  4. Raspberry Pi4 läuft!
    6.7k
pi4 buster
138 Beiträge 32 Kommentatoren 30.8k Aufrufe 22 Beobachtet
    denjo
    #84
    so, alles läuft außer mein tr-064 adapter
    host.raspberrypi
    2019-07-06 10:20:03.794
    info
    Restart adapter system.adapter.tr-064.0 because enabled
    host.raspberrypi
    error
    instance system.adapter.tr-064.0 terminated with code 1 ()
    host.raspberrypi
    error
    Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    host.raspberrypi
    error
    Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    host.raspberrypi
    error
    Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:829:12)
    host.raspberrypi
    error
    Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi
    error
    Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi
    error
    Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi
    error
    Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
    host.raspberrypi
    error
    Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
    host.raspberrypi
    error
    Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
    host.raspberrypi
    error
    Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    host.raspberrypi
    error
    Caught by controller[0]: TypeError: fns.adapter is not a function
    host.raspberrypi
    error
    Caught by controller[0]: ^
    host.raspberrypi
    error
    Caught by controller[0]: fns.adapter = fns.adapter(options);
    host.raspberrypi
    2019-07-06 10:20:03.793
    error
    Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
    • J Jan1
      @denjo
      Nein habe ich ja oben schon geschrieben, installiert alle Adapter neu außer manuell erstellt. Ist auch einer der großen Unterschiede zum Komplettbackup. Da wird einfach der IOBroker Ordner wieder hergestellt, so wie er vorher auch war und genau da liegt der Knackpunkt, wenn man das System wechselt.
      BBTownB Online
      BBTownB Online
      BBTown
      schrieb am zuletzt editiert von BBTown
      #85
      @denjo sagte in Raspberry Pi4 läuft!:
      Suche mal im Forum nach Themen zum tr-064, da gibt es eine Anleitung das zu fixen
      node v.8.x läuft nicht auf einem Pi4 (Buster)
      • D denjo
        host.raspberrypi
        info
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        host.raspberrypi
        error
        Jan1
        #86
        @denjo
        Du musst die community Version des Adapter über Github installieren oder den soef Fix anwenden. Bekanntes Problem und schon reichlich hier besprochen.
        • S Stoni
          bin grad durch Zufall auf den pi4 aufmerksam geworden. Nutze bislang den Pi3, der ansich auch noch ausreicht. Aber man will ja für die Zukunft gewappnet sein. Der pi4 besticht in aller erster Linie durch die 4gb RAM im Vergleich zu 1GB beim Vorgänger.
          Kann ich die sd-Karte von Pi 3 einfach im pi4 weiter nutzen oder muss ich alles neu aufsetzen? Könnte man dann zumindest ein aktuelles Backup vom backitup Adapter einspielen?
          Früher oder später möchte ich gerne ne SSD dran hängen. Da wäre die gleiche Frage mit dem Backup.
          VG Stoni
          Ach so, wo habt ihr bestellt? ;-)
          Markus MüllerM Offline
          Markus Müller
          #87
          @Stoni Danke, das du das gefragt hast. Bin ins Forum gekommen und das gleiche zu fragen :)
          • MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            #88
            @denjo
            das Problem hatte ich auch.
            mach mal:
            cd /opt/iobroker/
            iobroker stop tr-064
            cd /opt/iobroker/node_modules/iobroker.tr-064
            npm install soef
            Dann muß es wieder gehen.
            Gruß,
            Mathias
            IObroker auf dem NUC als VM.
            • MathiasJM MathiasJ
              @denjo
              mach mal:
              cd /opt/iobroker/
              npm install soef
              Gruß,
              Mathias
              denjo
              #89
              @MathiasJ läuft schon wieder mit der neuen version, aber danke
              MathiasJM 1 Antwort Letzte Antwort
              • D denjo
                MathiasJM Offline
                MathiasJM Offline
                MathiasJ
                #90
                @denjo
                bitte nichts zu danken.
                Ich warte mal, bis der neue Adapter in der Repro ist.....
                und außerdem muß ich immer noch auf den Raspberry PI 4B warten 😞
                • D darkiop
                  @Homoran sagte in [Raspberry Pi4 läuft!]
                  Noch bin ich nicht durch mit Testen ;-)
                  Bin gespannt ;)
                  Wenn ich mich richtig erinnere macht man auf dem Pi mit "rpi-update" ein FW Update
                  #91
                  @darkiop sagte in Raspberry Pi4 läuft!:
                  Bin gespannt ;)
                  Danke für diese Info, aber:
                  WARNING: 'rpi-update' updates to pre-releases of the linux
                  kernel tree and Videocore firmware.
                  'rpi-update' should only be used if there is a specific
                  reason to do so - for example, a request by a Raspberry Pi
                  engineer.
                  DO NOT use 'rpi-update' as part of a regular update process.
                  ich mach es trotzdem, auch wenn es noch pre-release ist.
                  Auf dem offiziellen Weg ist nämlich noch nichts da
                    #92
                    Erster Eindruck:
                    keine Änderung.
                    Ich hatte den Raspi jetzt ein paar Tage aus, daher die Lücke in der Grafik.
                    Die letzten Tage lag der Durchschnitt bei etwa 55°C
                    Heute morgen neu hochgefahren, da brauchte es wohl ein paar Minuten bis der Kühlkörper duchheizte. bis dahin lag die Temp sogar bei etwa 50°C.
