[Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
Neustart durchgeführt -> ohne Besserung…
Hier das Log nach dem Neustart:
! tuya.0 2019-02-09 15:17:27.193 debug stateChange tuya.0.72824806cc50e3576445.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1549721847191,"q":0,"from":"system.adapter.tuya.0","lc":1549719722883}
! tuya.0 2019-02-09 15:17:27.185 debug stateChange tuya.0.72824806cc50e3576445.9 {"val":"ffff5001ff0000","ack":true,"ts":1549721847183,"q":0,"from":"system.adapter.tuya.0","lc":1549719722876}
! tuya.0 2019-02-09 15:17:27.177 debug stateChange tuya.0.72824806cc50e3576445.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1549721847174,"q":0,"from":"system.adapter.tuya.0","lc":1549719722869}
! tuya.0 2019-02-09 15:17:27.169 debug stateChange tuya.0.72824806cc50e3576445.7 {"val":"ffff500100ff00","ack":true,"ts":1549721847166,"q":0,"from":"system.adapter.tuya.0","lc":1549719722861}
! tuya.0 2019-02-09 15:17:27.159 debug stateChange tuya.0.72824806cc50e3576445.6 {"val":"00ff0000000000","ack":true,"ts":1549721847157,"q":0,"from":"system.adapter.tuya.0","lc":1549719722854}
! tuya.0 2019-02-09 15:17:27.151 debug stateChange tuya.0.72824806cc50e3576445.5 {"val":"5900ff0105ffff","ack":true,"ts":1549721847149,"q":0,"from":"system.adapter.tuya.0","lc":1549719722847}
! tuya.0 2019-02-09 15:17:27.143 debug stateChange tuya.0.72824806cc50e3576445.4 {"val":255,"ack":true,"ts":1549721847141,"q":0,"from":"system.adapter.tuya.0","lc":1549719722839}
! tuya.0 2019-02-09 15:17:27.134 debug stateChange tuya.0.72824806cc50e3576445.3 {"val":255,"ack":true,"ts":1549721847132,"q":0,"from":"system.adapter.tuya.0","lc":1549719722826}
! tuya.0 2019-02-09 15:17:27.126 debug stateChange tuya.0.72824806cc50e3576445.2 {"val":"colour","ack":true,"ts":1549721847123,"q":0,"from":"system.adapter.tuya.0","lc":1549719722819}
! tuya.0 2019-02-09 15:17:27.119 debug stateChange tuya.0.72824806cc50e3576445.1 {"val":false,"ack":true,"ts":1549721847116,"q":0,"from":"system.adapter.tuya.0","lc":1549720625745}
! tuya.0 2019-02-09 15:17:27.104 info 72824806cc50e3576445: No schema exists, init basic states …
! tuya.0 2019-02-09 15:17:27.103 debug 72824806cc50e3576445: Received data: {"1":false,"2":"colour","3":255,"4":255,"5":"5900ff0105ffff","6":"00ff0000000000","7":"ffff500100ff00","8":"ffff8003ff000000ff000000ff000000000000000000","9":"fff
! tuya.0 2019-02-09 15:17:27.100 debug stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1549721847095,"q":0,"from":"system.adapter.tuya.0","lc":1549721847095}
! tuya.0 2019-02-09 15:17:27.099 debug connected set to true
! tuya.0 2019-02-09 15:17:27.097 debug stateChange tuya.0.72824806cc50e3576445.online {"val":true,"ack":true,"ts":1549721847090,"q":0,"from":"system.adapter.tuya.0","lc":1549721847090}
! tuya.0 2019-02-09 15:17:27.089 debug 72824806cc50e3576445: Connected to device
! tuya.0 2019-02-09 15:17:27.077 info Discover for local Tuya devices on port 6666
! tuya.0 2019-02-09 15:17:27.063 info Existing devices initialized
! tuya.0 2019-02-09 15:17:27.062 info 72824806cc50e3576445: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
! tuya.0 2019-02-09 15:17:27.056 info 72824806cc50e3576445 Init with IP=192.168.0.79, Key=undefined
! tuya.0 2019-02-09 15:17:27.019 debug connected set to false
! tuya.0 2019-02-09 15:17:27.003 debug 72824806cc50e3576445: Create device objects if not exist
! tuya.0 2019-02-09 15:17:27.001 debug 72824806cc50e3576445: Schema found for rrOujSy4Pf1BwEgV: null
! tuya.0 2019-02-09 15:17:27.000 debug init 1 known devices
! tuya.0 2019-02-09 15:17:26.988 info starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.15.0
! tuya.0 2019-02-09 15:17:26.876 debug statesDB connected
! tuya.0 2019-02-09 15:17:26.840 debug objectDB connected -
Bekomme die Lampe nicht mit Namen angezeigt und erhalte die Datenpunkte nicht in Echtzeit.
Ich habe mehrfach den Proxy-Sync ausgeführt.
