  4. Error Javascript Adapter nach Sayit
    3.2k
javascript adaptererror
48 Beiträge 4 Kommentatoren 4.4k Aufrufe 1 Beobachtet
    muckel
    schrieb am zuletzt editiert von Jey Cee
    Habt ihr hierzu eine Idee warum er manchmal nach dem Sayit abstürzt?
    javascript.0 2019-03-16 16:49:33.843 info received all objects
    javascript.0 2019-03-16 16:49:33.197 info received all states
    javascript.0 2019-03-16 16:49:32.114 info requesting all objects
    javascript.0 2019-03-16 16:49:32.113 info requesting all states
    javascript.0 2019-03-16 16:49:32.087 info starting. Version 4.1.12 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.3
    host.SmartHome 2019-03-16 16:49:31.191 info instance system.adapter.javascript.0 started with pid 16796
    host.SmartHome 2019-03-16 16:49:01.171 info Restart adapter system.adapter.javascript.0 because enabled
    host.SmartHome 2019-03-16 16:49:01.171 error instance system.adapter.javascript.0 terminated with code null ()
    host.SmartHome 2019-03-16 16:49:01.171 warn instance system.adapter.javascript.0 terminated due to SIGABRT
    Caught 2019-03-16 16:49:01.171 error by controller[12]: 12: 0x15d084f042fd
    Caught 2019-03-16 16:49:01.171 error by controller[12]: v8::internal::Runtime_SetProperty(int, v8::internal::Object**, v8::internal::Isolate*) [io.javascript.0]
    Caught 2019-03-16 16:49:01.171 error by controller[11]: 11:
    Caught 2019-03-16 16:49:01.171 error by controller[11]: v8::internal::Object::SetProperty(v8::internal::LookupIterator*, v8::internal::Handlev8::internal::Object, v8::internal::LanguageMode, v8::internal::Object::StoreFromKeyed) [io.j
    Caught 2019-03-16 16:49:01.171 error by controller[10]: 10:
    Caught 2019-03-16 16:49:01.171 error by controller[10]: v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handlev8::internal::Object, v8::internal::PropertyAttributes, v8::internal::Object::ShouldThrow
    Caught 2019-03-16 16:49:01.171 error by controller[9]: 9:
    Caught 2019-03-16 16:49:01.170 error by controller[9]: v8::internal::JSObject::AddDataElement(v8::internal::Handlev8::internal::JSObject, unsigned int, v8::internal::Handlev8::internal::Object, v8::internal::PropertyAttributes, v8::
    Caught 2019-03-16 16:49:01.170 error by controller[8]: 8:
    Caught 2019-03-16 16:49:01.170 error by controller[8]: 0xd62fb5 [io.javascript.0]
    Caught 2019-03-16 16:49:01.170 error by controller[7]: 7:
    Caught 2019-03-16 16:49:01.170 error by controller[7]: 0xd4b6dc [io.javascript.0]
    Caught 2019-03-16 16:49:01.170 error by controller[6]: 6:
    Caught 2019-03-16 16:49:01.170 error by controller[6]: v8::internal::Factory::NewUninitializedFixedArray(int) [io.javascript.0]
    Caught 2019-03-16 16:49:01.170 error by controller[5]: 5:
    Caught 2019-03-16 16:49:01.170 error by controller[5]: v8::internal::V8::FatalProcessOutOfMemory(char const*, bool) [io.javascript.0]
    Caught 2019-03-16 16:49:01.170 error by controller[4]: 4:
    Caught 2019-03-16 16:49:01.170 error by controller[4]: v8::Utils::ReportOOMFailure(char const*, bool) [io.javascript.0]
    Caught 2019-03-16 16:49:01.170 error by controller[3]: 3:
    Caught 2019-03-16 16:49:01.170 error by controller[3]: 0x8c21ec [io.javascript.0]
    Caught 2019-03-16 16:49:01.170 error by controller[2]: 2:
    Caught 2019-03-16 16:49:01.170 error by controller[2]: node::Abort() [io.javascript.0]
    Caught 2019-03-16 16:49:01.170 error by controller[1]: 1:
    Caught 2019-03-16 16:49:01.170 error by controller[0]: FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
    sonos.0 2019-03-16 16:46:38.397 info try to control id sonos.0.root.192_168_0_100.tts with {"val":"25;http://192.168.0.230:8086/state/sayit.1.tts.mp3","ack":false,"ts":1552751198396,"q":0,"from":"system.adapter.sayit.1","user":"system.u
    sayit.1 2019-03-16 16:46:38.395 info Set "sonos.0.root.192_168_0_100.tts: 25;http://192.168.0.230:8086/state/sayit.1.tts.mp3
    Liebe Grüße
    • M muckel
      Liebe Grüße
      @muckel sagte:
      Das sieht nach zu wenig RAM aus ?
