  3. Entwicklung
  4. ZigBee CC253x - neue/unbekannte Geräte - ab 0.10.x
adapter
304 Beiträge 42 Kommentatoren 70.6k Aufrufe 29 Beobachtet
    DiveDancer
    @Asgothian ich geh mal davon aus das du den Branch von Gestern Abend wieder hochgefahren hast.
    Dies ist das Ergebnis:
    Es gibt eine Fehlermeldung im Installations Log des ADAPTERS:
    Fertig mit Fehler: host.Rock64 Cannot install https://github.com/asgothian/ioBroker.zigbee/tarball/ecozy: 243
    $ ./iobroker url "https://github.com/asgothian/ioBroker.zigbee/tarball/ecozy" --debug
    npm install https://github.com/asgothian/ioBroker.zigbee/tarball/ecozy --production --save --prefix "/opt/iobroker" (System call)
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherdnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee
    npm
     WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm ERR! path /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherdnpm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd'
    npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd'
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd' }
    npm ERR!
    npm
    ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR!
     the command again as root/Administrator (though this is not recommended).
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-03-20T15_10_34_158Z-debug.log
    ERROR: host.Rock64 Cannot install https://github.com/asgothian/ioBroker.zigbee/tarball/ecozy: 243
    Der Log im ioBroker zeigt wieder Daten des ZigBee Adapters an:
    zigbee.0	2019-03-20 16:13:53.810	debug	User stateChange zigbee.0.info.pairingMode {"val":false,"ack":false,"ts":1553094833711,"q":0,"from":"system.adapter.zigbee.0","lc":1551514412695}
    zigbee.0	2019-03-20 16:13:53.809	debug	User stateChange zigbee.0.info.connection {"val":true,"ack":false,"ts":1553094833707,"q":0,"from":"system.adapter.zigbee.0","lc":1551514412677}
    zigbee.0	2019-03-20 16:13:53.708	info	zigbee-shepherd ready. version: 2.6.3 rev 20190223
    zigbee.0	2019-03-20 16:13:53.675	info	zigbee-shepherd started!
    zigbee.0	2019-03-20 16:13:52.705	info	Reset coordinator
    zigbee.0	2019-03-20 16:13:52.705	info	Queue is: true
    zigbee.0	2019-03-20 16:13:52.705	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0012023346-if00 with panID 6754 channel 11
    zigbee.0	2019-03-20 16:13:52.705	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.15.1
    Der Adapter ist GRÜN !
    Achtung!
    Das Thermostat wird nicht erkannt.
    Auch nach erneuten pairen ist ein Fragezeichen in der Kachel !
    LG DiveDancer
    • D DiveDancer
      npm
      npm ERR! errno -13
      npm ERR!
      npm
      npm ERR!
      npm ERR!
      Achtung!
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @DiveDancer Jo.. das installieren hat nicht geklappt weil die Zugriffsrechte auf /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd nicht sauber gesetzt sind.
      Geh doch bitte mal auf die Console in das Verzeichnis \opt\iobroker\node_modules und mach
      chown -R iobroker:iobroker *
      Danach solltest du problemlos installieren können.
        Matdos
        Ich habe hier mal ein Schloss von Danalock
        Es soll verriegel, entriegeln, und öffnen wenn schon entriegelt ist (Schlossfalle) Das kann zwar noch mehr wie Auto Unlock ect aber ich weiß nicht ob und wie man das in Iobroker benutzen könnte.
        0774A576-9BED-4037-B53A-2398B6860059.jpeg 59C5EFDD-23A4-42EB-8D40-C4C9446131F8.jpeg 0CF9103B-223F-4FC1-A318-81B9B11A62E2.jpeg
        • M Matdos
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @matdos1gmx-de
          Das ist leider aktuell noch nicht im zigbee-shepherd-converters drin. Ohne Test-Gerät kann ich das leider nicht implementieren.
          A.
          • AsgothianA Asgothian
            @matdos1gmx-de
            A.
            Matdos
            @Asgothian
            Hm also müsste ich dir das zusenden? Oder kannst du über meinen Rechner mit TeamViewer etwas machen?
            • AsgothianA Offline
              AsgothianA Offline
              Asgothian
              Prinzipiell kann das auch via Teamviewer gehen. Ich müsste mich da aber erst einlesen, und wir müssten so 2 bis 3 Stunden dafuer einplanen. Das ist nicht "mal eben so" getan.