Zertifikat installiert - Proxy-Einstellungen in WLAN geändert bzw. eingestellt -> IP des ioBrokers und Port 8888. Smart-Life App geöffnet und aktualisiert. Der Proxy-Server musste manuell gestoppt werden.
Zustand wie beschrieben.
Also:
1.) Echtzeit Updates vom gerät sollte auch ohne Proxy Sync kommen und in deinem Log war wenigstens einmal Daten drin. Die Geräte schicken aber nur ein/aus wirklich Echtzeit, Verbrauchsdaten oder so nur bei Änderungen über bestimmten Schwellen. Hier Debug Log und beobachten wenn Du was änderst. Da reicht das Log vom Start allein nicht aus.
Ansonsten: Die App auf dem Handy ist zu bzw sogar gekillt? Das kann auch ein Grund sein
2.) Wenn der proxy Sync geklappt hätte wäre der proxy automatisch aus gegangen und du hättest einen Haken gesehn UND im Log würde nicht stehen:
tuya.0 2019-02-09 15:17:27.062 info 72824806cc50e3576445: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!Ergo: Proxy-Sync hat nicht geklappt. Kamen irgendwelche Fehler in der App als Du nach dem Setup über den Proxy die App neu gestartet hast?
Sonst wäre auch hier das Log hochinteressant
Hier noch einmal das Log nach Start des Proxy-Servers:
Leider ist der Name des Geräts immer noch nicht da und auch der Adapter zeigt nicht das Schema und Echtzeit-Update an:
! tuya.0 2019-02-09 16:44:27.731 debug stateChange tuya.0.72824806cc50e3576445.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1549727067723,"q":0,"from":"system.adapter.tuya.0","lc":1549719722883}
! tuya.0 2019-02-09 16:44:27.731 debug stateChange tuya.0.72824806cc50e3576445.9 {"val":"ffff5001ff0000","ack":true,"ts":1549727067723,"q":0,"from":"system.adapter.tuya.0","lc":1549719722876}
! tuya.0 2019-02-09 16:44:27.731 debug stateChange tuya.0.72824806cc50e3576445.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1549727067722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722869}
! tuya.0 2019-02-09 16:44:27.731 debug stateChange tuya.0.72824806cc50e3576445.7 {"val":"ffff500100ff00","ack":true,"ts":1549727067722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722861}
! tuya.0 2019-02-09 16:44:27.731 debug stateChange tuya.0.72824806cc50e3576445.6 {"val":"00ff0000000000","ack":true,"ts":1549727067722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722854}
! tuya.0 2019-02-09 16:44:27.731 debug stateChange tuya.0.72824806cc50e3576445.5 {"val":"5900ff0105ffff","ack":true,"ts":1549727067722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722847}
! tuya.0 2019-02-09 16:44:27.731 debug stateChange tuya.0.72824806cc50e3576445.4 {"val":255,"ack":true,"ts":1549727067720,"q":0,"from":"system.adapter.tuya.0","lc":1549719722839}
! tuya.0 2019-02-09 16:44:27.730 debug stateChange tuya.0.72824806cc50e3576445.3 {"val":255,"ack":true,"ts":1549727067720,"q":0,"from":"system.adapter.tuya.0","lc":1549719722826}
! tuya.0 2019-02-09 16:44:27.721 debug stateChange tuya.0.72824806cc50e3576445.2 {"val":"colour","ack":true,"ts":1549727067718,"q":0,"from":"system.adapter.tuya.0","lc":1549719722819}
! tuya.0 2019-02-09 16:44:27.719 debug stateChange tuya.0.72824806cc50e3576445.1 {"val":false,"ack":true,"ts":1549727067716,"q":0,"from":"system.adapter.tuya.0","lc":1549720625745}
! tuya.0 2019-02-09 16:44:27.718 debug 72824806cc50e3576445: Received data: {"1":false,"2":"colour","3":255,"4":255,"5":"5900ff0105ffff","6":"00ff0000000000","7":"ffff500100ff00","8":"ffff8003ff000000ff000000ff000000000000000000","9":"ffff
! tuya.0 2019-02-09 16:43:27.733 debug stateChange tuya.0.72824806cc50e3576445.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1549727007727,"q":0,"from":"system.adapter.tuya.0","lc":1549719722883}
! tuya.0 2019-02-09 16:43:27.733 debug stateChange tuya.0.72824806cc50e3576445.9 {"val":"ffff5001ff0000","ack":true,"ts":1549727007727,"q":0,"from":"system.adapter.tuya.0","lc":1549719722876}
