  4. Hilfe bei MQTT mit ESP-01
18 Beiträge 4 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • coyoteC Offline
    coyoteC Offline
    coyote
    Nein hab ich nicht, aber was bringt mir denn deine Aussage jetzt? Ich weiß trotzdem nicht ob der Adapter das schafft oder nicht.
    Bzw. was ist dann die Lösung? Abfrage Zeit von 6 Sekunden erhöhen?
    Bin mir gerade nicht mal sicher ob alle Stati in 6 Sekunden aktualisiert werden oder nur die Raum Temperatur.
    Gesendet von meinem ONEPLUS A6013 mit Tapatalk
    • coyoteC Offline
      coyoteC Offline
      coyote
      Hier mal noch die Screenshots und das Sketch des ESP
      Sketch:
      MHI ESP2MQTT Interface v1.0.0
      Arduino-based communication interface for Mitsubishi Heavy Industries (MHI) SRK/SRF series air conditioners.
      Connects to the MHI CNS connector and synchronizes to its Serial Peripheral Interface (SPI). Updates from the MHI are processed and sent via serial to an ESP8266 running an MQTT client.
      Updates received via MQTT are sent from the ESP8266 to the Arduino over serial and injected into the SPI data frames to update the MHI.
      R.J. Dekker, June 2018
      #include <fs.h>
      #include <esp8266wifi.h>
      #include <dnsserver.h>
      #include <esp8266webserver.h>
      #include <wifiudp.h>
      #include <arduinoota.h>
      #include <wifimanager.h>        //https://github.com/tzapu/WiFiManager
      #include <arduinojson.h>        //https://github.com/bblanchon/ArduinoJson
      #include <pubsubclient.h>        //https://github.com/knolleary/pubsubclient
      #include <easytransfer.h>        //https://github.com/madsci1016/Arduino-EasyTransfer
      //Access point that WiFiManager starts for configuration. Name and password should be set below before flashing. This is hardcoded and cannot be changed later.
      #define configSSID  "MHI Wintergarten"        //AP name (give every unit a unique name before flashing)
      #define configPW    "password"        //Password to connect to the AP
      //Variables below are initial values that can be changed at any time from the WiFiManager configuration portal and will be stored in flash memory. If there are different values in config.json, they are overwritten.
      char mqtt_server[16]     = "0.0.0.0";
      char mqtt_port[9]        = "1883";
      char mqtt_user[20]       = "";
      char mqtt_pass[20]       = "";
      char wifiTimeout[3]      = "5";        //Timeout in minutes (max. 99) before WiFi configuration portal is turned off and the ESP tries to connect again to the previously configured AP (if any)
      char Room[20]            = "Roomname";
      char Thing[20]           = "Aircon";
      char Setpoint[60]        = "Setpoint";
      char statusSetpoint[60]  = "statusSetpoint";
      char State[60]           = "State";
      char statusState[60]     = "statusState";
      char statusRoomtemp[60]  = "statusRoomtemp";
      char Vanes[60]           = "Vanes";
      char statusVanes[60]     = "statusVanes";
      char Fanspeed[60]        = "Fanspeed";
      char statusFanspeed[60]  = "statusFanspeed";
      char debug[60]           = "debug";        //Send only
      char service[60]         = "service";        //Receive only
      //Variables below hold the current values of bit fields 4-7 and all adjustable settings to check if anything changed after receiving an update from the MHI/Arduino
      //Bit field variables are initialized with 255 to force an MQTT update with the most recent MHI settings directly after booting
      //The minimal set of bit fields needed to communicate power, mode, setpoint, roomtemp, vanes and fans speed is bit fields 4-7 and 10
      byte current_Bitfield4   = 255;        //Power, mode and vane swing settings
      int  current_Bitfield5   = 255;        //Vanes setting 1-4 and fan speed 1-3 (4 is in bit field 10)
      byte current_Bitfield6   = 255;        //Temperature setpoint
      byte current_Bitfield7   = 255;        //Room temperature
      byte current_Mode        = 255;
      byte current_Vanes       = 255;
      bool current_Swing       = false;
      byte current_Fanspeed    = 255;
      bool current_Fanspeed4   = false;
      bool debugit = false;        //Send some info (eg. MHI SPI bit field updates and errors) to debug topic
      int connectionFails = 0;        //Count number of failed MQTT connection attempts for restart
      //                               HEAT        COOL        AUTO        DRY         FAN
      static byte modeValues[5] = { 0b00010001, 0b00001001, 0b00000001, 0b00000101, 0b00001101 };                        //Used to extract current mode from bit field 4
      WiFiClient espClient;
      PubSubClient client(espClient);
      void callback(char* topic, byte* payload, unsigned int length);                                                    //Callback function header
      //Flag for saving data
      bool shouldSaveConfig = false;
      //Setup EasyTransfer (by Bill Porter)
      EasyTransfer ETin, ETout;
      struct RECEIVE_DATA_STRUCTURE {        //Variables received from Arduino
        byte currentMHI[8];        //Contains bitfields last received from MHI for bitfields 4 - 10 (currentMHI[0]-[6]). currentMHI[7] holds the number of SPI-MHI sync errors.
      struct SEND_DATA_STRUCTURE {        //Variable send to Arduino
        byte mode;        //Mode      [1]OFF,  [2]HEAT,  [3]COOL,  [4]AUTO,  [5]DRY,   [6]FAN,  [7]ON,  [64]RESET
        byte vanes;        //Vanes     [1]UP,   [2]2,     [3]3,     [4]DOWN,  [5]SWING
        byte fanspeed;        //Fanspeed  [1]1,    [2]2,     [3]3,     [4]4
        byte setpoint;        //Setpoint  [18]18 -> [30]30 degrees Celsius
      } __attribute__((packed));        //Necessary for correct transfer of struct between Arduino and ESP8266
      RECEIVE_DATA_STRUCTURE   fromArduino;
      SEND_DATA_STRUCTURE   toArduino;
      //Callback notifying us of the need to save WiFiManager config to FS
      void saveConfigCallback ()
        //Serial.println("Should save config");
        shouldSaveConfig = true;
      template <typename generic=""> void debug2mqtt(Generic text)
        if (debugit)
            client.publish(debug, text, true);
      void setup()
        ETin.begin(details(fromArduino), &Serial);        //Start the EasyTransfer library, pass in the data details and the name of the serial port
        ETout.begin(details(toArduino), &Serial);
        //Read configuration from FS json
        //Serial.println("Mounting FS...");
        if (SPIFFS.begin())
            //Serial.println("Mounted file system");
            if (SPIFFS.exists("/config.json"))
                //File exists, reading and loading
                //Serial.println("Reading config file");
                File configFile = SPIFFS.open("/config.json", "r");
                if (configFile)
                    //Serial.println("Opened config file");
                    size_t size = configFile.size();
                    //Allocate a buffer to store contents of the file.
