die Logfiles angesehen.
                    Es wurden nur im daemon Ordner logs erstellt.
                    Im ioBroker/log/ Ordner sind nur log files vom letzen erfolgreichen start des Brokers vom 11.10.
                    Hier aus dem daemon Ordner
                    In der iobroker.err.log (Download) wiederholt sich immer weider eine Meldung:
                    fs.js:114
                       throw err;
                    iobroker.wrapper.log
                    2019-10-13 20:52:29,049 INFO  - Starting ServiceWrapper in the service mode
                    2019-10-13 20:52:29,093 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                    2019-10-13 20:52:29,100 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                    2019-10-13 20:52:29,135 INFO  - Started process 8256
                    2019-10-13 20:52:29,142 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.RollingSizeTimeLogAppender
                    2019-10-13 20:52:40,830 INFO  - Starting ServiceWrapper in the service mode
                    2019-10-13 20:52:40,874 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                    2019-10-13 20:52:40,881 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                    2019-10-13 20:52:40,914 INFO  - Started process 10464
                    2019-10-13 20:52:40,923 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.RollingSizeTimeLogAppender
                    2019-10-13 20:53:02,316 INFO  - Starting ServiceWrapper in the service mode
                    2019-10-13 20:53:02,363 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                    2019-10-13 20:53:02,369 INFO  - Starting "D:\ioBroker\NUC\nodejs\node.exe" "D:\ioBroker\NUC\node_modules\iobroker.js-controller\controller.js"
                    2019-10-13 20:53:02,434 INFO  - Started process 3992
                    2019-10-13 20:53:02,448 DEBUG - Forwarding logs of the process System.Diagnostics.Process (node) to winsw.RollingSizeTimeLogAppender
                    Glasfaser 400
                    • sigi234S sigi234
                      Was kommt bei:
                      node -v
                      nodejs -v
                      npm -v
                      Stabilostick
                      Was kommt bei:
                      node -v
                      nodejs -v
                      npm -v
                      FYI: nodejs.exe braucht und gibt es auf Windows nicht.
                      • A aleks-83
                        @Stabilostick
                        fs.js:114
                           throw err;
                        Stabilostick
                        Da muss wohl nochmal TeamViewer ran.... Du hast noch die Nummer?
                          Was kommt bei:
                          node -v
                          nodejs -v
                          npm -v
                          sigi234S Online
                          sigi234S Online
                          @Stabilostick sagte in Windows Dienst lässt sich nicht mehr starten:
                          Was kommt bei:
                          node -v
                          nodejs -v
                          npm -v
                          ...füge ich immer via Insert Canned Response automatisch ein.
                          • sigi234S Online
                            sigi234S Online
                            Hm, bei mir kommt immer das im err.Log
                            Cannot parse "/Adapter_Icons/vis-views.json
                            Cannot parse "/Bilder/vis-views.json
                            Cannot parse "/Meine_Icons/vis-views.json
                            Cannot parse "/Mond/vis-views.json
                            Cannot parse "/Netzwerk/vis-views.json
                            Cannot parse "/Radiosender/vis-views.json
                            Cannot parse "/Sigi/vis-views.json
                            Cannot parse "/Sonstige/vis-views.json
                            Cannot parse "/Staubsauger/vis-views.json
                            Cannot parse "/Tankstellen_logos/vis-views.json
                            • sigi234S sigi234
                              Stabilostick
                              @sigi234
                              need ... more ... input. Welcher Adapter?
