  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.1k Aufrufe 51 Beobachtet
  • L locke987
    @Zefau
    Ich bekomme da Fehler beim installieren:
    iobroker 2019-09-17 10:33:19.457 info exit 0
    iobroker 2019-09-17 10:33:19.417 info npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-09-17T08_33_19_401Z-debug.log
    iobroker 2019-09-17 10:33:19.416 info
    iobroker 2019-09-17 10:33:19.409 info npm ERR! 404 tarball, folder, http url, or git url.
    iobroker 2019-09-17 10:33:19.409 info npm ERR! 404 Note that you can also install from a
    iobroker 2019-09-17 10:33:19.409 info npm ERR! 404 1. name can only contain URL-friendly charactersnpm ERR! 404 2. name can no longer contain capital letters
    iobroker 2019-09-17 10:33:19.407 info 404 Your package name is not valid, because
    iobroker 2019-09-17 10:33:19.392 info npm ERR!
    iobroker 2019-09-17 10:33:19.392 info 404 npm ERR! 404 'https://github.com/Zefau/ioBroker.nuki2/tree/nuki2/tarball/master' is not in the npm registry.
    iobroker 2019-09-17 10:33:19.390 info ERR!
    iobroker 2019-09-17 10:33:19.388 info 404 Not Found - GET https://github.com/Zefau/ioBroker.nuki2/tree/nuki2/tarball/masternpm
    iobroker 2019-09-17 10:33:19.386 info ERR!
    iobroker 2019-09-17 10:33:19.384 info
    iobroker 2019-09-17 10:33:19.383 info npm
    iobroker 2019-09-17 10:33:19.375 info E404
    iobroker 2019-09-17 10:33:19.373 info code
    iobroker 2019-09-17 10:33:19.372 info ERR!
    iobroker 2019-09-17 10:33:19.371 info
    iobroker 2019-09-17 10:33:19.369 info npm
    iobroker 2019-09-17 10:33:11.733 info npm install https://github.com/Zefau/ioBroker.nuki2/tree/nuki2/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    iobroker 2019-09-17 10:33:10.989 info install https://github.com/Zefau/ioBroker.nuki2/tree/nuki2/tarball/master
    iobroker 2019-09-17 10:33:10.447 info url "https://github.com/Zefau/ioBroker.nuki2/tree/nuki2" --debug
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    @locke987 liegt wohl am Branch. Ich hab's nochmal in den Master geladen. Probier mal bitte direkt https://github.com/Zefau/ioBroker.nuki2
    L 1 Antwort Letzte Antwort
    • ZefauZ Zefau
      locke987
      schrieb am zuletzt editiert von locke987
      @Zefau installieren konnte ich es, ich habe danach einen neue Instanz hinzugefügt und die alte Instanz deaktiviert, die Version ist laut iobroker noch die selbe, also 1.0.4
      Sollte der lockstate jetzt aktualisiert werden bei deaktivierten callback oder was ist jetzt anders?
      • L locke987
        ZefauZ Offline
        ZefauZ Offline
        Zefau
        @locke987 sagte in [Neuer Adapter] Nuki:
        Trag mal im Reiter der Web Api eine Refresh Zeit ein. In der Version auf Github gilt diese auch für die Bridge. Design muss ich noch ändern.
        Dann pollt er den Status regelmäßig ab.
        • ZefauZ Zefau
          locke987
          @Zefau ja das funktionier jetzt ...lockstate wird so jetzt auch upgedated.
          Danke Dir!
          Frage zum Webadapter:
          Was genau ist der Zweck des Webadapters? Es gibt ein paar mehr Objekte wie zum Beispiel doorstate richtig? Und wie werden diese Objekte dann upgedated? Ganz normal über die http appi und dem callback? Oder könnte man die WebApi auch alleine verwenden?
          • L locke987
            Danke Dir!
            ZefauZ Offline
            ZefauZ Offline
            Zefau
            @locke987 Die Web API liefert zusätzliche Informationen, beispielsweise Logs (damit wird auch das Interface aufgebaut, siehe https://forum.iobroker.net/assets/uploads/files/1553251416356-screenshot_2019-03-22-iobroker-nuki2.png), die gesamte Konfiguration und die berechtigten Benutzer - auch doorstate ist mit drin.
