  4. [gelöst]Backup & Restore klappt nicht
39 Beiträge 11 Kommentatoren 8.3k Aufrufe 3 Beobachtet
  • D DirtyAtze
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:49: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       v8::String::Utf8Value path(info[0]->ToString());
    In file included from /home/pi/.node-gyp/10.16.0/include/node/v8.h:26,
                     from /home/pi/.node-gyp/10.16.0/include/node/node.h:63,
                     from ../../nan/nan.h:54,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    /home/pi/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../src/serialport.cpp:48:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       v8::Local<v8::Object> options = info[1]->ToObject();
    In file included from /home/pi/.node-gyp/10.16.0/include/node/node.h:63,
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    In file included from ../src/./serialport.h:6,
    ../../nan/nan.h:1740:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:113:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:250:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../nan/nan.h:54,
    /home/pi/.node-gyp/10.16.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.node-gyp/10.16.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/pi/.node-gyp/10.16.0/include/node/node_object_wrap.h:84:78:   required from here
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /home/pi/.node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /home/pi/.node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    In file included from ../src/serialport.h:6,
                     from ../src/serialport_unix.cpp:2:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    In file included from ../src/poller.cpp:1:
    ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
    ../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       obj->callback.Call(2, argv);
        Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.79:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    pi@raspberrypi:~ $
    @DirtyAtze
    und?
    @DirtyAtze sagte in [gelöst]Backup & Restore klappt nicht:
      DirtyAtze
      Das sagt der fix:
      pi@raspberrypi:~ $ curl -sL https://iobroker.net/fix.sh | bash -
          Welcome to the ioBroker installation fixer!
          Script version: 2019-07-03
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      bash: Zeile 667: /opt/iobroker/iobroker: Keine Berechtigung
      chmod: Zugriff auf '/opt/iobroker/iobroker' nicht möglich: Datei oder Verzeichnis nicht gefunden
      chown: Zugriff auf '/opt/iobroker/iobroker' nicht möglich: Datei oder Verzeichnis nicht gefunden
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:~ $
      ist das in Ordnung?
      HomoranH AlCalzoneA 2 Antworten Letzte Antwort
      • D DirtyAtze
        Das sagt der fix:
        Autostart enabled!
        pi@raspberrypi:~ $
        ist das in Ordnung?
        Das sagt der fix:
        ein fix sollte jetzt nicht mehr nötig sein, aber:
        das muss sich @AlCalzone ansehen.
          DirtyAtze
          Und da ist auch schon der "trim fehler":
          pi@raspberrypi:~ $ iobroker status
          iobroker is running
          Objects type: file
          States  type: file
          pi@raspberrypi:~ $ iobroker stop
          pi@raspberrypi:~ $ iobroker restore
          Please specify one of the backup names:
          minimal_2019_07_07-20_35_35_backupiobroker.tar.gz or minimal_2019_07_07-20_35_35 or 0
          minimal_2019_07_05-09_15_24_std_backupiobroker.tar.gz or minimal_2019_07_05-09_15_24_std or 1
          pi@raspberrypi:~ $ iobroker restore 1
          /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568
                  if (parseInt(name.trim(), 10).toString() === name.trim().toString()) {
          TypeError: name.trim is not a function
              at BackupRestore.restoreBackup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568:27)
              at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1474:28)
              at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3087:29)
              at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:184:26)
              at runCallback (timers.js:705:18)
              at tryOnImmediate (timers.js:676:5)
              at processImmediate (timers.js:658:5)
          pi@raspberrypi:~ $
            DirtyAtze
            OK, nach änder der backupSetup.js ist es jetzt tatsächlich durchgelaufen!
            dann mal vielen Dank für die Unterstützung!!!
            • D DirtyAtze
              Das sagt der fix:
              Autostart enabled!
              pi@raspberrypi:~ $
              ist das in Ordnung?
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @DirtyAtze welche Ausgabe liefert
              ls -la /opt/iobroker
                DirtyAtze
                Werd ich heute Abend mal schauen.
                  DirtyAtze
                  Sorry, etwas verspätet...
                  • D DirtyAtze
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @DirtyAtze Ok danke ich hab ne Idee woran es liegt. Kannst du bitte noch die Ausgabe von folgendem Befehl posten?
                    sudo getfacl /opt/iobroker/iobroker
                      DirtyAtze
                      Last login: Sun Jul 14 11:14:57 2019 from 192.168.178.12
                      pi@raspberrypi:~ $ sudo getfacl /opt/iobroker/iobroker
                      getfacl: Entferne führende '/' von absoluten Pfadnamen
                      # file: opt/iobroker/iobroker
                      # owner: iobroker
                      # group: iobroker
                      user::rwx
                      group::r-x
                      group:iobroker:rwx              #effective:r-x
                      mask::r-x
                      other::r-x
                      pi@raspberrypi:~ $
