  4. Testinstallation unter Node 12.6.0
testsystemnode 12
41 Beiträge 5 Kommentatoren 6.5k Aufrufe 5 Beobachtet
  • MathiasJM Offline
    MathiasJM Offline
    MathiasJ
    Na, hat niemand eine Idee?
    Ansonsten muß icch dann die testinstallation einstampfen.
    Die produktive Installation läuft ja unter Node 10.
    IObroker auf dem NUC als VM.
    • MathiasJM MathiasJ
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @MathiasJ
      Da ist der interessante Part:
      @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      node-pre-gyp install --fallback-to-build
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v72-linux-arm.tar.gz
      node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@12.6.0 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
      make: Entering directory '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build'
      CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
      ../src/BluetoothHciSocket.cpp: In static member function 'static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)':
      ../src/BluetoothHciSocket.cpp:129:82: error: no matching function for call to 'v8::FunctionTemplate::GetFunction()'
      target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());
      In file included from /home/mzaspel/.node-gyp/12.6.0/include/node/node.h:63:0,
      from /home/mzaspel/.node-gyp/12.6.0/include/node/node_buffer.h:25,
      from ../src/BluetoothHciSocket.cpp:7:
      /home/mzaspel/.node-gyp/12.6.0/include/node/v8.h:5948:46: note: candidate: v8::MaybeLocalv8::Function v8::FunctionTemplate::GetFunction(v8::Localv8::Context)
      V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
      /home/mzaspel/.node-gyp/12.6.0/include/node/v8.h:5948:46: note: candidate expects 1 argument, 0 provided
      ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::poll()':
      ../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value)' is deprecated [-Wdeprecated-declarations]
      Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      In file included from ../src/BluetoothHciSocket.cpp:8:0:
      ../../../nan/nan.h:1045:46: note: declared here
      NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
      ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::emitErrnoError()':
      ../src/BluetoothHciSocket.cpp:270:109: warning: 'v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));
      In file included from /home/mzaspel/.node-gyp/12.6.0/include/node/v8-internal.h:14:0,
      from /home/mzaspel/.node-gyp/12.6.0/include/node/v8.h:25,
      from /home/mzaspel/.node-gyp/12.6.0/include/node/node.h:63,
      /home/mzaspel/.node-gyp/12.6.0/include/node/v8.h:3412:55: note: declared here
      V8_DEPRECATE_SOON("Use maybe version", Local<Value> Get(Local<Value> key));
      /home/mzaspel/.node-gyp/12.6.0/include/node/v8config.h:326:3: note: in definition of macro 'V8_DEPRECATE_SOON'
      declarator attribute((deprecated(message)))
      ../src/BluetoothHciSocket.cpp:283:93: warning: 'v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value
      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)':
      ../src/BluetoothHciSocket.cpp:396:34: error: no matching function for call to 'v8::Value::IntegerValue()'
      devId = arg0->IntegerValue();
      /home/mzaspel/.node-gyp/12.6.0/include/node/v8.h:2565:40: note: candidate: v8::Maybe<long long int> v8::Value::IntegerValue(v8::Localv8::Context) const
      V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(
      /home/mzaspel/.node-gyp/12.6.0/include/node/v8.h:2565:40: note: candidate expects 1 argument, 0 provided
      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)':
      ../src/BluetoothHciSocket.cpp:418:34: error: no matching function for call to 'v8::Value::IntegerValue()'
      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::GetDeviceList(Nan::NAN_METHOD_ARGS_TYPE)':
      ../src/BluetoothHciSocket.cpp:471:77: warning: 'bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      obj->Set(Nan::New("devId").ToLocalChecked(), Nan::New<Number>(devId));
      /home/mzaspel/.node-gyp/12.6.0/include/node/v8.h:3359:26: note: declared here
      bool Set(Local<Value> key, Local<Value> value));
      ../src/BluetoothHciSocket.cpp:472:78: warning: 'bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      obj->Set(Nan::New("devUp").ToLocalChecked(), Nan::New<Boolean>(devUp));
      ../src/BluetoothHciSocket.cpp:473:68: warning: 'bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      obj->Set(Nan::New("idVendor").ToLocalChecked(), Nan::Null());
      ../src/BluetoothHciSocket.cpp:474:69: warning: 'bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      obj->Set(Nan::New("idProduct").ToLocalChecked(), Nan::Null());
      ../src/BluetoothHciSocket.cpp:475:69: warning: 'bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      obj->Set(Nan::New("busNumber").ToLocalChecked(), Nan::Null());
      ../src/BluetoothHciSocket.cpp:476:73: warning: 'bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)' is deprecated: Use maybe version [-Wdeprecated-declarations]
      obj->Set(Nan::New("deviceAddress").ToLocalChecked(), Nan::Null());
      binding.target.mk:105: recipe for target 'Release/obj.target/binding/src/BluetoothHciSocket.o' failed
      make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build'
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack at ChildProcess.emit (events.js:203:13)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
      gyp ERR! System Linux 4.19.57-rockchip
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" "--module_name=binding" "--module_path=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
      gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      gyp ERR! node -v v12.6.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      Dabei handelt es sich tatsächlich um einen Fehler bei der Kompilierung. Node 12 geht also wohl doch noch nicht.
      MathiasJM SegwayS 2 Antworten Letzte Antwort
      • AlCalzoneA AlCalzone
        @MathiasJ
        gyp ERR! not ok
        MathiasJM Offline
        MathiasJM Offline
        MathiasJ
        @AlCalzone
        Sagte ich doch!
        Dann kann ich mein Testsystem beruhigt wieder abbauen.
        Gruß,
        Mathias
          @AlCalzone
          Sagte ich doch!
          Gruß,
          Mathias
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @MathiasJ Dankeschön!
            @MathiasJ
            gyp ERR! not ok
            SegwayS Offline
            SegwayS Offline
            Segway
            @AlCalzone sagte in Testinstallation unter Node 12.6.0:
            Bei mir läuft node12 einwandfrei seit mehreren Tagen auf meinem Testsystem !
            Gruß Dirk
            AlCalzoneA MathiasJM 2 Antworten Letzte Antwort
            • SegwayS Segway
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @Segway Und nutzt du auch den BLE-Adapter?
              • SegwayS Segway
                MathiasJM Offline
                MathiasJM Offline
                MathiasJ
                @Segway
                und den Adapter Radar2 nutzt Du auch unter node 12.6.0 nicht?
                Der läuft auf Node 12.6.0 nämlich auch nur mit hcitool only.
                • SegwayS Offline
                  SegwayS Offline
                  Segway
                  Nein benutze ich nicht ... brauche das so nicht bzw. habe es anders gelöst.
                  Hätte deutlicher schreiben sollen dass grundsätzlich node 12 funktioniert nur halt mit einigen Adaptern (noch) nicht. Das wird schnell überlesen und wenn dann nur noch sowas steht
                  dann gilt das lediglich für den Adapter aber nicht für das gesamte System oder andere Adapter :-) ist ja nicht umsonst der Hinweis. Aber viele Standard-Adapter gehen ja bereits.
                  Gruß Dirk
                  MathiasJM AlCalzoneA 2 Antworten Letzte Antwort
                  • SegwayS Segway
                    MathiasJM Offline
                    MathiasJM Offline
                    MathiasJ
                    @Segway
                    Bei mir lief die Testinstallation auch unter Node 12.
                    Nur die Adapter Radar2 mit noble und eben BLE nicht.
                    Das habe ich ja mehrfach erwähnt.
                    • SegwayS Segway
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @Segway meine Aussage war bezogen auf Matthias tests mit BLE, nicht auf node12 ansich
