  4. [Aufruf] Alexa2 2.6.0 Testen
alexa 2 adapter
254 Beiträge 25 Kommentatoren 46.7k Aufrufe 26 Beobachtet
  • sigi234S Online
    sigi234S Online
    $ ./iobroker url "https://github.com/Apollon77/ioBroker.alexa2.git"
    install https://github.com/Apollon77/ioBroker.alexa2/tarball/master
    npm install https://github.com/Apollon77/ioBroker.alexa2/tarball/master --production --save --prefix "C:/ioBroker" (System call)
    ERROR: internal/modul
    ERROR: es/cjs/loader.js:798
        throw err;
    SyntaxError: C:\ioBroker\node_modules\iobroker.alexa2\io-package.json: Unexpected token , in JSON at position 18635
        at JSON.parse (<anonymous>)
        at Object.Module._extensions..json (internal/modules/cjs/loader.js:795:27)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        at Module.require (internal/modules/cjs/loader.js:690:17)
        at requi
    ERROR: re (internal/modules/cjs/helpers.js:25:18)
        at Upload.uploadAdapter (C:\ioBroker\node_modules\iobroker.js-controller\lib\setup\setupUpload.js:266:19)
        at install.npmInstall (C:\ioBroker\node_modules\iobroker.js-controller\lib\setup.js:775:40)
        at ChildProcess.child.on (C:\ioBroker\node_modules\iobroker.js-controller\lib\setup\setupInstall.js:382:31)
    ERROR: process exited with code 1
    • apollon77A Offline
      Retry ...Fixed ... mensch bist Du schnell
      • apollon77A apollon77
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @apollon77 sagte in [Aufruf] Alexa2 2.6.0 Testen:
        hat jetzt geklappt :)
        $ ./iobroker url "https://github.com/Apollon77/ioBroker.alexa2/tarball/master" alexa2
        npm install https://github.com/Apollon77/ioBroker.alexa2/tarball/master --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
        npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        got /opt/iobroker/node_modules/iobroker.alexa2/admin
        upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
        upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
        upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
        upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
        upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
        upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
        upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
        upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
        upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
        upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
        upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
        upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
        upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
        upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
        upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
        upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
        upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
        upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
        process exited with code 0
        ° Fixer ---> iob fix
        • NegaleinN Offline
          NegaleinN Offline
          Negalein
          alle Kontakte sind da
          Nachrichten schicken funktioniert
          eigene Nachricht löschen (Button) funktioniert
          • NegaleinN Negalein
            sigi234S Online
            sigi234S Online
            @Negalein sagte in [Aufruf] Alexa2 2.6.0 Testen:
            Ja, bei mir auch..........Danke.
            • NegaleinN Offline
              NegaleinN Offline
              Negalein
              bei manchen Kontakten steht noch null dabei
              zB
              aber dann ein zusätzlicher Eintrag vom selben Kontakt ohne null
              • MicM Offline
                MicM Offline
                Mic
                Getestet, funktioniert wunderbar :-)
                Seh cool Ingo, vielen Dank!
                Das mit "null" habe ich auch bei ein paar Kontakten. Aber die will ich eh nicht kontaktieren 😁
                Interessant, von wo jetzt diese Kontakte herkommen, war mir nicht bewusst. Wohl aus dem Telefonbuch (Handy), und alle, die eine Alexa haben?
                  zB
                  @Negalein Dann ist bei einem Kontakt nur ein Vorname gesetzt und kein Nachname ...
                  Bitte nochmal neu von Github laden (immer noch 2.6.0). Ist immer noch da aber ohne dem null.
                  Der erste in deiner Liste ist irgendwas spezielles ... müsste man mal sehen was passiert wenn Du da was hin sendest :-)
                  • MicM Mic
                    @Mic sagte in [Aufruf] Alexa2 2.6.0 Testen:
                    Geh in die Alexa App, zweites Icon unten von links ... da hast Du genau das ...
                    MicM 1 Antwort Letzte Antwort
                      Hey All,
                      ich habe mal wieder etwas Zeit genutzt und noch weitere offene Dinge abgearbeitet und so ist auf GitHub gerade die v2.6.0 verfügbar und ich bitte um Tests 🙂
                      Changelog:
                      • Der Adapter liesst nun auch die Kontakte aus und listet diese unter "alexa2.0.Contacts" auf
                      • jeder Kontakt kann eine Textnachricht (wie per App) bekommen, Es leuchtet dasnn bei allen seinen Devices der Ring "gelb"
                      • Der eigene Kontakt ist speziell mit einem "(Self)" im Namen gekennzeichnet und hat einen Zusätzlichen Button um alle Nachrichten die an sich selbst gesendet wurden (also Sender und Empfänger sind identisch). Dabei ist es aber egal ob die vom Adapter angelegt wurden oder per App!
                      • In den Adapter.Settings kann man jetzt die Cookies resetten. Nach Speichern und Neustart müssen die Cookies neu gesetzt werden.
                      • Announcement und SSML werden jetzt mit einem Kommando gesendet, was synchroner bei Gruppen sein sollte. Speak bleibt wie bisher weil geht nicht anders
                      Installation über Custom Install/"die Katze" und danach Instanz manuell neu starten.
                      Bitte prüft vor allem Speak, Announce und SSML und viel Spass mit den Kontakten und auf viele gelbe Ringe :-)
                      Ingo
                      sigi234S Online
                      sigi234S Online
                      Hm......ist es vielleicht machbar das es eine Option gibt mit Contacts einlesen ja/nein? Oder einen Filter welche angezeigt werden sollen?
                      apollon77A GarfonsoG 2 Antworten Letzte Antwort
                      • sigi234S sigi234
                        @sigi234 Warum?
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          die null sind noch da
                            MicM Offline
                            MicM Offline
                            Mic
                            Da sind aber deutlich mehr Kontakte geführt als im Adapter. Weil diese keine Alexa haben, verknüpft mit Telefon? Echt interessant...
                            • sigi234S sigi234
                              GarfonsoG Offline
                              GarfonsoG Offline
                              Garfonso
                              @sigi234
                              die Funktion wünsche ich mir dringend für die Alexa App... aber das ist hier leider der falsche Rahmen. ;-)
                              Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                              Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
                                @Negalein Dann brauche ich log, gern per email an iobroker@fischer-ka.de. Am Ende vom Starten des Adapters hängt das Kontakt-Zeug. Ein Request lädt ie gesamte Kontaktliste und daraus wird dann aussortiert was der Adapter anzeigt.
                                • GarfonsoG Garfonso
                                  @sigi234
                                  @Garfonso Wie meinst Du das? Die Alexa-App hat genau diese Option ... Sie wurde mehrfach für den Adapter gewünscht, also hier ists. Man muss es ja nicht nutzen :-) (Ich persönlich habe auch keine Anwendung dafür)
                                  GarfonsoG 1 Antwort Letzte Antwort
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    jetzt sind sie ohne null da. Hat wohl etwas länger gedauert.
                                    • NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      ssml funktioniert auch
                                        @sigi234 Warum?
                                        sigi234S Online
                                        sigi234S Online
                                        @sigi234 Warum?
                                        Bin kein Freund von Nachnahmen, aber ich sehe gerade das man die Namen ändern kann...........
                                          @Negalein Bitte auch Gruppen testen