! tuya.0 2019-02-09 16:43:27.732 debug stateChange tuya.0.72824806cc50e3576445.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1549727007726,"q":0,"from":"system.adapter.tuya.0","lc":1549719722869}
! tuya.0 2019-02-09 16:43:27.729 debug stateChange tuya.0.72824806cc50e3576445.7 {"val":"ffff500100ff00","ack":true,"ts":1549727007725,"q":0,"from":"system.adapter.tuya.0","lc":1549719722861}
! tuya.0 2019-02-09 16:43:27.729 debug stateChange tuya.0.72824806cc50e3576445.6 {"val":"00ff0000000000","ack":true,"ts":1549727007722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722854}
! tuya.0 2019-02-09 16:43:27.729 debug stateChange tuya.0.72824806cc50e3576445.5 {"val":"5900ff0105ffff","ack":true,"ts":1549727007722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722847}
! tuya.0 2019-02-09 16:43:27.728 debug stateChange tuya.0.72824806cc50e3576445.4 {"val":255,"ack":true,"ts":1549727007722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722839}
! tuya.0 2019-02-09 16:43:27.726 debug stateChange tuya.0.72824806cc50e3576445.3 {"val":255,"ack":true,"ts":1549727007721,"q":0,"from":"system.adapter.tuya.0","lc":1549719722826}
! tuya.0 2019-02-09 16:43:27.722 debug stateChange tuya.0.72824806cc50e3576445.2 {"val":"colour","ack":true,"ts":1549727007717,"q":0,"from":"system.adapter.tuya.0","lc":1549719722819}
! tuya.0 2019-02-09 16:43:27.719 debug stateChange tuya.0.72824806cc50e3576445.1 {"val":false,"ack":true,"ts":1549727007715,"q":0,"from":"system.adapter.tuya.0","lc":1549720625745}
! tuya.0 2019-02-09 16:43:27.715 debug 72824806cc50e3576445: Received data: {"1":false,"2":"colour","3":255,"4":255,"5":"5900ff0105ffff","6":"00ff0000000000","7":"ffff500100ff00","8":"ffff8003ff000000ff000000ff000000000000000000","9":"ffff
! tuya.0 2019-02-09 16:42:27.732 debug stateChange tuya.0.72824806cc50e3576445.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1549726947722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722883}
! tuya.0 2019-02-09 16:42:27.732 debug stateChange tuya.0.72824806cc50e3576445.9 {"val":"ffff5001ff0000","ack":true,"ts":1549726947722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722876}
! tuya.0 2019-02-09 16:42:27.732 debug stateChange tuya.0.72824806cc50e3576445.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1549726947722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722869}
! tuya.0 2019-02-09 16:42:27.732 debug stateChange tuya.0.72824806cc50e3576445.7 {"val":"ffff500100ff00","ack":true,"ts":1549726947722,"q":0,"from":"system.adapter.tuya.0","lc":1549719722861}
! tuya.0 2019-02-09 16:42:27.732 debug stateChange tuya.0.72824806cc50e3576445.6 {"val":"00ff0000000000","ack":true,"ts":1549726947721,"q":0,"from":"system.adapter.tuya.0","lc":1549719722854}
! tuya.0 2019-02-09 16:42:27.732 debug stateChange tuya.0.72824806cc50e3576445.5 {"val":"5900ff0105ffff","ack":true,"ts":1549726947721,"q":0,"from":"system.adapter.tuya.0","lc":1549719722847}
! tuya.0 2019-02-09 16:42:27.731 debug stateChange tuya.0.72824806cc50e3576445.4 {"val":255,"ack":true,"ts":1549726947721,"q":0,"from":"system.adapter.tuya.0","lc":1549719722839}
! tuya.0 2019-02-09 16:42:27.722 debug stateChange tuya.0.72824806cc50e3576445.3 {"val":255,"ack":true,"ts":1549726947719,"q":0,"from":"system.adapter.tuya.0","lc":1549719722826}
! tuya.0 2019-02-09 16:42:27.720 debug stateChange tuya.0.72824806cc50e3576445.2 {"val":"colour","ack":true,"ts":1549726947717,"q":0,"from":"system.adapter.tuya.0","lc":1549719722819}
! tuya.0 2019-02-09 16:42:27.718 debug stateChange tuya.0.72824806cc50e3576445.1 {"val":false,"ack":true,"ts":1549726947714,"q":0,"from":"system.adapter.tuya.0","lc":1549720625745}