                    std::unique_ptr <char[]>buf(new char[size]);
                    configFile.readBytes(buf.get(), size);
                    DynamicJsonBuffer jsonBuffer;
                    JsonObject& json = jsonBuffer.parseObject(buf.get());
                    //json.printTo(Serial);
                    if (json.success())
                        //Serial.println("\nParsed json");
                        strcpy(mqtt_server, json["mqtt_server"]);
                        strcpy(mqtt_port, json["mqtt_port"]);
                        strcpy(mqtt_user, json["mqtt_user"]);
                        strcpy(mqtt_pass, json["mqtt_pass"]);
                        strcpy(wifiTimeout, json["wifiTimeout"]);
                        strcpy(Room, json["Room"]);
                        strcpy(Thing, json["Thing"]);
                        strcpy(Setpoint, json["Setpoint"]);
                        strcpy(statusSetpoint, json["statusSetpoint"]);
                        strcpy(State, json["State"]);
                        strcpy(statusState, json["statusState"]);
                        strcpy(statusRoomtemp, json["statusRoomtemp"]);
                        strcpy(Vanes, json["Vanes"]);
                        strcpy(statusVanes, json["statusVanes"]);
                        strcpy(Fanspeed, json["Fanspeed"]);
                        strcpy(statusFanspeed, json["statusFanspeed"]);
                        strcpy(debug, json["debug"]);
                        strcpy(service, json["service"]);
                    else
                        //Serial.println("Failed to load json config");
        else
            //Serial.println("Failed to mount FS");
        //The extra parameters to be configured (can be either global or just in the setup)
        //After connecting, parameter.getValue() will get you the configured value
        //id/name placeholder/prompt default length
        WiFiManagerParameter custom_mqtt_server("server", "MQTT Server", mqtt_server, 16);
        WiFiManagerParameter custom_mqtt_port("port", "MQTT Port", mqtt_port, 9);
        WiFiManagerParameter custom_mqtt_user("user", "MQTT Username", mqtt_user, 20);
        WiFiManagerParameter custom_mqtt_pass("pass", "MQTT Password", mqtt_pass, 20);
        WiFiManagerParameter custom_wifiTimeout("timeout", "5", wifiTimeout, 3);
        WiFiManagerParameter custom_topic_Room("Room", "Room name", Room, 20);
        WiFiManagerParameter custom_topic_Thing("Thing", "Thing name", Thing, 20);
        WiFiManagerParameter custom_topic_Setpoint("Setpoint", "Setpoint", Setpoint, 40);
        WiFiManagerParameter custom_topic_statusSetpoint("statusSetpoint", "statusSetpoint", statusSetpoint, 40);
        WiFiManagerParameter custom_topic_State("State", "State", State, 40);
        WiFiManagerParameter custom_topic_statusState("statusState", "statusState", statusState, 40);
        WiFiManagerParameter custom_topic_statusRoomtemp("statusRoomtemp", "statusRoomtemp", statusRoomtemp, 40);
        WiFiManagerParameter custom_topic_Vanes("Vanes", "Vanes", Vanes, 40);
        WiFiManagerParameter custom_topic_statusVanes("statusVanes", "statusVanes", statusVanes, 40);
        WiFiManagerParameter custom_topic_Fanspeed("Fanspeed", "Fanspeed", Fanspeed, 40);
        WiFiManagerParameter custom_topic_statusFanspeed("statusFanspeed", "statusFanspeed", statusFanspeed, 40);
        WiFiManagerParameter custom_topic_debug("debug", "debug", debug, 40);
        WiFiManagerParameter custom_topic_service("service", "service", service, 40);
        //WiFiManager
        //Local intialization. Once its business is done, there is no need to keep it around
        WiFiManager wifiManager;
        wifiManager.setDebugOutput(false);
        //Set config save notify callback
        wifiManager.setSaveConfigCallback(saveConfigCallback);
        //Optional: Set static ip
        //wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
        //Add all parameters here
        wifiManager.addParameter(&custom_mqtt_server);
        wifiManager.addParameter(&custom_mqtt_port);
        wifiManager.addParameter(&custom_mqtt_user);
        wifiManager.addParameter(&custom_mqtt_pass);
        wifiManager.addParameter(&custom_wifiTimeout);
        wifiManager.addParameter(&custom_topic_Room);
        wifiManager.addParameter(&custom_topic_Thing);
        wifiManager.addParameter(&custom_topic_Setpoint);
        wifiManager.addParameter(&custom_topic_statusSetpoint);
        wifiManager.addParameter(&custom_topic_State);
        wifiManager.addParameter(&custom_topic_statusState);
        wifiManager.addParameter(&custom_topic_statusRoomtemp);
        wifiManager.addParameter(&custom_topic_Vanes);
        wifiManager.addParameter(&custom_topic_statusVanes);
        wifiManager.addParameter(&custom_topic_Fanspeed);
        wifiManager.addParameter(&custom_topic_statusFanspeed);
        wifiManager.addParameter(&custom_topic_debug);
        wifiManager.addParameter(&custom_topic_service);
        //Set minimum quality of signal so it ignores AP's under that quality
        //Defaults to 8%
        wifiManager.setMinimumSignalQuality(5);
        //Sets timeout until configuration portal gets turned off
        //and retries connecting to the preconfigured AP
        wifiManager.setConfigPortalTimeout(atoi(wifiTimeout) * 60);                                                      //Convert minutes to seconds
        //Fetches ssid and pass and tries to connect
        //If it does not connect it starts an access point with the specified name
        //and goes into a blocking loop awaiting configuration
        if (!wifiManager.autoConnect(configSSID, configPW))
            //Serial.println("Failed to connect and hit timeout");
            delay(3000);
            //Reset and try again, or maybe put it to deep sleep
            ESP.reset();
            delay(5000);
        //If you get here you have connected to the WiFi
        //Serial.println("Connected...yeey :)");
        //Read updated parameters
        strcpy(mqtt_server, custom_mqtt_server.getValue());
        strcpy(mqtt_port, custom_mqtt_port.getValue());
        strcpy(mqtt_user, custom_mqtt_user.getValue());
        strcpy(mqtt_pass, custom_mqtt_pass.getValue());
        strcpy(wifiTimeout, custom_wifiTimeout.getValue());
        strcpy(Room, custom_topic_Room.getValue());
        strcpy(Thing, custom_topic_Thing.getValue());
        //Construct topic names
        //Topic prefix = "Room/Thing/"
        char topic_prefix[42] = "";
        strncpy(topic_prefix, Room, 20);
        strcat (topic_prefix, "/");
        strncat(topic_prefix, Thing, 20);
        //Start all topics with topic prefix
        strcpy(Setpoint, topic_prefix);
        strcpy(statusSetpoint, topic_prefix);
        strcpy(State, topic_prefix);
        strcpy(statusState, topic_prefix);
        strcpy(statusRoomtemp, topic_prefix);
        strcpy(Vanes, topic_prefix);
        strcpy(statusVanes, topic_prefix);
        strcpy(Fanspeed, topic_prefix);
        strcpy(statusFanspeed, topic_prefix);
        strcpy(debug, topic_prefix);
        strcpy(service, topic_prefix);
        //Append final topic level
        size_t maxAppend = 60 - sizeof(topic_prefix);
        strncat(Setpoint, custom_topic_Setpoint.getValue(), maxAppend);
        strncat(statusSetpoint, custom_topic_statusSetpoint.getValue(), maxAppend);
        strncat(State, custom_topic_State.getValue(), maxAppend);
        strncat(statusState, custom_topic_statusState.getValue(), maxAppend);
        strncat(statusRoomtemp, custom_topic_statusRoomtemp.getValue(), maxAppend);
        strncat(Vanes, custom_topic_Vanes.getValue(), maxAppend);
        strncat(statusVanes, custom_topic_statusVanes.getValue(), maxAppend);
        strncat(Fanspeed, custom_topic_Fanspeed.getValue(), maxAppend);
        strncat(statusFanspeed, custom_topic_statusFanspeed.getValue(), maxAppend);
        strncat(debug, custom_topic_debug.getValue(), maxAppend);
        strncat(service, custom_topic_service.getValue(), maxAppend);
        //Debug resulting topics to serial
      /*  Serial.println("Constructed topics:");
        Serial.println(Setpoint);
        Serial.println(statusSetpoint);
        Serial.println(State);
        Serial.println(statusState);
        Serial.println(statusRoomtemp);
        Serial.println(Vanes);
        Serial.println(statusVanes);
        Serial.println(Fanspeed);
        Serial.println(statusFanspeed);
        Serial.println(debug);
        Serial.println(service);
        //Save the custom parameters to FS
        if (shouldSaveConfig)
            //Serial.println("Saving config...");
            JsonObject& json = jsonBuffer.createObject();
            json["mqtt_server"] = mqtt_server;
            json["mqtt_port"] = mqtt_port;
            json["mqtt_user"] = mqtt_user;
            json["mqtt_pass"] = mqtt_pass;
            json["wifiTimeout"] = wifiTimeout;
            json["Room"] = Room;
            json["Thing"] = Thing;
            json["Setpoint"] = custom_topic_Setpoint.getValue();
            json["statusSetpoint"] = custom_topic_statusSetpoint.getValue();
            json["State"] = custom_topic_State.getValue();
            json["statusState"] = custom_topic_statusState.getValue();
            json["statusRoomtemp"] = custom_topic_statusRoomtemp.getValue();
            json["Vanes"] = custom_topic_Vanes.getValue();
            json["statusVanes"] = custom_topic_statusVanes.getValue();
            json["Fanspeed"] = custom_topic_Fanspeed.getValue();
            json["statusFanspeed"] = custom_topic_statusFanspeed.getValue();
            json["debug"] = custom_topic_debug.getValue();
            json["service"] = custom_topic_service.getValue();
            File configFile = SPIFFS.open("/config.json", "w");
      /*      if (!configFile)
                Serial.println("Failed to open config file for writing");
            json.printTo(configFile);
            configFile.close();
        //Serial.println();
        //Serial.print("Local IP adres: ");
        //Serial.println(WiFi.localIP());
        //Connect to MQTT broker and set callback
        client.setServer(mqtt_server, atoi(mqtt_port));
        client.setCallback(callback);
        //Configure Arduino OTA updater
        ArduinoOTA.setHostname(configSSID);        //Set OTA hostname and password (same as local access point for WiFiManager)
        ArduinoOTA.setPassword((const char *)configPW);
        //ArduinoOTA.setPort(8266);        //Port defaults to 8266
        ArduinoOTA.onError([](ota_error_t error)        //Send OTA error messages to MQTT debug topic
            if      (error == OTA_AUTH_ERROR)      client.publish(debug, " <ota>ERROR -> Auth failed", true);
            else if (error == OTA_BEGIN_ERROR)     client.publish(debug, " <ota>ERROR -> Begin failed", true);
            else if (error == OTA_CONNECT_ERROR)   client.publish(debug, " <ota>ERROR -> Connect failed", true);
            else if (error == OTA_RECEIVE_ERROR)   client.publish(debug, " <ota>ERROR -> Receive failed", true);
            else if (error == OTA_END_ERROR)       client.publish(debug, " <ota>ERROR -> End failed", true);
        ArduinoOTA.begin();
      void connect()
        // Loop until we're (re)connected
        while (!client.connected())
            //Serial.print("Attempting MQTT connection...");
            //MQTT connection: Attempt to connect to MQTT broker 3 times: SUCCESS -> continue | FAILED restart ESP
            //On restart it will first try to connect to the previously set AP. If that fails the config portal will be started.
