  4. [Aufruf] Test Shelly Adapter
shellyadapter
717 Beiträge 81 Kommentatoren 262.9k Aufrufe 30 Beobachtet
    Merowinger
    schrieb am zuletzt editiert von Merowinger
    #304
    Eigentlich lief der Adapter bislang wunderbar.. Jetzt habe ich ein Problem. Ich kann nur noch selten ein Gerät steuern und der log sagt folgendes
    2019-02-24 07:40:26.569 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:40:26.574 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:40:26.574 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    2019-02-24 07:40:38.103 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.178.70 vis.0
    2019-02-24 07:40:56.578 - info: host.iobroker instance system.adapter.shelly.0 started with pid 9005
    2019-02-24 07:40:56.945 - info: shelly.0 starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    2019-02-24 07:40:56.964 - info: shelly.0 Starting shelly.0 in version 2.1.4
    2019-02-24 07:40:57.004 - info: shelly.0 Listening for Shelly packets in the network
    2019-02-24 07:40:58.697 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.178.70
    2019-02-24 07:41:11.765 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:41:11.771 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:41:11.771 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    2019-02-24 07:41:15.378 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.178.70 vis.0
    2019-02-24 07:41:41.776 - info: host.iobroker instance system.adapter.shelly.0 started with pid 9015
    2019-02-24 07:41:42.104 - info: shelly.0 starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    2019-02-24 07:41:42.117 - info: shelly.0 Starting shelly.0 in version 2.1.4
    2019-02-24 07:41:42.151 - info: shelly.0 Listening for Shelly packets in the network
    2019-02-24 07:41:56.951 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:41:56.956 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:41:56.956 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    2019-02-24 07:42:23.146 - info: host.iobroker object change system.adapter.shelly.0
    2019-02-24 07:42:23.146 - info: host.iobroker "system.adapter.shelly.0" disabled
    2019-02-24 07:42:27.277 - error: shelly.0 adapter disabled
    2019-02-24 07:42:27.290 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 3 (Adapter disabled or invalid config)
    2019-02-24 07:42:27.296 - info: host.iobroker Do not restart adapter system.adapter.shelly.0 because disabled or deleted
    2019-02-24 07:42:34.606 - info: iobroker del shelly.0
    2019-02-24 07:42:34.816 - info: iobroker Delete adapter "shelly.0"
    2019-02-24 07:42:34.830 - info: iobroker host.iobroker Counted 1 instances of shelly
    2019-02-24 07:42:34.837 - info: iobroker host.iobroker Counted 14 devices of shelly.0
    2019-02-24 07:42:34.844 - info: iobroker host.iobroker Counted 31 channels of shelly.0
    2019-02-24 07:42:34.856 - info: iobroker host.iobroker Counted 173 states of shelly.0
    2019-02-24 07:42:34.935 - info: iobroker host.iobroker Counted 152 states (io.shelly.0.) from states
    2019-02-24 07:42:34.941 - info: iobroker host.iobroker Counted 8 states (system.adapter.shelly.0.
    ) from states
    2019-02-24 07:42:35.210 - info: iobroker host.iobroker Deleting 219 object(s).
    2019-02-24 07:42:35.262 - info: iobroker host.iobroker: Only 200 objects left to be deleted.
    2019-02-24 07:42:35.622 - info: host.iobroker object change system.adapter.shelly.0
    2019-02-24 07:42:35.622 - info: host.iobroker object deleted system.adapter.shelly.0
    2019-02-24 07:42:35.623 - info: iobroker host.iobroker Deleting 160 state(s).
