  3. Entwicklung
  4. ZigBee CC253x Adapter - nur neue/unbekannte Geräte Version 0.9.x
894 Beiträge 82 Kommentatoren 331.7k Aufrufe 23 Beobachtet
  • G Offline
    gosund
    #793
    @smarti2015 was sagt denn dmesg?
      smarti2015
      #794
      [    0.000000] Booting Linux on physical CPU 0x500
      [    0.000000] Linux version 4.14.70-rockchip (root@nightly) (gcc version 7.2.1        20171011 (Linaro GCC 7.2-2017.11)) #270 SMP PREEMPT Wed Sep 19 11:40:40 CEST 201        8
      [    0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio        n cache
      [    0.000000] OF: fdt: Machine model: Rockchip RK3288 Tinker Board
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] On node 0 totalpages: 524288
      [    0.000000] free_area_init_node: node 0, pgdat c13e39c0, node_mem_map eedfa00        0
      [    0.000000]   Normal zone: 1728 pages used for memmap
      [    0.000000]   Normal zone: 0 pages reserved
      [    0.000000]   Normal zone: 196608 pages, LIFO batch:31
      [    0.000000]   HighMem zone: 327680 pages, LIFO batch:31
      [    0.000000] percpu: Embedded 18 pages/cpu @eed8d000 s41048 r8192 d24488 u7372        8
      [    0.000000] pcpu-alloc: s41048 r8192 d24488 u73728 alloc=18*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522560
      [    0.000000] Kernel command line: consoleblank=0 scandelay root=UUID=18fd0e57-        fe5e-4ef2-b122-03c385105200 rw console=ttyS2,115200n8 rootfstype=ext4 loglevel=1        rootwait usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u
      [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Memory: 2048824K/2097152K available (13312K kernel code, 964K rwd        ata, 3072K rodata, 1024K init, 4636K bss, 48328K reserved, 0K cma-reserved, 1310        720K highmem)
      [    0.000000] Virtual kernel memory layout:
                         vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                         fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                         vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                         lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                         pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                         modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                           .text : 0xc0008000 - 0xc0e00000   (14304 kB)
                           .init : 0xc1200000 - 0xc1300000   (1024 kB)
                           .data : 0xc1300000 - 0xc13f1330   ( 965 kB)
                            .bss : 0xc13fe484 - 0xc18854c0   (4637 kB)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 45886 entries in 135 pages
      [    0.000000] Preemptible hierarchical RCU implementation.
      [    0.000000]  Tasks RCU enabled.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] rockchip_mmc_get_phase: invalid clk rate
      [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0x588fe9dc0, max_idle_ns: 440795202592 ns
      [    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980        46511097ns
      [    0.000023] Switching to timer-based delay loop, resolution 41ns
      [    0.001838] Console: colour dummy device 80x30
      [    0.001879] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 48.00 BogoMIPS (lpj=24000)
      [    0.001898] pid_max: default: 32768 minimum: 301
      [    0.002056] Security Framework initialized
      [    0.002067] Yama: becoming mindful.
      [    0.002148] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.002166] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.003196] CPU: Testing write buffer coherency: ok
      [    0.003607] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
      [    0.008017] Setting up static identity map for 0x100000 - 0x100060
      [    0.010026] Hierarchical SRCU implementation.
      [    0.014151] smp: Bringing up secondary CPUs ...
      [    0.022687] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
      [    0.030917] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
      [    0.039159] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
      [    0.039360] smp: Brought up 1 node, 4 CPUs
      [    0.039375] SMP: Total of 4 processors activated (192.00 BogoMIPS).
      [    0.039382] CPU: All CPU(s) started in SVC mode.
      [    0.041402] devtmpfs: initialized
      [    0.056437] random: get_random_u32 called from bucket_table_alloc+0x194/0x22c        with crng_init=0
      [    0.057257] VFP support v0.3: implementor 41 architecture 3 part 30 variant d        rev 0
      [    0.057660] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 1911260446275000 ns
      [    0.057683] futex hash table entries: 1024 (order: 4, 65536 bytes)
      [    0.058061] xor: measuring software checksum speed
      [    0.067489]    arm4regs  :  1036.000 MB/sec
      [    0.077637]    8regs     :   800.000 MB/sec
      [    0.087786]    32regs    :   800.000 MB/sec
      [    0.087797] xor: using function: arm4regs (1036.000 MB/sec)
      [    0.087814] pinctrl core: initialized pinctrl subsystem
      [    0.088997] NET: Registered protocol family 16
      [    0.092038] DMA: preallocated 2048 KiB pool for atomic coherent allocations
      [    0.093970] cpuidle: using governor ladder
      [    0.094029] cpuidle: using governor menu
      [    0.095326] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
      [    0.095336] hw-breakpoint: maximum watchpoint size is 4 bytes.
      [    0.124800] gpio gpiochip0: (gpio0): added GPIO chardev (254:0)
      [    0.124954] gpiochip_setup_dev: registered GPIOs 0 to 23 on device: gpiochip0        (gpio0)
      [    0.125393] gpio gpiochip1: (gpio1): added GPIO chardev (254:1)
      [    0.125523] gpiochip_setup_dev: registered GPIOs 24 to 55 on device: gpiochip        1 (gpio1)
      [    0.125914] gpio gpiochip2: (gpio2): added GPIO chardev (254:2)
      [    0.126027] gpiochip_setup_dev: registered GPIOs 56 to 87 on device: gpiochip        2 (gpio2)
      [    0.126473] gpio gpiochip3: (gpio3): added GPIO chardev (254:3)
      [    0.126589] gpiochip_setup_dev: registered GPIOs 88 to 119 on device: gpiochi        p3 (gpio3)
      [    0.126991] gpio gpiochip4: (gpio4): added GPIO chardev (254:4)
      [    0.127106] gpiochip_setup_dev: registered GPIOs 120 to 151 on device: gpioch        ip4 (gpio4)
      [    0.127550] gpio gpiochip5: (gpio5): added GPIO chardev (254:5)
      [    0.127667] gpiochip_setup_dev: registered GPIOs 152 to 183 on device: gpioch        ip5 (gpio5)
      [    0.128050] gpio gpiochip6: (gpio6): added GPIO chardev (254:6)
      [    0.128192] gpiochip_setup_dev: registered GPIOs 184 to 215 on device: gpioch        ip6 (gpio6)
      [    0.128627] gpio gpiochip7: (gpio7): added GPIO chardev (254:7)
      [    0.128762] gpiochip_setup_dev: registered GPIOs 216 to 247 on device: gpioch        ip7 (gpio7)
      [    0.129077] gpio gpiochip8: (gpio8): added GPIO chardev (254:8)
      [    0.129196] gpiochip_setup_dev: registered GPIOs 248 to 263 on device: gpioch        ip8 (gpio8)
      [    0.190423] raid6: int32x1  gen()    89 MB/s
      [    0.207215] raid6: int32x1  xor()   103 MB/s
      [    0.224788] raid6: int32x2  gen()   128 MB/s
      [    0.241859] raid6: int32x2  xor()   105 MB/s
      [    0.259464] raid6: int32x4  gen()   105 MB/s
      [    0.276394] raid6: int32x4  xor()    82 MB/s
      [    0.294012] raid6: int32x8  gen()   117 MB/s
      [    0.311163] raid6: int32x8  xor()    91 MB/s
      [    0.311173] raid6: using algorithm int32x2 gen() 128 MB/s
      [    0.311181] raid6: .... xor() 105 MB/s, rmw enabled
      [    0.311188] raid6: using intx1 recovery algorithm
      [    0.311749] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/v        sys-regulator[0]'
      [    0.312348] of_get_named_gpiod_flags: parsed 'gpio' property of node '/sdmmc-        regulator[0]' - status (0)
      [    0.313291] iommu: Adding device ff930000.vop to group 0
      [    0.313426] iommu: Adding device ff940000.vop to group 1
      [    0.313549] iommu: Adding device ff9a0000.vpu-service to group 2
      [    0.313673] iommu: Adding device ff9c0000.hevc-service to group 3
      [    0.316319] SCSI subsystem initialized
      [    0.316611] usbcore: registered new interface driver usbfs
      [    0.316688] usbcore: registered new interface driver hub
      [    0.316833] usbcore: registered new device driver usb
      [    0.316957] Linux video capture interface: v2.00
      [    0.317042] pps_core: LinuxPPS API ver. 1 registered
      [    0.317051] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome        tti <giometti@linux.it>
      [    0.317077] PTP clock support registered
      [    0.317926] Advanced Linux Sound Architecture Driver Initialized.