                    Aktuell liegt die Temperatur zwischen 55 und 58°C, also zumindest keine signifikante Erniedrigung der Temperatur.
                    Entweder ist es noch nicht in der Firmware drin, oder es bringt im Routinebetrieb nicht wirklich viel.
                      #93
                      Habe jetzt fleißig weiter getestet.
                      Zuerst habe ich den winzigen Standard-RPi-Kühler gegen den Kühler vom Tinkerboard getauscht. Das brachte immerhin etwa 3°C Absenkung der SOC-Temperatur.
                      Danach habe ich einen Monsterkühler genommen, der es mir erlaubte den BPi M3 über längere Zeit ohne Hitzeabstürze zu betreiben.
                      richtig brachte das aber nichts.
                      Selbst nachdem ich diesen Kühler mit Leitpaste (statt flüssiger Biokomponente) anklebte kamen veilleicht nochmal 2°C niedrigere Temperatur heraus.
                      Da dieser Kühler sehr lange "Finger" besitzt und die passive Temperaturabgabe nichts nutze, musste jetzt also noch die Wärmeabfuhr verbessert werden.
                      Also kam der Lüfter kurzentschlossen in meinen SBC-Schrank vor den 140mm Lüfter:
                      Das war dann wirklich was:
                      Die Temperatur liegt in dieser Kombination jetzt bei etwa 36°C
                        Erster Eindruck:
                        keine Änderung.
                        #94
                        @Homoran sagte:
                        Die letzten Tage lag der Durchschnitt bei etwa 55°C ...
                        Die Werte sind völlig in Ordnung. Interessant wäre das Verhalten in einem Standard-Gehäuse.
                          @Homoran sagte:
                          #95
                          @paul53 sagte in Raspberry Pi4 läuft!:
                          bis 65°C würde ichmir auch keine Sorgen machen.
                          Jepp!
                          Habe gerade nur dieses hier gefunden.
                          Die Dealer meines Vertrauens vor Ort (+/-) haben keine
                            Jepp!
                            MathiasJM Offline
                            MathiasJM Offline
                            MathiasJ
                            #96
                            @Homoran
                            Bin gespannt, wann die kühlerlosen Gehäuse kommen.
                            Ich habe mir so ein billiges Teil für den PI 3B+ aus Alu in der Bucht gekauft.
                            Der PI 3B+ ist jetzt ca 20 Grad kühler.
                            Für den PI 4B habe ich das Teil leider noch nicht gesehen, wäre aber durchaus interessant
                              @Homoran
                              #97
                              @MathiasJ sagte in Raspberry Pi4 läuft!:
                              Die Gehäuse für den Pi3 müssten mit ein wenig Anpassungen auch gehen.
                              Ich wollte das gerade testen, hatte den Pi4 schon heruntergefahren und fand dann mein Reserve-Gehäuse nicht mehr...
                              muss es wohl schon irgendwo verwendet haben.
                              Habe nucr noch ein Charly Gehäuse. Das ist aber nicht repräsentativ wenn man es nur als Pi-Gehäuse nutzt.
                                denjo
                                #98
                                Bei welchen Temperaturen sollte man sich denn sorgen machen meiner liegt aktuell bei 58 Grad ohne Gehäuse und Kühl Körper, ist aber alles bestellt???
                                • D denjo
                                  #99
                                  @denjo
                                  ich würde mir bis 65°C gar keine Gedanken machen, kurzfristig bis 70°C auch nicht.
                                  Irgendwo in den tiefen des Betriebssystems sind auch die max. Temperatur, bevor er runterfährt eingetragen.
                                  Müsste ich aber selber googeln wo.
                                    @denjo
                                    denjo
                                    #100
                                    @Homoran alles klar dann wird ich das mal beobachten wenn mein Gehäuse usw kommt, denke mal morgen
                                      MathiasJM Offline
                                      MathiasJM Offline
                                      MathiasJ
                                      #101
                                      @Homoran
                                      das wird wohl nicht gehen. Es handelt sich hierbei um dieses Gehäuse:
                                      https://www.pollin.de/p/joy-it-armor-gehaeuse-block-fuer-raspberry-pi-3-alu-schwarz-811012?&gclid=CjwKCAjw04vpBRB3EiwA0IieaqMSMgJ3OqvlPccsEtuS02h70zEwHhhbZs1IKEBVy0h2aTTVRazyjhoC0vcQAvD_BwE
                                      Gruß,
                                      Mathias
                                      paul53P HomoranH 2 Antworten Letzte Antwort
                                        @Homoran
                                        Gruß,
                                        Mathias
                                        #102
                                        @MathiasJ sagte:
                                        Das ist kein Gehäuse, sondern ein überdimensionierter Kühlkörper.
                                          @Homoran
                                          Gruß,
                                          Mathias
                                          #103
                                          Warum nicht?
                                          Ich weiß nicht wie es drinnen aussieht, aber die Unterschiede "nach Außen" liegen in den 2 Micro HDMI statt eines HDMI und dem USB-C statt des Micro-USB für die Stromversorgung.
                                          An diesen Stellen hat das Gehäuse
                                          nur einen Schlitz, wenn ich es auf dem Bild richtig sehe.
                                          Auf dem Board hat sich zwar ein wenig getan, aber bis auf die Pins für den PoE Anschluss sehe ich da auf anhieb nichts wirklich störendes
                                          paul53P MathiasJM 2 Antworten Letzte Antwort