! tuya.0 2019-02-09 16:42:27.714 debug 72824806cc50e3576445: Received data: {"1":false,"2":"colour","3":255,"4":255,"5":"5900ff0105ffff","6":"00ff0000000000","7":"ffff500100ff00","8":"ffff8003ff000000ff000000ff000000000000000000","9":"ffff
! tuya.0 2019-02-09 16:41:57.874 debug sendTo "stopProxy" to system.adapter.admin.0 from system.adapter.tuya.0
! tuya.0 2019-02-09 16:41:57.874 debug Message: {"command":"stopProxy","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":22,"ack":false,"time":1549726917863},"_id":37607884}
! tuya.0 2019-02-09 16:41:27.731 debug stateChange tuya.0.72824806cc50e3576445.10 {"val":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","ack":true,"ts":1549726887724,"q":0,"from":"system.adapter.tuya.0","lc":1549719722883}
! tuya.0 2019-02-09 16:41:27.731 debug stateChange tuya.0.72824806cc50e3576445.9 {"val":"ffff5001ff0000","ack":true,"ts":1549726887723,"q":0,"from":"system.adapter.tuya.0","lc":1549719722876}
! tuya.0 2019-02-09 16:41:27.731 debug stateChange tuya.0.72824806cc50e3576445.8 {"val":"ffff8003ff000000ff000000ff000000000000000000","ack":true,"ts":1549726887721,"q":0,"from":"system.adapter.tuya.0","lc":1549719722869}
! tuya.0 2019-02-09 16:41:27.731 debug stateChange tuya.0.72824806cc50e3576445.7 {"val":"ffff500100ff00","ack":true,"ts":1549726887720,"q":0,"from":"system.adapter.tuya.0","lc":1549719722861}
! tuya.0 2019-02-09 16:41:27.731 debug stateChange tuya.0.72824806cc50e3576445.6 {"val":"00ff0000000000","ack":true,"ts":1549726887720,"q":0,"from":"system.adapter.tuya.0","lc":1549719722854}
! tuya.0 2019-02-09 16:41:27.730 debug stateChange tuya.0.72824806cc50e3576445.5 {"val":"5900ff0105ffff","ack":true,"ts":1549726887720,"q":0,"from":"system.adapter.tuya.0","lc":1549719722847}
! tuya.0 2019-02-09 16:41:27.730 debug stateChange tuya.0.72824806cc50e3576445.4 {"val":255,"ack":true,"ts":1549726887719,"q":0,"from":"system.adapter.tuya.0","lc":1549719722839}
! tuya.0 2019-02-09 16:41:27.724 debug stateChange tuya.0.72824806cc50e3576445.3 {"val":255,"ack":true,"ts":1549726887718,"q":0,"from":"system.adapter.tuya.0","lc":1549719722826}
! tuya.0 2019-02-09 16:41:27.724 debug stateChange tuya.0.72824806cc50e3576445.2 {"val":"colour","ack":true,"ts":1549726887716,"q":0,"from":"system.adapter.tuya.0","lc":1549719722819}
! tuya.0 2019-02-09 16:41:27.723 debug stateChange tuya.0.72824806cc50e3576445.1 {"val":false,"ack":true,"ts":1549726887713,"q":0,"from":"system.adapter.tuya.0","lc":1549720625745}
! tuya.0 2019-02-09 16:41:27.718 debug 72824806cc50e3576445: Received data: {"1":false,"2":"colour","3":255,"4":255,"5":"5900ff0105ffff","6":"00ff0000000000","7":"ffff500100ff00","8":"ffff8003ff000000ff000000ff000000000000000000","9":"ffff
! tuya.0 2019-02-09 16:41:23.140 debug sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0 -
Hallo noch einmal - wollte nur Feedback geben, dass nun alles läuft und es einen wichtigen Punkt zu beachten gibt, wenn man das Prozedere nicht täglich durchläuft. Meine Fehler ist es gewesen im iOS 12 die Zertifikatsvertrauenseinstellungen zu aktivieren.
Zu finden unter: Einstellungen -> Allgemein -> Zertifikatsvertrauenseinstellungen -> AnyProxy aktivieren.
Das war bei mir nicht standardmässig aktiviert.
@apollon77 -> Das Bild ist von deinem GitHub Account: https://github.com/Apollon77/ioBroker.tuya/blob/master/PROXY.md
Danke für die Mühen
EDIT: Folgende Lampen wurden erfolgreich hinzugefügt.
Hallo - ich schon wieder :(
nach erfolgreicher Einrichtung vor 3 Tagen habe ich jetzt ein weiteres Problem.
Gestern war mein Log vom Tuya-Adapter ca. 535MB gross geworden - immer mit der Meldung (siehe unten). Alle 2-3 Sekunden kommt die gleiche Meldung, dass die App gestartet ist, was definitiv nicht der Fall ist.Ich habe bisher die Geräte vom WLAN getrennt, mein iPhone mit der App ausgemacht und auch den ioB neugestartet.
