  4. Neue Features
Neue Features
70 Beiträge 7 Kommentatoren 19.8k Aufrufe
  • ruhr70R
    ruhr70R
    ruhr70
    > "lebt" denn die CCU überhaupt? Vielleicht mal durchstarten …
    Ja. Die Programme innerhalb der CCU2 funktionieren auch.
    Ich hatte die CCU2 auch neugestartet (über die Weboberfläche).
    Im Log vom ioBroker findet man einige Fehler (Auszug, gefiltert ab der Stufe Warnung):
    host.iobroker 2015-03-01 19:34:06 error instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host.iobroker 2015-03-01 19:34:02 error instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
    TypeError: 2015-03-01 19:34:01 error at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
    TypeError: 2015-03-01 19:34:01 error at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
    TypeError: 2015-03-01 19:34:01 error at SAXStream.emit (events.js:92:17)
    TypeError: 2015-03-01 19:34:01 error at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
    TypeError: 2015-03-01 19:34:01 error at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
    TypeError: 2015-03-01 19:34:01 error at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
    TypeError: 2015-03-01 19:34:01 error at Server.emit (events.js:106:17)
    TypeError: 2015-03-01 19:34:01 error at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:378:29)
    TypeError: 2015-03-01 19:34:01 error at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
    TypeError: 2015-03-01 19:34:01 error at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:814:29)
    TypeError: 2015-03-01 19:34:01 error Cannot call method 'substring' of undefined
    uncaught 2015-03-01 19:34:01 error exception: Cannot call method 'substring' of undefined
    host.iobroker 2015-03-01 19:34:00 error instance system.adapter.ping.0 terminated with code 7 (Adapter already running)
    host.iobroker 2015-03-01 19:33:56 error instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    host.iobroker 2015-03-01 19:33:55 error instance system.adapter.hm-rega.0 terminated with code 6 (uncaught exception)
    host.iobroker 2015-03-01 19:33:49 error instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
    host.iobroker 2015-03-01 19:33:46 error instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    host.iobroker 2015-03-01 19:33:35 error instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host.iobroker 2015-03-01 19:33:31 error instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
    TypeError: 2015-03-01 19:33:30 error at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
    TypeError: 2015-03-01 19:33:30 error at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
    TypeError: 2015-03-01 19:33:30 error at SAXStream.emit (events.js:92:17)
    • HomoranH
      @ruhr70:
      Was ich bei meinem Problem komisch finde:
      Dass sich z.B. der Zustand einer Lampe in VIS ändert, wenn man dies per VIS macht, aber in der Realität nicht. `
      Wenn du damit sagen willst, was ich meine (Vis klicken -> Lampe an; Lampe an -> keine Änderung in vis) hatten wir hier schon mal das Problem. Ich kann mich nur nicht mehr daran erinnern, ob es gelöst wurde - und wenn ja, wie.
      @ruhr70:
      Ich dachte der Zustand der Lampe kommt über den Rückkanal, über die CCU2, über XML zu ioBroker und wird dann visualisiert `
      Das ist auch genau richtig.
      Allerdings kann die Antwort etwas dauern, je nachdem wie lang dein polling interval in hpc-rega eingestellt ist.
      @bku:
      "lebt" denn die CCU überhaupt? Vielleicht mal durchstarten … `
      also ein reboot kann wirklich nicht schaden.
      ich hatte in einem anderen Fall auch schon mal von xml-rpc auf bin-rpc umgestellt. Ob das sinnvoll ist, weiß ich jedoch nicht.
      EDIT: Die Errors waren nach einem Neustart von ioBroker? und nur einmalig? dann ist es nicht schlimm!
      Viel Glück
      • ruhr70R
        ruhr70R
        ruhr70
        ` > ruhr70 hat geschrieben:
        Allerdings kann die Antwort etwas dauern, je nachdem wie lang dein polling interval in hpc-rega eingestellt ist. `
        Nein, das meinte ich nicht. Da habe ich mich recht unklar ausgedrückt.
        Ich kann über VIS die Zustände von z.B. Lampen ändern.
        In VIS druck auf ein Lampensymbol, welches aus ist -> Lampe in VIS leuchtet.