            Die Web API hat keinen Callback. Dieser ist nur bei der Bridge API verfügbar. Die States werden über Polling geupdated.
            Theoretisch kann man die Web API auch alleine verwenden, aber gerade das schicken von Aktionen macht über die Bridge API mehr Sinn.
            • ZefauZ Zefau
              locke987
              @Zefau Danke für die Aufklärung!
              • cashC Offline
                cashC Offline
                cash
                Nachdem heute überraschend nicht nur der neue Türzylinder sondern auch das Nuki-Schloß und die Bridge angekommen sind habe ich mal den Nuki 2.0 Adapter von Zefau installiert.
                Läuft erstmal alles so wie es soll. Deshalb an dieser Stelle eine Danke an Zefau für diesen Adapter.
                • L locke987
                  @Zefau said in [Neuer Adapter] Nuki:
                  @locke987 habe ebenfalls den Nuki 2. Habe das Problem aber bisher nicht festgestellt.
                  Nutzt du die Callbacks? Du musst ja eigtl nicht direkt nach lockState die Information abrufen, da du die ja über den Callback bekommst?
                  Ja ich nutze die callbacks, und die funktionieren in der Regel auch, die callbacks dauern mit Deinem Adapter auch gar nicht so lange (ca. 10 Sek).
                  Mich würde interessieren was bei Dir passiert wenn Du zu schnell hintereinander lock/unlock Befehle über den Adapter schickst.
                  Also z.B.: Zustand des locks ist unlocked, du schickst den Befel lock, du hörst den Sperrvorgang, kurz nachdem der Sperrvorgang akustisch abgeschlossen ist schickst Du einen unlock Befehl.
                  Bei mir schaut das im debug Log dann so aus (http 503 error):
                  nuki2.0	2019-09-15 08:35:09.857	debug	Updating lock door__eingangstür with payload: {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":4
                  nuki2.0	2019-09-15 08:35:09.857	debug	updateLocks(): {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":48.28686,"longitude":16.107248,"
                  nuki2.0	2019-09-15 08:35:09.258	info	Successfully triggered action -UNLOCK- on Nuki Eingangstür.
                  nuki2.0	2019-09-15 08:35:01.758	debug	Action applied on Bridge API.
                  nuki2.0	2019-09-15 08:35:01.758	info	Triggered action -UNLOCK- on Nuki Eingangstür.
                  nuki2.0	2019-09-15 08:35:01.758	debug	State of nuki2.0.door__eingangstür.action has changed {"val":0,"ack":true,"ts":1568529301753,"q":0,"from":"system.adapter.nuki2.0","user":"system.user.admin","lc":1568529301753}.
                  nuki2.0	2019-09-15 08:35:01.753	debug	State of nuki2.0.door__eingangstür.action has changed {"val":1,"ack":false,"ts":1568529301750,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1568529301750}.
                  nuki2.0	2019-09-15 08:34:59.854	debug	Updating lock door__eingangstür with payload: {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":4
                  nuki2.0	2019-09-15 08:34:59.853	debug	updateLocks(): {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":48.28686,"longitude":16.107248,"
                  nuki2.0	2019-09-15 08:34:51.268	debug	503 - "HTTP 503 Unavailable"
                  nuki2.0	2019-09-15 08:34:51.267	warn	Error triggering action -UNLOCK- on Nuki Eingangstür. See debug log for details.
                  nuki2.0	2019-09-15 08:34:51.171	debug	Action applied on Bridge API.
                  nuki2.0	2019-09-15 08:34:51.170	info	Triggered action -UNLOCK- on Nuki Eingangstür.
                  nuki2.0	2019-09-15 08:34:51.164	debug	State of nuki2.0.door__eingangstür.action has changed {"val":0,"ack":true,"ts":1568529291159,"q":0,"from":"system.adapter.nuki2.0","user":"system.user.admin","lc":1568529291159}.
                  nuki2.0	2019-09-15 08:34:51.163	debug	State of nuki2.0.door__eingangstür.action has changed {"val":1,"ack":false,"ts":1568529291155,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1568529291155}.