        muckel
        Denke nicht das es am Speicher liegt.
        Betriebssystem
        ubuntu 17.10
        Architektur x64
        CPUs 4
        Geschwindigkeit 935 MHz
        Modell Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
        RAM 15.5 GB
        Node.js v8.11.3 (Es gibt eine neuere Version: v8.15.1)
        NPM 6.7.0
        Festplatte Größe 163.5 GB
        Festplatte frei 141 GB
        Anzahl der Adapter 259
        Aktive Instanzen 36
        • M muckel
          Betriebssystem
          ubuntu 17.10
          Architektur x64
          CPUs 4
          RAM 15.5 GB
          NPM 6.7.0
          Aktive Instanzen 36
          HomoranH Offline
          HomoranH Offline
          @muckel sagte in Error Javascript Adapter nach Sayit:
          Doch!
          weil:
          node v8 bis 8.12 ein Speicherleck hat
          • M muckel
            Betriebssystem
            ubuntu 17.10
            Architektur x64
            CPUs 4
            RAM 15.5 GB
            NPM 6.7.0
            Aktive Instanzen 36
            @muckel sagte:
            RAM 15.5 GB
            Am verfügbaren RAM sicherlich nicht. Hier gibt es eine Lösung, falls Update auf Node 8.15.1 nicht helfen sollte.
              muckel
              danke für die tipps! :-)
              ich habs mal händisch gefixt. schau ma mal ob es nochmal kommt.
              update auf 8.15 oder 10.x macht auch mucken. :-(
              ich schau mir das morgen nochmals genauer an.
                muckel
                schrieb am zuletzt editiert von muckel
                der fix hat leider nichts gebracht. Wieder Absturz wg. memory
                update auf 10.x:
                Last login: Sat Mar 16 22:59:44 2019 from 192.168.0.4
                erich@SmartHome:~$ sudo iobroker stop
                Stopping iobroker controller daemon...
                iobroker controller daemon stopped.
                No "killall.sh" script found. Just stop.
                erich@SmartHome:~$ sudo apt-get --purge remove node nodejs
                E: Paket node kann nicht gefunden werden.
                erich@SmartHome:~$ sudo apt-get autoremove
                0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                erich@SmartHome:~$ node -v
                v8.11.3
                erich@SmartHome:~$ nodejs -v
                v8.11.3
                erich@SmartHome:~$ npm -v
                6.7.0
                was soll ich tun ohne alles zu schrotten?
                Ubuntu 17.10
                Liebe Grüße
                  muckel
                  So, Teilerfolg! :-)
                  erich@SmartHome:/opt/iobroker$ npm -v
                  6.7.0
                  erich@SmartHome:/opt/iobroker$ node -v
                  v10.6.0
                  erich@SmartHome:/opt/iobroker$ nodejs -v
                  v10.6.0
                  Alles funktioniert außer MAXCUL. der findet den Serial Port nicht.
                  gelöscht und neu installiert hab ich den Adapter schon.
                  Gibt es da ein Problem mit V10.x?
                  RFLINK funktioniert!
