  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 625.1k Aufrufe 35 Beobachtet
  • R
    R
    Ritter
    schrieb am zuletzt editiert von Ritter
    #612
    Müsste das ganze nur unter Windows auch noch funktionieren. Was läuft hier schief? Hier das log im Ordner npm-cache:
    0 info it worked if it ends with ok
    1 verbose cli [ 'C:\Program Files\nodejs\node.exe',
    1 verbose cli 'C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js',
    1 verbose cli 'install',
    1 verbose cli 'ioBroker/ioBroker.js-controller' ]
    2 info using npm@6.9.0
    3 info using node@v10.16.0
    4 verbose npm-session 50c7e7f8e863a096
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 silly fetchPackageMetaData error for github:ioBroker/ioBroker.js-controller Error while executing:
    7 silly fetchPackageMetaData undefined ls-remote -h -t ssh://git@github.com/ioBroker/ioBroker.js-controller.git
    7 silly fetchPackageMetaData spawn git ENOENT
    8 timing stage:rollbackFailedOptional Completed in 1ms
    9 timing stage:runTopLevelLifecycles Completed in 7147ms
    10 verbose stack Error: spawn git ENOENT
    10 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:240:19)
    10 verbose stack at onErrorNT (internal/child_process.js:415:16)
    10 verbose stack at process._tickCallback (internal/process/next_tick.js:63:19)
    11 verbose cwd C:\iobroker
    12 verbose Windows_NT 10.0.18362
    13 verbose argv "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "ioBroker/ioBroker.js-controller"
    14 verbose node v10.16.0
    15 verbose npm v6.9.0
    16 error path git
    17 error code ENOENT
    18 error errno ENOENT
    19 error syscall spawn git
    20 error enoent Error while executing:
    20 error enoent undefined ls-remote -h -t ssh://git@github.com/ioBroker/ioBroker.js-controller.git
    20 error enoent
    20 error enoent
    20 error enoent spawn git ENOENT
    21 error enoent This is related to npm not being able to find a file.
    22 verbose exit [ 1, true ]
    • R Ritter
      16 error path git
      20 error enoent
      20 error enoent
      apollon77A
      apollon77A
      #613
      @Ritter Du musst git installieren weil halt aktuell vom GitHub direkt installiert wird während dem Test
      • R
        R
        Ritter
        #614
        Wie funktioniert das?
        • R Ritter
          apollon77A
          apollon77A
          #615
          @Ritter Google ist your friend ;-) https://git-scm.com/download/win
          • R
            R
            Ritter
            #616
            Das ganze installier ich auf dem Rechner wo iobroker läuft? Was gib ich dann im schwarzen Kasten ein?
            Auch cd c:/iobroker
            und dann
            npm install ioBroker/ioBroker.js-controller ?
            • R Ritter
              Auch cd c:/iobroker
              und dann
              apollon77A
              apollon77A
              #617
              @Ritter Wie wurde original installiert? Mit dem neuen Installer von @Stabilostick ?
              • R
                R
                Ritter
                #618
                Nein, händisch wie auf iobroker.net beschrieben.
                • apollon77A
                  apollon77A
                  #619
                  Dann sollte es so funktionieren
                  • R
                    R
                    Ritter
                    #620
                    Da bleibts stehen
                    Christian@NUC MINGW64 ~
                    $ cd c:/iobroker
                    Christian@NUC MINGW64 /c/iobroker
                    $ npm install ioBroker/ioBroker.js-controller
                    • R
                      R
                      Ritter
                      #621
                      Ok zu ungeduldig, jetzt ist die Version auch hier aktuell.
                      Vielen dank für deine Hilfe.
                      • apollon77A apollon77
                        @Nuggelbeb
                        1.) "Hyroglyphenzeichen": Der js-controller ändert keine Daten. Was ist das denn für ein System? Mit SD Karte? Wie alt? Kann es sein das was was anfängt komisch zu werden?
                        2.) backitup:
                        Was ist es für ein System? Master/Slave oder so? Wenn mehrere Hosts ... alle auf 2.0 oder nicht?
                        Mach mal mit 2.0 auf dem gleichen host manuell ein
                        iobroker backup tut das? Oder kommen da auch die Fehler?
                        Was ist mit dem File /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/main/iobroker_fritzbox_anrufmonitor.json is not a valid json file los? Ist das valide oder ist da ggf noch ein Byte "gekippt"? Der Fehler kommt von der backup Validierung ... deswegen bricht er ab und erzeugt das Backup nicht. Bitte prüfen
                        (und bevor Ihr fragt: in der 1.5 gab es keine Backup-Validierung :-) ... cooles Feature, gell und wir haben es unter anderem eingebaut um bei sterbenden SD Karten ein Feedback zu bekommen das etwas nicht stimmt bevor man im glauben das alles ok ist Backups erstellt die dann kaputt sind!)
