  4. Bitte Hilfe - ioBroker extrem instabil (gelöst)
53 Beiträge 6 Kommentatoren 7.9k Aufrufe 2 Beobachtet
    speedy
    werde mich bemühen, leider alles nicht so einfach, ist ein headless system…
    SSD Info habe ich, nur leider sagt mir das nicht wirklich etwas :(
    root@pve:~# smartctl -a /dev/sda
    smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.15.18-9-pve] (local build)
    Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
    === START OF INFORMATION SECTION ===
    Model Family:     SandForce Driven SSDs
    Device Model:     KINGSTON SMS200S3120G
    Serial Number:    50026B7243007DD7
    LU WWN Device Id: 5 0026b7 243007dd7
    Firmware Version: 524ABBF0
    User Capacity:    120,034,123,776 bytes [120 GB]
    Sector Size:      512 bytes logical/physical
    Rotation Rate:    Solid State Device
    Device is:        In smartctl database [for details use: -P show]
    ATA Version is:   ATA8-ACS, ACS-2 T13/2015-D revision 3
    SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
    Local Time is:    Sun Feb  3 12:38:18 2019 CET
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    General SMART Values:
    Offline data collection status:  (0x02) Offline data collection activity
                                            was completed without error.
                                            Auto Offline Data Collection: Disabled.
    Self-test execution status:      (   0) The previous self-test routine completed
                                            without error or no self-test has ever
                                            been run.
    Total time to complete Offline
    data collection:                (    0) seconds.
    capabilities:                    (0x79) SMART execute Offline immediate.
                                            No Auto Offline data collection support.
                                            Suspend Offline collection upon new
                                            command.
                                            Offline surface scan supported.
                                            Self-test supported.
                                            Conveyance Self-test supported.
                                            Selective Self-test supported.
    SMART capabilities:            (0x0003) Saves SMART data before entering
                                            power-saving mode.
                                            Supports SMART auto save timer.
    Error logging capability:        (0x01) Error logging supported.
                                            General Purpose Logging supported.
    Short self-test routine
    recommended polling time:        (   1) minutes.
    Extended self-test routine
    recommended polling time:        (  36) minutes.
    Conveyance self-test routine
    recommended polling time:        (   2) minutes.
    SCT capabilities:              (0x0025) SCT Status supported.
                                            SCT Data Table supported.
    SMART Attributes Data Structure revision number: 10
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
      1 Raw_Read_Error_Rate     0x0033   095   095   050    Pre-fail  Always       -       0/8330866
      5 Retired_Block_Count     0x0033   100   100   003    Pre-fail  Always       -       0
      9 Power_On_Hours_and_Msec 0x0032   094   094   000    Old_age   Always       -       5813h+21m+08.360s
     12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       118
    171 Program_Fail_Count      0x000a   000   000   000    Old_age   Always       -       0
    172 Erase_Fail_Count        0x0032   000   000   000    Old_age   Always       -       0
    174 Unexpect_Power_Loss_Ct  0x0030   000   000   000    Old_age   Offline      -       56
    177 Wear_Range_Delta        0x0000   000   000   000    Old_age   Offline      -       0
    181 Program_Fail_Count      0x000a   000   000   000    Old_age   Always       -       0
    182 Erase_Fail_Count        0x0032   000   000   000    Old_age   Always       -       0
    187 Reported_Uncorrect      0x0012   100   100   000    Old_age   Always       -       0
    194 Temperature_Celsius     0x0022   037   056   000    Old_age   Always       -       37 (Min/Max 20/56)
    195 ECC_Uncorr_Error_Count  0x001c   120   120   000    Old_age   Offline      -       0/8330866
    196 Reallocated_Event_Count 0x0033   100   100   003    Pre-fail  Always       -       0
    201 Unc_Soft_Read_Err_Rate  0x001c   120   120   000    Old_age   Offline      -       0/8330866
    204 Soft_ECC_Correct_Rate   0x001c   120   120   000    Old_age   Offline      -       0/8330866
    230 Life_Curve_Status       0x0013   100   100   000    Pre-fail  Always       -       100
    231 SSD_Life_Left           0x0013   100   100   010    Pre-fail  Always       -       0
    233 SandForce_Internal      0x0032   000   000   000    Old_age   Always       -       1020
    234 SandForce_Internal      0x0032   000   000   000    Old_age   Always       -       473
    241 Lifetime_Writes_GiB     0x0032   000   000   000    Old_age   Always       -       473
    242 Lifetime_Reads_GiB      0x0032   000   000   000    Old_age   Always       -       512
    SMART Error Log not supported
    SMART Self-test Log not supported
    SMART Selective self-test log data structure revision number 1
     SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
        1        0        0  Not_testing
        2        0        0  Not_testing
        3        0        0  Not_testing
        4        0        0  Not_testing
        5        0        0  Not_testing
    Selective self-test flags (0x0):
      After scanning selected spans, do NOT read-scan remainder of disk.