                  nuki2.0	2019-09-15 08:34:49.837	debug	Updating lock door__eingangstür with payload: {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":4
                  nuki2.0	2019-09-15 08:34:49.837	debug	updateLocks(): {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":48.28686,"longitude":16.107248,"
                  nuki2.0	2019-09-15 08:34:48.281	debug	503 - "HTTP 503 Unavailable"
                  nuki2.0	2019-09-15 08:34:48.281	warn	Error triggering action -UNLOCK- on Nuki Eingangstür. See debug log for details.
                  nuki2.0	2019-09-15 08:34:48.165	debug	Action applied on Bridge API.
                  nuki2.0	2019-09-15 08:34:48.164	info	Triggered action -UNLOCK- on Nuki Eingangstür.
                  nuki2.0	2019-09-15 08:34:48.159	debug	State of nuki2.0.door__eingangstür.action has changed {"val":0,"ack":true,"ts":1568529288155,"q":0,"from":"system.adapter.nuki2.0","user":"system.user.admin","lc":1568529288155}.
                  nuki2.0	2019-09-15 08:34:48.155	debug	State of nuki2.0.door__eingangstür.action has changed {"val":1,"ack":false,"ts":1568529288150,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1568529288150}.
                  nuki2.0	2019-09-15 08:34:40.755	debug	503 - "HTTP 503 Unavailable"
                  nuki2.0	2019-09-15 08:34:40.755	warn	Error triggering action -UNLOCK- on Nuki Eingangstür. See debug log for details.
                  nuki2.0	2019-09-15 08:34:40.651	debug	Action applied on Bridge API.
                  nuki2.0	2019-09-15 08:34:40.651	info	Triggered action -UNLOCK- on Nuki Eingangstür.
                  nuki2.0	2019-09-15 08:34:40.647	debug	State of nuki2.0.door__eingangstür.action has changed {"val":0,"ack":true,"ts":1568529280644,"q":0,"from":"system.adapter.nuki2.0","user":"system.user.admin","lc":1568529280644}.
                  nuki2.0	2019-09-15 08:34:40.644	debug	State of nuki2.0.door__eingangstür.action has changed {"val":1,"ack":false,"ts":1568529280641,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1568529280641}.
                  nuki2.0	2019-09-15 08:34:40.158	debug	Updated state door__eingangstür.logs to value [{"id":"5d7ddb778519f29a434e7190","smartlockId":447733957,"deviceType":0,"name":"Nuki Bridge ","action":2,"trigger":0,"state":0,"autoUnlock":false,"date":
                  nuki2.0	2019-09-15 08:34:39.857	debug	Updated state door__eingangstür.status.lastAction to value 2 (from 1).
                  nuki2.0	2019-09-15 08:34:39.857	debug	Updating lock door__eingangstür with payload: {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":4
                  nuki2.0	2019-09-15 08:34:39.851	debug	updateLocks(): {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":48.28686,"longitude":16.107248,"
                  nuki2.0	2019-09-15 08:34:35.019	debug	Updated state door__eingangstür.status.locked to value true (from false).
                  nuki2.0	2019-09-15 08:34:35.019	debug	Updated state door__eingangstür.status.lockState to value 1 (from 3).
                  nuki2.0	2019-09-15 08:34:35.018	debug	Updated state door__eingangstür.status.refreshed to value Sun Sep 15 2019 08:34:35 GMT+0200 (GMT+02:00) (from Sun Sep 15 2019 08:33:37 GMT+0200 (GMT+02:00)).
                  nuki2.0	2019-09-15 08:34:35.012	debug	Updating lock door__eingangstür with payload: {"nukiId":447733957,"state":{"state":1,"batteryCritical":false,"timestamp":"2019-09-15T06:34:35.008Z"}}
                  nuki2.0	2019-09-15 08:34:35.011	debug	Received payload via callback: {"deviceType":0,"nukiId":447733957,"mode":2,"state":1,"stateName":"locked","batteryCritical":false}
                  nuki2.0	2019-09-15 08:34:31.625	info	Successfully triggered action -LOCK- on Nuki Eingangstür.
                  nuki2.0	2019-09-15 08:34:29.844	debug	Updating lock door__eingangstür with payload: {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":4
                  nuki2.0	2019-09-15 08:34:29.843	debug	updateLocks(): {"smartlockId":447733957,"accountId":241889230,"type":0,"authId":3431665,"name":"Eingangstür","favorite":false,"config":{"name":"Eingangstür","latitude":48.28686,"longitude":16.107248,"
                  nuki2.0	2019-09-15 08:34:24.156	debug	Action applied on Bridge API.
                  nuki2.0	2019-09-15 08:34:24.156	info	Triggered action -LOCK- on Nuki Eingangstür.