            //If the config portal is not used within wifiTimeout (set in portal), the ESP will retry connecting to the previously set AP again.
            if (client.connect(configSSID, mqtt_user, mqtt_pass))
                //Serial.println("connected!");
                //Subscribe to topics that control the MHI state
                client.subscribe(Setpoint, 1);
                client.subscribe(State, 1);
                client.subscribe(Vanes, 1);
                client.subscribe(Fanspeed, 1);
                client.subscribe(service, 1);
                char msg[62] = "MHI2MQTT connected to MQTT broker at ";
                strncat(msg, mqtt_server, 15);
                strcat(msg, ":");
                strncat(msg, mqtt_port, 8);
                client.publish(debug, msg , true);        //Publish message to debug topic to test/notify MQTT connection
                Serial.begin(500000);
                while(Serial.available()) Serial.read();        //Empty serial read buffer. Arduino keeps sending updates over serial during wifi configuration and connecting MQTT broker.
            else
      /*        Serial.print("failed, rc = ");
                Serial.println(client.state());
                Serial.print("Failed connection attempts: ");
                Serial.println(connectionFails); */
                if (++connectionFails == 3)
                    //Serial.println("MQTT broker connection timeout...restarting!");
                    delay(1000);
                    ESP.restart();
                    delay(5000);
                    break;
                //Serial.println("Try again in 5 seconds...");
                delay(5000);
        //Serial.print("Message arrived on topic [");
        //Serial.print(topic);
        //Serial.print("]: ");
        char buffer[length + 1];
        for (int i = 0; i < length; i++)        //Copy payload to buffer string
            buffer[i] = (char)payload[i];
            //Serial.print((char)payload[i]);
        buffer[length] = '\0';        //Terminate string
        //Serial.println();
        //SERVICE COMMANDS
        if (strcmp(topic, service) == 0)
            if (strcmp(buffer, "reboot") == 0)
                toArduino.mode     = 64;        //Send code to restart Arduino
                toArduino.vanes    = 0;
                toArduino.fanspeed = 0;
                toArduino.setpoint = 0;
                ETout.sendData();
                client.publish(debug, " << Rebooting... >>", true);
                delay(2000);
                ESP.restart();        //Now restart ESP
                delay(5000);
                return;
            if (strcmp(buffer, "reinit") == 0)        //Start WiFiManager after erasing previously stored settings
                client.publish(debug, " << Reinitializing...(erase flash, reboot and start WiFiManager) >>", true);
                delay(500);
                SPIFFS.format();        //Erase flash
                delay(1000);
                WiFi.disconnect();        //Start WiFiManager  for reconfiguration
                delay(1000);
                ESP.restart();
                delay(5000);
                return;
            if (strcmp(buffer, "wifimanager") == 0)        //Start WiFiManager with previously stored settings
                client.publish(debug, " << Starting WiFiManager... >>", true);
                delay(500);
                WiFi.disconnect();
                delay(1000);
                ESP.restart();
                delay(5000);
                return;
            if (strcmp(buffer, "debugon") == 0)        //Send some info on debug topic, see debug2mqtt() in the code
                client.publish(debug, " << Debug ON >>", true);
                debugit = true;
                return;
            if (strcmp(buffer, "debugoff") == 0)
                client.publish(debug, " << Debug OFF >>", true);
                debugit = false;
                return;
            if (strcmp(buffer, "help") == 0)
                client.publish(debug, " <reboot>-> restart Arduino & ESP8266 | <reinit> -> erase flash and start WiFiManager", true);
                client.publish(debug, " <wifimanager>-> Start WiFiManager | <debugon> <debugoff>-> Show some info on debug topic", true);
                return;
            client.publish(debug, " << Unknown service command >>", true);
            return;
        int value = atoi(buffer);        //Convert payload to integer variable
        //POWER & MODE: payload = 0 [OFF], 1 [HEAT], 2 [COOL], 3 [AUTO], 4 [DRY], 5 [FAN], 6 [ON]
        if (strcmp(topic, State) == 0)
            if (value >= 0 && value < 7)
                toArduino.mode = value + 1;
                ETout.sendData();        //Send updated settings to Arduino using EasyTransfer
                //Serial.print("Mode change: ");
                //Serial.println(toArduino.mode);
                toArduino.mode = 0;
                debug2mqtt(" <esp>Updated power/mode settings send to Arduino/MHI.");
            else
                debug2mqtt(" << Error >> Value on MODE topic out of range [0-6]");
            return;
        //VANES: payload = 1 [1-UP], 2 [2], 3 [3], 4 [4-DOWN], 5 [SWING]
        if (strcmp(topic, Vanes) == 0)
            if (value > 0 && value < 6)
                toArduino.vanes = value;
                //Serial.print("Vanes change: ");
                //Serial.println(toArduino.vanes);
                debug2mqtt(" <esp>Updated vanes settings send to Arduino/MHI.");
            else
                debug2mqtt(" << Error >> Value on VANES topic out of range [1-5]");
            return;
        //FAN SPEED: payload = 1 [1-LOW], 2 [2], 3 [3], 4 [4-HIGH]
        if (strcmp(topic, Fanspeed) == 0)
            if (value > 0 && value < 5)
                toArduino.fanspeed = value;
                //Serial.print("Fan speed change: ");
                //Serial.println(toArduino.fanspeed);
                debug2mqtt(" <esp>Updated fan speed settings send to Arduino/MHI.");
            else
                debug2mqtt(" << Error >> Value on FAN SPEED topic out of range [1-4]");
            return;
        //TEMPERATURE SETPOINT: payload = temperature in degrees Celsius
        if (strcmp(topic, Setpoint) == 0)
            if (value > 17 && value < 31)
                toArduino.setpoint   = value;        //Bitfield containing target temperature
                //Serial.print("Setpoint change: ");
                //Serial.println(toArduino.setpoint);
                debug2mqtt(" <esp>Updated setpoint settings send to Arduino/MHI.");
            else
                debug2mqtt(" << Error >> Value on SETPOINT topic out of range [18-30]");
            return;
      void loop()
        ArduinoOTA.handle();        //Handle Arduino OTA updates
        if (!client.connected())        //Check MQTT connection
            connect();        //Connect first time. Reconnect when connection lost.
        client.loop();
        if (ETin.receiveData())        //Check for new data on serial (EasyTransfer). Returns false or true.
            delay(1);        //Make sure receive is complete. I've had occasional problems and this appears to solve them.
            if (debugit)        //If debug = on -> send part of SPI byte frame to MQTT debug topic
                char buffer[54] = " <mhi>Updated bit field 4-10:  ";
                int loc = 31;
                for (int i = 0; i < 7; i++)
                    snprintf(buffer + loc, 53 - loc , "%02X ", fromArduino.currentMHI[i]);
                    loc += 3;
                client.publish(debug, buffer, true);        //Send latest MHI bit field update to MQTT broker
                snprintf(buffer, 53, " <mhi>%d SPI resync/checksum errors", fromArduino.currentMHI[7]);
                client.publish(debug, buffer, true);        //Send cumulative number of checksum errors on Arduino-SPI-MHI connection to MQTT
            //Process MHI bit field 4-10 updates and only publish changes to corresponding MQTT statuses
            char msg[5] = "";        //Buffer string holding payload to publish
            byte buf = 0;
            //####### Bit field 4 >>> POWER, MODE & VANES (swing only) #######
            if (fromArduino.currentMHI[0] != current_Bitfield4)                                                          //Any change compared to previous bit field 4?
                debug2mqtt(" <mhi>Bit field 4 changed");
                current_Bitfield4 = fromArduino.currentMHI[0];                                                           //Store new current bit field 4
                //POWER and/or MODE changed
                if ((current_Bitfield4 & 0b00011101) != current_Mode)                                                    //Extract mode bits (3-5) en power bit (1)
                    current_Mode = current_Bitfield4 & 0b00011101;
                    //Get POWER and MODE states
                    if (bitRead(current_Mode, 0) == 0)        //Power is OFF
                        buf = 0;
                    else
                        for (int i = 0; i < 5; i++)        //Power is ON -> get MODE
                            if (current_Mode == modeValues[i])
                                buf = i + 1;
                                break;
                    snprintf(msg, 2, "%1d", buf);
                    client.publish(statusState, msg, true);                                                              //Send update to MQTT broker
                    debug2mqtt(" <mhi>Mode/Power changed");
      /*            Serial.println("State (Mode/Power) changed");
                    Serial.print("MQTT publish [");
                    Serial.print(statusState);
                    Serial.println(msg); */
                //VANES changed to swing
                if (bitRead(current_Bitfield4, 6))        //Check if new vanes setting is swing
                    if (!current_Swing)        //Check if changed compared to previous setting
                        current_Swing = true;
                        client.publish(statusVanes, "5", true);                                                          //Send update to MQTT broker
                        debug2mqtt(" <mhi>Vanes changed");
      /*                Serial.println("Vanes changed");
                        Serial.print(statusVanes);
                        Serial.println("5"); */
                else if (current_Swing)        //SWING changed from ON to OFF
                    current_Bitfield5 = -1;        //Force update of VANES below (bit field 5) by setting out-of-range values
            //####### Bit field 10 >>> FAN SPEED (setting 4 only) #######
            if (bitRead(fromArduino.currentMHI[6], 6))        //Check if new speed setting is 4
                if (!current_Fanspeed4)        //Check if changed compared to current setting
                    debug2mqtt(" <mhi>Bit field 10 changed");
                    current_Fanspeed4 = true;
                    client.publish(statusFanspeed, "4", true);                                                           //Send update to MQTT broker
                    debug2mqtt(" <mhi>Fan speed changed");
      /*            Serial.println("Fanspeed changed");
                    Serial.print(statusFanspeed);
            else if (current_Fanspeed4)        //FAN SPEED changed from 4 to 1-3
                current_Bitfield5 = -1;        //Force update of FANSPEED below (bit field 5) by setting out-of-range values
            //####### Bit field 5 >>> VANES (position 1-4) & FAN SPEED (setting 1-3) #######
            if ((int)fromArduino.currentMHI[1] != current_Bitfield5)                                                     //Any change compared to previous bit field 5? Force update of VANES if SWING was just switched off. Same for FAN SPEED 4.
