  4. LONG PRESS und Toggle per Blockly
    5.8k
blockly
36 Beiträge 5 Kommentatoren 5.5k Aufrufe 4 Beobachtet
  • foxriver76F foxriver76
    @Homoran sagte in LONG PRESS und Toggle per Blockly:
    HmIP-SMI55
    Entweder mal die Metadaten und das Gerät raus löschen (wäre vermutlich die schickere Lösung), dann auf den Log Eintrag hoffen oder die angelegten Metadaten zur Verfügung stellen.
    @foxriver76
    Done!
    2019-02-13 10:50:45.045  - debug: hm-rpc.1 getValueParamsets HmIP-SMI55.MAINTENANCE.1
    2019-02-13 10:50:45.046  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0014D709AEF7EF:0","VALUES"]
    2019-02-13 10:50:45.068  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SMI55.MAINTENANCE.1"
    2019-02-13 10:50:45.068  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"DUTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"LOW_BAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"LOW_BAT","TYPE":"BOOL","DEFAULT":false},"INSTALL_TEST":{"MIN":false,"OPERATIONS":3,"MAX":true,"FLAGS":2,"ID":"INSTALL_TEST","TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"OPERATING_VOLTAGE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"OPERATING_VOLTAGE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"OPERATING_VOLTAGE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"ERROR_CODE":{"MIN":0,"OPERATIONS":5,"MAX":255,"FLAGS":9,"ID":"ERROR_CODE","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false}}}
    2019-02-13 10:50:45.084  - debug: hm-rpc.1 getValueParamsets HmIP-SMI55.KEY_TRANSCEIVER.1
    2019-02-13 10:50:45.084  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0014D709AEF7EF:1","VALUES"]
    2019-02-13 10:50:45.097  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SMI55.KEY_TRANSCEIVER.1"
    2019-02-13 10:50:45.097  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PRESS_SHORT":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_SHORT","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.SHORT"},"PRESS_LONG":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_LONG","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.LONG"}}}
    2019-02-13 10:50:45.107  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0014D709AEF7EF:3","VALUES"]
    2019-02-13 10:50:45.127  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SMI55.MOTIONDETECTOR_TRANSCEIVER.1"
    2019-02-13 10:50:45.127  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"MOTION":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"MOTION","TYPE":"BOOL","DEFAULT":false,"CONTROL":"MOTIONDETECTOR_TRANSCEIVER.MOTION_DETECTION_STATE"},"RESET_MOTION":{"MIN":false,"OPERATIONS":2,"MAX":true,"FLAGS":1,"ID":"RESET_MOTION","TYPE":"ACTION","DEFAULT":false,"CONTROL":"MOTIONDETECTOR_TRANSCEIVER.RESET_MOTION"},"ILLUMINATION":{"MIN":0,"OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"ILLUMINATION","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"MOTIONDETECTOR_TRANSCEIVER.ILLUMINATION"},"CURRENT_ILLUMINATION":{"MIN":0,"OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"CURRENT_ILLUMINATION","TYPE":"FLOAT","DEFAULT":0},"CURRENT_ILLUMINATION_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"CURRENT_ILLUMINATION_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"ILLUMINATION_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"ILLUMINATION_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"MOTION_DETECTION_ACTIVE":{"MIN":false,"OPERATIONS":7,"MAX":true,"FLAGS":1,"ID":"MOTION_DETECTION_ACTIVE","TYPE":"BOOL","DEFAULT":true,"CONTROL":"MOTIONDETECTOR_TRANSCEIVER.MOTION_DETECTION_ACTIVE"}}}
    das ist alles!
    • foxriver76F Offline
      foxriver76F Offline
      foxriver76
      Top, danke.
      Und das ist der Dimmer, bei dem du meintest er hat für 50 % - 48,xy?
      Videotutorials & mehr
        Top, danke.
        @foxriver76
        Nein der HMIP-SMI55, bei dem die Tasten ein True liefern (anscheinend beim Drücken und beim Loslassen) anstelle nur ein einmaliges Signal
        Dimmer auch noch?
        paul53P foxriver76F 2 Antworten Letzte Antwort
          @foxriver76
          Dimmer auch noch?
          Beim Drücken ist noch nicht bekannt, ob ein langer Tastendruck erfolgt, sondern erst dann, wenn die zulässige Zeitspanne für den kurzen Tastendruck erreicht ist.
            @foxriver76
            Dimmer auch noch?
