  4. [Projekt] ioGo # Smarthome to go
iogoappandroid
1.1k Beiträge 61 Kommentatoren 481.1k Aufrufe 20 Beobachtet
    Strizz
    #524
    meine Versuche, den Adapter iobroker.iogo zu starten, sind leider bisher gescheitert. Ich bekomme folgende Fehlermeldungen im Log:
    ` > iogo.0 2019-01-28 16:21:31.800 error at Module.load (module.js:566:32)
    iogo.0 2019-01-28 16:21:31.800 error at Object.Module._extensions..js (module.js:664:10)
    iogo.0 2019-01-28 16:21:31.800 error at Module._compile (module.js:653:30)
    iogo.0 2019-01-28 16:21:31.800 error at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:32:13)
    iogo.0 2019-01-28 16:21:31.800 error at require (internal/module.js:11:18)
    iogo.0 2019-01-28 16:21:31.800 error at Module.require (module.js:597:17)
    iogo.0 2019-01-28 16:21:31.800 error at Function.Module._load (module.js:498:3)
    iogo.0 2019-01-28 16:21:31.800 error at tryModuleLoad (module.js:506:12)
    iogo.0 2019-01-28 16:21:31.800 error at Object.Module._extensions..node (module.js:682:18)
    iogo.0 2019-01-28 16:21:31.800 error Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v57-linux
    iogo.0 2019-01-28 16:21:31.777 error uncaught exception: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/n
    iogo.0 2019-01-28 16:20:57.712 error at Module.load (module.js:566:32)
    iogo.0 2019-01-28 16:20:57.712 error at Object.Module._extensions..js (module.js:664:10)
    iogo.0 2019-01-28 16:20:57.712 error at Module._compile (module.js:653:30)
    iogo.0 2019-01-28 16:20:57.712 error at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:32:13)
    iogo.0 2019-01-28 16:20:57.712 error at require (internal/module.js:11:18)
    iogo.0 2019-01-28 16:20:57.712 error at Module.require (module.js:597:17)
    iogo.0 2019-01-28 16:20:57.712 error at Function.Module._load (module.js:498:3)
    iogo.0 2019-01-28 16:20:57.712 error at tryModuleLoad (module.js:506:12)
    iogo.0 2019-01-28 16:20:57.712 error at Object.Module._extensions..node (module.js:682:18)
    iogo.0 2019-01-28 16:20:57.712 error Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v57-linux
    iogo.0 2019-01-28 16:20:57.696 error uncaught exception: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/n
    iogo.0 2019-01-28 16:20:20.662 info terminating</anonymous></anonymous> `
    Leider kann ich mit den Fehlermeldungen gar nichts anfangen. Sieht so aus, als ob mir irgendetwas fehlt oder nicht aktuell ist. Aber was?
    Node Version: v8.14.0
    NPM Version: v6.4.1
    Kann mir jemand weiterhelfen?
    Strizz
    • ? Offline
      #525
      @Strizz:
      NPM Version: v6.4.1
      Strizz `
      Was für ein Betriebssystem hast du?
        Strizz
        #526
        Hallo nisio,
        iobroker läuft bei mir auf einem Orangepi+2e mit 'ARMBIAN 5.60 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i'.
        Strizz
        • ? Offline
          #527
          @Strizz:
          Hallo nisio,
          Strizz `
          Da kann ich leider nicht helfen.
          Mach am besten einen eigenen Thread hier im Forum auf, bestimmt gibt es Jemanden der helfen kann.
          Sorry
          • ? Offline
            #528
            @shattered_dream:
            Iogo Adapter
            Gesendet von meinem ONEPLUS A3003 mit Tapatalk `
            Schick mir mal bitte eine PN mit email die du im iogo-adapter nutzt.
            vielleicht finde ich was im Log.
            • 9 Offline
              9 Offline
              9_Mad-Max_5
              #529
              @nisio:
              @9_Mad-Max_5:
              @shattered_dream:
              Hab das als Level.temperature deklariert…
              Interessanterweise hat ein Wert den slider und die Auswahl und der andere nur die Auswahl..
              Mhm selbst dann habe ich vorne eine Thermometer angezeigt und wenn ich hinten auf den Zahlenwert drücke um ihn zu ändern versucht er erfolglos zu synchronisieren. `
              Wie verbindest du dich zu deinem iobroker? Web, Cloud oder iogo-adapter? `
              Ich verbinde mich mit dem iogo Adapter direkt.
