  4. LONG PRESS und Toggle per Blockly
    5.8k
blockly
36 Beiträge 5 Kommentatoren 5.5k Aufrufe 4 Beobachtet
  • foxriver76F foxriver76
    @Homoran Vermutlich das gleiche Spiel, vorher kannst du mal schauen, was da steht wenn du hinten auf den Stift bei dem State gehst und dann auf RAW. Da müsste dann ein MAX: 1.05 oder so stehen.
    @foxriver76
    Hier die Send...
    2019-02-13 11:37:21.099  - debug: hm-rpc.1 getValueParamsets HmIP-BDT.MAINTENANCE.2
    2019-02-13 11:37:21.100  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0008D8A998C04E:0","VALUES"]
    2019-02-13 11:37:21.130  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.MAINTENANCE.2"
    2019-02-13 11:37:21.130  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"DUTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"INSTALL_TEST":{"MIN":false,"OPERATIONS":3,"MAX":true,"FLAGS":2,"ID":"INSTALL_TEST","TYPE":"BOOL","DEFAULT":false},"ERROR_OVERHEAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"ERROR_OVERHEAT","TYPE":"BOOL","DEFAULT":false},"OPERATING_VOLTAGE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"OPERATING_VOLTAGE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"ERROR_UPDATE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"ERROR_UPDATE","TYPE":"BOOL","DEFAULT":false},"ACTUAL_TEMPERATURE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"UNDERFLOW","FLAGS":1,"ID":"ACTUAL_TEMPERATURE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW","UNDERFLOW"]},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"ERROR_OVERLOAD":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"ERROR_OVERLOAD","TYPE":"BOOL","DEFAULT":false},"ERROR_CODE":{"MIN":0,"OPERATIONS":5,"MAX":255,"FLAGS":9,"ID":"ERROR_CODE","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"ACTUAL_TEMPERATURE":{"MIN":-3276.8,"OPERATIONS":5,"MAX":3276.7,"FLAGS":1,"ID":"ACTUAL_TEMPERATURE","TYPE":"FLOAT","DEFAULT":0},"OPERATING_VOLTAGE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0}}}
    2019-02-13 11:37:21.147  - debug: hm-rpc.1 getValueParamsets HmIP-BDT.KEY_TRANSCEIVER.2
    2019-02-13 11:37:21.148  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0008D8A998C04E:1","VALUES"]
    2019-02-13 11:37:21.158  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.KEY_TRANSCEIVER.2"
    2019-02-13 11:37:21.158  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PRESS_SHORT":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_SHORT","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.SHORT"},"PRESS_LONG":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_LONG","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.LONG"}}}
    2019-02-13 11:37:21.193  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.DIMMER_TRANSMITTER.2"
    2019-02-13 11:37:21.193  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"SECTION_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"UNKNOWN","FLAGS":1,"ID":"SECTION_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN"]},"LEVEL_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"ERROR","FLAGS":1,"ID":"LEVEL_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW","UNDERFLOW","ERROR"]},"PROCESS":{"MIN":"STABLE","OPERATIONS":5,"MAX":"NOT_STABLE","FLAGS":1,"ID":"PROCESS","TYPE":"ENUM","DEFAULT":"STABLE","VALUE_LIST":["STABLE","NOT_STABLE"]},"LEVEL":{"MIN":0,"OPERATIONS":5,"MAX":1.005,"FLAGS":1,"ID":"LEVEL","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"DIMMER_REAL.LEVEL"},"SECTION":{"MIN":0,"OPERATIONS":5,"MAX":15,"FLAGS":1,"ID":"SECTION","TYPE":"INTEGER","DEFAULT":0},"ACTIVITY_STATE":{"MIN":"UNKNOWN","OPERATIONS":5,"MAX":"STABLE","FLAGS":1,"ID":"ACTIVITY_STATE","TYPE":"ENUM","DEFAULT":"UNKNOWN","VALUE_LIST":["UNKNOWN","UP","DOWN","STABLE"]}}}