                                @sigi234
                                sigi234S Online
                                sigi234S Online
                                @sigi234
                                Cannot parse "/VIS/vis-views.json
                                Cannot parse "/Wetter_HD/vis-views.json
                                Cannot parse "/Wettericons/vis-views.json
                                Cannot parse "/fire/vis-views.json
                                (node:6428) UnhandledPromiseRejectionWarning: FirebaseError: 5 NOT_FOUND: No document to update: projects/iobroker-iogo/databases/(default)/documents/users/A4JRhBHOt8Q3xR8SjK7Q3hW2U8K2/adapters/system_adapter_js-controller
                                    at new FirestoreError (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\@firebase\firestore\dist\index.node.cjs.js:354:28)
                                    at ClientDuplexStream.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\@firebase\firestore\dist\index.node.cjs.js:22313:19)
                                    at ClientDuplexStream.emit (events.js:198:13)
                                    at ClientDuplexStream._emitStatusIfDone (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client.js:234:12)
                                    at ClientDuplexStream._receiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client.js:211:8)
                                    at Object.onReceiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:1306:15)
                                    at InterceptingListener._callNext (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:568:42)
                                    at InterceptingListener.onReceiveStatus (C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:618:8)
                                    at C:\Program Files\iobroker\Test\node_modules\iobroker.iogo\node_modules\grpc\src\client_interceptors.js:1123:18
                                (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4)
                                (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 5)
                                (node:6428) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 6)
                                { Error [ERR_UNHANDLED_ERROR]: Unhandled error. ('1811161726216929086534298f17edb7')
                                    at MerossCloud.emit (events.js:187:17)
                                    at MerossCloudDevice.devices.(anonymous function).on (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\meross-cloud\index.js:126:30)
                                    at MerossCloudDevice.emit (events.js:203:15)
                                    at MqttClient.client.on (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\meross-cloud\index.js:249:18)
                                    at MqttClient.emit (events.js:198:13)
                                    at TLSSocket.handleTLSerrors (C:\Program Files\iobroker\Test\node_modules\iobroker.meross\node_modules\mqtt\lib\connect\tls.js:26:18)
                                    at TLSSocket.emit (events.js:203:15)
                                    at emitErrorNT (internal/streams/destroy.js:91:8)
                                    at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                                    at process._tickCallback (internal/process/next_tick.js:63:19) context: '1811161726216929086534298f17edb7' }
                                  aleks-83
                                  Schreibe dir im Chat.
                                  Glasfaser 400
                                    aleks-83
                                    OK, also @Stabilostick hat sich meinen NUC mal angesehen.
                                    Vielen Dank nochmal dafür !
                                    Der Dienst wird wohl korrekt gestartet, aber direkt wieder beendet weil ioBroker die logfile nicht erstellen kann.
                                    Laut Error Log versucht der ioBroker ein log zu erstellen mit dem Namen:
                                    D:\ioBroker\NUC\log\iobroker..yyyy-10-Mo.10/14\
                                    Wobei NUC der Instanzen-Namen ist.
                                    Alles hinter iobroker. macht aber irgendiwe keinen Sinn und steht auch so nicht in meiner ioBroker Konfig.
                                    Wie sich das bei mir eingeschlichen hat, kann ich mir nicht erklären.
                                    Das Ende vom Lied ist halt ne Neuinstallation.
                                    Aber diese geht ja wirklich einfach und automatisiert dank dem Windows Installer.
                                    Glasfaser 400
                                    • A aleks-83
                                      aleks-83
                                      Was mir gerade noch aufgefallen ist bei der Neueinrichtung:
                                      Als er alle Adapter aus der Migration installiert hatte, habe ich per admin Adapter gesagt er soll alle Adapter updaten.
                                      Dann hat er versucht NPM upzugraden.
                                      Das ging schief.
                                      ... Hier wurden Adapter geupdatet ...
                                      Adapter "xs1" is not installed.
                                      Adapter "yahka" is not installed.
                                      Adapter "yamaha" is not installed.
                                      Adapter "yeelight-2" is not installed.
                                      Adapter "yr" is not installed.
                                      Adapter "zigbee" is not installed.
                                      Adapter "zont" is not installed.
                                      Adapter "zwave" is not installed.
                                      Adapter "zwave2" is not installed.
                                      Update js-controller from @1.5.14 to @2.0.29
                                      2019-10-14 20:36:35.125 - warn: host.NUC(NUCmaster) instance system.adapter.web.0 terminated due to SIGTERM
                                      2019-10-14 20:36:35.125 - info: host.NUC(NUCmaster) instance system.adapter.web.0 terminated with code null ()
                                      2019-10-14 20:36:37.511 - info: host.NUC(NUCmaster) instance system.adapter.web.0 started with pid 6360
                                      2019-10-14 20:36:38.566 - info: iobroker NPM version: 6.9.0
                                      2019-10-14 20:36:38.566 - info: iobroker npm install iobroker.js-controller@2.0.29 --unsafe-perm --production --save --prefix "D:/ioBroker/NUCmaster" (System call)
                                      2019-10-14 20:36:39.571 - info: web.0 starting. Version 2.4.5 in D:/ioBroker/NUCmaster/node_modules/iobroker.web, node: v10.16.3
                                      2019-10-14 20:36:41.833 - info: web.0 socket.io server listening on port 8083
                                      2019-10-14 20:36:41.838 - info: web.0 http server listening on port 8083
                                      2019-10-14 20:37:33.190 - info: iobroker gyp
                                      2019-10-14 20:37:33.191 - info: iobroker ERR!
