  4. Sonos Adapter aktualisiert nur teilweise
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
sonosdatenpunkteaktualisierung
52 Beiträge 8 Kommentatoren 7.3k Aufrufe 7 Beobachtet
  • H helfi9999
    @apollon77 habe jetzt über die Katze neu installiert und bekam folgende Meldungen:
    iobroker	2019-08-12 16:28:38.100	info	exit 0
    iobroker	2019-08-12 16:28:38.003	info	upload [0] sonos.admin /opt/iobroker/node_modules/iobroker.sonos/admin/index.html index.html text/html
    iobroker	2019-08-12 16:28:37.908	info	upload [1] sonos.admin /opt/iobroker/node_modules/iobroker.sonos/admin/index_m.html index_m.html text/html
    iobroker	2019-08-12 16:28:37.830	info	upload [2] sonos.admin /opt/iobroker/node_modules/iobroker.sonos/admin/sonos.png sonos.png image/png
    iobroker	2019-08-12 16:28:37.746	info	upload [3] sonos.admin /opt/iobroker/node_modules/iobroker.sonos/admin/words.js words.js application/javascript
    iobroker	2019-08-12 16:28:37.716	info	got /opt/iobroker/node_modules/iobroker.sonos/admin
    iobroker	2019-08-12 16:28:37.627	info	SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    iobroker	2019-08-12 16:28:37.626	info	npm WARN optional
    iobroker	2019-08-12 16:28:37.626	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
    iobroker	2019-08-12 16:28:37.626	info	SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    iobroker	2019-08-12 16:28:37.624	info	npm WARN optional
    iobroker	2019-08-12 16:28:37.624	info	notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY
    iobroker	2019-08-12 16:28:37.624	info	WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING
    iobroker	2019-08-12 16:28:37.622	info	npm
    iobroker	2019-08-12 16:28:37.622	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
    iobroker	2019-08-12 16:28:37.622	info	WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is i
    iobroker	2019-08-12 16:28:37.620	info	npm
    iobroker	2019-08-12 16:28:34.408	info	ERR! node-gyp -v v3.8.0gyp ERR! not ok
    iobroker	2019-08-12 16:28:34.407	info	gyp
    iobroker	2019-08-12 16:28:34.407	info	gyp ERR! node -v v10.16.2
    iobroker	2019-08-12 16:28:34.407	info	gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
    iobroker	2019-08-12 16:28:34.407	info	ERR! System Linux 5.0.0-23-genericgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    iobroker	2019-08-12 16:28:34.405	info	ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
    iobroker	2019-08-12 16:28:34.404	info	gyp
    iobroker	2019-08-12 16:28:34.404	info	gyp ERR! stack at ChildProcess.emit (events.js:198:13)
    iobroker	2019-08-12 16:28:34.404	info	gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    iobroker	2019-08-12 16:28:34.402	info	ERR! build error
    iobroker	2019-08-12 16:28:34.400	info	gyp
    iobroker	2019-08-12 16:28:34.396	info	make: *** [validation.target.mk:103: Release/obj.target/validation/src/validation.o] Fehler 1
    iobroker	2019-08-12 16:28:34.375	info	^~~~
    iobroker	2019-08-12 16:28:34.375	info	case 1: if (*source >= 0x80 && *source < 0xC2) return 0;
    iobroker	2019-08-12 16:28:34.375	info	../src/validation.cc:63:3: note: here
    iobroker	2019-08-12 16:28:34.375	info	^~~~~~
    iobroker	2019-08-12 16:28:34.375	info	switch (*source) {
    iobroker	2019-08-12 16:28:34.375	info	../src/validation.cc:54:5: warning: this statement may fall through [-Wimplicit-fallthrough=]
    iobroker	2019-08-12 16:28:34.375	info	case 2: if ((a = (*--srcptr)) > 0xBF) return 0;
    iobroker	2019-08-12 16:28:34.375	info	../src/validation.cc:53:3: note: here
    iobroker	2019-08-12 16:28:34.375	info	case 3: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
    iobroker	2019-08-12 16:28:34.375	info	../src/validation.cc:52:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
    iobroker	2019-08-12 16:28:34.375	info	../src/validation.cc:52:3: note: here
    iobroker	2019-08-12 16:28:34.375	info	case 4: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
    iobroker	2019-08-12 16:28:34.375	info	../src/validation.cc: In function ‘int isLegalUTF8(const uint8_t*, int)’:../src/validation.cc:51:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
    iobroker	2019-08-12 16:28:34.374	info	^~~~
    iobroker	2019-08-12 16:28:34.374	info	case 0 : ch += (uint8_t) value[i];
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:87:7: note: here
    iobroker	2019-08-12 16:28:34.374	info	~~~^~~~~
    iobroker	2019-08-12 16:28:34.374	info	case 1 : ch += (uint8_t) value[i++]; ch <<= 6;
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:86:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:86:7: note: here
    iobroker	2019-08-12 16:28:34.374	info	case 2 : ch += (uint8_t) value[i++]; ch <<= 6;
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:85:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:85:7: note: here