    If Selective self-test is pending on power-up, resume after 0 minute delay.
    root@pve:~#
    ioBroker - Neuling ;)
    • StabilostickS Offline
      Stabilostick
      Alt ist die SSD nicht. 242 Tage bislang gelaufen. 0 Errors. Sieht doch erst mal gut aus?
        Ich glaube die habe ich auch irgendwo verbaut. In meinen ioBroker-Installationen finde ich sie jetzt nicht. Kann sein, dass sie in einem Netbook ist.
        Habe damit jedenfalls bisher keine Probleme gehabt.
        Allerdings schon mit einem NUC - da war das Anschlusskabel zur SSD defekt.
          speedy
          OK, dann wird es vermutlich die SSD nicht sein.
          SSD Kabel: sporadische Probleme durch evtl. Wärmeentwicklung wären ja möglich
          aber nach dem Neustart von eben, und den deaktivierten Adaptern läuft er wieder
          ich werde zum Schwammerl, wo soll ich mit was anfangen?
          Wie kann ich den Fehler eingrenzen?
            @speedy:
            Wie kann ich den Fehler eingrenzen? `
            Normalerweise würde ich jetzt empfehlen Hardwaredaten zu loggen, was in einer VM nicht geht, da diese keine eigentliche Hardware hat.
            Da das Problem aber auch vorher beim RasPi auftrat denke ich, dass es woanders dran liegt.
            Da hilft es dann nur in diversen logs (iobroker/System) zu forschen, ob da etwas steht.
              Stabilostick
              Aber wenn sich Proxmox aufhängt, hat das einen Grund.
                @Stabilostick:
                Alt ist die SSD nicht. 242 Tage bislang gelaufen. 0 Errors. `
                Das ist wirklich nicht die Menge:
                Hier war es wohl das Netzteil, dass nach fast 1 Jahr stabilen Laufens immer wieder ausfiel.
                Habe ich vor 1 Woche ausgetauscht
                  speedy
                  das bedeutet wohl, dass das System so nicht zu retten sein wird.
                  Ich werde wohl nochmals von vorne beginnen müssen :(
                  und dann nur 1 od. 2 Adapter pro Woche installieren bis ich da bin wo ich hin will.
                  Dann funktioniert eben für eine gewisse Zeit sehr wenig bis nichts :(
                  Aber irgenwie muss ich ja weiter kommen…
                  Dennoch danke für eure Hilfe und Unterstützung,
                    speedy
                    Aber eine Uptime von gerade mal 7 Tagen ist auch nicht viel.
                    Ich möchte schon ein System, welches durchläuft.
                    Oder sind die 7 Tage wegen tausch des Netzteils?
                      Wie @stabilostick schon sagte, wenn sogar die VM (?? oder ganz proxmox) abschmiert liegt es Höchstwahrscheinlich nicht an ioBroker.
                      Ja!
                      Habe da noch ganz andere am Laufen:
                      • eric2905E Offline
                        eric2905E Offline
                        eric2905
                        Ok, ganz von vorne.
                        Wie hast Du Proxmox installiert?
                        Mit welchen Parametern hast Du die VM erstellt?
                        Container oder VM?
                        Dann sehen wir weiter. Bei mir läuft ioBroker auf 2 NUCs unter Proxmox völlig ohne Probleme.