                  Aufgefallen ist mir bei Deinem Adapter, dass über den callback die Werte relativ schnell zurückkommen (ca. 10 Sek), wenn ich zum Beispiel nach dem Zustand "lockstate" in meinem Skript prüfe so bekomme ich dann z.B.: den Zustand locked zurück, darf aber trotzdem über "action" noch nicht den Zustand unlock herbei führen da ich sonst wieder einen http 503 bekomme....man muss nochmal ca. 10 Sek. warten.
                  Beim Adapter von smaragdschlange dauert der callback länger (ca. 20 Sek.), wenn die Werte sich ändern kann man dann auch unmittelbar danach auch ein command absetzen.
                  Bei deinem Adapter bewirkt das zu schnelle drücken hintereinander dann auch manchmal, dass der Zustand des locks über den callback nicht geändert wird. Der steht dann der "lockstate" auf lock anstatt unlock und das kann man scheinbar nur durch ein stoppen und neustarten des Adapters wieder bereinigt werden.
                  Warum ist das alles ein Problem? Man schließt ja nicht dauern ab und gleich wieder auf etc.
                  Ich möchte mit iobroker in Verbindung mit nuki auch andere Dinge steuern wie die Alarmanlage, Türklingel etc. und da ist das timing schon wichtig. Und wenn man mal unabsichtlich (und ich hab auch kleine Kinder :-)
                  ) und eventuell kurz hintereinander eine Taste auf der Fernsteuerung drückt sollte sich die sch*** Bridge nicht aufhängen.
                  ZefauZ Offline
                  ZefauZ Offline
                  Zefau
                  @Sandmanyz
                  Ich habe übrigens keine Problem, nutze aber auch eine Software Bridge (bzw. Android Bridge App), siehe https://nuki.io/de/hilfe/bridge-de/android-bridge-app/android-bridge-app/.
                  Die Hardware der Nuki Bridge scheint einfach schlecht zu sein und mit vielen Abfragen nicht klarzukommen.
                  Leider unterstützt die Software Bridge den Nuki Opener nicht.
                  • ZefauZ Offline
                    ZefauZ Offline
                    Zefau
                    schrieb am zuletzt editiert von Zefau
                    ich entwickle gerade an einer Version v2.0.0, die verschiedene Verbesserung sowie den Support für den Nuki Opener mitbringt und suche noch Tester.
                    Installation
                    Alle Interessierten können den Adapter gerne installieren, siehe auch https://github.com/Zefau/ioBroker.nuki2/issues/18#issuecomment-533825482
                    Im Ordner /opt/iobroker:
                    npm i https://github.com/Zefau/ioBroker.nuki2.git#nuki-extended
                    danach
                    iobroker add nuki-extended
                    Features
                    • Support für den Nuki Opener
                    • Unterstützung des hashed token (siehe https://developer.nuki.io/page/nuki-bridge-http-api-190/4#heading--token)
                    • Nuki Web API wird nun als Fallback genutzt, sofern die Nuki Bridge API den Befehl nicht verarbeitet, z. B. aufgrund der Nichterreichbarkeit der Bridge (siehe https://forum.iobroker.net/post/300982 bzw. https://developer.nuki.io/t/random-http-503-unavailable/909/85?u=zefau)
                    • Sofern keine Nuki Web API genutzt wird, werden Befehle an die Bridge bei einem Fehler erneut geschickt
                    • Option für regelmäßige Synchronisierung hinzugefügt (Alternative zum Callback)
                    • Aktualisierung aller States über die Nuki Web API, wenn ein Callback über die Nuki Bridge API empfangen wurde
                    • Nuki Notifications (Benachrichtigungen) werden ausgelesen
                    Hinweise
                    Der Adapter Nuki2 wird mit dem Release v2.0.0 in nuki-extended umbenannt. Insofern wird mit der oben beschriebenen Installation ein neuer Adapter installiert. Der Nuki2 Adapter bleibt unverändert erhalten (nichts wird kaputt gemacht).