    iobroker	2019-08-12 16:28:34.374	info	case 3 : ch += (uint8_t) value[i++]; ch <<= 6;
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:84:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:84:7: note: here
    iobroker	2019-08-12 16:28:34.374	info	case 4 : ch += (uint8_t) value[i++]; ch <<= 6;
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:83:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc:83:7: note: here
    iobroker	2019-08-12 16:28:34.374	info	case 5 : ch += (uint8_t) value[i++]; ch <<= 6;
    iobroker	2019-08-12 16:28:34.374	info	../src/validation.cc: In function ‘int is_valid_utf8(size_t, char*)’:../src/validation.cc:82:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    iobroker	2019-08-12 16:28:34.264	info	^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.264	info	reinterpret_cast<Callback>(callback), type);
    iobroker	2019-08-12 16:28:34.264	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallb
    iobroker	2019-08-12 16:28:34.264	info	/home/iobroker/.node-gyp/10.16.2/include/node/node_object_wrap.h:84:78: required from here
    iobroker	2019-08-12 16:28:34.264	info	In file included from ../src/validation.cc:7:/home/iobroker/.node-gyp/10.16.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callbac
    iobroker	2019-08-12 16:28:34.189	info	^~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.189	info	NODE_MODULE(validation, init)
    iobroker	2019-08-12 16:28:34.189	info	../src/validation.cc:147:1: note: in expansion of macro ‘NODE_MODULE’
    iobroker	2019-08-12 16:28:34.189	info	^~~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.189	info	NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
    iobroker	2019-08-12 16:28:34.189	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
    iobroker	2019-08-12 16:28:34.189	info	(node::addon_register_func) (regfunc), \
    iobroker	2019-08-12 16:28:34.189	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node:
    iobroker	2019-08-12 16:28:34.189	info	In file included from ../src/validation.cc:8:../src/validation.cc: At global scope:
    iobroker	2019-08-12 16:28:34.188	info	^~~~~
    iobroker	2019-08-12 16:28:34.188	info	Local<Object> Value::ToObject() const {
    iobroker	2019-08-12 16:28:34.188	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:10046:15: note: declared here
    iobroker	2019-08-12 16:28:34.188	info	In file included from ../src/validation.cc:7:
    iobroker	2019-08-12 16:28:34.188	info	Local<Object> buffer_obj = args[0]->ToObject();
    iobroker	2019-08-12 16:28:34.188	info	../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Valu
    iobroker	2019-08-12 16:28:34.184	info	^~~~~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.184	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:386:13: note: candidate: ‘void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)’ inline void NODE_SET_METHOD(v8::Lo
    iobroker	2019-08-12 16:28:34.182	info	^~~~~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.182	info	inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
    iobroker	2019-08-12 16:28:34.182	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:372:13: note: candidate: ‘void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)’
    iobroker	2019-08-12 16:28:34.182	info	In file included from ../src/validation.cc:8:
    iobroker	2019-08-12 16:28:34.182	info	NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
    iobroker	2019-08-12 16:28:34.182	info	../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::Func
    iobroker	2019-08-12 16:28:34.175	info	^~~~~
    iobroker	2019-08-12 16:28:34.175	info	Local<Object> Value::ToObject() const {
    iobroker	2019-08-12 16:28:34.175	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:10046:15: note: declared here
    iobroker	2019-08-12 16:28:34.175	info	In file included from ../src/validation.cc:7:
    iobroker	2019-08-12 16:28:34.175	info	NanAssignPersistent(t_, t->ToObject());
    iobroker	2019-08-12 16:28:34.175	info	../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    iobroker	2019-08-12 16:28:34.175	info	In file included from ../src/validation.cc:15:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:
    iobroker	2019-08-12 16:28:34.167	info	^~~~~~~~~~
    iobroker	2019-08-12 16:28:34.167	info	declarator __attribute__((deprecated(message)))
    iobroker	2019-08-12 16:28:34.167	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
    iobroker	2019-08-12 16:28:34.167	info	V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));
    iobroker	2019-08-12 16:28:34.167	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:2916:51: note: declared here
    iobroker	2019-08-12 16:28:34.167	info	from ../src/validation.cc:7:
    iobroker	2019-08-12 16:28:34.167	info	In file included from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:26,
    iobroker	2019-08-12 16:28:34.167	info	v8::String::Value value(toStr);
