  4. BLE Adapter
BLE Adapter
bluetooth setcap fehler gelb s
57 Beiträge 12 Kommentatoren 12.4k Aufrufe 10 Beobachtet
  • Lenny.CBL Lenny.CB
    @AlCalzone
    hatte ich schon geahnt, dass das nicht so einfach wird.
    Sind jede Mengen Characteristics drin.
    nRF Connect, 2019-05-04
    LYWSD02 (3F:59:C8:81:30:61)
    V 09:57:40.327 Connecting to 3F:59:C8:81:30:61...
    D 09:57:40.328 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M or LE 2M)
    D 09:57:42.859 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I 09:57:42.859 Connected to 3F:59:C8:81:30:61
    D 09:57:42.932 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V 09:57:42.933 Discovering services...
    D 09:57:42.933 gatt.discoverServices()
    I 09:57:43.506 Connection parameters updated (interval: 35.0ms, latency: 0, timeout: 3000ms)
    I 09:57:43.823 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D 09:57:44.694 [Callback] Services discovered with status: 0
    I 09:57:44.695 Services discovered
    V 09:57:44.736 Generic Access (0x1800)
    • Device Name [R] (0x2A00)
    • Appearance [R] (0x2A01)
      Generic Attribute (0x1801)
    • Service Changed [I R] (0x2A05)
      Client Characteristic Configuration (0x2902)
      Device Information (0x180A)
    • Manufacturer Name String [R] (0x2A29)
    • Model Number String [R] (0x2A24)
    • Serial Number String [R] (0x2A25)
    • Hardware Revision String [R] (0x2A27)
    • Firmware Revision String [R] (0x2A26)
    • Software Revision String [R] (0x2A28)
    • System ID [R] (0x2A23)
      Unknown Service (0000fef5-0000-1000-8000-00805f9b34fb)
    • Unknown Characteristic [R W] (8082caa8-41a6-4021-91c6-56f9b954cc34)
    • Unknown Characteristic [R W] (724249f0-5ec3-4b5f-8804-42345af08651)
    • Unknown Characteristic [R] (6c53db25-47a1-45fe-a022-7c92fb334fd4)
    • Unknown Characteristic [R W] (9d84b9a3-000c-49d8-9183-855b673fda31)
    • Unknown Characteristic [R W WNR] (457871e8-d516-4ca1-9116-57d0b17b9cb2)
    • Unknown Characteristic [N R] (5f78df94-798c-46f5-990a-b3eb6a065c88)
    • Unknown Characteristic [R] (64b4e8b5-0de5-401b-a21d-acc8db3b913a)
    • Unknown Characteristic [R] (42c3dfdd-77be-4d9c-8454-8f875267fb3b)
    • Unknown Characteristic [R] (b7de1eea-823d-43bb-a3af-c4903dfce23c)
      Unknown Service (ebe0ccb0-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [R W] (ebe0ccb7-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [R] (ebe0ccb9-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [R W] (ebe0ccba-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [R] (ebe0ccbb-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [N R] (ebe0ccbc-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [R W] (ebe0ccbe-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [N R] (ebe0ccc1-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [W] (ebe0ccc2-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [R W] (ebe0ccc3-7a0a-4b0c-8a1a-6ff2997da3a6)
    • Unknown Characteristic [R] (ebe0ccc4-7a0a-4b0c-8a1a-6ff2997da3a6)
      Unknown Service (2b43ccc0-2506-415c-a16c-e4cc5f52ef78)
    • Unknown Characteristic [R] (2b43ccc1-2506-415c-a16c-e4cc5f52ef78)
    • Unknown Characteristic [N W WNR] (2b43ccc2-2506-415c-a16c-e4cc5f52ef78)
    • Unknown Characteristic [W WNR] (2b43ccc3-2506-415c-a16c-e4cc5f52ef78)
    • Unknown Characteristic [W WNR] (2b43ccc4-2506-415c-a16c-e4cc5f52ef78)
      Unknown Service (aaaaaaa0-aaaa-aaaa-aaaa-aaaaaaaaaaaa)
    • Unknown Characteristic [R W WNR] (aaaaaaa1-aaaa-aaaa-aaaa-aaaaaaaaaaaa)
      Unknown Service (fafafa00-fafa-fafa-fafa-fafafafafafa)
    • Unknown Characteristic [R W] (fafafa01-fafa-fafa-fafa-fafafafafafa)
      Unknown Service (0000fe95-0000-1000-8000-00805f9b34fb)