Nach Start des Tuya-Adapters erscheint immer wieder die gleiche Meldung:tuya.0 2019-02-13 14:04:51.370 debug stateChange tuya.0.85873706cc50e3c9df4b.10 {"val":"ffff0506ff000000ff00ffff00ff00ff0000ffff0000","ack":true,"ts":1550063091363,"q":0,"from":"system.adapter.tuya.0","lc":1549803745303} tuya.0 2019-02-13 14:04:51.370 debug stateChange tuya.0.85873706cc50e3c9df4b.9 {"val":"ffff5001ff0000","ack":true,"ts":1550063091363,"q":0,"from":"system.adapter.tuya.0","lc":1549803445268} tuya.0 2019-02-13 14:04:51.369 debug stateChange tuya.0.85873706cc50e3c9df4b.8 {"val":"ffff8006ff000000ff000000ffff0000ff0000ff0000","ack":true,"ts":1550063091363,"q":0,"from":"system.adapter.tuya.0","lc":1549803745302} tuya.0 2019-02-13 14:04:51.369 debug stateChange tuya.0.85873706cc50e3c9df4b.7 {"val":"ffff500100ff00","ack":true,"ts":1550063091362,"q":0,"from":"system.adapter.tuya.0","lc":1549803445267} tuya.0 2019-02-13 14:04:51.369 debug stateChange tuya.0.85873706cc50e3c9df4b.6 {"val":"bd76000168ffff","ack":true,"ts":1550063091362,"q":0,"from":"system.adapter.tuya.0","lc":1549803745302} tuya.0 2019-02-13 14:04:51.369 debug stateChange tuya.0.85873706cc50e3c9df4b.5 {"val":"fbff00003dffff","ack":true,"ts":1550063091362,"q":0,"from":"system.adapter.tuya.0","lc":1549803445264} tuya.0 2019-02-13 14:04:51.369 debug stateChange tuya.0.85873706cc50e3c9df4b.4 {"val":255,"ack":true,"ts":1550063091361,"q":0,"from":"system.adapter.tuya.0","lc":1549803445264} tuya.0 2019-02-13 14:04:51.369 debug stateChange tuya.0.85873706cc50e3c9df4b.3 {"val":255,"ack":true,"ts":1550063091361,"q":0,"from":"system.adapter.tuya.0","lc":1549803445263} tuya.0 2019-02-13 14:04:51.361 debug stateChange tuya.0.85873706cc50e3c9df4b.2 {"val":"0","ack":true,"ts":1550063091359,"q":0,"from":"system.adapter.tuya.0","lc":1550062371581} tuya.0 2019-02-13 14:04:51.359 debug stateChange tuya.0.85873706cc50e3c9df4b.1 {"val":true,"ack":true,"ts":1550063091356,"q":0,"from":"system.adapter.tuya.0","lc":1550062365344} tuya.0 2019-02-13 14:04:51.354 debug 85873706cc50e3c9df4b: Received data: {"1":true,"2":"white","3":255,"4":255,"5":"fbff00003dffff","6":"bd76000168ffff","7":"ffff500100ff00","8":"ffff8006ff000000ff000000ffff0000ff0000ff0000","9":"ffff5 tuya.0 2019-02-13 14:04:51.353 debug stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1550063091350,"q":0,"from":"system.adapter.tuya.0","lc":1550063091350} tuya.0 2019-02-13 14:04:51.352 debug connected set to true tuya.0 2019-02-13 14:04:51.351 debug stateChange tuya.0.85873706cc50e3c9df4b.online {"val":true,"ack":true,"ts":1550063091348,"q":0,"from":"system.adapter.tuya.0","lc":1550063091348} tuya.0 2019-02-13 14:04:51.347 debug 85873706cc50e3c9df4b: Connected to device tuya.0 2019-02-13 14:04:51.339 info 85873706cc50e3c9df4b Init with IP=192.168.0.80, Key=e4976c3b6b8fb1b0 tuya.0 2019-02-13 14:04:51.290 debug stateChange tuya.0.85873706cc50e3c9df4b.ip {"val":"192.168.0.80","ack":true,"ts":1550063091288,"q":0,"from":"system.adapter.tuya.0","lc":1549803385210} tuya.0 2019-02-13 14:04:51.288 debug stateChange tuya.0.85873706cc50e3c9df4b.online {"val":false,"ack":true,"ts":1550063091285,"q":0,"from":"system.adapter.tuya.0","lc":1550063090939} tuya.0 2019-02-13 14:04:51.284 debug 85873706cc50e3c9df4b: Create device objects if not exist tuya.0 2019-02-13 14:04:51.283 debug 85873706cc50e3c9df4b: Schema found for B6GeaaNA7DTT37Gr: [object Object] tuya.0 2019-02-13 14:04:51.283 debug Discovered device: 192.168.0.80:49154 - U��{"ip":"192.168.0.80","gwId":"85873706cc50e3c9df4b","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"B6GeaaNA7DTT37Gr","version" tuya.0 2019-02-13 14:04:50.943 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063090941,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:50.942 debug stateChange tuya.0.85873706cc50e3c9df4b.online {"val":false,"ack":true,"ts":1550063090939,"q":0,"from":"system.adapter.tuya.0","lc":1550063090939} tuya.0 2019-02-13 14:04:50.937 debug 72824806cc50e3576445: Disconnected from device tuya.0 2019-02-13 14:04:50.936 debug 85873706cc50e3c9df4b: Disconnected from device tuya.0 2019-02-13 14:04:50.500 debug Discovered device: 192.168.0.79:49160 - U��{"ip":"192.168.0.79","gwId":"72824806cc50e3576445","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"rrOujSy4Pf1BwEgV","version" tuya.0 2019-02-13 