  4. Shelly Adapter
Shelly Adapter
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
59 Beiträge 5 Kommentatoren 9.7k Aufrufe 5 Beobachtet
  • StabilostickS Offline
    Stabilostick
    So, bei der Shelly-Instanz:
    R 2 Antworten Letzte Antwort
    • StabilostickS Stabilostick
      Rocket85
      @Stabilostick
      Mal wieder auf dem Schlauch gestanden.
        Rocket85
        @Stabilostick
        host.raspberrypi 2019-02-12 01:00:11.740 info Restart adapter system.adapter.shelly.0 because enabled
        host.raspberrypi 2019-02-12 01:00:11.739 error instance system.adapter.shelly.0 terminated with code 0 (OK)
        shelly.0 2019-02-12 01:00:11.686 info Starting shelly.0 in version 2.1.0
        shelly.0 2019-02-12 01:00:11.674 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
        shelly.0 2019-02-12 01:00:11.552 debug statesDB connected
        shelly.0 2019-02-12 01:00:11.490 debug objectDB connected
        host.raspberrypi 2019-02-12 01:00:10.328 info instance system.adapter.shelly.0 started with pid 5729
        host.raspberrypi 2019-02-12 00:59:40.303 info Restart adapter system.adapter.shelly.0 because enabled
        host.raspberrypi 2019-02-12 00:59:40.303 error instance system.adapter.shelly.0 terminated with code 0 (OK)
        shelly.0 2019-02-12 00:59:40.252 info Starting shelly.0 in version 2.1.0
        shelly.0 2019-02-12 00:59:40.242 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
        shelly.0 2019-02-12 00:59:40.124 debug statesDB connected
        shelly.0 2019-02-12 00:59:40.061 debug objectDB connected
        host.raspberrypi 2019-02-12 00:59:38.909 info instance system.adapter.shelly.0 started with pid 5707
        host.raspberrypi 2019-02-12 00:59:08.878 info Restart adapter system.adapter.shelly.0 because enabled
        host.raspberrypi 2019-02-12 00:59:08.878 error instance system.adapter.shelly.0 terminated with code 0 (OK)
        shelly.0 2019-02-12 00:59:08.815 info Starting shelly.0 in version 2.1.0
        shelly.0 2019-02-12 00:59:08.806 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
        shelly.0 2019-02-12 00:59:08.688 debug statesDB connected
        shelly.0 2019-02-12 00:59:08.623 debug objectDB connected
        host.raspberrypi 2019-02-12 00:59:07.436 info instance system.adapter.shelly.0 started with pid 5685
        host.raspberrypi 2019-02-12 00:59:04.958 info instance system.adapter.shelly.0 terminated with code 0 (OK)
        host.raspberrypi 2019-02-12 00:59:04.894 info stopInstance system.adapter.shelly.0 killing pid 4699
        R 1 Antwort Letzte Antwort
        • R Rocket85
          @Stabilostick
          Rocket85
          @Rocket85 said in Shelly Adapter:
          @Stabilostick
          Da werd ich leider nicht schlau drauß, aber irgendwas stimmt mit dem Adapter glaube ich nicht!
            Stabilostick
            schrieb am zuletzt editiert von Stabilostick
            Drei mal gestopp worden und Du hattest ihn ein mal gestartet?
            Ist der Adapter konfigurierbar und Du hast ihn richtig konfiguriert?
            Leichtet die Ampel vor der Instanz immer grün?
              Rocket85
              @Stabilostick
              Ich hab leider nichts gemacht, kam alles automatisch. Ich habe lediglich einmal versucht einen Shelly von fals auf true zu schalten
                Rocket85
                @Stabilostick said in Shelly Adapter:
                Normal schon.
                Hab jetzt mal komplett gelöscht und neu installiert. Bis jetzt ist er noch nicht grün
                host.raspberrypi 2019-02-12 01:05:17.769 info Restart adapter system.adapter.shelly.0 because enabled
                host.raspberrypi 2019-02-12 01:05:17.766 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                host.raspberrypi 2019-02-12 01:05:16.336 info instance system.adapter.shelly.0 started with pid 6050
                host.raspberrypi 2019-02-12 01:05:16.308 info object change system.adapter.shelly.0
                host.raspberrypi 2019-02-12 01:04:47.951 info Restart adapter system.adapter.shelly.0 because enabled
                host.raspberrypi 2019-02-12 01:04:47.950 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                shelly.0 2019-02-12 01:04:47.897 info Starting shelly.0 in version 2.1.0
                shelly.0 2019-02-12 01:04:47.887 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                shelly.0 2019-02-12 01:04:47.771 debug statesDB connected
                shelly.0 2019-02-12 01:04:47.700 debug objectDB connected
                host.raspberrypi 2019-02-12 01:04:46.520 info instance system.adapter.shelly.0 started with pid 6027
                host.raspberrypi 2019-02-12 01:04:46.492 info object change system.adapter.shelly.0
                host.raspberrypi 2019-02-12 01:04:39.260 info Restart adapter system.adapter.shelly.0 because enabled
                host.raspberrypi 2019-02-12 01:04:39.259 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                shelly.0 2019-02-12 01:04:39.205 info Starting shelly.0 in version 2.1.0
                shelly.0 2019-02-12 01:04:39.193 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                shelly.0 2019-02-12 01:04:39.074 debug statesDB connected
                shelly.0 2019-02-12 01:04:39.010 debug objectDB connected
                • R Offline
                  Rocket85
                  geht leider immer in Dauerschleife so weiter!