                debug2mqtt(" <mhi>Bit field 5 changed");
                current_Bitfield5 = (int)fromArduino.currentMHI[1];                                                      //New current bit field 5
                //VANES changed
                if ((current_Bitfield5 & 0b00110000) != current_Vanes && !current_Swing)                                 //Extract vanes bits (5-6)
                    current_Vanes = current_Bitfield5 & 0b00110000;
                    //Get VANES position
                    buf = (current_Vanes >> 4) + 1;        //Convert to vanes position [1-4]
                    client.publish(statusVanes, msg, true);                                                              //Send update to MQTT broker
                //FAN SPEED (setting 1-3) changed
                if ((current_Bitfield5 & 0b00000111) != current_Fanspeed && !current_Fanspeed4)                          //Extract fan speed bits (1-3)
                    current_Fanspeed = current_Bitfield5 & 0b00000111;
                    //Get FAN SPEED
                    buf = current_Fanspeed + 1;        //Convert to fan speed (1-3)
                    client.publish(statusFanspeed, msg, true);                                                           //Send update to MQTT broker
            //####### Bit field 6 >>> TEMPERATURE SETPOINT #######
            if (fromArduino.currentMHI[2] != current_Bitfield6)
                debug2mqtt(" <mhi>Bit field 6 changed");
                current_Bitfield6 = fromArduino.currentMHI[2];                                                           //Store new setpoint byte value for reference in next SPI frame update
                //Extract new temperature setpoint (bitfield 6)
                buf = current_Bitfield6;
                buf = bitClear(buf, 7) >> 1;        //Clear bit 8 and shift right 1 bit (= divide by 2) -> buf = temperature in degr. Celsius
                snprintf(msg, 3, "%2d", buf);
                client.publish(statusSetpoint, msg, true);                                                               //Send update to MQTT broker
                debug2mqtt(" <mhi>Setpoint changed");
      /*        Serial.println("Setpoint changed");
                Serial.print(statusSetpoint);
            //####### Bit field 7 >>> ROOM TEMPERATURE #######
            if (fromArduino.currentMHI[3] != current_Bitfield7)
                debug2mqtt(" <mhi>Bit field 7 changed");
                current_Bitfield7 = fromArduino.currentMHI[3];                                                           //Store new setpoint byte value for reference in next SPI frame update
                //Calculate current room temperature in degrees Celsius from bitfield 7 using:
                // (BF7 - 61) / 4 (note: Calibration of temperature needs to be checked further)
                int temp = (int)current_Bitfield7 - 61;
                int dec = (temp % 4) * 25;        //Decimal value (can be xx.00; xx.25; xx.50; xx.75)
                temp /= 4;        //Truncated temperature (rounded down)
                snprintf(msg, 6, "%d.%02d", temp, dec);        //Construct temperature payload string
                client.publish(statusRoomtemp, msg, true);                                                               //Send update to MQTT broker
                debug2mqtt(" <mhi>Room temperature changed");
      /*        Serial.println("Roomtemp changed");
                Serial.print(statusRoomtemp);
      }</mhi></mhi></mhi></mhi></mhi></mhi></mhi></mhi></mhi></mhi></mhi></mhi></mhi></mhi></esp></esp></esp></esp></debugoff></debugon></wifimanager></reinit></reboot></ota></ota></ota></ota></ota></char[]></typename></easytransfer.h></pubsubclient.h></arduinojson.h></wifimanager.h></arduinoota.h></wifiudp.h></esp8266webserver.h></dnsserver.h></esp8266wifi.h></fs.h>`
      Ist es normal, dass im Adapter so viele Ereignisse ankommen, auch wenn kein Client verbunden ist?
       ![536_mqtt2.png](/assets/uploads/files/536_mqtt2.png) [/i][/i][/i][/i][/i]
        dondaik
        es bringt das nachdenken über die daten menge… drei temperaturen alle 6 sekunden ( was auch xx ist ) ok ... aber 3 x das gesamte paket in der zeit wäre zu viel ( für mich ) und da wäre dann auch die frage nach dem DC ...
        ps.: prg "lese" ich später..
        wer Schreibfehler findet darf sie behalten … :-(
        Ps: Anfänger im Bereich Tinkerboard + IOBROKER !
        • coyoteC Offline
          coyoteC Offline
          coyote
          Ja das verstehe ich schon. Leider kenne ich mich zu wenig mit der Arduino Programmierung aus.
          Wäre gut super wenn du es dir mal anschauen könntest. Ich hab nur im ioBroker gesehen, dass die Raumtemperatur sich alle 6 Sekunden aktualisiert. Ich verstehe eben momentan nicht, warum es ne Stunde läuft und dann war es dass.
          Eigentlich sollten auch die ESP's sich wieder mit dem Broker verbinden, was sie auch nicht mehr machen. Im Netzwerk seh ich sie aber noch und es wird auch kein eigener Hotspot von den ESP's eröffnet.
          Laut Beschreibung des Entwicklers, sollte sich ein Hotspot eröffnen wenn kein Zugang zum WLAN vorliegt, das funktioniert auch wenn ich den ESP in meinem AP blocke. Und eigentlich sollte sich der ESP mit dem Broker wieder verbinden, wenn im WLAN eingeloggt und die MQTT Verbindung abgebrochen ist, macht er aber nicht.
          Edit: hier mal noch das zweite Sketch für den Mini pro
          MHI SPI2ESP Interface v1.0.0
          Connects to the MHI CNS connector and synchronizes to its Serial Peripheral Interface (SPI). Updates from the MHI are sent via serial to an ESP8266 running an MQTT client.
          Updates received on the ESP8266 via MQTT are sent to the Arduino over serial and injected into the SPI data frames to update the MHI.
          //#include <avr wdt.h="">        //Watchdog for software reset: not working due to bootloader bug, but does not seem necessary anyway
          #include <easytransfer.h>        //EasyTransfer v2.1 - Bill Porter: https://github.com/madsci1016/Arduino-EasyTransfer
          volatile byte state = 0;        //'State machine' in loop(): [State=0] Priority is given to SPI interrupt to collect a full 20-byte SPI data frame. No other processing is allowed to keep in sync. [State=1] Pulse clock, set new/updated frames etc.. [State=2] Check for data received from ESP via serial
          volatile char bitfield = 0;        //Bitfield position counter for sending (tx_SPIframe[]) and recceiving (rx_SPIframe[])
          byte variantnumber = 0;        //Frame variation that is currently being sent (0, 1 or 2 in frameVariant[])
          byte framenumber = 1;        //Counter for how many times a frame variation has been sent (max. = 48)
          bool updateESP = true;        //Flag to ensure that an update is send to ESP only once every (repeatFrame x 2 x 3) SPI frames (~6 secs)
          bool checksumError = false;        //Flag for checksum error in frame 2 or 47\. If two errors occur at both these positions in a single 48-frame cycle -> SPI sync lost -> resync SPI
          byte newMode     = 0;        //Temporary storage of settings received from ESP
          byte newVanes    = 0;
          byte newFanspeed = 0;
          byte newSetpoint = 0;
          const byte rx_frameSignature[3] =  { 0x6C, 0x80, 0x04 };                                                           //SPI frame start signature: first 3 bytes in a full SPI data frame. Used to sync to MHI SPI data in SPI_sync() routine. Might be different on other unit types!
          //SPI frame that is currently being sent during the SPI interrupt routine. Contains base values that will be updated after the first 48-frame cycle with values received from MHI.
          //                         Bitfield:    1     2     3     4     5     6     7     8     9    10    11    12    13    14    15    16    17    18    19    20
          volatile byte tx_SPIframe[20]   =  { 0xA9, 0x00, 0x07, 0x4C, 0x00, 0x2A, 0xFF, 0x00, 0x00, 0x40, 0x00, 0x00, 0x80, 0xFF, 0xFF, 0xFF, 0x0F, 0x04, 0x05, 0xF5 };
          volatile byte rx_SPIframe[20];        //Array to collect a single frame of SPI data received from the MHI unit
          byte rx_bitfield4_10[7];        //Array containing bitfields 4-10 from rx_SPIframe, which holds current MHI mode, vanes, fans speed, ambient temperature and setpoint
          //Alternating bitfield 10-18 variations, each successively send for 48 frames. Bit 3 in bitfield 18 functions as a clock and is 1 for 24 frames and 0 for the subsequent 24 frames. I have never seen bit fields 11-12 changing, so don't know what they are for.