                    Die Objekte sind im Vergleich zur alten Version v1.0.4 neu strukturiert bzw. gruppiert.
                    Roadmap
                    https://github.com/Zefau/ioBroker.nuki2/projects/1
                    ? S 2 Antworten Letzte Antwort
                    • ZefauZ Zefau
                      Installation
                      danach
                      Features
                      Hinweise
                      Roadmap
                      @Zefau Guten Morgen, tolle Arbeit, vielen Dank!
                      Ich benutze seit beginn den Adapter von Smaragdschlange, läuft hier einwandfrei, bzw hatte ich damals selbst ein Javascript geschrieben, das die Lockstates abfragte und als objekte in iobroker anlegte. :-)
                      Allerdings hab ich natürlich auch das Problem, dass die Bridge ab und an mal nicht hinterher kommt .. aber recht selten.
                      Habe jetzt den nuki-extended installiert, hatte beim holen von git aber probleme mit den rechten von npm unter meinem normalen account, da meine iobroker installation schon sehr alt ist.. wurde durch die alten Versionen die Rechte vermurkst.. auch der Fixer hilft da nicht immer.. und auch ein
                      sudo chown -R 1000:1000 /home/ilovegym/.npm
                      half nicht..
                      Dafür der Adapter aber einwandfrei, bis jetzt, verwende darin die WebApi und die Bridge. Ich habe noch das allererste Nuki. Türkontakte etc mach ich alles über xiaomi.
                      iobroker läuft auf Linux Mint 18.3 in ner VM unter Proxmox. JS-Controller 1.5.14, Node 10.16.3, NPM 6.11.2.
                      ps: hab auch mal auf den PP Button gedrückt, gibts Dich auch bei Patreon.com ? :-)
                      • ZefauZ Zefau
                        Installation
                        danach
                        Features
                        Hinweise
                        Roadmap
                        Sandmanyz
                        @Zefau
                        Ich habe gerade mal mein Glück versucht. So richtig erfolgreich war ich nicht. Was durchaus an mir liegen kann. Es taucht kein neuer Adapter auf.
                        npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
                        npm notice created a lockfile as package-lock.json. You should commit this file.
                        npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                        npm WARN root No description
                        npm WARN root No repository field.
                        npm WARN root No README data
                        npm WARN root No license field.
                        + iobroker.nuki-extended@2.0.0
                        added 109 packages from 137 contributors and audited 541 packages in 17.291s
                        found 0 vulnerabilities
                        host.raspberrypi Unknown packetName nuki-extended
                        • S Sandmanyz
                          @Zefau
                          ZefauZ Offline
                          ZefauZ Offline
                          Zefau
                          #66
                          @Sandmanyz sorry, bitte im Ordner von ioBroker ausführen (/opt/iobroker).
                          • cashC Offline
                            cashC Offline
                            cash
                            #67
                            Muss ich auch testen sofern ich den Opener installiert kriege (sollte Montag kommen).
                            Aber mal zwei anderen Fragen zu dem alten Adapter. Zum einen habe ich heute einen neuen Benutzer eingerichtet der auch schon einmal erfolgreich die Tür geöffnet habe. Das ganze kann ich auch auf der Adapter Webseite (Protokoll) sehen. Aber der Benutzer taucht nicht in den Objekten auf? Für mich und meine Frau gibt es extra Punkte unter den Objekt users. Wo könnte das Problem liegen. Synronisation steht auf 60 Sekunden. Callback ist auch eingerichtet?
                            Die andere Frage: Wie kann ich mittels Script ermitteln welcher Benutzer die Tür geöffnet hat? Ich würde gerne das wenn der heute angelegte Benutzer die Tür öffnet das ich dann ein paar bestimmte Lampen einschalte, Alarmanlage ausgeschaltet wird usw. Der Benutzer ist unser Haussitter wenn wir im Urlaub sind...
                            • cashC Offline
                              cashC Offline
                              cash
                              #68
                              Habe nun doch mal eben den nuki-extended Adapter installiert. Aber auch hier taucht der Benutzer nicht bei den Usern auf? Nur meine Frau, ich und nuki_web...