                  host.raspberrypi 2019-02-12 01:08:13.531 info Restart adapter system.adapter.shelly.0 because enabled
                  host.raspberrypi 2019-02-12 01:08:13.531 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                  shelly.0 2019-02-12 01:08:13.471 info Starting shelly.0 in version 2.1.0
                  shelly.0 2019-02-12 01:08:13.456 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                  shelly.0 2019-02-12 01:08:13.328 debug statesDB connected
                  shelly.0 2019-02-12 01:08:13.264 debug objectDB connected
                  • R Offline
                    Rocket85
                    Jetzt wird der Shelly Adapter leider nicht mehr grün
                      Stabilostick
                      Kannst Du bitte das in dem folgendem Posting beschriebene ausprobieren und das Ergebnis hier posten?
                      https://forum.iobroker.net/topic/18687/shelly-adapter-funktioniert-nicht-error-log/2
                        Rocket85
                        @Stabilostick
                        Anbei das Ergebnis. Schon mal vielen DANK für deine Mühe.
                        Exception: TypeError: xmlserializer.Builder is not a constructor/TypeError: xmlserializer.Builder is not a constructor
                          Stabilostick
                          Kannst Du bitte den Shelly-Adapter mit der zugehörigen Instanz noch einmal löschen, wieder installieren und das Log der Installation hier posten (wenn er wieder nicht grün wird)?
                            Rocket85
                            @Stabilostick
                            $ ./iobroker add shelly  --host raspberrypi
                            host.raspberrypi create instance shelly
                            host.raspberrypi object shelly.0.info.connection created
                            host.raspberrypi object shelly.0.info created
                            host.raspberrypi object system.adapter.shelly.0.outputCount created
                            host.raspberrypi object system.adapter.shelly.0.inputCount created
                            host.raspberrypi object system.adapter.shelly.0.uptime created
                            host.raspberrypi object system.adapter.shelly.0.memRss created
                            host.raspberrypi object system.adapter.shelly.0.memHeapTotal created
                            host.raspberrypi object system.adapter.shelly.0.memHeapUsed created
                            host.raspberrypi object system.adapter.shelly.0.connected created
                            host.raspberrypi object system.adapter.shelly.0.alive created
                            host.raspberrypi object system.adapter.shelly.0 created
                            process exited with code 0
                              Stabilostick
                              Kann es sein, dass Du nur die Instanz aber nicht den Adapter gelöscht hast?
                                Rocket85
                                @Stabilostick
                                Eigentlich habe ich den Adapter gelöscht, allerdings habe ich eben mal den Haken bei - schließen wenn fertig - weg gemacht und da ist mir etwas aufgefallen.
                                $ ./iobroker del shelly
                                Delete adapter "shelly"
                                host.raspberrypi no instances of adapter shelly found
                                npm uninstall iobroker.shelly --silent --save --prefix "/opt/iobroker" (System call)
                                ERROR: Error deleting adapter shelly from disk: Error: host.raspberrypi: Cannot uninstall iobroker.shelly: 243
                                ERROR: You might have to delete it yourself!
                                  Stabilostick
                                  Vorschlag:
                                  1. Beende iobroker mit
                                    iobroker stop
                                    ausgeführt im iobroker-Ordner.
                                  2. Lösche manuell den node_modules/iobroker.shelly-Ordner (habe ich aus dem Gedächtnis so geschrieben)
                                  Dann wieder den ioBroker starten.
                                    Vorschlag:
                                      iobroker stop
                                    Rocket85
                                    @Stabilostick
                                    Rückmeldung:
                                    rm: das entfernen von ´node_modules/iobroker.shelly´ ist nicht möglich. Keine Berechtigung
                                      Stabilostick
                                      Dann mit etwas mehr Rechten. Stelle bitte den Befehl „sudo“ vor Deinen rm-Befehl
                                        Rocket85
                                        @Stabilostick
                                        Hab ich schon gemacht. DANKE....Moment Shelly ist weg, ich installiere neu!
                                        • R Offline
                                          Rocket85
                                          So langsam fehlen mir die Worte. Anbei das Log der Neuinstallation. Leider immer noch auf ROT.
                                          NPM version: 6.5.0
                                          npm install iobroker.shelly --production --save --prefix "/opt/iobroker" (System call)
                                          host.raspberrypi install adapter shelly
                                          got /opt/iobroker/node_modules/iobroker.shelly/admin
                                          upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                                          upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                                          upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                                          host.raspberrypi object system.adapter.shelly created