    2019-02-13 11:37:21.230  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.DIMMER_VIRTUAL_RECEIVER.2"
    2019-02-13 11:37:21.230  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"SECTION_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"UNKNOWN","FLAGS":1,"ID":"SECTION_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN"]},"LEVEL_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"ERROR","FLAGS":1,"ID":"LEVEL_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW","UNDERFLOW","ERROR"]},"ON_TIME":{"MIN":0,"UNIT":"s","OPERATIONS":2,"MAX":8580000,"FLAGS":1,"ID":"ON_TIME","TYPE":"FLOAT","DEFAULT":0},"PROCESS":{"MIN":"STABLE","OPERATIONS":5,"MAX":"NOT_STABLE","FLAGS":1,"ID":"PROCESS","TYPE":"ENUM","DEFAULT":"STABLE","VALUE_LIST":["STABLE","NOT_STABLE"]},"RAMP_TIME":{"MIN":0,"UNIT":"s","OPERATIONS":2,"MAX":8580000,"FLAGS":1,"ID":"RAMP_TIME","TYPE":"FLOAT","DEFAULT":0.5},"LEVEL":{"MIN":0,"UNIT":"100%","OPERATIONS":7,"MAX":1.005,"FLAGS":1,"ID":"LEVEL","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"DIMMER.LEVEL"},"SECTION":{"MIN":0,"OPERATIONS":5,"MAX":15,"FLAGS":1,"ID":"SECTION","TYPE":"INTEGER","DEFAULT":0},"ACTIVITY_STATE":{"MIN":"UNKNOWN","OPERATIONS":5,"MAX":"STABLE","FLAGS":1,"ID":"ACTIVITY_STATE","TYPE":"ENUM","DEFAULT":"UNKNOWN","VALUE_LIST":["UNKNOWN","UP","DOWN","STABLE"]}}}
    2019-02-13 11:37:21.262  - debug: hm-rpc.1 getValueParamsets HmIP-BDT.DIMMER_WEEK_PROFILE.2
    2019-02-13 11:37:21.263  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0008D8A998C04E:7","VALUES"]
    2019-02-13 11:37:21.275  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.DIMMER_WEEK_PROFILE.2"
    2019-02-13 11:37:21.275  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"WEEK_PROGRAM_TARGET_CHANNEL_LOCK":{"MIN":"MANU_MODE","OPERATIONS":2,"MAX":"AUTO_MODE_WITHOUT_RESET","FLAGS":1,"ID":"WEEK_PROGRAM_TARGET_CHANNEL_LOCK","TYPE":"ENUM","DEFAULT":"MANU_MODE","VALUE_LIST":["MANU_MODE","AUTO_MODE_WITH_RESET","AUTO_MODE_WITHOUT_RESET"],"CONTROL":"WEEK_PROFILE.TARGET_CHANNEL_LOCK"},"WEEK_PROGRAM_TARGET_CHANNEL_LOCKS":{"MIN":0,"OPERATIONS":2,"MAX":16777215,"FLAGS":1,"ID":"WEEK_PROGRAM_TARGET_CHANNEL_LOCKS","TYPE":"INTEGER","DEFAULT":0,"CONTROL":"WEEK_PROFILE.TARGET_CHANNEL_LOCKS"},"WEEK_PROGRAM_CHANNEL_LOCKS":{"MIN":0,"OPERATIONS":5,"MAX":16777215,"FLAGS":1,"ID":"WEEK_PROGRAM_CHANNEL_LOCKS","TYPE":"INTEGER","DEFAULT":0,"CONTROL":"WEEK_PROFILE.CHANNEL_LOCKS"}}}
      @foxriver76 sagte in LONG PRESS und Toggle per Blockly:
      oder so ;-)
      "max": 100.49999999999999,
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      schrieb am zuletzt editiert von foxriver76
      @Homoran Ja genau, für dich lokal, könntest du das Problem einfach hier beseitigen. Wenn es für dich kein Aufwand ist, wäre Meta + Objekt löschen und Daten hier posten für die Allgemeinheit cool. ;-)
      EDIT: hast ja schon.. vielen Dank :-)
      Videotutorials & mehr
        @Homoran sagte in LONG PRESS und Toggle per Blockly:
        Das Blockly reagiert zweimal auf press-long
        Das muss aber nicht bedeuten: Das erste Mal beim Drücken. Es kann auch sein, dass der erste Trigger zum Ende der PRESS_SHORT-Zeitspanne kommt. Zeichne bitte mal die beiden PRESS-Datenpunkte per History auf, damit wir alle schlauer werden.
