  4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
547 Beiträge 97 Kommentatoren 276.1k Aufrufe 20 Beobachtet
  • A
    A
    Apropo
    #293
    Heute 2 neue Gosund SP111 in Betrieb genommen:
    2019-01-01 17:19:23.457  - [32minfo[39m: tuya.0 new Shema added for product type eyEYwtdx9VhexxLW. Please send next line from logfile on disk to developer!
    2019-01-01 17:19:23.458  - [32minfo[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power3\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"延迟\",\"property\":{\"unit\":\"秒\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":2,\"type\":\"obj\",\"passive\":true,\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"add_ele\",\"name\":\"电量\",\"property\":{\"unit\":\"度\",\"min\":0,\"max\":500000,\"scale\":3,\"step\":100,\"type\":\"value\"},\"id\":3,\"type\":\"obj\",\"desc\":\"上报的为放大100倍之后的值,即上报56,实际值为0.56度\"},{\"mode\":\"ro\",\"code\":\"cur_current\",\"name\":\"电流\",\"property\":{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_power\",\"name\":\"功率\",\"property\":{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"ro\",\"code\":\"cur_voltage\",\"name\":\"电压\",\"property\":{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":6,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"LED\",\"name\":\"LED控制\",\"property\":{\"type\":\"bool\"},\"id\":7,\"type\":\"obj\",\"desc\":\"设备输出时可通过此控件控制红灯亮灭\"}]","schemaExt":"[{\"id\":1,\"inputType\":\" \"},{\"id\":2,\"inputType\":\" \"},{\"id\":7,\"inputType\":\" \"}]"}
    • S
      S
      SMARTY.ML
      #294
      kurze Frage vorm bestellen, laufen nachfolgende über diesen Adapter einwandfrei ohne Cloudanbinung?
      https://www.amazon.de/Steckdose-Stromve … alexa&th=1
      • A
        A
        Apropo
        #295
        Kurze Antwort : Ja
        • N
          N
          Nobody28
          #296
          Hier noch zwei neue Schematas ==>
          tuya.0	2019-01-11 19:58:35.565	info	{"schema":"[{\"mode\":\"rw\",\"code\":\"switch_1\",\"name\":\"开关1\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\"
          tuya.0	2019-01-11 19:58:35.565	info	new Shema added for product type VV8ZfLV6G2jY56Lx. Please send next line from logfile on disk to developer!
          tuya.0	2019-01-11 19:58:35.564	info	{"schema":"[{\"mode\":\"rw\",\"code\":\"switch_on\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\"
          tuya.0	2019-01-11 19:58:35.563	info	new Shema added for product type lFJaFOExN8tbpDDC. Please send next line from logfile on disk to developer!
          • apollon77A
            apollon77A
            #297
            Bitte am besten als GitHub issue aber ungekürzt aus dem log von platte
            Gesendet vom Handy …
            • N
              N
              Nobody28
              #298
              Wo liegen die da bitte? Und finde ich auch das erste Schema, was ich gepostet hatte noch?
              • sigi234S
                sigi234S
                #299
                Logfiles auf Platte /opt/iobroker/log/
                • N
                  N
                  Nobody28
                  #300
                  Das erste Schema kann ich leider da nicht finden.
                  Das andere habe ich Dir im Git gepostet ==>
                  https://github.com/Apollon77/ioBroker.tuya/issues/15
                  Danke Dir :)
                  • H
                    H
                    hansl100
                    #301
                    Hallo zusammen, ich würde gerne den neuen Adapter benutzen aber ich habe damit Probleme.
                    Nach der Adapterinstallation werden auch unter Objekte meine Geräte aufgelistet, sind natürlich nicht steuerbar.
                    Wenn ich danach den Qr Code scanne und das Zertifikat auf dem Handy installiere für WLAN sehe ich es nicht unter den Sicherheitszertifikaten. Nur wenn ich es für VPN/APP installiere sehe ich es unter Benutzerdefiniert. Wenn ich dann meine Smart Live APP starte passiert nichts undder Proxy läuft bis ich ihn abschalte. Irgendwie ist in den letzten Schritten ein Fehler von mir drin den ich nicht erkenne.
