  4. Hue Adapter error socket hang up
huepollingsocket hang up
34 Beiträge 7 Kommentatoren 4.2k Aufrufe 7 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    Fehlermeldung ?? log ??
    • mr_rioesM Offline
      mr_rioesM Offline
      mr_rioes
      hue.0	2019-03-13 06:26:44.366	error	Cannot get result for lightStatus8
      hue.0	2019-03-13 06:26:44.365	error	Error: socket hang up
      hue.0	2019-03-13 06:26:44.255	error	Cannot get result for lightStatus7
      hue.0	2019-03-13 06:26:44.252	error	Error: socket hang up
      hue.0	2019-03-13 06:26:44.140	error	Cannot get result for lightStatus6
      hue.0	2019-03-13 06:26:44.139	error	Error: socket hang up
      hue.0	2019-03-13 06:26:44.029	error	Cannot get result for lightStatus4
      hue.0	2019-03-13 06:26:44.026	error	Error: socket hang up
      hue.0	2019-03-13 06:26:43.918	error	Cannot get result for lightStatus2
      hue.0	2019-03-13 06:26:43.915	error	Error: socket hang up
      hue.0	2019-03-13 06:26:43.799	error	Cannot get result for lightStatus1
      hue.0	2019-03-13 06:26:43.796	error	Error: socket hang up
      hue.0	2019-03-13 06:26:43.679	error	Cannot get result for lightStatus16
      hue.0	2019-03-13 06:26:43.676	error	Error: socket hang up
      hue.0	2019-03-13 06:26:43.564	error	Cannot get result for lightStatus15
      hue.0	2019-03-13 06:26:43.562	error	Error: socket hang up
      hue.0	2019-03-13 06:26:39.377	info	creating/updating bridge device
      hue.0	2019-03-13 06:26:39.377	info	created/updated 6 light groups
      hue.0	2019-03-13 06:26:39.377	info	creating/updating light groups
      hue.0	2019-03-13 06:26:39.377	info	created/updated 10 light channels
      hue.0	2019-03-13 06:26:39.377	info	created/updated 18 switch channels
      hue.0	2019-03-13 06:26:39.377	warn	channel "Philips hue.presenceState" already exists, skipping lamp
      hue.0	2019-03-13 06:26:39.375	info	creating/updating switch channels
      hue.0	2019-03-13 06:26:39.193	info	starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.hue, node: v8.15.0
      EDIT: Log in Code Tags
      • wendy2702W Online
        wendy2702W Online
        Welche Version vom HUE Adapter?
        Mal die Instanz für das Loggen auf Debug stellen bitte.
        • arteckA Offline
          arteckA Offline
          arteck
          nimm die Bridge kurz vom Strom
          • mr_rioesM Offline
            mr_rioesM Offline
            mr_rioes
            Hab das mit diversen Adapter Versionen ausprobiert, immer der gleiche Fehler...
            Aktuell läuft 1.1.2.
            Die Bridge vom Strom nehmen, hab ich schon versucht, hat aber nix gebracht.
            Ein Debug log folgt dann heute Abend...
            • wendy2702W Online
              wendy2702W Online
              Hast du mal Version 0.6.9 probiert?
              • mr_rioesM Offline
                mr_rioesM Offline
                mr_rioes
                bin mir nicht ganz sicher, wie ich die ältere Version installiere...
                BBTownB 1 Antwort Letzte Antwort
                • wendy2702W Online
                  wendy2702W Online
                  Expertenmodus aktivieren, dann hinter dem Adapter auf das "+", gewünschte Version auswählen und installieren.
                  • mr_rioesM mr_rioes
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    schrieb am zuletzt editiert von BBTown
                    @mr_rioes Du kannst allerdings auch eine neue - noch nicht offiziell freigegebene Test-Version v1.2.3 - von jens-maus probieren die bei mir einwandfrei läuft:.
                    Die Installation erfolgt dann über "Adapter" - dort oben auf das "Katzen-Symbol (Installieren aus eigener URL)", auf die Registerkarte "BELIEBIG" wechseln und den Link dort eintragen und installieren.
                    • mr_rioesM Offline
                      mr_rioesM Offline
                      mr_rioes
                      klasse, danke!
                      Werde ich heute abend mal ausprobieren
                      • mr_rioesM Offline
                        mr_rioesM Offline
                        mr_rioes
                        schrieb am zuletzt editiert von mr_rioes
                        So, habe jetzt alles mal durchgetestet, nur leider ohne Erfolg.
                        Allerdings wirft die v1.2.3 andere Fehler aus, die in etwa so aussehen:
                        hue.0	2019-03-13 18:28:33.339	warn	lightQueue: retrying job lightStatus:16:fe163b7c4e7cfef7b6d6d0d3a4cf172d in 25 ms
                        hue.0	2019-03-13 18:28:33.338	warn	lightQueue: job lightStatus:16:fe163b7c4e7cfef7b6d6d0d3a4cf172d failed: Error: socket hang up
                        hue.0	2019-03-13 18:28:33.321	warn	lightQueue: retrying job lightStatus:15:bc9348bef04b2fbbcdd2baab936528a7 in 25 ms
                        hue.0	2019-03-13 18:28:33.320	warn	lightQueue: job lightStatus:15:bc9348bef04b2fbbcdd2baab936528a7 failed: Error: This job timed out after 5000 ms.
