  4. [Aufruf] Test Shelly Adapter
shellyadapter
717 Beiträge 81 Kommentatoren 262.8k Aufrufe 30 Beobachtet
    dos1973
    #461
    es kommen keine Coap...
    shelly.0	2019-05-28 19:59:24.718	debug	stateChange shelly.0.SHSW-25#737AB7#1.Relay1.Switch {"val":true,"ack":false,"ts":1559066364715,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1559066364715}
    shelly.0	2019-05-28 19:59:15.220	debug	stateChange shelly.0.SHSW-25#737AB7#1.Relay0.Switch {"val":true,"ack":false,"ts":1559066355216,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1559066355216}
    shelly.0	2019-05-28 19:58:56.994	debug	stateChange shelly.0.SHSW-25#72EB49#1.Shutter.Position {"val":100,"ack":false,"ts":1559066336990,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1559066336990}
    shelly.0	2019-05-28 19:58:16.810	debug	stateChange shelly.0.SHSW-1#2C7A2E#1.Relay0.Switch {"val":true,"ack":false,"ts":1559066296804,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1559066296804}
    shelly.0	2019-05-28 19:57:51.046	debug	stateChange shelly.0.SHSW-1#25A1AB#1.Relay0.Switch {"val":false,"ack":false,"ts":1559066271044,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1559066271044}
    shelly.0	2019-05-28 19:57:51.042	debug	stateChange shelly.0.SHSW-1#25A1AB#1.Relay0.Switch {"val":true,"ack":false,"ts":1559066271037,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1559066271037}
    shelly.0	2019-05-28 19:56:21.474	debug	system.adapter.admin.0: logging true
    shelly.0	2019-05-28 19:56:19.022	info	Listening for Shelly packets in the network
    shelly.0	2019-05-28 19:56:18.930	info	Stating Shelly adapter in CoAP modus.
    shelly.0	2019-05-28 19:56:18.759	info	starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    shelly.0	2019-05-28 19:56:18.689	debug	statesDB connected
    shelly.0	2019-05-28 19:56:18.645	debug	objectDB connected
    host.ioBroker	2019-05-28 19:56:17.682	info	instance system.adapter.shelly.0 started with pid 2874
    host.ioBroker	2019-05-28 19:56:15.196	info	instance system.adapter.shelly.0 terminated with code 0 (OK)
    shuttercontrol.0	2019-05-28 19:56:15.168	info	object system.adapter.shelly.0 changed: {"_id":"system.adapter.shelly.0","type":"instance","common":{"name":"shelly","version":"3.0.2","news":{"2.0.6":{"en":"Getting faster online status for Shelly d
    shelly.0	2019-05-28 19:56:15.162	info	Closing Adapter
    host.ioBroker	2019-05-28 19:56:15.149	info	stopInstance system.adapter.shelly.0 killing pid 2426
    shelly.0	2019-05-28 19:56:15.150	info	Closing Adapter
    • DiginixD Offline
      DiginixD Offline
      Diginix
      #462
      Ist COAP im Shelly überhaupt aktiviert?
      ..:: So long! Tom ::..
        dos1973
        schrieb am zuletzt editiert von dos1973
        #463
        ja, nicht bei allen. aber mit denen ich teste ja
        also das ist aktiv.
          dos1973
          #464
          ich würde den adapter gerne mal komplett entfernen und neu installieren, oder braucht es hier noch eine Info um den Fehler ggfs. zu verstehen?
            dos1973
            #465
            na das habe ich ja heute mächtig "verk....." und das Geschwätz zu Hause nervt am meisten... alles deinstalliert und den 3.02 neu installiert. es passiert nix. Der Adapter findet keine Shelly. Ich Versuchs jetzt nochmals mit 2.2.0
              dos1973
              #466
              ist der 2.20 auch schon auf COAP umgebaut? oder habe ich hier irgendetwas falsch gemacht?
              ich brauch hier echt Hilfe, bin am Ende und habe keinen Schimmer was ich noch machen kann.
              StuebiS 1 Antwort Letzte Antwort
              • D dos1973
                StuebiS Offline
                StuebiS Offline
                Stuebi
                #467
                @dos1973 , der Shelly Adapter läuft auch auf CoAP. Du musst für CoAP nichts installieren. Das spricht der Shelly out of the Box.
                ioBroker auf Synology DS216+II im Docker Container
                  dos1973
                  #468
                  ich habe ja jetzt alles auf Anfang... aber es tut sich leider nichts
                  • D dos1973
                    StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    #469
                    @dos1973 , was heißt am Anfang? Welche Adapter Version hast Du installiert?
