  4. Was bedeuten diese Fehler im Log=
15 Beiträge 3 Kommentatoren 1.9k Aufrufe
    audioconcept
    Hallo
    was bedeuten diese Fehler im Log?
    ioBroker.adminAdapterInstanzenObjekteZuständeEreignisseGruppenBenutzerAufzählungenHostsLognode-red.0Skripte
    System
    Admin
    Log	Log-Größe: 0.01 MB
    Refresh
    Copy
    Clear
    Clear on disk
    	Zeit		Nachricht
    x
    raspberrypi	2015-09-23 19:36:46	info	host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    raspberrypi	2015-09-23 19:36:46	error	host.raspberrypi instance system.adapter.admin.0 terminated with code 1 ()
    raspberrypi	2015-09-23 19:36:40	info	host.raspberrypi instance system.adapter.admin.0 started with pid 3125
    host-raspberrypi	2015-09-23 19:36:10	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:36:10	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:36:10	error	port 8081 already in use
    admin-0	2015-09-23 19:36:10	info	requesting all objects
    admin-0	2015-09-23 19:36:10	info	requesting all states
    admin-0	2015-09-23 19:36:10	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:36:05	info	instance system.adapter.admin.0 started with pid 3119
    host-raspberrypi	2015-09-23 19:35:35	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:35:35	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:35:35	error	port 8081 already in use
    admin-0	2015-09-23 19:35:35	info	requesting all objects
    admin-0	2015-09-23 19:35:35	info	requesting all states
    admin-0	2015-09-23 19:35:34	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:35:30	info	instance system.adapter.admin.0 started with pid 3109
    host-raspberrypi	2015-09-23 19:35:00	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:35:00	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:34:59	error	port 8081 already in use
    admin-0	2015-09-23 19:34:59	info	requesting all objects
    admin-0	2015-09-23 19:34:59	info	requesting all states
    admin-0	2015-09-23 19:34:59	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:34:54	info	instance system.adapter.admin.0 started with pid 3103
    host-raspberrypi	2015-09-23 19:34:24	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:34:24	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:34:24	error	port 8081 already in use
    admin-0	2015-09-23 19:34:24	info	requesting all objects
    admin-0	2015-09-23 19:34:24	info	requesting all states
    admin-0	2015-09-23 19:34:24	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:34:18	info	instance system.adapter.admin.0 started with pid 3093
    host-raspberrypi	2015-09-23 19:33:48	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:33:48	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:33:48	error	port 8081 already in use
    admin-0	2015-09-23 19:33:48	info	requesting all objects
    admin-0	2015-09-23 19:33:48	info	requesting all states
    admin-0	2015-09-23 19:33:48	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:33:43	info	instance system.adapter.admin.0 started with pid 3082
    host-raspberrypi	2015-09-23 19:33:13	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:33:13	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:33:13	error	port 8081 already in use
    admin-0	2015-09-23 19:33:12	info	requesting all objects
    admin-0	2015-09-23 19:33:12	info	requesting all states
    admin-0	2015-09-23 19:33:12	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:33:08	info	instance system.adapter.admin.0 started with pid 3076
    host-raspberrypi	2015-09-23 19:32:38	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:32:38	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:32:37	error	port 8081 already in use
    admin-0	2015-09-23 19:32:37	info	requesting all objects
    admin-0	2015-09-23 19:32:37	info	requesting all states
    admin-0	2015-09-23 19:32:37	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:32:32	info	instance system.adapter.admin.0 started with pid 3065
    host-raspberrypi	2015-09-23 19:32:02	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:32:02	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:32:02	error	port 8081 already in use
    admin-0	2015-09-23 19:32:02	info	requesting all objects
    admin-0	2015-09-23 19:32:02	info	requesting all states
    admin-0	2015-09-23 19:32:02	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:31:57	info	instance system.adapter.admin.0 started with pid 3059
    host-raspberrypi	2015-09-23 19:31:27	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:31:27	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:31:27	error	port 8081 already in use
    admin-0	2015-09-23 19:31:27	info	requesting all objects
    admin-0	2015-09-23 19:31:27	info	requesting all states
    admin-0	2015-09-23 19:31:26	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:31:21	info	instance system.adapter.admin.0 started with pid 3049
    host-raspberrypi	2015-09-23 19:30:51	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:30:51	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:30:51	error	port 8081 already in use
    admin-0	2015-09-23 19:30:50	info	requesting all objects
    admin-0	2015-09-23 19:30:50	info	requesting all states
    admin-0	2015-09-23 19:30:50	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:30:45	info	instance system.adapter.admin.0 started with pid 3039
    host-raspberrypi	2015-09-23 19:30:15	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:30:15	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:30:15	error	port 8081 already in use