    2019-02-24 07:42:35.843 - info: iobroker exit 0
    2019-02-24 07:42:46.325 - info: iobroker _restart
    2019-02-24 07:42:46.438 - info: iobroker Starting node restart.js
    2019-02-24 07:42:46.444 - info: iobroker exit 0
    2019-02-24 07:42:46.512 - info: host.iobroker received SIGTERM
    2019-02-24 07:42:51.518 - info: host.iobroker received SIGTERM
    2019-02-24 07:42:56.526 - info: host.iobroker force terminating
    2019-02-24 07:42:56.527 - info: Adapter admin still running
    2019-02-24 07:42:56.527 - info: Adapter discovery still running
    2019-02-24 07:42:56.527 - info: Adapter fritzbox still running
    2019-02-24 07:42:56.527 - info: Adapter tr-064 still running
    2019-02-24 07:42:56.527 - info: Adapter web still running
    2019-02-24 07:42:56.527 - info: Adapter javascript still running
    2019-02-24 07:42:56.527 - info: Adapter fritzdect still running
    2019-02-24 07:42:56.527 - info: Adapter scenes still running
    2019-02-24 07:42:56.527 - info: Adapter onvif still running
    2019-02-24 07:42:56.547 - info: host.iobroker received SIGTERM
    2019-02-24 07:43:01.856 - info: host.iobroker iobroker.js-controller version 1.4.2 js-controller starting
    2019-02-24 07:43:01.857 - info: host.iobroker Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2019-02-24 07:43:01.857 - info: host.iobroker hostname: iobroker, node: v8.15.0
    2019-02-24 07:43:01.858 - info: host.iobroker ip addresses: 192.168.178.138 fe80::b4f5:beff:fecc:dde4
    2019-02-24 07:43:01.879 - info: host.iobroker inMem-states listening on port 9000
    2019-02-24 07:43:01.916 - info: host.iobroker inMem-objects listening on port 9001
    2019-02-24 07:43:01.920 - info: host.iobroker InMemoryDB connected
    2019-02-24 07:43:01.924 - info: host.iobroker 31 instances found
    2019-02-24 07:43:01.928 - info: host.iobroker starting 22 instances
    2019-02-24 07:43:01.938 - info: host.iobroker instance system.adapter.admin.0 started with pid 9111
    2019-02-24 07:43:02.563 - error: admin.0 setObject id missing!!
    2019-02-24 07:43:02.567 - info: admin.0 starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
    2019-02-24 07:43:02.573 - info: admin.0 requesting all states
    2019-02-24 07:43:02.573 - info: admin.0 requesting all objects
    2019-02-24 07:43:02.573 - info: admin.0 Request actual repository...
    2019-02-24 07:43:02.690 - info: admin.0 received all states
    2019-02-24 07:43:02.859 - info: admin.0 received all objects
    2019-02-24 07:43:02.921 - info: host.iobroker Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    2019-02-24 07:43:02.880 - info: admin.0 http server listening on port 8081
    2019-02-24 07:43:02.880 - info: admin.0 Use link "http://localhost:8081" to configure.
    2019-02-24 07:43:04.558 - info: admin.0 Repository received successfully.
    2019-02-24 07:43:05.933 - info: host.iobroker instance system.adapter.discovery.0 started with pid 9128
    2019-02-24 07:43:06.227 - info: discovery.0 starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v8.15.0
    2019-02-24 07:43:09.936 - info: host.iobroker instance system.adapter.fritzbox.0 started with pid 9138
    2019-02-24 07:43:10.317 - info: fritzbox.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v8.15.0
    2019-02-24 07:43:10.320 - info: fritzbox.0 try to connect: 192.168.178.1
    2019-02-24 07:43:10.334 - info: fritzbox.0 adapter connected to fritzbox: 192.168.178.1
    2019-02-24 07:43:13.933 - info: host.iobroker instance system.adapter.tr-064.0 started with pid 9148
    2019-02-24 07:43:14.341 - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.15.0
    2019-02-24 07:43:17.933 - info: host.iobroker instance system.adapter.web.0 started with pid 9158
    2019-02-24 07:43:18.354 - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.15.0
    2019-02-24 07:43:18.483 - info: web.0 socket.io server listening on port 8082
    2019-02-24 07:43:18.484 - info: web.0 http server listening on port 8082
    2019-02-24 07:43:22.243 - info: vis.0 starting. Version 1.1.7 in /opt/iobroker/node_modules/iobroker.vis, node: v8.15.0
    2019-02-24 07:43:22.317 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.178.70
    2019-02-24 07:43:22.664 - info: vis.0 vis license is OK.