              • ? Offline
                #530
                @9_Mad-Max_5:
                @nisio:
                @9_Mad-Max_5:
                Ich verbinde mich mit dem iogo Adapter direkt. `
                • N Offline
                  N Offline
                  noe1712
                  #531
                  Hey,
                  ist der Adapter eigentlich noch Aktuell? Habe probleme bein anmelden. Kann mir jemand sagen wie man scih anmeldet schritt für schritt? Mit dem aus Github komme ich leider nicht weit :(
                  • ? Offline
                    #532
                    @noe1712:
                    Hey,
                    ist der Adapter eigentlich noch Aktuell? Habe probleme bein anmelden. Kann mir jemand sagen wie man scih anmeldet schritt für schritt? Mit dem aus Github komme ich leider nicht weit :( `
                    ist alles noch aktuell.
                    In der Android App musst du dir einen Account anlegen (Email+passwort) diese Angaben kannst du dann anschließend in dem ioBroker.iogo Adapter nutzen.
                    Reicht das als Info?
                    Was ist noch unklar?
                    • N Offline
                      N Offline
                      noe1712
                      #533
                      Alles klar,
                      ja ein Konto habe ich mir erstellt, allerdings wenn ich bei dem Adapter auf Konfigurieren gehe steht dort nichts. Nur klein unten "This adapter does not need a configuration." Ist es vielleicht noch eine alte Version? :D
                      • ? Offline
                        #534
                        @noe1712:
                        Alles klar,
                        ja ein Konto habe ich mir erstellt, allerdings wenn ich bei dem Adapter auf Konfigurieren gehe steht dort nichts. Nur klein unten "This adapter does not need a configuration." Ist es vielleicht noch eine alte Version? :D `
                        Welche Version nutzt du?
                        • N Offline
                          N Offline
                          noe1712
                          #535
                          Die 0.2.6 :?
                          • ? Offline
                            #536
                            v0.2.6 ist die aktuellste.
                            Versuch mal ob ein erneutes upload in der console hilft
                            iobroker upload iogo
                            • N Offline
                              N Offline
                              noe1712
                              #537
                              Hat leider auch nicht geholfen. Hab mal 2 Screenshots gemacht, einmal von der Konfigurieren Seite von iogo und von dem was passiert wenn ich den Command eingebe. Kann damit leider nicht viel anfangen. Poste hier auch noch mal meinen Log (Weiß leider nicht wie ich den in so einer kleinen Zeile zum Scrollen poste, vielleicht kann mir das jemand erklären :D ) weiß leider nichts mit dem ganzen anzufangen und die vielen roten Sachen sind sicherlich nicht gut :shock: .
                              hue.0 2019-02-03 15:29:03.305 warn could not connect to ip
                              hue.0 2019-02-03 15:28:58.301 warn could not connect to ip
                              admin.1 2019-02-03 15:28:56.271 info system.adapter.admin.0: logging false
                              admin.1 2019-02-03 15:28:56.270 info system.adapter.admin.0: logging false
                              ping.0 2019-02-03 15:28:56.264 info system.adapter.admin.0: logging false
                              cloud.0 2019-02-03 15:28:56.264 info system.adapter.admin.0: logging false
                              hue.0 2019-02-03 15:28:56.262 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:28:56.262 info Restart adapter system.adapter.admin.0 because enabled
                              sonos.0 2019-02-03 15:28:56.262 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:28:56.262 error instance system.adapter.admin.0 terminated with code 1 ()
                              discovery.0 2019-02-03 15:28:56.261 info system.adapter.admin.0: logging false
                              rpi2.0 2019-02-03 15:28:56.261 info system.adapter.admin.0: logging false
                              javascript.0 2019-02-03 15:28:56.260 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:28:56.260 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:28:56.259 info system.adapter.admin.0: logging false
                              backitup.0 2019-02-03 15:28:56.258 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:28:56.258 info system.adapter.admin.0: logging false
                              alexa2.0 2019-02-03 15:28:56.257 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:28:56.257 info system.adapter.admin.0: logging false
                              socketio.0 2019-02-03 15:28:56.256 info system.adapter.admin.0: logging false
                              fakeroku.0 2019-02-03 15:28:56.256 info system.adapter.admin.0: logging false
                              history.0 2019-02-03 15:28:56.255 info system.adapter.admin.0: logging false
                              spotify-premium.0 2019-02-03 15:28:56.254 info system.adapter.admin.0: logging false
                              broadlink2.0 2019-02-03 15:28:56.252 info system.adapter.admin.0: logging false
                              harmony.0 2019-02-03 15:28:56.251 info system.adapter.admin.0: logging false
                              wifilight.0 2019-02-03 15:28:56.251 info system.adapter.admin.0: logging false
                              web.0 2019-02-03 15:28:56.251 info system.adapter.admin.0: logging false
