  4. [Aufruf] Tuya Adapter Tests verschlüsselte Geräte
tuya
209 Beiträge 27 Kommentatoren 63.9k Aufrufe 14 Beobachtet
  • apollon77A apollon77
    Das bleibt erhalten. Ist in de Objekten gespeichert
    Old_EngineerO
    Old_EngineerO
    Old_Engineer
    @apollon77 1.07 jetzt installiert, Initialspeicherverbrauch ~50 MB Er hat aber doch einige Objekte verloren, die neuen Rolladenschalter aber auch Lichtschalter die lange in Betrieb waren.
    Bei der Installation bekomme ich folgende Meldungen, diese habe ich bisher ignoriert, weil die schon bei der Erstinstalltion von 1.07 kamen mit der ich keine Probleme hatte.
    npm
    WARN
    deprecated clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    host.raspberrypi install adapter tuya
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.tuya"
    npm
    WARN deprecated clipboard-js@0.3.6: Please migrate to https://github.com/lgarron/clipboard-polyfill
    npm
    WARN
    deprecated
    gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    npm
    WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm
    WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm
    WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm
    WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm
    notice created a lockfile as package-lock.json. You should commit this file.
    npm
    WARN
    • apollon77A
      apollon77A
      Ja die Meldungen kannst Du ignorieren,
      Was meinst Du mit Objekte verloren? Der löscht an sich keine Objekte ... was sagt das log?
      Old_EngineerO 1 Antwort Letzte Antwort
        Old_EngineerO
        Old_EngineerO
        Old_Engineer
        @apollon77 Unter tuya.0 fehlen Geräte die vorher da waren.
        Im log nur rpi, mqtt, javascript, info und web - nix von tuya
        Speicherverbrauch jetzt nach 1 Stunde ~ 65 MB, steigt also auch
        • apollon77A
          apollon77A
          Mal reloaded? Der Adaoter löscht an sich keine Devices die da sind - also wenn Du nur adapter neu installiert hast kann das an sich nicht sein. Irgendwelche Filter?
            Old_EngineerO
            Old_EngineerO
            Old_Engineer
            @apollon77 Ich hatte sogare den ganzen Raspi neu gestartet. Hatte jetzt nochmal den Proxy gestartet und mit der (Android) Smart Life APP aktualisiert. Auf den ersten Blick ist alles wieder da, Speicher ~63 MB
            tuya.0 2019-07-04 13:56:19.399 info Discover for local Tuya devices on port 6666
            tuya.0 2019-07-04 13:56:19.398 info Existing devices initialized
            tuya.0 2019-07-04 13:56:19.398 info 16388024cc50e3c8f20a Init with IP=192.168.1.107, Key=5ff318e520f44e6a
            tuya.0 2019-07-04 13:56:19.398 info 45007282dc4f22734986: Can not start because IP unknown
            tuya.0 2019-07-04 13:56:19.398 info 72510830bcddc2e48d01: Can not start because IP unknown
            tuya.0 2019-07-04 13:56:19.398 info 87874800dc4f22ec3531 Init with IP=192.168.1.110, Key=71cf909fa51006eb
            tuya.0 2019-07-04 13:56:19.398 info 16388024cc50e3c90117 Init with IP=192.168.1.106, Key=4573f7b21b443b16
            tuya.0 2019-07-04 13:56:19.398 info 05075075dc4f22e89e9a: Can not start because IP unknown
            tuya.0 2019-07-04 13:56:19.398 info 16388024cc50e3c8f006 Init with IP=192.168.1.111, Key=3645ca507eca6b3f
            tuya.0 2019-07-04 13:56:19.398 info 16388024cc50e3c900ff: Can not start because IP unknown
            tuya.0 2019-07-04 13:56:19.397 info 87874800dc4f22ee9510: Can not start because IP unknown
            tuya.0 2019-07-04 13:56:19.397 info 05075075dc4f22eb7e6f: Can not start because IP unknown
            tuya.0 2019-07-04 13:56:19.397 info 45007282ecfabc4afb57: Can not start because IP unknown
            tuya.0 2019-07-04 13:56:19.397 info 16388024cc50e3c8fca7 Init with IP=192.168.1.104, Key=d9ea1862444b567d
            tuya.0 2019-07-04 13:56:19.397 info 4446311768c63ae253f2 Init with IP=192.168.1.117, Key=da6378621503b424
            tuya.0 2019-07-04 13:56:19.397 info 87874800dc4f22ee973d Init with IP=192.168.1.102, Key=2a734db6b8fc7636
            tuya.0 2019-07-04 13:56:19.396 info 87874800dc4f22ecc671 Init with IP=192.168.1.109, Key=7d6bc97429f33dbf
            tuya.0 2019-07-04 13:56:18.646 info starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.16.0
            tuya.0 2019-07-04 13:56:09.623 info starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.16.0
            tuya.0 2019-07-04 13:56:09.296 error no connection to objects DB
            • v522533V
              v522533V
              v522533
              Ich kann das mit dem Speicherverbrauch bestätigen. Gestern neue Version vom Adapter installiert. Initial mit ca. 140 MB Ram gelaufen. Heute nach der Arbeit steht der Adapter bei 180 Mb Ram. Sonst keine Auffälligkeiten.