      [    0.318637] Bluetooth: Core ver 2.22
      [    0.318704] NET: Registered protocol family 31
      [    0.318714] Bluetooth: HCI device and connection manager initialized
      [    0.318732] Bluetooth: HCI socket layer initialized
      [    0.318745] Bluetooth: L2CAP socket layer initialized
      [    0.318794] Bluetooth: SCO socket layer initialized
      [    0.319471] NetLabel: Initializing
      [    0.319482] NetLabel:  domain hash size = 128
      [    0.319489] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
      [    0.319585] NetLabel:  unlabeled traffic allowed by default
      [    0.320740] clocksource: Switched to clocksource arch_sys_counter
      [    0.447562] VFS: Disk quotas dquot_6.6.0
      [    0.447668] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.447940] FS-Cache: Loaded
      [    0.448209] CacheFiles: Loaded
      [    0.465674] NET: Registered protocol family 2
      [    0.466676] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.466832] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
      [    0.467095] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.467257] UDP hash table entries: 512 (order: 2, 24576 bytes)
      [    0.467327] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
      [    0.467657] NET: Registered protocol family 1
      [    0.468353] RPC: Registered named UNIX socket transport module.
      [    0.468363] RPC: Registered udp transport module.
      [    0.468371] RPC: Registered tcp transport module.
      [    0.468379] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.468697] Trying to unpack rootfs image as initramfs...
      [    0.896823] Freeing initrd memory: 4500K
      [    0.898407] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counte        rs available
      [    0.901135] Initialise system trusted keyrings
      [    0.901386] workingset: timestamp_bits=14 max_order=19 bucket_order=5
      [    0.911589] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.913168] FS-Cache: Netfs 'nfs' registered for caching
      [    0.914092] NFS: Registering the id_resolver key type
      [    0.914128] Key type id_resolver registered
      [    0.914136] Key type id_legacy registered
      [    0.914159] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.914212] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.915028] JFS: nTxBlock = 8192, nTxLock = 65536
      [    0.921916] SGI XFS with security attributes, no debug enabled
      [    0.924823] aufs 4.14-20171218
      [    0.925760] NOHZ: local_softirq_pending 80
      [    0.933367] NET: Registered protocol family 38
      [    0.933553] async_tx: api initialized (async)
      [    0.933568] Key type asymmetric registered
      [    0.933577] Asymmetric key parser 'x509' registered
      [    0.933666] bounce: pool size: 64 pages
      [    0.933791] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        46)
      [    0.934015] io scheduler noop registered
      [    0.934025] io scheduler deadline registered
      [    0.934101] io scheduler cfq registered (default)
      [    0.934111] io scheduler mq-deadline registered
      [    0.934119] io scheduler kyber registered
      [    0.942386] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-2        41330
      [    0.942405] dma-pl330 ff250000.dma-controller:       DBUFF-128x8bytes Num_Cha        ns-8 Num_Peri-20 Num_Events-16
      [    0.943489] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-2        41330
      [    0.943506] dma-pl330 ffb20000.dma-controller:       DBUFF-64x8bytes Num_Chan        s-5 Num_Peri-6 Num_Events-10
      [    0.944357] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
      [    0.947066] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 39, base_baud =        1500000) is a 16550A
      [    0.948353] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 41, base_baud =        1500000) is a 16550A
      [    0.948575] console [ttyS2] enabled
      [    0.949849] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 42, base_baud =        1500000) is a 16550A
      [    0.951104] ff1c0000.serial: ttyS1 at MMIO 0xff1c0000 (irq = 43, base_baud =        1500000) is a 16550A
      [    0.953453] gpiomem-rk3288 ff750000.rk3288-gpiomem: Initialised: Registers at        0xff750000
      [    0.957602] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0e7594        8)
      [    0.958177] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0e7594        8)
      [    0.958294] rockchip-drm display-subsystem: failed to bind ff980000.hdmi (ops        0xc0e76ed4): -517
      [    0.958758] rockchip-drm display-subsystem: master bind failed: -517
      [    0.959100] usbcore: registered new interface driver udl
      [    0.963403] brd: module loaded
      [    0.976058] loop: module loaded
      [    0.976114] lkdtm: No crash points registered, enable through debugfs
      [    0.978590] rockchip-spi ff130000.spi: chipselect 0 already in use
      [    0.978607] spi_master spi2: spi_device register error /spi@ff130000/spidev@1
      [    0.978624] spi_master spi2: Failed to create SPI device for /spi@ff130000/sp        idev@1
      [    0.980415] mdio_bus fixed-0: GPIO lookup for consumer reset
      [    0.980428] mdio_bus fixed-0: using lookup tables for GPIO lookup
      [    0.980440] mdio_bus fixed-0: lookup for GPIO reset failed
      [    0.980469] libphy: Fixed MDIO Bus: probed
      [    0.980478] tun: Universal TUN/TAP device driver, 1.6
      [    0.982463] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
      [    0.982523] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available y        et, deferred probing
      [    0.983622] PPP generic driver version 2.4.2
      [    0.984293] usbcore: registered new interface driver rt2500usb
      [    0.984368] usbcore: registered new interface driver rt73usb
      [    0.984437] usbcore: registered new interface driver rt2800usb
      [    0.984512] usbcore: registered new interface driver rtl8xxxu
      [    0.984587] usbcore: registered new interface driver rndis_wlan
      [    0.984596] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet dri        ver
      [    0.984675] usbcore: registered new interface driver pegasus
      [    0.984796] usbcore: registered new interface driver rtl8150
      [    0.984873] usbcore: registered new interface driver r8152
      [    0.984942] usbcore: registered new interface driver asix
      [    0.985007] usbcore: registered new interface driver ax88179_178a
      [    0.985070] usbcore: registered new interface driver cdc_ether
      [    0.985141] usbcore: registered new interface driver dm9601
      [    0.985220] usbcore: registered new interface driver smsc75xx
      [    0.985295] usbcore: registered new interface driver smsc95xx
      [    0.985358] usbcore: registered new interface driver net1080
      [    0.985423] usbcore: registered new interface driver rndis_host
      [    0.985488] usbcore: registered new interface driver MOSCHIP usb-ethernet dri        ver
      [    0.985581] usbcore: registered new interface driver cdc_ncm
      [    0.985648] usbcore: registered new interface driver cdc_mbim
      [    0.986137] dwc2 ff540000.usb: ff540000.usb supply vusb_d not found, using du        mmy regulator
      [    0.986267] dwc2 ff540000.usb: ff540000.usb supply vusb_a not found, using du        mmy regulator
      [    1.090097] dwc2 ff540000.usb: DWC OTG Controller
      [    1.090156] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
      [    1.090206] dwc2 ff540000.usb: irq 48, io mem 0xff540000
      [    1.090636] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
      [    1.090651] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
      [    1.090662] usb usb1: Product: DWC OTG Controller
      [    1.090674] usb usb1: Manufacturer: Linux 4.14.70-rockchip dwc2_hsotg
      [    1.090684] usb usb1: SerialNumber: ff540000.usb
