  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.1k Aufrufe 51 Beobachtet
  • cashC Offline
    cashC Offline
    cash
    #77
    Beim stoppen vom Adapter sieht es auch nicht so richtig gut aus:
    nuki-extended.1	2019-09-29 10:37:45.590	info	Listening for Nuki events on port 51988.
    nuki-extended.1	2019-09-29 10:37:43.946	info	Polling Nuki Web API with a frequency of 60s.
    nuki-extended.1	2019-09-29 10:37:43.689	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v8.14.0
    host.iobroker_v2_19-05-19	2019-09-29 10:37:40.169	info	instance system.adapter.nuki-extended.1 started with pid 4631
    host.iobroker_v2_19-05-19	2019-09-29 10:37:40.047	info	object change system.adapter.nuki-extended.1
    host.iobroker_v2_19-05-19	2019-09-29 10:37:17.484	info	instance system.adapter.nuki-extended.1 terminated with code 0 (OK)
    Caught	2019-09-29 10:37:17.484	error	by controller[2]: (node:4553) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with
    Caught	2019-09-29 10:37:17.484	error	by controller[2]: (node:4553) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at process._tickCallback (internal/process/next_tick.js:181:9)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at endReadableNT (_stream_readable.js:1064:12)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at Socket.emit (events.js:208:7)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at emitNone (events.js:111:20)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at Socket.socketOnEnd (_http_client.js:437:9)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at ClientRequest.emit (events.js:211:7)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at emitOne (events.js:116:13)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
    Caught	2019-09-29 10:37:17.484	error	by controller[1]: at Request.emit (events.js:211:7)
    Caught	2019-09-29 10:37:17.483	error	by controller[1]: at emitOne (events.js:116:13)
    Caught	2019-09-29 10:37:17.483	error	by controller[1]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    Caught	2019-09-29 10:37:17.483	error	by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
    Caught	2019-09-29 10:37:17.483	error	by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
    Caught	2019-09-29 10:37:17.483	error	by controller[1]: at new RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
    Caught	2019-09-29 10:37:17.483	error	by controller[1]: (node:4553) UnhandledPromiseRejectionWarning: RequestError: Error: socket hang up
    nuki-extended.1	2019-09-29 10:37:17.458	info	Adapter stopped und unloaded.
    host.iobroker_v2_19-05-19	2019-09-29 10:37:17.433	info	stopInstance system.adapter.nuki-extended.1 killing pid 4553
    host.iobroker_v2_19-05-19	2019-09-29 10:37:17.433	info	"system.adapter.nuki-extended.1" disabled
    nuki-extended.1	2019-09-29 10:37:17.435	info	Adapter stopped und unloaded.
    Nach dem Neustart des Adapters scheint er aber jetzt ruhig zu sein.
    • cashC cash
      ZefauZ Offline
      ZefauZ Offline
      Zefau
      #78
      @cash vielen Dank für das Testen! Kannst du dir die aktuelle Version von Github installieren (v2.0.0-rc.2)? Danke!
      Changelog:
      • added support for multiple devices (including Nuki Opener) on adapter web interface
      • added option to not retrieve all information (by deselecting config or users) via Nuki Web API
      cashC 1 Antwort Letzte Antwort
      • ZefauZ Zefau
        Changelog:
        cashC Offline
        cashC Offline
        cash
        #79
        @Zefau Kann ich machen. Wie kann ich den Adapter updaten ohne eine neue Instanz anzulegen? Wo ich heute Morgen die Version installiert habe, hat er eine neue Instanz angelegt und dort musste ich dann wieder Token, Api, IP usw neu eingeben....
        • cashC cash
          ZefauZ Offline
          ZefauZ Offline
          Zefau
          #80
          @cash sagte in [Neuer Adapter] Nuki:
          Einfach im Ordner /opt/iobroker
          npm i https://github.com/Zefau/ioBroker.nuki2.git#nuki-extended
          Dann sollte er die vorhandene Installation einfach überschreiben und die Konfiguration beibehalten.