          //                         Bitfield:   10    11    12    13    14    15    16    17    18
          const byte frameVariant[3][9]  {   { 0x40, 0x00, 0x00, 0x80, 0xFF, 0xFF, 0xFF, 0x0F, 0x04 },  //variant number 0
                                             { 0x80, 0x00, 0x00, 0x32, 0xD6, 0x01, 0x00, 0x0F, 0x04 },  //variant number 1
                                             { 0x80, 0x00, 0x00, 0xF1, 0xF7, 0xFF, 0xFF, 0x0F, 0x04 }   //variant number 2
          //MODE bitmasks                            Bitfield #4
          const byte modeMask[8][2]      { //     CLEAR   |    SET
                                             { 0b00100010, 0b00000000 },  //0 = Unchanged (only clear 'write' bits)
                                             { 0b00100011, 0b00000010 },  //1 = OFF
                                             { 0b00111111, 0b00110011 },  //2 = HEAT
                                             { 0b00111111, 0b00101011 },  //3 = COOL
                                             { 0b00111111, 0b00100011 },  //4 = AUTO
                                             { 0b00111111, 0b00100111 },  //5 = DRY
                                             { 0b00111111, 0b00101111 },  //6 = FAN
                                             { 0b00100011, 0b00000011 }   //7 = ON (using last mode)
          //VANES bitmasks                          Bitfield #4             Bitfield #5
          const byte vanesMask[6][4]     { //     CLEAR   |    SET        CLEAR   |    SET
                                             { 0b10000000, 0b00000000, 0b10000000, 0b00000000 },  //0 = Unchanged (only clear 'write' bits)
                                             { 0b11000000, 0b10000000, 0b10110000, 0b10000000 },  //1 = 1 (up)
                                             { 0b11000000, 0b10000000, 0b10110000, 0b10010000 },  //2 = 2
                                             { 0b11000000, 0b10000000, 0b10110000, 0b10100000 },  //3 = 3
                                             { 0b11000000, 0b10000000, 0b10110000, 0b10110000 },  //4 = 4 (down)
                                             { 0b11000000, 0b11000000, 0b10000000, 0b00000000 }   //5 = swing
          //FANSPEED bitmasks                        Bitfield #5             Bitfield #10
          const byte fanspeedMask[5][4]  { //     CLEAR   |    SET        CLEAR   |    SET
                                             { 0b00001000, 0b00000000, 0b11011000, 0b00000000 },  //0 = Unchanged (only clear 'write' bits)
                                             { 0b00001111, 0b00001000, 0b11011000, 0b00000000 },  //1 = Speed 1
                                             { 0b00001111, 0b00001001, 0b11011000, 0b00000000 },  //2 = Speed 2
                                             { 0b00001111, 0b00001010, 0b11011000, 0b00000000 },  //3 = Speed 3
                                             { 0b00001111, 0b00001010, 0b11011000, 0b00010001 }   //4 = Speed 4
          struct RECEIVE_DATA_STRUCTURE {        //Variables received from ESP
          struct SEND_DATA_STRUCTURE {        //Variable send to ESP
            byte currentMHI[8];        //Contains bitfields last received from MHI for bitfields 4-10 (holding current settings for mode, vanes, fanspeed, setpoint and ambient temperature) and a SPI sync error count
          RECEIVE_DATA_STRUCTURE  fromESP;
          SEND_DATA_STRUCTURE     toESP;
          //ROUTINES, SETUP and MAIN LOOP
          void setup (void)
            delay(7000);        //Delay to allow ESP8266 to boot
            Serial.begin (500000);
            while(Serial.available()) Serial.read();        //Empty serial read buffer from possible junk send by ESP during boot
            //wdt_enable(WDTO_8S);        //Start Watchdog Timer (WDT) to detect hang ups
            ETin.begin(details(fromESP), &Serial);        //Start the EasyTransfer library, pass in the data details and the name of the serial port
            ETout.begin(details(toESP), &Serial);
            pinMode(SCK, INPUT);
            pinMode(MISO, OUTPUT);
            SPCR = (0< <spie)|(0<<spe)|(1<<dord)|(0<<mstr)|(1<<cpol)|(1<<cpha); 1/18/19/20/configurate/spi/slave:/no/interrupts/(yet)/|/disable/hardware/lsb/first/slave/mode/sck/high/when/idle/data/valid/on/falling/edge/toesp.currentmhi[7]="0;" reset/checksum/resync/errors/spi_sync();/sync/to/master/(mosi)/wdt_reset();/watchdog/timer/}/end/of/setup/inline/bool/verify_checksum/(void)/routine/verify/a/received/frame./don't/care/pass/the/array/function,/because/it's/same/that/needs/be/checked/every/time./{/uint16_t/sum="0;" for/(int/bf="0;" </18;/bf++)/calculate/byte/frame/(sum/bytes/18)/+="rx_SPIframe[bf];" return/(rx_spiframe[18]="=" highbyte(sum)/&&/rx_spiframe[19]="=" lowbyte(sum));/msb/and/compare/with/20\./returns/true/if/is/correct./void/update_checksum/update/(byte/19)/20)./updated/by/summing/bitfield/-/tx_spiframe[18]="highByte(sum);" write/tx_spiframe[19]="lowByte(sum);" softwarereset(void)/(uint8_t/prescaler)/not/working/as/aspected/(bootloader/bug?)./revert/more/primitive/method./asm/volatile/("/jmp/0");/wdt_enable(prescaler);/start/provided/prescaler/while(1)/{}/spi_sync/spcr/&="~(1<<SPIE);" turn/off/during/syncing/memcpy(&tx_spiframe[9],/&framevariant[0][0],/9);/copy/(part/of)/next/current/sending/upcoming/clock/cycle/update_checksum();/recalculate/tx_spiframe/int/resyncattempts="0;" count/number/attempts./resyncing/doesn't/work="">restart system
            resync:
            //Finds the start of the first complete frame by looking for a signature.
            //When the first SPI transfer is started, the data sometimes starts in the middle of a frame
            //or out of sync with the SPI clock. This routine scans for the first 3 bytes as given
            //in rx_frameSignature[]. It then reads and discards the next 17 bytes before handing further
            //SPI data exchange to the interrupt routine ISR(SPI_STC_vect).
            //Serial.print("Syncing SPI to master...");
            int hits = 0;        //Number of times consecutive signature bytes have been encountered
            int cycle = 0;        //Stores number of bytes checked for signature. If too high -> SPI out of sync?
            byte r;        //Used to store read byte
            SPCR &= ~(1< <spe); 15/turn/off/spi/hardware/delay(15);/for/resyncs:/if/sync/is/lost/because/data/exhange/shifted/out/of/phase/a/few/bits,/then/waiting/msecs/should/end/up/somewhere/between/two/frames/-="">resync
            SPCR |= (1< <spe); turn/spi/hardware/back/on,/hopefully/in/sync/while(1)/{/if/(cycle++="">25)        //If scan takes >25 SPI bytes -> SPI CLK out-of-sync -> reset SPI and try again
                    if (resyncAttempts > 2)        //Too many resync attempts -> restart system
                        resyncAttempts = 0;
                        //Serial.println("Too many SPI sync errors!");
                        //Serial.println("Restarting system...");
                        delay(500);
                        softwareReset();    //softwareReset(WDTO_60MS);                                                      //Restart using Watchdog Timer
                        delay(5000);
                    //Serial.println("SPI sync error!");
                    //Serial.println("Restarting SPI hardware...");
                    cycle = 0;        //Signature took too long -> SPI bytes bit-shifted? -> 1st try = restart SPI
                    ++resyncAttempts;        //Track number of resync attempts
                    goto resync;        //Restart signature scan. Not very elegant, but it works.
                hits = 0;
                do        //Scan for 3-byte signature
                    SPDR = 0;        //Send back zero for each read byte
                    while(!(SPSR & (1< <spif))) 3/{};/wait/for/new/byte/in/spi/data/register/r="SPDR;" read/from/}/while/(r="=" rx_framesignature[hits++]/&/hits/</3);/if/(hits="=" 3)/break;/a/row/-="">signature found!
            for (int t = 0; t < 17; t++)        //Discard the next 17 bytes after signature to skip to the start byte of the next frame
                SPDR = 0;
                while(!(SPSR & (1< <spif))) {};/r="SPDR;" }/reset/counters/and/state/for/resyncs/variantnumber="0;" framenumber="1;" bitfield="0;" checksumerror="false;" spdr="tx_SPIframe[0];" prepare/spi/data/register/(spdr)/to/send/1st/byte/of/frame/on/interrupt/serial.println("synced!");/spcr/|="(1<<SPIE);" turn/interrupts/end/routine/spi_sync/isr/(spi_stc_vect)/{/routine:/this/is/triggered/when/a/read/write/has/just/occurred./the/that/needs/be/sent/should/already/in/called./therefore/done/before/ends./rx_spiframe[bitfield]="SPDR;" new/from/(mosi)./previously/written/simultaneously/(miso)./if/(bitfield="=" 19)/completely/sent,/switch/next/(processing/frames,/sending/reveiving/esp)/else/increase/position/counter/setup/spi_stc_vect/void/loop/(void)/wdt_reset();/watchdog/timer./readingframe/takes/too/long/-="">SPI signal lost -> restart system and resync
            switch (state)
                case 0:        //<<<state 0="">>> Do nothing (wait until a complete SPI frame has been send/received)
                  break;
                case 1:        //<<<state 1="">>> Complete frame send/received -> decide what to do based on current frame number (out of 48)
                  switch (framenumber)
                      case 2:        // Verify checksum on SPI frame that was just received and send to ESP8266 if correct
                        if (verify_checksum())        //Verify checksum
                            if (variantnumber == 1 || updateESP)                                                             //Send updated MHI settings to ESP9288 in the 10th SPI frame repeat of frame 2 out of 3 (every ~6 seconds) or immediately after a new setting was sent to the MHI
                                memcpy(&toESP.currentMHI, &rx_SPIframe[3], 7);                                               //Copy bitfields 4-10 from the most recent MHI SPI frame to new array for sending to ESP
                                ETout.sendData();        //Send to ESP using EasyTransfer.
