  5. Wieder mal ne ganz einfache frage
    5.6k
blockly
19 Beiträge 5 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • dslraserD dslraser
    @freaktech
    vielleicht geht es auch einfacher, aber so vielleicht.
    Vorschlag:
     <variables>
       <variable type="" id="1c+CmVxs~Q*g{UTCsbQ3">30minutensperre</variable>
       <variable type="undefined" id="timeout">timeout</variable>
     </variables>
     <block type="variables_set" id="hod__D;JILc[fYGnaC47" x="-212" y="-438">
       <field name="VAR" id="1c+CmVxs~Q*g{UTCsbQ3" variabletype="">30minutensperre</field>
       <value name="VALUE">
         <block type="math_number" id="szxU01PbbTwlL=z8viPF">
           <field name="NUM">0</field>
         </block>
       </value>
       <next>
         <block type="on" id="#OK]W*,szc^DPTq-1cK^">
           <field name="OID">hm-rpc.0.xxx.1.PRESENCE_DETECTION_STATE</field>
           <field name="CONDITION">true</field>
           <statement name="STATEMENT">
             <block type="controls_if" id="b|psAqq^u7jI.~_l$6]R">
               <value name="IF0">
                 <block type="logic_compare" id="1BH[PlV7lc2H?09$(hoU">
                   <field name="OP">EQ</field>
                   <value name="A">
                     <block type="variables_get" id="%Phj$LaXf93tfP_D%l{B">
                     </block>
                   </value>
                   <value name="B">
                     <block type="math_number" id="qyN[?(TaOmBNG|5mhEvt">
                     </block>
                   </value>
                 </block>
               </value>
               <statement name="DO0">
                 <block type="math_change" id="-TKGA?(d+I_wK|7wp`v#">
                   <value name="DELTA">
                     <shadow type="math_number" id="TnzQ/trR7J=CKTqaF.[I">
                       <field name="NUM">1</field>
                     </shadow>
                     <block type="math_number" id="^ES`cXDPiJUeY|Q|4`ve">
                     </block>
                   </value>
                   <next>
                     <block type="request" id="j8*Tr]9P{.zqpV1rjzgJ">
                       <mutation with_statement="false"></mutation>
                       <field name="WITH_STATEMENT">FALSE</field>
                       <field name="LOG"></field>
                       <value name="URL">
                         <shadow type="text" id="n,Li=IwpN0apU]OiS:qb">
                           <field name="TEXT">http://10.0.0.62:2323/?cmd=restartApp&amp;password=0000</field>
                         </shadow>
                       </value>
                       <next>
                         <block type="timeouts_settimeout" id="I0qh3=nsM}=SP7W*e95_">
                           <field name="DELAY">30</field>
                           <field name="UNIT">min</field>
                             <block type="variables_set" id="TX[f{R!=%q1eBiBWfzEF">
                                 <block type="math_number" id="#3?ee+9esVl1LLG9Hq!0">
                                 </block>
                               </value>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    Was ich nicht ganz verstehe, soll einfach alle 30 Minuten gesendet werden, oder bei Bewegung max. einmal in 30 Minuten ?
    freaktech
    @dslraser
    danke ich probier es mal
    udn wie würde ein selbständiges senden alle 30 min aussehen?
    • F freaktech
      @dslraser
      dslraserD Offline
      dslraserD Offline
      dslraser
      @freaktech sagte in Wieder mal ne ganz einfache frage:
      @dslraser
      <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="0CdjUM+lp{]s!WKlB`oY" x="-187.06545257568376" y="-12.855085031925114">
       <field name="SCHEDULE">0,30 * * * *</field>
         <block type="request" id="(fwpk4)Gr~S4|w`w.Bcg">
           <value name="URL">
             <shadow type="text" id="gzlS#Aa#glj$Zs^q*Cib">
             </shadow>
           </value>
         </block>
       </statement>
      </block>
      • F Offline
        freaktech
        ich finde im Blocky das setze auf ganz oben nicht ?!?
        • F freaktech
          dslraserD Offline
          dslraserD Offline
          dslraser
          @freaktech
          unter Variablen selbst erstellen, oder mein Blockly importieren.
          F 1 Antwort Letzte Antwort
            @freaktech
            freaktech
            @dslraser
            ah hast ja eh angehängt, danke werde beides nach der Arbeit testen :-) und berichten
            freu
            • F Offline
              freaktech
              muss ich diese 30 min sperre noch wo anlegen?
              unter java objekte oder so?
              oder nur das Skript einfügen und starten?
              • F freaktech
                dslraserD Offline
                dslraserD Offline
                dslraser
                @freaktech
                das hatte ich oben gefragt...?