    • Unknown Characteristic [N W] (00000001-0000-1000-8000-00805f9b34fb)
    • Unknown Characteristic [R] (00000002-0000-1000-8000-00805f9b34fb)
    • Unknown Characteristic [R] (00000004-0000-1000-8000-00805f9b34fb)
    • Unknown Characteristic [N W] (00000005-0000-1000-8000-00805f9b34fb)
    • Unknown Characteristic [W] (00000010-0000-1000-8000-00805f9b34fb)
    • Unknown Characteristic [R W] (00000013-0000-1000-8000-00805f9b34fb)
    • Unknown Characteristic [R] (00000014-0000-1000-8000-00805f9b34fb)
      Unknown Descriptor (fafafa01-fafa-fafa-fafa-fafafafafafa)
      D 09:57:44.737 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
      D 09:57:44.738 gatt.setCharacteristicNotification(5f78df94-798c-46f5-990a-b3eb6a065c88, true)
      D 09:57:44.739 gatt.setCharacteristicNotification(ebe0ccbc-7a0a-4b0c-8a1a-6ff2997da3a6, true)
      D 09:57:44.740 gatt.setCharacteristicNotification(ebe0ccc1-7a0a-4b0c-8a1a-6ff2997da3a6, true)
      D 09:57:44.742 gatt.setCharacteristicNotification(2b43ccc2-2506-415c-a16c-e4cc5f52ef78, true)
      D 09:57:44.744 gatt.setCharacteristicNotification(00000001-0000-1000-8000-00805f9b34fb, true)
      D 09:57:44.746 gatt.setCharacteristicNotification(00000005-0000-1000-8000-00805f9b34fb, true)
      I 09:57:44.814 Connection parameters updated (interval: 35.0ms, latency: 0, timeout: 3000ms)
    Nur mal so, wie kann ich sehen was da übermittelt wird?
    Sonst noch kurz zum Display:
    • cooles Teil, schaut sehr wertig aus
    • zeigt mit dem Adapter Temp/Hum/RSSI an
    • Uhr kommt nur aus der APP (kann nicht gestellt werden - jedenfalls noch nicht raus bekommen wie)
    • Gerät kann man nur bei Serverauswahl "China" hinzu fügen
    • Uhr geht eine Stunde nach. Vermutlich wegen "China-Server"
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @Lenny-CB sagte in BLE Adapter:
    Keine Ahnung 🤷
      adarof
      Hallo
      Meine LED Panels scheinen mir auch BLE zu machen. Dump von nRF Connect unten.
      Gäbe es eine Möglichkeit die im BLE-Adapter auch bekannt zu machen?
      Ich könnte dann ja erstmal nur lesen (wenn ich rausbekomme, wie die READ-Services zu dekodieren sind - ich denke dadrüber bekomme ich die RGB Werte sowie Helligkeitswerte) und später vielleicht durch ausprobieren auch die WRITE-Services (auch wenn der Adapter gerade noch garkein Write unterstützt).
      Gruss -
      telink_mesh1 (A4:C1:38:28:A4:0D)
      V	07:56:30.372	Connecting to A4:C1:38:28:A4:0D...
      D	07:56:30.373	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) (hidden)
      D	07:56:30.765	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
      I	07:56:30.766	Connected to A4:C1:38:28:A4:0D
      D	07:56:30.788	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
      V	07:56:30.834	Discovering services...
      D	07:56:30.834	gatt.discoverServices()
      D	07:56:31.613	[Callback] Services discovered with status: 0
      I	07:56:31.613	Services discovered
      V	07:56:31.645	Generic Access (0x1800)
      - Device Name [R] (0x2A00)
       Characteristic User Description (0x2901)
      - Appearance [R] (0x2A01)
      - Firmware Revision String [R] (0x2A26)
      - Manufacturer Name String [R] (0x2A29)
      - Model Number String [R] (0x2A24)
      - Hardware Revision String [R] (0x2A27)
      Unknown Service (00010203-0405-0607-0809-0a0b0c0d1910)
      - Unknown Characteristic [N R W] (00010203-0405-0607-0809-0a0b0c0d1911)
      - Unknown Characteristic [R W WNR] (00010203-0405-0607-0809-0a0b0c0d1912)
      - Unknown Characteristic [R WNR] (00010203-0405-0607-0809-0a0b0c0d1913)
      - Unknown Characteristic [R W] (00010203-0405-0607-0809-0a0b0c0d1914)
      V	07:56:54.271	Beginning reliable write...