                                updateESP = false;        //Uncheck flag to send update only once
                        else
                            if (checksumError)        //If true then the previous checksum at frame 47 was also wrong -> SPI sync lost? -> resync
                                toESP.currentMHI[7]++;        //Count resyncs triggered by consecutive checksum errors and send to ESP for debugging
                                updateESP = true; SPI_sync(); return;
                            checksumError = true;
                            updateESP     = true;
                        state = 0;
                        break;        //Start from beginning of loop() and wait for next complete SPI frame
                      case 24:        // Current frame variation has been sent 24 times -> clear clock bit in bit field 18 for the next 24 frames
                        bitClear(tx_SPIframe[17], 2);        //Clear clock bit 3 in bitfield 18-> update checksum and resend for 24 cycles
                        update_checksum();        //Recalculate checksum of tx_SPIframe
                        state = 0;
                      case 47:        // Collect the most recent bit fields 4-10 for constructing an updated tx_SPIframe after the upcoming frame (48)
                            memcpy(&rx_bitfield4_10, &rx_SPIframe[3], 7);                                                    //Get bitfields 4-10 from the last MHI SPI frame to use for the upcoming tx_SPIframe update
                        else
                            if (checksumError)        //If true then the previous checksum at frame 2 was also wrong -> SPI sync lost? -> resync
                        state = 0;
                        break;
                      case 48:        // Current frame variation has been send 48 times -> construct next frame variant using most recent bit fields 4-10 collected in frame 47
                        framenumber = 0;        //Reset repeat frame counter
                        if (++variantnumber > 2) variantnumber = 0;                                                          //Increase frame counter -> test if all 3 frames sent -> restart with frame 1
                        memcpy(&tx_SPIframe[9], &frameVariant[variantnumber][0], 9);                                         //Copy (part of) the next frame to the current frame for sending on the upcoming bitfield 18 clock cycle
                        //******************* CONSTRUCTION OF UPDATED BIT FIELDS *******************
                        //Set 'state change' bits and 'write' bits if MQTT update received from ESP
                        //otherwise only clear 'write' bits using masks from the xxxMask[0][] arrays
                        //Bitfields 4, 5, 6, 10 are based on the last received MHI values (frame 47)
                        tx_SPIframe[3]  =  rx_bitfield4_10[0] & ~modeMask[newMode][0];                                       //Clear mode bits (bitfield 4)
                        tx_SPIframe[3] |=  modeMask[newMode][1];                                                             //Set mode bits
                        tx_SPIframe[3] &= ~vanesMask[newVanes][0];                                                           //Clear vanes bits (bitfield 4)
                        tx_SPIframe[3] |=  vanesMask[newVanes][1];                                                           //Set vanes bits
                        tx_SPIframe[4]  =  rx_bitfield4_10[1] & ~vanesMask[newVanes][2];                                     //Clear vanes bits (bitfield 5)
                        tx_SPIframe[4] |=  vanesMask[newVanes][3];                                                           //Set vanes bits
                        tx_SPIframe[4] &= ~fanspeedMask[newFanspeed][0];                                                     //Clear fanspeed bits (bitfield 5)
                        tx_SPIframe[4] |=  fanspeedMask[newFanspeed][1];                                                     //Set fanspeed bits
                        bitWrite(rx_bitfield4_10[6], 0, bitRead(rx_bitfield4_10[6], 6));                                     //Copy bit 7 from rx_SPIframe[9] to bit 1 as the status bits for fan speed 4 appear to be swapped (!?) between MISO and MOSI
                        tx_SPIframe[9] &=  ~0b00111111;        //Clear bits 1-6 and keep variant bits 7-8
                        tx_SPIframe[9] |=  (rx_bitfield4_10[6] & ~fanspeedMask[newFanspeed][2]);
                        tx_SPIframe[9] |=  fanspeedMask[newFanspeed][3];                                                     //Set fanspeed bits
                        //Construct setpoint bitfield (#6) from last MHI value or MQTT update
                        if (newSetpoint == 0)
                            tx_SPIframe[5] = rx_bitfield4_10[2] & ~0b10000000;                                               //Copy last received MHI setpoint and clear the write bit
                        else
                            tx_SPIframe[5] = (newSetpoint << 1) | 0b10000000;                                                //MQTT updated setpoint in degrees Celsius -> shift 1 bit left and set write bit (#8)
                        //Reset all state changes
                        newMode     = 0;
                        newVanes    = 0;
                        newFanspeed = 0;
                        newSetpoint = 0;
                        state = 0;
                        break;        //Start from beginning of loop() and wait for next complete SPI frame.
                      default:
                        state = 2;        //Use time (~30 ms) until next frame for receiving commands from ESP
                  framenumber++;        //Increase repeat counter to keep track of the number of times the current frame has been sent
                case 2:        //<<<state 2="">>> Check once if data received from ESP via serial (EasyTransfer)
                      delay(1);        //Delay to allow fromESP.xxx to be updated
                      if (fromESP.mode == 64)   softwareReset();  //softwareReset(WDTO_60MS);                                //Requested reset by ESP8266 via MQTT service topic (bitfield = 32 received)
                      //Store new commands received from ESP in newXXX, but only if not equal to zero
                      //to prevent cancellation of previous commands that have not been send yet
                      newMode     = (fromESP.mode > 0) ? fromESP.mode : newMode;
                      newVanes    = (fromESP.vanes > 0) ? fromESP.vanes : newVanes;
                      newFanspeed = (fromESP.fanspeed > 0) ? fromESP.fanspeed : newFanspeed;
                      newSetpoint = (fromESP.setpoint > 0) ? fromESP.setpoint : newSetpoint;
                      updateESP = true;        //Flag for MHI status feedback: get an MHI update after frame number 2 and send it to the ESP for updating status of the MQTT topics
                  state = 0;        //Check for serial data once between every SPI frame (approx. every 40 ms). If this is done continuously in the loop and/or after the calculations done on frames 2, 24, 47, 48, then SPI sync can be lost.
                  break;
              }  //End switch..case
          }    //End of loop</state></state></state></spif)))></spif)))></spe);></spe);></spie)|(0<<spe)|(1<<dord)|(0<<mstr)|(1<<cpol)|(1<<cpha);></easytransfer.h></avr>
          • coyoteC Offline
            coyoteC Offline
            coyote
            Ähm, könnte die Maske vllt schon mein Problem sein? Befeuert der Broker dann die Clients mit allem was er kennt?
            Habe jetzt mal die Maske auf mqtt.0.* geändert, heute Mittag dann ein neuer Versuch
              dondaik
              so, wie ich es auf die schnelle sehe wird alles "bei änderung" gesendet …. und dann ist es schon etwas heftig ( aus meiner sicht )
              ggf mal einen slave - iobroker nur mit mqtt für die klimageräte aufsetzten und testen ...
              • coyoteC Offline
                coyoteC Offline
                coyote
                Genau, das hab ich mir auch gerade gedacht. Das erklärt auch die hunderte von logeinträge von mqtt, wenn er auf debug steht
                • coyoteC Offline
                  coyoteC Offline
                  coyote
                  @dondaik:
                  ggf mal einen slave - iobroker nur mit mqtt für die klimageräte aufsetzten und testen … `
                  Ich probiere später mal mit der Maske, da ich sonst eh momentan nichts am MQTT Adapter dran hab.
                  Ja ok, könnte ich auch noch ausprobieren, einfach mal nen Raspi oder ne VM auf dem NUC als Slave
                  • coyoteC Offline
                    coyoteC Offline
                    coyote
                    Habe gerade nochmal von vorne angefangen.
                    So wie es aussieht hat er irgendwann den MQTT Adapter abgeschossen und dann verbinden sich die Clients nicht mehr, warum sie sich nicht mehr verbinden weiß ich leider nicht.