                        Gruß,
                        Eric
                        Von unterwegs getippert
                          speedy
                          Proxmox via USB Stick lt. Videoanleitung (https://www.youtube.com/watch?v=492AQDA89GU)
                          Erstellt somit eine VM
                          • eric2905E Offline
                            eric2905E Offline
                            eric2905
                            Ok, das sieht erst mal brauchbar aus.
                            Was sind das für 2 USB-Geräte, die Du jetzt schon eingebunden hast?
                            Nachtrag/Edit:
                            Die 3 GB RAM könnten etwas knapp werden.
                            Ich habe 8 zugewiesen und es sind über 4 in Benutzung (laut Proxmox)
                            Gruß,
                            Eric
                              speedy
                              ok, danke.
                              ich habe nun folgende Adapter installiert und teilweise am laufen.
                              ich werde das mal so belassen, wobei hierbei die wichtigsten für mich deaktiviert sind.
                              Aber vielleicht kann ich so einer Neuinstallation doch noch entgehen (ist doch recht viel Zeit und Arbeit).
                              Wenn es so nun bis morgen ohne Probleme läuft werde ich der VM auch mehr Speicher gönnen.
                              Was meinst du, wie viel der 8GB kann ich der VM überhaupt weitergeben?
                              root@iobroker:/home/psw# iobroker list instances
                              system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.backitup.0              : backitup    -  enabled
                              system.adapter.daswetter.0             : daswetter   -  enabled
                              system.adapter.discovery.0             : discovery   -  enabled
                              system.adapter.flot.0                  : flot        -  enabled
                              system.adapter.history.0               : history     -  enabled
                              system.adapter.ical.0                  : ical        - disabled
                              system.adapter.ical.1                  : ical        - disabled
                              system.adapter.ical.2                  : ical        - disabled
                              system.adapter.ical.3                  : ical        - disabled
                              system.adapter.ical.4                  : ical        - disabled
                              system.adapter.icons-fatcow-hosting.0  : icons-fatcow-hosting -  enabled
                              system.adapter.icons-icons8.0          : icons-icons8 -  enabled
                              system.adapter.icons-material-png.0    : icons-material-png -  enabled
                              system.adapter.icons-mfd-svg.0         : icons-mfd-svg -  enabled
                              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  enabled
                              system.adapter.javascript.0            : javascript  - disabled
                              system.adapter.mihome.0                : mihome      -  enabled, port: 9898, bind: 192.168.1.8
                              system.adapter.mobile.0                : mobile      - disabled
                              system.adapter.mqtt.0                  : mqtt        - disabled, port: 1880
                              system.adapter.radar.0                 : radar       -  enabled
                              system.adapter.rickshaw.0              : rickshaw    -  enabled
                              system.adapter.sayit.0                 : sayit       -  enabled, port: 0
                              system.adapter.sonoff.0                : sonoff      -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.sonos.0                 : sonos       -  enabled
                              system.adapter.telegram.0              : telegram    - disabled, port: 8443, bind: 0.0.0.0
                              system.adapter.text2command.0          : text2command -  enabled
                              system.adapter.vis-bars.0              : vis-bars    -  enabled
                              system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
                              system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd -  enabled
                              system.adapter.vis-keyboard.0          : vis-keyboard -  enabled
                              system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
                              system.adapter.vis.0                   : vis         -  enabled
                              system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.wifilight.0             : wifilight   -  enabled
                              system.adapter.yeelight-2.0            : yeelight-2  -  enabled
                              system.adapter.zigbee.0                : zigbee      - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED3018-if00
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                Lass erst mal laufen.
                                Aber die Frage nach den beiden USB-Geräten hätte ich gerne noch beantwortet ;-)
                                Gruß,
                                Eric
                                  Warum flot und rickshaw?
                                  27 Adapter wären für einen RasPi wahrscheinlich eh zuviel gewesen.
                                  Das schafft der mit seinen 1GB RAM nicht.
                                  Wenn du dann noch aufwändige Views und Charts (diese mit Rickshaw und Flot generierst) könnte es mit den 3GB auch schon knapp werden.
                                  Den realen Verbrauch an RAM von
                                  • yeelight
                                  • wifilight
                                  • sonoff
                                  • radar
                                  • mihome
                                  und daswetter
                                  kann ich nicht beurteilen, da ich sie nicht nutze.
