  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.1k Aufrufe 51 Beobachtet
  • cashC Offline
    cashC Offline
    cash
    #83
    @Zefau said in [Neuer Adapter] Nuki:
    iobroker upload nuki-extended
    In der Gui sehe ich den Adapter unter "Adapter" nicht sondern nur unter Instanzen. Habe also iobroker upload gemacht. Sieht nicht gut aus:
    host.iobroker_v2_19-05-19	2019-09-29 14:53:40.249	info	object change system.adapter.nuki-extended.1
    host.iobroker_v2_19-05-19	2019-09-29 14:53:30.238	info	Restart adapter system.adapter.nuki-extended.1 because enabled
    host.iobroker_v2_19-05-19	2019-09-29 14:53:30.238	error	instance system.adapter.nuki-extended.1 terminated with code 1 ()
    Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Module._compile (module.js:653:30)
    Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nuki-extended/nuki-extended.js:11:16)
    Caught	2019-09-29 14:53:30.238	error	by controller[0]: at require (internal/module.js:11:18)
    Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Module.require (module.js:597:17)
    Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Function.Module._load (module.js:498:3)
    Caught	2019-09-29 14:53:30.238	error	by controller[0]: at tryModuleLoad (module.js:506:12)
    Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Module.load (module.js:566:32)
    Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nuki-extended/lib/nuki-bridge-api/index.js:1:76)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at require (internal/module.js:11:18)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Module.require (module.js:597:17)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Function.Module._load (module.js:498:3)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at tryModuleLoad (module.js:506:12)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Module.load (module.js:566:32)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Module._compile (module.js:653:30)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nuki-extended/lib/nuki-bridge-api/lib/bridge.js:2:13)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Function.Module._load (module.js:475:25)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
    Caught	2019-09-29 14:53:30.237	error	by controller[0]: Error: Cannot find module 'sha.js'
    Caught	2019-09-29 14:53:30.236	error	by controller[0]: ^
    Caught	2019-09-29 14:53:30.236	error	by controller[0]: throw err;
    Caught	2019-09-29 14:53:30.236	error	by controller[0]: module.js:550
    host.iobroker_v2_19-05-19	2019-09-29 14:53:29.406	info	instance system.adapter.nuki-extended.1 started with pid 9573
    host.iobroker_v2_19-05-19	2019-09-29 14:52:59.320	info	Restart adapter system.adapter.nuki-extended.1 because enabled
    Adapter wird nicht grün
    • cashC cash
      ZefauZ Offline
      ZefauZ Offline
      Zefau
      #84
      @cash arg, ist ein neues Modul, was für den hashed token verwendet wird, was ich vergessen habe in den Dependencies anzugeben. Sorry.
      Kannst du nochmal von Github nachinstallieren? Danke dir!
      cashC 1 Antwort Letzte Antwort
      • ZefauZ Zefau
        cashC Offline
        cashC Offline
        cash
        #85
        @Zefau Adapter wird nicht grün. Bleibt gelb. Log sieht gut aus:
        nuki-extended.1	2019-09-29 15:02:10.771	info	Polling Nuki Web API with a frequency of 60s.
        nuki-extended.1	2019-09-29 15:02:10.545	info	starting. Version 2.0.0-rc.2 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v8.14.0
        host.iobroker_v2_19-05-19	2019-09-29 15:02:08.761	info	instance system.adapter.ical.0 terminated with code 0 (OK)
        host.iobroker_v2_19-05-19	2019-09-29 15:02:08.736	info	instance system.adapter.nuki-extended.1 started with pid 9811
        host.iobroker_v2_19-05-19	2019-09-29 15:02:08.718	info	"system.adapter.nuki-extended.1" enabled
        host.iobroker_v2_19-05-19	2019-09-29 15:02:08.716	info	object change system.adapter.nuki-extended.1
        host.iobroker_v2_19-05-19	2019-09-29 15:02:00.022	info	instance system.adapter.ical.0 started with pid 9797
        host.iobroker_v2_19-05-19	2019-09-29 15:01:41.079	info	object change system.adapter.nuki-extended.1
        hue-extended.0	2019-09-29 14:59:13.705	info	Successfully set /groups/3/action/scene on Hue Flur (to 68FF4wtPdcqvqmr).
        javascript.2	2019-09-29 14:59:11.090	info	script.js.Flur.Licht_durch_Bewegungsmelder: Licht wurde zwischen 11:00 und 15:00 Uhr eingeschaltet. --- Helligkeitswert: 88
        host.iobroker_v2_19-05-19	2019-09-29 14:54:01.249	info	Do not restart adapter system.adapter.nuki-extended.1 because disabled or deleted
        Im Adapter selber habe ich jetzt die Optionen.
        • cashC Offline
          cashC Offline
          cash
          #86
          Nachtrag: Adapter nochmal gestoppt und wieder gestartet jetzt ist er grün
          • cashC Offline
            cashC Offline
            cash
            schrieb am zuletzt editiert von cash
            #87
            @Zefau Die Webseite mit dem logs wird nicht mehr angezeigt?