                              sonoff.0 2019-02-03 15:28:56.250 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:28:56.150 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                              admin.0 2019-02-03 15:28:56.110 info Request actual repository…
                              admin.0 2019-02-03 15:28:55.943 info received all objects
                              admin.0 2019-02-03 15:28:54.460 info received all states
                              admin.0 2019-02-03 15:28:53.758 info requesting all objects
                              admin.0 2019-02-03 15:28:53.757 info requesting all states
                              hue.0 2019-02-03 15:28:53.299 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:28:50.963 info instance system.adapter.admin.0 started with pid 20320
                              host.All-In-One_RasPi 2019-02-03 15:28:48.885 info Restart adapter system.adapter.firetv.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:28:48.884 error instance system.adapter.firetv.0 terminated with code 1 ()
                              host.All-In-One_RasPi 2019-02-03 15:28:48.884 error Caught by controller[0]: at bootstrap_node.js:609:3
                              host.All-In-One_RasPi 2019-02-03 15:28:48.883 error Caught by controller[0]: at startup (bootstrap_node.js:188:16)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.883 error Caught by controller[0]: at Function.Module.runMain (module.js:693:10)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.882 error Caught by controller[0]: at Function.Module._load (module.js:497:3)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.882 error Caught by controller[0]: at tryModuleLoad (module.js:505:12)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.881 error Caught by controller[0]: at Module.load (module.js:565:32)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.881 error Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.880 error Caught by controller[0]: at Module._compile (module.js:652:30)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.880 error Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:6:14)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.879 error Caught by controller[0]: at require (internal/module.js:11:18)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.879 error Caught by controller[0]: at Module.require (module.js:596:17)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.878 error Caught by controller[0]: at Function.Module._load (module.js:474:25)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.878 error Caught by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
                              host.All-In-One_RasPi 2019-02-03 15:28:48.877 error Caught by controller[0]: Error: Cannot find module './node_modules/adbkit/lib/adb/client'
                              host.All-In-One_RasPi 2019-02-03 15:28:48.877 error Caught by controller[0]: ^
                              host.All-In-One_RasPi 2019-02-03 15:28:48.876 error Caught by controller[0]: throw err;
                              host.All-In-One_RasPi 2019-02-03 15:28:48.876 error Caught by controller[0]: module.js:549
                              hue.0 2019-02-03 15:28:48.295 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:28:47.856 info instance system.adapter.firetv.0 started with pid 20312
                              host.All-In-One_RasPi 2019-02-03 15:28:44.457 info Restart adapter system.adapter.tr-064.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:28:44.456 error instance system.adapter.tr-064.0 terminated with code 1 ()
                              hue.0 2019-02-03 15:28:43.283 warn could not connect to ip
                              tr-064.0 2019-02-03 15:28:39.431 error ~
                              tr-064.0 2019-02-03 15:28:39.431 error ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
                              tr-064.0 2019-02-03 15:28:39.431 error ~~ Fatal error. Can not connect to your FritzBox.
                              tr-064.0 2019-02-03 15:28:39.430 error Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 500 - {'code':500}
                              hue.0 2019-02-03 15:28:38.280 warn could not connect to ip
                              tr-064.0 2019-02-03 15:28:37.866 info starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                              tr-064.0 2019-02-03 15:28:37.810 info States connected to redis: 127.0.0.1:6379
                              host.All-In-One_RasPi 2019-02-03 15:28:35.815 info instance system.adapter.tr-064.0 started with pid 20302
                              hue.0 2019-02-03 15:28:33.277 warn could not connect to ip
                              hue.0 2019-02-03 15:28:28.274 warn could not connect to ip
                              hue.0 2019-02-03 15:28:23.271 warn could not connect to ip
                              admin.1 2019-02-03 15:28:20.964 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:28:20.968 info system.adapter.admin.0: logging false
                              discovery.0 2019-02-03 15:28:20.964 info system.adapter.admin.0: logging false
                              javascript.0 2019-02-03 15:28:20.964 info system.adapter.admin.0: logging false
                              socketio.0 2019-02-03 15:28:20.963 info system.adapter.admin.0: logging false
                              ping.0 2019-02-03 15:28:20.962 info system.adapter.admin.0: logging false
                              admin.1 2019-02-03 15:28:20.958 info system.adapter.admin.0: logging false
                              javascript.0 2019-02-03 15:28:20.963 info system.adapter.admin.0: logging false