                        hue.0	2019-03-13 18:28:33.315	warn	lightQueue: retrying job sensorStatus:56:2e297a6536a3e0514989cdcb057627a8 in 25 ms
                        hue.0	2019-03-13 18:28:33.314	warn	lightQueue: job sensorStatus:56:2e297a6536a3e0514989cdcb057627a8 failed: Error: socket hang up
                        hue.0	2019-03-13 18:28:33.311	warn	lightQueue: retrying job sensorStatus:50:2fd78c8c78757bc54bf7bd67a1c4ad8e in 25 ms
                        hue.0	2019-03-13 18:28:33.310	warn	lightQueue: job sensorStatus:50:2fd78c8c78757bc54bf7bd67a1c4ad8e failed: Error: socket hang up
                        hue.0	2019-03-13 18:28:33.306	warn	lightQueue: retrying job
                        davon dann hunderte, solange das Polling aktiviert ist.
                        Ich nutze übrigens die Bridge V2, hab vergessen das zu erwähnen.
                        Bridge vom Netz nehmen hat leider auch nicht geholfen...
                        • mr_rioesM Offline
                          mr_rioesM Offline
                          mr_rioes
                          niemand eine Idee?
                            Moin moin.
                            Mache grade meinen ersten Gehversuche mit iobroker.
                            Sieht soweit ja sehr vielversprechend aus.
                            Leiser stoße ich bereits jetzt auf ein größeres Problem...
                            Wenn ich im Hue adapter das Polling aktiviere schmiert dieser regelmäßig ab und es ist mir auch nicht möglich die Lampen per iobroker einzuschalten o.Ä.
                            Parallel läuft bei mir als Produktivsystem im Moment noch Domoticz. Dort funktionieren die Lampen / Bewegungsmelder etc. alle Problemfrei. Schließe daraus also, dass das Hue Hub nicht das Problem sein sollte.
                            Ich habe zwar einige Posts hier im Forum gefunden, wo Leute das gleiche Problem schildern, leider aber keine Lösung dazu... Was mich wundert, da Hue nun wirklich kein exotisches System ist.
                            Achja, das Problem tritt mit einer frisch installierten Version(Image von der Website) auf dem Pi3b+ auf.
                            Danke schonmal im Vorraus
                            wendy2702W Online
                            wendy2702W Online
                            @mr_rioes sagte in Hue Adapter error socket hang up:
                            Wie ist der PI mit dem Netzwerk verbunden?
                            LAN / WLAN ?
                            • mr_rioesM Offline
                              mr_rioesM Offline
                              mr_rioes
                              Habe beides schon ausprobiert...
                              • haselchenH Offline
                                haselchenH Offline
                                haselchen
                                Und was ist mit der Idee die Version 0.6.9 zu installieren?
                                Bisher die Stabilste.
                                Im Adapter selber die IP der Bridge eingegeben und neuen User erstellt?
                                  wendy2702W Online
                                  wendy2702W Online
                                  Ergiebige Antwort...
                                  Andere Frage... wie sind ioBroker Rechner und HUE Bridge im Netzwerk eingebunden?
                                  Repeater/ APs/ Powerlan oder irgendetwas dazwischen?
                                  Mal einen PING vom ioBroker Rechner auf die Bridge gemacht und geschaut wie die Zeiten sind oder ob es aussetzer gibt?
                                  Mal einen neuen User eingerichtet?
                                  Wurden mit irgendeiner Fremdapp Lampen / Scenen etc. hinzugefügt?
                                  mr_rioesM 1 Antwort Letzte Antwort
                                  • wendy2702W wendy2702
                                    mr_rioesM Offline
                                    mr_rioesM Offline
                                    mr_rioes
                                    Bridge ist per lan Kabel direkt an der FritzBox, keine Repeater oder ähnliches.
                                    Die Ping Zeiten sind normal (1-5ms) .
                                    Es sind Philips fremde Geräte an der Bridge angemeldet (Osram Steckdose, noname LED-Stripe). Diese wurden aber alle mit der Hue App angelegt.
                                    User habe ich mehrfach an der Bridge neu erstellt. die Version 0.6.9 hat leider bei mir zu dem selben Fehler geführt.
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      ich weiss aus persönliche rErfahrung das die Software Version an der Bridge ne rolle Spielt..
                                      was bzw. wann lief da das letzte Update...
                                      ich kann mich entsinnen das die Tage was rauskam..
                                      ich habe meine 0.6.9 am laufen.. ab und an habe ich auch ein error dass ne Birne nicht erreichbar war
                                      • wendy2702W Online
                                        wendy2702W Online
                                        Ich habe Adapter 0.6.9 und auf der HUE Bridge SW: 1901181309
                                        Aktuell 13 Lampen davon 2 mal OSRAM
                                        Diese Einstellungen:
                                        Gibt es vielleicht im Syslog noch etwas das einen Hinweis geben könnte?
                                        Was heißt "frisch installierte Version" genau?
                                        Welche Versionen Admin, NodeJS, NPM, JS-Controller?
                                        Läuft noch etwas anderes auf dem PI?
                                        • cashC Offline
                                          cashC Offline
                                          cash
                                          Was ist denn bei Polling eingestellt?
                                          Wieviele Lampen hast Du?
                                          Welche Zeit hast Du bei Deimen Produktivsystem als Pollingzeit eingestellt?
                                          Die Hue-Bridge informiert niemanden über eine Änderung. Das heißt jedes andere System muss die Daten regelmäßig abfragen. Und jetzt kommt das Problem: Mehr als 10 Abfragen pro Sekunden verkraftet die Hue-Bridge nicht. Wenn Du nun ein Polling von 1 Sekunde eingestellt hast und mehr als 10 Lampen kommt es zwangsweise zu Problemen.
                                          Also Deines altes System deaktivieren. Bei ioborker Polling auf 30 Sekunden oder mehr und es sollte laufen. Nachteil: Du siehst nur zeitverzögert welche Lampen an und aus sind wenn Du die nicht 100% über iobroker steuerst.
                                          arteckA mr_rioesM 2 Antworten Letzte Antwort