                Was möchtest Du ?
                • F Offline
                  freaktech
                  schrieb am zuletzt editiert von freaktech
                  ich brauch 2 Sachen!
                  A: sende einfach dumm alle 30 min ein Kommando
                  B: sende bei Ereignis ein Kommando
                  aber falls es innerhalb der 30 minuten wieder auslöst nicht
                  nur falls nach 30 min wieder eine bewegung erkannt wird wieder einmal dann
                  ist die 30minuten variable nicht dann als datenpunkt unter java objekte zu sehen?!? oder ist das nur intern im script
                  versteh ich nicht ganz was er mit dieser variablen macht
                  die fragt er ja ab also müsste die doch auch wo gespeichert werden?
                  AsgothianA dslraserD 2 Antworten Letzte Antwort
                  • F freaktech
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    Es ist eine Variable innerhalb des scripts, sprich der Wert existiert nur solange das Script läuft und kann nicht von außerhalb des scripted eingesehen werden.
                    Das bedeutet das das erste Ereignis nach starten des scriptes die url immer aufgerufen wird.
                    A.
                    • F Offline
                      freaktech
                      danke, dann versteh ich das.
                      Also Code A:
                      der Bewegungsmelder löst aus
                      Commando wird gesendet
                      und egal wie oft er wieder auslöst
                      30 min lang wird nichts gesendet
                      ich will hier einen screen für 40 min einschalten
                      dann schlägt dort ein screensaver zu
                      mal schaun nachmittag ob das so klappt
                      danke
                      und dieser sendet einfach alle 30 min 1 x den code
                      ich will alle 30 min etwas refreshen lassen
                      • F freaktech
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        @freaktech
                        Außerhalb des Triggers, ganz oben, wird die Variable auf 0 gesetzt (einmalig beim Scriptstart). Dann wird im Trigger geschaut ob der BWM wahr wird. Wenn er wahr wird und die Variable 0 ist, dann wird die Variable auf 1 gesetzt und der Schaltvorgang, oder was auch immer, ausgelöst. Wenn dann der Trigger wieder wahr wird und die Zeit noch nicht abgelaufen ist, dann ist die Variable immer noch ungleich 0 und es wird nicht geschaltet. Nach 30 Minuten (eingestellte Zeit im Timeout) wird die Variable wieder auf 0 gesetzt, somit kann beim nächsten wahr werden des BWM (Trigger) wieder geschaltet werden und das Spiel beginnt von vorn.
                        Die Variable kannst Du nennen wie Du willst, die könnte auch Bockwurst heißen.
                        Das soll nur die Erklärung für das Blockly sein, das ist dann aber noch nicht genau das was Du haben willst. (da hast Du jetzt Deine Anfrage konkretisiert)
                        Ich bin jetzt aber nicht mehr am Rechner...
                          @freaktech
                          freaktech
                          @dslraser
                          du verwirrst mich gerade
                          hast du nicht gerade diese Funktion beschrieben?
                          • F freaktech
                            @dslraser
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            @dslraser
                            Was verwirrt Dich denn ?
                            Genau das habe ich oben geschrieben...
                              @dslraser
                              freaktech
                              @dslraser
                              und für das einfach ealle 30 minuten ohne eregnis senden
                              dieses
                              weil du geschrieben hast, du hattest was falsch versteanden von der Funktionen ?!??
                              • F freaktech
                                Also Code A:
                                danke
                                @freaktech sagte:
                                Der Screensaver soll also nie aktiv werden (30 Minuten Refresh) ? Oder gibt es eine Bedingung, unter der er aktiv werden soll ?
                                  @freaktech sagte:
                                  freaktech
                                  ich hab das Problem dass mein tablet manchmal nicht aufwacht.
                                  dieser Fullybrowser läuft einfach nicht sauber auf dem aktuellem galayxy tab 10a
                                  somit will ich die Fullkiosk APP einmal alle alle 30 min restarten lassen
                                  dafür das Script dass egal was passiert eine restart macht.
                                  das andere script soll den screen einschalten
                                  aber nur 1 x pro 30 min bei bewegung (es bleibt dann für 35 min an)
                                  leider läuft dieser fullybrowser bei mir instabil
                                  er wacht einfach irgendwann nur noch halb auf
                                  man merkt er reagiert ladet aber die url nicht
                                  • F freaktech
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @freaktech wie ist denn der Abfrageintervall im Adapter selbst? Vllt passt da etwas nicht.
                                    120000ms sind bei mir eingestellt.
                                    Vllt noch in den Einstellungen...cache löschen aktivieren.