                              history.0 2019-02-03 15:28:20.961 info system.adapter.admin.0: logging false
                              rpi2.0 2019-02-03 15:28:20.960 info system.adapter.admin.0: logging false
                              spotify-premium.0 2019-02-03 15:28:20.959 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:28:20.949 info Restart adapter system.adapter.admin.0 because enabled
                              backitup.0 2019-02-03 15:28:20.960 info system.adapter.admin.0: logging false
                              sonos.0 2019-02-03 15:28:20.960 info system.adapter.admin.0: logging false
                              alexa2.0 2019-02-03 15:28:20.959 info system.adapter.admin.0: logging false
                              sonoff.0 2019-02-03 15:28:20.959 info system.adapter.admin.0: logging false
                              web.0 2019-02-03 15:28:20.960 info system.adapter.admin.0: logging false
                              harmony.0 2019-02-03 15:28:20.957 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:28:20.956 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:28:20.953 info system.adapter.admin.0: logging false
                              broadlink2.0 2019-02-03 15:28:20.956 info system.adapter.admin.0: logging false
                              fakeroku.0 2019-02-03 15:28:20.955 info system.adapter.admin.0: logging false
                              cloud.0 2019-02-03 15:28:20.954 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:28:20.955 info system.adapter.admin.0: logging false
                              hue.0 2019-02-03 15:28:20.955 info system.adapter.admin.0: logging false
                              wifilight.0 2019-02-03 15:28:20.953 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:28:20.948 error instance system.adapter.admin.0 terminated with code 1 ()
                              admin.0 2019-02-03 15:28:20.911 error port 8081 already in use
                              host.All-In-One_RasPi 2019-02-03 15:28:20.845 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                              admin.0 2019-02-03 15:28:20.805 info Request actual repository…
                              admin.0 2019-02-03 15:28:20.519 info received all objects
                              admin.0 2019-02-03 15:28:19.185 info received all states
                              admin.0 2019-02-03 15:28:18.494 info requesting all objects
                              admin.0 2019-02-03 15:28:18.491 info requesting all states
                              admin.0 2019-02-03 15:28:18.451 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                              admin.0 2019-02-03 15:28:18.376 info States connected to redis: 127.0.0.1:6379
                              hue.0 2019-02-03 15:28:18.268 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:28:17.840 info Restart adapter system.adapter.firetv.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:28:17.840 error instance system.adapter.firetv.0 terminated with code 1 ()
                              Caught 2019-02-03 15:28:17.840 error by controller[0]: at bootstrap_node.js:609:3
                              Caught 2019-02-03 15:28:17.840 error by controller[0]: at startup (bootstrap_node.js:188:16)
                              Caught 2019-02-03 15:28:17.840 error by controller[0]: at Function.Module.runMain (module.js:693:10)
                              Caught 2019-02-03 15:28:17.840 error by controller[0]: at Function.Module._load (module.js:497:3)
                              Caught 2019-02-03 15:28:17.840 error by controller[0]: at tryModuleLoad (module.js:505:12)
                              Caught 2019-02-03 15:28:17.840 error by controller[0]: at Module.load (module.js:565:32)
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: at Object.Module._extensions..js (module.js:663:10)
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: at Module._compile (module.js:652:30)
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:6:14)
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: at require (internal/module.js:11:18)
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: at Module.require (module.js:596:17)
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: at Function.Module._load (module.js:474:25)
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: Error: Cannot find module './node_modules/adbkit/lib/adb/client'
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: ^
                              Caught 2019-02-03 15:28:17.839 error by controller[0]: throw err;
                              Caught 2019-02-03 15:28:17.838 error by controller[0]: module.js:549
                              host.All-In-One_RasPi 2019-02-03 15:28:16.654 info instance system.adapter.firetv.0 started with pid 20256
                              host.All-In-One_RasPi 2019-02-03 15:28:15.672 info instance system.adapter.admin.0 started with pid 20250
                              hue.0 2019-02-03 15:28:13.266 warn could not connect to ip
                              hue.0 2019-02-03 15:28:08.262 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:28:05.785 info Restart adapter system.adapter.tr-064.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:28:05.785 error instance system.adapter.tr-064.0 terminated with code 1 ()
                              hue.0 2019-02-03 15:28:03.260 warn could not connect to ip
                              tr-064.0 2019-02-03 15:28:00.759 error ~
                              tr-064.0 2019-02-03 15:28:00.759 error ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
                              tr-064.0 2019-02-03 15:28:00.759 error ~~ Fatal error. Can not connect to your FritzBox.