                    Evtl. sieht den jemand und kann mir auf die Sprünge helfen. Habe es mit einem Adroid 6 und 7 Handy versucht.
                    Danke und Gruß
                    Hansl
                    • H
                      H
                      hansl100
                      #302
                      Als Nachtrag hier noch das LOG von der Adapter Installation bis zum ersten Start der Smart Live APP:
                      tuya.0 2019-01-12 23:04:09.282 info Anyproxy ready to receive requests
                      tuya.0 2019-01-12 23:03:11.468 info 04200218ecfabc93b538: No schema exists, init basic states …
                      tuya.0 2019-01-12 23:03:11.454 info 04200218ecfabc93b538: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:11.451 info 04200218ecfabc93b538 Init with IP=192.168.123.71, Key=undefined
                      tuya.0 2019-01-12 23:03:11.357 info 01200559ecfabc05cc3c: No schema exists, init basic states ...
                      tuya.0 2019-01-12 23:03:11.339 info 01200559ecfabc05cc3c: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:11.336 info 01200559ecfabc05cc3c Init with IP=192.168.123.37, Key=undefined
                      tuya.0 2019-01-12 23:03:11.064 info 01200559ecfabc05cc3a: No schema exists, init basic states ...
                      tuya.0 2019-01-12 23:03:11.038 info 01200559ecfabc05cc3a: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:11.035 info 01200559ecfabc05cc3a Init with IP=192.168.123.85, Key=undefined
                      tuya.0 2019-01-12 23:03:10.889 info 01200559ecfabc05cc49: No schema exists, init basic states ...
                      tuya.0 2019-01-12 23:03:10.874 info 01200559ecfabc05cc49: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:10.871 info 01200559ecfabc05cc49 Init with IP=192.168.123.63, Key=undefined
                      tuya.0 2019-01-12 23:03:10.588 info 83318041bcddc2ee6de9: No schema exists, init basic states ...
                      tuya.0 2019-01-12 23:03:10.575 info 83318041bcddc2ee6de9: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:10.572 info 83318041bcddc2ee6de9 Init with IP=192.168.123.87, Key=undefined
                      tuya.0 2019-01-12 23:03:10.038 info 012005596001946651db: No schema exists, init basic states ...
                      tuya.0 2019-01-12 23:03:10.023 info 012005596001946651db: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:10.021 info 012005596001946651db Init with IP=192.168.123.47, Key=undefined
                      tuya.0 2019-01-12 23:03:09.890 info 012005592c3ae843d92b: No schema exists, init basic states ...
                      tuya.0 2019-01-12 23:03:09.871 info 012005592c3ae843d92b: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:09.868 info 012005592c3ae843d92b Init with IP=192.168.123.39, Key=undefined
                      tuya.0 2019-01-12 23:03:09.794 info 02200057ecfabc8b7a5d: No schema exists, init basic states ...
                      tuya.0 2019-01-12 23:03:09.767 info 02200057ecfabc8b7a5d: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:09.764 info 02200057ecfabc8b7a5d Init with IP=192.168.123.80, Key=undefined
                      tuya.0 2019-01-12 23:03:09.686 info 012005592c3ae8433807: No schema exists, init basic states ...
                      tuya.0 2019-01-12 23:03:09.642 info 0220012668c63aa81e70: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:09.638 info 0220012668c63aa81e70 Init with IP=192.168.123.84, Key=undefined
                      tuya.0 2019-01-12 23:03:09.634 info 012005592c3ae8433807: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                      tuya.0 2019-01-12 23:03:09.600 info 012005592c3ae8433807 Init with IP=192.168.123.62, Key=undefined
                      tuya.0 2019-01-12 23:03:09.353 info Discover for local Tuya devices on port 6666
                      tuya.0 2019-01-12 23:03:09.328 info Existing devices initialized
                      tuya.0 2019-01-12 23:03:09.270 info starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.14.0
                      tuya.0 2019-01-12 23:03:09.065 info States connected to redis: 127.0.0.1:6379
                      tuya.0 2019-01-12 23:03:08.875 error no connection to objects DB
                      Beginnt das Problem schon bei dr Adapterinstallation mit dieser Logzeile??