              Gruß Chris
              • lobomauL lobomau
                @apollon77 ich würde behaupten, dass der proxy nicht an war. Ich habe mal den Adapter neugestartet, er beginnt bei 45 MB. Ich beobachte mal wohin er geht.
                nach 2Std: 50 MB
                nach 5 STd.: 56 MB
                lobomauL
                lobomauL
                lobomau
                schrieb am zuletzt editiert von lobomau
                @lobomau sagte in [Aufruf] Tuya Adapter Tests verschlüsselte Geräte:
                nach 2Std: 50 MB
                nach 5 STd.: 56 MB
                nach 7 Std.: 57 MB
                ich hatte dann mal die Steckdose abgemacht und später wieder angesteckt. Adapter blieb dann gelb. Leider ist der Neustart des Adapters bei mir nicht erfolgreich:
                host.iobroker	2019-07-04 18:35:13.279	info	Restart adapter system.adapter.tuya.0 because enabled
                host.iobroker	2019-07-04 18:35:13.279	error	instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
                host.iobroker	2019-07-04 18:35:12.153	info	instance system.adapter.tuya.0 started with pid 11173
                host.iobroker	2019-07-04 18:35:07.273	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                Das hatte ich schon mal. Ich habe durch einen Neustart von ioBroker es wieder ans Laufen gebracht. Wahrscheinlich läuft der Prozess doppelt. Man kann ja auch Prozesse einzeln beenden. Muss ich nochmal nachlesen wie das ging. kill pid...
                Wenn ich "top" eingebe sehe ich keine io.tuya Process laufen.
                Host: NUC8i3 mit Proxmox:
                • Slave: Pi4
                  Da wäre jetzt natürlich mal interessant wie sich die 1.0 da vorher verhalten hat ...
                  Old_EngineerO
                  Old_EngineerO
                  Old_Engineer
                  @apollon77 Ich würde mal sagen, der Adapter 1.07 liegt bei meinem Setup konstant bei 65-67 MB.
                  Ich habe nun doch verschlüsselte (Rolladenschalter) gefunden, die ich nicht schalten kann. Gemeldete Version 1.1.6, die 1.1.4 aus der gleichen Bestellung funktionieren, die 1.1.6 waren bisher nicht im Einsatz. Merkwürdigerweise melden beide "Neueste Firmware bereits installiert". Schalter sind auch absolut baugleich.
                  • apollon77A
                    apollon77A
                    #66
                    Alles im Bereich bis 80 MB können normale Standard Fluktuationen sein, sogar mehr je nach Anzahl der Devices und so ... auch fluktuationen +/-50MB sind wenig.
                    Error 7 kann vorkommen. Sollte nicht tut es aber.
                    Ich habe auch gleiche Geräte wo die App sagt das kein FW Update bereitsteht aber es andere Versionen sind. Es gibt halt nur die vorinstallierte FW und keine Updates ...
                    v522533V 1 Antwort Letzte Antwort
                      v522533V
                      v522533V
                      v522533
                      #67
                      @apollon77
                      ich habe gestern abend gegen 19:00 die Instanz neu gestartet. Ging los bei 45 MB, heute morgen sind es schon wieder 130 MB. Tendenz steigend.
                      Gruß Chris
                      lobomauL apollon77A 2 Antworten Letzte Antwort
                      • v522533V v522533
                        @apollon77
                        lobomauL
                        lobomauL
                        lobomau
                        #68
                        @v522533 sagte in [Aufruf] Tuya Adapter Tests verschlüsselte Geräte:
                        @apollon77
                        ich habe auch ungefähr zu der Zeit neugestartet. Bin jetzt bei 69 MB.
                        • Slave: Pi4
                        • v522533V v522533
                          @apollon77
                          apollon77A
                          apollon77A
                          #69
                          @v522533 Wie viele Tuya Geräte? nodejs version?
                          v522533V 3 Antworten Letzte Antwort
                            v522533V
                            v522533V
                            v522533
                            #70
                            @apollon77
                            node 10.16.0, 4 Geräte davon 2 verschlüsselt und 2 unverschlüsselt. (2 Teckin Steckdosen und 2 Gosund Steckdosen)
                            Gruß Chris
                              v522533V
                              v522533V
                              v522533
                              #71
                              @apollon77
                              Zwischenstand: 20:00 220MB
                              Gruß Chris
                                v522533V
                                v522533V
                                v522533
                                #72
                                @apollon77
                                gestern Abend 23 Uhr: Instanz stand bei 280 MB. Habe dann neu gestartet. Daraufhin haben alle verbundenen Steckdosen sich ausgeschaltet. Danach gings wieder bei 45 MB los und alles lief ohne Fehler. Heute Morgen wieder bei 140 MB.