    admin-0	2015-09-23 19:30:15	info	requesting all objects
    admin-0	2015-09-23 19:30:15	info	requesting all states
    admin-0	2015-09-23 19:30:15	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:30:11	info	instance system.adapter.ical.1 terminated with code 0 (OK)
    host-raspberrypi	2015-09-23 19:30:10	info	instance system.adapter.ical.0 terminated with code 0 (OK)
    host-raspberrypi	2015-09-23 19:30:10	info	instance system.adapter.admin.0 started with pid 3033
    ical-1	2015-09-23 19:30:05	info	processing URL: Dorotka http://www.dorotka.net/kalenderdatei/defaultcalendar.ics
    ical-0	2015-09-23 19:30:05	info	processing URL: Mülltermine http://www.dorotka.net/kalenderdatei/mülltermine.ics
    ical-0	2015-09-23 19:30:04	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
    ical-1	2015-09-23 19:30:04	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
    host-raspberrypi	2015-09-23 19:30:00	info	instance system.adapter.ical.0 started with pid 3018
    host-raspberrypi	2015-09-23 19:30:00	info	instance system.adapter.ical.1 started with pid 3017
    host-raspberrypi	2015-09-23 19:29:40	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:29:40	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:29:40	error	port 8081 already in use
    admin-0	2015-09-23 19:29:40	info	requesting all objects
    admin-0	2015-09-23 19:29:40	info	requesting all states
    admin-0	2015-09-23 19:29:40	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:29:35	info	instance system.adapter.admin.0 started with pid 3007
    host-raspberrypi	2015-09-23 19:29:05	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:29:05	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:29:04	error	port 8081 already in use
    admin-0	2015-09-23 19:29:04	info	requesting all objects
    admin-0	2015-09-23 19:29:04	info	requesting all states
    admin-0	2015-09-23 19:29:04	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:28:59	info	instance system.adapter.admin.0 started with pid 3001
    host-raspberrypi	2015-09-23 19:28:29	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:28:29	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:28:29	error	port 8081 already in use
    admin-0	2015-09-23 19:28:29	info	requesting all objects
    admin-0	2015-09-23 19:28:29	info	requesting all states
    admin-0	2015-09-23 19:28:29	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:28:24	info	instance system.adapter.admin.0 started with pid 2992
    host-raspberrypi	2015-09-23 19:27:54	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:27:54	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:27:54	error	port 8081 already in use
    admin-0	2015-09-23 19:27:53	info	requesting all objects
    admin-0	2015-09-23 19:27:53	info	requesting all states
    admin-0	2015-09-23 19:27:53	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:27:48	info	instance system.adapter.admin.0 started with pid 2981
    host-raspberrypi	2015-09-23 19:27:18	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:27:18	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:27:18	error	port 8081 already in use
    admin-0	2015-09-23 19:27:18	info	requesting all objects
    admin-0	2015-09-23 19:27:18	info	requesting all states
    admin-0	2015-09-23 19:27:17	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:27:13	info	instance system.adapter.admin.0 started with pid 2972
    host-raspberrypi	2015-09-23 19:26:43	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:26:43	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:26:43	error	port 8081 already in use
    admin-0	2015-09-23 19:26:42	info	requesting all objects
    admin-0	2015-09-23 19:26:42	info	requesting all states
    admin-0	2015-09-23 19:26:42	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:26:37	info	instance system.adapter.admin.0 started with pid 2962
    host-raspberrypi	2015-09-23 19:26:07	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:26:07	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:26:07	error	port 8081 already in use
    admin-0	2015-09-23 19:26:07	info	requesting all objects
    admin-0	2015-09-23 19:26:07	info	requesting all states
    admin-0	2015-09-23 19:26:07	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:26:02	info	instance system.adapter.admin.0 started with pid 2956
    host-raspberrypi	2015-09-23 19:25:32	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:25:32	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:25:32	error	port 8081 already in use
    admin-0	2015-09-23 19:25:31	info	requesting all objects
    admin-0	2015-09-23 19:25:31	info	requesting all states
    admin-0	2015-09-23 19:25:31	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-09-23 19:25:26	info	instance system.adapter.admin.0 started with pid 2947
    host-raspberrypi	2015-09-23 19:24:56	info	Restart adapter system.adapter.admin.0 because enabled
    host-raspberrypi	2015-09-23 19:24:56	error	instance system.adapter.admin.0 terminated with code 1 ()
    admin-0	2015-09-23 19:24:56	error	port 8081 already in use
    admin-0	2015-09-23 19:24:56	info	requesting all objects
    admin-0	2015-09-23 19:24:56	info	requesting all states
    admin-0	2015-09-23 19:24:56	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
    Gruß aus Dortmund
    Michael
    <size size="85">Ausstattung: PI 4 , Rasbian , IOBroker , Admin 1.2.3, VIS 0.10.2, Host 0.90 [wird immer auf dem neuesten Stand geha…</size>
      tesso
      Da läuft noch ein Prozess der Port 8081 schon belegt.
