  4. [Vorlage] Variable Zeitsteuerung mit VIS Editor
    6.6k
vistemplate
919 Beiträge 47 Kommentatoren 344.3k Aufrufe 75 Beobachtet
  • sigi234S sigi234
    Keine Ahnung ich bekomme es einfach nicht hin.
    Licht schaltet einfach nicht.
    9.9.2019, 21:35:49.681	[warn ]: javascript.0     at script.js.Sigi.Timer_1:197:39
    9.9.2019, 21:35:49.681	[warn ]: javascript.0     at compareCond (script.js.Sigi.Timer_1:196:32)
    9.9.2019, 21:35:49.681	[warn ]: javascript.0     at Object.<anonymous> (script.js.Sigi.Timer_1:467:5)
    9.9.2019, 21:35:54.697	[warn ]: javascript.0     at script.js.Sigi.Timer_1:197:39
    9.9.2019, 21:35:54.697	[warn ]: javascript.0     at compareCond (script.js.Sigi.Timer_1:196:32)
    9.9.2019, 21:35:54.697	[warn ]: javascript.0     at Object.<anonymous> (script.js.Sigi.Timer_1:467:5)
    9.9.2019, 21:35:59.701	[warn ]: javascript.0     at script.js.Sigi.Timer_1:197:39
    9.9.2019, 21:35:59.701	[warn ]: javascript.0     at compareCond (script.js.Sigi.Timer_1:196:32)
    9.9.2019, 21:35:59.701	[warn ]: javascript.0     at Object.<anonymous> (script.js.Sigi.Timer_1:467:5)
    9.9.2019, 21:36:04.703	[warn ]: javascript.0     at script.js.Sigi.Timer_1:197:39
    9.9.2019, 21:36:04.703	[warn ]: javascript.0     at compareCond (script.js.Sigi.Timer_1:196:32)
    9.9.2019, 21:36:04.703	[warn ]: javascript.0     at Object.<anonymous> (script.js.Sigi.Timer_1:467:5)
    9.9.2019, 21:36:09.709	[warn ]: javascript.0     at script.js.Sigi.Timer_1:197:39
    9.9.2019, 21:36:09.709	[warn ]: javascript.0     at compareCond (script.js.Sigi.Timer_1:196:32)
    9.9.2019, 21:36:09.709	[warn ]: javascript.0     at Object.<anonymous> (script.js.Sigi.Timer_1:467:5)
    9.9.2019, 21:36:14.710	[warn ]: javascript.0     at script.js.Sigi.Timer_1:197:39
    9.9.2019, 21:36:14.710	[warn ]: javascript.0     at compareCond (script.js.Sigi.Timer_1:196:32)
    9.9.2019, 21:36:14.710	[warn ]: javascript.0     at Object.<anonymous> (script.js.Sigi.Timer_1:467:5)
    9.9.2019, 21:36:19.715	[warn ]: javascript.0     at script.js.Sigi.Timer_1:197:39
    9.9.2019, 21:36:19.715	[warn ]: javascript.0     at compareCond (script.js.Sigi.Timer_1:196:32)
    9.9.2019, 21:36:19.715	[warn ]: javascript.0     at Object.<anonymous> (script.js.Sigi.Timer_1:467:5)
    9.9.2019, 21:36:20.732	[info ]: javascript.0 Stop script script.js.Sigi.Timer_1
    9.9.2019, 21:36:20.746	[info ]: javascript.0 Start javascript script.js.Sigi.Timer_1
    9.9.2019, 21:36:20.746	[info ]: javascript.0 script.js.Sigi.Timer_1: registered 20 subscriptions and 3 schedules
    9.9.2019, 21:36:21.248	[error]: javascript.0     at createConditionsJSON (script.js.Sigi.Timer_1:176:55)
    9.9.2019, 21:36:21.248	[error]: javascript.0     at Object.main (script.js.Sigi.Timer_1:984:5)
    9.9.2019, 21:36:24.716	[warn ]: javascript.0     at script.js.Sigi.Timer_1:197:39
    9.9.2019, 21:36:24.716	[warn ]: javascript.0     at compareCond (script.js.Sigi.Timer_1:196:32)
    9.9.2019, 21:36:24.716	[warn ]: javascript.0     at Object.<anonymous> (script.js.Sigi.Timer_1:467:5)
    GiuseppeS
    #229
    @sigi234
    Falls Du den Haupt-Pfad des Skripts nicht geändert hast, bitte lade die Inhalte folgender Objekte hoch (direkt als code oder txt-Anhang):
    • javascript.0.Timer.Devices.ConditionJSON
    • javascript.0.Timer.Devices.TimerJSON
    Sind in der Aufzählung für die Bedingungen wirklich nur States oder doch Channels? Nur States sind zulässig.