                  Liebe Grüße
                    muckel
                    eine Frage hätte ich noch,
                    von V 10.6 auf die letzte V 10.15.x (ich glaube 3)
                    wie mache ich es richtig?
                    danke im voraus
                      muckel
                      node = 10.15.3
                      nodejs = 10.6
                      npm = 6.4.1
                      wie installiere ich die nodejs 10.15.3 damit die versionen gleich sind?
                      kann mir da wer einen Tip geben?
                      HomoranH wendy2702W 2 Antworten Letzte Antwort
                      • wendy2702W Online
                        wendy2702W Online
                        Linux?
                        Dann sollte dieser Sprung mit
                        apt update
                        apt upgrade
                        Gehen.
                        Nach dem ersten Befehl kann man sich mit
                        apt —upgradeable
                        Anzeigen lassen für welche Pakete es updates gibt.
                          muckel
                          @wendy2702 said in Error Javascript Adapter nach Sayit:
                          apt —upgradeable
                          ich habe ubuntu 17.10 installiert.
                          installiert er da nicht ubuntu 18.x?
                          • wendy2702W wendy2702
                            Linux?
                            apt update
                            apt upgrade
                            Gehen.
                            apt —upgradeable
                            wendy2702W Online
                            wendy2702W Online
                            @wendy2702
                            Nein. Das wäre ein Distro update, der läuft anders.
                            Mache doch erstmal
                            apt update
                            Wenn du dir unsicher bist.
                            Was kommt dann?
                              muckel
                              apt -update ergibt:
                              erich@SmartHome:~$ sudo apt update
                              OK:1 http://at.archive.ubuntu.com/ubuntu artful InRelease
                              Holen:2 http://at.archive.ubuntu.com/ubuntu artful-updates InRelease [88,7 kB]
                              OK:3 https://deb.nodesource.com/node_10.x artful InRelease
                              Holen:4 http://at.archive.ubuntu.com/ubuntu artful-backports InRelease [74,6 kB]
                              OK:5 http://security.ubuntu.com/ubuntu artful-security InRelease
                              Es wurden 163 kB in 0 s geholt (216 kB/s).
                              Alle Pakete sind aktuell.
                              ich komme über 10.6 nicht hinaus
                              • wendy2702W Online
                                wendy2702W Online
                                Scheinbar steht die neue Version noch nicht in drin:
                                Link Text
                                Dann wohl nur hiermit:
                                Link Text
                                  muckel
                                  genau:
                                  mit curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash - komme ich nur auf version 10.6
                                  17.10 ist nicht mehr supportet lt. UBUNTU. vielleicht liegt es daran?
                                  obwohl:
                                  https://deb.nodesource.com/node_10.x/pool/main/n/nodejs/https://deb.nodesource.com/node_10.x/pool/main/n/nodejs/nodejs_10.15.3-1nodesource1_arm64.deb
                                  • M muckel
                                    genau:
                                    obwohl:
                                    wendy2702W Online
                                    wendy2702W Online
                                    Das wird es sein.
                                    Kannst es vielleicht noch über NVM
                                    Versuchen.
                                      muckel
                                      Das traue ich mir nicht "probieren"
                                      Das "How To Install Node.js on Ubuntu "16.04"
                                      das ist für 16.04 und nicht für 17.10
                                      gerade mit nodejs node kann das System so zerschossen sein dass nichts mehr geht.
                                      meine reinstall.sh funktioniert auch seit Ewigkeiten nicht und die killall.sh meint er nicht zu finden, dabei sind beide Dateien im folder /opt/iobroker/ rechte auch OK.
                                      Momentan hab ich keine Idee mehr :-(
                                      • wendy2702W Online
                                        wendy2702W Online
                                        Mach ein Backup... der Platte/SD Karte und von ioBroker.
                                        Oder lass es bei 10.6 oder hat es einen besonderen Grund für den Upgrade?
                                          muckel
                                          Ja, viele WARN und ERR beim installieren von Adaptern.
