  4. gelöst: Dash Adapter: wrong ELF class
dash
5 Beiträge 3 Kommentatoren 440 Aufrufe 2 Beobachtet
    derrapf
    schrieb am zuletzt editiert von derrapf
    Hi alle
    Ich habe IOBroker auf einen Rock64 portiert.
    Beim Dash Button Adapter (0.3.1) habe ich Probleme. Beim Starten kommt immer "wrong ELF class: ELFCLASS32"
    host.ioBroker-Rock64	2019-05-02 22:45:00.078	info	instance system.adapter.tvspielfilm.0 started with pid 28856
    host.ioBroker-Rock64	2019-05-02 22:41:58.123	info	Do not restart adapter system.adapter.amazon-dash.0 because disabled or deleted
    host.ioBroker-Rock64	2019-05-02 22:41:58.123	error	instance system.adapter.amazon-dash.0 terminated with code 3 (Adapter disabled or invalid config)
    Caught	2019-05-02 22:41:58.123	error	by controller[0]: at Module.load (module.js:566:32)
    Caught	2019-05-02 22:41:58.122	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    Caught	2019-05-02 22:41:58.122	error	by controller[0]: at Module._compile (module.js:653:30)
    Caught	2019-05-02 22:41:58.122	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/pcap/pcap.js:3:21)
    Caught	2019-05-02 22:41:58.122	error	by controller[0]: at require (internal/module.js:11:18)
    Caught	2019-05-02 22:41:58.122	error	by controller[0]: at Module.require (module.js:597:17)
    Caught	2019-05-02 22:41:58.122	error	by controller[0]: at Function.Module._load (module.js:498:3)
    Caught	2019-05-02 22:41:58.122	error	by controller[0]: at tryModuleLoad (module.js:506:12)
    Caught	2019-05-02 22:41:58.121	error	by controller[0]: at Module.load (module.js:566:32)
    Caught	2019-05-02 22:41:58.121	error	by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    Caught	2019-05-02 22:41:58.120	error	by controller[0]: Error: /opt/iobroker/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32
    amazon-dash.0	2019-05-02 22:41:58.053	error	adapter disabled
    amazon-dash.0	2019-05-02 22:41:57.888	info	States connected to redis: 127.0.0.1:6379
    amazon-dash.0	2019-05-02 22:41:57.730	error	at Module.load (module.js:566:32)
    amazon-dash.0	2019-05-02 22:41:57.730	error	at Object.Module._extensions..js (module.js:664:10)
    amazon-dash.0	2019-05-02 22:41:57.730	error	at Module._compile (module.js:653:30)
    amazon-dash.0	2019-05-02 22:41:57.730	error	at Object.<anonymous> (/opt/iobroker/node_modules/pcap/pcap.js:3:21)
    amazon-dash.0	2019-05-02 22:41:57.730	error	at require (internal/module.js:11:18)
    amazon-dash.0	2019-05-02 22:41:57.730	error	at Module.require (module.js:597:17)
    amazon-dash.0	2019-05-02 22:41:57.730	error	at Function.Module._load (module.js:498:3)
    amazon-dash.0	2019-05-02 22:41:57.730	error	at tryModuleLoad (module.js:506:12)
    amazon-dash.0	2019-05-02 22:41:57.730	error	at Object.Module._extensions..node (module.js:682:18)
    amazon-dash.0	2019-05-02 22:41:57.730	error	Error: /opt/iobroker/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32
    amazon-dash.0	2019-05-02 22:41:57.718	error	uncaught exception: /opt/iobroker/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS3
    Node ist v8.15.0
    NPM ist 6.9.0.
    Gruss Ralf
    • ? Offline
      pcap installiert?
      apt-get install libpcap-dev
      • D derrapf
        Hi alle
        Node ist v8.15.0
        NPM ist 6.9.0.
        Gruss Ralf
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @derrapf sagte in Dash Adapter: wrong ELF class:
        ELFCLASS32"
        Du hast Binaries, die für ein 32-bit-System kompiliert waren auf ein 64-bit-System übertragen. Das läuft nicht, die musst du neu kompilieren.
        Im besten Fall sollte das mit einem npm rebuild im Ordner /opt/iobroker funktionieren. Andernfalls kannst du auch in /opt/iobroker/node_modules/pcap/ ein npm i --production ausführen, um nur das pcap-Modul neu zu kompilieren.
          pcap installiert?
          derrapf
          @Yetiberg
          Ja.
          Reading package lists... Done
          Building dependency tree
          libpcap-dev is already the newest version (1.8.1-3).
          0 upgraded, 0 newly installed, 0 to remove and 19 not upgraded.