          • ZefauZ Zefau
            cashC Offline
            cashC Offline
            cash
            #81
            @Zefau habe ich gemacht. Habe auch gesehen das er was installiert bzw aktualisiert hat aber eine Veränderung sehe ich aber beim Adapter nicht. Das heißt der Adapter sieht noch genauso aus wie vorher. Kann dort nichts zusätzlich einstellen wegen User oder so...
            • cashC cash
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #82
              Stimmt, kannst du den Adapter mal uploaden? Also entweder über die GUI oder
              iobroker upload nuki-extended
              Dann sollte er bei Adapter-Start die Version v2.0.0-rc.2 anzeigen.
              • cashC Offline
                cashC Offline
                cash
                #83
                @Zefau said in [Neuer Adapter] Nuki:
                In der Gui sehe ich den Adapter unter "Adapter" nicht sondern nur unter Instanzen. Habe also iobroker upload gemacht. Sieht nicht gut aus:
                host.iobroker_v2_19-05-19	2019-09-29 14:53:40.249	info	object change system.adapter.nuki-extended.1
                host.iobroker_v2_19-05-19	2019-09-29 14:53:30.238	info	Restart adapter system.adapter.nuki-extended.1 because enabled
                host.iobroker_v2_19-05-19	2019-09-29 14:53:30.238	error	instance system.adapter.nuki-extended.1 terminated with code 1 ()
                Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Module._compile (module.js:653:30)
                Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nuki-extended/nuki-extended.js:11:16)
                Caught	2019-09-29 14:53:30.238	error	by controller[0]: at require (internal/module.js:11:18)
                Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Module.require (module.js:597:17)
                Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Function.Module._load (module.js:498:3)
                Caught	2019-09-29 14:53:30.238	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Module.load (module.js:566:32)
                Caught	2019-09-29 14:53:30.238	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nuki-extended/lib/nuki-bridge-api/index.js:1:76)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at require (internal/module.js:11:18)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Module.require (module.js:597:17)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Function.Module._load (module.js:498:3)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Module.load (module.js:566:32)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Module._compile (module.js:653:30)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.nuki-extended/lib/nuki-bridge-api/lib/bridge.js:2:13)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Function.Module._load (module.js:475:25)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
                Caught	2019-09-29 14:53:30.237	error	by controller[0]: Error: Cannot find module 'sha.js'
                Caught	2019-09-29 14:53:30.236	error	by controller[0]: ^
                Caught	2019-09-29 14:53:30.236	error	by controller[0]: throw err;
                Caught	2019-09-29 14:53:30.236	error	by controller[0]: module.js:550
                host.iobroker_v2_19-05-19	2019-09-29 14:53:29.406	info	instance system.adapter.nuki-extended.1 started with pid 9573
                host.iobroker_v2_19-05-19	2019-09-29 14:52:59.320	info	Restart adapter system.adapter.nuki-extended.1 because enabled
                Adapter wird nicht grün
                • cashC cash
                  ZefauZ Offline
                  ZefauZ Offline
                  Zefau
                  #84
                  @cash arg, ist ein neues Modul, was für den hashed token verwendet wird, was ich vergessen habe in den Dependencies anzugeben. Sorry.
                  Kannst du nochmal von Github nachinstallieren? Danke dir!
                  • ZefauZ Zefau
                    cashC Offline
                    cashC Offline
                    cash
                    #85
                    @Zefau Adapter wird nicht grün. Bleibt gelb. Log sieht gut aus:
                    nuki-extended.1	2019-09-29 15:02:10.771	info	Polling Nuki Web API with a frequency of 60s.
                    nuki-extended.1	2019-09-29 15:02:10.545	info	starting. Version 2.0.0-rc.2 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v8.14.0
                    host.iobroker_v2_19-05-19	2019-09-29 15:02:08.761	info	instance system.adapter.ical.0 terminated with code 0 (OK)
                    host.iobroker_v2_19-05-19	2019-09-29 15:02:08.736	info	instance system.adapter.nuki-extended.1 started with pid 9811
                    host.iobroker_v2_19-05-19	2019-09-29 15:02:08.718	info	"system.adapter.nuki-extended.1" enabled
                    host.iobroker_v2_19-05-19	2019-09-29 15:02:08.716	info	object change system.adapter.nuki-extended.1
                    host.iobroker_v2_19-05-19	2019-09-29 15:02:00.022	info	instance system.adapter.ical.0 started with pid 9797
                    host.iobroker_v2_19-05-19	2019-09-29 15:01:41.079	info	object change system.adapter.nuki-extended.1
                    hue-extended.0	2019-09-29 14:59:13.705	info	Successfully set /groups/3/action/scene on Hue Flur (to 68FF4wtPdcqvqmr).