                                      2019-10-14 20:37:33.193 - info: iobroker
                                      2019-10-14 20:37:33.199 - info: iobroker build error
                                      2019-10-14 20:37:33.200 - info: iobroker
                                      2019-10-14 20:37:33.229 - info: iobroker gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack at ChildProcess.onExit (D:\ioBroker\NUCmaster\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
                                      gyp ERR! stack at ChildProcess.emit (events.js:198:13)
                                      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                      gyp ERR! System Windows_NT 10.0.18362
                                      2019-10-14 20:37:33.235 - info: iobroker gyp ERR! command "D:\\ioBroker\\NUCmaster\\nodejs\\node.exe" "D:\\ioBroker\\NUCmaster\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp
                                      2019-10-14 20:37:33.237 - info: iobroker ERR!
                                      2019-10-14 20:37:33.241 - info: iobroker cwd D:\ioBroker\NUCmaster\node_modules\iobroker.js-controller\node_modules\unix-dgramgyp ERR!
                                      2019-10-14 20:37:33.242 - info: iobroker node -v v10.16.3gyp ERR! node-gyp -v v3.8.0
                                      gyp ERR! not ok
                                      2019-10-14 20:38:12.125 - info: iobroker npm
                                      2019-10-14 20:38:12.126 - info: iobroker
                                      2019-10-14 20:38:12.130 - info: iobroker WARN
                                      2019-10-14 20:38:12.133 - info: iobroker
                                      2019-10-14 20:38:12.140 - info: iobroker optional
                                      2019-10-14 20:38:12.144 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules\iobroker.js-controller\node_modules\fsevents):
                                      2019-10-14 20:38:12.165 - info: iobroker npm
                                      2019-10-14 20:38:12.176 - info: iobroker
                                      2019-10-14 20:38:12.180 - info: iobroker WARN
                                      2019-10-14 20:38:12.181 - info: iobroker
                                      2019-10-14 20:38:12.182 - info: iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
                                      2019-10-14 20:38:12.183 - info: iobroker npm
                                      2019-10-14 20:38:12.187 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\iobroker.js-controller\node_modules\unix-dgram):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: `node-gyp rebuild`
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                      2019-10-14 20:38:12.256 - info: iobroker Host "NUC(NUCmaster)" (win32) updated
                                      2019-10-14 20:38:12.256 - info: iobroker Starting node restart.js
                                      2019-10-14 20:38:12.343 - info: iobroker exit 0
                                      2019-10-14 20:39:43.348 - info: host.NUC(NUCmaster) Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                      Kann es sein dass er das beim letzten Update auch versucht hat, und mir die Zeile mit dem mkdir zerschossen hat?
                                      Ich habe den NUC jetzt aber schon neu gestartet.
                                      Der Dienst startet noch ganz normal.
                                      Dann werde ich den button "Alle Adapter updaten" erst mal meiden.
                                      EDIT:
                                      Der Admin zeigt mir aber an ich hätte die 2.0.29
                                      Glasfaser 400
                                      StabilostickS A 2 Antworten Letzte Antwort
                                      • A aleks-83
                                        Das ging schief.
                                        gyp ERR! not ok
                                        EDIT:
                                        Stabilostick
                                        Das ging schief.
                                        Nein, hat er nicht.
                                        Du hast den neuesten js-controller installiert aus Latest. Dabei ist der Buildvorgang für die optionale Komponente "unix-dgram", die sowieso nur auf Linux funktioniert, fehlgeschlagen. "fsevents" braucht es nur auf Apple-Rechnern. Also alles kein Problem und kein Grund zur Sorge:
                                        Das ist das Wichtige am Ende. 0 = alles Ok.
                                        • sigi234S sigi234
                                          @sigi234
                                          Stabilostick
                                          @sigi234
                                          Ich fürchte, da bin ich raus. Firebase, iogo und Meross kenne ich nicht. Gehört das wirklich zum Thema "Windows Dienst lässt sich nicht starten", das hier besprochen wird?
