  4. MQTT und Tasmota
MQTT und Tasmota
mqtttasmotaiobroker
46 Beiträge 7 Kommentatoren 17.3k Aufrufe 4 Beobachtet
  • E Offline
    ecki945
    Hab ich. Leider hat sich nicht viel geändert.
    00:00:00 CFG: Loaded from flash at 3FB, Count 17
    00:00:00 Project sonoff Sonoff Version 6.5.0.16(sonoff)-2_5_2
    00:00:00 SNS: Hardware Serial
    00:00:00 WIF: Connecting to AP1 FRITZ!Box 7490 in mode 11N as sonoff-3209...
    00:00:04 WIF: Connected
    00:00:04 HTP: Web server active on sonoff-3209 with IP address 192.168.178.45
    19:35:20 MQT: Attempting connection...
    19:35:20 MQT: Connected
    19:35:20 MQT: tele/sonoff/LWT = Online (retained)
    19:35:20 MQT: cmnd/sonoff/POWER =
    19:35:20 RSL: tele/sonoff/INFO1 = {"Module":"Generic","Version":"6.5.0.16(sonoff)","FallbackTopic":"cmnd/DVES_63AC89_fb/","GroupTopic":"sonoffs"}
    19:35:20 MQT: tele/sonoff/INFO2 = {"WebServerMode":"Admin","Hostname":"sonoff-3209","IPAddress":"192.168.178.45"}
    19:35:20 MQT: tele/sonoff/INFO3 = {"RestartReason":"Software/System restart"}
    19:35:28 RSL: tele/sonoff/STATE = {"Time":"2019-08-11T19:35:28","Uptime":"0T00:00:14","Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":21,"Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"34:31:C4:38:A0:8B","Channel":11,"RSSI":66,"LinkCount":1,"Downtime":"0T00:00:04"}}
    19:35:28 RSL: tele/sonoff/SENSOR = {"Time":"2019-08-11T19:35:28","SML":{"Total_in":1635.5859,"Total_out":17788.1531,"Power_curr":308,"Meter_number":"0649534b011073747990"}}
    19:35:38 RSL: tele/sonoff/STATE = {"Time":"2019-08-11T19:35:38","Uptime":"0T00:00:24","Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"34:31:C4:38:A0:8B","Channel":11,"RSSI":66,"LinkCount":1,"Downtime":"0T00:00:04"}}
    19:35:38 RSL: tele/sonoff/SENSOR = {"Time":"2019-08-11T19:35:38","SML":{"Total_in":1635.5868,"Total_out":17788.1531,"Power_curr":308,"Meter_number":"0649534b011073747990"}}
    19:35:48 RSL: tele/sonoff/STATE = {"Time":"2019-08-11T19:35:48","Uptime":"0T00:00:34","Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"34:31:C4:38:A0:8B","Channel":11,"RSSI":66,"LinkCount":1,"Downtime":"0T00:00:04"}}
    19:35:48 RSL: tele/sonoff/SENSOR = {"Time":"2019-08-11T19:35:48","SML":{"Total_in":1635.5876,"Total_out":17788.1531,"Power_curr":308,"Meter_number":"0649534b011073747990"}}
    19:35:58 RSL: tele/sonoff/STATE = {"Time":"2019-08-11T19:35:58","Uptime":"0T00:00:44","Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"34:31:C4:38:A0:8B","Channel":11,"RSSI":64,"LinkCount":1,"Downtime":"0T00:00:04"}}
    19:35:58 RSL: tele/sonoff/SENSOR = {"Time":"2019-08-11T19:35:58","SML":{"Total_in":1635.5885,"Total_out":17788.1531,"Power_curr":317,"Meter_number":"0649534b011073747990"}}
    sonoff.0	2019-08-11 20:37:08.521	debug	Client [DVES_63AC89] pingreq
    sonoff.0	2019-08-11 20:37:05.395	debug	system.adapter.admin.0: logging true
    sonoff.0	2019-08-11 20:36:56.038	debug	system.adapter.admin.0: logging false
    sonoff.0	2019-08-11 20:36:53.487	debug	Client [DVES_63AC89] pingreq
    sonoff.0	2019-08-11 20:36:38.487	debug	stateChange sonoff.0.DVES_63AC89.POWER: {"val":false,"ack":true,"ts":1565548598480,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1565546656230}
    sonoff.0	2019-08-11 20:36:38.471	debug	[DVES_63AC89] Received: cmnd/sonoff/POWER =
    sonoff.0	2019-08-11 20:36:38.458	debug	stateChange sonoff.0.DVES_63AC89.alive: {"val":true,"ack":true,"ts":1565548598455,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1565548598455}
    sonoff.0	2019-08-11 20:36:38.429	debug	stateChange sonoff.0.info.connection: {"val":"DVES_63AC89","ack":true,"ts":1565548598412,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1565548598412}
    sonoff.0	2019-08-11 20:36:38.239	info	Client [DVES_63AC89] connected with secret 1565548598211_1404
    sonoff.0	2019-08-11 20:36:27.262	debug	stateChange sonoff.0.DVES_63AC89.alive: {"val":false,"ack":true,"ts":1565548587259,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1565548583399}
    sonoff.0	2019-08-11 20:36:27.220	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1565548587206,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1565548587206}
    sonoff.0	2019-08-11 20:36:27.191	info	Starting MQTT authenticated server on port 1882
    sonoff.0	2019-08-11 20:36:27.113	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.16.2
    sonoff.0	2019-08-11 20:36:27.067	debug	statesDB connected
    sonoff.0	2019-08-11 20:36:27.015	debug	objectDB connected
    Ich glaube da hat sich grundsätzlich nicht viel geändert.