      [    1.091590] hub 1-0:1.0: USB hub found
      [    1.091664] hub 1-0:1.0: 1 port detected
      [    1.092647] dwc2 ff580000.usb: ff580000.usb supply vusb_d not found, using du        mmy regulator
      [    1.092814] dwc2 ff580000.usb: ff580000.usb supply vusb_a not found, using du        mmy regulator
      [    1.093082] dwc2 ff580000.usb: dwc2_check_param_tx_fifo_sizes: Invalid parame        ter g-tx-fifo-size, setting to default average
      [    1.093116] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
      [    1.094937] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.094947] ehci-platform: EHCI generic platform driver
      [    1.095306] ehci-platform ff500000.usb: EHCI Host Controller
      [    1.095639] ehci-platform ff500000.usb: new USB bus registered, assigned bus        number 2
      [    1.095852] ehci-platform ff500000.usb: irq 47, io mem 0xff500000
      [    1.102803] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
      [    1.103129] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
      [    1.103144] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
      [    1.103156] usb usb2: Product: EHCI Host Controller
      [    1.103167] usb usb2: Manufacturer: Linux 4.14.70-rockchip ehci_hcd
      [    1.103177] usb usb2: SerialNumber: ff500000.usb
      [    1.104009] hub 2-0:1.0: USB hub found
      [    1.104100] hub 2-0:1.0: 1 port detected
      [    1.105183] usbcore: registered new interface driver cdc_acm
      [    1.105192] cdc_acm: USB Abstract Control Model driver for USB modems and ISD        N adapters
      [    1.105286] usbcore: registered new interface driver usblp
      [    1.105361] usbcore: registered new interface driver cdc_wdm
      [    1.105520] usbcore: registered new interface driver usb-storage
      [    1.105649] usbcore: registered new interface driver usbserial
      [    1.105770] usbcore: registered new interface driver usbserial_generic
      [    1.105823] usbserial: USB Serial support registered for generic
      [    1.105898] usbcore: registered new interface driver keyspan
      [    1.105943] usbserial: USB Serial support registered for Keyspan - (without f        irmware)
      [    1.105987] usbserial: USB Serial support registered for Keyspan 1 port adapt        er
      [    1.106039] usbserial: USB Serial support registered for Keyspan 2 port adapt        er
      [    1.106081] usbserial: USB Serial support registered for Keyspan 4 port adapt        er
      [    1.106157] usbcore: registered new interface driver option
      [    1.106201] usbserial: USB Serial support registered for GSM modem (1-port)
      [    1.106403] usbcore: registered new interface driver oti6858
      [    1.106447] usbserial: USB Serial support registered for oti6858
      [    1.106518] usbcore: registered new interface driver qcserial
      [    1.106562] usbserial: USB Serial support registered for Qualcomm USB modem
      [    1.106646] usbcore: registered new interface driver sierra
      [    1.106699] usbserial: USB Serial support registered for Sierra USB modem
      [    1.107805] usbcore: registered new interface driver iforce
      [    1.107916] usbcore: registered new interface driver xpad
      [    1.108092] usbcore: registered new interface driver usbtouchscreen
      [    1.108807] i2c /dev entries driver
      [    1.109875] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f0fab000
      [    1.110785] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f0fad000
      [    1.111698] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0faf000
      [    1.112678] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f0fb1000
      [    1.114646] rk808 0-001b: chip id: 0x0
      [    1.119246] rk808 0-001b: GPIO lookup for consumer dvs
      [    1.119259] rk808 0-001b: using device tree for GPIO lookup
      [    1.119316] of_get_named_gpiod_flags: parsed 'dvs-gpios' property of node '/i        2c@ff650000/pmic@1b[0]' - status (0)
      [    1.119569] rk808 0-001b: GPIO lookup for consumer dvs
      [    1.119582] rk808 0-001b: using device tree for GPIO lookup
      [    1.119648] of_get_named_gpiod_flags: parsed 'dvs-gpios' property of node '/i        2c@ff650000/pmic@1b[1]' - status (0)
      [    1.119859] DCDC_REG1: supplied by vcc_sys
      [    1.121198] DCDC_REG2: supplied by vcc_sys
      [    1.122308] DCDC_REG3: supplied by vcc_sys
      [    1.122792] DCDC_REG4: supplied by vcc_sys
      [    1.123796] LDO_REG1: supplied by vcc_sys
      [    1.125522] LDO_REG2: supplied by vcc_sys
      [    1.126912] LDO_REG3: supplied by vcc_sys
      [    1.128432] LDO_REG4: supplied by vcc_io
      [    1.129944] LDO_REG5: supplied by vcc_io
      [    1.131458] LDO_REG6: supplied by vcc_io
      [    1.133075] LDO_REG7: supplied by vcc_sys
      [    1.134621] LDO_REG8: supplied by vcc_sys
      [    1.135989] SWITCH_REG1: supplied by vcc_io
      [    1.136428] SWITCH_REG2: supplied by vcc_io
      [    1.141424] rk808-rtc rk808-rtc: registered as rtc0
      [    1.141535] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0fb3000
      [    1.142542] i2c i2c-2: of_i2c: invalid addr=0 on /i2c@ff660000/af-controller@        0
      [    1.142558] i2c i2c-2: Failed to create I2C device for /i2c@ff660000/af-contr        oller@0
      [    1.142576] i2c i2c-2: of_i2c: invalid addr=0 on /i2c@ff660000/m24c08@50
      [    1.142588] i2c i2c-2: Failed to create I2C device for /i2c@ff660000/m24c08@5        0
      [    1.142612] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0fb5000
      [    1.143455] IR NEC protocol handler initialized
      [    1.143463] IR RC5(x/sz) protocol handler initialized
      [    1.143471] IR RC6 protocol handler initialized
      [    1.143477] IR JVC protocol handler initialized
      [    1.143484] IR Sony protocol handler initialized
      [    1.143491] IR SANYO protocol handler initialized
      [    1.143497] IR Sharp protocol handler initialized
      [    1.143504] IR MCE Keyboard/mouse protocol handler initialized
      [    1.143511] IR XMP protocol handler initialized
      [    1.143640] usbcore: registered new interface driver uvcvideo
      [    1.143648] USB Video Class driver (1.1.1)
      [    1.148606] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-d        evel@redhat.com
      [    1.148951] device-mapper: raid: Loading target version 1.13.0
      [    1.149197] Bluetooth: HCI UART driver ver 2.3
      [    1.149209] Bluetooth: HCI UART protocol H4 registered
      [    1.149218] Bluetooth: HCI UART protocol ATH3K registered
      [    1.149226] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [    1.149325] usbcore: registered new interface driver bfusb
      [    1.149426] usbcore: registered new interface driver btusb
      [    1.149436] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
      [    1.150428] of: /cpus/cpu@501: Couldn't find opp node
      [    1.153144] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 500000 K        Hz
      [    1.153536] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed        to: 600000 KHz
      [    1.154385] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
      [    1.154389] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
      [    1.154403] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '        /sdio-pwrseq[0]' - status (0)
      [    1.154425] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
      [    1.154429] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
      [    1.154444] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '        /sdio-pwrseq[1]' - status (0)
      [    1.154576] sdhci: Secure Digital Host Controller Interface driver
      [    1.154578] sdhci: Copyright(c) Pierre Ossman
      [    1.154580] Synopsys Designware Multimedia Card Interface Driver
      [    1.155026] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode        .