                              • cashC Offline
                                cashC Offline
                                cash
                                schrieb am zuletzt editiert von cash
                                #69
                                Im Log erscheint bei mir immer:
                                	getWebApi(): Error retrieving smartlocks: Cannot read property 'replace' of null
                                Habe den gleichen Token wie beim alten Adapter eingetragen. Der alte Adapter ist deaktiviert.
                                • cashC cash
                                  ZefauZ Offline
                                  ZefauZ Offline
                                  Zefau
                                  #70
                                  @cash sagte in [Neuer Adapter] Nuki:
                                  Erscheint der Benutzer auf der Nuki Web Seite unter https://web.nuki.io/de/#/admin/users ?
                                  cashC 1 Antwort Letzte Antwort
                                  • ZefauZ Zefau
                                    cashC Offline
                                    cashC Offline
                                    cash
                                    #71
                                    @Zefau Komisch. Dort ist er auch nicht. Habe dem Benutzer nicht erlaubt aus der Ferne zu öffen. In der App ist er aber unter Benutzer zu finden.
                                    • cashC cash
                                      ZefauZ Offline
                                      ZefauZ Offline
                                      Zefau
                                      #72
                                      Der Callback selbst liefert diese Daten nicht. Mit der Nuki Web API bekommst du aber alle Events in den log State geschrieben. Den kannst du per Skript auswerten.
                                      • cashC Offline
                                        cashC Offline
                                        cash
                                        #73
                                        @Zefau hast Du dazu schon eine Idee wo mein Problem sein könnte?
                                        Das Log bevor der Fehler immer und immer wieder kommt sieht erstmal ok aus:
                                        nuki-extended.0	2019-09-29 09:37:21.624	info	Listening for Nuki events on port 51988.
                                        nuki-extended.0	2019-09-29 09:37:20.036	info	Polling Nuki Web API with a frequency of 60s.
                                        nuki-extended.0	2019-09-29 09:37:19.812	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v8.14.0
                                        host.iobroker_v2_19-05-19	2019-09-29 09:37:16.087	info	instance system.adapter.nuki-extended.0 started with pid 3008
                                        host.iobroker_v2_19-05-19	2019-09-29 09:37:15.852	info	"system.adapter.nuki-extended.0" enabled
                                        Ein Problem habe ich auch mit einen Javascript:
                                        var logging = true;
                                        var debugging = false;
                                        var Dauer = 1;      //nach x Minuten kommt eine Push das die Tür offen steht
                                        var timer = null;
                                        //var id_Status = 'nuki-extended.0.smartlocks.wohnungstür.state.closed'/*Indication if door is closed (boolean of doorState)*/
                                        var id_Status = 'nuki2.0.door__wohnungstür.status.closed'/*Indication if door is closed (boolean of doorState)*/;
                                        var sendpush = true;
                                        function func_Nuki(){
                                           var Status = getState(id_Status).val;
                                           if(!Status){
                                               if(logging){
                                                   log('Die Wohnungstür ist offen. Starte Timer für '+Dauer +' Minuten');
                                           else{
                                               if(logging){
                                                   log('Die Wohnungstür ist geschlossen.');
                                        on({id: id_Status, val: false, ack: true}, func_Nuki);
                                        Das Script soll einfach nur Testweise eine Push schicken wenn die Tür offen ist. Deshalb val: false.
                                        Das gleiche Script nutze ich relativ häufig bei verschiedenen Adaptern. Aber hier reagiert es einfach nicht. Lasse ich das val: false komplett weg. Funktioniert das Script und reagiert entsprechend auf die Statusänderung. Als ob der Wert von den Objekt kein booelan wäre. Laut Objekt RAW ist es aber natürlich ein boolean.
                                        In der Endfassung soll das Script mich informieren wenn die Tür nach x Minuten immer noch offen steht.
                                        ZefauZ 2 Antworten Letzte Antwort
                                        • cashC cash
                                          var logging = true;
                                          var timer = null;
                                             if(!Status){
                                                 if(logging){
                                             else{
                                                 if(logging){
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #74
                                          @cash bzgl. des Fehlers installier mal bitte die aktuelle Entwickler-Version von Github drüber (siehe https://forum.iobroker.net/post/304268). Hoffe, dass es damit behoben ist.