                Matdos
                @Asgothian
                Ja Zeit wäre kein Problem wenn du Lust hast melde dich ich sende dir mal meine Handy Nummer ansonsten ist es auch kein Problem und ich versende es an dich incl Rückversand Schein so das du keine Kosten hast.
                  DiveDancer
                  @Asgothian Installation ist Fehlerfrei verlaufen, Danke
                  Die 6 Objekte sind wie zu Beginn angelegt.
                  Nicht mehr.
                  Muss ich mir auch in diesem Zustand Gedanken um den Stromverbrauch machen?
                  LG DiveDancer
                  • D DiveDancer
                    Nicht mehr.
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @DiveDancer sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte - ab Adapter 0.10.x:
                    Fein
                    Sorgen nicht unbedingt, aber du solltest es im Auge behalten. Wenn ich die Anleitung richtig verstanden habe meldet der Thermostat sich ja wenn ihm der Saft aus geht.
                    Wie wollen wir vorgehen um bei den fehlenden Datenpunkten vorwärts zu kommen ? Jeweils ein Punkt nach dem Anderen mit Installation über Github und Kommunikation "asynchron" hier wird so eine Woche brauchen bis wir durch sind. Das ist eigentlich nicht im Sinne des Erfinders.
                    • M Matdos
                      @Asgothian
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @matdos1gmx-de Erst einmal vorbereiten. Kannst du den zigbee-adapter mal auf debug logging stellen, das schloss auf/zu schliessen um zu sehen ob es von sich aus schon lesbare Zigbee-Meldungen schickt ?
                      A
                        A
                        Matdos
                        @Asgothian
                        Sorry das ich mich jetzt erst melde ich musste das Schloss noch mal raus nehmen aus dem Adapter das die Verbindung zur App nicht mehr ging, jetzt bekomme ich es seit ner Stunde nicht mehr angelernt 🙄
                        Wie stellle ich den Adapter auf debugg?
                        • M Matdos
                          @Asgothian
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @matdos1gmx-de
                          In der Instanz-Ansieht auf Expertenmodus schalten (Screen Shot 2019-03-20 at 18.27.14 .png )
                          , dann in der Spalte Loglevel umstellenScreen Shot 2019-03-20 at 18.27.43 .png
                            @matdos1gmx-de
                            Matdos
                            @Asgothian
                            Ok habe denn Adapter umgestelllt neu gestartet und das Schloss ist auch wieder angelernt als unbekannt.
                            Das einzige was ich vom Schloss sehe ist unten das Feld aber kein Ordner und da ändert sich auch nichts image.jpg
                            • M Matdos
                              @Asgothian
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @matdos1gmx-de
                              So weit so gut.
                              Jetzt auf die Log-Ansicht, und das Schloss per Schlüssel / per von hand drehen auf und zu schliessen, und schauen ob es da Meldungen vom Schloss gibt.. so was wie
                              zigbee.1	2019-03-20 18:48:55.590	debug	Publish {"battery":74}
                              zigbee.1	2019-03-20 18:48:55.590	debug	Device 0xd0cf5efffec6d1ed emit event attReport with data:{"cid":"genPowerCfg","data":{"batteryPercentageRemaining":74}}
                              zigbee.1	2019-03-20 18:48:55.590	debug	handleMessage. {"type":"attReport","endpoints":[{"device":{"_id":3,"type":"EndDevice","ieeeAddr":"0xd0cf5efffec6d1ed","nwkAddr":35310,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Battery
                              zigbee.1	2019-03-20 18:48:55.590	debug	Publish {"linkquality":0}
                              natürlich mit der Adresse des Schlosses als "ieeeAddr"
                                Matdos
                                schrieb am zuletzt editiert von Matdos
                                Hm ne habe jetzt mehrmals geöffnet und geschlossen aber mit der Adresse vom Schloss kommen keine Meldungen rein!
                                Die Verbindung wird als rot angezeigt, vieleicht hilft das
                                  Fein
                                  DiveDancer
                                  @Asgothian sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte - ab Adapter 0.10.x:
                                  Fein
                                  Über die Objekte wird sich das Ventil aktuell schon mal nicht melden können.
                                  Und da die Display Funktion in meinen Augen eh nicht schön gelöst ist bin ich ja mal auf die Batteriewarnung gespannt.
