  5. Unerklärliches Verhalten meiner Scripte
    5.6k
24 Beiträge 5 Kommentatoren 2.8k Aufrufe 2 Beobachtet
  • U UltraJochen
    Du meinst als Export?
      <block type="on" id="g+UhoA,!24M((63y#zPd" x="-1712" y="-1012">
        <field name="OID">mqtt.0.LuxWinterG.Sensor_BH1750.Lux</field>
        <statement name="STATEMENT">
          <block type="controls_if" id="X@[;x,?{pO.p-rY_l-]B">
            <value name="IF0">
              <block type="logic_operation" id="zR-Jz8s|9-?2K-[U$t2O" inline="false">
                <field name="OP">AND</field>
                <value name="A">
                  <block type="time_compare_ex" id="m7w`Wn:88^2ZpJUUT(eW">
                    <mutation end_time="true" actual_time="true"></mutation>
                    <field name="USE_ACTUAL_TIME">TRUE</field>
                    <field name="OPTION">between</field>
                    <value name="START_TIME">
                      <shadow type="text" id="lSP%zSv}GiqI1Gmos-Q3">
                        <field name="TEXT">22:08</field>
                      </shadow>
                      <block type="time_astro" id="0dVzfV*R]+A;nZBqnNup">
                        <field name="TYPE">sunset</field>
                        <field name="OFFSET">-120</field>
                      </block>
                    </value>
                    <value name="END_TIME">
                      <shadow type="text" id="]a=5lhd4JFW2$k6J/Bhz">
                        <field name="TEXT">22:00</field>
                      </shadow>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_compare" id="10M^V;LR.mi/yD[kfT}c">
                    <field name="OP">LTE</field>
                    <value name="A">
                      <block type="get_value" id="K9zR)-$`w*uIAliM/XZ;">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="4@/~7.+9Nx$|2@^!d?Ej">
                        <field name="NUM">10</field>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="control" id="wWbT4++85c$Gd4MwLTOk">
                <mutation delay_input="false"></mutation>
                <field name="OID">deconz.0.Lights.5.bri</field>
                <value name="VALUE">
                  <block type="math_number" id="PD@Pr:0Uk7dG}I9oVccp">
                    <field name="NUM">80</field>
                  </block>
                </value>
              </block>
            </statement>
            <statement name="ELSE">
              <block type="control" id="B6([GexicV$OB6r33jLI">
                <field name="OID">deconz.0.Lights.5.on</field>
                  <block type="logic_boolean" id="e.61YfNps%r2P`16LJR+">
                  </block>
                </value>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @UltraJochen Nein, du kannst oben rechts auf den Knopf Screen Shot 2019-08-20 at 18.50.23 .png drücken um den JS code zu lesen
    A.
    U 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      U Offline
      U Offline
      UltraJochen
      @Asgothian
      ahh, ok
      on({id: "mqtt.0.LuxWinterG.Sensor_BH1750.Lux"/*/LuxWinterG/Sensor_BH1750/Lux*/, change: "any"}, function (obj) {
        var value = obj.state.val;
        if (compareTime(getAstroDate("sunset", undefined, -120), '22:00', "between", null) && getState("mqtt.0.LuxWinterG.Sensor_BH1750.Lux").val <= 10) {
          setState("deconz.0.Lights.5.bri"/*Kommode bri*/, 80);
        } else {
          setState("deconz.0.Lights.5.on"/*Kommode on*/, false);
      • U UltraJochen
        @Asgothian
        ahh, ok
          } else {
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @UltraJochen mm.. das ist die Variante ohne die log ausgaben.. kannst du nochmal die mit den Ausgaben posten ? Das Script sieht erst einmal ok aus.
        A.
        • U Offline
          U Offline
          UltraJochen
          Achso, die Debug-Option habe ich noch nicht gebaut.
          Das Script sieht für mich auch ok aus. Um es realistisch zu testen, müsste das angepasste Script dann ja auch die Nacht durchlaufen. Tagsüber (bzw. bis 22:00 funzt es super).
          Wie ist denn diese Angabe im Log zu verstehen:
          date=Tue Aug 20 2019 05:00:51 GMT+0200 (CEST)) => Tue Aug 20 2019 20:37:33 GMT+0200 (CEST)
          AsgothianA paul53P 2 Antworten Letzte Antwort
          • U UltraJochen
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @UltraJochen
            da muss ich passen - ich war davon aus gegangen das die Meldung von einem Logeintrag stammt.
            • U UltraJochen
              @UltraJochen:
              getAstroDate() liefert um 5:00 Uhr den Zeitpunkt des Sonnenuntergangs: 20:37:33 MESZ.
              • U Offline
                U Offline
                UltraJochen
                schrieb am zuletzt editiert von UltraJochen
                Ok, hier ist ein Eintrag wo sich die Lampe einschaltet:
                2019-08-20 01:20:38.333 - info: javascript.0 script.js.common.Licht.NachtlichtKommode: getAstroDate(pattern=sunset, date=Tue Aug 20 2019 01:20:38 GMT+0200 (CEST)) => Mon Aug 19 2019 20:39:39 GMT+0200 (CEST)
                2019-08-20 01:20:38.334 - info: javascript.0 script.js.common.Licht.NachtlichtKommode: getState(id=mqtt.0.LuxWinterG.Sensor_BH1750.Lux, timerId=undefined) => {"val":0,"ack":true,"ts":1566256838332,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1566240922188}
                2019-08-20 01:20:38.334 - info: javascript.0 script.js.common.Licht.NachtlichtKommode: setForeignState(id=deconz.0.Lights.5.bri, state=80)
                2019-08-20 01:20:38.339 - info: deconz.0 setLightState: {"bri": 80, "on": true} 5 deconz.0.Lights.5.bri
                2019-08-20 01:20:38.341 - info: deconz.0 options: {"url":"http://192.168.178.34:8077/api/80A7A3FC4A/lights/5/state","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{\"bri\": 80, \"on\": true}"}
                • U UltraJochen
                  @UltraJochen sagte:
                  Welche Version des JS-Adapters ?
                  • U Offline
                    U Offline
                    UltraJochen
                    Müsste 4.1.12 sein.
                    • U UltraJochen
                      Müsste 4.1.12 sein.
                      @UltraJochen sagte:
                      Müsste 4.1.12 sein.
                      Dann update auf 4.1.14 (in latest).
                        @UltraJochen sagte:
                        Müsste 4.1.12 sein.
                        U Offline
                        U Offline
                        UltraJochen
                        juut, ist erledigt. Ich bin gespannt, was heute nacht passiert.
                        Edit: Heute Nacht lief alles wie es sollte. Ich werds die Tage aber noch weiter beobachten.
                        Vielen Dank für die Hilfe. :)