      Versuche````
      cd /opt/iobroker
      ./iobroker stop
      ps -A | grep io
      Dann sollte ein oder mehrere Prozesse mit io auftauchen. Diese dann mit kill Prozess-ID löschen oder den raspy neu starten.
        audioconcept
        Hi
        hab ich ausgeführt und dann neu gestartet.
        Jetzt steht im Log:
        Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
        raspberrypi	2015-09-24 08:23:59	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi	2015-09-24 08:23:59	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
        raspberrypi	2015-09-24 08:23:52	info	host.raspberrypi instance system.adapter.admin.1 started with pid 2971
        raspberrypi	2015-09-24 08:23:22	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi	2015-09-24 08:23:22	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
        raspberrypi	2015-09-24 08:23:15	info	host.raspberrypi instance system.adapter.admin.1 started with pid 2962
        raspberrypi	2015-09-24 08:22:45	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi	2015-09-24 08:22:45	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
        raspberrypi	2015-09-24 08:22:38	info	host.raspberrypi instance system.adapter.admin.1 started with pid 2956
        raspberrypi	2015-09-24 08:22:08	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi	2015-09-24 08:22:08	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
        raspberrypi	2015-09-24 08:21:57	info	host.raspberrypi instance system.adapter.admin.1 started with pid 2947
        raspberrypi	2015-09-24 08:21:27	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi	2015-09-24 08:21:27	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
        example.1	2015-09-24 08:21:22	info	example.1 stateChange example.1.testVariable {'val':null,'ack':true,'ts':1443075683,'from':'system.adapter.example.1','lc':1443075683}
        Dieses steht nach der Ausführung noch drin:
        Gruß aus Dortmund
        Michael
          audioconcept
          Hi
          wenn ich jetzt mal einen Restart mache kommt dieses hier (aber Iobroker läuft trotzdem):
          Gruß aus Dortmund
          Michael
            Bitte als root starten!
              audioconcept
              Ich hab es noch mal als admin gemacht und dann habe ich jetzt nur noch:
              ps -A | grep io
              2753 ? 00:00:13 io.hm-rega.0
              Im Log steht jetzt noch als Fehler:
              host-raspberrypi	2015-09-24 12:45:11	error	 instance system.adapter.admin.1 terminated with code 1 ()
              admin-1	2015-09-24 12:45:09	error	 port 8081 already in use
              admin-1	2015-09-24 12:45:02	error	 no connection to objects DB
              raspberrypi	2015-09-24 12:45:11	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
              Gruß aus Dortmund
              Michael
                @audioconcept:
                Ich hab es noch mal als admin gemacht `
                ich denke doch als root - oder?
                Was ist sonst noch auf deinem Raspi drauf?
                Wenn nur ioBroker, dann mach mal einen reboot des Raspi
                Oder
                Hast du bei der Konfiguration bei einem Adapter den Port auf 8081 umgestellt?
                Wieso hast du 2x admin laufen?
                  audioconcept
                  Hi Homoran
                  sorry meinte als root.
                  Neustart des Pi hab ich immer gemacht.
                  Ich hab wirklich zwei Admin drauf. Hatte mich auch schon gefragt warum, dachte aber es muss so sein.
                  Admin 0 und Admin 1
                  Kann ich den Admin 1 einfach mal auf inaktiv setzen?
                  Hab es auf inaktiv gesetzt und neustart gemacht und mal sehen ob es dann besser ist.
                  Gruß aus Dortmund
                  Michael
                    audioconcept
                    Jepp
                    keine Fehlermeldungen mehr seit dem admin :1 auf inaktiv.
                    Kann ich den einfach löschen?
                    Vielen Dank.
                    Gruß aus Dortmund
                    Michael
                      Natürlich, sonst hätte ich nicht gefragt!
                      @audioconcept:
                      Hatte mich auch schon gefragt warum, `
                      Das ist mein Text!
                      @Homoran:
                      Wieso hast du 2x admin laufen? `
                      Wenn da keine Absicht hintersteckt - z.B. weil du dich aus den Systemgeschossen hast, weil der erste admin falsch konfiguriert war, kannst du den zweiten löschen.
                      Überprüfe aber bitte vorher die Konfig.