                                  Das Display ist immer tot.
                                  Um die Temperatur manuell zu verstellen muss zuvor noch für 2 Sekunden eine andere Touchscreen-taste gedrückt werden bevor die Temperatur überhaupt erstmal angezeigt wird. Erst dann ist für einen kurzen Zeitraum die Temperatur zu verstellen.
                                  Ich brauche eh mehrere wenn ich mich für das System entscheide.
                                  Ich habe da noch das eine oder andere unter Beobachtung.
                                  Ich weiß nicht wie es dir am liebsten ist, aber ich könnte beim Kauf als Versandadresse die deine angeben.
                                  Da wäre dann auch die Zentraleinheit (Bridge) dabei. Vielleicht ist es damit ersichtlicher wieviel Objekte das System managed.
                                  Team Viewer kann ich dir sicher auch ermöglichen.
                                  Du weißt wahrscheinlich am besten wie du am effektivsten voran kommst.
                                  Da richte ich mich ganz nach dir.
                                  Gibt es da eigentlich irgendwo ein Videotutorial für die Integration von neuen Devices, um sich mal einen Überblick zu verschaffen an was für Schrauebn du so drehen musst um die neuen Objekte und Devices zu integrieren?
                                  LG DiveDancer
                                  • D DiveDancer
                                    Fein
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    Es wird einen Datenpunkt für die Batterie geben. Der ist in den Datenpunkten versteckt die bei Dir aktuell aaskommentiert sind. Den bekommen wir aber noch - auch kurzfristig.
                                    Teamviewer und TS / Skype / andere voice Funktion ist mir eigentlich am liebsten. Dann kann ich in dem Zusammenhang auch erklären was ich wo warum tue. Zusätzlich müsste ich auf deinem ioBroker einen zusaetzlichen Adapter installieren - den können wir hinterher aber auch wieder runter werfen - er ermöglicht es dir (bzw. mir via teamviewer) direkt auf dem iobroker code anzupassen. Das ist die eleganteste Variante fuer diese Art von Entwicklung
                                    Gibt es da eigentlich irgendwo ein Videotutorial für die Integration von neuen Devices, um sich mal einen Überblick zu verschaffen an was für Schrauben du so drehen musst um die neuen Objekte und Devices zu integrieren?
                                    Ein Videotutorial gibt es meines Wissens nicht - macht aus meiner Sicht auch keinen Sinn, da es extrem davon abhängt was wirklich zu tun ist. Das können wir aber gemeinsam durchgehen - ist kein Hexenwerk.
                                    A.
                                      DiveDancer
                                      schrieb am zuletzt editiert von DiveDancer
                                      @Asgothian wenn TS = Teamspeak ist dann muss ich das noch installieren,
                                      ansonsten brauchen wir nur noch nen Termin.
                                      Das brauch ich eh, weil ich auch am Freitag an der Runde der großen Netzwerke interessiert bin. ;-)
                                      LG DiveDancer
                                        @EubaFieldRacer - Dein Dimmer (von diesem Post) sollte mit der aktuellen 0.10.2er version funktionieren.
                                        A.
                                        Falls nicht: Bitte Adapter-Version und Zigbee-Shepherd-Converters version posten.
                                        EubaFieldRacer
                                        @Asgothian said in ZigBee CC253x Adapter - nur neue/unbekannte Geräte - ab Adapter 0.10.x:
                                        A.
                                        ja der läuft einwandfrei, hatte ich am WE schon ausprobiert und auch zurückgemeldet. Ist wahrscheinlich untergegangen...
                                        • F Offline
                                          Findus
                                          #66
                                          Mueller Tint Fernbedienung: Loesung gefunden:
                                          Nach "sonntam" der dies implementiert hat ist Version 20190223 zwingend notwendig. Nur dann funktioniert die Fernbedienung ohne Gruppe.
                                          "For me it works flawlessly. If you are using an old pre 20190223 firmware for your CC2531/CC2530 stick you have to find out the group your IKEA/Tint remote is in by sniffing zigbee traffic (see here). Then you will have to create a group within iobroker.zigbee with that group ID so the coordinator can listen to the messages."
                                          Ich habe die von arteck bereit gestellte Version 20190315 geflashed uns sie da, jetzt funktioniert die Fernbedienung.