    • G GiuseppeS
      @sigi234
      sigi234S Online
      sigi234S Online
      #230
      @GiuseppeS sagte in [Vorlage] Variable Zeitsteuerung mit VIS Editor:
      @sigi234
      javascript.0.Timer.Devices.TimerJSON.json
      javascript.0.Timer.Devices.ConditionJSON.json
      // Nachfolgende Einträge zwingend anpassen:
      // Eine Aufzählung für Geräte (z.B. Rollläden) angeben:
      var deviceEnum = "enum.functions.Licht";
      // Eine Aufzählung für States der Bedingungen:
      var deviceCond = "enum.functions.timerconditions";
      // Widget-Nummer für Widget "Timer bearbeiten" (View in Dialog)
      var DlgWidget = 'w00311'
      G 1 Antwort Letzte Antwort
      • sigi234S sigi234
        @sigi234
        GiuseppeS
        #231
        @sigi234
        Sorry, hatte mich nicht genau ausgedrückt. Ich hätte gern die Inhalte aus den rechts gelb markierten Bereichen:
        Aber vorab: Wann bekommst Du die Fehler? Direkt immer nach Neustart eins unveränderten Skripts? Als Du alles neu importiert hattest und die Konfiguration im Skript oben bzgl. der Aufzählungen durchgeführt hattest, kamen danach nach 2-3 Neustarts schon diese Fehler oder erst nachdem Du innerhalb der Timer in der VIS die Bedingungen verändert hast?
        GlasfaserG sigi234S 2 Antworten Letzte Antwort
        • G GiuseppeS
          @sigi234
          GlasfaserG Offline
          GlasfaserG Offline
          #232
          @GiuseppeS
          In Timerconditions sind die Aktoren drin !!!!!!!!!!! Das sind doch nicht die Bedingungen ??
          • GlasfaserG Glasfaser
            @GiuseppeS
            GiuseppeS
            #233
            @Glasfaser
            Schon, aber die kann er auch als Bedingungen verwenden... Habe z.B. meine Rollladen Aktoren auch als Bedingungen drin. Weil Soll und Ist Positionen in einem State stehen.
            @sigi234
            Ist das so gewollt?
            • G GiuseppeS
              @sigi234
              sigi234S Online
              sigi234S Online
              #234
              @sigi234
              {"Licht_Vorraum:1.STATE":{"ID":"hm-rpc.1.OEQ0473764.1.STATE","Val":true,"Changed":false},"Philips_hue.Hue_lightstrip_Küche.on":{"ID":"hue.0.Philips_hue.Hue_lightstrip_Küche.on","Val":true,"Changed":true}}
              {"Licht_Vorraum:1":{"1":{"ObjID":"hm-rpc.1.OEQ0473764.1","DeviceNr":0,"Aktiv":false,"Zeit":"10:00","Std":"10","Min":"00","Sollwert":"100","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 10 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsNr":"0","ConditionsTrue":true,"Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true},"2":{"ObjID":"hm-rpc.1.OEQ0473764.1","DeviceNr":0,"Aktiv":false,"Zeit":"19:00","Std":"19","Min":"00","Sollwert":"0","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 19 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsTrue":true,"ConditionsNr":"0","Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true}},"Steckdose Stehlampe":{"1":{"ObjID":"tuya.0.07200471bcddc28298e0","DeviceNr":2,"Aktiv":false,"Zeit":"10:00","Std":"10","Min":"00","Sollwert":"100","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 10 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsNr":"0","ConditionsTrue":true,"Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true},"2":{"ObjID":"tuya.0.07200471bcddc28298e0","DeviceNr":2,"Aktiv":false,"Zeit":"19:00","Std":"19","Min":"00","Sollwert":"0","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 19 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsTrue":true,"ConditionsNr":"0","Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true}},"Philips_hue":{"1":{"ObjID":"hue.0.Philips_hue","DeviceNr":4,"Aktiv":false,"Zeit":"10:00","Std":"10","Min":"00","Sollwert":"100","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 10 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsNr":"0","ConditionsTrue":true,"Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true},"2":{"ObjID":"hue.0.Philips_hue","DeviceNr":4,"Aktiv":false,"Zeit":"19:00","Std":"19","Min":"00","Sollwert":"0","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 19 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsTrue":true,"ConditionsNr":"0","Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true}},"Stehlampe