        Zur Lösung für Blockly: Ich würde eine Sperrvariable verwenden, die beim ersten Trigger auf true und wenn true, auf false gesetzt wird.
        @paul53 sagte in LONG PRESS und Toggle per Blockly:
        mach ich!
        und da habe ich einiges versucht, hat aber nicht geklappt.
        Da kommen wir an meine Grenzen, ich weiß anscheinend nicht genau, wo ich sie starten und wo beenden muss.
        Eine oder zwei Sekunden müssten reichen
          mach ich!
            Danke!
            Mach ich gleich.
            Doch zuerst die letzten Studien.
            log :
            2019-02-13 11:51:20.996  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:20.997  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
            2019-02-13 11:51:21.556  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:21.556  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
            2019-02-13 11:51:34.487  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:34.487  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
            2019-02-13 11:51:34.919  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:34.919  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
            2019-02-13 11:51:40.389  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:40.389  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
            2019-02-13 11:51:40.931  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:40.931  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
            2019-02-13 11:51:42.652  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:42.652  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
            2019-02-13 11:51:42.898  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:42.898  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
            2019-02-13 11:51:44.408  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:44.408  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
            2019-02-13 11:51:44.653  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
            2019-02-13 11:51:44.653  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
            History:
            true	true		2019-02-13 11:51:44.652
            true	true		2019-02-13 11:51:44.407
            true	true		2019-02-13 11:51:42.897
            true	true		2019-02-13 11:51:42.651
            true	true		2019-02-13 11:51:40.930
            true	true		2019-02-13 11:51:40.388
            true	true		2019-02-13 11:51:34.918
            true	true		2019-02-13 11:51:34.486
            true	true		2019-02-13 11:51:21.556
            true	true		2019-02-13 11:51:20.995
            true	true		2019-02-13 11:48:44.555
            true	true		2019-02-13 11:48:43.520
            true	true		2019-02-13 11:48:40.226
            true	true		2019-02-13 11:48:39.925
            true	true		2019-02-13 11:48:37.540
            true	true		2019-02-13 11:48:36.601
            true	true		2019-02-13 11:48:34.290
            true	true		2019-02-13 11:48:33.352
            true	true		2019-02-13 11:48:30.586
            true	true		2019-02-13 11:48:29.662
            true	true		2019-02-13 11:48:24.156
            true	true		2019-02-13 11:48:23.196
            null	true		2019-02-13 11:44:52.355
              Danke!
              Mach ich gleich.
              log :
              History:
              History:
              Danke.
              Der Vergleich mit PRESS_SHORT wäre noch interessant: Kommt der erste PRESS_LONG-Trigger vor dem PRESS_SHORT-Trigger (beim Drücken) oder gleichzeitig ? Kennst Du die Zeitspanne für PRESS_SHORT ?
                Hab ich natürlich nicht geloggt 😳
                Natürlich, habe sie ja selbst auf 0.3 gesetzt
                Habe das Blockly aber jetzt geändert.
                ist das so mit dem zusätzlich falls/sonst block ok?
                  Nein, Du hast wahr und unwahr vertauscht bei setze Sperre auf.
                    Ooops, tatsächlich!
                    Hat auch nicht geklappt - welch Wunder ;-)
                    Habe aber was anderes festgestellt.
                    Wenn ich nur einen "kurzen LONG_PRESS" mache klappt alles wie ich will, warte ich jedoch mit dem loslassen bis die Lampe die Helligkeit gewechselt hat, springt sie wieder zurück.
                    Melde mich gleich wieder
                      @foxriver76
                      Hier die Send...
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      @foxriver76
                      Hier die Send...
                      Ist gefixt und zukünftig werden beim neuanlegen von Geräten mit einem MAX von 1.005 dieser automatisch auf 1 korrigiert, da das Problem schon häufiger vorgekommen ist und man nicht bei jedem Gerät auf die manuelle Korrektur warten möchte. --> RPC 1.9.7
                        Ooops, tatsächlich!
                        Jetzt klappt es wie gewollt, egal wie lange ich drücke.
                        Danke!