                                  Was steht denn oben rechts in deinem Reiter Instanzen?
                                    speedy
                                    @Eric:
                                    sorry, ging unter
                                    1x USB für Zigbee CC2531
                                    1x USB für Bluetooth -> radar Adapter für Anwesenheitserkennung
                                    @Rainer:
                                    gesamte RAM-Nutzung: 743 MB / Frei: 74% = 2.232 MB [Host: iobroker - 14 Prozesse]
                                      speedy
                                      Update:
                                      ca. 3,5 Std. ohne Probleme bis auf Zigbee.
                                      Hier gibt es eine Fehlermeldung im Log:
                                      2019-02-03 14:19:50.870  - warn: zigbee.0 Failed to configure 0x7cb03eaa00b08ed2 Plug 01
                                      2019-02-03 14:22:20.911  - error: zigbee.0 Cannot get the Node Descriptor of the Device: 0x7cb03eaa00b08ed2 (Error: Timed out after 10000 ms)
                                      2019-02-03 14:27:20.852  - error: zigbee.0 Cannot get the Node Descriptor of the Device: 0x7cb03eaa00b08ed2 (Error: Timed out after 10000 ms)
                                      Hierbei handelt es sich um einen Osram plug, welcher auf halber Strecke zu einem Sensor liegt, damit die Verbindung sichergestellt wird.
                                      Aber lt. Netzwerk hat sich dieser Sensor direkt verbunden.
                                      Ob das nun eine Rolle spielt? (Ich hatte auch in der Vergangenheit das Gefühl, dass Zigbee nicht ganz so optimal läuft).
                                      Auslastung: gesamte RAM-Nutzung: 989 MB / Frei: 66% = 2.003 MB [Host: iobroker - 16 Prozesse]
                                      Nun habe ich Telegram gestartet und warte mal was hier passiert, wird auch der letzte Adapter sein bis morgen Abend.
                                      Auslastung: gesamte RAM-Nutzung: 1055 MB / Frei: 65% = 1.957 MB [Host: iobroker - 17 Prozesse]
                                      Ich werde dies hier gleich mal als eine art Logbuch weiterführen, im Falle, dass jemand mal ein ähnliches Problem hat.
                                      • apollon77A Offline
                                        Zigbee Timeouts haben auch erstmal nichts mit deinem Problem zu tun. Die können auftreten und sagen nur das das Gerät nicht so geantwortet hat wie es sollte. Das ist aber erstmal egal.
                                        Was ist denn für ein Netzteil am Nuc? Ich hatte schonmal große probleme mit einem netzteil was versagt.
                                        Was mich immer noch stutzig macht ist was Du am ANfang geschrieben hattest das Proxmox den Status der VM nicht kannte. Ist das immer noch so? Dann würe ich erstmal bei Proxmos ansetzen.
                                        Was auch helfen kann ist das noch in der VOm zu installieren: https://pve.proxmox.com/wiki/Qemu-guest-agent.
                                        Auch ich habe einige Nuc und Proxmox im Einsatz und alles stabil.
                                          speedy
                                          Netzteil habe ich das originale in Verwendung.
                                          Werde ich aber auch einfach mal gegen ein stärkeres tauschen, diese kosten ja nicht die Welt.
                                          Danke für den Tipp.
                                          Das Problem mit Proxmox entstand aber erst nachdem die VM mit ioBroker derart instabil wurde.
                                          Evtl. ist es auch ein Speicherproblem wie oben bereits angedeutet wurde, wobei dies aber der aktuell angezeigte Verbrauch eher ausschließen würde.
                                          Speicher kann ich ja auch noch von 3 GB auf 6 erhöhen (dann bliebe Proxmox aber nur mehr 2 GB).
                                          Vielleicht möchte hierzu noch jemand eine Empfehlung abgeben (8GB sind verbaut).
                                          Proxmox Qemu-guest-agent werde ich jedenfalls noch nachinstallieren, hört sich vernünftig an.
                                          Bis jetzt läuft das System wieder, werde am Abend javascript aktivieren (jedoch nicht alle Scripts).
                                          Ich vermute, dass ich meine Scripts nicht ausreichend sauber programmiert habe.
                                          Wird ein mühseliger Weg…