                        #622
                        @apollon77
                        😧 Sorry, ich bin Endanwender - kein Profi. Ich stelle fest und melde es. 👶
                        Was mit iobroker_fritzbox_anrufmonitor.json ist, weiß ich nicht. Adapter läuft.
                        Master System: Raspberry 4 4GB ioBroker auf USB-Stick
                        Client System: Raspberry 2B ioBroker auf SD-Karte
                        • J
                          J
                          Jan1
                          #623
                          @apollon77
                          bin eben auch auf 2.0.24 hoch und hab nun ne Menge Fehler im Log nach einem Neustart:
                          host.Beelink	2019-10-08 08:03:26.811	error	Caught by controller[32]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.811	error	Caught by controller[32]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.811	error	Caught by controller[32]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.811	error	Caught by controller[32]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.810	error	Caught by controller[32]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.810	error	Caught by controller[32]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.810	error	Caught by controller[32]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.810	error	Caught by controller[32]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.810	error	Caught by controller[32]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.810	error	Caught by controller[32]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.810	error	Caught by controller[31]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.809	error	Caught by controller[31]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.809	error	Caught by controller[31]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.809	error	Caught by controller[31]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.809	error	Caught by controller[31]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.809	error	Caught by controller[31]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.809	error	Caught by controller[31]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.808	error	Caught by controller[31]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.808	error	Caught by controller[31]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.808	error	Caught by controller[31]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.808	error	Caught by controller[31]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.808	error	Caught by controller[31]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.808	error	Caught by controller[31]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.807	error	Caught by controller[31]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.807	error	Caught by controller[31]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.807	error	Caught by controller[31]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.807	error	Caught by controller[31]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.807	error	Caught by controller[31]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.807	error	Caught by controller[31]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.806	error	Caught by controller[31]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.806	error	Caught by controller[30]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.806	error	Caught by controller[30]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.806	error	Caught by controller[30]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.806	error	Caught by controller[30]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.806	error	Caught by controller[30]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.806	error	Caught by controller[30]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.805	error	Caught by controller[30]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.805	error	Caught by controller[30]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.805	error	Caught by controller[30]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.805	error	Caught by controller[30]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.805	error	Caught by controller[30]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.805	error	Caught by controller[30]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.804	error	Caught by controller[30]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.804	error	Caught by controller[29]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.804	error	Caught by controller[29]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.804	error	Caught by controller[29]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.804	error	Caught by controller[29]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.804	error	Caught by controller[29]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.804	error	Caught by controller[29]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[29]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[29]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[29]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[29]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[28]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[28]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[28]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[28]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.803	error	Caught by controller[28]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[28]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[27]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[27]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[27]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[27]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[27]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[27]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[26]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[26]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.802	error	Caught by controller[26]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[26]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[26]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[26]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[25]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[25]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[25]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[25]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[25]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.801	error	Caught by controller[25]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[24]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[24]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[24]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[24]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[24]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[24]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[23]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[23]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.800	error	Caught by controller[23]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.799	error	Caught by controller[23]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.799	error	Caught by controller[23]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.799	error	Caught by controller[23]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.799	error	Caught by controller[22]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.799	error	Caught by controller[22]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.799	error	Caught by controller[22]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.799	error	Caught by controller[22]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.799	error	Caught by controller[22]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[22]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[21]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[21]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[21]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[21]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[21]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[21]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[20]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.798	error	Caught by controller[20]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[20]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[20]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[20]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[20]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[19]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[19]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[19]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[19]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.797	