                                          Ab und zu Abstürze vom Javascipt Adapter (1.5.7)
                                          Vielleicht geht das mit 10.15.3 weg. Das ist zumindest der Plan ;-)
                                          Log vom heutigen Chromecast update.
                                          2019-03-19 17:13:24.219 - info: iobroker upgrade chromecast
                                          2019-03-19 17:13:24.743 - info: iobroker Update chromecast from @2.2.2 to @2.2.3
                                          2019-03-19 17:13:24.961 - info: iobroker NPM version: 6.4.1
                                          2019-03-19 17:13:25.182 - info: iobroker npm install iobroker.chromecast@2.2.3 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                                          2019-03-19 17:13:57.148 - info: iobroker ../src/contextify.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE ContextifyContext::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/contextify.cc:62:74: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                          ContextifyContext* ctx = new ContextifyContext(info[0]->ToObject());
                                          In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0,
                                          from ../src/contextify.cc:1:
                                          /home/erich/.node-gyp/10.15.3/include/node/v8.h:10046:15: note: declared here
                                          Local Value::ToObject() const {
                                          2019-03-19 17:13:57.152 - info: iobroker ../src/contextify.cc: In static member function ‘static v8::Local ContextWrap::createV8Context(v8::Local)’:../src/contextify.cc:131:68: error: no matching function for call to ‘v8::Function::NewInstance()’
                                          Local wrapper = Nan::New(constructor)->NewInstance();
                                          /home/erich/.node-gyp/10.15.3/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal v8::Function::NewInstance(v8::Local, int, v8::Local*) const
                                          V8_WARN_UNUSED_RESULT MaybeLocal NewInstance(
                                          2019-03-19 17:13:57.153 - info: iobroker /home/erich/.node-gyp/10.15.3/include/node/v8.h:3993:44: note: candidate expects 3 arguments, 0 provided/home/erich/.node-gyp/10.15.3/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal v8::Function::NewInstance(v8::Local) const
                                          /home/erich/.node-gyp/10.15.3/include/node/v8.h:3996:44: note: candidate expects 1 argument, 0 provided
                                          2019-03-19 17:13:57.154 - info: iobroker ../src/contextify.cc:150:16: error: ‘class v8::ObjectTemplate’ has no member named ‘SetAccessCheckCallbacks’; did you mean ‘SetAccessCheckCallback’? otmpl->SetAccessCheckCallbacks(GlobalPropertyNamedAccessCheck,
                                          2019-03-19 17:13:57.155 - info: iobroker ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertyGetter(v8::Local, const Nan::PropertyCallbackInfo&)’:../src/contextify.cc:176:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                          Local data = info.Data()->ToObject();
                                          2019-03-19 17:13:57.156 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                          2019-03-19 17:13:57.156 - info: iobroker ../src/contextify.cc:182:80: error: no matching function for call to ‘v8::Object::GetRealNamedProperty(v8::Local&)’ Local rv = Nan::New(ctx->sandbox)->GetRealNamedProperty(property);
                                          /home/erich/.node-gyp/10.15.3/include/node/v8.h:3562:43: note: candidate: v8::MaybeLocal v8::Object::GetRealNamedProperty(v8::Local, v8::Local)
                                          V8_WARN_UNUSED_RESULT MaybeLocal GetRealNamedProperty(
                                          /home/erich/.node-gyp/10.15.3/include/node/v8.h:3562:43: note: candidate expects 2 arguments, 1 provided
                                          ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertySetter(v8::Local, v8::Local, const Nan::PropertyCallbackInfo&)’:
                                          ../src/contextify.cc:192:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                          2019-03-19 17:13:57.157 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                          2019-03-19 17:13:57.157 - info: iobroker ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertyQuery(v8::Local, const Nan::PropertyCallbackInfo&)’:../src/contextify.cc:203:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                          2019-03-19 17:13:57.160 - info: iobroker ../src/contextify.cc:209:67: error: no matching function for call to ‘v8::Object::GetRealNamedProperty(v8::Local&)’ if (!Nan::New(ctx->sandbox)->GetRealNamedProperty(property).IsEmpty() ||