                              tr-064.0 2019-02-03 15:28:00.758 error Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 500 - {'code':500}
                              tr-064.0 2019-02-03 15:27:59.303 info starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                              tr-064.0 2019-02-03 15:27:59.166 info States connected to redis: 127.0.0.1:6379
                              hue.0 2019-02-03 15:27:58.257 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:27:57.312 info instance system.adapter.tr-064.0 started with pid 20239
                              hue.0 2019-02-03 15:27:53.254 warn could not connect to ip
                              hue.0 2019-02-03 15:27:48.252 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:27:46.639 info Restart adapter system.adapter.firetv.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:27:46.639 error instance system.adapter.firetv.0 terminated with code 1 ()
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at bootstrap_node.js:609:3
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at startup (bootstrap_node.js:188:16)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at Function.Module.runMain (module.js:693:10)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at Function.Module._load (module.js:497:3)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at tryModuleLoad (module.js:505:12)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at Module.load (module.js:565:32)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at Object.Module._extensions..js (module.js:663:10)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at Module._compile (module.js:652:30)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:6:14)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at require (internal/module.js:11:18)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at Module.require (module.js:596:17)
                              Caught 2019-02-03 15:27:46.638 error by controller[0]: at Function.Module._load (module.js:474:25)
                              Caught 2019-02-03 15:27:46.637 error by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
                              Caught 2019-02-03 15:27:46.637 error by controller[0]: Error: Cannot find module './node_modules/adbkit/lib/adb/client'
                              Caught 2019-02-03 15:27:46.637 error by controller[0]: ^
                              Caught 2019-02-03 15:27:46.637 error by controller[0]: throw err;
                              Caught 2019-02-03 15:27:46.636 error by controller[0]: module.js:549
                              admin.1 2019-02-03 15:27:45.674 info system.adapter.admin.0: logging false
                              admin.1 2019-02-03 15:27:45.673 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:27:45.660 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:27:45.660 info system.adapter.admin.0: logging false
                              backitup.0 2019-02-03 15:27:45.667 info system.adapter.admin.0: logging false
                              history.0 2019-02-03 15:27:45.664 info system.adapter.admin.0: logging false
                              ping.0 2019-02-03 15:27:45.665 info system.adapter.admin.0: logging false
                              rpi2.0 2019-02-03 15:27:45.663 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:27:45.654 info Restart adapter system.adapter.admin.0 because enabled
                              discovery.0 2019-02-03 15:27:45.665 info system.adapter.admin.0: logging false
                              sonos.0 2019-02-03 15:27:45.663 info system.adapter.admin.0: logging false
                              web.0 2019-02-03 15:27:45.664 info system.adapter.admin.0: logging false
                              spotify-premium.0 2019-02-03 15:27:45.663 info system.adapter.admin.0: logging false
                              hue.0 2019-02-03 15:27:45.662 info system.adapter.admin.0: logging false
                              broadlink2.0 2019-02-03 15:27:45.662 info system.adapter.admin.0: logging false
                              socketio.0 2019-02-03 15:27:45.661 info system.adapter.admin.0: logging false
                              alexa2.0 2019-02-03 15:27:45.662 info system.adapter.admin.0: logging false
                              cloud.0 2019-02-03 15:27:45.661 info system.adapter.admin.0: logging false
                              sonoff.0 2019-02-03 15:27:45.661 info system.adapter.admin.0: logging false
                              harmony.0 2019-02-03 15:27:45.661 info system.adapter.admin.0: logging false
                              fakeroku.0 2019-02-03 15:27:45.660 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:27:45.659 info system.adapter.admin.0: logging false
                              javascript.0 2019-02-03 15:27:45.662 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:27:45.659 info system.adapter.admin.0: logging false
                              wifilight.0 2019-02-03 15:27:45.659 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:27:45.653 error instance system.adapter.admin.0 terminated with code 1 ()
                              admin.0 2019-02-03 15:27:45.619 error port 8081 already in use
                              host.All-In-One_RasPi 2019-02-03 15:27:45.556 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                              admin.0 2019-02-03 15:27:45.513 info Request actual repository…
                              admin.0 2019-02-03 15:27:45.203 info received all objects
                              host.All-In-One_RasPi 2019-02-03 15:27:44.640 info instance system.adapter.firetv.0 started with pid 20221
                              admin.0 2019-02-03 15:27:43.770 info received all states
                              hue.0 2019-02-03 15:27:43.250 warn could not connect to ip
                              admin.0 2019-02-03 15:27:43.079 info requesting all objects
                              admin.0 2019-02-03 15:27:43.076 info requesting all states
                              admin.0 2019-02-03 15:27:43.032 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                              admin.0 2019-02-03 15:27:42.972 info States connected to redis: 127.0.0.1:6379
                              host.All-In-One_RasPi 2019-02-03 15:27:40.259 info instance system.adapter.admin.0 started with pid 20209
                              hue.0 2019-02-03 15:27:38.248 warn could not connect to ip
                              hue.0 2019-02-03 15:27:33.246 warn could not connect to ip
                              hue.0 2019-02-03 15:27:28.241 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:27:27.287 info Restart adapter system.adapter.tr-064.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:27:27.287 error instance system.adapter.tr-064.0 terminated with code 1 ()
                              hue.0 2019-02-03 15:27:23.238 warn could not connect to ip
                              tr-064.0 2019-02-03 15:27:22.263 error ~
                              tr-064.0 2019-02-03 15:27:22.263 error ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
                              tr-064.0 2019-02-03 15:27:22.262 error ~~ Fatal error. Can not connect to your FritzBox.