                                Gruß Chris
                                • apollon77A
                                  apollon77A
                                  #73
                                  Warum auch immer sich die Steckdosen ausschalten sollten. Komisch.
                                  • v522533V v522533
                                    @apollon77
                                    apollon77A
                                    apollon77A
                                    #74
                                    @v522533 schalten die sich auch aus wenn du normal den Adapter beendest?
                                    • v522533V
                                      v522533V
                                      v522533
                                      schrieb am zuletzt editiert von v522533
                                      #75
                                      @apollon77
                                      ne das ganze ist auch nicht nachzuvollziehen, ist bisher nur einmal beim neustart passiert.
                                      Gruß Chris
                                      • marcusklM
                                        marcusklM
                                        marcuskl
                                        #76
                                        Ich habe mir 2 Gosund Sp111 geholt und in der Smart Life App hinzugefügt und wollte dann mit dem Tuya Adapter die Geräte wie bescjreiben hinzufügen, aber das klappt nicht.
                                        Hier ein auszug aus meinem Log:
                                        2019-07-15 17:46:25.911  - error: Caught by controller[0]: { Error: bind EADDRINUSE 0.0.0.0:6666
                                        2019-07-15 17:46:25.912  - error: Caught by controller[0]:     at _handle.lookup (dgram.js:266:18)
                                        2019-07-15 17:46:25.912  - error: Caught by controller[0]:     at _combinedTickCallback (internal/process/next_tick.js:142:11)
                                        2019-07-15 17:46:25.912  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:181:9)
                                        2019-07-15 17:46:25.912  - error: Caught by controller[0]:   errno: 'EADDRINUSE',
                                        2019-07-15 17:46:25.912  - error: Caught by controller[0]:   code: 'EADDRINUSE',
                                        2019-07-15 17:46:25.912  - error: Caught by controller[0]:   syscall: 'bind',
                                        2019-07-15 17:46:25.912  - error: Caught by controller[0]:   address: '0.0.0.0',
                                        2019-07-15 17:46:25.912  - error: Caught by controller[0]:   port: 6666 }
                                        2019-07-15 17:46:25.912  - error: Caught by controller[1]: { Error: bind EADDRINUSE 0.0.0.0:6667
                                        2019-07-15 17:46:25.912  - error: Caught by controller[1]:     at _handle.lookup (dgram.js:266:18)
                                        2019-07-15 17:46:25.913  - error: Caught by controller[1]:     at _combinedTickCallback (internal/process/next_tick.js:142:11)
                                        2019-07-15 17:46:25.913  - error: Caught by controller[1]:     at process._tickCallback (internal/process/next_tick.js:181:9)
                                        2019-07-15 17:46:25.913  - error: Caught by controller[1]:   errno: 'EADDRINUSE',
                                        2019-07-15 17:46:25.913  - error: Caught by controller[1]:   code: 'EADDRINUSE',
                                        2019-07-15 17:46:25.913  - error: Caught by controller[1]:   syscall: 'bind',
                                        2019-07-15 17:46:25.913  - error: Caught by controller[1]:   address: '0.0.0.0',
                                        2019-07-15 17:46:25.913  - error: Caught by controller[1]:   port: 6667 }
                                        2019-07-15 17:46:25.913  - error: host.iobroker instance system.adapter.tuya.0 terminated with code 6 (uncaught exception)
                                        2019-07-15 17:46:25.913  - info: host.iobroker Restart adapter system.adapter.tuya.0 because enabled
                                        2019-07-15 17:46:27.529  - info: tuya.0 Anyproxy ready to receive requests
                                        2019-07-15 17:46:53.197  - info: info.0 Popup-News readed...
                                        2019-07-15 17:46:55.923  - info: host.iobroker instance system.adapter.tuya.0 started with pid 27153
                                        2019-07-15 17:46:56.554  - error: Caught by controller[0]: [AnyProxy WARN][2019-07-15 17:46:27]: both "-i(--intercept)" and rule.beforeDealHttpsRequest are specified, the "-i" option will be ignored.
                                        2019-07-15 17:46:56.554  - error: host.iobroker instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
                                        2019-07-15 17:46:56.554  - info: host.iobroker Restart adapter
                                        Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
                                        Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
                                        • marcusklM marcuskl
                                          apollon77A
                                          apollon77A
                                          #77
                                          @marcuskl dann belegt irgendetwas anderes auf dem Host den Port 6666 und 6667. finde das und beende es.
                                          marcusklM 1 Antwort Letzte Antwort
                                          83.9k