Wohnzimmer":{"1":{"ObjID":"meross.0.1811161726216929086534298f17edb7","DeviceNr":6,"Aktiv":false,"Zeit":"10:00","Std":"10","Min":"00","Sollwert":"100","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 10 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsNr":"0","ConditionsTrue":true,"Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true},"2":{"ObjID":"meross.0.1811161726216929086534298f17edb7","DeviceNr":6,"Aktiv":false,"Zeit":"19:00","Std":"19","Min":"00","Sollwert":"0","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 19 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsTrue":true,"ConditionsNr":"0","Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true}},"Lights":{"1":{"ObjID":"hue-extended.0.lights","DeviceNr":8,"Aktiv":false,"Zeit":"10:00","Std":"10","Min":"00","Sollwert":"100","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 10 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsNr":"0","ConditionsTrue":true,"Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true},"2":{"ObjID":"hue-extended.0.lights","DeviceNr":8,"Aktiv":false,"Zeit":"19:00","Std":"19","Min":"00","Sollwert":"0","TageVIS":"täglich","CronTage":"0,1,2,3,4,5,6","Cron":"0 19 * * 0,1,2,3,4,5,6","Astro":"manuell","Random":"0","RandPM":"pm","Offset":"0","OffsetPM":"m","ConditionsTrue":true,"ConditionsNr":"0","Conditions":{"1":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"2":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""},"3":{"ConditionStr":"","CondState":"","CondComp":"==","CondValue":""}},"Mo":true,"Di":true,"Mi":true,"Do":true,"Fr":true,"Sa":true,"So":true}}}
                @GiuseppeS
                sigi234S Online
                sigi234S Online
                #235
                @Glasfaser sagte in [Vorlage] Variable Zeitsteuerung mit VIS Editor:
                Was gehört dann da rein? Bitte mal einen Screenshot was Ihr drinnen habt.
                • sigi234S sigi234
                  @sigi234
                  GiuseppeS
                  #236
                  @sigi234
                  Gerade gesehen, dass keine Bedingungen in deinen Timern aktiv sind, ist das korrekt?
                  Sitze nicht mehr vor dem PC, kann also nicht genauer analysieren. Aber evtl liegt Es zahm den verwendeten Namen der Bedingungen. Versuche die bitte so zu ändern, dass keine Punkte in den Namen vorkommen.
                  • sigi234S sigi234
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #237
                    @sigi234
                    Das sind meine Bedingungen :
                    Das meine Rollladen im EG
                      @sigi234
                      sigi234S Online
                      sigi234S Online
                      #238
                      @Glasfaser
                      hm-rpc.1	2019-09-09 23:14:00.026	error	xmlrpc -> setValue: no dpType for hm-rpc.1.OEQ0473764.1!
                      javascript.0	2019-09-09 23:14:00.008	info	script.js.Sigi.Timer_1: Timer: Licht_Vorraum:1 (An)
                      javascript.0	2019-09-09 23:13:27.153	info	script.js.Sigi.Timer_1: Schedule "Licht_Vorraum:1 #1": 1 | 14 23 * * 0,1,2,3,4,5,6 | hm-rpc.1.OEQ0473764.1 | true
                      javascript.0	2019-09-09 23:13:27.153	info	script.js.Sigi.Timer_1: Schedule für "Licht_Vorraum:1 #1" erstellen:
                      • sigi234S sigi234
                        @Glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #239
                        @sigi234
                        Du musst ein State oder Level (je nach Aktor ) in die Aufzählung ziehen .
                          @sigi234
                          sigi234S Online
                          sigi234S Online
                          #240
                          @sigi234
                          Hab ich ja gemacht:
                          • sigi234S sigi234
                            @sigi234
                            Hab ich ja gemacht:
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #241
                            @sigi234
                            Nochmal :
                            in den Timerconditions gehören nur Bedingungen rein nichts zum schalten bzw. was du schalten willst .
