  4. [gelöst] Feld mit wechselnder Farbe durch Ereignis
    5.1k
vis
38 Beiträge 7 Kommentatoren 4.4k Aufrufe 5 Beobachtet
    @Linguistix nein kein direktes widget, es ist eine definition in einem Widget, auch Link Text noch was zum nachlesen
    alternativ kannst du auch bei einem html so eintragen
    oder sowas z.b.
    [{"tpl":"tplJquiButtonState","data":{"oid":"","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":true,"buttontext":"{wert:ping.0.IoBroker.192_168_178_32; wert !=\"true\" ? \"<div style='color:red'>GalaxyS8 nicht erreichbar!</div>\" :: \"GalaxyS8 erreichbar\"}","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"timestamp","lc-is-interval":false,"lc-is-moment":false,"lc-format":"DD.MM.YYYY hh:mm:ss","lc-position-vert":"middle","lc-position-horz":"right","lc-offset-vert":"0","lc-offset-horz":"0","lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"trans","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":"10","lc-zindex":0,"value":"","name":"!_info_Update-Button","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","no_style":false,"lc-oid":"ping.0.IoBroker.192_168_178_32"},"style":{"left":"60px","top":"30px","width":"300px","height":"30px","z-index":"3","border-width":"2px","border-radius":"10px","box-shadow":"8px 8px 8px rgba(20, 20, 20, 50)","border-color":"#505253","border-style":"solid"},"widgetSet":"jqui"}]
    sieht dann so aus
    Linguistix
    @crunchip alles klar den werde ich das heute Abend mal Probieren
    Gruß René
    • IoBroker auf Windows 10 (Testsystem)
    • IoBroker auf Intel Nuc i3 (Produktivsystem)
    • Homematic IP
    • Rolladenaktor Broll
    • Tür Sensoren
    • Samsung TAB A als Anzeige
    • L Offline
      Linguistix
      Also entweder bin ich Blind oder ich finde es nicht kann die Felder nicht finden mit dem False HTML und True HTML :(
      Gruß René
      • Homematic IP
      • Tür Sensoren
      • L Linguistix
        crunchipC Abwesend
        crunchipC Abwesend
        @Linguistix ein widget boolen html
        L 1 Antwort Letzte Antwort
        • L Offline
          Linguistix
          Ich hab ein normales html widget genommen. Kann da aber nix finden.
          Gruß René
          • Homematic IP
          • Tür Sensoren
          • bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            widget: valuelist html style
            und dann:
            ergibt in vis:
            Oder das was arteck schreibt: bindings benutzen.
            Danke.
              Linguistix
              schrieb am zuletzt editiert von Linguistix
              @crunchip jetzt hab ich verstanden das bool widget hab ich genommen Werte habe ich eingetragen. Die Anzeige sollt sich quasi ändern. Ich werde es ja gleich sehen.
              Gruß René
              • Homematic IP
              • Tür Sensoren
              • L Offline
                Linguistix
                Also das Widget hab ich soweit auch alle Werte eingetragen jedoch wechselt die Schrift bei geschlossen die Farbe noch nicht. An was könnte es noch liegen? Im Tankerkönig nehme ich die Zeile wo open und closed steht für die Objekt ID oder?
                Gruß René
                • Homematic IP
                • Tür Sensoren
                sigi234S crunchipC 2 Antworten Letzte Antwort
                • L Linguistix
                  sigi234S Online
                  sigi234S Online
                  @Linguistix
                  Ist die Tankstelle auch geschlossen?
                  • sigi234S sigi234
                    @Linguistix
                    Linguistix
                    @sigi234 japp seit 21 uhr. Steht so jetzt auch drinnen, closed.
                    Gruß René
                    • Homematic IP
                    • Tür Sensoren
                    • L Linguistix
                      sigi234S Online
                      sigi234S Online
                      @Linguistix sagte in Feld mit wechselnder Farbe durch Ereignis:
                      Was für ein Widget hast du genommen? Lade es mal hoch.
                      Wie schaut der DP genau aus, welche Werte bekommst du?
                      • sigi234S sigi234
                        Linguistix
                        @sigi234 Als Widget habe ich das Bool Html genommen.
                        Was meinst du mit DP bin noch nicht so firm mit den Kürzeln.
                        Gruß René
                        • Homematic IP
                        • Tür Sensoren
                        • L Linguistix
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @Linguistix
                          Auf wieviel Minuten hast du den Cronjob eingestellt wann der Adapter die Daten holt ?
                          • L Linguistix
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @Linguistix hab bei mir mal nachgesehen, ist schon ewig her als ich das eingerichtet hatte.
                            es sind bei mir zwei widget übereinander gelegt, damit es farblich richtig angezeigt wird , mit open/closed
                            aber wie gesagt, es geht auch in einem widget, mit bindings, siehe oben, oder wie Bahnuhr schrieb, mit dem html valuelist.