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            @Homoran Ja ich wollte dein Problem adressieren, dass der Dimmer die falschen Werte zeigt, insofern es daran liegt, was ich vermute. Bzgl dem Verhalten der Taster habe ich leider keine Erfahrung.
              seltsamerweise aber doch - siehe log im früheren Screenshot
              Das Blockly reagiert zweimal auf press-long
                @foxriver76
                Was kann ich da für dich tun?
                LEVEL	state state	level.dimmer			99.5 %
                Copy aus den Objects - wurde per HM-Programm auf 100% gestellt
                  @foxriver76
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  @Homoran Vermutlich das gleiche Spiel, vorher kannst du mal schauen, was da steht wenn du hinten auf den Stift bei dem State gehst und dann auf RAW. Da müsste dann ein MAX: 1.05 oder so stehen.
                    @foxriver76 sagte in LONG PRESS und Toggle per Blockly:
                    oder so ;-)
                    "max": 100.49999999999999,
                    • paul53P Offline
                      Das muss aber nicht bedeuten: Das erste Mal beim Drücken. Es kann auch sein, dass der erste Trigger zum Ende der PRESS_SHORT-Zeitspanne kommt. Zeichne bitte mal die beiden PRESS-Datenpunkte per History auf, damit wir alle schlauer werden.
                      Zur Lösung für Blockly: Ich würde eine Sperrvariable verwenden, die beim ersten Trigger auf true und wenn true, auf false gesetzt wird.
                        @foxriver76
                        Hier die Send...
                        2019-02-13 11:37:21.099  - debug: hm-rpc.1 getValueParamsets HmIP-BDT.MAINTENANCE.2
                        2019-02-13 11:37:21.100  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0008D8A998C04E:0","VALUES"]
                        2019-02-13 11:37:21.130  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.MAINTENANCE.2"
                        2019-02-13 11:37:21.130  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"DUTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"INSTALL_TEST":{"MIN":false,"OPERATIONS":3,"MAX":true,"FLAGS":2,"ID":"INSTALL_TEST","TYPE":"BOOL","DEFAULT":false},"ERROR_OVERHEAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"ERROR_OVERHEAT","TYPE":"BOOL","DEFAULT":false},"OPERATING_VOLTAGE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"OPERATING_VOLTAGE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"ERROR_UPDATE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"ERROR_UPDATE","TYPE":"BOOL","DEFAULT":false},"ACTUAL_TEMPERATURE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"UNDERFLOW","FLAGS":1,"ID":"ACTUAL_TEMPERATURE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW","UNDERFLOW"]},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"ERROR_OVERLOAD":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"ERROR_OVERLOAD","TYPE":"BOOL","DEFAULT":false},"ERROR_CODE":{"MIN":0,"OPERATIONS":5,"MAX":255,"FLAGS":9,"ID":"ERROR_CODE","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"ACTUAL_TEMPERATURE":{"MIN":-3276.8,"OPERATIONS":5,"MAX":3276.7,"FLAGS":1,"ID":"ACTUAL_TEMPERATURE","TYPE":"FLOAT","DEFAULT":0},"OPERATING_VOLTAGE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0}}}
                        2019-02-13 11:37:21.147  - debug: hm-rpc.1 getValueParamsets HmIP-BDT.KEY_TRANSCEIVER.2
                        2019-02-13 11:37:21.148  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0008D8A998C04E:1","VALUES"]
                        2019-02-13 11:37:21.158  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.KEY_TRANSCEIVER.2"
                        2019-02-13 11:37:21.158  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PRESS_SHORT":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_SHORT","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.SHORT"},"PRESS_LONG":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_LONG","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.LONG"}}}
                        2019-02-13 11:37:21.193  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.DIMMER_TRANSMITTER.2"