      D	07:56:54.271	gatt.beginReliableWrite()
      V	07:57:06.019	Reading remote RSSI...
      D	07:57:06.019	gatt.readRemoteRssi()
      I	07:57:06.042	Remote RSSI received: -69 dBm
      V	07:57:09.808	Reading all characteristics...
      V	07:57:09.809	Reading characteristic 00002a00-0000-1000-8000-00805f9b34fb
      D	07:57:09.809	gatt.readCharacteristic(00002a00-0000-1000-8000-00805f9b34fb)
      I	07:57:09.869	Read Response received from 00002a00-0000-1000-8000-00805f9b34fb, value: (0x) 54-65-6C-69-6E-6B-20-74-4C-69-67-68-74-00
      A	07:57:09.869	"Telink tLight " received
      V	07:57:09.888	Reading characteristic 00002a01-0000-1000-8000-00805f9b34fb
      D	07:57:09.888	gatt.readCharacteristic(00002a01-0000-1000-8000-00805f9b34fb)
      I	07:57:09.953	Read Response received from 00002a01-0000-1000-8000-00805f9b34fb, value: (0x) 00-00
      A	07:57:09.953	"[0] Unknown" received
      V	07:57:09.973	Reading characteristic 00002a26-0000-1000-8000-00805f9b34fb
      D	07:57:09.973	gatt.readCharacteristic(00002a26-0000-1000-8000-00805f9b34fb)
      I	07:57:10.143	Read Response received from 00002a26-0000-1000-8000-00805f9b34fb, value: (0x) 56-31-2E-36-00-00-00-00-00-00-00-00
      A	07:57:10.143	"V1.6        " received
      V	07:57:10.160	Reading characteristic 00002a29-0000-1000-8000-00805f9b34fb
      D	07:57:10.160	gatt.readCharacteristic(00002a29-0000-1000-8000-00805f9b34fb)
      I	07:57:10.262	Read Response received from 00002a29-0000-1000-8000-00805f9b34fb, value: (0x) 74-65-6C-69-6E-6B-5F-6D-65-73-68-31-00
      A	07:57:10.262	"telink_mesh1 " received
      V	07:57:10.275	Reading characteristic 00002a24-0000-1000-8000-00805f9b34fb
      D	07:57:10.275	gatt.readCharacteristic(00002a24-0000-1000-8000-00805f9b34fb)
      I	07:57:10.342	Read Response received from 00002a24-0000-1000-8000-00805f9b34fb, value: (0x) 6D-6F-64-65-6C-20-69-64-20-31-32-33-00
      A	07:57:10.342	"model id 123 " received
      V	07:57:10.358	Reading characteristic 00002a27-0000-1000-8000-00805f9b34fb
      D	07:57:10.358	gatt.readCharacteristic(00002a27-0000-1000-8000-00805f9b34fb)
      I	07:57:10.422	Read Response received from 00002a27-0000-1000-8000-00805f9b34fb, value: (0x) 22-22-22-22, """"""
      A	07:57:10.422	"""""" received
      V	07:57:10.435	Reading characteristic 00010203-0405-0607-0809-0a0b0c0d1911
      D	07:57:10.435	gatt.readCharacteristic(00010203-0405-0607-0809-0a0b0c0d1911)
      I	07:57:10.544	Read Response received from 00010203-0405-0607-0809-0a0b0c0d1911, value: (0x) 00
      A	07:57:10.544	"(0x) 00" received
      V	07:57:10.566	Reading characteristic 00010203-0405-0607-0809-0a0b0c0d1912
      D	07:57:10.566	gatt.readCharacteristic(00010203-0405-0607-0809-0a0b0c0d1912)
      I	07:57:10.622	Read Response received from 00010203-0405-0607-0809-0a0b0c0d1912, value: (0x) 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
      A	07:57:10.622	"(0x) 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00" received
      V	07:57:10.648	Reading characteristic 00010203-0405-0607-0809-0a0b0c0d1913
      D	07:57:10.648	gatt.readCharacteristic(00010203-0405-0607-0809-0a0b0c0d1913)
      I	07:57:10.743	Read Response received from 00010203-0405-0607-0809-0a0b0c0d1913, value: (0x) E0-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
      A	07:57:10.743	"(0x) E0-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00" received