                              tr-064.0 2019-02-03 15:27:22.261 error Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 500 - {'code':500}
                              tr-064.0 2019-02-03 15:27:20.526 info starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                              tr-064.0 2019-02-03 15:27:20.470 info States connected to redis: 127.0.0.1:6379
                              host.All-In-One_RasPi 2019-02-03 15:27:18.528 info instance system.adapter.tr-064.0 started with pid 20159
                              hue.0 2019-02-03 15:27:18.236 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:27:14.623 info Restart adapter system.adapter.firetv.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:27:14.623 error instance system.adapter.firetv.0 terminated with code 1 ()
                              Caught 2019-02-03 15:27:14.623 error by controller[0]: at bootstrap_node.js:609:3
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at startup (bootstrap_node.js:188:16)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Function.Module.runMain (module.js:693:10)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Function.Module._load (module.js:497:3)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at tryModuleLoad (module.js:505:12)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Module.load (module.js:565:32)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Object.Module._extensions..js (module.js:663:10)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Module._compile (module.js:652:30)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:6:14)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at require (internal/module.js:11:18)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Module.require (module.js:596:17)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Function.Module._load (module.js:474:25)
                              Caught 2019-02-03 15:27:14.622 error by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
                              Caught 2019-02-03 15:27:14.621 error by controller[0]: Error: Cannot find module './node_modules/adbkit/lib/adb/client'
                              Caught 2019-02-03 15:27:14.621 error by controller[0]: ^
                              Caught 2019-02-03 15:27:14.621 error by controller[0]: throw err;
                              Caught 2019-02-03 15:27:14.621 error by controller[0]: module.js:549
                              host.All-In-One_RasPi 2019-02-03 15:27:13.603 info instance system.adapter.firetv.0 started with pid 20153
                              hue.0 2019-02-03 15:27:13.226 warn could not connect to ip
                              admin.1 2019-02-03 15:27:10.261 info system.adapter.admin.0: logging false
                              admin.1 2019-02-03 15:27:10.260 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:27:10.261 info system.adapter.admin.0: logging false
                              javascript.0 2019-02-03 15:27:10.260 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:27:10.257 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:27:10.244 info Restart adapter system.adapter.admin.0 because enabled
                              javascript.0 2019-02-03 15:27:10.258 info system.adapter.admin.0: logging false
                              broadlink2.0 2019-02-03 15:27:10.251 info system.adapter.admin.0: logging false
                              socketio.0 2019-02-03 15:27:10.255 info system.adapter.admin.0: logging false
                              hue.0 2019-02-03 15:27:10.250 info system.adapter.admin.0: logging false
                              history.0 2019-02-03 15:27:10.256 info system.adapter.admin.0: logging false
                              discovery.0 2019-02-03 15:27:10.254 info system.adapter.admin.0: logging false
                              rpi2.0 2019-02-03 15:27:10.255 info system.adapter.admin.0: logging false
                              spotify-premium.0 2019-02-03 15:27:10.254 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:27:10.249 info system.adapter.admin.0: logging false
                              alexa2.0 2019-02-03 15:27:10.252 info system.adapter.admin.0: logging false
                              web.0 2019-02-03 15:27:10.251 info system.adapter.admin.0: logging false
                              wifilight.0 2019-02-03 15:27:10.250 info system.adapter.admin.0: logging false
                              harmony.0 2019-02-03 15:27:10.250 info system.adapter.admin.0: logging false
                              backitup.0 2019-02-03 15:27:10.249 info system.adapter.admin.0: logging false
                              sonos.0 2019-02-03 15:27:10.249 info system.adapter.admin.0: logging false
                              cloud.0 2019-02-03 15:27:10.248 info system.adapter.admin.0: logging false
                              sonoff.0 2019-02-03 15:27:10.251 info system.adapter.admin.0: logging false
                              ping.0 2019-02-03 15:27:10.251 info system.adapter.admin.0: logging false
                              fakeroku.0 2019-02-03 15:27:10.250 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:27:10.248 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:27:10.244 error instance system.adapter.admin.0 terminated with code 1 ()
                              admin.0 2019-02-03 15:27:10.210 error port 8081 already in use
                              host.All-In-One_RasPi 2019-02-03 15:27:10.147 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                              admin.0 2019-02-03 15:27:10.105 info Request actual repository…
                              admin.0 2019-02-03 15:27:09.767 info received all objects
                              admin.0 2019-02-03 15:27:08.407 info received all states
                              hue.0 2019-02-03 15:27:08.223 warn could not connect to ip
                              admin.0 2019-02-03 15:27:07.724 info requesting all objects
                              admin.0 2019-02-03 15:27:07.722 info requesting all states