        Die echte Lampe zeigt keinerlei Reaktion.
        Wenn sie aus war bleibt sie aus.
        Wenn sie an war, bleibt sie an.
        Egal, wie oft ich in VIS den Zustand ändere (dort wird jede Änderung visualisiert: an, aus, an, aus, usw.).
        Das ist es u.a., was mich bei meinem Problem verwundert.
        Der Zustand einer Lampe in VIS sollte sich doch erst ändern, wenn die Information von der CCU kommt.
        • BluefoxB
          @ruhr70:
          TypeError: 2015-03-01 19:33:30 error at SAXStream.emit (events.js:92:17) `
          Probiere mal ioBroker.hm-rpc 0.3.5
          • HomoranH
            Bluefox hat gerade wieder zwei neue updates eingestellt ;-)
            Wenn das aber nicht über die WebUI funktioniert, frage ich mich ob du die aktuelle Version von controller und admin hast.
            Deswegen war auch die Frage nach dem Alter der Installation.
            Andererseits arbeitest du in einer VM - da habe ich gar keine Ahnung von, aber da gibt es auch einen Thread mit Issues in den Pfaden.
            • ruhr70R
              ruhr70R
              ruhr70
              Habe gerade mal alles was geht neu gestartet (von der VM, Update Fusion, MacBook, CCU, usw.). Hat etwas gedauert.
              Danach habe ich die beiden Updates gesehen (hm-rpc und vis) und beide eingespielt.
              hey, ihr legt ja eine Geschwindigkeit an den Tag, dass einem Schwindelig wird :-)
              Folgendes viel auf:
              Positive Änderungen:
              • die Updates konnte ich diesmal beide über den Browser einspielen :-)
              • im VIS Editor werden nun bei mir Sichtbarkeit und Format (unter Allgemein) angezeigt. Das war vorher nicht der Fall. Top!
              Ob das an den neuen Versionen lag oder an den Reboots…?
              Folgende Punkte sind mir aufgefallen:
              • Mein Grundproblem: hm-rpc funktioniert immer noch nicht (wechselt unter ioBroker/Instanzen auch mal munter zwischen läuft ja und nein). Die Zustandswechsel in VIS haben nichts mit der Realität zu tun.
              • ioBroker.admin: Instanzen: in der Spalte aktiviert steht mal: "ja", mal "true" oder nein (nicht einheitlich, gefiltert werden kann entweder nach ja oder nach true) (EDIT: nach cmd+r im Chrome steht überall wieder ja oder nein. Dann gefiltert nach "ja" und es wird nur eine Zeile von sechs angezeigt. Filter raus: est steht tlw.wieder ja und tlw. wieder true in der Spalte.)
              • Adapter: ausser dass abwechselnd hm-rega und hm-rpc nicht funktionieren, steht bei VIS unter läuft und verbunden nun "" (nichts). VIS ist aktiv.
              • Timestamp eigene Formatierung: "DD.MM.YY hh:mm" zeigt: "01.01.115 20:23" (beim Jahr steht 115 statt 15)
              • HomoranH
                Ich fürchte da liegt etwas an der VM (dann bin ich wenigstens raus und andere müssen arbeiten ;-) )
                Die in .vis bedienten widgets erhalten sofort den geänderten status, nicht erst bei feedback des Aktors.
                Ich halte das auch für sinnvoll, denn wenn das Feedback 30 Sekunden dauert, und die Reaktion nicht vom Bedienpanel aus sichtbar ist, klickt man sonst aus Verzweiflung immer wieder auf den Button, bis eine Reaktion erfolgt.
                …und viel Glück
                • BluefoxB
                  #66
                  @ruhr70:
                    "läuft ja und nein" heisst wird gestartet und stürzt ab. Dein Log soll voll sein. Her damit. (Mindestens was hm-rpc angeht)
                    @ruhr70:
                      Ok.. Habe noch nie über "Aktive" gefiltert. Da will ich sowieso was umbauen. Danke.
                      @ruhr70:
                        Der hat keinen Prozess. Nur die Webseiten über "web". Daher kann er nicht laufen.
                        @ruhr70:
                        • Timestamp eigene Formatierung: "DD.MM.YY hh:mm" zeigt: "01.01.115 20:23" (beim Jahr steht 115 statt 15) Danke. Habe gefixt. Kommt in der nächsten Version.