                    javascript.2	2019-09-29 14:59:11.090	info	script.js.Flur.Licht_durch_Bewegungsmelder: Licht wurde zwischen 11:00 und 15:00 Uhr eingeschaltet. --- Helligkeitswert: 88
                    host.iobroker_v2_19-05-19	2019-09-29 14:54:01.249	info	Do not restart adapter system.adapter.nuki-extended.1 because disabled or deleted
                    Im Adapter selber habe ich jetzt die Optionen.
                    • cashC Offline
                      cashC Offline
                      cash
                      #86
                      Nachtrag: Adapter nochmal gestoppt und wieder gestartet jetzt ist er grün
                      • cashC Offline
                        cashC Offline
                        cash
                        schrieb am zuletzt editiert von cash
                        #87
                        @Zefau Die Webseite mit dem logs wird nicht mehr angezeigt?
                        Please activate Nuki Web API to retrieve log entries!
                        Web Api ist aktiviert.
                        !![0_1569763023889_Bildschirmfoto 2019-09-29 um 15.15.43.png](Uploading 100%)
                        • cashC cash
                          ZefauZ Offline
                          ZefauZ Offline
                          Zefau
                          #88
                          Der Screenshot wurde leider nicht richtig hochgeladen.
                          Kannst du mal im Browser die Konsole öffnen und prüfen, ob dort ein Fehler drin steht?
                          Also bei Firefox über Web Developer und dann Web Console. Im Chrome über Weitere Tools und dann Entwicklertools.
                          • ZefauZ Zefau
                            cashC Offline
                            cashC Offline
                            cash
                            #89
                            @Zefau Mache ich nachher. Will das trockende Wetter nutzen und mit dem Hund ne Runde drehen bevor es gleich wieder regnet.
                            Das Bild war ein Scnreenshot vom Admi wo man sah wann die Daten sowohl per Webapi als auch per Bridge aktualisiert wurden. Irgendwie konnte ich das Bild aber nicht hochladen.
                            Fehler auf der Seite glaube ich nicht. Die Seite sah ganz gut aus bis auf eben der Hinweis anstelle der logs. Vom Design sah es ebenfalls so aus wie wenn die Logs dort stehen.
                            Werde gleich aber gucken.
                            • ? Offline
                              #90
                              Hi, hab mal rc2 installiert, läuft ohne Probleme. Zeigt auch alle User und Vorgänge uber die Api an. Danke!
                                ZefauZ Offline
                                ZefauZ Offline
                                Zefau
                                #91
                                @ilovegym sagte in [Neuer Adapter] Nuki:
                                Auch auf dem adapter web interface (klick auf die Kachel in der Übersicht)?
                                • ZefauZ Zefau
                                  #92
                                  @Zefau ja!
                                  • cashC Offline
                                    cashC Offline
                                    cash
                                    #93
                                    Es bleibt dabei. Bei mir kommt dort nichts:
                                    • cashC cash
                                      ZefauZ Offline
                                      ZefauZ Offline
                                      Zefau
                                      #94
                                      @cash Merkwürdig. Welchen Browser benutzt du? Welche bzw. wie viele Locks / Opener hast du im Adapter?
                                      Steht sonst noch was im Log? Also beispielsweise Retrieving smartlocks logs.. bzw. Found X entries in smartlocks logs. ?
                                      • cashC Offline
                                        cashC Offline
                                        cash
                                        #95
                                        Wie man sieht steht webApi sync auf true und wird auch aktuell gesynct. Was aber komisch ist, ist das Bridge-Api Last. Das war da wo ich den Adapter neu gestartet habe?
                                        ZefauZ 2 Antworten Letzte Antwort
                                        • cashC cash
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #96
                                          @cash Hast du das Objekt logs in den Datenpunkten unter smartlocks?