                        2019-02-13 11:37:21.193  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"SECTION_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"UNKNOWN","FLAGS":1,"ID":"SECTION_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN"]},"LEVEL_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"ERROR","FLAGS":1,"ID":"LEVEL_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW","UNDERFLOW","ERROR"]},"PROCESS":{"MIN":"STABLE","OPERATIONS":5,"MAX":"NOT_STABLE","FLAGS":1,"ID":"PROCESS","TYPE":"ENUM","DEFAULT":"STABLE","VALUE_LIST":["STABLE","NOT_STABLE"]},"LEVEL":{"MIN":0,"OPERATIONS":5,"MAX":1.005,"FLAGS":1,"ID":"LEVEL","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"DIMMER_REAL.LEVEL"},"SECTION":{"MIN":0,"OPERATIONS":5,"MAX":15,"FLAGS":1,"ID":"SECTION","TYPE":"INTEGER","DEFAULT":0},"ACTIVITY_STATE":{"MIN":"UNKNOWN","OPERATIONS":5,"MAX":"STABLE","FLAGS":1,"ID":"ACTIVITY_STATE","TYPE":"ENUM","DEFAULT":"UNKNOWN","VALUE_LIST":["UNKNOWN","UP","DOWN","STABLE"]}}}
                        2019-02-13 11:37:21.230  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.DIMMER_VIRTUAL_RECEIVER.2"
                        2019-02-13 11:37:21.230  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"SECTION_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"UNKNOWN","FLAGS":1,"ID":"SECTION_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN"]},"LEVEL_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"ERROR","FLAGS":1,"ID":"LEVEL_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW","UNDERFLOW","ERROR"]},"ON_TIME":{"MIN":0,"UNIT":"s","OPERATIONS":2,"MAX":8580000,"FLAGS":1,"ID":"ON_TIME","TYPE":"FLOAT","DEFAULT":0},"PROCESS":{"MIN":"STABLE","OPERATIONS":5,"MAX":"NOT_STABLE","FLAGS":1,"ID":"PROCESS","TYPE":"ENUM","DEFAULT":"STABLE","VALUE_LIST":["STABLE","NOT_STABLE"]},"RAMP_TIME":{"MIN":0,"UNIT":"s","OPERATIONS":2,"MAX":8580000,"FLAGS":1,"ID":"RAMP_TIME","TYPE":"FLOAT","DEFAULT":0.5},"LEVEL":{"MIN":0,"UNIT":"100%","OPERATIONS":7,"MAX":1.005,"FLAGS":1,"ID":"LEVEL","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"DIMMER.LEVEL"},"SECTION":{"MIN":0,"OPERATIONS":5,"MAX":15,"FLAGS":1,"ID":"SECTION","TYPE":"INTEGER","DEFAULT":0},"ACTIVITY_STATE":{"MIN":"UNKNOWN","OPERATIONS":5,"MAX":"STABLE","FLAGS":1,"ID":"ACTIVITY_STATE","TYPE":"ENUM","DEFAULT":"UNKNOWN","VALUE_LIST":["UNKNOWN","UP","DOWN","STABLE"]}}}
                        2019-02-13 11:37:21.262  - debug: hm-rpc.1 getValueParamsets HmIP-BDT.DIMMER_WEEK_PROFILE.2
                        2019-02-13 11:37:21.263  - info: hm-rpc.1 xmlrpc -> getParamsetDescription ["0008D8A998C04E:7","VALUES"]
                        2019-02-13 11:37:21.275  - warn: hm-rpc.1 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-BDT.DIMMER_WEEK_PROFILE.2"
                        2019-02-13 11:37:21.275  - warn: hm-rpc.1 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"WEEK_PROGRAM_TARGET_CHANNEL_LOCK":{"MIN":"MANU_MODE","OPERATIONS":2,"MAX":"AUTO_MODE_WITHOUT_RESET","FLAGS":1,"ID":"WEEK_PROGRAM_TARGET_CHANNEL_LOCK","TYPE":"ENUM","DEFAULT":"MANU_MODE","VALUE_LIST":["MANU_MODE","AUTO_MODE_WITH_RESET","AUTO_MODE_WITHOUT_RESET"],"CONTROL":"WEEK_PROFILE.TARGET_CHANNEL_LOCK"},"WEEK_PROGRAM_TARGET_CHANNEL_LOCKS":{"MIN":0,"OPERATIONS":2,"MAX":16777215,"FLAGS":1,"ID":"WEEK_PROGRAM_TARGET_CHANNEL_LOCKS","TYPE":"INTEGER","DEFAULT":0,"CONTROL":"WEEK_PROFILE.TARGET_CHANNEL_LOCKS"},"WEEK_PROGRAM_CHANNEL_LOCKS":{"MIN":0,"OPERATIONS":5,"MAX":16777215,"FLAGS":1,"ID":"WEEK_PROGRAM_CHANNEL_LOCKS","TYPE":"INTEGER","DEFAULT":0,"CONTROL":"WEEK_PROFILE.CHANNEL_LOCKS"}}}
                          oder so ;-)
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          schrieb am zuletzt editiert von foxriver76
                          @Homoran Ja genau, für dich lokal, könntest du das Problem einfach hier beseitigen. Wenn es für dich kein Aufwand ist, wäre Meta + Objekt löschen und Daten hier posten für die Allgemeinheit cool. ;-)
                          EDIT: hast ja schon.. vielen Dank :-)
                            @paul53 sagte in LONG PRESS und Toggle per Blockly:
                            mach ich!