14:04:49.648 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063089647,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:49.522 debug 72824806cc50e3576445: Disconnected from device tuya.0 2019-02-13 14:04:49.521 debug 72824806cc50e3576445: Error from device (2): App still open on your mobile phone? Error: Error from socket tuya.0 2019-02-13 14:04:47.522 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063087520,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:47.519 debug 72824806cc50e3576445: Disconnected from device tuya.0 2019-02-13 14:04:47.518 debug 72824806cc50e3576445: Error from device (1): App still open on your mobile phone? Error: Error from socket tuya.0 2019-02-13 14:04:47.503 debug Discovered device: 192.168.0.79:49160 - U��{"ip":"192.168.0.79","gwId":"72824806cc50e3576445","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"rrOujSy4Pf1BwEgV","version" tuya.0 2019-02-13 14:04:45.521 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063085519,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:45.517 debug 72824806cc50e3576445: Disconnected from device tuya.0 2019-02-13 14:04:45.516 debug 72824806cc50e3576445: Error from device (0): App still open on your mobile phone? Error: Error from socket tuya.0 2019-02-13 14:04:44.514 info 72824806cc50e3576445 Init with IP=192.168.0.79, Key=f3f876ea955a31bc tuya.0 2019-02-13 14:04:44.507 debug stateChange tuya.0.72824806cc50e3576445.ip {"val":"192.168.0.79","ack":true,"ts":1550063084506,"q":0,"from":"system.adapter.tuya.0","lc":1549719722647} tuya.0 2019-02-13 14:04:44.506 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063084503,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:44.502 debug 72824806cc50e3576445: Create device objects if not exist tuya.0 2019-02-13 14:04:44.501 debug 72824806cc50e3576445: Schema found for rrOujSy4Pf1BwEgV: null tuya.0 2019-02-13 14:04:44.500 debug Discovered device: 192.168.0.79:49160 - U��{"ip":"192.168.0.79","gwId":"72824806cc50e3576445","active":2,"ability":0,"mode":0,"encrypt":true,"productKey":"rrOujSy4Pf1BwEgV","version" tuya.0 2019-02-13 14:04:44.180 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063084178,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:44.177 debug 72824806cc50e3576445: Disconnected from device tuya.0 2019-02-13 14:04:44.176 debug 72824806cc50e3576445: Error from device (3): App still open on your mobile phone? Error: Error from socket tuya.0 2019-02-13 14:04:42.178 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063082175,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:42.173 debug 72824806cc50e3576445: Disconnected from device tuya.0 2019-02-13 14:04:42.172 debug 72824806cc50e3576445: Error from device (2): App still open on your mobile phone? Error: Error from socket tuya.0 2019-02-13 14:04:40.171 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063080170,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:40.169 debug 72824806cc50e3576445: Disconnected from device tuya.0 2019-02-13 14:04:40.167 debug 72824806cc50e3576445: Error from device (1): App still open on your mobile phone? Error: Error from socket tuya.0 2019-02-13 14:04:38.170 debug stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1550063078167,"q":0,"from":"system.adapter.tuya.0","lc":1550063078167} tuya.0 2019-02-13 14:04:38.170 debug connected set to false tuya.0 2019-02-13 14:04:38.168 debug stateChange tuya.0.72824806cc50e3576445.online {"val":false,"ack":true,"ts":1550063078166,"q":0,"from":"system.adapter.tuya.0","lc":1550062304500} tuya.0 2019-02-13 14:04:38.164 debug 72824806cc50e3576445: Disconnected from device tuya.0 2019-02-13 14:04:38.163 debug 72824806cc50e3576445: Error from device (0): App still open on your mobile phone? Error: Error from socket tuya.0 2019-02-13 14:04:37.283 debug stateChange tuya.0.85873706cc50e3c9df4b.10 {"val":"ffff0506ff000000ff00ffff00ff00ff0000ffff0000","ack":true,"ts":1550063077274,"q":0,"from":"system.adapter.tuya.0","lc":1549803745303} tuya.0 2019-02-13 14:04:37.283 debug stateChange tuya.0.85873706cc50e3c9df4b.9 {"val":"ffff5001ff0000","ack":true,"ts":1550063077274,"q":0,"from":"system.adapter.tuya.0","lc":1549803445268} tuya.0 2019-02-13 14:04:37.282 debug stateChange tuya.0.85873706cc50e3c9df4b.8 {"val":"ffff8006ff000000ff000000ffff0000ff0000ff0000","ack":true,"ts":1550063077274,"q":0,"from":"system.adapter.tuya.0","lc":1549803745302} tuya.0 2019-02-13 14:04:37.282 debug stateChange tuya.0.85873706cc50e3c9df4b.7 {"val":"ffff500100ff00","ack":true,"ts":1550063077273,"q":0,"from":"system.adapter.tuya.0","lc":1549803445267} tuya.0 2019-02-13 14:04:37.278 debug stateChange tuya.0.85873706cc50e3c9df4b.6 {"val":"bd76000168ffff","ack":true,"ts":1550063077273,"q":0,"from":"system.adapter.tuya.0","lc":1549803745302} tuya.0 2019-02-13 14:04:37.274 debug stateChange tuya.0.85873706cc50e3c9df4b.5 {"val":"fbff00003dffff","ack":true,"ts":1550063077271,"q":0,"from":"system.adapter.tuya.0","lc":1549803445264} tuya.0 2019-02-13 14:04:37.273 debug stateChange tuya.0.85873706cc50e3c9df4b.4 {"val":255,"ack":true,"ts":1550063077267,"q":0,"from":"system.adapter.tuya.0","lc":1549803445264} tuya.0 2019-02-13 14:04:37.271 debug stateChange tuya.0.85873706cc50e3c9df4b.3 {"val":255,"ack":true,"ts":1550063077266,"q":0,"from":"system.adapter.tuya.0","lc":1549803445263} tuya.0 2019-02-13 14:04:37.269 debug stateChange tuya.0.85873706cc50e3c9df4b.2 {"val":"0","ack":true,"ts":1550063077265,"q":0,"from":"system.adapter.tuya.0","lc":1550062371581} tuya.0 2019-02-13 14:04:37.267 debug stateChange tuya.0.85873706cc50e3c9df4b.1 {"val":true,"ack":true,"ts":1550063077263,"q":0,"from":"system.adapter.tuya.0","lc":1550062365344} tuya.0 2019-02-13 14:04:37.262 debug 85873706cc50e3c9df4b: Received data: {"1":true,"2":"white","3":255,"4":255,"5":"fbff00003dffff","6":"bd76000168ffff","7":"ffff500100ff00","8":"ffff8006ff000000ff000000ffff0000ff0000ff0000","9":"ffff5 tuya.0 2019-02-13 14:04:37.221 debug stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1550063077217,"q":0,"from":"system.adapter.tuya.0","lc":1550063077217} tuya.0 2019-02-13 14:04:37.221 debug connected set to true tuya.0 2019-02-13 14:04:37.219 debug stateChange tuya.0.85873706cc50e3c9df4b.online {"val":true,"ack":true,"ts":1550063077211,"q":0,"from":"system.adapter.tuya.0","lc":1550063077211} tuya.0 2019-02-13 14:04:37.210 debug 85873706cc50e3c9df4b: Connected to device tuya.0 2019-02-13 14:04:37.171 info Discover for local Tuya devices on port 6666 tuya.0 2019-02-13 14:04:37.164 info Existing devices initialized tuya.0 2019-02-13 14:04:37.163 info 85873706cc50e3c9df4b Init with IP=192.168.0.80, Key=e4976c3b6b8fb1b0 tuya.0 2019-02-13 14:04:37.156 info 72824806cc50e3576445 Init with IP=192.168.0.79, Key=f3f876ea955a31bc tuya.0 2019-02-13 14:04:37.046 debug 85873706cc50e3c9df4b: Create device objects if not exist tuya.0 2019-02-13 14:04:37.041 debug 72824806cc50e3576445: Create device objects if not exist tuya.0 2019-02-13 14:04:37.037 debug init 2 known devices tuya.0 2019-02-13 14:04:37.025 debug connected set to false tuya.0 2019-02-13 14:04:36.994 info starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.15.0Ich bitte um Hilfe vorab.
nukleuz
Hallo apollon77,
gibt es eine Möglichkeit die abgefangenen Daten des Tuya Adapters bei einem Umzug mitzunehmen?Ich frage deshalb, weil ich die iobroker Installation wegen Speichermangels von einem Raspberry Pi3 auf einen Dockercontainer umziehen will. Ich würde gerne die bereits abgefangenen Daten für den Tuya Adapter mitnehmen und nicht erneut das Ganze Prozedere mit Zertifikat, Proxy usw. durchführen, da das beim letzten Mal erst beim fünften oder sechsten Anlauf geklappt hat.
Danke im Voraus
Hallo apollon77,
Danke im Voraus
@victory Hi, das geht bei vielen Adaptern schon ganz einfach, in den Instanzen in die Adapterkonfig gehen, dann bei den drei kleinen Kreisen ( das erste hat ein Fragezeichen, das nächste ist Konfigupload das übernächste Konfigdownload ) anklicken. Einfach mal den Mauszeiger drüberhalten, erklärung folgt.. ;-)
Hi, ich habe seit ein paar Tagen auch ein paar Geräte mit Tuya-Adapter eingebunden, genauer gesagt eine Steckdosenleiste 3-fach, eine 4-fach und 2 Gosund SP1. Es läuft eigentlich alles wunderbar soweit. Nun habe ich den Geräten den Internetzugang abgedreht (muss ja nicht sein) und bekomme seitdem von den beiden Gosund keinen Stromverbrauch mehr aktualiert. Steuern geht problemlos bei allen Dosen, auch manuelles Schalten an der Dose kommt in iobroker an, nur der Stromverbrauch aktualisiert sich nicht mehr. Ist da zwingend Zugang zur Cloud für das Gerät nötig?