                            Die Aktoren die du schalten willst gehören in :
                              @sigi234
                              Nochmal :
                              sigi234S Online
                              sigi234S Online
                              #242
                              @Glasfaser
                              Ich gebe auf.
                              • sigi234S sigi234
                                @Glasfaser
                                Ich gebe auf.
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #243
                                @sigi234
                                OK … ich weiß jetzt nicht warum … aber kein Problem ☺
                                  @sigi234
                                  GiuseppeS
                                  #244
                                  @sigi234
                                  Er gab auf weil die Grundlagen des ersten Post nicht beachtet wurden.
                                  Ich übrigens schon früher da mein Wecker bereits um 5 Uhr klingelt.
                                  Bei den Inhalten der zwei Datenpunkte, die du weiter oben als Code angefügt hattest, ist mir aufgefallen, dass in deinen ConditionJson Unterobjekte von deinen TimerJSON existieren. Aber unterhalb der in TimerJSON und somit in deiner Aufzählung Licht eingesetzten Objekte dürfte nichts stehen...
                                  Daher nochmal die Bitte:
                                  Prüfe und korrigiere die Inhalte, die in deiner Aufzählung "Licht" stehen. Es dürfen nur die States eines Objekts drin stehen (letzte Stufe bei den Objekten, drunter sollte keine Ebene mehr sein).
                                  Wenn Du die Aufzählung Licht korrigiert hast, bitte stoppe das Skript, lösche das State "javascript.0.Timer.Devices.TimerJSON" und starte erneut das Skript.
                                  Bei den Bedingungen besteht auch nur die Pflicht States in der Aufzählung zu verwenden. Was du einsetzt, ist dir überlassen. ABER es dürfen eben nur States sein (also die Objekte der untersten Ebene, die übrigens im IoBroker Objekt-Reiter nicht als Ordner angezeigt werden).
                                  Wenn ich die Zeit finde werde ich in den kommenden Tagen, oder am Wochenende, zwei Videos einstellen. Einmal die grundsätzliche Erklärung des Timers und dann noch die Einrichtung.
                                  • G Offline
                                    GiuseppeS
                                    #245
                                    @sigi234
                                    Darauf beziehe ich mich übrigens. In oberer Code Zeile ganz klar Unterobjekt von zweiter Zeile (Ergänzung ".STATE").
                                    • G Offline
                                      GiuseppeS
                                      #246
                                      Habe ein kleines Update hochgeladen.
                                      Mir war gestern aufgefallen, dass die Anzeige des nächsten Timers bei einem bestimmten Fall fehlerhaft war (wenn mehrere Timer anstehen, aber keiner davon am "heutigen" Tag). Habe die Funktion korrigiert, diese könnt ihr einfach in euren Skripten ersetzen:
                                      // Zeigt alle kommenden Timer in Liste (optimiert für DropDown-Liste)
                                      function nextTimer(){
                                          var TimerJSON = JSON.parse(getState("javascript.0.Timer." + path + ".TimerJSON").val);
                                          var timeStamp, checkTime, firstKey, splitKey, newKey;
                                          var allTimer = {};
                                          Object.keys(TimerJSON).forEach(function(key) {
                                              for(var i = 1; i <= length(TimerJSON[key]); i++) {
                                                  // Hier werden alle Timer durchlaufen
                                                  if (TimerJSON[key][i].Aktiv && TimerJSON[key][i].ConditionsTrue){
                                                      // Timer ist Aktiv und Bedingungen sind erfüllt
                                                      var tmp = TimerJSON[key][i].CronTage.split(",");
                                                      for(var j = 0; j < tmp.length; j++) {
                                                          tmp[j] = (tmp[j] == 0 ? 7 : tmp[j]);
                                                          timeStamp = tmp[j] + " " + TimerJSON[key][i].Zeit;
                                                          if (showValues){
                                                              if (allTimer.hasOwnProperty(timeStamp)) {allTimer[timeStamp] += ", " + key + " (" + TimerJSON[key][i].Sollwert + ")"}
                                                              else {allTimer[timeStamp] = key + " (" + TimerJSON[key][i].Sollwert + ")";}
                                                          } else {
                                                              if (allTimer.hasOwnProperty(timeStamp)) {allTimer[timeStamp] += ", " + key}