                        audioconcept
                        Hi
                        grins ja war dein Spruch :-)
                        Ich bin mir nicht sicher was ich genau nachsehen soll in der Konfig. aber ich kann es auch nicht aktiviert so lassen.
                        Hab aber jetzt noch diese Meldungen bekommen:
                        cal-1	2015-09-24 15:31:54	info	 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
                        ical-0	2015-09-24 15:31:54	info	 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
                        ical-0	2015-09-24 15:31:44	error	 no connection to objects DB
                        ical-1	2015-09-24 15:31:44	error	 no connection to objects DB
                        host-raspberrypi	2015-09-24 15:30:00	info	 instance system.adapter.ical.0 started with pid 3500
                        host-raspberrypi	2015-09-24 15:30:00	info	 instance system.adapter.ical.1 started with pid 3499
                        hm-rega-0	2015-09-24 15:28:26	warn	 Pending request for more than 125000 ms
                        hm-rega-0	2015-09-24 15:28:18	warn	 Pending request for more than 100000 ms
                        hm-rega-0	2015-09-24 15:28:10	warn	 Pending request for more than 75000 ms
                        hm-rega-0	2015-09-24 15:28:01	warn	 Pending request for more than 50000 ms
                        hm-rega-0	2015-09-24 15:27:50	warn	 Pending request for more than 25000 ms
                        hm-rega-0	2015-09-24 15:26:56	warn	 Pending request for more than 125000 ms
                        hm-rega-0	2015-09-24 15:26:48	warn	 Pending request for more than 100000 ms
                        hm-rega-0	2015-09-24 15:26:40	warn	 Pending request for more than 75000 ms
                        hm-rega-0	2015-09-24 15:26:31	warn	 Pending request for more than 50000 ms
                        hm-rega-0	2015-09-24 15:26:20	warn	 Pending request for more than 25000 ms
                        fritzbox-0	2015-09-24 15:23:48	info	 data from 192.168.0.1: 24.09.15 15:23:48;DISCONNECT;0;0;
                        fritzbox-0	2015-09-24 15:23:25	info	 data from 192.168.0.1: 24.09.15 15:23:25;RING;0;xxxxxxxxx;7223772;ISDN;
                        fritzbox-0	2015-09-24 13:21:35	info	 adapter connected to fritzbox: 192.168.0.1
                        host-raspberrypi	2015-09-24 15:00:21	info	 instance system.adapter.ical.1 terminated with code 0 (OK)
                        host-raspberrypi	2015-09-24 15:00:21	info	 instance system.adapter.ical.0 terminated with code 0 (OK)
                        Gruß aus Dortmund
                        Michael
                          Ich hab mal die Telefonnummer aus deinem log ausge-ixt
                          @audioconcept:
                          Ich bin mir nicht sicher was ich genau nachsehen soll in der Konfig. `
                          Vergleiche admin-0 und admin-1
                          wenn die gleich sind kannst du admin-1 löschen.
                          @audioconcept:
                          aber ich kann es auch nicht aktiviert so lassen. `
                          Nein, kannst du nicht!
                          Da hat ioBroker probllem (gehabt) die rega auf der CCU zu erreichen.
                          Nicht dass die abgestürzt ist.
                            audioconcept
                            Hi ich bekomme es nicht gelöscht.Bleibt ewig dort hängen.
                            $ ./iobroker del admin.1
                            host.raspberrypi Counted 1 instances of admin.1
                            host.raspberrypi Counted 7 states "system.adapter.admin.1*" from states
                            Im Admin 0 steht die IP auf 0.0.0.0 da muss doch die vom Server rein? Oder?
                            Ich hab im Admin 0 dann die Serveradresse eingetragen. War das ein Fehler? Jetzt hab ich beim Aufruf immer dieses Zahnrad am laufen.
                            Was kann ich da machen?
                            VIS geht aber einwandfrei. Komme nur nicht ins Admin
                            Gruß aus Dortmund
                            Michael
                              Ja das war ein Fehler! Da MUSS 0.0.0.0 stehen.
                              Such mal im Forum, das muss stehen, wie man jetzt es halbwegs gerettet bekommt
                              Irgenwie mit iobroker add admin und einer portangabe.
                              Sonsthast du wieder das andere problem.
                              Bin nicht mehr am PC
                              Gesendet von meinem LIFETAB_S785X mit Tapatalk
                                audioconcept
                                iobroker set admin.0 –ip 0.0.0.0
                                war die Rettung. Jetzt geht es wieder.
                                Jetzt muss ich nur noch Admin .1 gelöscht bekommen.
                                Gruß aus Dortmund
                                Michael
