  4. [gelöst] MQTT es werden keine Daten mehr empfangen
    2.5k
    4.5k
11 Beiträge 4 Kommentatoren 3.2k Aufrufe
  • F Offline
    frankie
    manchmal erscheint im Log folgende Meldung:
    mqtt-0   2015-09-15 01:35:57   info   Connected to localhost
    Danach werden keine MQQT Daten mehr empfangen.
    Wenn man dann anschliessend einen Reload auf den MQTT Adapter ausführt werden sofort wieder Daten empfangen.
    Press Ctrl+A and Ctrl+C to copy log to clipboard and click with mouse anywhere to close.
    history-0	2015-09-15 11:00:13	info	moved 1 history datapoints from Redis history.javascript.0.ehz361z5.lieferung to CouchDB history.javascript.0.ehz361z5.lieferung.20150915
    history-0	2015-09-15 11:00:13	info	moved 201 history datapoints from Redis history.javascript.0.ehz361z5.lieferung to CouchDB history.javascript.0.ehz361z5.lieferung.20150914
    history-0	2015-09-15 11:00:13	info	1 remaining datapoints of history.javascript.0.ehz361z5.lieferung
    history-0	2015-09-15 11:00:13	info	moved 480 history datapoints from Redis history.javascript.0.ehz361z5.lieferung to CouchDB history.javascript.0.ehz361z5.lieferung.20150913
    history-0	2015-09-15 11:00:13	info	201 remaining datapoints of history.javascript.0.ehz361z5.lieferung
    history-0	2015-09-15 11:00:12	info	moving 480 entries to couchdb
    javascript-0	2015-09-15 11:00:02	info	script.js.ehz361z5: ehz361z5: Bezug=521.4445893089775 W @ Intervall=0.07822685788787484 s
    javascript-0	2015-09-15 11:00:02	info	script.js.ehz361z5: ehz361t5: Bezug erhalten newState=006752.3016@2015.09.15 11:00:03 oldState=006745.6358@2015.09.14 22:13:03 (float new=6752.3016 old=6745.6358)
    mqtt-0	2015-09-15 11:00:00	info	Connected to localhost
    mqtt-0	2015-09-15 11:00:00	info	Try to connect to mqtt://localhost:1883?clientId=ioBroker.mqtt.0
    mqtt-0	2015-09-15 10:59:58	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.mqtt
    host-raspberrypi	2015-09-15 10:59:51	info	instance system.adapter.mqtt.0 started with pid 14293
    host-raspberrypi	2015-09-15 10:59:47	info	instance system.adapter.mqtt.0 terminated with code 0 (OK)
    host-raspberrypi	2015-09-15 10:59:47	info	stopInstance system.adapter.mqtt.0 killing pid 6209
    host-raspberrypi	2015-09-15 10:59:47	info	object change system.adapter.mqtt.0
    pushover-0	2015-09-15 07:07:50	info	Send pushover notification: {'message':'sunrise (top edge of the sun appears on the horizon)','title':'Information - Zu Hause','priority':'0'}
    javascript-0	2015-09-15 07:07:50	info	sendTo 'send' to system.adapter.pushover.0 from system.adapter.javascript.0: {'message':'sunrise (top edge of the sun appears on the horizon)','title':'Information - Zu Hause','priority':0}
    pushover-0	2015-09-15 06:10:00	info	Send pushover notification: {'message':'Es ist 06:10 Uhr, jetzt kommt die Gartentemperatur 11.3°C und Luftfeuchte 84 %','title':'Information - Zu Hause','priority':'0'}
    javascript-0	2015-09-15 06:10:00	info	sendTo 'send' to system.adapter.pushover.0 from system.adapter.javascript.0: {'message':'Es ist 06:10 Uhr, jetzt kommt die Gartentemperatur 11.3°C und Luftfeuchte 84 %','title':'Information - Zu Hause','priority':0}
    mqtt-0	2015-09-15 02:59:11	info	Connected to localhost
    host-raspberrypi	2015-09-15 02:17:49	info	Delete log file iobroker.log.2015-09-08
    Frank
    Raspberry Pi 2 - Raspbian 4.1.6-v7+
    node v0.12.7 (Installation nach http://nodered.org/docs/hardware/raspberrypi.html)
    mosquitto 1.4.3
    ioBroker.js-controller 0.7.12
    • F Offline
      frankie
      Leider wiederholt sich diese Fehlersituation 2 bis 3 mal täglich. Ab diesem Zeitpunkt werden keine MQTT Meldugen mehr empfangen.
      mqtt-0	2015-09-20 13:29:48	info	Connected to localhost
      javascript-0	2015-09-20 13:29:02	info	script.js.ehz361z5: ehz361z5: Lieferung=2471.9999999797437 W @ Intervall=60 s
      javascript-0	2015-09-20 13:29:02	info	script.js.ehz361z5: ehz361z5: Lieferung erhalten newState=018525.6287@2015.09.20 13:29:02 oldState=018525.5875@2015.09.20 13:28:02 (float new=18525.6287 old=18525.5875)
      Hat jemand einen Vorschlag zur Analyse?