      [    1.155046] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
      [    1.155053] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
      [    1.155079] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 30,32 bit        host data width,256 deep fifo
      [    1.155162] dwmmc_rockchip ff0c0000.dwmmc: GPIO lookup for consumer cd
      [    1.155166] dwmmc_rockchip ff0c0000.dwmmc: using device tree for GPIO lookup
      [    1.155172] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node        '/dwmmc@ff0c0000[0]'
      [    1.155176] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node        '/dwmmc@ff0c0000[0]'
      [    1.155179] dwmmc_rockchip ff0c0000.dwmmc: using lookup tables for GPIO looku
      GEEKOM AS 6
        smarti2015
        #795
        p
        [    1.155183] dwmmc_rockchip ff0c0000.dwmmc: lookup for GPIO cd failed
        [    1.155187] dwmmc_rockchip ff0c0000.dwmmc: GPIO lookup for consumer wp
        [    1.155190] dwmmc_rockchip ff0c0000.dwmmc: using device tree for GPIO lookup
        [    1.155193] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node        '/dwmmc@ff0c0000[0]'
        [    1.155197] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node        '/dwmmc@ff0c0000[0]'
        [    1.155200] dwmmc_rockchip ff0c0000.dwmmc: using lookup tables for GPIO looku        p
        [    1.155203] dwmmc_rockchip ff0c0000.dwmmc: lookup for GPIO wp failed
        [    1.167053] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,        actual 400000HZ div = 0)
        [    1.179647] dwmmc_rockchip ff0d0000.dwmmc: 'num-slots' was deprecated.
        [    1.179948] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode        .
        [    1.179983] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
        [    1.179999] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
        [    1.180129] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 31,32 bit        host data width,256 deep fifo
        [    1.180155] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was        deprecated.
        [    1.180212] dwmmc_rockchip ff0d0000.dwmmc: GPIO lookup for consumer wp
        [    1.180221] dwmmc_rockchip ff0d0000.dwmmc: using device tree for GPIO lookup
        [    1.180234] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node        '/dwmmc@ff0d0000[0]'
        [    1.180246] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node        '/dwmmc@ff0d0000[0]'
        [    1.180255] dwmmc_rockchip ff0d0000.dwmmc: using lookup tables for GPIO looku        p
        [    1.180265] dwmmc_rockchip ff0d0000.dwmmc: lookup for GPIO wp failed
        [    1.180353] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
        [    1.180364] mmc_host mmc1: card is non-removable.
        [    1.180780] random: fast init done
        [    1.192860] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,        actual 400000HZ div = 0)
        [    1.205444] dwmmc_rockchip ff0f0000.dwmmc: 'num-slots' was deprecated.
        [    1.205663] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode        .
        [    1.205696] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
        [    1.205743] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
        [    1.205856] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 32,32 bit        host data width,256 deep fifo
        [    1.205922] dwmmc_rockchip ff0f0000.dwmmc: GPIO lookup for consumer wp
        [    1.205932] dwmmc_rockchip ff0f0000.dwmmc: using device tree for GPIO lookup
        [    1.205945] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node        '/dwmmc@ff0f0000[0]'
        [    1.205957] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node        '/dwmmc@ff0f0000[0]'
        [    1.205966] dwmmc_rockchip ff0f0000.dwmmc: using lookup tables for GPIO looku        p
        [    1.205975] dwmmc_rockchip ff0f0000.dwmmc: lookup for GPIO wp failed
        [    1.206023] mmc_host mmc2: card is non-removable.
        [    1.217756] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,        actual 400000HZ div = 0)
        [    1.226829] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000        Hz, actual 50000000HZ div = 0)
        [    1.227998] mmc1: new high speed SDIO card at address 0001
        [    1.229999] sdhci-pltfm: SDHCI platform and OF driver helper
        [    1.230177] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-        leds/act-led[0]' - status (0)
        [    1.230195] no flags found for gpios
        [    1.230337] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-        leds/heartbeat-led[0]' - status (0)
        [    1.230352] no flags found for gpios
        [    1.230471] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-        leds/pwr-led[0]' - status (0)
        [    1.230483] no flags found for gpios
        [    1.230908] ledtrig-cpu: registered to indicate activity on CPUs
        [    1.230996] hidraw: raw HID events driver (C) Jiri Kosina
        [    1.231699] usbcore: registered new interface driver usbhid
        [    1.231703] usbhid: USB HID core driver
        [    1.232014] ashmem: initialized
        [    1.233935] usbcore: registered new interface driver snd-usb-audio
        [    1.236441] Initializing XFRM netlink socket
        [    1.236797] NET: Registered protocol family 10
        [    1.237522] Segment Routing with IPv6
        [    1.237585] ip6_tables: (C) 2000-2006 Netfilter Core Team
        [    1.237815] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
        [    1.238487] NET: Registered protocol family 17
        [    1.238501] NET: Registered protocol family 15
        [    1.238549] Bridge firewalling registered
        [    1.238644] Bluetooth: RFCOMM socket layer initialized
        [    1.238663] Bluetooth: RFCOMM ver 1.11
        [    1.238672] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
        [    1.238680] Bluetooth: HIDP socket layer initialized
        [    1.238729] 8021q: 802.1Q VLAN Support v1.8
        [    1.238745] lib80211: common routines for IEEE802.11 drivers
        [    1.238750] lib80211_crypt: registered algorithm 'NULL'
        [    1.238753] lib80211_crypt: registered algorithm 'WEP'
        [    1.238757] lib80211_crypt: registered algorithm 'CCMP'
        [    1.238760] lib80211_crypt: registered algorithm 'TKIP'
        [    1.238779] Key type dns_resolver registered
        [    1.239033] ThumbEE CPU extension supported.
        [    1.239041] Registering SWP/SWPB emulation handler
        [    1.239446] registered taskstats version 1
        [    1.239450] Loading compiled-in X.509 certificates
        [    1.240001] Btrfs loaded, crc32c=crc32c-generic
        [    1.242020] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 1500000        00Hz, actual 148500000HZ div = 0)
        [    1.253995] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0e7594        8)
        [    1.254247] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0e7594        8)
        [    1.254380] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a        with HDCP (DWC MHL PHY)
        [    1.254773] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0e76e        d4)
        [    1.254780] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
        [    1.254783] [drm] No driver support for vblank timestamp query.