                  • ruhr70R
                    ruhr70R
                    ruhr70
                    #67
                      Hi Bluefox,
                      danke, dass Du Dir das anschaust :-)
                      Mein Log ist mittlerweile fast 5 GB groß :shock:
                      Log-Größe: 4885.53 MB
                      Anbei die Daten von heute moregen, gefiltert ab Stufe "Warnung":
                      [color]iobroker	2015-03-02 06:51:26	error	host.iobroker instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      hm-rpc.0	2015-03-02 06:51:25	error	TypeError: Cannot read property 'length' of undefined at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54) at Adapter.deleteChannel (/opt/
                      hm-rpc.0	2015-03-02 06:51:25	error	uncaught exception: Cannot read property 'length' of undefined
                      iobroker	2015-03-02 06:51:21	error	host.iobroker instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      hm-rpc.0	2015-03-02 06:51:20	error	TypeError: Cannot read property 'length' of undefined at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54) at Adapter.deleteChannel (/opt/
                      hm-rpc.0	2015-03-02 06:51:20	error	uncaught exception: Cannot read property 'length' of undefined
                      iobroker	2015-03-02 06:50:55	error	host.iobroker instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      hm-rpc.0	2015-03-02 06:50:54	error	TypeError: Cannot read property 'length' of undefined at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54) at Adapter.deleteChannel (/opt/
                      hm-rpc.0	2015-03-02 06:50:54	error	uncaught exception: Cannot read property 'length' of undefined
                      iobroker	2015-03-02 06:50:50	error	host.iobroker instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      hm-rpc.0	2015-03-02 06:50:49	error	TypeError: Cannot read property 'length' of undefined at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54) at Adapter.deleteChannel (/opt/
                      hm-rpc.0	2015-03-02 06:50:49	error	uncaught exception: Cannot read property 'length' of undefined
                      iobroker	2015-03-02 06:50:24	error	host.iobroker instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      hm-rpc.0	2015-03-02 06:50:23	error	TypeError: Cannot read property 'length' of undefined at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54) at Adapter.deleteChannel (/opt/
                      hm-rpc.0	2015-03-02 06:50:23	error	uncaught exception: Cannot read property 'length' of undefined
                      iobroker	2015-03-02 06:50:19	error	host.iobroker instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      hm-rpc.0	2015-03-02 06:50:19	error	TypeError: Cannot read property 'length' of undefined at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54) at Adapter.deleteChannel (/opt/
                      hm-rpc.0	2015-03-02 06:50:19	error	uncaught exception: Cannot read property 'length' of undefined
                      iobroker	2015-03-02 06:49:53	error	host.iobroker instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      hm-rpc.0	2015-03-02 06:49:52	error	TypeError: Cannot read property 'length' of undefined at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54) at Adapter.deleteChannel (/opt/
                      hm-rpc.0	2015-03-02 06:49:52	error	uncaught exception: Cannot read property 'length' of undefined
                      iobroker	2015-03-02 06:49:48	error	host.iobroker instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      hm-rpc.0	2015-03-02 06:49:48	error	TypeError: Cannot read property 'length' of undefined at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54) at Adapter.deleteChannel (/opt/
                      hm-rpc.0	2015-03-02 06:49:48	error	uncaught exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:49:22	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:49:21	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:49:21	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:49:21	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:49:21	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:49:21	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:49:21	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:49:21	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:49:21	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:49:21	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:49:21	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:49:21	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:49:21	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:49:17	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:49:17	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:49:17	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:49:17	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:49:17	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:49:17	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:49:17	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:49:17	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:49:17	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:49:17	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:49:17	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:49:17	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:49:17	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:48:51	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:48:50	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:48:50	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:48:50	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:48:50	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:48:50	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:48:50	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:48:50	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:48:50	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:48:50	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:48:50	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:48:50	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:48:50	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:48:46	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:48:46	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:48:46	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:48:46	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:48:46	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:48:46	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:48:46	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:48:46	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:48:46	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:48:46	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:48:46	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:48:46	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:48:46	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:48:20	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:48:20	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:48:20	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:48:20	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:48:20	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:48:20	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:48:20	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:48:20	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:48:20	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:48:20	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:48:20	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:48:20	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:48:20	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:48:15	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:48:15	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:48:15	