                            und da habe ich einiges versucht, hat aber nicht geklappt.
                            Da kommen wir an meine Grenzen, ich weiß anscheinend nicht genau, wo ich sie starten und wo beenden muss.
                            Eine oder zwei Sekunden müssten reichen
                              mach ich!
                                Danke!
                                Mach ich gleich.
                                Doch zuerst die letzten Studien.
                                log :
                                2019-02-13 11:51:20.996  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:20.997  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                                2019-02-13 11:51:21.556  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:21.556  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                                2019-02-13 11:51:34.487  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:34.487  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
                                2019-02-13 11:51:34.919  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:34.919  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
                                2019-02-13 11:51:40.389  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:40.389  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                                2019-02-13 11:51:40.931  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:40.931  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                                2019-02-13 11:51:42.652  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:42.652  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
                                2019-02-13 11:51:42.898  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:42.898  - info: javascript.0 script.js.Licht.Badlicht_repair: hell
                                2019-02-13 11:51:44.408  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:44.408  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                                2019-02-13 11:51:44.653  - info: javascript.0 script.js.Licht.Badlicht_repair: oben lang!
                                2019-02-13 11:51:44.653  - info: javascript.0 script.js.Licht.Badlicht_repair: nicht hell
                                History:
                                true	true		2019-02-13 11:51:44.652
                                true	true		2019-02-13 11:51:44.407
                                true	true		2019-02-13 11:51:42.897
                                true	true		2019-02-13 11:51:42.651
                                true	true		2019-02-13 11:51:40.930
                                true	true		2019-02-13 11:51:40.388
                                true	true		2019-02-13 11:51:34.918
                                true	true		2019-02-13 11:51:34.486
                                true	true		2019-02-13 11:51:21.556
                                true	true		2019-02-13 11:51:20.995
                                true	true		2019-02-13 11:48:44.555
                                true	true		2019-02-13 11:48:43.520
                                true	true		2019-02-13 11:48:40.226
                                true	true		2019-02-13 11:48:39.925
                                true	true		2019-02-13 11:48:37.540
                                true	true		2019-02-13 11:48:36.601
                                true	true		2019-02-13 11:48:34.290
                                true	true		2019-02-13 11:48:33.352
                                true	true		2019-02-13 11:48:30.586
                                true	true		2019-02-13 11:48:29.662
                                true	true		2019-02-13 11:48:24.156
                                true	true		2019-02-13 11:48:23.196
                                null	true		2019-02-13 11:44:52.355
                                  Danke!
                                  Mach ich gleich.
                                  log :
                                  History:
                                  History:
                                  Danke.
                                  Der Vergleich mit PRESS_SHORT wäre noch interessant: Kommt der erste PRESS_LONG-Trigger vor dem PRESS_SHORT-Trigger (beim Drücken) oder gleichzeitig ? Kennst Du die Zeitspanne für PRESS_SHORT ?
                                    Hab ich natürlich nicht geloggt 😳
                                    Natürlich, habe sie ja selbst auf 0.3 gesetzt
                                    Habe das Blockly aber jetzt geändert.
                                    ist das so mit dem zusätzlich falls/sonst block ok?
                                      Nein, Du hast wahr und unwahr vertauscht bei setze Sperre auf.
                                        Ooops, tatsächlich!
                                        Hat auch nicht geklappt - welch Wunder ;-)
                                        Habe aber was anderes festgestellt.
                                        Wenn ich nur einen "kurzen LONG_PRESS" mache klappt alles wie ich will, warte ich jedoch mit dem loslassen bis die Lampe die Helligkeit gewechselt hat, springt sie wieder zurück.
                                        Melde mich gleich wieder
                                          @foxriver76
                                          Hier die Send...
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          @foxriver76
                                          Hier die Send...
                                          Ist gefixt und zukünftig werden beim neuanlegen von Geräten mit einem MAX von 1.005 dieser automatisch auf 1 korrigiert, da das Problem schon häufiger vorgekommen ist und man nicht bei jedem Gerät auf die manuelle Korrektur warten möchte. --> RPC 1.9.7