                    hier ein Teil des Logs bis zum Abschuss:
                    2019-02-08 17:37:46.815  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":"MHI2MQTT connected to MQTT broker at 192.168.66.68:1883","ack":true,"ts":1549643866804,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866804}
                    2019-02-08 17:37:46.822  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 293
                    2019-02-08 17:37:46.823  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 292
                    2019-02-08 17:37:46.823  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 291
                    2019-02-08 17:37:46.823  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 290
                    2019-02-08 17:37:46.824  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 289
                    2019-02-08 17:37:46.824  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 288
                    2019-02-08 17:37:46.824  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 295
                    2019-02-08 17:37:46.824  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 294
                    2019-02-08 17:37:46.827  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 293
                    2019-02-08 17:37:46.827  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 292
                    2019-02-08 17:37:46.827  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 295
                    2019-02-08 17:37:46.827  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 294
                    2019-02-08 17:37:46.828  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 293
                    2019-02-08 17:37:46.828  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 292
                    2019-02-08 17:37:46.831  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 291
                    2019-02-08 17:37:46.832  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 290
                    2019-02-08 17:37:46.832  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 289
                    2019-02-08 17:37:46.832  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 288
                    2019-02-08 17:37:46.832  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 295
                    2019-02-08 17:37:46.832  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 294
                    2019-02-08 17:37:46.840  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":21.75,"ack":true,"ts":1549643866816,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866816}
                    2019-02-08 17:37:46.841  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":21.75,"ack":true,"ts":1549643866816,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866816}
                    2019-02-08 17:37:46.848  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549643866818,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866818}
                    2019-02-08 17:37:46.850  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549643866818,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866818}
                    2019-02-08 17:37:46.850  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549643866818,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866818}
                    2019-02-08 17:37:46.850  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549643866820,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866818}
                    2019-02-08 17:37:46.857  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549643866848,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866818}
                    2019-02-08 17:37:46.875  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549643866852,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866818}
                    2019-02-08 17:37:46.875  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549643866852,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866818}
                    2019-02-08 17:37:46.875  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549643866853,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866818}
                    2019-02-08 17:37:46.881  - [34mdebug[39m: mqtt.0 Create object for topic: Kinderzimmer/Kli@$@#@"@[ID: mqtt.0.Kinderzimmer.Kli@$@#@"@]
                    2019-02-08 17:37:46.881  - [33mwarn[39m: mqtt.0 Used invalid characters: mqtt.0.Kinderzimmer.Kli@$@#@"@ changed to mqtt.0.Kinderzimmer.Kli@$@#@_@
                    2019-02-08 17:37:46.895  - [33mwarn[39m: mqtt.0 Used invalid characters: mqtt.0.Kinderzimmer.Kli@$@#@"@ changed to mqtt.0.Kinderzimmer.Kli@$@#@_@
                    2019-02-08 17:37:46.900  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Kli@$@#@_@: {"val":"\u0001!@\u0002\u0001 @\u0002\u0001'@\u0002\u0001&1>\u0000\u001eKinderzimmer","ack":true,"ts":1549643866897,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866897}
                    2019-02-08 17:37:46.900  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Kli@$@#@_@: {"val":"\u0001!@\u0002\u0001 @\u0002\u0001'@\u0002\u0001&1>\u0000\u001eKinderzimmer","ack":true,"ts":1549643866897,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549643866897}
                    2019-02-08 17:37:46.908  - [34mdebug[39m: mqtt.0 Client [MHI Schlafzimmer] Resend message topic: Schlafzimmer/Klimaanlage/service, payload: null
                    2019-02-08 17:37:46.919  - [34mdebug[39m: mqtt.0 Client [MHI Schlafzimmer] Resend message topic: Schlafzimmer/Klimaanlage/Fanspeed, payload: null
                    2019-02-08 17:37:46.929  - [34mdebug[39m: mqtt.0 Client [MHI Schlafzimmer] Resend message topic: Schlafzimmer/Klimaanlage/Vanes, payload: null
                    2019-02-08 17:37:46.940  - [34mdebug[39m: mqtt.0 Client [MHI Schlafzimmer] Resend message topic: Schlafzimmer/Klimaanlage/State, payload: null
                    2019-02-08 17:37:46.951  - [34mdebug[39m: mqtt.0 Client [MHI Schlafzimmer] Resend message topic: Schlafzimmer/Klimaanlage/service, payload: null
                    2019-02-08 17:37:48.520  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 26989
                    2019-02-08 17:37:48.523  - [31merror[39m: mqtt.0 uncaught exception: Cannot read property 'topic' of undefined
                    2019-02-08 17:37:48.524  - [31merror[39m: mqtt.0 TypeError: Cannot read property 'topic' of undefined
                        at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:406:32)
                        at Connection.client.on.packet (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:820:21)
                        at emitOne (events.js:116:13)
                        at Connection.emit (events.js:211:7)
                        at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:10:8)
                        at addChunk (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream/lib/_stream_readable.js:291:12)
                        at readableAddChunk (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream/lib/_stream_readable.js:278:11)
                        at Connection.Readable.push (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream/lib/_stream_readable.js:245:10)
                    2019-02-08 17:37:48.524  - [34mdebug[39m: mqtt.0 Old client MHI Kinderzimmer with secret 1549643217875_4556 sends subscribe. Ignore! Actual secret is 1549643836068_3879
                    2019-02-08 17:37:49.026  - [32minfo[39m: mqtt.0 terminating
                    2019-02-08 17:37:49.046  - [31merror[39m: Caught by controller[0]: TypeError: Cannot read property 'topic' of undefined
                    2019-02-08 17:37:49.047  - [31merror[39m: Caught by controller[0]:     at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:406:32)
                    2019-02-08 17:37:49.047  - [31merror[39m: Caught by controller[0]:     at Connection.client.on.packet (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:820:21)
                    2019-02-08 17:37:49.047  - [31merror[39m: Caught by controller[0]:     at emitOne (events.js:116:13)
                    2019-02-08 17:37:49.047  - [31merror[39m: Caught by controller[0]:     at Connection.emit (events.js:211:7)
                    2019-02-08 17:37:49.047  - [31merror[39m: Caught by controller[0]:     at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:10:8)
                    2019-02-08 17:37:49.047  - [31merror[39m: Caught by controller[0]:     at addChunk (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream/lib/_stream_readable.js:291:12)
                    2019-02-08 17:37:49.047  - [31merror[39m: Caught by controller[0]:     at readableAddChunk (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream/lib/_stream_readable.js:278:11)
                    2019-02-08 17:37:49.047  - [31merror[39m: Caught by controller[0]:     at Connection.Readable.push (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream/lib/_stream_readable.js:245:10)
                    2019-02-08 17:37:49.047  - [31merror[39m: host.debian instance system.adapter.mqtt.0 terminated with code 0 (OK)
                    2019-02-08 17:37:49.047  - [32minfo[39m: host.debian Restart adapter system.adapter.mqtt.0 because enabled
                    Jetzt sieht es so aus:
                    mqtt.0	2019-02-08 19:44:58.723	debug	onStateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20.25,"ack":true,"ts":1549651498720,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651498720}
                    mqtt.0	2019-02-08 19:44:58.722	debug	stateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20.25,"ack":true,"ts":1549651498720,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651498720}
                    mqtt.0	2019-02-08 19:44:57.012	debug	Client [MHI Kinderzimmer] pingreq
                    mqtt.0	2019-02-08 19:44:53.069	debug	onStateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":19.75,"ack":true,"ts":1549651493066,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651493066}
                    mqtt.0	2019-02-08 19:44:53.069	debug	stateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":19.75,"ack":true,"ts":1549651493066,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651493066}
                    mqtt.0	2019-02-08 19:44:52.738	debug	onStateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.5,"ack":true,"ts":1549651492736,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651492736}
                    mqtt.0	2019-02-08 19:44:52.738	debug	stateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.5,"ack":true,"ts":1549651492736,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651492736}
                    mqtt.0	2019-02-08 19:44:47.935	debug	Client [MHI Wintergarten] pingreq
                    mqtt.0	2019-02-08 19:44:47.411	debug	onStateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20,"ack":true,"ts":1549651487408,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651487408}
                    mqtt.0	2019-02-08 19:44:47.411	debug	stateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20,"ack":true,"ts":1549651487408,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651487408}
                    mqtt.0	2019-02-08 19:44:47.012	debug	onStateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.75,"ack":true,"ts":1549651487009,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651487009}
                    mqtt.0	2019-02-08 19:44:47.012	debug	stateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.75,"ack":true,"ts":1549651487009,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651487009}
                    mqtt.0	2019-02-08 19:44:41.851	debug	Client [MHI Kinderzimmer] pingreq
                    Soweit so gut, mal abwarten wie lange es so läuft.
                    @dondaik
                    Du kannst mir nicht zufällig erklären, warum die Clients nach dem disconnect sich nicht mehr verbinden? Das sollten sie laut Anleitung eigentlich tun. Mit dem WLAN AP sind sie immer noch verbunden.
                    Werde morgen das Schlafzimmer auch nochmal einbinden. Mal schauen wie lange Wintergarten und Kinderzimmer verbunden bleiben….
                    • coyoteC Offline
                      coyoteC Offline
                      coyote
                      Leider gleiches Spiel, nach ca. 2 Stunden, MQTT Adapter abgeschossen.
                      Hier mal das Log dazu. Seltsam, dass der ESP vom Wintergarten wohl einwandfrei funktioniert.