    2019-02-24 07:43:23.591 - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
    2019-02-24 07:43:25.932 - info: host.iobroker instance system.adapter.javascript.0 started with pid 9178
    2019-02-24 07:43:26.585 - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.15.0
    2019-02-24 07:43:26.588 - info: javascript.0 requesting all states
    2019-02-24 07:43:26.592 - info: javascript.0 requesting all objects
    2019-02-24 07:43:26.696 - info: javascript.0 received all states
    2019-02-24 07:43:26.860 - info: javascript.0 received all objects
    2019-02-24 07:43:26.900 - info: javascript.0 Start javascript script.js.common.Raff_runter
    2019-02-24 07:43:26.905 - info: javascript.0 script.js.common.Raff_runter: registered 1 subscription and 0 schedules
    2019-02-24 07:43:26.905 - info: javascript.0 Start javascript script.js.common.Raff_nauf
    2019-02-24 07:43:26.906 - info: javascript.0 script.js.common.Raff_nauf: registered 1 subscription and 0 schedules
    2019-02-24 07:43:35.670 - info: iobroker add shelly --host iobroker
    2019-02-24 07:43:35.916 - info: iobroker host.iobroker create instance shelly
    2019-02-24 07:43:35.923 - info: iobroker host.iobroker object shelly.0.info.connection created
    2019-02-24 07:43:35.955 - info: iobroker host.iobroker object shelly.0.info created
    2019-02-24 07:43:35.982 - info: iobroker host.iobroker object system.adapter.shelly.0.outputCount created
    2019-02-24 07:43:36.008 - info: iobroker host.iobroker object system.adapter.shelly.0.inputCount created
    2019-02-24 07:43:36.036 - info: iobroker host.iobroker object system.adapter.shelly.0.uptime created
    2019-02-24 07:43:36.063 - info: iobroker host.iobroker object system.adapter.shelly.0.memRss created
    2019-02-24 07:43:36.091 - info: iobroker host.iobroker object system.adapter.shelly.0.memHeapTotal created
    2019-02-24 07:43:36.118 - info: iobroker host.iobroker object system.adapter.shelly.0.memHeapUsed created
    2019-02-24 07:43:36.146 - info: iobroker host.iobroker object system.adapter.shelly.0.connected created
    2019-02-24 07:43:36.174 - info: iobroker host.iobroker object system.adapter.shelly.0.alive created
    2019-02-24 07:43:36.204 - info: host.iobroker object change system.adapter.shelly.0
    2019-02-24 07:43:36.208 - info: host.iobroker instance system.adapter.shelly.0 started with pid 9198
    2019-02-24 07:43:36.209 - info: iobroker host.iobroker object system.adapter.shelly.0 created
    2019-02-24 07:43:36.216 - info: iobroker exit 0
    2019-02-24 07:43:36.813 - info: shelly.0 starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    2019-02-24 07:43:36.816 - info: shelly.0 Starting shelly.0 in version 2.1.4
    2019-02-24 07:43:36.869 - info: shelly.0 Listening for Shelly packets in the network
    2019-02-24 07:43:38.274 - info: vis-google-fonts.0 starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v8.15.0
    2019-02-24 07:43:38.827 - info: host.iobroker instance system.adapter.vis-google-fonts.0 terminated while should be started once
    2019-02-24 07:43:45.933 - info: host.iobroker instance system.adapter.fritzdect.0 started with pid 9219
    2019-02-24 07:43:46.528 - info: fritzdect.0 starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v8.15.0
    2019-02-24 07:43:46.530 - info: fritzdect.0 entered ready
    2019-02-24 07:43:50.607 - info: fritzdect.0 Talking to FritzBox with firmware: 07.01
    2019-02-24 07:43:50.796 - info: fritzdect.0 create Devices 1
    2019-02-24 07:43:50.796 - info: fritzdect.0 setting up Repeater/DECT100 object FRITZ!DECT Repeater Küche
    2019-02-24 07:43:57.360 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:43:57.366 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:43:57.367 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    2019-02-24 07:44:09.931 - info: host.iobroker instance system.adapter.scenes.0 started with pid 9229
    2019-02-24 07:44:10.219 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v8.15.0