      V	07:57:10.755	Reading characteristic 00010203-0405-0607-0809-0a0b0c0d1914
      D	07:57:10.755	gatt.readCharacteristic(00010203-0405-0607-0809-0a0b0c0d1914)
      I	07:57:10.822	Read Response received from 00010203-0405-0607-0809-0a0b0c0d1914, value: (0x) 00-72-B4-14-60-83-FE-C3-5A-4D-A8-5D-CB-2D-1A-88-BF
      A	07:57:10.822	"(0x) 00-72-B4-14-60-83-FE-C3-5A-4D-A8-5D-CB-2D-1A-88-BF" received
      V	07:57:10.835	10 characteristics read
      D	07:58:43.455	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
      E	07:58:43.460	Error 8 (0x8): GATT CONN TIMEOUT
      I	07:58:43.460	Disconnected
      D	07:58:43.650	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
      • C Offline
        Cliff
        Hallo und Moin,
        ich hadere schon länger mit dem BLE- Adapter, bzw. der Funktionalität.
        Installiert ist BLE in der aktuellsten Version. Der Adapter ist grün, meldet 'Powered' und so weit alles OK.
        Leider erkennt er mein Flower- Care nicht. Per App, bzw. mit nRF ist das Gerät sofort zu entdecken.
        Um es ganz verrückt zu machen: Der Adapter hat das Gerät EINMALIG erkannt, die Objekte angelegt und mit Daten gefüllt. Seither ist schweigen im Walde, bzw. ich bekomme keine Daten mehr...
        • C Cliff
          Hallo und Moin,
          Jan1
          @Cliff
          Auf was läuft Dein IOBroker? Bei mir kackt ab und an mal das BT Modul meines BeeLink ab und da hilft einmal runter fahren und spannungsfrei, danach ist das BT Modul wieder online und der BLE Adapter läuft. Die Sensoren dürfen auch nicht über BT mit der APP verbunden sein, sonst gibts auch Probleme.
          • C Offline
            Cliff
            schrieb am zuletzt editiert von Cliff
            hatte ich vergessen zu schreiben:
            Es läuft auf einem Rock64.
            Andere Devices werden wie verrückt erkannt (Allerdings dann nur RSSI).
            Habe schon mehrere Bluetooth Dongle probiert. Ohne Änderung.
            Wie schon geschrieben:
            Der Adapter läuft grundsätzlich ohne Probleme (Grün und so...).
            In wie fern nicht mit der App verbunden?
            ich verwende Flower Care. Der Sensor ist nicht mit dem Handy gekoppelt. Die App im Regelfall geschlossen.
            • C Cliff
              Jan1
              @Cliff
              Hm, welche FW Version läuft denn auf dem Sensor? Da die ja aber auch schon mal funktioniert hatten, dürfte es daran aber auch nicht liegen.
              Hast Du ne grafische Oberfläche für Dein Linux? Wenn ich Probleme habe, geh ich auf den BeeLink unter Debian Buster direkt rein und schau ob unter BT mein Adapter noch erkannt wird, wenn dem nicht so ist, ist mein Workaround das was ich oben geschrieben hatte.
              Sonst fällt mir dazu nichts mehr ein.
              • C Offline
                Cliff
                Firmware ist die Aktuellste (3.2.1).
                Der Flowercare Sensor wird z.B. von nRf sofort erkannt.
                Habe leider nur Armbian drauf laufen.
                Der Bluetoothadapter wird einwandfrei vom System erkannt (HciTool/ Adapter ist ja auch 'grün').
                • C Cliff
                  Jan1
                  @Cliff
                  Aber in Reichweite sind die Sensoren? Bei mir sind 6m schon grenzwertig.
                  • C Offline
                    Cliff
                    Habe den Sensor schon einmal testweise direkt neben den Rechner gelegt. Ändert nichts.