error	Caught by controller[19]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[19]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[18]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[18]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[18]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[18]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[18]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[18]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[17]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.796	error	Caught by controller[17]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[17]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[17]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[17]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[17]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[16]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[16]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[16]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[16]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.795	error	Caught by controller[16]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.794	error	Caught by controller[16]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.794	error	Caught by controller[15]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.794	error	Caught by controller[15]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.794	error	Caught by controller[15]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.794	error	Caught by controller[15]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.794	error	Caught by controller[15]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.794	error	Caught by controller[15]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[15]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[15]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[15]: TypeError: Cannot read property 'extendObject' of null
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:61:11)
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[14]: at Socket.emit (events.js:198:13)
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[14]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:644:25)
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[14]: at Adapter.extendForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1911:30)
                          host.Beelink	2019-10-08 08:03:26.793	error	Caught by controller[14]: TypeError: Cannot read property 'extendObject' of null
                          außerdem bringt Node-Red einige Warnungen (könnte aber auch an der Adapter Version 1.12.0 liegen:
                          host.Beelink	2019-10-08 07:51:38.856	warn	Error from InMemDB: Error: config NOT SUPPORTED
                          node-red.0	2019-10-08 07:51:38.834	warn	(32412) 8 Oct 07:51:38 - [warn] Projekte inaktiviert: editorTheme.projects.enabled=false
                          node-red.0	2019-10-08 07:51:36.674	info	(29313) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          node-red.0	2019-10-08 07:51:34.832	info	(32412) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                          node-red.0	2019-10-08 07:51:34.057	info	(32412) starting. Version 1.12.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v10.16.3
                          host.Beelink	2019-10-08 07:51:33.265	warn	Error from InMemDB: Error: config NOT SUPPORTED
                          node-red.0	2019-10-08 07:51:32.672	warn	(29313) Got terminate signal. Checking desired PID: 32412 vs own PID 29313
                          node-red.0	2019-10-08 07:51:32.671	warn	(29313) Got terminate signal. Checking desired PID: 0 vs own PID 29313
                          host.Beelink	2019-10-08 07:51:32.669	info	instance system.adapter.node-red.0 started with pid 32412
                          host.Beelink	2019-10-08 07:51:30.178	info	instance system.adapter.node-red.0 terminated with code 156 (156)
                          node-red.0	2019-10-08 07:51:30.162	info	(29205) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          host.Beelink	2019-10-08 07:51:30.154	info	stopInstance timeout "1000 system.adapter.node-red.0 killing pid 29205
                          node-red.0	2019-10-08 07:51:29.150	info	(29205) kill node-red task
                          Ansonsten scheint alles zu laufen.
                          apollon77A 2 Antworten Letzte Antwort
                            @e-i-k-e Bitte mal https://github.com/GermanBluefox/ioBroker.vis-justgage versuchen. PR steht bei PMant aus
                            E
                            E
                            e-i-k-e
                            #624
                            @apollon77
                            Habe den Adapter sauber entfernt und neun eingespielt.
                            Leider keine Änderung. :/
                            apollon77A BluefoxB 2 Antworten Letzte Antwort
                              @apollon77
                              apollon77A
                              apollon77A
                              #625
                              @Nuggelbeb Dann poste das File doch mal hier. Dann sehen wir was damit los ist. Fakt ist in jedem Fall das das Backup nicht erstellt wird weil dieses File nicht valide ist.
                              • J Jan1
                                @apollon77
                                apollon77A
                                apollon77A
                                #626
                                @Jan1 Kommen die Fehler die ganze Zeit? Oder war das einmalig? Wenn einmalig dann war das scheinbar beim beenden vom ioBroker wo die DB schon weg war aber der Adapter noch lief. Was hast Du im Admin ggf mit Objekten gemacht zu dem Zeitpunkt?
                                • J Jan1
                                  @apollon77
                                  apollon77A
                                  apollon77A
                                  #627
                                  @Jan1 Das "Error from InMemDB: Error: config NOT SUPPORTED" bitte ignorieren. Geht mit der kommenden 2.0.25 dann weg. Ist irrelevant.
                                  Die anderen Meldungen bedeuten das ein Adapter lief der js-controller aber eine andere prozess-ID gesetzt hat ... damit hat sich die alte nun sauber beendet. Sieht an sich auch ok aus. kam auch nur einmalig oder?
                                  • E e-i-k-e
                                    @apollon77
                                    apollon77A
                                    apollon77A
                                    #628
                                    @e-i-k-e Neu installiert via Custom Install von Beliebiger URL und die genutzt die ich geschrieben habe? Der Fix ist gerade nur im Fork von Bluefox ... also must DU von anderer URL installieren
                                    E 1 Antwort Letzte Antwort
                                      J
                                      J
                                      Jan1
                                      #629
                                      @apollon77
                                      Ich habe ein Neustart durchgeführt sonst eigentlich nichts und ja war einmalig (zumindest bis jetzt). An sonst kommt nun nur noch die NOT SUPPORTED Meldung welche ignoriert werden soll.
                                      Dann warte ich mal auf die nächste Version und berichte.
                                        E
                                        E
                                        e-i-k-e
                                        #630
                                        @apollon77
                                        Korrekt, hab die URL über " Installieren aus eigener URL -> Beliebig" installiert.
                                        v. 1.0.1 wird mir anschließend auch Angezeigt.
                                        • J Jan1
                                          @apollon77
                                          apollon77A
                                          apollon77A
                                          #631
                                          @Jan1 So Fehler könnten kommen (aber ggf auch früher) wenn während dem beenden irgendwie noch Dinge "In Arbeit" sind. Scheinbar gibt es Fälle wo jetzt die DB schneller weg ist als früher bzw als der Socket.io Server vom Admin :-)
                                          33.2k
                                          84.4k