    • E ecki945
      GlasfaserG Offline
      GlasfaserG Offline
      @ecki945
      Hast du auch den Sonoff Adapter neu gestartet !?
      • E Offline
        ecki945
        @Jan1 Deine Angaben sind nicht ganz korrekt:
        Nach dem Linken und Compilieren seh ich ja den "Speicherverbrauch":
        Der Sketch verwendet 585864 Bytes (56%) des Programmspeicherplatzes. Das Maximum sind 1044464 Bytes.
        Globale Variablen verwenden 49864 Bytes (60%) des dynamischen Speichers, 32056 Bytes für lokale Variablen verbleiben. Das Maximum sind 81920 Bytes.
        • E Offline
          ecki945
          @Glasfaser
          Ja Natürlich. Beide neu gestartet.
          GlasfaserG J 2 Antworten Letzte Antwort
          • E ecki945
            @Glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @ecki945
            Flash du ein fertige "bin " Datei ?
            • E Offline
              ecki945
              Nein. Selber compilieren. Aber wie schon geschrieben im original code nur die notwendigen defines anpassen.
              • E ecki945
                GlasfaserG Offline
                GlasfaserG Offline
                @ecki945
                Ahh .. schon mal ein ganz anderes Thema.
                Habe es auch mal versucht , aber mit fertigen bin war ich immer auf der richtigen Seite ,
                Da bin leider raus , aber Suche mal nach subscribe mqtt.
                • E ecki945
                  Jan1
                  @ecki945 sagte in MQTT und Tasmota:
                  Das sind nicht meine Angaben, sondern die von Dir gepostete. 4MB werden erkannt und 3MB davon verwendet. Wenn Du an der ini nichts geändert hättest, dann wäre sogar wie Du schon geschrieben hast nur 1MB verfügbar, da Tasmota offiziel nur 1MB Flash unterstützt.
                  Gegal, ist mir eben aufhefallen, dass fa schon was nicht stimmt.
                  • E ecki945
                    @Glasfaser
                    Jan1
                    @Glasfaser
                    Wie beide, Adapter und Device, oder hast den Sonoff und den MQTT Adapter parallel laufen?
                    • J Jan1
                      @Glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Jan1
                      Er hat nur den Sonoff Adapter an .
                      Er meint damit : Sonoff-Adapter und den ESP neu gestartet
                      • E Offline
                        ecki945
                        Guten Morgen. Es sind sonos und mqtt adapter installiert. Jedoch läuft nur der sonos adapter.
                        • E Offline
                          ecki945
                          Ich flashe mal eine fertige bin datei auf den esp8266 und werde wieder berichten.
                          • E Offline
                            ecki945
                            Rückmeldung für die Nachwelt:
                            Das neu compilieren mit den diesen Einstellungen in der Arduino IDE hatte leider kein Erfolg. Die "Nutzdaten" wurden in IO-Broker nicht angezeigt.
                            Auch das Austauschen der Plattform.txt Datei nicht:
                            "Replace in Arduino IDE folder portable\packages\esp8266\hardware\esp8266\2.5.2 file platform.txt with the Tasmota Source code file arduino\version 2.5.1\platform.txt.", beschrieben hier:
                            https://github.com/arendst/Sonoff-Tasmota/wiki/Arduino-IDE
                            Erst als ich im LIB Verzeichnis der Ardiuno IDE "aufgeräumt" habe, funktioniert nun die Datenübertragung komplett, mit den Boardeinstellungen von oben aus der Grafik.
                            Danke Euch für Eure Geduld und Tipps.
                            • E ecki945
                              Jan1
                              @ecki945
                              Warum kompilierst Du mit Arduino? Da muss man sehr genau wissen was man macht. Mit Atom oder VSC geht das direkt über Tasmota geregelt von ganz alleine. Ich nutze alle 3 und fahre mit VSC am besten.
                              • E Offline
                                ecki945
                                VSC oder Atom kennen ich nicht.
                                Wenn ich es richtig gegoogelt habe ist VSC == Visual Studio Code?
                                • E ecki945
                                  Jan1
                                  @ecki945
                                  Sind eigentlich die Standard Programme dafür und Tasmota so gestrickt, dass eben die Einstellungen automatisch gesetzt werden.
                                  Arduino setzt wesentlich mehr Grundwissen voraus und ist etwas umständlicher zu bedienen. Wenn Du damit zu recht kommst, ist das aber OK.