        [    1.254812] [drm] Cannot find any crtc or sizes
        [    1.255146] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem o        n minor 0
        [    1.255773] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
        [    1.255849] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
        [    1.255856] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
        [    1.255862] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
        [    1.255874] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
        [    1.255969] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
        [    1.260981] rk_gmac-dwmac ff290000.ethernet: init for RGMII
        [    1.261014] stmmac - user ID: 0x10, Synopsys ID: 0x35
        [    1.261020] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled
        [    1.261025] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register suppo        rted
        [    1.261030] rk_gmac-dwmac ff290000.ethernet: Normal descriptors
        [    1.261034] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine suppo        rted
        [    1.261039] rk_gmac-dwmac ff290000.ethernet: COE Type 2
        [    1.261043] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported
        [    1.261047] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported
        [    1.261073] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watc        hdog Timer
        [    1.261128] mdio_bus stmmac-0: GPIO lookup for consumer reset
        [    1.261133] mdio_bus stmmac-0: using lookup tables for GPIO lookup
        [    1.261138] mdio_bus stmmac-0: lookup for GPIO reset failed
        [    1.261164] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of no        de '/ethernet@ff290000[0]' - status (0)
        [    1.665009] dwmmc_rockchip ff0c0000.dwmmc: Successfully tuned phase to 157
        [    1.665024] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
        [    1.665382] mmcblk0: mmc0:59b4 USD00 15.1 GiB
        [    1.666407]  mmcblk0: p1
        [    1.743836] dwmmc_rockchip ff0f0000.dwmmc: Busy; trying anyway
        [    2.243846] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 stat        us 0x80202000)
        [    2.258788] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz,        actual 300000HZ div = 0)
        [    2.280835] [drm] Cannot find any crtc or sizes
        [    2.296469] libphy: stmmac: probed
        [    2.296478] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_        addr=stmmac-0:00, irq=POLL)
        [    2.296483] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_        addr=stmmac-0:01, irq=POLL)
        [    2.297451] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-        keys/button@0[0]' - status (0)
        [    2.297469] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set        _config() operations
        [    2.297587] input: gpio-keys as /devices/platform/gpio-keys/input/input0
        [    2.298427] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:20        UTC (1358499020)
        [    2.298795] vcc_sd: supplied by vcc_io
        [    2.298834] vcc_sd: disabling
        [    2.298842] ALSA device list:
        [    2.298845]   No soundcards found.
        [    2.298958] ttyS2 - failed to request DMA
        [    2.300342] Freeing unused kernel memory: 1024K
        [    2.329539] random: systemd-udevd: uninitialized urandom read (16 bytes read)
        [    2.329844] random: systemd-udevd: uninitialized urandom read (16 bytes read)
        [    2.329899] random: systemd-udevd: uninitialized urandom read (16 bytes read)
        [    2.358745] usb 2-1: new high-speed USB device number 2 using ehci-platform
        [    2.410748] usb 1-1: new high-speed USB device number 2 using dwc2
        [    2.543724] NOHZ: local_softirq_pending 80
        [    2.544725] NOHZ: local_softirq_pending 80
        [    2.545723] NOHZ: local_softirq_pending 80
        [    2.547721] NOHZ: local_softirq_pending 80
        [    2.560266] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
        [    2.560410] mali ffa30000.gpu: Protected mode not available
        [    2.561601] mali ffa30000.gpu: Probed as mali0
        [    2.593028] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
        [    2.593035] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [    2.593039] usb 1-1: Product: USB2.0 Hub
        [    2.594181] hub 1-1:1.0: USB hub found
        [    2.595401] hub 1-1:1.0: 4 ports detected
        [    2.697276] usb 2-1: config 1 has an invalid interface number: 255 but max is        6
        [    2.697283] usb 2-1: config 1 has no interface number 6
        [    2.698378] usb 2-1: New USB device found, idVendor=0bda, idProduct=481a
        [    2.698383] usb 2-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
        [    2.698387] usb 2-1: Product: USB Audio
        [    2.698391] usb 2-1: Manufacturer: Generic
        [    2.698394] usb 2-1: SerialNumber: 201405280001
        [    2.784833] dwmmc_rockchip ff0f0000.dwmmc: Busy; trying anyway
        [    3.284842] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 stat        us 0x80202000)
        [    3.299764] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz,        actual 200000HZ div = 0)
        [    3.827754] dwmmc_rockchip ff0f0000.dwmmc: Busy; trying anyway
        [    4.327773] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 stat        us 0x80202000)
        [    4.328728] NOHZ: local_softirq_pending 40
        [    4.342751] NOHZ: local_softirq_pending 202
        [    4.342858] mmc_host mmc2: Bus speed (slot 0) = 187500Hz (slot req 100000Hz,        actual 93750HZ div = 1)
        [    4.354749] NOHZ: local_softirq_pending 82
        [    4.360749] NOHZ: local_softirq_pending 02
        [    4.363748] NOHZ: local_softirq_pending 82
        [    4.392747] usb 1-1.1: new full-speed USB device number 3 using dwc2
        [    4.473548] usb 1-1.1: New USB device found, idVendor=0451, idProduct=16a8
        [    4.473557] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber        =3
        [    4.473564] usb 1-1.1: Product: TI CC2531 USB CDC
        [    4.473571] usb 1-1.1: Manufacturer: Texas Instruments
        [    4.473578] usb 1-1.1: SerialNumber: __0X00124B0014D9DE6A
        [    4.474828] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
        [    4.540746] usb 1-1.4: new full-speed USB device number 4 using dwc2
        [    4.635309] usb 1-1.4: New USB device found, idVendor=0a12, idProduct=0001
        [    4.635319] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber        =0
        [    4.635326] usb 1-1.4: Product: CSR8510 A10
        [    4.807291] input: Generic USB Audio as /devices/platform/ff500000.usb/usb2/2        -1/2-1:1.255/0003:0BDA:481A.0001/input/input1
        [    4.859379] hid-generic 0003:0BDA:481A.0001: input,hiddev96,hidraw0: USB HID        v1.11 Device [Generic USB Audio] on usb-ff500000.usb-1/input255
        [    4.878878] dwmmc_rockchip ff0f0000.dwmmc: Busy; trying anyway
        [    4.979903] random: crng init done
        [    4.979912] random: 7 urandom warning(s) missed due to ratelimiting
        [    5.378900] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 stat        us 0x80202000)
        [   10.167045] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode.        Opts: (null)
        [   10.418389] systemd[1]: System time before build time, advancing clock.
        [   10.458359] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
        [   10.458811] systemd[1]: Detected architecture arm.
        [   10.473548] systemd[1]: Set hostname to <tinkerboard>.
        [   10.612239] systemd-sysv-generator[234]: Overwriting existing symlink /run/sy        stemd/generator.late/iobroker.service with real service.
        [   10.612994] systemd-sysv-generator[234]: Overwriting existing symlink /run/sy        stemd/generator.late/nut-client.service with real service.
        [   10.613147] systemd-sysv-generator[234]: Overwriting existing symlink /run/sy        stemd/generator.late/ups-monitor.service with real service.
        [   10.739060] systemd[1]: Created slice System Slice.
        [   10.746980] systemd[1]: Listening on udev Control Socket.
        [   10.754988] systemd[1]: Started Forward Password Requests to Wall Directory W        atch.
        [   10.770568] systemd[1]: Listening on Syslog Socket.
        [   10.779759] systemd[1]: Created slice system-serial\x2dgetty.slice.
        [   10.789443] systemd[1]: Created slice User and Session Slice.