                        2019-02-13 12:08:37.422  - info: javascript.0 script.js.Licht.Badlicht_repair: registered 2 subscriptions and 0 schedules
                        2019-02-13 12:08:54.848  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                        2019-02-13 12:08:54.848  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                        2019-02-13 12:09:16.885  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                        2019-02-13 12:09:16.885  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
                        2019-02-13 12:09:19.730  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                        2019-02-13 12:09:19.731  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                        2019-02-13 12:09:21.906  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                        2019-02-13 12:09:21.906  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
                        2019-02-13 12:09:25.893  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                        2019-02-13 12:09:25.893  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                        2019-02-13 12:09:37.176  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                        2019-02-13 12:09:37.177  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
                        Willst du noch die history von short und long?
                          Hier long:
                          true	true		2019-02-13 12:09:38.769
                          true	true		2019-02-13 12:09:37.175
                          true	true		2019-02-13 12:09:26.628
                          true	true		2019-02-13 12:09:25.892
                          true	true		2019-02-13 12:09:23.829
                          true	true		2019-02-13 12:09:21.905
                          true	true		2019-02-13 12:09:20.187
                          true	true		2019-02-13 12:09:19.729
                          true	true		2019-02-13 12:09:17.525
                          true	true		2019-02-13 12:09:16.884
                          true	true		2019-02-13 12:08:55.963
                          true	true		2019-02-13 12:08:54.846
                          true	true		2019-02-13 12:03:30.208
                          true	true		2019-02-13 12:03:29.844
                          true	true		2019-02-13 12:03:27.559
                          true	true		2019-02-13 12:03:27.381
                          true	true		2019-02-13 12:03:21.084
                          true	true		2019-02-13 12:03:20.083
                          true	true		2019-02-13 12:03:18.024
                          true	true		2019-02-13 12:03:17.743
                          true	true		2019-02-13 12:03:15.460
                          true	true		2019-02-13 12:03:15.062
                          true	true		2019-02-13 12:03:11.751
                          true	true		2019-02-13 12:03:10.763
                          true	true		2019-02-13 12:03:07.513
                          true	true		2019-02-13 12:03:07.370
                          true	true		2019-02-13 12:03:05.054
                          true	true		2019-02-13 12:03:03.683
                          true	true		2019-02-13 12:03:00.947
                          true	true		2019-02-13 12:02:59.797
                          und hier short:
                          true	true		2019-02-13 12:09:29.817
                          true	true		2019-02-13 12:09:28.582
                          null	true		2019-02-13 12:01:11.854
                          kann aber sein, dass die auch entstanden sind, als ich irrtümlich beim testen mal zu kurz getippt hatte
                            Danke!
                            Da ja entweder ein PRESS_SHORT -Trigger oder 2 PRESS_LONG-Trigger erfolgen, nutzt es wenig.
                              nutzt es wenig.
                              sehe ich auch so - schade.
                              Aber deine Sperrvariable nutzt.
                              Danke nochmals
                                ich weiß nicht ob es an meinen Programmierkünsten oder an der Anbindung der HMIP-Geräte liegt.
                                Ich habe seit gestern einen neuen Dimmer für das Badlicht, weil der alte gesponnen hat.
                                Der Dimmer wird von einem Wandtaster mit BWM per Direktverknüpfung gesteuert, zusätzlich wird nachts über einen virtuellen Kanal das Licht noch weiter gedimmt. Üblicherweise wird mit 50% auf dem Hauptkanal angeschaltet, damit noch Luft nach oben ist.
                                Ich möchte jetzt über den Wandtaster aber auch "im Notfall", oder auch für andere volles Licht haben UND das auch wieder zurückstellen können.
                                Dazu habe ich das folgende Blockly gebastelt.
                                Wie man jetzt am log schon sieht, haben anscheinend die IP Taster nicht nur einen LONG PRESS Impuls, sondern bekommen die ganze Zeit, während gedrückt wird weitere Impulse.
                                Warum schaltet das dumme Licht nicht auf hell??
                                rantanplanR Online
                                rantanplanR Online
                                rantanplan
                                Kommen da wirklich mehrere Impulse, mit long_press true?
                                Zu bedenken sind Kommunikationsdauer ioBroker-> Taster -> ioBroker und asynchrone Abarbeitung JavaScript. Zumal Du Verzögerungen einsetzt.
                                Rantanplan
                                • rantanplanR rantanplan
                                  @rantanplan sagte in LONG PRESS und Toggle per Blockly:
                                  wie erkenne ich das "wirklich"?
                                    Laut History-Daten für PRESS_LONG: Ja.