      Zur Zeit hilft nur ein Restart des Mqtt Adapters.
      mosquitto 1.4.3
      • BluefoxB Offline
        BluefoxB Offline
        Ich wurde Wireshark Aufzeichnung machen. Aber ich sehe, dass es auf Raspi läuft. Es wird komplizierte.
        Kann jemand den Fall bestätigen?
        • H Offline
          hometm
          ich kann dies nicht bestätigen. Bei mir läuft der Adapter seit mehreren Wochen ohne Probleme.
          Ich erhalte ca. 1x täglich die Meldungen eines Verbindungsneuaufbaus:
          mqtt-0 2015-09-21 07:11:47 info Client [arduinoClient] connected
          mqtt-0 2015-09-21 07:11:47 info Client [arduinoClient] closed
          Aber der Datenaustausch funktioniert ohne Neustart o.ä.
          • F Offline
            frankie
            @hometm:
            mqtt-0 2015-09-21 07:11:47 info Client [arduinoClient] closed `
            Kann es sein, dass Du den mqtt Adapter als Server benutzt?
            Ich nutze ihn als Client.
            mosquitto 1.4.3
            • H Offline
              hometm
              @frankie:
              Kann es sein, dass Du den mqtt Adapter als Server benutzt? `
              Ja
                Arminhh
                ich habe das Problem, das die " Privaten Daten" nicht übermittelt werden. Ich habe versucht unter den MQTT Einstellungen bei Prefix für alle Topics: + oder # oder /#. kein Erfolg!
                mfg
                Arminhh
                • F Offline
                  frankie
                  @hometm:
                  @frankie:
                  Ja `
                  Habe den ioBroker Mqtt Apater auch auf Server umgestellt. Die Clients habe ich dann anstelle von meiner mosquitto Bridge direkt an den neuen ioBroker Mqtt Broker angeschlossen.
                  Seit mehreren Tagen werden nun die Daten ohne Probleme empfangen. Scheint nun alles zu laufen.
                  Demnächst werde ich noch meine MySensors Infrastruktur "anschließen". Werde dann berichten…
                  mosquitto 1.4.3
                  • BluefoxB Offline
                    BluefoxB Offline
                    @Arminhh:
                    mfg
                    Arminhh `
                    Wie sehen die Topics für Privaten Daten aus?
                      Arminhh
                      Hallo Bluefox,
                      eigentlich möchte ich nicht Deine Zeit beanspruchen, weil ich nicht weiß ob ich nur zu blöde bin. Ich steige noch nicht so richtig durch den Owntracks Flow hier im Forumdurch.
                      Laut Owntrack ist der Parmeter für alle Dateien Owntrack / #
                      Die Daten sehen so aus. {"_type":"transition","lat":53.xxxx,"lon":10.0xxxxx,"acc":34,"tst":1443337834,"wtst":1442258432,"desc":"zuhause","event":"enter","tid":"S5"}
                      Danke für die Nachfrage
                      mfg
                      Armin
                      • F Offline
                        frankie
                        @frankie:
                        Demnächst werde ich noch meine MySensors Infrastruktur "anschließen". Werde dann berichten… `
                        Habe nun auch die MySensors Mqtt Schnittselle an den ioBroker Mqtt Broker angebunden. Auch diese Daten kommen nun ohne Probleme.
                        Hier die mosquitto Bridge Einstellungen um den Mqtt Datenfluss vom Standard MySenors Mqtt Gateway über eine mosquitto Bridge in den ioBroker Mqtt Broker zu "pumpen":
                        root@raspberrypi:/etc/mosquitto/conf.d# cat mysensors.conf
                        connection mysensors-MQTT-gateway-IN
                        address 192.168.178.66
                        cleansession true
                        topic # in 0 MySensors/ MyMQTT/
                        connection mysensors-MQTT-gateway-OUT
                        address 192.168.178.32:18830
                        cleansession true
                        topic # out 0 MySensors/ MySensors/
                        Daher setze ich diesen Thread auch auf gelöst.
                        mosquitto 1.4.3