        [   10.796815] systemd[1]: Reached target Slices.
        [   11.091159] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-        ro
        [   11.740981] systemd-journald[326]: Received request to flush runtime journal        from PID 1
        [   11.781574] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-g        pio' property of node '/sound[0]'
        [   11.781584] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-        gpio' property of node '/sound[0]'
        [   11.781954] asoc-simple-card sound: i2s-hifi <-> ff890000.i2s mapping ok
        [   11.792817] generic_raw_uart: loading out-of-tree module taints kernel.
        [   11.793953] rk3288-crypto ff8a0000.cypto-controller: Crypto Accelerator succe        ssfully registered
        [   11.800407] of_get_named_gpiod_flags: parsed 'pivccu,reset_pin' property of n        ode '/serial@ff190000[0]' - status (0)
        [   11.800426] no flags found for pivccu,reset_pin
        [   11.800464] of_get_named_gpiod_flags: parsed 'pivccu,red_pin' property of nod        e '/serial@ff190000[0]' - status (0)
        [   11.800473] no flags found for pivccu,red_pin
        [   11.802822] of_get_named_gpiod_flags: parsed 'pivccu,green_pin' property of n        ode '/serial@ff190000[0]' - status (0)
        [   11.802841] no flags found for pivccu,green_pin
        [   11.802886] of_get_named_gpiod_flags: parsed 'pivccu,blue_pin' property of no        de '/serial@ff190000[0]' - status (0)
        [   11.802896] no flags found for pivccu,blue_pin
        [   11.870906] r8723bs: module is from the staging directory, the quality is unk        nown, you have been warned.
        [   11.882831] RTL8723BS: module init start
        [   11.882837] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
        [   11.882839] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
        [   11.884471] pnetdev = ecdcb800
        [   12.106204] RTL8723BS: rtw_ndev_init(wlan0)
        [   12.107068] RTL8723BS: module init ret =0
        [   12.165775] dw_apb_raw_uart ff190000.serial: Initialized dw_apb device; mapba        se=0xff190000; irq=40; sclk rate=1843200; pclk rate=74250000
        [   12.250275] stmmac_ethtool_get_link_ksettings: eth0: PHY is not registered
        [   12.250282] br0: port 1(eth0) entered blocking state
        [   12.250285] br0: port 1(eth0) entered disabled state
        [   12.250425] device eth0 entered promiscuous mode
        [   12.306574] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_b        us:phy_addr=stmmac-0:00, irq=POLL)
        [   12.317760] rk_gmac-dwmac ff290000.ethernet eth0: PTP not supported by HW
        [   12.317970] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
        [   12.543203] br0: port 1(eth0) entered blocking state
        [   12.543210] br0: port 1(eth0) entered forwarding state
        [   12.543283] IPv6: ADDRCONF(NETDEV_UP): br0: link is not ready
        [   13.288833] br0: port 1(eth0) entered disabled state
        [   13.353529] rk_gmac-dwmac ff290000.ethernet eth0: Link is Up - 1Gbps/Full - f        low control rx/tx
        [   13.353555] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   13.353625] br0: port 1(eth0) entered blocking state
        [   13.353629] br0: port 1(eth0) entered forwarding state
        [   13.353740] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
        [   14.739127] zram: Added device: zram0
        [   14.739670] zram: Added device: zram1
        [   14.740326] zram: Added device: zram2
        [   14.741005] zram: Added device: zram3
        [   14.775244] zram0: detected capacity change from 0 to 262959104
        [   14.801754] Adding 256792k swap on /dev/zram0.  Priority:5 extents:1 across:2        56792k SS
        [   14.803779] zram1: detected capacity change from 0 to 262959104
        [   14.820652] Adding 256792k swap on /dev/zram1.  Priority:5 extents:1 across:2        56792k SS
        [   14.821830] zram2: detected capacity change from 0 to 262959104
        [   14.835338] Adding 256792k swap on /dev/zram2.  Priority:5 extents:1 across:2        56792k SS
        [   14.836755] zram3: detected capacity change from 0 to 262959104
        [   14.850901] Adding 256792k swap on /dev/zram3.  Priority:5 extents:1 across:2        56792k SS
        [   15.428612] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
        [   15.436777] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
        [   16.611317] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
        [   16.769873] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
        [   17.170940] Started plat_eq3ccu2
        [   17.290807] ip_tables: (C) 2000-2006 Netfilter Core Team
        [   17.353536] IPv6: ADDRCONF(NETDEV_UP): lxcbr0: link is not ready
        [   17.430524] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
        [   30.102043] br0: port 2(vethpivccu) entered blocking state
        [   30.102050] br0: port 2(vethpivccu) entered disabled state
        [   30.102218] device vethpivccu entered promiscuous mode
        [   30.102509] IPv6: ADDRCONF(NETDEV_UP): vethpivccu: link is not ready
        [   30.137764] eth0: renamed from vethV36A6V
        [   30.149313] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
        [   30.151755] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   30.151872] IPv6: ADDRCONF(NETDEV_CHANGE): vethpivccu: link becomes ready
        [   30.151957] br0: port 2(vethpivccu) entered blocking state
        [   30.151962] br0: port 2(vethpivccu) entered forwarding state
        [   38.261392] eq3loop: created slave ttyS0
        [   38.261754] eq3loop: created slave mmd_bidcos
        [   40.541634] eq3loop: eq3loop_open_slave() mmd_bidcos
        [   53.944772] eq3loop: eq3loop_open_slave() ttyS0
        [   53.944903] eq3loop: eq3loop_close_slave() ttyS0
        [   53.948247] eq3loop: eq3loop_open_slave() ttyS0
        [   53.948349] eq3loop: eq3loop_close_slave() ttyS0
        [   53.955901] eq3loop: eq3loop_open_slave() ttyS0
        [   53.958012] eq3loop: eq3loop_ioctl_slave() ttyS0: unhandled ioctl 0x5459
        [   53.958024] eq3loop: eq3loop_ioctl_slave() ttyS0: unhandled ioctl 0x545D
        GEEKOM AS 6
        • G Offline
          gosund
          #796
          @smarti2015 mach mal
          dmesg |grep -i acm
          dann sollte in etwa so etwas kommen:
          dmesg |grep -i usb|grep -i acm
          [    3.985095] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
          [    3.989826] usbcore: registered new interface driver cdc_acm
          [    3.989837] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
          und dann noch ein lsusb - der Adapter sollte so zu sehen sein:
          Bus 001 Device 004: ID 0451:16a8 Texas Instruments, Inc.
          was kommt, wenn Du ls -la /dev/ttyACM0 eingibst? Passen die Berechtigungen evtl. nicht?
          crw-rw---- 1 root dialout 166, 0 Mär 17 23:12 /dev/ttyACM0
            smarti2015
            schrieb am zuletzt editiert von smarti2015
            #797
            Hab alles eingegeben und sieht gut aus. Nachdem ich das Tinkerboard runtergefahren habe, hab ich mal den angeschlossenen USB Stick rausgezogen und den ZigBee Stick umgesteckt. Wieder hochgefahren da war er wieder. Bis eben kamen noch große Timeout, aber hab grad noch nen Vermutung was das sein könnte. Erstmal gehen ein paar Lampen wieder. Ich danke dir für deine Hilfe und Tipps!!!