Wenn dem so wäre, dann werde ich wohl doch den Hack von Heise versuchen und auf die beiden SP1 Tasmota aufspielen, dann sollte der Stromverbrauch ja auch im Sonoff-Adapter ankommen, oder?Bei den Mehrfachdosen habe ich es nicht geschafft, den einzelnen Buchsen vernünftige Namen zu geben. Auch umbenennen in Smart Life blieb nur so lange, bis ich die App einmal beendet und neu gestartet hatte, danach hiessen alle wieder "switch1", "switch2" usw. Dabei war Internet aber sogar noch aktiv. Gibt es da irgendeinen Trick, um das permanent zu machen und im iobroker auch darzustellen?
Gruss, Jürgen
nukleuz
Hallo apollon77,
Danke im Voraus
Gruss, Jürgen
@Wildbill sagte in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
Keine Ahnung. Wenn Du die Summe des Verbrauchs und nicht die aktuellen Werte meinst so werden die meines Wissens nach nicht auf dem gerät selbst sondern genau in der Cloud ermittelt. Kannst Du natürlich auch über ioBroker Adapter selbst ermitteln.
Ändere die Namen in den iobroker Objekten. Die werden nur überschrieben wenn Du neu syncst.
nein, ich meine die Messwerte wie Spannung, Strom in mA , Leistung und Volt. Die aktualisieren sich bei mir anscheinend nur, wenn die Dosen "nach Hause" funken dürfen. Dann landen die Werte auch aktualisiert in iobroker. Wenn ich den Dosen das Internet verbiete und sie einmal neu starte (also kurz mal aus- und wieder einstecken) funktioniert in iobroker nur noch der Datenpunkt zum Schalten, alle anderen bleiben auf dem letzten Stand stehen. Habe das jetzt mehrfach getestet, die App war dann auch jedes mal aus (im Android über die Einstellungen --> Apps gestoppt) und das Handy sogar mal im Flugmodus. Wie es auch immer läuft, der Adapter bekommt hier anscheinend nur aktuelle Werte, wenn die Dose Verbindung zur Cloud hat.
Werde es bei Gelegenheit wohl doch mal testen, wie es mit Tasmota aussieht.
Das mit den Namen werde ich dann so akzeptieren, noch kann ich mir merken auf welcher der beiden Dosen welcher switch was macht. Immerhin laufen sie zu 90% automatisiert in Scripten. Wenn ich jetzt die Namen ändere und mal wieder die App brauche, dann laufen womöglich die Scripte nicht mehr, weil sich die Namen geändert haben?!
Auf jeden Fall ein dickes Danke für den Adapter.
Gruss, Jürgen
nur als kurzes Update. Ich habe die beiden Gosunds mit der "Heise"-Methode nun mit Tasmota 6.4.1 geflasht und nun habe ich im iobroker im Sonoff-Adapter auch sauber die gewünschten Werte. Da sich der Aufwand zum OTA-Flashen hier in Grenzen hält (Raspi oder ähnliches spannt WLAN auf und Stecker holt sich da die Software) kann ich das nur empfehlen. Die SP1 haben auch direkt in Tasmota ein passendes Profil.
Da das Flashen auf diese Art eigentlich mit jedem Tuya-Gerät gehen müsste, habe ich gleich die Vierfach-Steckdose auch geflasht. Der Aufwand war hier ertwas höher, da ich im Generic-Profil erstmal schauen musste, wo welches Relais liegt, aber das läuft nun auch sauber, allerdings kommen auch hier die Klarnamen im iobroker nicht an, obwohl sie im Tasmota-Webif für MQTT eigentlich gesetzt sind. Aber es gibt kleinere Probleme. Nun werde ich noch die Dreifachdose flashen und dann kann ich die SmartLife-App eigentlich wieder vom Handy schmeissen. Und den Adapter auch löschen, so hilfreich er ist. Aber direkt per MQTT ist nochmal einen Zacken fescher.
Gruss, Jürgen
Einige … Wenn das Schema nicht bekannt ist dann werden die Werte grob erstellt. Erst beim Sync wird das echte Schema ausgelesen und ggf im Log gepostet wenn nicht bekannt so das es gemeldet werden kann.
@apollon77 said in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
muss das schema im tuya adapter hinterlegt werden, oder kann man die geräte auch teilweise schon so nutzen?
Hallo an Alle,
ich bin neu hier und habe ein kleines Problem mit dem Tuya Adapter. Im IoBroker 2 verschiedene Steckdosen registriert, soweit alles i.O. An sich hat auch alles super funktioniert aber bei der Doppelsteckdose werden die Werte leider nicht korrekt angegeben.
Könnt Ihr mir sagen ob ich irgendetwas machen kann, damit die Werte richtig dargestellt werden?
Doppelsteckdosentyp: OxaOxe 2-Fach smart Steckdose!
Richtig wäre: Strom 75 mA / Leistung 8,6 W / Spannug 226,5 V