          Gruss Ralf
          • AlCalzoneA AlCalzone
            ELFCLASS32"
            derrapf
            @AlCalzone
            Ok. Hab ich mal gemacht:
            root@ioBroker-Rock64:~# cd /opt/iobroker
            root@ioBroker-Rock64:/opt/iobroker# npm rebuild
            > iobroker.amazon-dash@0.3.1 preinstall /opt/iobroker/node_modules/iobroker.amazon-dash
            > apt install libpcap-dev -y || true
            > pcap@2.1.0 install /opt/iobroker/node_modules/pcap
            > node-gyp rebuild
            make: Entering directory '/opt/iobroker/node_modules/pcap/build'
              CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
              CXX(target) Release/obj.target/pcap_binding/pcap_session.o
            ../pcap_session.cc: In static member function 'static void PcapSession::PacketReady(u_char*, const pcap_pkthdr*, const u_char*)':
            ../pcap_session.cc:85:102: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                 Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(session->packet_ready_cb), 0, NULL);
            In file included from ../pcap_session.h:4:0,
                             from ../pcap_session.cc:7:
            ../../nan/nan.h:929:46: note: declared here
               NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
              SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
              COPY Release/pcap_binding.node
            make: Leaving directory '/opt/iobroker/node_modules/pcap/build'
            > socketwatcher@0.3.0 install /opt/iobroker/node_modules/socketwatcher
            > node-gyp rebuild
            make: Entering directory '/opt/iobroker/node_modules/socketwatcher/build'
              CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
            ../socket_watcher.cpp: In static member function 'static void SocketWatcher::Callback(uv_poll_t*, int, int)':
            ../socket_watcher.cpp:77:60: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
               Nan::MakeCallback(watcher->handle(), callback, argc, argv);
            In file included from ../socket_watcher.hpp:8:0,
                             from ../socket_watcher.cpp:5:
              SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
              COPY Release/socketwatcher.node
            make: Leaving directory '/opt/iobroker/node_modules/socketwatcher/build'
            > iobroker.javascript@4.1.12 postinstall /opt/iobroker/node_modules/iobroker.javascript
            > node ./install/installTypings.js
            Installing NodeJS typings...
            latest @types: 12, installed node: 8
            npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/http-signature/package.json
            npm ERR! code ENOENT
            npm ERR! errno -2
            npm ERR! syscall open
            npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/http-signature/package.json'
            npm ERR! enoent This is related to npm not being able to find a file.
            npm ERR! enoent
            npm ERR!     /root/.npm/_logs/2019-05-07T22_05_58_217Z-debug.log
            Sieht aber nicht so gesund aus oder?
            Die zweite genannte Möglichkeit:
            root@ioBroker-Rock64:/opt/iobroker# cd /opt/iobroker/node_modules/pcap/
            root@ioBroker-Rock64:/opt/iobroker/node_modules/pcap# npm i --production
            npm WARN deprecated istanbul@0.3.22: This module is no longer maintained, try this instead:
            npm WARN deprecated   npm i nyc
            npm WARN deprecated Visit https://istanbul.js.org/integrations for other alternatives.
            npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
            npm WARN deprecated coffee-script@1.3.3: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
            npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
            npm WARN deprecated to-iso-string@0.0.2: to-iso-string has been deprecated, use @segment/to-iso-string instead.
            npm WARN deprecated formatio@1.1.1: This package is unmaintained. Use @sinonjs/formatio instead
            npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
            npm WARN deprecated samsam@1.1.2: This package has been deprecated in favour of @sinonjs/samsam
            npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
            npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
            npm WARN deprecated samsam@1.1.3: This package has been deprecated in favour of @sinonjs/samsam
            npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
            npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
            npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
            npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
            npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
            > socketwatcher@0.3.0 install /opt/iobroker/node_modules/pcap/node_modules/socketwatcher
            > node-gyp rebuild
            make: Entering directory '/opt/iobroker/node_modules/pcap/node_modules/socketwatcher/build'
            ../../nan/nan.h:959:46: note: declared here
            make: Leaving directory '/opt/iobroker/node_modules/pcap/node_modules/socketwatcher/build'
            npm WARN lifecycle pcap@2.1.0~install: cannot run in wd pcap@2.1.0 node-gyp rebuild (wd=/opt/iobroker/node_modules/pcap)
            npm notice created a lockfile as package-lock.json. You should commit this file.
            npm WARN pcap@2.1.0 No license field.
            added 2 packages from 10 contributors and audited 318 packages in 38.721s
            found 40 vulnerabilities (9 low, 19 moderate, 11 high, 1 critical)
              run `npm audit fix` to fix them, or `npm audit` for details
            Immerhin: Man kann amazon.dash starten ohne Abstürze:
            amazon-dash.0	2019-05-08 00:09:39.194	info	starting pcap session on default interface
            amazon-dash.0	2019-05-08 00:09:39.184	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.15.0
            Allerdings bleibt der Adapter rot...
            Nein! Stimmt nicht. Eben ist er grün geworden. Hat nur ne Weile gedauert
            Prima!
            Danke für die Hilfe!
            Gruss Ralf