            Das beim paaren bereits angelernte Lampen immer wieder erkannt und gepaart werden ist normal oder? Selbst wenn die 60 Sekunden abgelaufen sind und ich das Fenster offen lassen kommen Minuten später noch Meldungen über erkannte Lampen. Woher weiss ich, das er mit dem Suchen fertig ist?
            GEEKOM AS 6
              smarti2015
              #798
              Jetzt ist er wieder weg:
              false
              falsezigbee.0	2019-03-17 23:36:31.195	debug	User stateChange zigbee.0.info.connection {"val":false,"ack":false,"ts":1552862191185,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1552862163774}
              false
              falsezigbee.0	2019-03-17 23:36:31.194	debug	User stateChange zigbee.0.info.pairingMessage {"val":"Error: Error while starting zigbee-shepherd!. Error: Error Resource temporarily unavailable Cannot lock port","ack":false,"ts":1552862191168,"q":0
              false
              falsezigbee.0	2019-03-17 23:36:31.163	error	Error while starting zigbee-shepherd!. Error: Error Resource temporarily unavailable Cannot lock port
              false
              falsezigbee.0	2019-03-17 23:36:31.147	info	Starting zigbee-shepherd
              false
              falsezigbee.0	2019-03-17 23:36:03.795	debug	User stateChange zigbee.0.info.connection {"val":false,"ack":false,"ts":1552862163774,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1552862163774}
              false
              falsezigbee.0	2019-03-17 23:36:03.794	debug	User stateChange zigbee.0.info.pairingMessage {"val":"Error: Error while starting zigbee-shepherd!. Error: request timeout","ack":false,"ts":1552862163769,"q":0,"from":"system.adapter.zigbee.0","user"
              false
              falsezigbee.0	2019-03-17 23:36:03.140	error	Error while starting zigbee-shepherd!. Error: request timeout
              false
              falsezigbee.0	2019-03-17 23:35:57.948	debug	sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
              false
              falsezigbee.0	2019-03-17 23:35:57.947	debug	List of ports: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS3"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS0"}]
              false
              falsezigbee.0	2019-03-17 23:35:57.588	debug	sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
              false
              falsezigbee.0	2019-03-17 23:35:57.551	debug	getGroups result: {}
              false
              falsezigbee.0	2019-03-17 23:35:57.532	debug	sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
              false
              falsezigbee.0	2019-03-17 23:35:56.881	debug	system.adapter.admin.0: logging true
              false
              falsezigbee.0	2019-03-17 23:35:56.854	debug	system.adapter.admin.0: logging true
              false
              falsezigbee.0	2019-03-17 23:35:54.703	debug	system.adapter.admin.0: logging false
              false
              falsezigbee.0	2019-03-17 23:35:51.153	debug	sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
              false
              falsezigbee.0	2019-03-17 23:35:51.152	debug	List of ports: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS3"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS0"}]
              false
              falsezigbee.0	2019-03-17 23:35:51.070	debug	sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
              false
              falsezigbee.0	2019-03-17 23:35:51.069	debug	getGroups result: {}
              false
              falsezigbee.0	2019-03-17 23:35:50.955	debug	sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
              false
              falsezigbee.0	2019-03-17 23:35:46.807	info	Starting zigbee-shepherd
              false
              falsezigbee.0	2019-03-17 23:35:31.121	info	Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
              false
              falsezigbee.0	2019-03-17 23:35:29.551	info	Reset coordinator
              false
              falsezigbee.0	2019-03-17 23:35:29.478	info	Queue is: true
              false
              falsezigbee.0	2019-03-17 23:35:29.478	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9DE6A-if00 with panID 6754 channel 11
              false
              falsezigbee.0	2019-03-17 23:35:29.425	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v6.16.0
              false
              falsezigbee.0	2019-03-17 23:35:29.329	debug	statesDB connected
              false
              falsezigbee.0	2019-03-17 23:35:29.247	debug	objectDB connected
              GEEKOM AS 6
              • AsgothianA Asgothian
                @MyzerAT
                das ist einfach: im Adapter, settings Seite, reset (full reset, not soft reset), und shepherd.db löschen.
                MyzerATM Offline
                MyzerATM Offline
                MyzerAT
                #799
                @Asgothian sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte:
                @MyzerAT
                so habe fertig, alles neu angelernt, ist eine -heiden Arbeit, aber man lernt ja auch einiges dadurch und gleich Backup davon gemacht!
                lg Rudi
                Node 22.23.0
                Nodejs 22.23.0
                npm 10.9.8
                js-controller 7.2.2
                • MyzerATM MyzerAT
                  @MyzerAT
                  smarti2015
                  #800
                  @MyzerAT Wie hast du das hinbekommen, das die IKEA Verstärker so schön auf genutzt werden? Meine Waren mit dem Coordinator verbunden und mehr nicht.
                  GEEKOM AS 6
                  MyzerATM 1 Antwort Letzte Antwort
                  • S smarti2015
                    So, nachdem ich nun ca 30 Lampen und Sensoren gepaart habe, geht nichts mehr. Der Adapter bleibt auf gelb und sagt, ich soll den Adapter vorher konfigurieren. Ist alles richtig ein gestellt, alles neu gestartet, rebootet usw nichts. Er bleibt auf gelb. Ich glaub das war es für mich. Nachdem ich nun Stunden gebraucht habe, alles zu paaren, die ganzen IKEA Fernbedienungen programmiert und alle Scripte umgeschrieben. Ist jetzt alles futsch und im Haus geht Lampentechnisch nichts mehr. Das gibt morgen früh Ärger mit der Chefin :( Zuerst haben noch die Gruppen wunderbar funktoniert, dann konnte ich sie nicht mehr ansprechen und musste die Lampen im Script alle einzeln ansprechen. Damit konnte ich noch leben, aber jetzt ist der Supergau. :(
                    zigbee.0	2019-03-17 22:50:25.735	error	Error while starting zigbee-shepherd!. Error: Error: No such file or directory, cannot open /dev/serial/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9DE6A-if00
                    zigbee.0	2019-03-17 22:50:25.719	info	Starting zigbee-shepherd
                    Nach dem Befehl: # ls -la /dev/serial/by-id/
                    usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9DE6A-if00 -> ../../ttyACM0
                    Das sollte doch richtig eingetragen sein oder? Zumindest lief es bis vor ein paar Minuten
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #801
                    @smarti2015
                    es gibt ein Problem in der Firmware bei Devices > 30.. ist bestätugt
                    https://github.com/Koenkk/Z-Stack-firmware/issues/60
                    • arteckA arteck
                      @smarti2015
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #802
                      @arteck
                      Wobei es aus meiner Sicht so aus sieht das der Ansatz von Koenkk mit dem Heap-Problem richtig ist - 30 ist keine harte Grenze. Anscheinend ist es so das Router mehr Speicher auf dem Coordinator benötigen als End-Devices, daher ist eher Schluss wenn man viele Router (i.e. Lampen, Steckdosen, etc.) einsetzt.
                      Diese Grenze gibt es im Übrigen auch bei allen anderen mir bekannten Gateways. (Hue, deConz, Xiaomi, etc. Sie liegt aber immer anders.)
                        smarti2015
                        #803
                        Naja als ich sag mal es waren vielleicht so 26 oder 27 genau. Über 30 war ich nicht. Hab jetzt alles zurückgesetzt, neu geflasht und er erkennt wieder Lampen usw. Nur ich hab es dann gestern aufgegeben, gab dann nur eine Notbeleuchtung heute morgen und schnell raus, bevor die Chefin wach geworden ist.