                              admin.0 2019-02-03 15:27:07.684 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                              admin.0 2019-02-03 15:27:07.630 info States connected to redis: 127.0.0.1:6379
                              host.All-In-One_RasPi 2019-02-03 15:27:04.818 info instance system.adapter.admin.0 started with pid 20143
                              hue.0 2019-02-03 15:27:03.220 warn could not connect to ip
                              hue.0 2019-02-03 15:26:58.217 warn could not connect to ip
                              hue.0 2019-02-03 15:26:53.213 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:26:48.501 info Restart adapter system.adapter.tr-064.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:26:48.501 error instance system.adapter.tr-064.0 terminated with code 1 ()
                              hue.0 2019-02-03 15:26:48.211 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:26:43.579 info Restart adapter system.adapter.firetv.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:26:43.579 error instance system.adapter.firetv.0 terminated with code 1 ()
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at bootstrap_node.js:609:3
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at startup (bootstrap_node.js:188:16)
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at Function.Module.runMain (module.js:693:10)
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at Function.Module._load (module.js:497:3)
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at tryModuleLoad (module.js:505:12)
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at Module.load (module.js:565:32)
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at Object.Module._extensions..js (module.js:663:10)
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at Module._compile (module.js:652:30)
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:6:14)
                              Caught 2019-02-03 15:26:43.579 error by controller[0]: at require (internal/module.js:11:18)
                              Caught 2019-02-03 15:26:43.578 error by controller[0]: at Module.require (module.js:596:17)
                              Caught 2019-02-03 15:26:43.578 error by controller[0]: at Function.Module._load (module.js:474:25)
                              Caught 2019-02-03 15:26:43.578 error by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
                              Caught 2019-02-03 15:26:43.578 error by controller[0]: Error: Cannot find module './node_modules/adbkit/lib/adb/client'
                              Caught 2019-02-03 15:26:43.578 error by controller[0]: ^
                              Caught 2019-02-03 15:26:43.578 error by controller[0]: throw err;
                              Caught 2019-02-03 15:26:43.578 error by controller[0]: module.js:549
                              tr-064.0 2019-02-03 15:26:43.475 error ~
                              tr-064.0 2019-02-03 15:26:43.475 error ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
                              tr-064.0 2019-02-03 15:26:43.475 error ~~ Fatal error. Can not connect to your FritzBox.
                              tr-064.0 2019-02-03 15:26:43.473 error Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {'code':401}
                              hue.0 2019-02-03 15:26:43.207 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:26:42.439 info instance system.adapter.firetv.0 started with pid 20137
                              tr-064.0 2019-02-03 15:26:41.857 info starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                              tr-064.0 2019-02-03 15:26:41.803 info States connected to redis: 127.0.0.1:6379
                              host.All-In-One_RasPi 2019-02-03 15:26:39.956 info instance system.adapter.tr-064.0 started with pid 20127
                              hue.0 2019-02-03 15:26:38.203 warn could not connect to ip
                              admin.1 2019-02-03 15:26:34.814 info system.adapter.admin.0: logging false
                              admin.1 2019-02-03 15:26:34.813 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:26:34.800 info system.adapter.admin.0: logging false
                              javascript.0 2019-02-03 15:26:34.803 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:26:34.810 info system.adapter.admin.0: logging false
                              web.0 2019-02-03 15:26:34.804 info system.adapter.admin.0: logging false
                              socketio.0 2019-02-03 15:26:34.803 info system.adapter.admin.0: logging false
                              history.0 2019-02-03 15:26:34.805 info system.adapter.admin.0: logging false
                              javascript.1 2019-02-03 15:26:34.807 info system.adapter.admin.0: logging false
                              ping.0 2019-02-03 15:26:34.802 info system.adapter.admin.0: logging false
                              sonoff.0 2019-02-03 15:26:34.801 info system.adapter.admin.0: logging false
                              alexa2.0 2019-02-03 15:26:34.800 info system.adapter.admin.0: logging false
                              cloud.0 2019-02-03 15:26:34.800 info system.adapter.admin.0: logging false
                              iogo.0 2019-02-03 15:26:34.799 info system.adapter.admin.0: logging false
                              discovery.0 2019-02-03 15:26:34.805 info system.adapter.admin.0: logging false
                              sonos.0 2019-02-03 15:26:34.804 info system.adapter.admin.0: logging false
                              spotify-premium.0 2019-02-03 15:26:34.803 info system.adapter.admin.0: logging false
                              javascript.0 2019-02-03 15:26:34.802 info system.adapter.admin.0: logging false
                              harmony.0 2019-02-03 15:26:34.802 info system.adapter.admin.0: logging false
                              broadlink2.0 2019-02-03 15:26:34.802 info system.adapter.admin.0: logging false
                              rpi2.0 2019-02-03 15:26:34.801 info system.adapter.admin.0: logging false