    iobroker	2019-08-12 16:28:34.167	info	In file included from ../src/validation.cc:15:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declaration
    iobroker	2019-08-12 16:28:34.164	info	^~~~~~~~~~
    iobroker	2019-08-12 16:28:34.164	info	declarator __attribute__((deprecated(message)))
    iobroker	2019-08-12 16:28:34.164	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
    iobroker	2019-08-12 16:28:34.164	info	V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));
    iobroker	2019-08-12 16:28:34.164	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:2916:51: note: declared here
    iobroker	2019-08-12 16:28:34.164	info	from ../src/validation.cc:7:
    iobroker	2019-08-12 16:28:34.164	info	In file included from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:26,
    iobroker	2019-08-12 16:28:34.164	info	v8::String::Value value(toStr);
    iobroker	2019-08-12 16:28:34.164	info	../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v
    iobroker	2019-08-12 16:28:34.155	info	^~~~~~~~~~~~~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.155	info	, (uv_after_work_cb)NanAsyncExecuteComplete
    iobroker	2019-08-12 16:28:34.155	info	../node_modules/nan/nan.h:1800:25: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-
    iobroker	2019-08-12 16:28:34.155	info	In file included from ../src/validation.cc:15:../node_modules/nan/nan.h: In function ‘void NanAsyncQueueWorker(NanAsyncWorker*)’:
    iobroker	2019-08-12 16:28:34.143	info	^~~~~~~~~~
    iobroker	2019-08-12 16:28:34.143	info	__attribute__((deprecated(message))) declarator
    iobroker	2019-08-12 16:28:34.143	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
    iobroker	2019-08-12 16:28:34.143	info	^~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.143	info	NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    iobroker	2019-08-12 16:28:34.143	info	In file included from ../src/validation.cc:8:/home/iobroker/.node-gyp/10.16.2/include/node/node.h:177:50: note: declared here
    iobroker	2019-08-12 16:28:34.142	info	^~~
    iobroker	2019-08-12 16:28:34.142	info	# define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))
    iobroker	2019-08-12 16:28:34.142	info	../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’
    iobroker	2019-08-12 16:28:34.142	info	));
    iobroker	2019-08-12 16:28:34.142	info	../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCa
    iobroker	2019-08-12 16:28:34.142	info	In file included from ../src/validation.cc:15:
    iobroker	2019-08-12 16:28:34.142	info	^~~~~~~~~~
    iobroker	2019-08-12 16:28:34.142	info	__attribute__((deprecated(message))) declarator
    iobroker	2019-08-12 16:28:34.142	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
    iobroker	2019-08-12 16:28:34.142	info	^~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.142	info	NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    iobroker	2019-08-12 16:28:34.142	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:177:50: note: declared here
    iobroker	2019-08-12 16:28:34.142	info	In file included from ../src/validation.cc:8:
    iobroker	2019-08-12 16:28:34.142	info	In file included from ../src/validation.cc:15:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*
    iobroker	2019-08-12 16:28:34.125	info	^~~~~~~~~~
    iobroker	2019-08-12 16:28:34.125	info	__attribute__((deprecated(message))) declarator
    iobroker	2019-08-12 16:28:34.125	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
    iobroker	2019-08-12 16:28:34.125	info	^~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.125	info	NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    iobroker	2019-08-12 16:28:34.125	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:163:50: note: declared here
    iobroker	2019-08-12 16:28:34.125	info	In file included from ../src/validation.cc:8:
    iobroker	2019-08-12 16:28:34.125	info	v8::Isolate::GetCurrent(), target, method, argc, argv));
    iobroker	2019-08-12 16:28:34.125	info	../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(...,
    iobroker	2019-08-12 16:28:34.125	info	In file included from ../src/validation.cc:15:
    iobroker	2019-08-12 16:28:34.125	info	In file included from ../src/validation.cc:15:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:
    iobroker	2019-08-12 16:28:34.124	info	^~~~~~~~~~
    iobroker	2019-08-12 16:28:34.124	info	__attribute__((deprecated(message))) declarator
    iobroker	2019-08-12 16:28:34.124	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
    iobroker	2019-08-12 16:28:34.124	info	^~~~~~~~~~~~
    iobroker	2019-08-12 16:28:34.124	info	NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    iobroker	2019-08-12 16:28:34.124	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:170:50: note: declared here
    iobroker	2019-08-12 16:28:34.124	info	In file included from ../src/validation.cc:8:
    iobroker	2019-08-12 16:28:34.124	info	v8::Isolate::GetCurrent(), target, symbol, argc, argv));
    iobroker	2019-08-12 16:28:34.124	info	../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCall
    iobroker	2019-08-12 16:28:34.124	info	In file included from ../src/validation.cc:15:
    iobroker	2019-08-12 16:28:34.124	info	../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:
    iobroker	2019-08-12 16:28:34.124	info	/home/iobroker/.node-gyp/10.16.2/include/node/node.h:177:50: note: declared here
    iobroker	2019-08-12 16:28:34.124	info	v8::Isolate::GetCurrent(), target, func, argc, argv));
    iobroker	2019-08-12 16:28:34.124	info	../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCa
    iobroker	2019-08-12 16:28:34.124	info	In file included from ../src/validation.cc:15:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>
    iobroker	2019-08-12 16:28:34.122	info	^~~~~~~~~~
    iobroker	2019-08-12 16:28:34.122	info	declarator __attribute__((deprecated(message)))
    iobroker	2019-08-12 16:28:34.122	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
    iobroker	2019-08-12 16:28:34.122	info	V8_DEPRECATED("Use maybe version", Local<Value> Run());
    iobroker	2019-08-12 16:28:34.122	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1271:51: note: declared here
    iobroker	2019-08-12 16:28:34.122	info	from ../src/validation.cc:7:
    iobroker	2019-08-12 16:28:34.122	info	In file included from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:26,
    iobroker	2019-08-12 16:28:34.122	info	return script->Run();
    iobroker	2019-08-12 16:28:34.122	info	../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    iobroker	2019-08-12 16:28:34.122	info	../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:
    iobroker	2019-08-12 16:28:34.122	info	In file included from ../src/validation.cc:15:
    iobroker	2019-08-12 16:28:34.122	info	return script->BindToCurrentContext()->Run();
    iobroker	2019-08-12 16:28:34.122	info	../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    iobroker	2019-08-12 16:28:34.122	info	In file included from ../src/validation.cc:15:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:
    iobroker	2019-08-12 16:28:34.121	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1537:51: note: candidate expects 4 arguments, 2 provided
    iobroker	2019-08-12 16:28:34.121	info	^~~~~~~
    iobroker	2019-08-12 16:28:34.121	info	static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(
    iobroker	2019-08-12 16:28:34.121	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1537:51: note: candidate: ‘static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*,
    iobroker	2019-08-12 16:28:34.121	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1510:51: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
    iobroker	2019-08-12 16:28:34.121	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1510:51: note: candidate: ‘static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::Scr
    iobroker	2019-08-12 16:28:34.121	info	In file included from ../src/validation.cc:7:
    iobroker	2019-08-12 16:28:34.121	info	return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
    iobroker	2019-08-12 16:28:34.121	info	../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
    iobroker	2019-08-12 16:28:34.121	info	In file included from ../src/validation.cc:15:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
    iobroker	2019-08-12 16:28:34.120	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1537:51: note: candidate expects 4 arguments, 2 provided
    iobroker	2019-08-12 16:28:34.120	info	^~~~~~~
    iobroker	2019-08-12 16:28:34.120	info	static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(
    iobroker	2019-08-12 16:28:34.120	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1537:51: note: candidate: ‘static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*,
    iobroker	2019-08-12 16:28:34.120	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1510:51: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
    iobroker	2019-08-12 16:28:34.120	info	/home/iobroker/.node-gyp/10.16.2/include/node/v8.h:1510:51: note: candidate: ‘static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::Scr
    iobroker	2019-08-12 16:28:34.120	info	In file included from ../src/validation.cc:7:
    iobroker	2019-08-12 16:28:34.120	info	return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
    iobroker	2019-08-12 16:28:34.120	info	../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for cal
    apollon77A Online
    apollon77A Online
    @helfi9999 Ich sehe das aktuell nur warnungen, alles ok
    H 2 Antworten Letzte Antwort
    • apollon77A apollon77
      H Online
      H Online
      helfi9999
      @apollon77 tja Problem geblieben nach der Installation keine DP's werden aktualisiert.