                        Setze mich heute Nachmittag wieder ran. Also ich wollte eigentlich schon gern IKEA und HUE Gateways verbannen und meine Xiaomi Sensoren alle einbinden. Da komme ich auf alle Fälle über 30. Heißt das jetzt es geht nicht, oder solange bis eine ne FW für den Stick kommt, oder wird das nicht klappen.
                        Die Frage ist auch, wir hatten die Tage ja Thema zu viele Repeater/Router. Jeder meiner Lampen ist ja ein Repeater oder? Teilweise hab ich sogar 3 LEDs in einer Lampe. Da kommen ne Menge Repeater zusammen, allerdings hat das mit den Gateways immer problemlos funktioniert.
                        Was mir gestern abend noch aufgefallen ist, es hat alles geklappt, bis ich 1 oder 2 Hue Lampen reinnehmen wollte. Dann war alles futsch. Nachdem Reset und dem Neuflashen habe ich dann erst 2-3 andere Lampen gepaart und dann kam ich wieder zur den Hues. Prompt fing es wieder an zu spinnen. Hab mir leider das Log nicht aufgehoben, aber mir kam es so vor, als würde tatsächlich eine Lampe das Problem verursachen. Könnte das sein?
                        GEEKOM AS 6
                        • S smarti2015
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #804
                          @smarti2015 sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte:
                          Ich rechne nicht damit das alleine durch den Einsatz von "vielen Routern in Lampenform" Probleme auftauchen. Wenn das so wäre wären alle bestehenden Hue Topologieen instabil, da diese zu mehr als 50% aus Routern bestehen.
                          Der Damals verlinkte Text kam vom BSI und ist für sicherheitskritische Anwendungen gedacht. Die darin vorkommenden Anmerkungen sind nicht falsch, treffen aber auf diese Situation einfach nicht zu. Mehrere Leuchten in einer Lampe werden sich nicht als Kette mit dem Koordinator verbinden, sondern jede einzelne, solange der Koordinator selber noch genügend end-devices ansprechen kann.
                          Hier gibt es ggf. einen Zusammenhang - da muss aber auf der Firmware-seite geschaut werden. Es ist denkbar das der Speicherbedarf pro Gerät auf dem Koordinator davon abhängig ist wie das Gerät (softwaretechnisch, logisch) aufgebaut ist. Ob es da signifikante Unterschiede zwischen verschiedenen Zigbee Geräten gibt weiss ich noch nicht.
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            #805
                            jao das was bei mir auch so.. solange Hues nicht im spiel waren..aber das ist reine Vermutung meiner seits
                            . hmm da du auch mit Hues arbeitest währe vielleicht (auch wens lässtig ist) hilfreich meine Vermutung zu bestätigen.. also zu schauen obs ohne Hues und Devices > 30 alleg geht und solange eine Hue ins spiel kommt die Verbindung abgebrochen wird
                            • G Offline
                              gosund
                              schrieb am zuletzt editiert von gosund
                              #806
                              Probier doch mal die max-devices Firmware:
                              https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/CC2531/alternatives/max_devices
                              https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/CC2531/alternatives/max_devices/bin
                              AsgothianA arteckA 2 Antworten Letzte Antwort
                              • G gosund
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #807
                                @gosund sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte:
                                Vorsicht - da die Hue Lampen Router sind ist es denkbar das diese FW so ziemlich sofort nicht geht. Bitte nicht mit einem grossen "produktiv" netz ausprobieren :)
                                • G gosund
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #808
                                  @gosund
                                  nein Vergiss es .. diese Firmware ist nur zum Betrieb ohne Router gedacht.. da hier der Speicher anders verwaltet(ausgereizt) wird
                                    smarti2015
                                    #809
                                    Also ich habe zuerst Xiaomi Temperatur Sensoren und Bewegungsmelder verbunden, dann ne Menge IKEA und ein paar Hue dazwischen. Bis dahin lief alles super. Dann kam ich zu den Flur Hue Lampen und vom Gefühl her, lag es jetzt an der einen Lampe. Wie gesagt, als ich alles neu gemacht habe und grad 4 Lampen gepaart hatte, kam wieder diese LED und irgendwie ging es wieder los. Ich würde die heute einfach mal weglassen und alles neu aufbauen. Das Gute ist, man lernt ja viel übers System und es flutscht dann immer besser 😁
                                    Hab es noch nicht aufgegeben, weil ich gern alles über ZigBee Stick steuern will, aber ich befürchte langsam das ich zuviele Geräte habe. Hab ja noch nicht alle IKEA Lampen drin und die Rauchmelder sollten auch rein von Honeywell, wobei ich die wohl lieber im Xiaomi Gateway erstmal drin lasse.
                                    Hab da noch zwei Fragen:
                                    1. Das beim Paaren bereits angelernte Lampen immer wieder erkannt und gepaart werden ist normal oder? Selbst wenn die 60 Sekunden abgelaufen sind und ich das Fenster offen lassen kommen Minuten später noch Meldungen über erkannte Lampen. Woher weiss ich, das er mit dem Suchen fertig ist?
                                    2. Könnt ihr kurz bitte erklären was die Farbe und Zahlen bedeuten? Mal ist es rot, mal blau
                                    1. Ich habe angefangen mit den Gruppen zu arbeiten und das hat sich super in den Scripten dann gemacht um einfach mal einen Raum mit mehreren Lampen über einen Befehl anzusprechen. Auf einmal funktionierten die Gruppen aber nicht mehr. Einzeln konnte man die Lampen über ZigBee steuern über die Gruppe nicht mehr. Funktioniert das schon stabil oder sollte man das lieber noch nicht verwenden
                                    2. Ab wann muss man eigentlich wieder neu paaren? Immer wenn ich den Adapter deinstalliere und neu installiere, wenn ich den Stick mit der gleichen Version flashe oder wenn ich einen neue Version flashe? Kann man das irgendwie sichern oder wird da immer nen neuer Verschlüsselungs-Code generiert und man muss daher immer neu paaren?
                                    DANKE!!!!
                                    GEEKOM AS 6
                                    G D AsgothianA 3 Antworten Letzte Antwort
                                    • S smarti2015
                                      DANKE!!!!
                                      gosund
                                      #810
                                      @smarti2015 Hol' Dir doch einfach einen zweiten Stick und mach' zwei Netze draus.
                                      Habe gerade welche für US$ 4.84 inkl. Versand gefunden, hole mir gleich auch noch einen :)
                                      http://s.click.aliexpress.com/e/KrlQ2Ms
                                      • S smarti2015
                                        DANKE!!!!
                                        der_maik
                                        #811
                                        @smarti2015 Ich habe so ziemlich genau die Problem wie du. Und so langsam zweifle ich daran das es ausschließlich an der Firmware und der Menge der Geräte liegt, weil die Probleme erst mit der 0.10.2 aufgetaucht sind. Meine Gruppen funktionieren seit der 0.10.2 ebenfalls nicht mehr und auch erst seit der 0.10.2 werden bei mir immer wieder bereits gekoppelte Geräte neu gekoppelt.
                                        • G gosund
                                          smarti2015
                                          #812
                                          @gosund ah wenn das geht mach ich das glatt. Wenn dann da zwei Sticks in relativer Nähe zusammen funken das stört nicht ?
                                          GEEKOM AS 6
                                          G 1 Antwort Letzte Antwort