    2019-02-24 07:44:25.931 - info: host.iobroker instance system.adapter.onvif.0 started with pid 9239
    2019-02-24 07:44:26.347 - info: onvif.0 starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.onvif, node: v8.15.0
    2019-02-24 07:44:27.370 - info: host.iobroker instance system.adapter.shelly.0 started with pid 9249
    2019-02-24 07:44:27.690 - info: shelly.0 starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    2019-02-24 07:44:27.706 - info: shelly.0 Starting shelly.0 in version 2.1.4
    2019-02-24 07:44:27.741 - info: shelly.0 Listening for Shelly packets in the network
    2019-02-24 07:44:42.473 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:44:42.479 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:44:42.479 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    2019-02-24 07:45:12.483 - info: host.iobroker instance system.adapter.shelly.0 started with pid 9259
    2019-02-24 07:45:12.805 - info: shelly.0 starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    2019-02-24 07:45:12.817 - info: shelly.0 Starting shelly.0 in version 2.1.4
    2019-02-24 07:45:12.856 - info: shelly.0 Listening for Shelly packets in the network
    2019-02-24 07:45:27.671 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:45:27.675 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:45:27.676 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    2019-02-24 07:45:57.678 - info: host.iobroker instance system.adapter.shelly.0 started with pid 9269
    2019-02-24 07:45:58.001 - info: shelly.0 starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    2019-02-24 07:45:58.011 - info: shelly.0 Starting shelly.0 in version 2.1.4
    2019-02-24 07:45:58.045 - info: shelly.0 Listening for Shelly packets in the network
    2019-02-24 07:46:12.828 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:46:12.834 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:46:12.835 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    2019-02-24 07:46:39.279 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.178.70
    2019-02-24 07:46:42.839 - info: host.iobroker instance system.adapter.shelly.0 started with pid 9279
    2019-02-24 07:46:43.193 - info: shelly.0 starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    2019-02-24 07:46:43.205 - info: shelly.0 Starting shelly.0 in version 2.1.4
    2019-02-24 07:46:43.248 - info: shelly.0 Listening for Shelly packets in the network
    2019-02-24 07:46:48.426 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.178.70 vis.0
    2019-02-24 07:46:57.986 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:46:57.992 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:46:57.993 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    2019-02-24 07:47:27.997 - info: host.iobroker instance system.adapter.shelly.0 started with pid 9289
    2019-02-24 07:47:28.315 - info: shelly.0 starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
    2019-02-24 07:47:28.326 - info: shelly.0 Starting shelly.0 in version 2.1.4
    2019-02-24 07:47:28.360 - info: shelly.0 Listening for Shelly packets in the network
    2019-02-24 07:47:43.146 - warn: shelly.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
    2019-02-24 07:47:43.151 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (OK)
    2019-02-24 07:47:43.152 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
    hmm jetzt beim Versuch zu löschen...
    iobroker 2019-02-24 07:52:14.833 info exit 0
    host.iobroker 2019-02-24 07:52:07.805 error Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/shelly.admin/data.json: ENOENT: no such file or directory, open '/opt/iobroker/node
    iobroker 2019-02-24 07:52:07.001 info npm uninstall iobroker.shelly --silent --save --prefix "/opt/iobroker" (System call)
    iobroker 2019-02-24 07:52:06.811 info host.iobroker Deleting 1 state(s).
    iobroker 2019-02-24 07:52:06.807 info host.iobroker Deleting 2 object(s).