                              hue.0 2019-02-03 15:26:34.801 info system.adapter.admin.0: logging false
                              fakeroku.0 2019-02-03 15:26:34.799 info system.adapter.admin.0: logging false
                              backitup.0 2019-02-03 15:26:34.801 info system.adapter.admin.0: logging false
                              wifilight.0 2019-02-03 15:26:34.799 info system.adapter.admin.0: logging false
                              host.All-In-One_RasPi 2019-02-03 15:26:34.795 info Restart adapter system.adapter.admin.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:26:34.794 error instance system.adapter.admin.0 terminated with code 1 ()
                              admin.0 2019-02-03 15:26:34.762 error port 8081 already in use
                              host.All-In-One_RasPi 2019-02-03 15:26:34.696 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                              admin.0 2019-02-03 15:26:34.656 info Request actual repository…
                              admin.0 2019-02-03 15:26:34.383 info received all objects
                              hue.0 2019-02-03 15:26:33.201 warn could not connect to ip
                              admin.0 2019-02-03 15:26:33.031 info received all states
                              admin.0 2019-02-03 15:26:32.330 info requesting all objects
                              admin.0 2019-02-03 15:26:32.327 info requesting all states
                              admin.0 2019-02-03 15:26:32.281 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                              admin.0 2019-02-03 15:26:32.225 info States connected to redis: 127.0.0.1:6379
                              host.All-In-One_RasPi 2019-02-03 15:26:29.663 info instance system.adapter.admin.0 started with pid 20105
                              hue.0 2019-02-03 15:26:28.198 warn could not connect to ip
                              hue.0 2019-02-03 15:26:23.195 warn could not connect to ip
                              hue.0 2019-02-03 15:26:18.192 warn could not connect to ip
                              hue.0 2019-02-03 15:26:13.190 warn could not connect to ip
                              host.All-In-One_RasPi 2019-02-03 15:26:12.413 info Restart adapter system.adapter.firetv.0 because enabled
                              host.All-In-One_RasPi 2019-02-03 15:26:12.413 error instance system.adapter.firetv.0 terminated with code 1 ()
                              • N noe1712
                                #538
                                @noe1712 Die Fehler im Log kommen vom firetv-adapter. Von iogo stehen keine Fehler im Log. Die Konfiguration der iogo Instanz ist nicht die aktuelle. Welche Verion von iogo-adapter hast du installiert?
                                • BreisgauerB Offline
                                  BreisgauerB Offline
                                  Breisgauer
                                  #539
                                  Hi, ich teste gerade die ioGo App. Aber so richtig erschließt sich mir das Konzept noch nicht, oder ich stehe auf dem Schlauch.
                                  Die App habe ich installiert, und sowohl über den ioGo Adapter als auch über iosocket kann ich eine Verbindung zwischen App und ioBroker Server herstellen. Die Info in der App zeigt auch eine Verbindung, mehrere Räume, Funktionen und States.
                                  Es gibt States mit Lese und Schreibzugriff. Da ich eine KNX basierte Hauselektrik habe, sind Schreib und Leseobjekte (States) getrennt, dh. States haben entweder eine Schreib- oder Leseberechtigung. Der Status eines Lichts wird zum Beispiel über ein Object mit dem Namen Status ausgelesen, und das Licht wird über ein anderes Objekt "Aktion" geschalten.
                                  In der App wird unter der Funktionen kaum ein State angezeigt. So hat "enum.functions.light" zwar mehrere Objekte zugeordnet, zeigt aber in der App kein einziges an.
                                  Hat jemand eine Idee, was ich falsch mache?
                                  -- breisgauer
                                  Produktiv: iobroker in Docker; latest stable versions for adapters. ETS 5 (aktuelle Version)
                                  • G Offline
                                    Gerni
                                    #540
                                    Habe auch mal die App geladen und Adapter (Version 0.3.0) installiert. Verbindung per iogo funktioniert auch allerdings schaltet der Adapter dann wieder auf rot.
                                    Über den Cloud Adapter jedoch nicht. Welche Daten müssen da rein? Iot oder Cloud Adapter Zugangsdaten?
                                    Jede Menge verschiedenes Zeug
                                    • G Gerni
                                      #541
                                      @Gerni said in [Projekt] ioGo # Native Android App:
                                      Version 0.3.0 scheint noch einen Bug zu haben. Wird heute Abend gefixt. Die stable version 0.2.6 sollte ohne Probleme laufen...
                                      G 1 Antwort Letzte Antwort
                                      • BreisgauerB Breisgauer
                                        -- breisgauer
                                        #542
                                        @Breisgauer said in [Projekt] ioGo # Native Android App:
                                        -- breisgauer
                                        Hast du der enums States zugeordnet? Zuordnung über Channel oder Device sind aktuell nicht unterstützt.
                                        BreisgauerB 1 Antwort Letzte Antwort
                                          -- breisgauer
                                          BreisgauerB Offline
                                          BreisgauerB Offline
                                          Breisgauer
                                          #543
                                          @nisio
                                          Ja, habe ich zugeordnet.