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:48:15	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:48:15	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:48:15	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:48:15	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:48:15	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:48:15	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:48:15	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:48:15	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:48:15	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:48:15	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:47:49	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:47:49	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:47:49	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:47:49	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:47:49	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:47:49	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:47:49	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:47:49	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:47:49	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:47:49	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:47:49	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:47:49	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:47:49	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:47:44	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:47:44	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:47:44	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:47:44	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:47:44	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:47:44	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:47:44	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:47:44	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:47:44	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:47:44	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:47:44	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:47:44	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:47:44	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:47:18	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:47:18	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:47:18	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:47:18	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:47:18	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:47:18	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:47:18	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:47:18	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:47:18	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:47:18	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:47:18	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:47:18	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:47:18	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:47:13	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:47:13	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:47:13	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:47:13	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:47:13	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:47:13	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:47:13	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:47:13	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:47:13	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:47:13	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:47:13	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:47:13	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:47:13	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:46:47	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:46:47	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:46:47	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:46:47	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:46:47	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:46:47	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:46:47	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:46:47	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:46:47	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:46:47	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:46:47	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:46:47	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:46:47	error	exception: Cannot read property 'length' of undefined
                      host.iobroker	2015-03-02 06:46:42	error	instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
                      TypeError:	2015-03-02 06:46:42	error	at emit (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:325:33)
                      TypeError:	2015-03-02 06:46:42	error	at Object.SAXStream._parser.onend (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/node_modules/sax/lib/sax.js:171:8)
                      TypeError:	2015-03-02 06:46:42	error	at SAXStream.emit (events.js:92:17)
                      TypeError:	2015-03-02 06:46:42	error	at Deserializer.onDone (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:92:12)
                      TypeError:	2015-03-02 06:46:42	error	at callback (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/deserializer.js:65:7)
                      TypeError:	2015-03-02 06:46:42	error	at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/homematic-xmlrpc/lib/server.js:42:14
                      TypeError:	2015-03-02 06:46:42	error	at Server.emit (events.js:106:17)
                      TypeError:	2015-03-02 06:46:42	error	at Server. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:379:29)
                      TypeError:	2015-03-02 06:46:42	error	at Adapter.deleteChannel (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:860:18)
                      TypeError:	2015-03-02 06:46:42	error	at Adapter.deleteChannelFromEnum (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:817:54)
                      TypeError:	2015-03-02 06:46:42	error	Cannot read property 'length' of undefined
                      uncaught	2015-03-02 06:46:42	error	exception: Cannot read property 'length' of undefined[/color]
                    • ruhr70R
                      ruhr70R
                      ruhr70
                      #68
                      ` > Es wird dir helfen wenn du hm-rpc Adapter komplet löschst. "admin"->"Adapter"->löschen.
                      Kontrolliere bitte, dass in der Lasche "Objekte" kein Gerät/Kanal danach für hm-rpc zu sehen ist.
                      Falls, doch was da, dann lösche es manuell (da gibt es Knopf).
                      Danach installiere hm-rpc erneut. `
                      Danke Bluefox!
                      Das hat super funktioniert!
                      Konntest Du das dem Log entnehmen oder wäre das in dem Fall die gängige Vorgehensweise?
                      • BluefoxB
                        #69
                        @ruhr70:
                        Konntest Du das dem Log entnehmen oder wäre das in dem Fall die gängige Vorgehensweise? `
                        Das habe ich schon aus dem Log gelesen und eine neue Version von js-controller gemacht habe, die das Fehler beseitigen sollte.
                        Es war ein Fehler, beim rauslöschen eines Gerätes aus ioBroker. Du hast vermutlich neulich ein Gerät aus CCU entfernt und ioBroker wollte sich auch synchronisieren (Gerät löschen) und das ging nicht. Das war alles im Log. ;)
                        • ruhr70R
                          ruhr70R
                          ruhr70
                          #70
                          Ja, stimmt. Das Problem trat auf, nachdem ich ein Gerät in der CCU entfernt hatte. Danke!
                          84.2k