    iobroker 2019-02-24 07:52:06.800 info host.iobroker Counted 1 states (system.adapter.shelly.*) from states
    iobroker 2019-02-24 07:52:06.711 info host.iobroker Counted 1 states of shelly
    iobroker 2019-02-24 07:52:06.699 info host.iobroker Counted 1 adapters for shelly
    iobroker 2019-02-24 07:52:06.687 info host.iobroker no instances of adapter shelly found
    iobroker 2019-02-24 07:52:06.674 info Delete adapter "shelly"
    iobroker 2019-02-24 07:52:06.472 info del shelly
    host.iobroker 2019-02-24 07:51:58.907 error startInstance system.adapter.shelly.0: object not found!
    StuebiS 1 Antwort Letzte Antwort
    • M Merowinger
      ) from states
      StuebiS Offline
      StuebiS Offline
      Stuebi
      #305
      @Merowinger , wie ich sehe willst Du den Adapter löschen und neue anlegen. Ist der Fehler immer noch da? Wenn ja, sage bitte bescheid. Ich habe eine Idee, woran es liegt und würde es gerne korrigieren und Dir die Version zum Testen geben.
      ioBroker auf Synology DS216+II im Docker Container
        Merowinger
        #306
        Wow fuck, das ging schnell.
        Jou habe gelöscht und neu installiert. Weiterhin startet er alle Minute neu... Aber ich kann mittlerweile wenigstens steuern...
        • M Merowinger
          StuebiS Offline
          StuebiS Offline
          Stuebi
          schrieb am zuletzt editiert von Stuebi
          #307
          @Merowinger kannst Du bitte den Shelly Adapter einmal im Debug Modus starten (Auf Instanzen gehen, dort Experenmodus aktivieren und dann bei Shelly bei Log Stufe von Info auf Debug wechseln).
          Ich brauch das Logfile bist zum Fehler und ein paar Einträge danach.
          Wenn es geht, erstelle bitte auf Github ein Issue und stelle dort das Logfile zur Verfügung.
          https://github.com/schmupu/ioBroker.shelly/issues
            Merowinger
            #308
            @Stuebi habe leider keinen GitHub Account.
            Seit umstellen auf loglevel-debug und wieder zurück auf info habe ich den Fehler nicht mehr gesehen :-(
            • StuebiS Offline
              StuebiS Offline
              Stuebi
              #309
              Ab Version 2.1.5. (Latest) wird auch der Shelly Smoke unterstützt. Es werden die Objekte Smoke detected, Temperatur und Batterie Status angezeigt.
              Mehr Infos hier: https://github.com/schmupu/ioBroker.shelly
              Stübi
              • E Offline
                eMd
                schrieb am zuletzt editiert von eMd
                #310
                Was soll ich mit der Meldung anfangen?
                system.adapter.shelly.0 terminated by request of the instance itself and will not be restarted, before user restarts it
                Folgendes habe ich noch gefunden im log
                host.ioBroker-Tinker	2019-03-13 15:44:06.048	info	Do not restart adapter system.adapter.shelly.1 because desired by instance
                host.ioBroker-Tinker	2019-03-13 15:44:06.047	error	instance system.adapter.shelly.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
                shelly.1	2019-03-13 15:44:06.005	warn	Exception: TypeError: Cannot read property 'startsWith' of undefined
                MfG
                eMd
                Master: Intel NUC 16GB/500GB
                Slave: Raspberry Pi 3 + Homematicmodul
                Shelly, Google Home, Zigbee Aqara, Sonoff
                Meine VIS: https://youtu.be/JMYr2KYlpME
                E 1 Antwort Letzte Antwort
                • E eMd
                  MfG
                  eMd
                  eMd
                  #311
                  Erledigt, ein Fritz Box Neustart hat gereicht fragt mich nicht warum.... 😃
                  • C Offline
                    Crazy
                    #312
                    Hatte heute ebenfalls einen roten Shelly Adapter mit folgender Log Message:
                    instance system.adapter.shelly.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                    Nach manuellem Adapter Restart läufts erstmal wieder.