            Please activate Nuki Web API to retrieve log entries!
            Web Api ist aktiviert.
            !![0_1569763023889_Bildschirmfoto 2019-09-29 um 15.15.43.png](Uploading 100%)
            • cashC cash
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #88
              @cash sagte in [Neuer Adapter] Nuki:
              Der Screenshot wurde leider nicht richtig hochgeladen.
              Kannst du mal im Browser die Konsole öffnen und prüfen, ob dort ein Fehler drin steht?
              Also bei Firefox über Web Developer und dann Web Console. Im Chrome über Weitere Tools und dann Entwicklertools.
              • ZefauZ Zefau
                cashC Offline
                cashC Offline
                cash
                #89
                @Zefau Mache ich nachher. Will das trockende Wetter nutzen und mit dem Hund ne Runde drehen bevor es gleich wieder regnet.
                Das Bild war ein Scnreenshot vom Admi wo man sah wann die Daten sowohl per Webapi als auch per Bridge aktualisiert wurden. Irgendwie konnte ich das Bild aber nicht hochladen.
                Fehler auf der Seite glaube ich nicht. Die Seite sah ganz gut aus bis auf eben der Hinweis anstelle der logs. Vom Design sah es ebenfalls so aus wie wenn die Logs dort stehen.
                Werde gleich aber gucken.
                • ? Offline
                  #90
                  Hi, hab mal rc2 installiert, läuft ohne Probleme. Zeigt auch alle User und Vorgänge uber die Api an. Danke!
                    ZefauZ Offline
                    ZefauZ Offline
                    Zefau
                    #91
                    @ilovegym sagte in [Neuer Adapter] Nuki:
                    Auch auf dem adapter web interface (klick auf die Kachel in der Übersicht)?
                    • ZefauZ Zefau
                      #92
                      @Zefau ja!
                      • cashC Offline
                        cashC Offline
                        cash
                        #93
                        Es bleibt dabei. Bei mir kommt dort nichts:
                        • cashC cash
                          ZefauZ Offline
                          ZefauZ Offline
                          Zefau
                          #94
                          @cash Merkwürdig. Welchen Browser benutzt du? Welche bzw. wie viele Locks / Opener hast du im Adapter?
                          Steht sonst noch was im Log? Also beispielsweise Retrieving smartlocks logs.. bzw. Found X entries in smartlocks logs. ?
                          • cashC Offline
                            cashC Offline
                            cash
                            #95
                            Wie man sieht steht webApi sync auf true und wird auch aktuell gesynct. Was aber komisch ist, ist das Bridge-Api Last. Das war da wo ich den Adapter neu gestartet habe?
                            ZefauZ 2 Antworten Letzte Antwort
                            • cashC cash
                              ZefauZ Offline
                              ZefauZ Offline
                              Zefau
                              #96
                              @cash Hast du das Objekt logs in den Datenpunkten unter smartlocks?
                              • ZefauZ Zefau
                                cashC Offline
                                cashC Offline
                                cash
                                #97
                                @Zefau Adapter aktiv derzeit nur den extended. Deaktiviert ist noch der nuki 2.0 von Dir. Sonst keine Nuki Adapter.
                                Log ist absolut sauber. Keine Logs vom Adapter. Benutze Chrome auf einen MacbookPro. Sieht aber bei Safari genau so aus.
                                • cashC cash
                                  ZefauZ Offline
                                  ZefauZ Offline
                                  Zefau
                                  #98
                                  Hast du denn Sync aktiviert für die Bridge API? Oder Callback?
                                  • cashC cash
                                    ZefauZ Offline
                                    ZefauZ Offline
                                    Zefau
                                    #99
                                    Ich meine hast du den Datenpunkt nuki-extended.0.smartlocks.wohnungstür.logs (wohnungstür ist mein Nuki Lock) ?
                                    • cashC Offline
                                      cashC Offline
                                      cash
                                      #100
                                      Ja den Datenpunkt habe ich. Ich nutze Callback.
                                      Im Log ist der letzte Eintrag von "date":"2019-09-29T15:12:12.000Z"},
                                      • cashC Offline
                                        cashC Offline
                                        cash
                                        #101
                                        Callback wurde um 10:37 das letzte mal aktualisiert?
                                        • cashC Offline
                                          cashC Offline
                                          cash
                                          #102
                                          So noch etwas weiter getestet. Habe erstmal den Adapter gestoppt und alle Datenpunkte gelöscht. Nach Neustart wird der Adapter grün und legt alle Datenpunkte wieder an. Auch den "log". Aber auch hier ist der letzte Eintrag wie oben schon geschrieben von 15:12. Wo ich das schreibe würde ich ja sagen das das nicht 15:12 ist sondern eher 17:12 Uhr? Das würde auch eher zum Protokoll von web.nuki.io passen, denn um 17:12 habe ich einen Eintrag um 15:12 nicht. Scheint also ein Problem mit der Zeitzone zu sein?
                                          Aber trotzdem bleibt die Webseite leer bzw er schreibt dort weiterhin: Please activate Nuki Web API to retrieve log entries!