                    Hast Du irgendwelche Netzwerkkomponenten ausgetauscht, z.B. Swich etc.?
                      dos1973
                      #470
                      ja, ich habe heute einen Unifi AP in mein Netzwerk gebaut... hatte ich vorher schon geschrieben.
                      Aber IP und Namen hat sich nichts verändert. Der DHCP ist weiterhin wie vorher meine Fritzbox.
                      Wenn ich jetzt in das alte Wlan Netzwerk switch gehts auch nicht.
                      jetzt habe ich den Adapter 2.08
                      • D dos1973
                        StuebiS Offline
                        StuebiS Offline
                        Stuebi
                        #471
                        @dos1973 sagte in [Aufruf] Test Shelly Adapter:
                        Das Problem liegt an Deinem Netzwerk. Das CoAP Netzwerkprotokoll verschickt UDP Multicast Nachrichten. Wenn der Adapter diese nicht empfängt, bleiben die irgendwo im Netzwerk hängen.
                        Entweder Du suchst den Fehler im Netzwerk oder installierst den Shelly Adapter in Version 3.0.2 und stellst alles auf MQTT um. Dann geht aber die Shelly Cloud nicht mehr (falls Du die benötigst)
                          dos1973
                          #472
                          kann ich das irgendwie testen (manuell) mit dem UDP Multicast... also nur Obst wirklich daran liegt?
                          die cloud nutze ich nicht, was heißt denn alles umstellen auf mqtt, habe keine Vorstellung was das bedeutet. was würdest du denn empfehlen, eher suchen oder umstellen?
                          • D dos1973
                            StuebiS Offline
                            StuebiS Offline
                            Stuebi
                            #473
                            @dos1973 , das kann ich Dir nicht sagen. Ich selber würde nach dem Fehler suchen. Kannst aber parallel dazu auf MQTT stellen.
                            Hier findest Du wie es geht: https://github.com/schmupu/ioBroker.shelly/blob/master/docs/EN/INSTALL.md
                              dos1973
                              #474
                              nach dem Fehler suchen ist gut ;-)
                              daher die frage, wie ich es testen kann...
                              edit: mit mqtt gehts sofort, aber es geht nur entweder/ oder ?
                              • D dos1973
                                StuebiS Offline
                                StuebiS Offline
                                Stuebi
                                #475
                                @dos1973 , also ich würde im Internet nach Unifi AP und Multicast / UDP suchen. Vielleicht gibt es andere Leute mit ähnlichen Problemen. Die Unifi Doku hilft ja auch weiter. Da ist ein wenig Forschergeister gefragt.
                                Wenn Du es leichter haben willst, dann lassen die Shellys im MQTT Modus laufen. Dann hast Du den Stress mit den Multicast nicht.
                                • StuebiS Stuebi
                                  dos1973
                                  #476
                                  @Stuebi
                                  ich schaue mal wie weit ich komme...
                                  prinzipiell hätte ich gesagt, multicast ist weniger gut... aber ich bin Laie
                                  • D dos1973
                                    @Stuebi
                                    StuebiS Offline
                                    StuebiS Offline
                                    Stuebi
                                    #477
                                    @dos1973 , es gibt da kein gut oder schlecht CoAP (Multicast) und MQTT haben Vor und Nachteile.
                                    Ich selber nutze Beides (muss ich ja auch wegen der Adapter Entwicklung)
                                      dos1973
                                      #478
                                      ich habe noch etwas bei mir im Netz rumgespielt...
                                      jetzt schaut es so aus, es kommen eine Shellys zum Vorschein.
                                      ich habe in allen shelly "COAP" eingestellt
                                      Alle angezeigten Werte stimmen, ip etc. Aber ich kann die shelly nicht aus iobroker schalten, noch wird der zustand angezeigt.
                                      Echt komisch?!?
                                      ich mac Schluß für heute... kein Lust mehr und manchmal ist mal eine Nacht ruhen lassen ganz hilfreich.
                                      • D dos1973
                                        Echt komisch?!?
                                        StuebiS Offline
                                        StuebiS Offline
                                        Stuebi
                                        #479
                                        @dos1973 , welche Version hast du jetzt installiert? Und was steht in Log?
                                        In der Version 3.0.3 die noch nicht offiziell ist, habe ich noch einen Fehler den ich in der nächsten Stunde behebe.
                                          Apropo
                                          #480
                                          Also prinzipiell gibt es mit UniFi keine Probleme und da gibt's soweit ich weiß auch nichts was man einstellen kann. Bei mir läuft alles perfekt darüber. Und du sagst ja auch, dass es über das Wlan der Fritzbox auch nicht klappt, oder?
                                          Nutzt du evtl. ein managed Switch woran dein Iobroker Gerät hängt? Vielleicht blockiert das Switch da was.