                                                              else {allTimer[timeStamp] = key;}
                                          var allTimerLength = length(allTimer);
                                          var d = new Date();
                                          var actDay = (d.getDay() == 0 ? 7 : d.getDay());
                                          var actTime = ('0' + d.getHours()).slice(-2) + ":" + ('0' + d.getMinutes()).slice(-2);
                                          var actTimeStamp = actDay + " " + actTime;
                                          if (allTimerLength == 0){
                                              setState("javascript.0.Timer." + path + ".NextDevice", "Keine Timer");
                                              setState("javascript.0.Timer." + path + ".NextDevices", "Keine Timer");
                                          else if (allTimerLength == 1){
                                              firstKey = Object.keys(allTimer)[0];
                                              splitKey = firstKey.split(" ");
                                              newKey = TageJSON[splitKey[0]] + " " + splitKey[1];
                                              setState("javascript.0.Timer." + path + ".NextDevice", newKey + " - " + allTimer[firstKey]);
                                              setState("javascript.0.Timer." + path + ".NextDevices", newKey + " - " + allTimer[firstKey]);
                                          else {
                                              firstKey = "";
                                              var listBefore = "";
                                              var listAfter = "";
                                              var listComplete = "";
                                              Object.keys(allTimer).sort().forEach(function(key) {
                                                  if (key > actTimeStamp){
                                                      if (firstKey == "") {firstKey = key};
                                                      splitKey = key.split(" ");
                                                      newKey = ( parseInt(splitKey[0]) == actDay ? "" : TageJSON[splitKey[0]]) + " " + splitKey[1];
                                                      listAfter += newKey + " - " + allTimer[key] + ";" ;
                                                  else {
                                                      listBefore += newKey + " - " + allTimer[key] + ";" ;
                                              listComplete = listAfter + listBefore;
                                              setState("javascript.0.Timer." + path + ".NextDevice", listComplete.split(";")[0]);
                                              setState("javascript.0.Timer." + path + ".NextDevices", listComplete.slice(0, listComplete.length - 1));
                                      Habe ansonsten noch alle Subscribes in Funktionen gepackt, und deren Ausführung am Ende der Main Funktion verzögert eingefügt. Somit entstehen nun nur noch zwei Fehler nach der ersten Ausführung des Skripts (also wenn noch keine States erstellt wurden). Wollte die Fehler eigentlich komplett eliminieren aber die letzten Beiden sind iwie sehr zäh :man-facepalming:
                                      • G Offline
                                        GiuseppeS
                                        #247
                                        Und noch ein Update hinterher: Keine neue Funktionalität, aber höherer Komfort.
                                        • Die Sollwerte-Auswahl im PopUp wird entsprechend der hinterlegten Devices angezeigt. Ist es ein Boolean Device (true/false), wird in der Auswahl nur An/Aus zur Auswahl dargestellt.
                                        • Wenn kein boolean, dann wird der Rest angezeigt (Zahlenwerte + Auf/ab)
                                        Theoretisch könnte ich diese Auswahl auf für die Bedingungen vorgeben. Besteht hierbei Interesse?
                                        Bei den Bedingungen hatte ich Vorgaben bisher nicht integriert, damit diese möglichst frei genutzt werden können.
                                        Für das Update in bestehende Skripte würde ich empfehlen komplett neu zu importieren. Auch das PopUp!
                                        Einfacher Import:
                                        Nur Skript-Inhalt unter Zeile 40 kopieren und im eigenen Skript alles unter Zeile 40 damit ersetzen. Es kamen oben keine neuen Variablen dazu, daher bleiben eure Voreinstellungen davon unberührt.
                                        • G GiuseppeS
                                          Einfacher Import:
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #248
                                          Update durchgeführt , Werte der DropDown-Liste werden je nach Aktor erfüllt .
                                          Wie immer …. 👍
                                          Frage ……., bei den Updates muss ich immer händisch die Werte ändern , könntest du es nicht mit reinnehme , dann ist es kompatibel mit @Mic Log Script .
                                          MicM G 2 Antworten Letzte Antwort