                      @AlCalzone sagte in BLE Adapter:
                      Ich vermute nicht, dazu brauche ich die Mac-Adress-Präfixe. Außer die sind unverändert.
                      heut kam das gute Stück. @AlCalzone willst mal schauen ob du das intergrieren kannst? 😀
                      wenn ich beim ble-Adapter neue Devices erlaube kommt Folgendes:
                      value vom "fe95" ist "70205b04ba613081c8593f09041002d500"
                      die App nRF Connect habe ich auch, falls du da was brauchst.
                      enemy2003
                      Hab auch so ein Teil, ble Adapter auf 0.8.1
                      kann man da was tun? Danke :)
                      • E enemy2003
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @enemy2003 sagte in BLE Adapter:
                        kann man da was tun
                        Sollte in Version 0.8.2 (gerade released) korrekt ausgelesen werden.
                        E 1 Antwort Letzte Antwort
                        • AlCalzoneA AlCalzone
                          kann man da was tun
                          enemy2003
                          @AlCalzone
                          Funktioniert perfekt, ich verneige mich und bedanke mich vielmals ☺️
                          • C Offline
                            Cliff
                            So,
                            bei mir läuft es jetzt auch.
                            Nochmaliger Tausch des Bluetooth- Dongles, sowie eine USB- Verlängerung um den Dongle ein wenig vom Rock64 weg zu bekommen haben es scheinbar gebracht.
                            • bmueller77B Offline
                              bmueller77B Offline
                              bmueller77
                              @AlCalzone
                              Probleme mit dem Laufen des Adapters hab ich nicht, aber mit den Standardsettings legt er mir knapp 30.000 Objekte an. Leider ist mir nicht bekannt, welche Services es gibt, um diese evtl. zu filtern. Lässt sich die Anzahl der Objekte ggf. reduzieren?
                              • bmueller77B bmueller77
                                @AlCalzone
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @bmueller77 Am besten nimmst du den Haken weg bei "Geräte ohne Service-Daten erfassen", das sollte viele Geräte schon mal ignorieren.
                                Die verfügbaren Plugins findest du hier: https://github.com/AlCalzone/iobroker.ble#supported-plugins
                                Wenn du bestimmte Geräte auswerten willst, siehst du auch in dem jeweiligen Objektbaum, welche Services (=> State-Name) dieses Gerät sendet.
                                Lenny.CBL crunchipC 2 Antworten Letzte Antwort
                                  Lenny.CBL Offline
                                  Lenny.CBL Offline
                                  Lenny.CB
                                  @AlCalzone grad wieder ein neuer Xiaomi Sensor angekommen:
                                  value vom "fe95" ist "303247031ad34d10342d580d"
                                  battery und rssi fehlen.
                                  Kann man da was machen?
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    @Lenny-CB:
                                    Ich vermute dass ein Firmware-Update des Sensors hilft. Da ein Teil der Daten ja ankommt, sendet der das ggf. nicht. Alternativ zeig mal das Debug-Log von ein paar Minuten, ob da was zu erkennen ist.
                                    Lenny.CBL 1 Antwort Letzte Antwort
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @AlCalzone grad mal auf die Seite gekuckt, da ich auch das Problem mit Unmassen von Geräten habe.
                                      Da steht der Mosquito Repellent ja schon mit bei? Gibts da was neues?
                                      denn bei mir sieht er immer noch so aus,
                                      du wolltest mal gucken was es mit diesen unknown... auf sich hat. Ansteuern, sprich an/aus schalten wird da wohl nicht möglich sein?
                                        @Lenny-CB:
                                        Lenny.CBL Offline
                                        Lenny.CBL Offline
                                        Lenny.CB
                                        schrieb am zuletzt editiert von Lenny.CB
                                        @Lenny-CB:
                                        Ich denke auch es war das Update. rssi und battery ist nunda und wird gefüllt.
                                        Der Service fe95 ist weg aber fdcd ist noch da. Weist du was dahinter steckt? kann man das ausblenden?
                                        Ich muss sagen, mir gefällt das mit dem ePaper sehr gut. Schaut mit der "Glasscheibe" vorn drauf auch recht edel aus.
                                          @Lenny-CB:
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          @Lenny-CB Schick mir bitte mal den String, ich schau mal ob sich das auch parsen lässt.
                                          @crunchip Leider nein. Zu viele andere Baustellen (insbesondere Z-Wave) derzeit. Steuern ist eh noch eine andere Hausnummer.
                                          crunchipC Lenny.CBL 2 Antworten Letzte Antwort