                      • apollon77A
                        apollon77A
                        #303
                        Nein der Fehler ist ok beim Start, da ging es nicht schnell genug.
                        Naja Du musst den Proxy Sync machen. Ggf hier schauen https://github.com/Apollon77/ioBroker.t … r/PROXY.md
                        • A
                          A
                          Apropo
                          #304
                          Hast du denn auch den Proxy in deinen WLAN Einstellungen eingetragen? Davon hast du zumindest nichts geschrieben
                          • H
                            H
                            hansl100
                            #305
                            Hallo und danke für deine Antwort.
                            Ich habe den QR Code mit dem Handy gescannt,die Datei runtergeladen und nach Anleitung mit der Einstellung "WLAN" installiert.
                            Danach die Smart Live APP geöffnet und gewartet das sich der Proxy ausschaltet. Aberdas Fenster mit dem QR Code ist offen geblieben.
                            Habe ich da noch etwas übersehen?
                            Hansl
                            • A
                              A
                              Apropo
                              #306
                              Wenn ich dich richtig verstehe hast du nur das Zertifikat installiert. Du musst aber auch noch in den Wlan Einstellungen bei Proxy die IP deines IoBroker und den Port eingeben.
                              • H
                                H
                                hansl100
                                #307
                                Könntest du mir da helfn?
                                Hab eben das versucht,komme aber nicht weiter.
                                Habe in den erweiterten Netzwekeinstellungen für mein wlan folgende Einstellmöglichkeiten:
                                DHCP
                                Proxy=ohne
                                Dann wenn ich Proxy auf manuell stelle:
                                Proxy Hostname
                                Proxy Port
                                Proxy umgehen
                                Wo müsste ich das was eintrsgen?
                                Mein Handy ist ein samsung J5 mit Android 7
                                • A
                                  A
                                  Apropo
                                  #308
                                  Bei Proxy Hostname muss die IP von deinem IoBroker rein und der Port ist 8888 wenn du ihn nicht geändert hast. Das wars dann eigentlich auch schon. Danach sollte es eigentlich funktionieren wenn du die App öffnest. Also das Fenster mit dem QR Code sollte sich automatisch schließen.
                                  • K
                                    K
                                    Kilik
                                    #309
                                    OWSOO RGBW Controller
                                    https://www.amazon.de/dp/B0792ZYXTS/?coliid=IF6WBA4G45X4Y&colid=2QZIWWQH4LRD1&psc=0&ref_=lv_ov_lig_dp_it
                                    {"schema":"[{"mode":"rw","code":"switch_on","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power3","id":1,"type":"obj","desc":""},{"mode":"rw","code"
                                    new Shema added for product type qxJSyTLEtX5WrzA9. Please send next line from logfile on disk to developer!
                                    • R
                                      R
                                      ronaldm
                                      #310
                                      Hallo, ist nun bei mir eingerichtet, die Geräte funktionieren nun auch ohne direkter Internetverbindung. Leider geht meine Lampe an und aus, aber Alexa sagt Lampe unterstützt dies nicht wenn ich versuche die Farbe zu setzen.
                                      Unterstützt der Tuya Adapter Farbe bei LEDs?
                                      Wenn ja, wie muss ich das Einstellen?
                                      CCU2 (7 Geräte) - Synology DS1813+ (DSM 6 + ioBroker, vis-history)
                                      • apollon77A
                                        apollon77A
                                        #311
                                        @Kilik:
                                        new Shema added for product type qxJSyTLEtX5WrzA9. Please send next line from logfile on disk to developer! `
                                        Bitte vollständig aus dem Logfile auf Platte holen, hier abgeschnitten und als GitHub issue melden. Danke
                                        • apollon77A
                                          apollon77A
                                          #312
                                          @ronaldm:
                                          Wenn ja, wie muss ich das Einstellen? `
                                          Kommt darauf an was Du so für States hast und so … zeig doch mal bzw hast Du ein Log vom Proxy-Sync mit einer Ausgabe für den Entwickler?)
                                          33.2k
                                          84.3k