      Intel NUC mit Iobroker
        H Online
        H Online
        helfi9999
        @apollon77 selbst der web controller zeigt kein Cover, Track, Artist, Album an.
        • apollon77A Online
          apollon77A Online
          naja dfann ist die Wahrscheinlichste Erklärung die das Sonos was geändert hat und der Adapter jetzt das ändern muss. Und hier kommt genau das Thema: Ohne Sonos kriegt man das nicht raus ... also müssen wir schauen wie wir da weitermachen
          H 1 Antwort Letzte Antwort
            H Online
            H Online
            helfi9999
            @apollon77 das ist ärgerlich habe leider keine ahnung wie sowas geht sonst würde ich gerne helfen, habe gesehen das bluefox sich auch damit auskennt vielleicht hat er eine sonos im github habe ich auch schon reingeschrieben bis jetzt aber noch keine antwort.
            https://github.com/ioBroker/ioBroker.sonos/issues/48
            • H Offline
              hesse
              @apollon77 komischerweise funktinioniert die http-api von jishy ja noch sehr gut und die alten Installationen scheinen weiterhin zu laufen,also denke ich nicht, dass es an einer Änderung von Sonos liegt ... ich vermute aktuell, dass es an irgeneinder neueren Version von abhängigen Paketen liegt. Ich bin aktuell dabei beide Installation zu vergleichen und die Unterschiedlichen Versionen aufzulisten. Wenn ich fertig bin poste ich es hier ... vlt. hilft das bei der Analyse ...
              • H Offline
                hesse
                Also folgende Unterschiede hab ich gefunden:
                zusätzlich ist mir noch aufgefallen, das folgender Befehl als deprecated geflaggt ist:
                fs.exists
                • cashC Offline
                  cashC Offline
                  cash
                  Da ich die Auto Update Funktion von Sonos deaktiviert habe kann ich zumindest sagen das ich schon bestimmt 4 Wochen kein Sonos Update gemacht habe. Bei mir läuft der Adapter aber auch weiterhin ganz normal.
                  • H Offline
                    hesse
                    schrieb am zuletzt editiert von hesse
                    @Bluefox du bist mein Held! Vielen vielen Dank! Mit deiner Überarbeitung für Version 2.0.0 funktioniert bei mir die aktualisierung aller Datenpunkte wieder.
                    BluefoxB 1 Antwort Letzte Antwort
                    • H hesse
                      BluefoxB Offline
                      BluefoxB Offline
                      @hesse Es gibt aber kein SONOS-WEB mehr, da dieses Modul nicht vom Author weitergepflegt wird...
                      H H 2 Antworten Letzte Antwort
                      • BluefoxB Bluefox
                        H Online
                        H Online
                        helfi9999
                        @Bluefox du bist klasse. Danke die Sonos-Web brauche ich nicht habe mir alles in meiner Vis eingebaut.
                        • BluefoxB Bluefox
                          hesse
                          @Bluefox das ist kein Problem, die Sonos Web brauche ich auch nicht, das kann man ja alles selbst abbilden in seiner Visualisierung, hauptsache die Datenpunkte werden aktualisiert :)
                          Ich hätte noch ein paar Wünsche:
                          • Informationen der TV Funktionen, wenn man eine Soundbar verwendet (Nightmode, enhanced-speech-mode, loudness)
                          • Übertragungstyp: Stereo, DolbyDigital
                          Aber ich werde mir das erstmal selbst anschauen ob die Infos bereit gestellt werden, so dass man sie einbauen könnte.
                          Dir gilt auf jeden Fall ein großer Dank für den schnellen Fix, nun brauch ich mir nicht irgendwas komisches mit der http-api bauen :)
                            TJ1973
                            Nur um den Post (den ich mal gestartet habe) abzuschließen. Mein Problem wurde gelöst, indem ich über Github den neuesten Adapter installiert habe. Interessant wäre evtl. noch, dass in einer Gruppe nur der Player der die Führung hat aktualisiert wird. Die anderen nicht. Danke an alle, die mitdiskutiert haben.