                            Es gibt mehrere Möglichkeiten, musst du entscheiden, mit was du dir leichter tust bzw besser zurecht kommst.
                            das ist ein beispiel mit zwei übereinander gelegten widget´s
                            [{"tpl":"tplValueBool","data":{"oid":"tankerkoenig.0.stations.3.status","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"closed","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_true":"<font color=\"#cc0000\">closed","html_false":"","visibility-oid":"tankerkoenig.0.stations.3.status"},"style":{"left":"294px","top":"62px","width":"70px","height":"20px","text-align":"center","font-family":"RobotoCondensed-Regular"},"widgetSet":"basic"},{"tpl":"tplValueBool","data":{"oid":"tankerkoenig.0.stations.3.status","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"open","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_true":"<font color=\"#00cc00\">open","html_false":"<font color=\"#cc0000\">closed","visibility-oid":"tankerkoenig.0.stations.3.status"},"style":{"left":"294px","top":"62px","width":"70px","height":"20px","text-align":"center","font-family":"RobotoCondensed-Regular"},"widgetSet":"basic"}]
                              Linguistix
                              @crunchip in welcher Zeile hast du den Code eingetragen? Kommt der bei HTML True rein?
                              Gruß René
                              • Homematic IP
                              • Tür Sensoren
                              • L Offline
                                Linguistix
                                Ich habe mich an das ValueList HTML Style gesetzt. Die Werte habe ich wie folgt eingetragen:
                                wenn ich diese bei Testwert ändere funktioniert es soweit.
                                wenn ich jetzt aber jedoch den Testwert rausnehme und die Vis starte zeigt es mir nix mehr an.
                                Bei Objekt ID habe ich die Zeile Status genommen:
                                Muss ich jetzt noch etwas eintragen das es mir dies auch in der Vis anzeigt?
                                Gruß René
                                • Homematic IP
                                • Tür Sensoren
                                sigi234S bahnuhrB 3 Antworten Letzte Antwort
                                • L Linguistix
                                  sigi234S Online
                                  sigi234S Online
                                  @Linguistix
                                  Exportiere das Widget mal und ich teste es bei mir.
                                  Homer.J.H 1 Antwort Letzte Antwort
                                  • L Linguistix
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    Liegt vermutlich daran, dass nicht 0 oder 1 übermittelt wird.
                                    Folgendes funktioniert.
                                    widget: basic string
                                    Bei background color folgendes eintragen (binding):
                                    {v:tankerkoenig.0.stations.0.status;(v=="open") ? "green": "red"}
                                    anbei widget:
                                    [{"tpl":"tplValueString","data":{"oid":"tankerkoenig.0.stations.0.status","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"776px","top":"577px","width":"114px","height":"20px","color":"white","background":"","background-color":"{v:tankerkoenig.0.stations.0.status;(v==\"open\") ? \"green\": \"red\"}"},"widgetSet":"basic"}]
                                    Dann klappt es !
                                    mfg
                                    Danke.
                                    sigi234S L 2 Antworten Letzte Antwort
                                    • L Linguistix
                                      sigi234S Online
                                      sigi234S Online
                                      Nimm mal das und leg es übereinander:Objekt ID anpassen!
                                      [{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"closed","visibility-oid":"tankerkoenig.0.stations.1.status","html_prepend":"geschlossen","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"777px","top":"685px","width":"180px","height":"24px","color":"white","text-align":"center","font-size":"18px","background":"red","padding-right":"","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"","visibility-cond":"==","visibility-val":"open","visibility-oid":"tankerkoenig.0.stations.1.status","html_prepend":"geöffnet","html_append":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"777px","top":"716px","width":"180px","height":"24px","color":"rgb(68, 68, 68)","text-align":"center","font-size":"18px","background":"rgb(0, 255, 0)","padding-right":"","z-index":"5"},"widgetSet":"basic"}]
                                      • bahnuhrB bahnuhr
                                        anbei widget:
                                        Dann klappt es !
                                        mfg
                                        sigi234S Online
                                        sigi234S Online
                                        @bahnuhr sagte in Feld mit wechselnder Farbe durch Ereignis:
                                        Ja, denke ich auch, da der Wert open oder closed ist. Wäre gut wenn es einen DP gibt : Tankstelle geöffnet true oder false
                                        • L Offline
                                          Linguistix
                                          @bahnuhr
                                          Puh schwere Geburt aber echt danke für eure Mühe und Hilfe,
                                          die Codes sind Widges die ich importieren kann wenn ich das jetzt richtig verstanden habe. Ist halt alles noch relative neu für mich.
                                          Das es an der Objekt ID liegt hab ich mir irgendwie gedacht da es ja so funktioniert mit dem Test. ich werde es heute abend mal daheim Ausprobieren.
                                          Gruß René
                                          • Homematic IP
                                          • Tür Sensoren