                      `2019-02-08 21:59:47.203  - [34mdebug[39m: mqtt.0 Old client MHI Kinderzimmer with secret 1549658282049_8121 sends pingreq. Ignore! Actual secret is 1549659558610_1868
                      2019-02-08 21:59:47.203  - [34mdebug[39m: mqtt.0 Old client MHI Kinderzimmer with secret 1549658282049_8121 sends publish. Ignore! Actual secret is 1549659558610_1868
                      2019-02-08 21:59:47.203  - [34mdebug[39m: mqtt.0 Old client MHI Kinderzimmer with secret 1549658282049_8121 sends puback. Ignore! Actual secret is 1549659558610_1868
                      2019-02-08 21:59:47.204  - [34mdebug[39m: mqtt.0 Old client MHI Kinderzimmer with secret 1549658282049_8121 sends puback. Ignore! Actual secret is 1549659558610_1868
                      2019-02-08 21:59:47.204  - [34mdebug[39m: mqtt.0 Old client MHI Kinderzimmer with secret 1549658282049_8121 sends publish. Ignore! Actual secret is 1549659558610_1868
                      2019-02-08 21:59:47.635  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":19.5,"ack":true,"ts":1549659587633,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659587633}
                      2019-02-08 21:59:47.635  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":19.5,"ack":true,"ts":1549659587633,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659587633}
                      2019-02-08 21:59:47.647  - [34mdebug[39m: mqtt.0 Client [MHI Wintergarten]  pingreq
                      2019-02-08 21:59:48.012  - [34mdebug[39m: mqtt.0 Client [MHI Kinderzimmer] Resend message topic: Kinderzimmer/Klimaanlage/State, payload: null
                      2019-02-08 21:59:48.023  - [34mdebug[39m: mqtt.0 Client [MHI Kinderzimmer] Resend message topic: Kinderzimmer/Klimaanlage/Setpoint, payload: null
                      2019-02-08 21:59:49.276  - [32minfo[39m: mqtt.0 Client [MHI Kinderzimmer] subscribes on "mqtt.0.Kinderzimmer.Klimaanlage.State"
                      2019-02-08 21:59:49.276  - [32minfo[39m: mqtt.0 Client [MHI Kinderzimmer] publishOnSubscribe
                      2019-02-08 21:59:49.276  - [32minfo[39m: mqtt.0 Client [MHI Kinderzimmer] subscribes on "mqtt.0.Kinderzimmer.Klimaanlage.Vanes"
                      2019-02-08 21:59:49.277  - [32minfo[39m: mqtt.0 Client [MHI Kinderzimmer] subscribes on "mqtt.0.Kinderzimmer.Klimaanlage.Fanspeed"
                      2019-02-08 21:59:49.277  - [32minfo[39m: mqtt.0 Client [MHI Kinderzimmer] publishOnSubscribe
                      2019-02-08 21:59:49.277  - [32minfo[39m: mqtt.0 Client [MHI Kinderzimmer] subscribes on "mqtt.0.Kinderzimmer.Klimaanlage.service"
                      2019-02-08 21:59:49.280  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":"MHI2MQTT connected to MQTT broker at 192.168.66.68:1883","ack":true,"ts":1549659589278,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659552355}
                      2019-02-08 21:59:49.282  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 93
                      2019-02-08 21:59:49.282  - [34mdebug[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for MHI Kinderzimmer message ID: 88
                      2019-02-08 21:59:49.282  - [34mdebug[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for MHI Kinderzimmer message ID: 89
                      2019-02-08 21:59:49.282  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 90
                      2019-02-08 21:59:49.282  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 91
                      2019-02-08 21:59:49.283  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 92
                      2019-02-08 21:59:49.283  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 93
                      2019-02-08 21:59:49.284  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 93
                      2019-02-08 21:59:49.284  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 92
                      2019-02-08 21:59:49.284  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 91
                      2019-02-08 21:59:49.284  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 90
                      2019-02-08 21:59:49.284  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 89
                      2019-02-08 21:59:49.284  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 88
                      2019-02-08 21:59:49.285  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 92
                      2019-02-08 21:59:49.285  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 91
                      2019-02-08 21:59:49.285  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 90
                      2019-02-08 21:59:49.285  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 89
                      2019-02-08 21:59:49.285  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 88
                      2019-02-08 21:59:49.286  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 93
                      2019-02-08 21:59:49.287  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 92
                      2019-02-08 21:59:49.287  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 91
                      2019-02-08 21:59:49.287  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 90
                      2019-02-08 21:59:49.287  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 93
                      2019-02-08 21:59:49.287  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 89
                      2019-02-08 21:59:49.288  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 88
                      2019-02-08 21:59:49.288  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 93
                      2019-02-08 21:59:49.294  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549659589291,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589291}
                      2019-02-08 21:59:49.294  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549659589291,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589291}
                      2019-02-08 21:59:49.306  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.25,"ack":true,"ts":1549659589292,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589292}
                      2019-02-08 21:59:49.306  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.25,"ack":true,"ts":1549659589292,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589292}
                      2019-02-08 21:59:49.306  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549659589293,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589291}
                      2019-02-08 21:59:49.306  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549659589293,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589291}
                      2019-02-08 21:59:49.306  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549659589294,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589291}
                      2019-02-08 21:59:49.329  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 92
                      2019-02-08 21:59:49.329  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 91
                      2019-02-08 21:59:49.331  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 90
                      2019-02-08 21:59:49.331  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 89
                      2019-02-08 21:59:49.331  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 88
                      2019-02-08 21:59:49.331  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 93
                      2019-02-08 21:59:49.331  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 92
                      2019-02-08 21:59:49.331  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 91
                      2019-02-08 21:59:49.332  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 92
                      2019-02-08 21:59:49.332  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 91
                      2019-02-08 21:59:49.332  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 90
                      2019-02-08 21:59:49.332  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 89
                      2019-02-08 21:59:49.332  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 88
                      2019-02-08 21:59:49.332  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received puback for unknown message ID: 93
                      2019-02-08 21:59:49.333  - [33mwarn[39m: mqtt.0 Client [MHI Kinderzimmer] Received pubcomp for unknown message ID: 28527
                      2019-02-08 21:59:49.336  - [31merror[39m: mqtt.0 uncaught exception: Cannot read property 'topic' of undefined
                      2019-02-08 21:59:49.336  - [31merror[39m: mqtt.0 TypeError: Cannot read property 'topic' of undefined
                      2019-02-08 21:59:49.338  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549659589329,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589291}
                      2019-02-08 21:59:49.339  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.debug: {"val":" << Unknown service command >>","ack":true,"ts":1549659589329,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589291}
                      2019-02-08 21:59:49.344  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.5,"ack":true,"ts":1549659589340,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589340}
                      2019-02-08 21:59:49.344  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.5,"ack":true,"ts":1549659589340,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549659589340}
                      2019-02-08 21:59:49.354  - [34mdebug[39m: mqtt.0 Create object for topic: Kinderzimmer/Klimaanlage/d1.[/code]`
                      So sah es aus, bevor er mit dem payload null (was auch immer das heißt angefangen hat.
                      `~~[code]~~2019-02-08 19:48:03.022  - [34mdebug[39m: mqtt.0 Client [MHI Wintergarten]  pingreq
                      2019-02-08 19:48:05.484  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20.5,"ack":true,"ts":1549651685483,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651685483}
                      2019-02-08 19:48:05.484  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20.5,"ack":true,"ts":1549651685483,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651685483}
                      2019-02-08 19:48:11.150  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20.25,"ack":true,"ts":1549651691148,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651691148}
                      2019-02-08 19:48:11.150  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20.25,"ack":true,"ts":1549651691148,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651691148}
                      2019-02-08 19:48:12.376  - [34mdebug[39m: mqtt.0 Client [MHI Kinderzimmer]  pingreq
                      2019-02-08 19:48:18.027  - [34mdebug[39m: mqtt.0 Client [MHI Wintergarten]  pingreq
                      2019-02-08 19:48:22.468  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20,"ack":true,"ts":1549651702467,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651702467}
                      2019-02-08 19:48:22.468  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Wintergarten.Klimaanlage.statusRoomtemp: {"val":20,"ack":true,"ts":1549651702467,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651702467}
                      2019-02-08 19:48:25.019  - [34mdebug[39m: mqtt.0 stateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.75,"ack":true,"ts":1549651705018,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651705018}
                      2019-02-08 19:48:25.019  - [34mdebug[39m: mqtt.0 onStateChange mqtt.0.Kinderzimmer.Klimaanlage.statusRoomtemp: {"val":22.75,"ack":true,"ts":1549651705018,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1549651705018}
                      2019-02-08 19:48:27.413  - [34mdebug[39m: mqtt.0 Client [MHI Kinderzimmer]  pingreq[/code]`
                      Jemand ne Idee wie ich hier weiter komme?
                      • G Offline
                        gutgut30
                        Hast du die Nummer stabil zum Laufen gebracht? Also ich bekomme es nicht hin, habe ständig Geistereinträge im iobroker usw.
                        coyoteC 1 Antwort Letzte Antwort
                        • G gutgut30
                          coyoteC Offline
                          coyoteC Offline
                          coyote
                          @gutgut30 meinst du jetzt allgemein mit MQTT oder das Klimaanlagen Projekt?
                          Ich nutze mittlerweile diese Version für die Klimaanlage: https://github.com/absalom-muc/MHI-AC-Ctrl
                          Da läuft alles einwandfrei.
                          G ThatsITT 2 Antworten Letzte Antwort
                          • coyoteC coyote
                            gutgut30
                            @coyote Okay, wird auch mein nächster Step sein. Klingt auf jeden Fall stabiler :)
                            • G gutgut30
                              coyoteC Offline
                              coyoteC Offline
                              coyote
                              @gutgut30 genau, läuft bei mir jetzt so weit Anfang des Jahres und hatte bisher keinerlei Abbrüche oder Geisterdatenpunkte.
                              Aber ich muss dann auch erst Mal den Sommer abwarten, wenn die Geräte richtig in Betrieb sind.
                              • coyoteC coyote
                                ThatsITT Offline
                                ThatsITT Offline
                                ThatsIT
                                @coyote Hallo, ich steuere mit ioBroker meine Homematic IP Geräte und Google minis. Nun würde ich gerne auch meine MHI, die ich über ein Wi-Fi-Modul von AirConWithMe.com / IntesisHome.com eingebunden habe, steuern können. Anscheinend geht das nur mit MQTT. Damit habe ich aber überhaupt keine Erfahrung. Könntest du mir sagen, wie du dein Klimaanlagen Projekt umgesetzt hast? Wie bekomme ich die MHI mit MQTT verbunden?
                                • ThatsITT ThatsIT
                                  coyoteC Offline
                                  coyoteC Offline
                                  coyote
                                  @ThatsIT ich habe ja das Projekt aus dem obigen GitHub Link umgesetzt. Da wird die MQTT Verbindung über das arduino Programm hergestellt. Wie das mit deinen WiFi Modul funktioniert, weiß ich leider nicht.