                                          2019-03-19 17:13:57.160 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                          ../src/contextify.cc:210:71: error: no matching function for call to ‘v8::Object::GetRealNamedProperty(v8::Local&)’
                                          !Nan::New(ctx->proxyGlobal)->GetRealNamedProperty(property).IsEmpty()) {
                                          2019-03-19 17:13:57.161 - info: iobroker ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertyDeleter(v8::Local, const Nan::PropertyCallbackInfo&)’:../src/contextify.cc:218:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                          2019-03-19 17:13:57.161 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                          2019-03-19 17:13:57.163 - info: iobroker ../src/contextify.cc: In static member function ‘static void ContextWrap::GlobalPropertyEnumerator(const Nan::PropertyCallbackInfo&)’:../src/contextify.cc:229:52: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                          2019-03-19 17:13:57.163 - info: iobroker In file included from /home/erich/.node-gyp/10.15.3/include/node/node.h:63:0, from ../src/contextify.cc:1:
                                          2019-03-19 17:13:57.169 - info: iobroker ../src/contextify.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE ContextifyScript::RunInContext(Nan::NAN_METHOD_ARGS_TYPE)’:../src/contextify.cc:319:62: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                          if (!ContextifyContext::InstanceOf(info[0]->ToObject()))
                                          2019-03-19 17:13:57.169 - info: iobroker ../src/contextify.cc:322:95: warning: ‘v8::Local v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] ContextifyContext* ctx = Nan::ObjectWrap::Unwrap(info[0]->ToObject());
                                          2019-03-19 17:13:57.297 - info: iobroker make: *** [Release/obj.target/contextify/src/contextify.o] Fehler 1
                                          2019-03-19 17:13:57.298 - info: iobroker gyp
                                          2019-03-19 17:13:57.299 - info: iobroker
                                          2019-03-19 17:13:57.299 - info: iobroker ERR! build error
                                          2019-03-19 17:13:57.299 - info: iobroker gyp
                                          2019-03-19 17:13:57.300 - info: iobroker ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                                          gyp ERR! stack at ChildProcess.emit (events.js:189:13)
                                          gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                          2019-03-19 17:13:57.300 - info: iobroker gyp ERR! System Linux 4.13.0-46-genericgyp
                                          2019-03-19 17:13:57.301 - info: iobroker ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/contextify
                                          gyp ERR! node -v v10.15.3
                                          gyp ERR!
                                          2019-03-19 17:13:57.301 - info: iobroker node-gyp -v v3.8.0gyp ERR! not ok
                                          2019-03-19 17:13:59.626 - info: iobroker npm
                                          2019-03-19 17:13:59.627 - info: iobroker WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/arraybuffer.slic/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/base64-arraybuff/package.json'
                                          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-schedule/node_modules/cron-parser/node_modules/is-nan/node_modules/define-properties/node_modules/obj/package.json'
                                          npm
                                          2019-03-19 17:13:59.627 - info: iobroker WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/node_modules/cliui/node_modules/wrap-ansi/node_modules/string-width/node_modules/is-fullwidth-code-p/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-/package.json'
                                          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_modules/cross-spawn/node_modules/which/node_modules/i/package.json'
                                          2019-03-19 17:13:59.628 - info: iobroker npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none is installed. You must install peer dependencies yourself.
                                          2019-03-19 17:13:59.628 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                          npm WARN
                                          2019-03-19 17:13:59.629 - info: iobroker optional SKIPPING OPTIONAL DEPENDENCY: contextify@0.1.15 (node_modules/contextify):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: contextify@0.1.15 install: node-gyp rebuild
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                          2019-03-19 17:13:59.630 - info: iobroker
                                          2019-03-19 17:13:59.657 - info: iobroker npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.chromecast"