                    • StuebiS Stuebi
                      @klausiob , nein aber werde ich im Shelly Adapter berücksichtigen.
                      klausiob
                      #313
                      @Stuebi Mein Shelly 2.5 ist nun unterwegs. Hast Du diesen im Adapter berücksichtigt? In der Info der V2.1.9 steht er nicht drin.
                      Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                      node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                      • K klausiob
                        StuebiS Offline
                        StuebiS Offline
                        Stuebi
                        #314
                        @klausiob , Shelly 2.5 und 1 PM ist unterwegs. Sobald ich diese habe, werden die unterstützt.
                        • StuebiS Stuebi
                          klausiob
                          schrieb am zuletzt editiert von klausiob
                          #315
                          @Stuebi Mein Shelly 2.5 ist da und wurde im iobroker zunächst problemlos integriert.☺
                          Steuerung über Alexa funktioniert auch.
                          • K klausiob
                            StuebiS Offline
                            StuebiS Offline
                            Stuebi
                            #316
                            @klausiob , das hört sich gut an. Soweit ich weiß, kann der Shelly 2.5 an jedem Kanal den Verbrauch messen. Da muss ich nochmals ran.
                            • StuebiS Stuebi
                              klausiob
                              #317
                              @Stuebi Ein zweiter Shelly 2.5 läuft auch. Gibt es für die Gruppensteuerung aus der App auch eigene Datenpunkte oder muß man dass selber programmieren?
                              • K klausiob
                                StuebiS Offline
                                StuebiS Offline
                                Stuebi
                                #318
                                @klausiob sagte in [Aufruf] Test Shelly Adapter:
                                Die Shelly Programmierung für den 2.5 steht morgen auf dem Plan.
                                Für die Gruppensteuerung stellt die Shelly API leider keine Datenpunkte zur Verfügung.
                                Stübi
                                • StuebiS Offline
                                  StuebiS Offline
                                  Stuebi
                                  #319
                                  In der Version 2.2.0 (Latest) am Montag werden folgende Geräte nun komplett mit Power Anzeige pro Kanal unterstützt.
                                  • Shelly 1 PM
                                  • Shelly 2.5
                                  Wer nicht bis Montag warten möchte, kann den Shelly Adapter schon jetzt in der Version 2.2.0 über Github laden. (Adapter -> Installieren über externe URL und dann Shelly auswählen).
                                  Stübi
                                    dos1973
                                    #320
                                    Ich hoffe dass meine Lieferung am Montag versendet wird.
                                    Klasse dass es schon im Adapter verfügbar ist!
                                    • C Offline
                                      Conquest
                                      #321
                                      ich habe eine Problem mit dem Shelly-Adapter. Leider bekomme ich keine Verbindung er bleibt rot.
                                      Mein Server läuft in einer Virtuellen Maschine ist das vielleicht das Problem? Vielleicht kann mir ja jemand helfen. Log ist im Anhang.
                                      LG
                                      • C Conquest
                                        LG
                                        StuebiS Offline
                                        StuebiS Offline
                                        Stuebi
                                        #322
                                        @Conquest , ist Deine virtuelle Maschine im gleichem Subnetz wie die Shelly Geräte? Das ist Voraussetzung, damit es funktioniert.
                                        Du kannst unter dem Reiter 'Instanzen' den Experten Modus aktivieren und dann den Loglevel des Shelly Adapters auf Debug stellen.
                                        Wenn Du dann leere CoAP Nachrichten im Log siehst, liegt es am Netzwerk (UDP u. Multicasting).
                                        C 1 Antwort Letzte Antwort
                                        • StuebiS Stuebi
                                          Conquest
                                          #323
                                          @Stuebi sagte in [Aufruf] Test Shelly Adapter:
                                          Wo sehe ich ob ich im gleichen Subnetz bin?
